AM335x custom board kernel panic
Other Parts Discussed in Thread: AM3352
We have designed custom board using AM3352.
Board configuration is as follows:
1. AM3352
2. Spansion NOR flash 256MB
3. DDR 256MB
4. Linux 3.2.0 form ti-sdk-am335x-evm-06.00.00.00.
5. UBIFS file system
6. Watchdog 3 min timeout
U-Boot 2013.10 (Apr 24 2015 - 15:17:49)
I2C:   ready
DRAM:  256 MiB
WARNING: Caches not enabled
Flash: ERROR: too many flash sectors
[CKR] flash_real_protect() - something tried to protect - but disregarded. Sector#: 0
[CKR] flash_real_protect() - something tried to protect - but disregarded. Sector#: 1
[CKR] flash_real_protect() - something tried to protect - but disregarded. Sector#: 2
[CKR] flash_real_protect() - something tried to protect - but disregarded. Sector#: 4
256 MiB
MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
Net:   dev->name cpsw  devname cpsw
Hit any key to stop autoboot:  0
Card did not respond to voltage select!
mmc0(part 0) is current device
Un-Protect Flash Bank # 1
................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................ done
..... done
Un-Protected 5 sectors
... done
Un-Protected 3 sectors
. done
Un-Protected 1 sectors
starting script
Boot the Current Kernel - first time
Saving Environment to Flash...
Protect off 08080000 ... 0809FFFF
. done
Erasing Flash...
. done
Erased 1 sectors
Writing to Flash... done
..... done
## Booting kernel from Legacy Image at 080a0000 ...
   Image Name:   Linux-3.2.0
   Image Type:   ARM Linux Kernel Image (uncompressed)
   Data Size:    3126248 Bytes = 3 MiB
   Load Address: 80008000
   Entry Point:  80008000
   Verifying Checksum ... OK
   Loading Kernel Image ... OK
Starting kernel ...
[    0.000000] Linux version 3.2.0 (mitydsp@mitydsp-dev) (gcc version 4.7.3 20130226 (prerelease) (crosstool-NG linaro-1.13.1-4.7-2013.03-20130313 - Linaro GCC 2013.03) ) #286 Wed Apr 22 10:11:00 EDT 2015
[    0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] Machine: vanguard_370d
[    0.000000] Memory policy: ECC disabled, Data cache writeback
[    0.000000] AM335X ES2.1 (neon )
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 65024
[    0.000000] Kernel command line: console=ttyO0,115200n8 rootwait=1 rw ubi.mtd=5 rootfstype=ubifs root=ubi0:rootfs init=/init
[    0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[    0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[    0.000000] Memory: 256MB = 256MB total
[    0.000000] Memory: 253388k/253388k available, 8756k reserved, 0K highmem
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xfff00000 - 0xfffe0000   ( 896 kB)
[    0.000000]     vmalloc : 0xd0800000 - 0xff000000   ( 744 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xd0000000   ( 256 MB)
[    0.000000]     modules : 0xbf000000 - 0xc0000000   (  16 MB)
[    0.000000]       .text : 0xc0008000 - 0xc057f000   (5596 kB)
[    0.000000]       .init : 0xc057f000 - 0xc05b3000   ( 208 kB)
[    0.000000]       .data : 0xc05b4000 - 0xc0622c10   ( 444 kB)
[    0.000000]        .bss : 0xc0622c34 - 0xc0650ae8   ( 184 kB)
[    0.000000] NR_IRQS:396
[    0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[    0.000000] Total of 128 interrupts on 1 active controller
[    0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[    0.000000] omap_dm_timer_switch_src: Switching to HW default clocksource(sys_clkin_ck) for timer1, this may impact timekeeping in low power state
[    0.000000] OMAP clocksource: GPTIMER1 at 24000000 Hz
[    0.000000] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 178956ms
[    0.000000] Console: colour dummy device 80x30
[    0.000197] Calibrating delay loop... 531.66 BogoMIPS (lpj=2658304)
[    0.046644] pid_max: default: 32768 minimum: 301
[    0.046761] Security Framework initialized
[    0.046860] Mount-cache hash table entries: 512
[    0.047233] CPU: Testing write buffer coherency: ok
[    0.047984] devtmpfs: initialized
[    0.066907] omap_hwmod: gfx: failed to hardreset
[    0.082777] omap_hwmod: pruss: failed to hardreset
[    0.083892] print_constraints: dummy:
[    0.084245] NET: Registered protocol family 16
[    0.086311] OMAP GPIO hardware version 0.1
[    0.088394] omap_mux_init: Add partition: #1: core, flags: 0
[    0.090174]  omap_hsmmc.0: alias fck already exists
[    0.090497]  omap_i2c.1: alias fck already exists
[    0.090743]  omap_i2c.2: alias fck already exists
[    3.118395]  edma.0: alias fck already exists
[    3.118418]  edma.0: alias fck already exists
[    3.118435]  edma.0: alias fck already exists
[    3.143981] bio: create slab <bio-0> at 0
[    3.145955] SCSI subsystem initialized
[    3.146596] usbcore: registered new interface driver usbfs
[    3.146903] usbcore: registered new interface driver hub
[    3.147101] usbcore: registered new device driver usb
[    3.147446] registerd cppi-dma Intr @ IRQ 17
[    3.147460] Cppi41 Init Done Qmgr-base(d0872000) dma-base(d0870000)
[    3.147469] Cppi41 Init Done
[    3.147496] musb-ti81xx musb-ti81xx: musb0, board_mode=0x11, plat_mode=0x1
[    3.147797] musb-ti81xx musb-ti81xx: musb1, board_mode=0x11, plat_mode=0x1
[    3.166658] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[    3.186642] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[    3.188971] cfg80211: Calling CRDA to update world regulatory domain
[    3.190086] Switching to clocksource gp timer
[    3.206664] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[    3.206864] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
[    3.207177] MUSB0 controller's USBSS revision = 4ea20800
[    3.207211] musb0: Enabled SW babble control
[    3.207692] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[    3.207805] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
[    3.207936] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[    3.207950] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.207963] usb usb1: Product: MUSB HDRC host driver
[    3.207972] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
[    3.207982] usb usb1: SerialNumber: musb-hdrc.0
[    3.208900] hub 1-0:1.0: USB hub found
[    3.208932] hub 1-0:1.0: 1 port detected
[    3.209525] musb-hdrc musb-hdrc.0: USB Host mode controller at d084c000 using DMA, IRQ 18
[    3.209708] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
[    3.210024] MUSB1 controller's USBSS revision = 4ea20800
[    3.210053] musb1: Enabled SW babble control
[    3.210569] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[    3.210617] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
[    3.210713] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[    3.210727] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    3.210738] usb usb2: Product: MUSB HDRC host driver
[    3.210747] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
[    3.210757] usb usb2: SerialNumber: musb-hdrc.1
[    3.211612] hub 2-0:1.0: USB hub found
[    3.211640] hub 2-0:1.0: 1 port detected
[    3.212228] musb-hdrc musb-hdrc.1: USB Host mode controller at d084e800 using DMA, IRQ 19
[    3.212646] NET: Registered protocol family 2
[    3.212841] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[    3.213132] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[    3.213274] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[    3.213360] TCP: Hash tables configured (established 8192 bind 8192)
[    3.213371] TCP reno registered
[    3.213383] UDP hash table entries: 256 (order: 0, 4096 bytes)
[    3.213404] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[    3.213589] NET: Registered protocol family 1
[    3.213840] RPC: Registered named UNIX socket transport module.
[    3.213853] RPC: Registered udp transport module.
[    3.213860] RPC: Registered tcp transport module.
[    3.213868] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    3.213950] NetWinder Floating Point Emulator V0.97 (double precision)
[    3.225485] VFS: Disk quotas dquot_6.5.2
[    3.225549] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[    3.226062] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
[    3.226292] msgmni has been set to 494
[    3.229340] alg: No test for stdrng (krng)
[    3.230178] io scheduler noop registered
[    3.230194] io scheduler deadline registered
[    3.230270] io scheduler cfq registered (default)
[    3.231215] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
[    3.232932] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[    3.895504] console [ttyO0] enabled
[    3.899845] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[    3.907719] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[    3.915550] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[    3.923368] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[    3.931201] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[    3.939505] omap4_rng omap4_rng: OMAP4 Random Number Generator ver. 2.00
[    3.955816] brd: module loaded
[    3.964106] loop: module loaded
[    3.969541] mtdoops: mtd device (mtddev=name/number) must be supplied
[    3.976410] physmap platform flash device: 10000000 at 10000000
[    3.988054] Number of erase regions: 1
[    3.992001] Primary Vendor Command Set: 0002 (AMD/Fujitsu Standard)
[    3.998540] Primary Algorithm Table at 0040
[    4.002914] Alternative Vendor Command Set: 0000 (None)
[    4.008363] No Alternate Algorithm Table
[    4.012460] Vcc Minimum:  2.7 V
[    4.015733] Vcc Maximum:  3.6 V
[    4.019004] No Vpp line
[    4.021558] Typical byte/word write timeout: 256 µs
[    4.026735] Maximum byte/word write timeout: 512 µs
[    4.031920] Typical full buffer write timeout: 512 µs
[    4.037279] Maximum full buffer write timeout: 2048 µs
[    4.042745] Typical block erase timeout: 256 ms
[    4.047469] Maximum block erase timeout: 2048 ms
[    4.052293] Typical chip erase timeout: 524288 ms
[    4.057198] Maximum chip erase timeout: 4194304 ms
[    4.062203] Device size: 0x10000000 bytes (256 MiB)
[    4.067290] Flash Device Interface description: 0x0001
[    4.072656]   - x16-only asynchronous interface
[    4.077379] Max. bytes in buffer write: 0x200
[    4.081928] Number of Erase Block Regions: 1
[    4.086383]   Erase Region #0: BlockSize 0x20000 bytes, 2048 blocks
[    4.092938] Correcting S70GL02GS CFI data
[    4.097123] physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x004801
[    4.107853] physmap-flash.0: Found 1 x16 devices at 0x8000000 in 16-bit bank
[    4.115233] Amd/Fujitsu Extended Query Table at 0x0040
[    4.120615]   Amd/Fujitsu Extended Query version 1.5.
