Task question for the new guy
Hi
I have added this to an empty RTOS project.  Why is the task not running?
Kind regards
 *  ======== empty.c ========
/* XDCtools Header files */
#include <xdc/std.h>
#include <xdc/runtime/System.h>
/* BIOS Header files */
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Clock.h>
#include <ti/sysbios/knl/Task.h>
/* TI-RTOS Header files */
// #include <ti/drivers/I2C.h>
#include <ti/drivers/PIN.h>
// #include <ti/drivers/SPI.h>
// #include <ti/drivers/UART.h>
// #include <ti/drivers/Watchdog.h>
/* Board Header files */
#include "Board.h"
#define TASKSTACKSIZE   512
Task_Struct task0Struct;
Char task0Stack[TASKSTACKSIZE];
Task_Struct task1Struct;
Char task1Stack[TASKSTACKSIZE];
/* Pin driver handle */
static PIN_Handle ledPinHandle;
static PIN_State ledPinState;
uint8_t  g_configPinStatus=0;
uint8_t  g_currentState=0;
 * Application LED pin configuration table:
 *   - All LEDs board LEDs are off.
PIN_Config ledPinTable[] = {
    Board_LED0 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    Board_LED1 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
	Board_LED2 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
	    Board_LED3 | PIN_GPIO_OUTPUT_EN | PIN_GPIO_LOW | PIN_PUSHPULL | PIN_DRVSTR_MAX,
    PIN_TERMINATE
 *  ======== heartBeatFxn ========
 *  Toggle the Board_LED0. The Task_sleep is determined by arg0 which
 *  is configured for the heartBeat Task instance.
Void heartBeatFxn(UArg arg0, UArg arg1)
    while (1) {
        Task_sleep((UInt)arg0);
        PIN_setOutputValue(ledPinHandle, Board_LED0,
                           !PIN_getOutputValue(Board_LED0));
        System_printf("Now In hearBeat");
 *  ======== CheckCfgPin ========
 *  Check Cfg Pin
Void checkCFGPin(UArg arg0, UArg arg1)
    while (1)
    	g_configPinStatus = PIN_getInputValue(EnableConfig);
    	System_printf("Now in checkCfg");
    	if(g_configPinStatus&1 == 1)
    		PIN_setOutputValue(ledPinHandle, Board_LED2,
    		                           !PIN_getOutputValue(Board_LED2));
 *  ======== main ========
int main(void)
    Task_Params taskParams;
    Task_Params cfgChkTsk;
    /* Call board init functions */
    Board_initGeneral();
    // Board_initI2C();
    // Board_initSPI();
    // Board_initUART();
    // Board_initWatchdog();
    /* Construct heartBeat Task  thread */
    Task_Params_init(&taskParams);
    taskParams.arg0 = 1000000 / Clock_tickPeriod;
    taskParams.stackSize = TASKSTACKSIZE;
    taskParams.stack = &task0Stack;
    Task_construct(&task0Struct, (Task_FuncPtr)heartBeatFxn, &taskParams, NULL);
    Task_Params_init(&cfgChkTsk);
    cfgChkTsk.arg0 = 5000000 / Clock_tickPeriod;
    cfgChkTsk.stackSize = TASKSTACKSIZE;
    cfgChkTsk.stack = &task0Stack;
	Task_construct(&task1Struct, (Task_FuncPtr)checkCFGPin, &cfgChkTsk, NULL);
    /* Open LED pins */
    ledPinHandle = PIN_open(&ledPinState, ledPinTable);
    if(!ledPinHandle) {
        System_abort("Error initializing board LED pins\n");
    //PIN_setOutputValue(ledPinHandle, Board_LED1, 1);
    System_printf("Starting the example\nSystem provider is set to SysMin. "
                  "Halt the target to view any SysMin contents in ROV.\n");
    /* SysMin will only print to the console when you call flush or exit */
    System_flush();
    /* Start BIOS */
    BIOS_start();
    return (0);
Ben
