Other Parts Discussed in Thread: TVP7002, TVP5158, TEST2
hi, i have a custom 8148+adv7611 board.the incoming video is 1080p30.
i have run saLoopBackFbdev successfully, but when i run gst to encode the video into avi , the output avi file size is 0, and there is 'Could not negotiate format' error.
Because my external decoder is adv7611( output RGB 24), i removed sub device call in the ti81xxvin_main.c (please check the attachment)
here is my pipeline and log:
root@dm814x-evm:~# gst-launch --gst-debug=3 v4l2src device=/dev/video0 always-co
py=false queue-size=12 num-buffers=2000 ! 'video/x-raw-yuv-strided,format=(fourc
c)NV12,width=1920,height=1080,framerate=(fraction)30/1' ! omxbufferalloc numBuff
ers=12 ! omx_h264enc ! queue ! avimux ! queue ! filesink location=v4l2cap.avi
0:00:00.021020713 1795 0x16050 INFO GST_INIT gstquery.c:108:_gst_query_initialize: init queries
0:00:00.028411277 1795 0x16050 INFO GST_INIT gstmessage.c:73:_gst_message_initialize: init messages
0:00:00.030225374 1795 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:350:_gst_plugin_initialize: registering 0 static plugins
0:00:00.031720521 1795 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:255:gst_plugin_register_static: registered static plugin "staticelements"
0:00:00.031833621 1795 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:257:gst_plugin_register_static: added static plugin "staticelements", result: 1
0:00:00.031922421 1795 0x16050 INFO GST_REGISTRY gstregistry.c:1599:ensure_current_registry: reading registry cache: /tmp/gst_registry.bin
0:00:00.192282687 1795 0x16050 INFO GST_REGISTRY gstregistrybinary.c:614:gst_registry_binary_read_cache: loaded /tmp/gst_registry.bin in 0.160233 seconds
0:00:00.192842687 1795 0x16050 INFO GST_REGISTRY gstregistry.c:1469:scan_and_update_registry: Validating plugins from registry cache: /tmp/gst_registry.bin
0:00:00.203093937 1795 0x16050 INFO GST_REGISTRY gstregistry.c:1561:scan_and_update_registry: Registry cache has not changed
0:00:00.203219937 1795 0x16050 INFO GST_REGISTRY gstregistry.c:1628:ensure_current_registry: registry reading and updating done, result = 1
0:00:00.203293187 1795 0x16050 INFO GST_INIT gst.c:792:init_post: GLib runtime version: 2.24.1
0:00:00.203372087 1795 0x16050 INFO GST_INIT gst.c:794:init_post: GLib headers version: 2.24.1
0:00:00.203650837 1795 0x16050 INFO GST_PIPELINE gstparse.c:299:gst_parse_launch_full: parsing pipeline description 'v4l2src device=/dev/video0 always-copy=false queue-size=12 num-buffers=2000 ! video/x-raw-yuv-strided,format=(fourcc)NV12,width=1920,height=1080,framerate=(fraction)30/1 ! omxbufferalloc numBuffers=12 ! omx_h264enc ! queue ! avimux ! queue ! filesink location=v4l2cap.avi '
0:00:00.210925893 1795 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstvideo4linux2.so" loaded
0:00:00.211087393 1795 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "v4l2src"
0:00:00.216320549 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseSrc@0x154060> adding pad 'src'
0:00:00.237238561 1795 0x16050 INFO omx gstomx_videomixer.c:2183:init_interfaces: GstChildProxy interface registered
0:00:00.237442810 1795 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstomx.so" loaded
0:00:00.237564460 1795 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omxbufferalloc"
0:00:00.238743410 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstomxBufferAlloc@0x159858> adding pad 'sink'
0:00:00.238869960 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstomxBufferAlloc@0x159858> adding pad 'src'
0:00:00.239179360 1795 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "omx_h264enc"
0:00:00.241557359 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstOmxBaseFilter@0x15c060> adding pad 'sink'
0:00:00.241690559 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstOmxBaseFilter@0x15c060> adding pad 'src'
0:00:00.246076908 1795 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstcoreelements.so" loaded
0:00:00.246213508 1795 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "queue"
0:00:00.248342207 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstQueue@0x99080> adding pad 'sink'
0:00:00.248721556 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstQueue@0x99080> adding pad 'src'
0:00:00.254698253 1795 0x16050 INFO GST_PLUGIN_LOADING gstplugin.c:859:gst_plugin_load_file: plugin "/usr/lib/gstreamer-0.10/libgstavi.so" loaded
0:00:00.254836403 1795 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "avimux"
0:00:00.258132802 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstAviMux@0x16d040> adding pad 'src'
0:00:00.594347450 1795 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "queue"