[    4.125893] number of CFI chips: 2
[    4.129457] Creating 6 MTD partitions on "physmap-flash.0":
[    4.135291] 0x000000000000-0x000000080000 : "uboot"
[    4.142042] 0x000000080000-0x0000000a0000 : "uboot-env"
[    4.148801] 0x0000000a0000-0x0000005a0000 : "Current kernel"
[    4.156031] 0x0000005a0000-0x000000aa0000 : "Backup kernel"
[    4.163165] 0x000000aa0000-0x000000fa0000 : "Failsafe kernel"
[    4.170498] 0x000000fa0000-0x000010000000 : "File System"
[    4.178163] UBI: attaching mtd5 to ubi0
[    4.182226] UBI: physical eraseblock size:   131072 bytes (128 KiB)
[    4.188765] UBI: logical eraseblock size:    130944 bytes
[    4.194406] UBI: smallest flash I/O unit:    1
[    4.199041] UBI: VID header offset:          64 (aligned 64)
[    4.204951] UBI: data offset:                128
[    4.339819] UBI: max. sequence number:       513
[    4.372466] UBI: attached mtd5 to ubi0
[    4.376390] UBI: MTD device name:            "File System"
[    4.382162] UBI: MTD device size:            240 MiB
[    4.387341] UBI: number of good PEBs:        1923
[    4.392255] UBI: number of bad PEBs:         0
[    4.396888] UBI: number of corrupted PEBs:   0
[    4.401529] UBI: max. allowed volumes:       128
[    4.406344] UBI: wear-leveling threshold:    4096
[    4.411256] UBI: number of internal volumes: 1
[    4.415889] UBI: number of user volumes:     1
[    4.420529] UBI: available PEBs:             0
[    4.425162] UBI: total number of reserved PEBs: 1923
[    4.430347] UBI: number of PEBs reserved for bad PEB handling: 0
[    4.436613] UBI: max/mean erase counter: 1/0
[    4.441071] UBI: image sequence number:  1220350900
[    4.446263] UBI: background thread "ubi_bgt0d" started, PID 534
[    4.500164] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[    4.506626] davinci_mdio davinci_mdio.0: detected phy mask fffffff7
[    4.513445] am335x_KSZ9021_phy_fixup 221611 here addr = 3
[    4.519903] davinci_mdio.0: probed
[    4.523477] davinci_mdio davinci_mdio.0: phy[3]: device 0:03, driver Micrel KSZ9021 Gigabit PHY
[    4.532749] rtl8192cu driver version=v4.0.2_9000.20130911
[    4.538384] build time: Apr 22 2015 10:10:56
[    4.543030] usbcore: registered new interface driver rtl8192cu
[    4.549162] Initializing USB Mass Storage driver...
[    4.554477] usbcore: registered new interface driver usb-storage
[    4.560761] USB Mass Storage support registered.
[    4.566153] mousedev: PS/2 mouse device common for all mice
[    4.572691] i2c /dev entries driver
[    4.730682] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    4.737179] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
[    4.745888] cpuidle: using governor ladder
[    4.750636] cpuidle: using governor menu
[    4.756838] omap4_aes_mod_init: loading AM33X AES driver
[    4.762527] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02
[    4.769027] omap4_aes_probe: probe() done
[    4.773456] omap4_sham_mod_init: loading AM33X SHA/MD5 driver
[    4.779569] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03
[    4.790136] omap4_sham_probe: probe() done
[    4.796741] usbcore: registered new interface driver usbhid
[    4.802587] usbhid: USB HID core driver
[    4.807451] tiadc tiadc: attached adc driver
[    4.812081] oprofile: hardware counters not available
[    4.817354] oprofile: using timer interrupt.
[    4.821852] nf_conntrack version 0.5.0 (3959 buckets, 15836 max)
[    4.828610] ip_tables: (C) 2000-2006 Netfilter Core Team
[    4.834311] TCP cubic registered
[    4.837685] NET: Registered protocol family 17
[    4.842376] lib80211: common routines for IEEE802.11 drivers
[    4.848614] Registering the dns_resolver key type
[    4.853639] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[    4.861659] ThumbEE CPU extension supported.
[    4.866177] mux: Failed to setup hwmod io irq -22
[    4.871756] Power Management for AM33XX family
[    4.876608] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[    4.883305] Copied the M3 firmware to UMEM
[    4.887658] Cortex M3 Firmware Version = 0x181
[    4.892770] sr_init: platform driver register failed
[    4.901416] clock: disabling unused clocks to save power
[    4.911151] Detected MACID=54:4a:16:ce:9e:54
[    4.917161] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
[    5.066963] UBIFS: recovery needed
[    5.429300] UBIFS: recovery completed
[    5.433276] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
[    5.439549] UBIFS: file system size:   249972096 bytes (244113 KiB, 238 MiB, 1909 LEBs)
[    5.447921] UBIFS: journal size:       8912384 bytes (8703 KiB, 8 MiB, 69 LEBs)
[    5.455559] UBIFS: media format:       w4/r0 (latest is w4/r0)
[    5.461651] UBIFS: default compressor: lzo
[    5.465922] UBIFS: reserved for root:  0 bytes (0 KiB)
[    5.471846] VFS: Mounted root (ubifs filesystem) on device 0:14.
[    5.478616] devtmpfs: mounted
[    5.482085] Freeing init memory: 208K
[    5.486072] Failed to execute /init.  Attempting defaults...
INIT: version 2.88 booting
Error opening /dev/fb0: No such file or directory
Starting udev
[    6.328907] udev[666]: starting version 164
Starting Bootlog daemon: bootlogd: cannot allocate pseudo tty: No such file or directory
bootlogd.
ALSA: Restoring mixer settings...
Configuring network interfaces... [    9.046020] am335x_KSZ9021_phy_fixup 221611 here addr = 3
[    9.052400] net eth0: CPSW phy found : id is : 0x221611
[    9.058636] net eth0: PHY already attached
udhcpc (v1.20.2) started
Sending discover...
Sending discover...
Sending discover...
No lease, failing
done.
Wed Jun 26 00:04:00 UTC 2013
INIT: Entering runlevel: 5
/etc/init.d/rc: line 56: /etc/rc5.d/S02dbus-1: Permission denied
Starting Dropbear SSH server: dropbear.
Performing wifi calibration...
rm: can't remove '/lib/firmware/ti-connectivity/wl1271-nvs.bin': No such file or directory
rmmod: error while loading shared libraries: libkmod.so.2: cannot open shared object file: No such file or directory
Unable to open file /usr/share/ti/wifi-utils/ini_files/127x/TQS_S_2.6.ini (No such file or directory)
Failed to read ini file /usr/share/ti/wifi-utils/ini_files/127x/TQS_S_2.6.ini
Calibration not complete. Removing half-baked nvs
modprobe: error while loading shared libraries: libkmod.so.2: cannot open shared object file: No such file or directory
hwclock: can't open '/dev/misc/rtc': No such file or directory
Starting network benchmark server: netserver.
Starting syslogd/klogd: done
Starting Lighttpd Web Server: lighttpd.
I2C:   ready
DRAM:  256 MiB
256 MiB
..... done
... done
. done
starting script
. done
Erasing Flash...
. done
Erased 1 sectors
..... done
Starting kernel ...
Starting udev
bootlogd.
Sending discover...
Sending discover...
Sending discover...
No lease, failing
done.
On some of the boards in production we have observed, reboots and kernel panic in the debug log. Log and the dmesg output attached(during boot) is as below.
We are trying to find out where the issue is. Is it because of the NOR issue or DDR or the kernel. But some of the boards which are running with the same firmware are doing good with out reboots for more than 72 hours. The units rebooting are rebooting repeatedly every 15 - 45 min interval.
Any help or suggestion to identify the root cause is greatly appreciated.
[ 1432.650440] Unable to handle kernel paging request at virtual address f046003e
[ 1432.657999] Unable to handle kernel paging request at virtual address f046003e
[ 1432.665540] Unable to handle kernel paging request at virtual address f046003e
[ 1432.673079] Unable to handle kernel paging request at virtual address f046003e
[ 1432.682967] Unable to handle kernel paging request at virtual address f046003e
[ 1432.690507] Unable to handle kernel paging request at virtual address f046003e
[ 1432.698046] Unable to handle kernel paging request at virtual address f046003e
[ 1432.705586] Unable to handle kernel paging request at virtual address f046003e
[ 1435.440560] Unable to handle kernel NULL pointer dereference at virtual address 00000148
[ 1435.449232] Unable to handle kernel paging request at virtual address e24dd0b0
[ 1435.456988] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.464736] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.472480] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.480212] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.487958] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.495714] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.503457] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.511209] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.518949] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.526700] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.534460] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.542209] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.549969] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.557711] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.565460] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.573189] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.580937] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.588674] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.596425] Unable to handle kernel paging request at virtual address e59fc0a4
[ 1435.604175] Unable to handle kernel NULL pointer dereference at virtual address 000000a8
[ 1435.612831] pgd = c0004000
[ 1435.615782] [000000a8] *pgd=00000000
[ 1435.619697] Internal error: Oops: 17 [#1]
