I have followed the basic tutorial to run TI-RTOS on IAR 7.40. I am able to run and import the example to the IAR compiler. But I am having the following problem with the "even_EK_TM4C1294CL_TI" example
This example works fine when run on the CCS compiler. but in IAR it shows following errors
Error[Li005]: no definition for "ti_sysbios_knl_Event_construct" [referenced from L:\TiRTOS\ExampleOne\Debug\Obj\event.o]
Error[Li005]: no definition for "ti_sysbios_knl_Mailbox_construct" [referenced from L:\TiRTOS\ExampleOne\Debug\Obj\event.o]
When I checked the CCS compiler I found that during pre-compiling a file "event_pem4f.c" is created and in that file, the definition of above functions are written. But IAR does not create this file and shows error.
How can this issue be solved? What I am not doing what is causing this issue?