0:00:00.594786750 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstQueue@0x99258> adding pad 'sink'
0:00:00.595178251 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstQueue@0x99258> adding pad 'src'
0:00:00.595387951 1795 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "filesink"
0:00:00.596388351 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseSink@0x170130> adding pad 'sink'
0:00:00.596873501 1795 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "pipeline"
0:00:00.597759501 1795 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking v4l2src0:(any) to omxbufferalloc0:(any) (0/0) with caps "0x12a220"
0:00:00.597905801 1795 0x16050 INFO GST_ELEMENT_FACTORY gstelementfactory.c:371:gst_element_factory_create: creating element "capsfilter"
0:00:00.598780850 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x174050> adding pad 'sink'
0:00:00.599040850 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<GstBaseTransform@0x174050> adding pad 'src'
0:00:00.599212250 1795 0x16050 INFO GST_STATES gstbin.c:1759:gst_bin_get_state_func:<pipeline0> getting state
0:00:00.599398250 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:00.599618600 1795 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element v4l2src0:(any) to element capsfilter0:sink
0:00:00.599721350 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:963:gst_element_get_static_pad: found pad capsfilter0:sink
0:00:00.599818350 1795 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: v4l2src0 and capsfilter0 in same bin, no need for ghost pads
0:00:00.600039550 1795 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link v4l2src0:src and capsfilter0:sink
0:00:00.601255650 1795 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked v4l2src0:src and capsfilter0:sink, successful
0:00:00.601460450 1795 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element capsfilter0:src to element omxbufferalloc0:(any)
0:00:00.601557550 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:963:gst_element_get_static_pad: found pad capsfilter0:src
0:00:00.601656650 1795 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link capsfilter0:src and omxbufferalloc0:sink
0:00:00.941435900 1795 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: capsfilter0 and omxbufferalloc0 in same bin, no need for ghost pads
0:00:00.941605050 1795 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link capsfilter0:src and omxbufferalloc0:sink
0:00:00.945217851 1795 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked capsfilter0:src and omxbufferalloc0:sink, successful
0:00:00.945396401 1795 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking omxbufferalloc0:(any) to omxh264enc0:(any) (0/0) with caps "(nil)"
0:00:00.945497001 1795 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element omxbufferalloc0:(any) to element omxh264enc0:(any)
0:00:00.945594751 1795 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link omxbufferalloc0:src and omxh264enc0:sink
0:00:00.949182450 1795 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: omxbufferalloc0 and omxh264enc0 in same bin, no need for ghost pads
0:00:00.949322950 1795 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link omxbufferalloc0:src and omxh264enc0:sink
0:00:00.952886350 1795 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked omxbufferalloc0:src and omxh264enc0:sink, successful
0:00:00.953078550 1795 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking omxh264enc0:(any) to queue0:(any) (0/0) with caps "(nil)"
0:00:00.953173850 1795 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element omxh264enc0:(any) to element queue0:(any)
0:00:00.953271400 1795 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link omxh264enc0:src and queue0:sink
0:00:00.953391750 1795 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: omxh264enc0 and queue0 in same bin, no need for ghost pads
0:00:00.953524700 1795 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link omxh264enc0:src and queue0:sink
0:00:00.953629750 1795 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked omxh264enc0:src and queue0:sink, successful
0:00:00.953784450 1795 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking queue0:(any) to avimux0:(any) (0/0) with caps "(nil)"
0:00:00.953876850 1795 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element queue0:(any) to element avimux0:(any)
0:00:00.954487350 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:716:gst_element_add_pad:<avimux0> adding pad 'video_00'
0:00:00.954679100 1795 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: queue0 and avimux0 in same bin, no need for ghost pads