[ 1435.624056] CPU: 0 Not tainted (3.2.0 #286)
[ 1435.628997] PC is at do_bad_area+0x34/0x8c
[ 1435.633465] LR is at do_translation_fault+0x70/0xa8
[ 1435.638791] pc : [<c001a234>] lr : [<c001a2fc>] psr: 200f0193
[ 1435.638911] sp : ffdca0d0 ip : a00f0193 fp : ffdca0f4
[ 1435.651133] r10: 1a000076 r9 : 49b001ac r8 : ffdca1c8
[ 1435.656798] r7 : cf5c4000 r6 : e59fc0a4 r5 : 00000005 r4 : ffdca1c8
[ 1435.663839] r3 : 00000000 r2 : ffdca0d0 r1 : 00000005 r0 : e59fc0a4
[ 1435.670865] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment user
[ 1435.678655] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1435.684851] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1435.690863] Stack: (0xffdca0d0 to 0x00002017)
[ 1435.695549] Backtrace: invalid frame pointer 0xffdca0f4
[ 1435.701328] Code: e1a06000 e593300c e1a05001 e31c000f (e59370a8)
[ 1435.707969] ---[ end trace 39f7c14e1359982e ]---
[ 1435.712964] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1435.721630] pgd = c0004000
[ 1435.724577] [00000003] *pgd=00000000
[ 1435.728489] Internal error: Oops: 17 [#2]
[ 1435.732840] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1435.738787] PC is at do_exit+0x3c/0x648
[ 1435.742987] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1435.749046] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1435.749167] sp : ffdc9ed8 ip : 00000000 fp : ffdc9f0c
[ 1435.761390] r10: ffdc8000 r9 : c001a238 r8 : c001a236
[ 1435.767045] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1435.774088] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1435.781114] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1435.788810] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1435.795009] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1435.801028] Stack: (0xffdc9ed8 to 0x00002017)
[ 1435.805717] Backtrace: invalid frame pointer 0xffdc9f0c
[ 1435.811502] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1435.818048] ---[ end trace 39f7c14e1359982f ]---
[ 1435.823030] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1435.831691] pgd = c0004000
[ 1435.834646] [00000003] *pgd=00000000
[ 1435.838560] Internal error: Oops: 17 [#3]
[ 1435.842914] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1435.848845] PC is at do_exit+0x3c/0x648
[ 1435.853037] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1435.859081] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1435.859198] sp : ffdc9ce0 ip : 00000000 fp : ffdc9d14
[ 1435.871415] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1435.877063] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1435.884097] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1435.891123] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1435.898809] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1435.905007] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1435.911019] Stack: (0xffdc9ce0 to 0x00002017)
[ 1435.915697] Backtrace: invalid frame pointer 0xffdc9d14
[ 1435.921479] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1435.928029] ---[ end trace 39f7c14e13599830 ]---
[ 1435.933017] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1435.941662] pgd = c0004000
[ 1435.944616] [00000003] *pgd=00000000
[ 1435.948532] Internal error: Oops: 17 [#4]
[ 1435.952884] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1435.958816] PC is at do_exit+0x3c/0x648
[ 1435.963008] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1435.969059] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1435.969176] sp : ffdc9ae8 ip : 00000000 fp : ffdc9b1c
[ 1435.981399] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1435.987048] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1435.994081] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.001103] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.008796] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1436.014985] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1436.020988] Stack: (0xffdc9ae8 to 0x00002017)
[ 1436.025671] Backtrace: invalid frame pointer 0xffdc9b1c
[ 1436.031450] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1436.037993] ---[ end trace 39f7c14e13599831 ]---
[ 1436.042979] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1436.051639] pgd = c0004000
[ 1436.054590] [00000003] *pgd=00000000
[ 1436.058497] Internal error: Oops: 17 [#5]
[ 1436.062843] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1436.068772] PC is at do_exit+0x3c/0x648
[ 1436.072964] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1436.079020] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1436.079136] sp : ffdc98f0 ip : 00000000 fp : ffdc9924
[ 1436.091362] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1436.097016] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1436.104061] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.111088] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.118777] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1436.124972] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1436.130981] Stack: (0xffdc98f0 to 0x00002017)
[ 1436.135664] Backtrace: invalid frame pointer 0xffdc9924
[ 1436.141439] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1436.147985] ---[ end trace 39f7c14e13599832 ]---
[ 1436.152972] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1436.161632] pgd = c0004000
[ 1436.164587] [00000003] *pgd=00000000
[ 1436.168500] Internal error: Oops: 17 [#6]
[ 1436.172856] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1436.178785] PC is at do_exit+0x3c/0x648
[ 1436.182984] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1436.189043] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1436.189160] sp : ffdc96f8 ip : 00000000 fp : ffdc972c
[ 1436.201378] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1436.207032] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1436.214067] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.221099] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.228789] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1436.234989] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1436.240999] Stack: (0xffdc96f8 to 0x00002017)
[ 1436.245678] Backtrace: invalid frame pointer 0xffdc972c
[ 1436.251465] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1436.258011] ---[ end trace 39f7c14e13599833 ]---
[ 1436.263001] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1436.271654] pgd = c0004000
[ 1436.274611] [00000003] *pgd=00000000
[ 1436.278524] Internal error: Oops: 17 [#7]
[ 1436.282872] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1436.288805] PC is at do_exit+0x3c/0x648
[ 1436.293004] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1436.299068] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1436.299186] sp : ffdc9500 ip : 00000000 fp : ffdc9534
[ 1436.311403] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1436.317057] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1436.324104] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.331134] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.338834] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1436.345033] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1436.351046] Stack: (0xffdc9500 to 0x00002017)
[ 1436.355724] Backtrace: invalid frame pointer 0xffdc9534
[ 1436.361505] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1436.368052] ---[ end trace 39f7c14e13599834 ]---
[ 1436.373036] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1436.381690] pgd = c0004000
[ 1436.384634] [00000003] *pgd=00000000
[ 1436.388532] Internal error: Oops: 17 [#8]
[ 1436.392884] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1436.398823] PC is at do_exit+0x3c/0x648
[ 1436.403016] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1436.409081] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1436.409201] sp : ffdc9308 ip : 00000000 fp : ffdc933c
[ 1436.421439] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1436.427093] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1436.434134] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.441163] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.448869] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1436.455069] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1436.461082] Stack: (0xffdc9308 to 0x00002017)
[ 1436.465762] Backtrace: invalid frame pointer 0xffdc933c
[ 1436.471539] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1436.478092] ---[ end trace 39f7c14e13599835 ]---
[ 1436.483080] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1436.491741] pgd = c0004000
[ 1436.494694] [00000003] *pgd=00000000
[ 1436.498605] Internal error: Oops: 17 [#9]
[ 1436.502955] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1436.508886] PC is at do_exit+0x3c/0x648
[ 1436.513087] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1436.519151] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1436.519270] sp : ffdc9110 ip : 00000000 fp : ffdc9144
[ 1436.531497] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1436.537147] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1436.544186] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.551219] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.558911] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1436.565105] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1436.571118] Stack: (0xffdc9110 to 0x00002017)
[ 1436.575794] Backtrace: invalid frame pointer 0xffdc9144
