AM572x EEPROM
Other Parts Discussed in Thread: AM5728
We have a custom board based on am5728 gpevm, we also have eeprom similar to evm on board, how do we write the board name to the eeprom frm uboot, our uboot recognizes our brd as UKNOWN(beagle-x15?), So what  other parameters are  stored in e eeprom other than board name?  Is the uboot doing the pin mus and selecting the dts based on this board name? For some reason we r not getting pclk , hsync , vsync on vout1 port of our brd, does our brd pin mux is configured for bb-x15 ? Which dnt have an lcd?
Regards suhas
    Have a look at ti_am_eeprom structutre in board/ti/common/include/board_detect.h:
    * struct ti_am_eeprom - This structure holds data read in from the
    * AM335x, AM437x, AM57xx TI EVM EEPROMs.
    * @header: This holds the magic number
    * @name: The name of the board
    * @version: Board revision
    * @serial: Board serial number
    * @config: Reserved
    * @mac_addr: Any MAC addresses written in the EEPROM
    * The data is this structure is read from the EEPROM on the board.
    * It is used for board detection which is based on name. It is used
    * to configure specific TI boards. This allows booting of multiple
    * TI boards with a single MLO and u-boot.
    You could check that by tracking what is happening in board/ti/am57xx/board.c. If this is the case, then you could add the settings for pclk, hsync, vsync under the bb-x15 part of the board init.
    Yordan
  • Thnx for the timely reply, im not able to write to the eeprom on our brd, its interfaced to processor on i2c bus 0, i have pulled down the writecprotect, our eeprom addr is 50, pulled down all addr bits of eeprom, in uboot i give the command U-Boot# i2c dev 1
    Setting bus to 1
    U-Boot# i2c dev 0
    Setting bus to 0
    U-Boot# i2c md 0x50 0 0x10
    0000: ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ff ................
    U-Boot# i2c mm 0x50 0
    00000000: ff ? AA
    00000001: ff ? BB
    00000002: ff ? CC
    00000003: ff ? DD
    00000004: ff ? U-Boot# <INTERRUPT>
    U-Boot# <INTERRUPT>
    U-Boot#
    U-Boot#
    U-Boot#
    U-Boot# i2c mw 0x50 0 0x10 0xAA
    Y this happening, is the uboot buggy? How do we write frm linux user space then?
  • Do you have the i2c part of u-boot (board/ti/am57xx/board.c) code updated?
    What is the output of i2c probe?
    Yordan
