What should be the color combination for drawing face detection rectangular box which is not following RGB model
Hii TI Community,
In face detect demo of C6748 LCDK
CvScalar        blue = {255, 0, 0, 0};
is drawing blue rectangle across face.
It is working perfect for blue color but when I am changing other values it is making black rectangle. It is not following RGB model.
What model it is following?
If I want to draw red color box what should be CvScalar vale?
CvScalar        red = {0,255, 0, 0, 0}; ???
CvScalar        green = {0,0,255, 0}; ???
Any arbitary color how to represent?
With regards,
AS
  • Hi Amlan,
    When I looked at the code, I just came across, this line at "cxcore.h"
    "#define CV_RGB( r, g, b )  cvScalar( (b), (g), (r), 0 )"  // b - blue ; g - green;  r- red
    so my understanding would be, for white,
    CvScalar   white = {255, 255, 255, 0};
    for green,
    CvScalar   green = {0, 255, 0, 0};
    for red,
    CvScalar   red = {255, 0, 0, 0};
    Try this and let me know how it goes for you....
  • Dear Shankari G ,You are right but it is not working and I don't know why.
    if blue has small value it is converting the image rectangle to blue else it is changing to black.
    CvScalar blue = {255, 0, 255, 0}; Colour o/p isblue
    CvScalar blue = {0, 255,0, 0}; Colour o/p is With regardsAs
  • Dear Sir,
    I am trying from morning till unable to sort out why there z a problem in colour.
    CvScalar blue = {0, 255,0, 0}; Colour o/p is black
    CvScalar blue = {0, 0, 0, 0}; Colour o/p is blue
    CvScalar blue = {0,0, 255,0}; Colour o/p is black
    CvScalar blue = {25, 0, 255, 0}; Colour o/p is blue
    CvScalar blue = {255, 255,255, 0}; Colour o/p is blue
    even in small value it is converting to blue else it is taking as 0 i.e. black. other R G has no effect. How to solve this?
    With regards,AS
  • Hi Amlan,
    [quote user="Amlan"] if blue has small value it is converting the image rectangle to blue else it is changing to black.
    CvScalar blue = {0, 255,0, 0}; Colour o/p is [/quote ]
    For what value it is changing into black and for what value it is changing into blue? specify that small value??
  • Dear Sir,What may be the RGB value If B> 0 it is blue else it is black.
    Monitor have no effect on other Green and Red value.Please suggest why?
    With regards,AS
  • Hi Amlan,
    If that is the case, either that might be a bug or that is the default way that they would have written it.
    To solve this, I would recommend you to do a step by step debugging on things like "cvScalar" -->  "CV_DEFAULT(0)" etc.
    And also check, whether the value passed on the "(g), (r), 0 )" are taken into effect or what ever may be the value of these parameters, the actual value passed is just "0" through "CV_DEFAULT(0)"!!?? , if that is the case, experiment by modifying  "CV_DEFAULT( 255 ) instead of CV_Default (0), etc.