[ 1436.581576] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1436.588128] ---[ end trace 39f7c14e13599836 ]---
[ 1436.593112] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1436.601774] pgd = c0004000
[ 1436.604726] [00000003] *pgd=00000000
[ 1436.608636] Internal error: Oops: 17 [#10]
[ 1436.613083] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1436.619022] PC is at do_exit+0x3c/0x648
[ 1436.623215] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1436.629279] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1436.629401] sp : ffdc8f18 ip : 00000000 fp : ffdc8f4c
[ 1436.641638] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1436.647300] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1436.654347] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.661380] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.669077] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1436.675275] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1436.681290] Stack: (0xffdc8f18 to 0x00002017)
[ 1436.685965] Backtrace: invalid frame pointer 0xffdc8f4c
[ 1436.691746] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1436.698296] ---[ end trace 39f7c14e13599837 ]---
[ 1436.703286] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1436.711956] pgd = c0004000
[ 1436.714910] [00000003] *pgd=00000000
[ 1436.718821] Internal error: Oops: 17 [#11]
[ 1436.723260] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1436.729189] PC is at do_exit+0x3c/0x648
[ 1436.733382] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1436.739443] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1436.739560] sp : ffdc8d20 ip : 00000000 fp : ffdc8d54
[ 1436.751777] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1436.757434] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1436.764475] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.771498] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.779199] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1436.785393] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1436.791407] Stack: (0xffdc8d20 to 0x00002017)
[ 1436.796091] Backtrace: invalid frame pointer 0xffdc8d54
[ 1436.801871] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1436.808420] ---[ end trace 39f7c14e13599838 ]---
[ 1436.813411] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1436.822075] pgd = c0004000
[ 1436.825030] [00000003] *pgd=00000000
[ 1436.828937] Internal error: Oops: 17 [#12]
[ 1436.833384] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1436.839313] PC is at do_exit+0x3c/0x648
[ 1436.843505] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1436.849559] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1436.849676] sp : ffdc8b28 ip : 00000000 fp : ffdc8b5c
[ 1436.861903] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1436.867557] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1436.874596] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.881622] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.889318] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1436.895516] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1436.901531] Stack: (0xffdc8b28 to 0x00002017)
[ 1436.906217] Backtrace: invalid frame pointer 0xffdc8b5c
[ 1436.912003] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1436.918552] ---[ end trace 39f7c14e13599839 ]---
[ 1436.923544] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1436.932202] pgd = c0004000
[ 1436.935160] [00000003] *pgd=00000000
[ 1436.939069] Internal error: Oops: 17 [#13]
[ 1436.943513] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1436.949448] PC is at do_exit+0x3c/0x648
[ 1436.953641] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1436.959704] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1436.959821] sp : ffdc8930 ip : 00000000 fp : ffdc8964
[ 1436.972050] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1436.977707] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1436.984748] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1436.991775] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1436.999468] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1437.005666] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1437.011670] Stack: (0xffdc8930 to 0x00002017)
[ 1437.016353] Backtrace: invalid frame pointer 0xffdc8964
[ 1437.022129] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1437.028672] ---[ end trace 39f7c14e1359983a ]---
[ 1437.033656] Unable to handle kernel NULL pointer dereference at virtual address 00000003
[ 1437.042305] pgd = c0004000
[ 1437.045253] [00000003] *pgd=00000000
[ 1437.049163] Internal error: Oops: 17 [#14]
[ 1437.053604] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1437.059536] PC is at do_exit+0x3c/0x648
[ 1437.063725] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1437.069777] pc : [<c003f808>] lr : [<c0059684>] psr: a00f0113
[ 1437.069892] sp : ffdc8738 ip : 00000000 fp : ffdc876c
[ 1437.082115] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1437.087770] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1437.094803] r3 : ffffffff r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1437.101829] Flags: NzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1437.109523] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1437.115716] Process  À (pid: 0, stack limit = 0xffdc82f0)
[ 1437.121722] Stack: (0xffdc8738 to 0x00002017)
[ 1437.126396] Backtrace: invalid frame pointer 0xffdc876c
[ 1437.132178] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1437.138728] ---[ end trace 39f7c14e1359983b ]---
[ 1437.143721] Unable to handle kernel NULL pointer dereference at virtual address 0000000a
[ 1437.152382] pgd = c0004000
[ 1437.155339] [0000000a] *pgd=00000000
[ 1437.159252] Internal error: Oops: 17 [#15]
[ 1437.163694] CPU: 0 Tainted: G D (3.2.0 #286)
[ 1437.169632] PC is at do_exit+0x3c/0x648
[ 1437.173832] LR is at blocking_notifier_call_chain+0x20/0x28
[ 1437.179900] pc : [<c003f808>] lr : [<c0059684>] psr: 200f0113
[ 1437.180018] sp : ffdc8540 ip : 00000000 fp : ffdc8574
[ 1437.192252] r10: ffdc8000 r9 : c003f80c r8 : c003f80a
[ 1437.197912] r7 : 00000001 r6 : ffdc8000 r5 : 00000000 r4 : 0000000b
[ 1437.204944] r3 : 00000006 r2 : ffdc8000 r1 : 00000000 r0 : 00000000
[ 1437.211976] Flags: nzCv IRQs on FIQs on Mode SVC_32 ISA ARM Segment user
[ 1437.219671] Control: 10c5387d Table: 8f5c4019 DAC: 00000015
[ 1437.225873] Process A (pid: -1071488416, stack limit = 0xffdc82f0)
[ 1437.232528] Stack: (0xffdc8540 to 0xffdca185)
[ 1437.237408] 8540: 00000000 ffdc85ba ffdc8000 c003f80a c003f80c ffdc8000 ffdc8574 ffdc8568
[ 1437.246341] 8560: c003c7d4 00000001 ffdc85ec ffdc8578 c0017e60 c003f7d8 ffdc82f0 0000000b
[ 1437.255276] 8580: 100f0193 00000008 65dc86f0 37303062 20356131 36393565 34343233 35336520
[ 1437.264213] 85a0: 30303033 61302030 30303030 28203630 33393565 34303031 c0002029 c04601a4
[ 1437.273145] 85c0: c051a9c4 00000003 00000017 00000000 ffdc86f0 00000003 c003f80c ffdc8000
[ 1437.282073] 85e0: ffdc8604 ffdc85f0 c045fe9c c0017d50 ffdc86f0 ffdc8000 ffdc863c ffdc8608
[ 1437.291006] 8600: c001a1f0 c045fe4c ffdc863c ffdc8618 c003c90c 00000017 c001a008 c05ba364
[ 1437.299932] 8620: 00000003 ffdc86f0 c003f80c ffdc8000 ffdc86ec ffdc8640 c00083b0 c001a014
[ 1437.308861] 8640: 00000000 00008844 ffdc868c ffdc8658 c003cf74 c00591f4 00008844 00000000
[ 1437.317788] 8660: c01e9780 ffdc86d4 ffdc86d4 00000003 0000003a c05d4e04 0000000f c0625da1
[ 1437.326716] 8680: ffdc8724 ffdc8690 c003d324 c003ce18 0000004b c0625d7a a0eae254 000000b3
[ 1437.335646] 86a0: 95956376 0000014e ffdc86c6 600f0113 10624dd3 c0625d7a a0b549cc 000000b3
[ 1437.344572] 86c0: 00000004 205b014e 37333431 c003f808 a00f0113 ffffffff ffdc8724 c003f80a
[ 1437.353501] 86e0: ffdc876c ffdc86f0 c0014158 c0008380 00000000 00000000 ffdc8000 ffffffff
[ 1437.362432] 8700: 0000000b 00000000 ffdc8000 00000001 c003f80a c003f80c ffdc8000 ffdc876c
[ 1437.371364] 8720: 00000000 ffdc8738 c0059684 c003f808 a00f0113 ffffffff 00000000 ffdc87b2
[ 1437.380293] 8740: ffdc8000 c003f80a c003f80c ffdc8000 ffdc876c ffdc8760 c003c7d4 00000001
[ 1437.389224] 8760: ffdc87e4 ffdc8770 c0017e60 c003f7d8 ffdc82f0 0000000b 100f0193 00000008
[ 1437.398161] 8780: 65dc88e8 37303062 20356131 36393565 34343233 35336520 30303033 61302030
[ 1437.407091] 87a0: 30303030 28203630 33393565 34303031 c0002029 c04601a4 c051a9c4 00000003
[ 1437.416011] 87c0: 00000017 00000000 ffdc88e8 00000003 c003f80c ffdc8000 ffdc87fc ffdc87e8
[ 1437.424946] 87e0: c045fe9c c0017d50 ffdc88e8 ffdc8000 ffdc8834 ffdc8800 c001a1f0 c045fe4c
[ 1437.433873] 8800: ffdc8834 ffdc8810 c003c90c 00000017 c001a008 c05ba364 00000003 ffdc88e8
[ 1437.442801] 8820: c003f80c ffdc8000 ffdc88e4 ffdc8838 c00083b0 c001a014 00000000 0000838c
[ 1437.451727] 8840: ffdc8884 ffdc8850 c003cf74 c00591f4 0000838c 00000000 c01e9780 ffdc88cc
[ 1437.460661] 8860: ffdc88cc 00000003 0000003a c05d4e04 0000000f c0625da1 ffdc891c ffdc8888
[ 1437.469586] 8880: c003d324 c003ce18 0000004b c0625d7a 9d64c836 000000b3 8f0517b3 0000014e
[ 1437.478516] 88a0: ffdc88be 600f0113 10624dd3 c0625d7a 9d2f2100 000000b3 00000004 205b014e
[ 1437.487454] 88c0: 36333431 c003f808 a00f0113 ffffffff ffdc891c c003f80a ffdc8964 ffdc88e8
[ 1437.496380] 88e0: c0014158 c0008380 00000000 00000000 ffdc8000 ffffffff 0000000b 00000000
[ 1437.505313] 8900: ffdc8000 00000001 c003f80a c003f80c ffdc8000 ffdc8964 00000000 ffdc8930
[ 1437.514244] 8920: c0059684 c003f808 a00f0113 ffffffff 00000000 ffdc89aa ffdc8000 c003f80a