0:00:00.954817100 1795 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link queue0:src and avimux0:video_00
0:00:01.291235250 1795 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked queue0:src and avimux0:video_00, successful
0:00:01.291410300 1795 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking avimux0:(any) to queue1:(any) (0/0) with caps "(nil)"
0:00:01.291504650 1795 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element avimux0:(any) to element queue1:(any)
0:00:01.291602200 1795 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link avimux0:src and queue1:sink
0:00:01.291701000 1795 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: avimux0 and queue1 in same bin, no need for ghost pads
0:00:01.291826900 1795 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link avimux0:src and queue1:sink
0:00:01.291929650 1795 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked avimux0:src and queue1:sink, successful
0:00:01.292084250 1795 0x16050 INFO GST_PIPELINE ./grammar.y:568:gst_parse_perform_link: linking queue1:(any) to filesink0:(any) (0/0) with caps "(nil)"
0:00:01.292176850 1795 0x16050 INFO GST_ELEMENT_PADS gstutils.c:1568:gst_element_link_pads_full: trying to link element queue1:(any) to element filesink0:(any)
0:00:01.292270700 1795 0x16050 INFO GST_PADS gstutils.c:1028:gst_pad_check_link: trying to link queue1:src and filesink0:sink
0:00:01.292404150 1795 0x16050 INFO GST_PADS gstutils.c:1468:prepare_link_maybe_ghosting: queue1 and filesink0 in same bin, no need for ghost pads
0:00:01.292562250 1795 0x16050 INFO GST_PADS gstpad.c:1941:gst_pad_link_prepare: trying to link queue1:src and filesink0:sink
0:00:01.292691200 1795 0x16050 INFO GST_PADS gstpad.c:2124:gst_pad_link_full: linked queue1:src and filesink0:sink, successful
Setting pipeline to PAUSED ...
0:00:01.297072851 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<filesink0> completed state change to READY
0:00:01.297180251 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<filesink0> posting state-changed NULL to READY
0:00:01.297445801 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'filesink0' changed state to 2(READY) successfully
0:00:01.297576651 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<queue1> completed state change to READY
0:00:01.297662001 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<queue1> posting state-changed NULL to READY
0:00:01.297785401 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'queue1' changed state to 2(READY) successfully
0:00:01.633451200 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<avimux0> completed state change to READY
0:00:01.633545850 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<avimux0> posting state-changed NULL to READY
0:00:01.633668850 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'avimux0' changed state to 2(READY) successfully
0:00:01.633787250 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<queue0> completed state change to READY
0:00:01.633871300 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<queue0> posting state-changed NULL to READY
0:00:01.633989350 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'queue0' changed state to 2(READY) successfully
0:00:01.634107400 1795 0x16050 INFO omx gstomx_base_filter.c:153:change_state:<omxh264enc0> begin: changing state NULL -> READY
0:00:02.712529850 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxh264enc0> completed state change to READY
0:00:02.712762900 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxh264enc0> posting state-changed NULL to READY
0:00:02.712949750 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxh264enc0' changed state to 2(READY) successfully
0:00:02.713116700 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxbufferalloc0> completed state change to READY
0:00:02.713207450 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxbufferalloc0> posting state-changed NULL to READY
0:00:02.713331750 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxbufferalloc0' changed state to 2(READY) successfully
0:00:02.713450600 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<capsfilter0> completed state change to READY
0:00:02.713537300 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<capsfilter0> posting state-changed NULL to READY
0:00:02.713658000 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 2(READY) successfully
0:00:02.714349850 1795 0x16050 INFO v4l2 v4l2_calls.c:480:gst_v4l2_open:<v4l2src0> Opened device 'TI81xx_catalogue' (/dev/video0) successfully
0:00:02.714582750 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<v4l2src0> completed state change to READY