[ 1437.523176] 8940: c003f80c ffdc8000 ffdc8964 ffdc8958 c003c7d4 00000001 ffdc89dc ffdc8968
[ 1437.532105] 8960: c0017e60 c003f7d8 ffdc82f0 0000000b 100f0193 00000008 65dc8ae0 37303062
[ 1437.541040] 8980: 20356131 36393565 34343233 35336520 30303033 61302030 30303030 28203630
[ 1437.549971] 89a0: 33393565 34303031 c0002029 c04601a4 c051a9c4 00000003 00000017 00000000
[ 1437.558900] 89c0: ffdc8ae0 00000003 c003f80c ffdc8000 ffdc89f4 ffdc89e0 c045fe9c c0017d50
[ 1437.567828] 89e0: ffdc8ae0 ffdc8000 ffdc8a2c ffdc89f8 c001a1f0 c045fe4c ffdc8a2c ffdc8a08
[ 1437.576768] 8a00: c003c90c 00000017 c001a008 c05ba364 00000003 ffdc8ae0 c003f80c ffdc8000
[ 1437.585698] 8a20: ffdc8adc ffdc8a30 c00083b0 c001a014 00000000 00007ed4 ffdc8a7c ffdc8a48
[ 1437.594628] 8a40: c003cf74 c00591f4 00007ed4 00000000 c01e9780 ffdc8ac4 ffdc8ac4 00000003
[ 1437.603550] 8a60: 0000003a c05d4e04 0000000f c0625da1 ffdc8b14 ffdc8a80 c003d324 c003ce18
[ 1437.612479] 8a80: 0000004b c0625d7a 99de9451 000000b3 88749bed 0000014e ffdc8ab6 600f0113
[ 1437.621406] 8aa0: 10624dd3 c0625d7a 99a8eedb 000000b3 00000004 205b014e 36333431 c003f808
[ 1437.630341] 8ac0: a00f0113 ffffffff ffdc8b14 c003f80a ffdc8b5c ffdc8ae0 c0014158 c0008380
[ 1437.639265] 8ae0: 00000000 00000000 ffdc8000 ffffffff 0000000b 00000000 ffdc8000 00000001
[ 1437.648199] 8b00: c003f80a c003f80c ffdc8000 ffdc8b5c 00000000 ffdc8b28 c0059684 c003f808
[ 1437.657135] 8b20: a00f0113 ffffffff 00000000 ffdc8ba2 ffdc8000 c003f80a c003f80c ffdc8000
[ 1437.666061] 8b40: ffdc8b5c ffdc8b50 c003c7d4 00000001 ffdc8bd4 ffdc8b60 c0017e60 c003f7d8
[ 1437.674990] 8b60: ffdc82f0 0000000b 100f0193 00000008 65dc8cd8 37303062 20356131 36393565
[ 1437.683930] 8b80: 34343233 35336520 30303033 61302030 30303030 28203630 33393565 34303031
[ 1437.692863] 8ba0: c0002029 c04601a4 c051a9c4 00000003 00000017 00000000 ffdc8cd8 00000003
[ 1437.701799] 8bc0: c003f80c ffdc8000 ffdc8bec ffdc8bd8 c045fe9c c0017d50 ffdc8cd8 ffdc8000
[ 1437.710741] 8be0: ffdc8c24 ffdc8bf0 c001a1f0 c045fe4c ffdc8c24 ffdc8c00 c003c90c 00000017
[ 1437.719670] 8c00: c001a008 c05ba364 00000003 ffdc8cd8 c003f80c ffdc8000 ffdc8cd4 ffdc8c28
[ 1437.728600] 8c20: c00083b0 c001a014 00000000 00007a1c ffdc8c74 ffdc8c40 c003cf74 c00591f4
[ 1437.737533] 8c40: 00007a1c 00000000 c01e9780 ffdc8cbc ffdc8cbc 00000003 0000003a c05d4e04
[ 1437.746456] 8c60: 0000000f c0625da1 ffdc8d0c ffdc8c78 c003d324 c003ce18 0000004b c0625d7a
[ 1437.755391] 8c80: 96587257 000000b3 81e44184 0000014e ffdc8cae 600f0113 10624dd3 c0625d7a
[ 1437.764320] 8ca0: 9622c9e7 000000b3 00000004 205b014e 36333431 c003f808 a00f0113 ffffffff
[ 1437.773244] 8cc0: ffdc8d0c c003f80a ffdc8d54 ffdc8cd8 c0014158 c0008380 00000000 00000000
[ 1437.782170] 8ce0: ffdc8000 ffffffff 0000000b 00000000 ffdc8000 00000001 c003f80a c003f80c
[ 1437.791101] 8d00: ffdc8000 ffdc8d54 00000000 ffdc8d20 c0059684 c003f808 a00f0113 ffffffff
[ 1437.800032] 8d20: 00000000 ffdc8d9a ffdc8000 c003f80a c003f80c ffdc8000 ffdc8d54 ffdc8d48
[ 1437.808954] 8d40: c003c7d4 00000001 ffdc8dcc ffdc8d58 c0017e60 c003f7d8 ffdc82f0 0000000b
[ 1437.817884] 8d60: 100f0193 00000008 65dc8ed0 37303062 20356131 36393565 34343233 35336520
[ 1437.826805] 8d80: 30303033 61302030 30303030 28203630 33393565 34303031 c0002029 c04601a4
[ 1437.835735] 8da0: c051a9c4 00000003 00000017 00000000 ffdc8ed0 00000003 c003f80c ffdc8000
[ 1437.844655] 8dc0: ffdc8de4 ffdc8dd0 c045fe9c c0017d50 ffdc8ed0 ffdc8000 ffdc8e1c ffdc8de8
[ 1437.853574] 8de0: c001a1f0 c045fe4c ffdc8e1c ffdc8df8 c003c90c 00000017 c001a008 c05ba364
[ 1437.862506] 8e00: 00000003 ffdc8ed0 c003f80c ffdc8000 ffdc8ecc ffdc8e20 c00083b0 c001a014
[ 1437.871434] 8e20: 00000000 00007564 ffdc8e6c ffdc8e38 c003cf74 c00591f4 00007564 00000000
[ 1437.880364] 8e40: c01e9780 ffdc8eb4 ffdc8eb4 00000003 0000003a c05d4e04 0000000f c0625da1
[ 1437.889300] 8e60: ffdc8f04 ffdc8e70 c003d324 c003ce18 0000004b c0625d7a 92d1f335 000000b3
[ 1437.898229] 8e80: 7b53399a 0000014e ffdc8ea6 600f0113 10624dd3 c0625d7a 929c455c 000000b3
[ 1437.907157] 8ea0: 00000004 205b014e 36333431 c003f808 a00f0113 ffffffff ffdc8f04 c003f80a
[ 1437.916079] 8ec0: ffdc8f4c ffdc8ed0 c0014158 c0008380 00000000 00000000 ffdc8000 ffffffff
[ 1437.925005] 8ee0: 0000000b 00000000 ffdc8000 00000001 c003f80a c003f80c ffdc8000 ffdc8f4c
[ 1437.933933] 8f00: 00000000 ffdc8f18 c0059684 c003f808 a00f0113 ffffffff 00000000 ffdc8f92
[ 1437.942859] 8f20: ffdc8000 c003f80a c003f80c ffdc8000 ffdc8f4c ffdc8f40 c003c7d4 00000001
[ 1437.951792] 8f40: ffdc8fc4 ffdc8f50 c0017e60 c003f7d8 ffdc82f0 0000000b 100f0193 00000008
[ 1437.960726] 8f60: 65dc90c8 37303062 20356131 36393565 34343233 35336520 30303033 61302030
[ 1437.969656] 8f80: 30303030 28203630 33393565 34303031 c0002029 c04601a4 c051a9c4 00000003
[ 1437.978580] 8fa0: 00000017 00000000 ffdc90c8 00000003 c003f80c ffdc8000 ffdc8fdc ffdc8fc8
[ 1437.987516] 8fc0: c045fe9c c0017d50 ffdc90c8 ffdc8000 ffdc9014 ffdc8fe0 c001a1f0 c045fe4c
[ 1437.996444] 8fe0: ffdc9014 ffdc8ff0 c003c90c 00000017 c001a008 c05ba364 00000003 ffdc90c8
[ 1438.005372] 9000: c003f80c ffdc8000 ffdc90c4 ffdc9018 c00083b0 c001a014 00000000 000070ad
[ 1438.014299] 9020: ffdc9064 ffdc9030 c003cf74 c00591f4 000070ad 00000000 c01e9780 ffdc90ac
[ 1438.023227] 9040: ffdc90ac 00000003 0000003a c05d4e04 0000000f c0625da1 ffdc90fc ffdc9068
[ 1438.032146] 9060: c003d324 c003ce18 0000004b c0625d7a 8f4c892a 000000b3 74c435cd 0000014e
[ 1438.041065] 9080: ffdc909e 600f0113 10624dd3 c0625d7a 8f16daca 000000b3 00000004 205b014e
[ 1438.049992] 90a0: 36333431 c003f808 a00f0113 ffffffff ffdc90fc c003f80a ffdc9144 ffdc90c8
[ 1438.058910] 90c0: c0014158 c0008380 00000000 00000000 ffdc8000 ffffffff 0000000b 00000000
[ 1438.067834] 90e0: ffdc8000 00000001 c003f80a c003f80c ffdc8000 ffdc9144 00000000 ffdc9110
[ 1438.076763] 9100: c0059684 c003f808 a00f0113 ffffffff 00000000 ffdc918a ffdc8000 c003f80a
[ 1438.085694] 9120: c003f80c ffdc8000 ffdc9144 ffdc9138 c003c7d4 00000001 ffdc91bc ffdc9148
[ 1438.094611] 9140: c0017e60 c003f7d8 ffdc82f0 0000000b 100f0193 00000008 65dc92c0 37303062
[ 1438.103536] 9160: 20356131 36393565 34343233 35336520 30303033 61302030 30303030 28203630
[ 1438.112469] 9180: 33393565 34303031 c0002029 c04601a4 c051a9c4 00000003 00000017 00000000
[ 1438.121397] 91a0: ffdc92c0 00000003 c003f80c ffdc8000 ffdc91d4 ffdc91c0 c045fe9c c0017d50
[ 1438.130322] 91c0: ffdc92c0 ffdc8000 ffdc920c ffdc91d8 c001a1f0 c045fe4c ffdc920c ffdc91e8
[ 1438.139249] 91e0: c003c90c 00000017 c001a008 c05ba364 00000003 ffdc92c0 c003f80c ffdc8000
[ 1438.148170] 9200: ffdc92bc ffdc9210 c00083b0 c001a014 00000000 00006bf6 ffdc925c ffdc9228
[ 1438.157097] 9220: c003cf74 c00591f4 00006bf6 00000000 c01e9780 ffdc92a4 ffdc92a4 00000003
[ 1438.166032] 9240: 0000003a c05d4e04 0000000f c0625da1 ffdc92f4 ffdc9260 c003d324 c003ce18
[ 1438.174955] 9260: 0000004b c0625d7a 8bc715b0 000000b3 6e35206d 0000014e ffdc9296 600f0113
[ 1438.183877] 9280: 10624dd3 c0625d7a 8b9173a2 000000b3 00000004 205b014e 36333431 c003f808
[ 1438.192810] 92a0: a00f0113 ffffffff ffdc92f4 c003f80a ffdc933c ffdc92c0 c0014158 c0008380
[ 1438.201725] 92c0: 00000000 00000000 ffdc8000 ffffffff 0000000b 00000000 ffdc8000 00000001
[ 1438.210649] 92e0: c003f80a c003f80c ffdc8000 ffdc933c 00000000 ffdc9308 c0059684 c003f808
[ 1438.219581] 9300: a00f0113 ffffffff 00000000 ffdc9382 ffdc8000 c003f80a c003f80c ffdc8000
[ 1438.228517] 9320: ffdc933c ffdc9330 c003c7d4 00000001 ffdc93b4 ffdc9340 c0017e60 c003f7d8
[ 1438.237442] 9340: ffdc82f0 0000000b 100f0193 00000008 65dc94b8 37303062 20356131 36393565
[ 1438.246378] 9360: 34343233 35336520 30303033 61302030 30303030 28203630 33393565 34303031
[ 1438.255308] 9380: c0002029 c04601a4 c051a9c4 00000003 00000017 00000000 ffdc94b8 00000003
[ 1438.264244] 93a0: c003f80c ffdc8000 ffdc93cc ffdc93b8 c045fe9c c0017d50 ffdc94b8 ffdc8000
[ 1438.273180] 93c0: ffdc9404 ffdc93d0 c001a1f0 c045fe4c ffdc9404 ffdc93e0 c003c90c 00000017
[ 1438.282108] 93e0: c001a008 c05ba364 00000003 ffdc94b8 c003f80c ffdc8000 ffdc94b4 ffdc9408
[ 1438.291026] 9400: c00083b0 c001a014 00000000 0000673f ffdc9454 ffdc9420 c003cf74 c00591f4
[ 1438.299956] 9420: 0000673f 00000000 c01e9780 ffdc949c ffdc949c 00000003 0000003a c05d4e04
[ 1438.308880] 9440: 0000000f c0625da1 ffdc94ec ffdc9458 c003d324 c003ce18 0000004b c0625d7a
[ 1438.317805] 9460: 8841a1f2 000000b3 67a60a8f 0000014e ffdc948e 600f0113 10624dd3 c0625d7a
[ 1438.326738] 9480: 880c0176 000000b3 00000004 205b014e 36333431 c003f808 a00f0113 ffffffff
[ 1438.335656] 94a0: ffdc94ec c003f80a ffdc9534 ffdc94b8 c0014158 c0008380 00000000 00000000
[ 1438.344581] 94c0: ffdc8000 ffffffff 0000000b 00000000 ffdc8000 00000001 c003f80a c003f80c
[ 1438.353511] 94e0: ffdc8000 ffdc9534 00000000 ffdc9500 c0059684 c003f808 a00f0113 ffffffff
[ 1438.362433] 9500: 00000000 ffdc957a ffdc8000 c003f80a c003f80c ffdc8000 ffdc9534 ffdc9528
[ 1438.371364] 9520: c003c7d4 00000001 ffdc95ac ffdc9538 c0017e60 c003f7d8 ffdc82f0 0000000b
[ 1438.380295] 9540: 100f0193 00000008 65dc96b0 37303062 20356131 36393565 34343233 35336520
[ 1438.389228] 9560: 30303033 61302030 30303030 28203630 33393565 34303031 c0002029 c04601a4
[ 1438.398162] 9580: c051a9c4 00000003 00000017 00000000 ffdc96b0 00000003 c003f80c ffdc8000
[ 1438.407096] 95a0: ffdc95c4 ffdc95b0 c045fe9c c0017d50 ffdc96b0 ffdc8000 ffdc95fc ffdc95c8
[ 1438.416023] 95c0: c001a1f0 c045fe4c ffdc95fc ffdc95d8 c003c90c 00000017 c001a008 c05ba364
[ 1438.424958] 95e0: 00000003 ffdc96b0 c003f80c ffdc8000 ffdc96ac ffdc9600 c00083b0 c001a014
[ 1438.433893] 9600: 00000000 00006288 ffdc964c ffdc9618 c003cf74 c00591f4 00006288 00000000
[ 1438.442818] 9620: c01e9780 ffdc9694 ffdc9694 00000003 0000003a c05d4e04 0000000f c0625da1
[ 1438.451751] 9640: ffdc96e4 ffdc9650 c003d324 c003ce18 0000004b c0625d7a 84bc4c9c 000000b3
[ 1438.460675] 9660: 61172d55 0000014e ffdc9686 600f0113 10624dd3 c0625d7a 8486ac64 000000b3
[ 1438.469602] 9680: 00000004 205b014e 36333431 c003f808 a00f0113 ffffffff ffdc96e4 c003f80a
[ 1438.478530] 96a0: ffdc972c ffdc96b0 c0014158 c0008380 00000000 00000000 ffdc8000 ffffffff
[ 1438.487460] 96c0: 0000000b 00000000 ffdc8000 00000001 c003f80a c003f80c ffdc8000 ffdc972c
[ 1438.496387] 96e0: 00000000 ffdc96f8 c0059684 c003f808 a00f0113 ffffffff 00000000 ffdc9772
[ 1438.505327] 9700: ffdc8000 c003f80a c003f80c ffdc8000 ffdc972c ffdc9720 c003c7d4 00000001
[ 1438.514261] 9720: ffdc97a4 ffdc9730 c0017e60 c003f7d8 ffdc82f0 0000000b 100f0193 00000008
[ 1438.523192] 9740: 65dc98a8 37303062 20356131 36393565 34343233 35336520 30303033 61302030
[ 1438.532123] 9760: 30303030 28203630 33393565 34303031 c0002029 c04601a4 c051a9c4 00000003
[ 1438.541045] 9780: 00000017 00000000 ffdc98a8 00000003 c003f80c ffdc8000 ffdc97bc ffdc97a8
[ 1438.549966] 97a0: c045fe9c c0017d50 ffdc98a8 ffdc8000 ffdc97f4 ffdc97c0 c001a1f0 c045fe4c
[ 1438.558897] 97c0: ffdc97f4 ffdc97d0 c003c90c 00000017 c001a008 c05ba364 00000003 ffdc98a8
[ 1438.567828] 97e0: c003f80c ffdc8000 ffdc98a4 ffdc97f8 c00083b0 c001a014 00000000 00005dd1
[ 1438.576756] 9800: ffdc9844 ffdc9810 c003cf74 c00591f4 00005dd1 00000000 c01e9780 ffdc988c
[ 1438.585685] 9820: ffdc988c 00000003 0000003a c05d4e04 0000000f c0625da1 ffdc98dc ffdc9848
[ 1438.594606] 9840: c003d324 c003ce18 0000004b c0625d7a 81373d2f 000000b3 5a88d251 0000014e
[ 1438.603536] 9860: ffdc987e 600f0113 10624dd3 c0625d7a 8101a4ea 000000b3 00000004 205b014e
[ 1438.612458] 9880: 36333431 c003f808 a00f0113 ffffffff ffdc98dc c003f80a ffdc9924 ffdc98a8
[ 1438.621380] 98a0: c0014158 c0008380 00000000 00000000 ffdc8000 ffffffff 0000000b 00000000
[ 1438.630305] 98c0: ffdc8000 00000001 c003f80a c003f80c ffdc8000 ffdc9924 00000000 ffdc98f0
[ 1438.639235] 98e0: c0059684 c003f808 a00f0113 ffffffff 00000000 ffdc996a ffdc8000 c003f80a
[ 1438.648165] 9900: c003f80c ffdc8000 ffdc9924 ffdc9918 c003c7d4 00000001 ffdc999c ffdc9928
[ 1438.657092] 9920: c0017e60 c003f7d8 ffdc82f0 0000000b 100f0193 00000008 65dc9aa0 37303062
[ 1438.666030] 9940: 20356131 36393565 34343233 35336520 30303033 61302030 30303030 28203630
[ 1438.674960] 9960: 33393565 34303031 c0002029 c04601a4 c051a9c4 00000003 00000017 00000000
[ 1438.683880] 9980: ffdc9aa0 00000003 c003f80c ffdc8000 ffdc99b4 ffdc99a0 c045fe9c c0017d50
[ 1438.692808] 99a0: ffdc9aa0 ffdc8000 ffdc99ec ffdc99b8 c001a1f0 c045fe4c ffdc99ec ffdc99c8
[ 1438.701736] 99c0: c003c90c 00000017 c001a008 c05ba364 00000003 ffdc9aa0 c003f80c ffdc8000
[ 1438.710670] 99e0: ffdc9a9c ffdc99f0 c00083b0 c001a014 00000000 0000591a ffdc9a3c ffdc9a08
[ 1438.719598] 9a00: c003cf74 c00591f4 0000591a 00000000 c01e9780 ffdc9a84 ffdc9a84 00000003
[ 1438.728525] 9a20: 0000003a c05d4e04 0000000f c0625da1 ffdc9ad4 ffdc9a40 c003d324 c003ce18
[ 1438.737453] 9a40: 0000004b c0625d7a 7db26a4f 000000b3 53fae818 0000014e ffdc9a76 600f0113
[ 1438.746389] 9a60: 10624dd3 c0625d7a 7d7cc39f 000000b3 00000004 205b014e 35333431 c003f808
[ 1438.755317] 9a80: a00f0113 ffffffff ffdc9ad4 c003f80a ffdc9b1c ffdc9aa0 c0014158 c0008380
[ 1438.764244] 9aa0: 00000000 00000000 ffdc8000 ffffffff 0000000b 00000000 ffdc8000 00000001
[ 1438.773171] 9ac0: c003f80a c003f80c ffdc8000 ffdc9b1c 00000000 ffdc9ae8 c0059684 c003f808
[ 1438.782098] 9ae0: a00f0113 ffffffff 00000000 ffdc9b62 ffdc8000 c003f80a c003f80c ffdc8000
[ 1438.791031] 9b00: ffdc9b1c ffdc9b10 c003c7d4 00000001 ffdc9b94 ffdc9b20 c0017e60 c003f7d8
[ 1438.799964] 9b20: ffdc82f0 0000000b 100f0193 00000008 65dc9c98 37303062 20356131 36393565
[ 1438.808885] 9b40: 34343233 35336520 30303033 61302030 30303030 28203630 33393565 34303031
[ 1438.817803] 9b60: c0002029 c04601a4 c051a9c4 00000003 00000017 00000000 ffdc9c98 00000003
[ 1438.826732] 9b80: c003f80c ffdc8000 ffdc9bac ffdc9b98 c045fe9c c0017d50 ffdc9c98 ffdc8000
[ 1438.835655] 9ba0: ffdc9be4 ffdc9bb0 c001a1f0 c045fe4c ffdc9be4 ffdc9bc0 c003c90c 00000017
[ 1438.844580] 9bc0: c001a008 c05ba364 00000003 ffdc9c98 c003f80c ffdc8000 ffdc9c94 ffdc9be8
[ 1438.853510] 9be0: c00083b0 c001a014 00000000 00005463 ffdc9c34 ffdc9c00 c003cf74 c00591f4
[ 1438.862433] 9c00: 00005463 00000000 c01e9780 ffdc9c7c ffdc9c7c 00000003 0000003a c05d4e04
[ 1438.871363] 9c20: 0000000f c0625da1 ffdc9ccc ffdc9c38 c003d324 c003ce18 0000004b c0625d7a
[ 1438.880292] 9c40: 7a2d7359 000000b3 4d6cbaa6 0000014e ffdc9c6e 600f0113 10624dd3 c0625d7a
[ 1438.889223] 9c60: 79f7d49d 000000b3 00000004 205b014e 35333431 c003f808 a00f0113 ffffffff
[ 1438.898140] 9c80: ffdc9ccc c003f80a ffdc9d14 ffdc9c98 c0014158 c0008380 00000000 00000000
[ 1438.907060] 9ca0: ffdc8000 ffffffff 0000000b 00000000 ffdc8000 00000001 c003f80a c003f80c
[ 1438.915987] 9cc0: ffdc8000 ffdc9d14 00000000 ffdc9ce0 c0059684 c003f808 a00f0113 ffffffff
[ 1438.924917] 9ce0: 00000000 ffdc9d5a ffdc8000 c003f80a c003f80c ffdc8000 ffdc9d14 ffdc9d08
[ 1438.933839] 9d00: c003c7d4 00000001 ffdc9d8c ffdc9d18 c0017e60 c003f7d8 ffdc82f0 0000000b
[ 1438.942762] 9d20: 100f0193 00000008 65dc9e90 37303062 20356131 36393565 34343233 35336520
[ 1438.951689] 9d40: 30303033 61302030 30303030 28203630 33393565 34303031 c0002029 c04601a4
[ 1438.960624] 9d60: c051a9c4 00000003 00000017 00000000 ffdc9e90 00000003 c001a238 ffdc8000
[ 1438.969548] 9d80: ffdc9da4 ffdc9d90 c045fe9c c0017d50 ffdc9e90 ffdc8000 ffdc9ddc ffdc9da8
[ 1438.978480] 9da0: c001a1f0 c045fe4c ffdc9ddc ffdc9db8 c003c90c 00000017 c001a008 c05ba364
[ 1438.987412] 9dc0: 00000003 ffdc9e90 c001a238 ffdc8000 ffdc9e8c ffdc9de0 c00083b0 c001a014
[ 1438.996328] 9de0: 00000000 00004fac ffdc9e2c ffdc9df8 c003cf74 c00591f4 00004fac 00000000
[ 1439.005257] 9e00: c01e9780 ffdc9e74 ffdc9e74 00000003 0000003a c05d4e04 0000000f c0625da1
[ 1439.014187] 9e20: ffdc9ec4 ffdc9e30 c003d324 c003ce18 ffdc9e74 c0625d7a 76a7af90 000000b3
[ 1439.023109] 9e40: 46dd0fb1 0000014e ffdc9e66 600f0113 10624dd3 cf66bfb0 0000003e 0001a236
[ 1439.032038] 9e60: 00000004 205b9e70 35333431 c003f808 a00f0113 ffffffff ffdc9ec4 c001a236
[ 1439.040955] 9e80: ffdc9f0c ffdc9e90 c0014158 c0008380 00000000 00000000 ffdc8000 ffffffff
[ 1439.049877] 9ea0: 0000000b 00000000 ffdc8000 00000001 c001a236 c001a238 ffdc8000 ffdc9f0c
[ 1439.058802] 9ec0: 00000000 ffdc9ed8 c0059684 c003f808 a00f0113 ffffffff 00000000 ffdc9f52
[ 1439.067736] 9ee0: ffdc8000 c001a236 c001a238 ffdc8000 ffdc9f0c ffdc9f00 c003c7d4 00000001
[ 1439.076668] 9f00: ffdc9f84 ffdc9f10 c0017e60 c003f7d8 ffdc82f0 0000000b 100f0193 00000008
[ 1439.085605] 9f20: 65dca088 36306131 20303030 33393565 63303033 61316520 30303530 33652031
[ 1439.094546] 9f40: 30306331 28206630 33393565 38613037 c0002029 c04601a4 c051a9c4 000000a8
[ 1439.103474] 9f60: 00000017 00000000 ffdca088 000000a8 49b001ac 1a000076 ffdc9f9c ffdc9f88
[ 1439.112408] 9f80: c045fe9c c0017d50 ffdca088 ffdc8000 ffdc9fd4 ffdc9fa0 c001a1f0 c045fe4c
[ 1439.121342] 9fa0: 00000000 00000000 8f129f80 00000017 c001a008 c05ba364 000000a8 ffdca088
[ 1439.130282] 9fc0: 49b001ac 1a000076 ffdca084 ffdc9fd8 c00083b0 c001a014 00000000 00000000
[ 1439.139203] 9fe0: 00000000 00000000 8f129fc0 c001a03c 100f0193 ffffffff ffdca044 000000a4
[ 1439.148130] a000: ffdca08c 00000005 00000005 00000000 1b478423 a7c5ac47 ffdca054 ffdca028
[ 1439.157050] a020: c01e78f0 c01e76a0 00000000 ffdca1ad ffdca086 00000001 00000000 ffffffff
[ 1439.165973] a040: 0000014e ffdca170 00000000 00000000 ffdca0a4 ffdca060 c023738c c02370b0
[ 1439.174902] a060: 00000000 c001a234 200f0193 ffffffff ffdca0bc ffdca1c8 ffdca0f4 ffdca088
[ 1439.183827] a080: c0014158 c0008380 e59fc0a4 00000005 ffdca0d0 00000000 ffdca1c8 00000005
[ 1439.192757] a0a0: e59fc0a4 cf5c4000 ffdca1c8 49b001ac 1a000076 ffdca0f4 a00f0193 ffdca0d0
[ 1439.201692] a0c0: c001a2fc c001a234 200f0193 ffffffff c0625cd0 00004ab2 00000005 c0004000
[ 1439.210617] a0e0: 00000000 cf5c4000 ffdca114 ffdca0f8 c001a2fc c001a20c 00000005 c001a28c
[ 1439.219545] a100: c05ba344 e59fc0a4 ffdca1c4 ffdca118 c00083b0 c001a298 c003ca10 c003c894
[ 1439.228479] a120: 00000000 00004b04 ffdca16c ffdca138 c003cf74 c00591f4 00004b04 00000000
[ 1439.237403] a140: c01e9780 ffdca1b4 ffdca1b4 00000003 00000058 c05d4e04 0000000f c0625dbf
[ 1439.246336] a160: ffdca204 ffdca170 c003d324 c003ce18 ffdca1c0 c0625d7a 7315eb74 000000b3
[ 1439.255157] a180: 40370a15 0000014e
[ 1439.258918] Backtrace: invalid frame pointer 0xffdc8574
[ 1439.264700] Code: eb0071a5 e5963244 e3530000 0a000006 (e5931004)
[ 1439.271249] ---[ end trace 39f7c14e1359983c ]---
[ 1439.276218] Kernel panic - not syncing: Fatal exception in interrupt
[ 1439.283021] Backtrace: invalid frame pointer 0xffdc833c
Thanks.
  • Please post the complete log. Please do not paste it in the text field, post it as an attachment (drag and drop the file in the text window).
  • Hi Biser,
    Thankyou for replying. I have attached the file here.
    We are seeing this problem on some of the boards, most of the times we see an error
    Then we start getting internal error : Oops then final leads to kernel panic.
    Raj.
    I2C:   ready
    DRAM:  256 MiB
    256 MiB
    ..... done
    ... done
    . done
    starting script
    . done
    Erasing Flash...
    . done
    Erased 1 sectors
    ..... done
    Starting kernel ...