0:00:02.714677500 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<v4l2src0> posting state-changed NULL to READY
0:00:02.714813200 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 2(READY) successfully
0:00:02.715462401 1795 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<pipeline0> committing state from NULL to READY, pending PAUSED, next PAUSED
0:00:02.715855551 1795 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<pipeline0> continue state change READY to PAUSED, final PAUSED
0:00:02.716227751 1795 0x16050 INFO GST_STATES gstbin.c:2498:gst_bin_change_state_func:<pipeline0> child 'filesink0' is changing state asynchronously to PAUSED
0:00:02.717049601 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<queue1> completed state change to PAUSED
0:00:02.717158601 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<queue1> posting state-changed READY to PAUSED
0:00:02.717290801 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'queue1' changed state to 3(PAUSED) successfully
0:00:02.717470201 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<avimux0> completed state change to PAUSED
0:00:02.717561101 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<avimux0> posting state-changed READY to PAUSED
0:00:03.053602100 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'avimux0' changed state to 3(PAUSED) successfully
0:00:03.054129400 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<queue0> completed state change to PAUSED
0:00:03.054229300 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<queue0> posting state-changed READY to PAUSED
0:00:03.054354150 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'queue0' changed state to 3(PAUSED) successfully
0:00:03.054473950 1795 0x16050 INFO omx gstomx_base_filter.c:153:change_state:<omxh264enc0> begin: changing state READY -> PAUSED
0:00:03.054590900 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxh264enc0> completed state change to PAUSED
0:00:03.054675550 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxh264enc0> posting state-changed READY to PAUSED
0:00:03.054797650 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxh264enc0' changed state to 3(PAUSED) successfully
0:00:03.055304501 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxbufferalloc0> completed state change to PAUSED
0:00:03.055404051 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxbufferalloc0> posting state-changed READY to PAUSED
0:00:03.055527401 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxbufferalloc0' changed state to 3(PAUSED) successfully
0:00:03.055701101 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<capsfilter0> completed state change to PAUSED
0:00:03.055794051 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<capsfilter0> posting state-changed READY to PAUSED
0:00:03.055916351 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 3(PAUSED) successfully
0:00:03.056192451 1795 0x16050 INFO v4l2 gstv4l2object.c:1036:gst_v4l2_object_fill_format_list:<v4l2src0> got 4 format(s):
0:00:03.056279751 1795 0x16050 INFO v4l2 gstv4l2object.c:1042:gst_v4l2_object_fill_format_list:<v4l2src0> NV12
0:00:03.056384051 1795 0x16050 INFO v4l2 gstv4l2object.c:1042:gst_v4l2_object_fill_format_list:<v4l2src0> YUYV
0:00:03.056456601 1795 0x16050 INFO v4l2 gstv4l2object.c:1042:gst_v4l2_object_fill_format_list:<v4l2src0> RGB3
0:00:03.056527801 1795 0x16050 INFO v4l2 gstv4l2object.c:1042:gst_v4l2_object_fill_format_list:<v4l2src0> NV16
0:00:03.057103551 1795 0x16050 INFO v4l2src gstv4l2src.c:611:gst_v4l2src_get_caps:<v4l2src0> probed caps: 0x9be60
Mode set is 0
0:00:03.393761250 1795 0x16050 INFO v4l2 gstv4l2object.c:1525:gst_v4l2_object_get_caps_info:<v4l2src0> rowstride: 1920
0:00:03.393882150 1795 0x16050 WARN basesrc gstbasesrc.c:2778:gst_base_src_start:<v4l2src0> error: Could not negotiate format
0:00:03.393963150 1795 0x16050 WARN basesrc gstbasesrc.c:2778:gst_base_src_start:<v4l2src0> error: Check your filtered caps, if any
0:00:03.394139750 1795 0x16050 INFO GST_ERROR_SYSTEM gstelement.c:1865:gst_element_message_full:<v4l2src0> posting message: Could not negotiate format
0:00:03.394338750 1795 0x16050 INFO GST_ERROR_SYSTEM gstelement.c:1888:gst_element_message_full:<v4l2src0> posted error message: Could not negotiate format
0:00:03.394446100 1795 0x16050 WARN basesrc gstbasesrc.c:2974:gst_base_src_activate_push:<v4l2src0> Failed to start in push mode
0:00:03.394520650 1795 0x16050 INFO GST_PADS gstpad.c:983:gst_pad_activate_push:<v4l2src0:src> failed to activate in push mode
0:00:03.394609650 1795 0x16050 WARN GST_PADS gstpad.c:734:gst_pad_set_active:<v4l2src0:src> Failed to activate pad