    [    0.000196] Calibrating delay loop... 531.66 BogoMIPS (lpj=2658304)
    [    0.046641] pid_max: default: 32768 minimum: 301
    [    0.046754] Security Framework initialized
    [    0.046850] Mount-cache hash table entries: 512
    [    0.047226] CPU: Testing write buffer coherency: ok
    [    0.047967] devtmpfs: initialized
    [    0.066877] omap_hwmod: gfx: failed to hardreset
    [    0.082748] omap_hwmod: pruss: failed to hardreset
    [    0.083849] print_constraints: dummy:
    [    0.084210] NET: Registered protocol family 16
    [    0.086264] OMAP GPIO hardware version 0.1
    [    0.088354] omap_mux_init: Add partition: #1: core, flags: 0
    [    0.090150]  omap_hsmmc.0: alias fck already exists
    [    0.090476]  omap_i2c.1: alias fck already exists
    [    0.090731]  omap_i2c.2: alias fck already exists
    [    3.118374]  edma.0: alias fck already exists
    [    3.118397]  edma.0: alias fck already exists
    [    3.118414]  edma.0: alias fck already exists
    [    3.143898] bio: create slab <bio-0> at 0
    [    3.145893] SCSI subsystem initialized
    [    3.146540] usbcore: registered new interface driver usbfs
    [    3.146857] usbcore: registered new interface driver hub
    [    3.147055] usbcore: registered new device driver usb
    [    3.147389] registerd cppi-dma Intr @ IRQ 17
    [    3.147402] Cppi41 Init Done Qmgr-base(d0872000) dma-base(d0870000)
    [    3.147411] Cppi41 Init Done
    [    3.147438] musb-ti81xx musb-ti81xx: musb0, board_mode=0x11, plat_mode=0x1
    [    3.147731] musb-ti81xx musb-ti81xx: musb1, board_mode=0x11, plat_mode=0x1
    [    3.166654] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
    [    3.186637] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
    [    3.188960] cfg80211: Calling CRDA to update world regulatory domain
    [    3.190070] Switching to clocksource gp timer
    [    3.206718] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
    [    3.206917] musb-hdrc musb-hdrc.0: dma type: dma-cppi41
    [    3.207231] MUSB0 controller's USBSS revision = 4ea20800
    [    3.207265] musb0: Enabled SW babble control
    [    3.207744] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
    [    3.207860] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 1
    [    3.207988] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
    [    3.208002] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.208015] usb usb1: Product: MUSB HDRC host driver
    [    3.208025] usb usb1: Manufacturer: Linux 3.2.0 musb-hcd
    [    3.208035] usb usb1: SerialNumber: musb-hdrc.0
    [    3.208956] hub 1-0:1.0: USB hub found
    [    3.208987] hub 1-0:1.0: 1 port detected
    [    3.209582] musb-hdrc musb-hdrc.0: USB Host mode controller at d084c000 using DMA, IRQ 18
    [    3.209763] musb-hdrc musb-hdrc.1: dma type: dma-cppi41
    [    3.210080] MUSB1 controller's USBSS revision = 4ea20800
    [    3.210170] musb1: Enabled SW babble control
    [    3.210623] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
    [    3.210671] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 2
    [    3.210765] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
    [    3.210778] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    3.210790] usb usb2: Product: MUSB HDRC host driver
    [    3.210800] usb usb2: Manufacturer: Linux 3.2.0 musb-hcd
    [    3.210810] usb usb2: SerialNumber: musb-hdrc.1
    [    3.211669] hub 2-0:1.0: USB hub found
    [    3.211695] hub 2-0:1.0: 1 port detected
    [    3.212304] musb-hdrc musb-hdrc.1: USB Host mode controller at d084e800 using DMA, IRQ 19
    [    3.212730] NET: Registered protocol family 2
    [    3.212925] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
    [    3.213209] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
    [    3.213353] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
    [    3.213439] TCP: Hash tables configured (established 8192 bind 8192)
    [    3.213451] TCP reno registered
    [    3.213462] UDP hash table entries: 256 (order: 0, 4096 bytes)
    [    3.213484] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
    [    3.213669] NET: Registered protocol family 1
    [    3.213917] RPC: Registered named UNIX socket transport module.
    [    3.213931] RPC: Registered udp transport module.
    [    3.213939] RPC: Registered tcp transport module.
    [    3.213947] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    3.214030] NetWinder Floating Point Emulator V0.97 (double precision)
    [    3.225554] VFS: Disk quotas dquot_6.5.2
    [    3.225621] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
    [    3.226131] JFFS2 version 2.2. (NAND) © 2001-2006 Red Hat, Inc.
    [    3.226359] msgmni has been set to 494
    [    3.229438] alg: No test for stdrng (krng)
    [    3.230274] io scheduler noop registered
    [    3.230289] io scheduler deadline registered
    [    3.230363] io scheduler cfq registered (default)
    [    3.231284] Serial: 8250/16550 driver, 4 ports, IRQ sharing disabled
    [    3.233001] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
    [    3.895572] console [ttyO0] enabled
    [    3.899915] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
    [    3.907802] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
    [    3.915630] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
    [    3.923452] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
    [    3.931275] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
    [    3.939582] omap4_rng omap4_rng: OMAP4 Random Number Generator ver. 2.00
    [    3.955945] brd: module loaded
    [    3.964212] loop: module loaded
    [    3.969670] mtdoops: mtd device (mtddev=name/number) must be supplied
    [    3.976537] physmap platform flash device: 10000000 at 10000000
    [    3.988181] Number of erase regions: 1
    [    3.992126] Primary Vendor Command Set: 0002 (AMD/Fujitsu Standard)
    [    3.998665] Primary Algorithm Table at 0040
    [    4.003041] Alternative Vendor Command Set: 0000 (None)
    [    4.008490] No Alternate Algorithm Table
    [    4.012586] Vcc Minimum:  2.7 V
    [    4.015859] Vcc Maximum:  3.6 V
    [    4.019130] No Vpp line
    [    4.021684] Typical byte/word write timeout: 256 µs
    [    4.026861] Maximum byte/word write timeout: 512 µs
    [    4.032045] Typical full buffer write timeout: 512 µs
    [    4.037404] Maximum full buffer write timeout: 2048 µs
    [    4.042870] Typical block erase timeout: 256 ms
    [    4.047593] Maximum block erase timeout: 2048 ms
    [    4.052417] Typical chip erase timeout: 524288 ms
    [    4.057322] Maximum chip erase timeout: 4194304 ms
    [    4.062328] Device size: 0x10000000 bytes (256 MiB)
    [    4.067414] Flash Device Interface description: 0x0001
    [    4.072780]   - x16-only asynchronous interface
    [    4.077504] Max. bytes in buffer write: 0x200
    [    4.082054] Number of Erase Block Regions: 1
    [    4.086508]   Erase Region #0: BlockSize 0x20000 bytes, 2048 blocks
    [    4.093063] Correcting S70GL02GS CFI data
    [    4.097248] physmap-flash.0: Found 1 x16 devices at 0x0 in 16-bit bank. Manufacturer ID 0x000001 Chip ID 0x004801
    [    4.107978] physmap-flash.0: Found 1 x16 devices at 0x8000000 in 16-bit bank
    [    4.115363] Amd/Fujitsu Extended Query Table at 0x0040
    [    4.120746]   Amd/Fujitsu Extended Query version 1.5.
    [    4.126023] number of CFI chips: 2
    [    4.129586] Creating 6 MTD partitions on "physmap-flash.0":
    [    4.135420] 0x000000000000-0x000000080000 : "uboot"
    [    4.142182] 0x000000080000-0x0000000a0000 : "uboot-env"
    [    4.148946] 0x0000000a0000-0x0000005a0000 : "Current kernel"
    [    4.156168] 0x0000005a0000-0x000000aa0000 : "Backup kernel"
    [    4.163306] 0x000000aa0000-0x000000fa0000 : "Failsafe kernel"
    [    4.170645] 0x000000fa0000-0x000010000000 : "File System"
    [    4.178294] UBI: attaching mtd5 to ubi0
    [    4.182354] UBI: physical eraseblock size:   131072 bytes (128 KiB)
    [    4.188893] UBI: logical eraseblock size:    130944 bytes
    [    4.194534] UBI: smallest flash I/O unit:    1
    [    4.199169] UBI: VID header offset:          64 (aligned 64)
    [    4.205080] UBI: data offset:                128
    [    4.339881] UBI: max. sequence number:       152
    [    4.372550] UBI: attached mtd5 to ubi0
    [    4.376474] UBI: MTD device name:            "File System"
    [    4.382247] UBI: MTD device size:            240 MiB
    [    4.387425] UBI: number of good PEBs:        1923
    [    4.392339] UBI: number of bad PEBs:         0
    [    4.396972] UBI: number of corrupted PEBs:   0
    [    4.401612] UBI: max. allowed volumes:       128
    [    4.406426] UBI: wear-leveling threshold:    4096
    [    4.411338] UBI: number of internal volumes: 1
    [    4.415970] UBI: number of user volumes:     1
    [    4.420610] UBI: available PEBs:             0
    [    4.425242] UBI: total number of reserved PEBs: 1923
    [    4.430426] UBI: number of PEBs reserved for bad PEB handling: 0
    [    4.436691] UBI: max/mean erase counter: 1/0
    [    4.441150] UBI: image sequence number:  1954740848
    [    4.446339] UBI: background thread "ubi_bgt0d" started, PID 534
    [    4.500149] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
    [    4.506608] davinci_mdio davinci_mdio.0: no live phy, scanning all
    [    4.513411] davinci_mdio: probe of davinci_mdio.0 failed with error -5
    [    4.520426] rtl8192cu driver version=v4.0.2_9000.20130911
    [    4.526062] build time: Apr 22 2015 10:10:56
    [    4.530707] usbcore: registered new interface driver rtl8192cu
    [    4.536840] Initializing USB Mass Storage driver...
    [    4.542155] usbcore: registered new interface driver usb-storage
    [    4.548424] USB Mass Storage support registered.
    [    4.553802] mousedev: PS/2 mouse device common for all mice
    [    4.560367] i2c /dev entries driver
    [    4.700679] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    4.707174] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
    [    4.715890] cpuidle: using governor ladder
    [    4.720641] cpuidle: using governor menu
    [    4.726859] omap4_aes_mod_init: loading AM33X AES driver
    [    4.732544] omap4-aes omap4-aes: AM33X AES hw accel rev: 3.02
    [    4.739035] omap4_aes_probe: probe() done
    [    4.743453] omap4_sham_mod_init: loading AM33X SHA/MD5 driver
    [    4.749566] omap4-sham omap4-sham: AM33X SHA/MD5 hw accel rev: 4.03
    [    4.760083] omap4_sham_probe: probe() done
    [    4.766709] usbcore: registered new interface driver usbhid
    [    4.772557] usbhid: USB HID core driver
    [    4.777421] tiadc tiadc: attached adc driver
    [    4.782058] oprofile: hardware counters not available
    [    4.787330] oprofile: using timer interrupt.
    [    4.791827] nf_conntrack version 0.5.0 (3959 buckets, 15836 max)
    [    4.798587] ip_tables: (C) 2000-2006 Netfilter Core Team
    [    4.804284] TCP cubic registered
    [    4.807657] NET: Registered protocol family 17
    [    4.812349] lib80211: common routines for IEEE802.11 drivers
    [    4.818585] Registering the dns_resolver key type
    [    4.823594] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
    [    4.831612] ThumbEE CPU extension supported.