0:00:03.394700700 1795 0x16050 INFO GST_STATES gstelement.c:2658:gst_element_change_state:<v4l2src0> have FAILURE change_state return
0:00:03.394784050 1795 0x16050 INFO GST_STATES gstelement.c:2235:gst_element_abort_state:<v4l2src0> aborting state from READY to PAUSED
0:00:03.394871250 1795 0x16050 INFO GST_STATES gstbin.c:2508:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' failed to go to state 3(PAUSED)
0:00:03.395428051 1795 0x16050 INFO GST_STATES gstelement.c:2658:gst_element_change_state:<pipeline0> have FAILURE change_state return
ERROR: Pipeline doesn't want to pause.
ERROR: from element /GstPipeline:pipeline0/GstV4l2Src:v4l2src0: Could not negotiate format
Additional debug info:
gstbasesrc.c(2778): gst_base_src_start (): /GstPipeline:pipeline0/GstV4l2Src:v4l2src0:
Setting pipeline to NULL ...
0:00:03.399421550 1795 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<filesink0> committing state from READY to READY, pending NULL, next NULL
0:00:03.399561900 1795 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<filesink0> continue state change READY to NULL, final NULL
0:00:03.399762250 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<filesink0> completed state change to NULL
0:00:03.399856700 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<filesink0> posting state-changed READY to NULL
0:00:03.400028350 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'filesink0' changed state to 1(NULL) successfully
0:00:03.400531450 1795 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<queue1> committing state from PAUSED to READY, pending NULL, next NULL
0:00:03.736527601 1795 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<queue1> continue state change READY to NULL, final NULL
0:00:03.736672001 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<queue1> completed state change to NULL
0:00:03.736758651 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<queue1> posting state-changed READY to NULL
0:00:03.736879851 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'queue1' changed state to 1(NULL) successfully
0:00:03.737085151 1795 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<avimux0> committing state from PAUSED to READY, pending NULL, next NULL
0:00:03.737215651 1795 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<avimux0> continue state change READY to NULL, final NULL
0:00:03.737343901 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<avimux0> completed state change to NULL
0:00:03.737427301 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<avimux0> posting state-changed READY to NULL
0:00:03.737544501 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'avimux0' changed state to 1(NULL) successfully
0:00:03.737911451 1795 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<queue0> committing state from PAUSED to READY, pending NULL, next NULL
0:00:03.738045651 1795 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<queue0> continue state change READY to NULL, final NULL
0:00:03.738173951 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<queue0> completed state change to NULL
0:00:03.738257701 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<queue0> posting state-changed READY to NULL
0:00:03.738376351 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'queue0' changed state to 1(NULL) successfully
0:00:03.738491751 1795 0x16050 INFO omx gstomx_base_filter.c:153:change_state:<omxh264enc0> begin: changing state PAUSED -> READY
0:00:03.738636650 1795 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<omxh264enc0> committing state from PAUSED to READY, pending NULL, next NULL
0:00:03.738760450 1795 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<omxh264enc0> continue state change READY to NULL, final NULL
0:00:03.738848650 1795 0x16050 INFO omx gstomx_base_filter.c:153:change_state:<omxh264enc0> begin: changing state READY -> NULL
0:00:03.778763950 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxh264enc0> completed state change to NULL
0:00:03.778935750 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxh264enc0> posting state-changed READY to NULL
0:00:03.779111350 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxh264enc0' changed state to 1(NULL) successfully
0:00:04.115402801 1795 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<omxbufferalloc0> committing state from PAUSED to READY, pending NULL, next NULL
0:00:04.115561401 1795 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<omxbufferalloc0> continue state change READY to NULL, final NULL
0:00:04.115697201 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<omxbufferalloc0> completed state change to NULL
0:00:04.115783151 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<omxbufferalloc0> posting state-changed READY to NULL
0:00:04.115903851 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'omxbufferalloc0' changed state to 1(NULL) successfully
0:00:04.116087451 1795 0x16050 INFO GST_STATES gstelement.c:2314:gst_element_continue_state:<capsfilter0> committing state from PAUSED to READY, pending NULL, next NULL
0:00:04.116215451 1795 0x16050 INFO GST_STATES gstelement.c:2323:gst_element_continue_state:<capsfilter0> continue state change READY to NULL, final NULL
0:00:04.116342201 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<capsfilter0> completed state change to NULL
0:00:04.116426601 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<capsfilter0> posting state-changed READY to NULL
0:00:04.116543401 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'capsfilter0' changed state to 1(NULL) successfully
0:00:04.116861501 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<v4l2src0> completed state change to NULL
0:00:04.116955451 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<v4l2src0> posting state-changed READY to NULL
0:00:04.117079201 1795 0x16050 INFO GST_STATES gstbin.c:2492:gst_bin_change_state_func:<pipeline0> child 'v4l2src0' changed state to 1(NULL) successfully
0:00:04.117497601 1795 0x16050 INFO GST_STATES gstelement.c:2341:gst_element_continue_state:<pipeline0> completed state change to NULL
0:00:04.117597501 1795 0x16050 INFO GST_STATES gstelement.c:2354:gst_element_continue_state:<pipeline0> posting state-changed READY to NULL
0:00:04.117733401 1795 0x16050 INFO GST_STATES gstbin.c:1759:gst_bin_get_state_func:<pipeline0> getting state
Freeing pipeline ...
0:00:04.118102601 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking capsfilter0:src(0x16e9a0) and omxbufferalloc0:sink(0x1560c8)
0:00:04.118273701 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked capsfilter0:src and omxbufferalloc0:sink
0:00:04.118434401 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking v4l2src0:src(0x156000) and capsfilter0:sink(0x16e8d8)
0:00:04.454790500 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked v4l2src0:src and capsfilter0:sink
0:00:04.455035701 1795 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "capsfilter0"
0:00:04.455203051 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<capsfilter0> dispose
0:00:04.455296551 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<capsfilter0> removing pad 'src'
0:00:04.455461701 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<capsfilter0> removing pad 'sink'
0:00:04.455587901 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<capsfilter0> parent class dispose
0:00:04.455685751 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<capsfilter0> finalize
0:00:04.455777001 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<capsfilter0> finalize parent
0:00:04.455882451 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking queue1:src(0x156708) and filesink0:sink(0x16e810)
0:00:04.456022201 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked queue1:src and filesink0:sink
0:00:04.456226601 1795 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "filesink0"
0:00:04.456348151 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<filesink0> dispose
0:00:04.456434551 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<filesink0> removing pad 'sink'
0:00:04.456555801 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<filesink0> parent class dispose
0:00:04.456657851 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<filesink0> finalize
0:00:04.456746901 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<filesink0> finalize parent
0:00:04.456849851 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking avimux0:src(0x156578) and queue1:sink(0x156640)
0:00:04.456986351 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked avimux0:src and queue1:sink
0:00:04.457151051 1795 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "queue1"
0:00:04.457270451 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<queue1> dispose
0:00:04.457357451 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<queue1> removing pad 'src'
0:00:04.457517001 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<queue1> removing pad 'sink'
0:00:04.794222100 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<queue1> parent class dispose
0:00:04.794333900 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<queue1> finalize
0:00:04.794423250 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<queue1> finalize parent
0:00:04.794523100 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking queue0:src(0x1564b0) and avimux0:video_00(0x16ea68)