    [    4.836130] mux: Failed to setup hwmod io irq -22
    [    4.841709] Power Management for AM33XX family
    [    4.846563] Trying to load am335x-pm-firmware.bin (60 secs timeout)
    [    4.853262] Copied the M3 firmware to UMEM
    [    4.857615] Cortex M3 Firmware Version = 0x181
    [    4.862732] sr_init: platform driver register failed
    [    4.871382] clock: disabling unused clocks to save power
    [    4.881121] Detected MACID=54:4a:16:ce:9a:fa
    [    4.887139] drivers/rtc/hctosys.c: unable to open rtc device (rtc0)
    [    5.036697] UBIFS: recovery needed
    [    5.309330] UBIFS: recovery completed
    [    5.313294] UBIFS: mounted UBI device 0, volume 0, name "rootfs"
    [    5.319566] UBIFS: file system size:   249972096 bytes (244113 KiB, 238 MiB, 1909 LEBs)
    [    5.327938] UBIFS: journal size:       8912384 bytes (8703 KiB, 8 MiB, 69 LEBs)
    [    5.335574] UBIFS: media format:       w4/r0 (latest is w4/r0)
    [    5.341667] UBIFS: default compressor: lzo
    [    5.345938] UBIFS: reserved for root:  0 bytes (0 KiB)
    [    5.351914] VFS: Mounted root (ubifs filesystem) on device 0:14.
    [    5.358785] devtmpfs: mounted
    [    5.362252] Freeing init memory: 208K
    [    5.366238] Failed to execute /init.  Attempting defaults...
    Starting udev
    [    6.216166] udev[666]: starting version 164
    bootlogd.
    Configuring network interfaces... [    8.904989] PHY 0:03 not found
    [    8.908200] PHY 0:03 not found
    Sending discover...
    Sending discover...
    Sending discover...
    No lease, failing
    done.
    Tue Jun 25 23:23:00 UTC 2013
    Starting Lighttpd Web Server: [   19.164925] BUG: Bad page state in process cp  pfn:8fba1
    [   19.170534] page:c0848420 count:0 mapcount:-1073741824 mapping:  (null) index:0x16
    [   19.178434] page flags: 0x0()
    [   19.181539] Backtrace:
    [   19.184121] [<c0017ba4>] (dump_backtrace+0x0/0x10c) from [<c045fe3c>] (dump_stack+0x18/0x1c)
    [   19.192939]  r6:c05d5d10 r5:c0848420 r4:c06383a0 r3:c05d4e30
    [   19.198876] [<c045fe24>] (dump_stack+0x0/0x1c) from [<c0078d50>] (bad_page+0xac/0x10c)
    [   19.207158] [<c0078ca4>] (bad_page+0x0/0x10c) from [<c00792ec>] (get_page_from_freelist+0x474/0x560)
    [   19.216697]  r6:c0853630 r5:00000000 r4:c0848420 r3:00000000
    [   19.222637] [<c0078e78>] (get_page_from_freelist+0x0/0x560) from [<c00798b4>] (__alloc_pages_nodemask+0xe8/0x664)
    [   19.233367] [<c00797cc>] (__alloc_pages_nodemask+0x0/0x664) from [<c0083fc4>] (shmem_getpage_gfp+0x140/0x500)
    [   19.243730] [<c0083e84>] (shmem_getpage_gfp+0x0/0x500) from [<c0084450>] (shmem_write_begin+0x40/0x48)
    [   19.253459] [<c0084410>] (shmem_write_begin+0x0/0x48) from [<c0075a94>] (generic_file_buffered_write+0x1a8/0x26c)
    [   19.264186] [<c00758ec>] (generic_file_buffered_write+0x0/0x26c) from [<c0075d9c>] (__generic_file_aio_write+0x244/0x478)
    [   19.275639] [<c0075b58>] (__generic_file_aio_write+0x0/0x478) from [<c0076034>] (generic_file_aio_write+0x64/0xd0)
    [   19.286458] [<c0075fd0>] (generic_file_aio_write+0x0/0xd0) from [<c009fb8c>] (do_sync_write+0xac/0xec)
    [   19.296186] [<c009fae0>] (do_sync_write+0x0/0xec) from [<c009fc70>] (vfs_write+0xa4/0x148)
    [   19.304824] [<c009fbcc>] (vfs_write+0x0/0x148) from [<c009fdcc>] (sys_write+0x40/0x78)
    [   19.313093]  r8:00001000 r7:bee2aa24 r6:cf621ac0 r5:00000000 r4:000f6000
    [   19.320124] [<c009fd8c>] (sys_write+0x0/0x78) from [<c0014580>] (ret_fast_syscall+0x0/0x30)
    [   19.328850]  r8:c0014728 r7:00000004 r6:00000004 r5:bee2aa24 r4:00001000
    [   19.335870] Disabling lock debugging due to kernel taint
    lighttpd.
    I have checked for file system permissions, tempfs file system, free RAM everything looks good.
    Another error:
    [  227.543187] BUG: Bad page state in process pidof  pfn:8ceb3
    [  227.549045] page:c07ee660 count:0 mapcount:-1073741824 mapping:  (null) index:0x4006f
    [  227.557241] page flags: 0x0()
    [  227.560337] Backtrace:
    [  227.562929] [<c0017ba4>] (dump_backtrace+0x0/0x10c) from [<c045fe3c>] (dump_stack+0x18/0x1c)
    [  227.571747]  r6:c0853630 r5:c07ee660 r4:c06383a0 r3:c05d4e30
    [  227.577685] [<c045fe24>] (dump_stack+0x0/0x1c) from [<c0078d50>] (bad_page+0xac/0x10c)
    [  227.585969] [<c0078ca4>] (bad_page+0x0/0x10c) from [<c00792ec>] (get_page_from_freelist+0x474/0x560)
    [  227.595509]  r6:c0853630 r5:00000000 r4:c07ee660 r3:00000000
    [  227.601469] [<c0078e78>] (get_page_from_freelist+0x0/0x560) from [<c00798b4>] (__alloc_pages_nodemask+0xe8/0x664)
    [  227.612209] [<c00797cc>] (__alloc_pages_nodemask+0x0/0x664) from [<c008c7c4>] (handle_pte_fault+0x478/0x618)
    [  227.622486] [<c008c34c>] (handle_pte_fault+0x0/0x618) from [<c008c9f4>] (handle_mm_fault+0x90/0xc0)
    [  227.631948] [<c008c964>] (handle_mm_fault+0x0/0xc0) from [<c001a164>] (do_page_fault+0x15c/0x1f8)
    [  227.641229] [<c001a008>] (do_page_fault+0x0/0x1f8) from [<c00083b0>] (do_DataAbort+0x3c/0xa4)
    [  227.650143] [<c0008374>] (do_DataAbort+0x0/0xa4) from [<c0014158>] (__dabt_svc+0x38/0x60)
    [  227.658691] Exception stack(0xcf479e60 to 0xcf479ea8)
    [  227.664031] 9e60: 400ba000 cea1a01c fffffffd 6e69622f 0068732f 2f74662f 68676968 63656863
    [  227.672583] 9e80: 68732e6b cea1a000 cf479f78 cf479f0c 00000004 cf479eac 74662f00 c01dcf7c
    [  227.681128] 9ea0: 000f0013 ffffffff
    [  227.684765]  r8:68732e6b r7:cf479e94 r6:ffffffff r5:000f0013 r4:c01dcf7c
    [  227.691816] [<c00bd8ac>] (simple_read_from_buffer+0x0/0xe0) from [<c00ea088>] (proc_info_read+0xc0/0xdc)
    [  227.701730] [<c00e9fc8>] (proc_info_read+0x0/0xdc) from [<c009fa3c>] (vfs_read+0xa0/0x144)
    [  227.710362] [<c009f99c>] (vfs_read+0x0/0x144) from [<c009fd54>] (sys_read+0x40/0x78)
    [  227.718456]  r8:00000400 r7:400ba000 r6:cf7536c0 r5:00000000 r4:00000000
    [  227.725488] [<c009fd14>] (sys_read+0x0/0x78) from [<c0014580>] (ret_fast_syscall+0x0/0x30)
    [  227.734122]  r8:c0014728 r7:00000003 r6:00001000 r5:44bfdc68 r4:0001d6d8
    Another run time error:
      148.650532] Unable to handle kernel paging request at virtual address 8f64b000
    [  148.658155] pgd = cf5c8000
    [  148.661168] [8f64b000] *pgd=00000000
    [  148.664926] Internal error: Oops: 805 [#1]
    [  148.669205] CPU: 0    Tainted: G    B         (3.2.0 #286)
    [  148.674955] PC is at __strncpy_from_user+0x10/0x40
    [  148.679967] LR is at getname_flags+0xb0/0x120
    [  148.684514] pc : [<c01de0b0>]    lr : [<c00a8454>]    psr: 200f0013
    [  148.684520] sp : cf479f20  ip : 40971b90  fp : cf479f44
    [  148.696500] r10: 00001000  r9 : cf478000  r8 : 00000000
    [  148.701951] r7 : 00000000  r6 : c05b6294  r5 : 40971b90  r4 : 8f64b000
    [  148.708763] r3 : 0000002f  r2 : 00000fff  r1 : 40971b91  r0 : 8f64b000
    [  148.715577] Flags: nzCv  IRQs on  FIQs on  Mode SVC_32  ISA ARM  Segment user
    [  148.723025] Control: 10c5387d  Table: 8f5c8019  DAC: 00000015
    [  148.729021] Process main (pid: 1362, stack limit = 0xcf4782f0)
    [  148.735108] Stack: (0xcf479f20 to 0xcf47a000)
    [  148.739658] 9f20: 00000241 00000000 ffffff9c 00000005 00000001 00000000 cf479f54 cf479f48
    [  148.748199] 9f40: c00a85b4 c00a83b0 cf479f94 cf479f58 c009eda8 c00a85a8 40039000 c0014728
    [  148.756738] 9f60: 00000241 000001b6 00000022 00000300 49b00468 00000000 00000004 00000005
    [  148.765279] 9f80: c0014728 00000000 cf479fa4 cf479f98 c009ee9c c009ed08 00000000 cf479fa8
    [  148.773818] 9fa0: c0014580 c009ee84 49b00468 00000000 40971b90 00000241 000001b6 000001b6
    [  148.782358] 9fc0: 49b00468 00000000 00000004 00000005 00000004 00117268 00000000 40972514
    [  148.790898] 9fe0: 00000000 40971b00 00059b24 00059b34 800f0010 40971b90 00000000 00000000
    [  148.799431] Backtrace:
    [  148.801994] [<c00a83a4>] (getname_flags+0x0/0x120) from [<c00a85b4>] (getname+0x18/0x1c)
    [  148.810447] [<c00a859c>] (getname+0x0/0x1c) from [<c009eda8>] (do_sys_open+0xac/0x17c)
    [  148.818715] [<c009ecfc>] (do_sys_open+0x0/0x17c) from [<c009ee9c>] (sys_open+0x24/0x28)
    [  148.827087] [<c009ee78>] (sys_open+0x0/0x28) from [<c0014580>] (ret_fast_syscall+0x0/0x30)
    [  148.835717] Code: e1a0c001 e2522001 54d13001 4a000003 (e4c03001)
    [  148.842120] ---[ end trace 7927601e2ac68cf1 ]---
  • Hello Raj.,
    Could you also attach a boot log from one working board?
    Kemal