0:00:04.794664050 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked queue0:src and avimux0:video_00
0:00:04.794836750 1795 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "avimux0"
0:00:04.794984401 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<avimux0> dispose
0:00:04.795073901 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<avimux0> removing pad 'video_00'
0:00:04.795171101 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<avimux0> removing pad 'src'
0:00:04.795308551 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<avimux0> parent class dispose
0:00:04.795496401 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<avimux0> finalize
0:00:04.795619051 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<avimux0> finalize parent
0:00:04.795746851 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking omxh264enc0:src(0x156320) and queue0:sink(0x1563e8)
0:00:04.795892151 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked omxh264enc0:src and queue0:sink
0:00:04.796062801 1795 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "queue0"
0:00:04.796182551 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<queue0> dispose
0:00:04.796269051 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<queue0> removing pad 'src'
0:00:04.796404401 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<queue0> removing pad 'sink'
0:00:04.796538401 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<queue0> parent class dispose
0:00:04.796638501 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<queue0> finalize
0:00:04.796727151 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<queue0> finalize parent
0:00:04.796828251 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1713:gst_pad_unlink: unlinking omxbufferalloc0:src(0x156190) and omxh264enc0:sink(0x156258)
0:00:05.132271100 1795 0x16050 INFO GST_ELEMENT_PADS gstpad.c:1758:gst_pad_unlink: unlinked omxbufferalloc0:src and omxh264enc0:sink
0:00:05.132457650 1795 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "omxh264enc0"
0:00:05.132583400 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<omxh264enc0> dispose
0:00:05.132671850 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<omxh264enc0> removing pad 'src'
0:00:05.132796100 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<omxh264enc0> removing pad 'sink'
0:00:05.132914950 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<omxh264enc0> parent class dispose
0:00:05.133029200 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<omxh264enc0> finalize
0:00:05.133118600 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<omxh264enc0> finalize parent
0:00:05.133231950 1795 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "omxbufferalloc0"
0:00:05.133349300 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<omxbufferalloc0> dispose
0:00:05.133435150 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<omxbufferalloc0> removing pad 'src'
0:00:05.133596750 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<omxbufferalloc0> removing pad 'sink'
0:00:05.133735200 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<omxbufferalloc0> parent class dispose
0:00:05.133827700 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<omxbufferalloc0> finalize
0:00:05.133916350 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<omxbufferalloc0> finalize parent
0:00:05.134026750 1795 0x16050 INFO GST_PARENTAGE gstbin.c:1440:gst_bin_remove_func:<pipeline0> removed child "v4l2src0"
0:00:05.134170250 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<v4l2src0> dispose
0:00:05.134257350 1795 0x16050 INFO GST_ELEMENT_PADS gstelement.c:835:gst_element_remove_pad:<v4l2src0> removing pad 'src'
0:00:05.134375000 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<v4l2src0> parent class dispose
0:00:05.134556950 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<v4l2src0> finalize
0:00:05.134653350 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<v4l2src0> finalize parent
0:00:05.470265900 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2955:gst_element_dispose:<pipeline0> dispose
0:00:05.470405150 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:2979:gst_element_dispose:<pipeline0> parent class dispose
0:00:05.470500350 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3010:gst_element_finalize:<pipeline0> finalize
0:00:05.470590250 1795 0x16050 INFO GST_REFCOUNTING gstelement.c:3021:gst_element_finalize:<pipeline0> finalize parent
0:00:05.470685000 1795 0x16050 INFO GST_INIT gst.c:1010:gst_deinit: deinitializing GStreamer
0:00:05.495808101 1795 0x16050 INFO GST_INIT gst.c:1113:gst_deinit: deinitialized GStreamer
