I have a custom board that uses the AM3352 processor. Everything is working except the GPIO pin mapping. The only GPIO bank that works correctly is GPIO 96-127. This is mapped with a modified am335x-evmsk.dts file that I'm using to test my board functionality. If I load the beaglebone black am335x-boneblack.dtb file on the same os and board the GPIO address is correct. Below is a bit of detail of my system.
Linux: Custom built with yocto
dts: Modified am335x-evmsk.dts (attached below)
Have tried with ti-linux-processor-sdk as well with same results. Thus concluding that it must be my dts file.
Output from board with BBB dtb:
root@beaglebone:~# cat /sys/kernel/debug/gpio GPIOs 0-31, platform/44e07000.gpio, gpio: gpio-6 ( |cd ) in lo IRQ GPIOs 32-63, platform/4804c000.gpio, gpio: gpio-53 ( |? ) out lo gpio-54 ( |? ) out lo gpio-55 ( |? ) out hi gpio-56 ( |? ) out lo GPIOs 64-95, platform/481ac000.gpio, gpio: GPIOs 96-127, platform/481ae000.gpio, gpio:
As you can see the address is correct. Output with custom dtb file:
GPIOs 0-31, platform/481ac000.gpio, gpio: GPIOs 32-63, platform/44e07000.gpio, gpio: gpio-38 ( |cd ) in lo IRQ GPIOs 64-95, platform/4804c000.gpio, gpio: GPIOs 96-127, platform/481ae000.gpio, gpio: gpio-114 ( |sysfs ) out hi gpio-115 ( |sysfs ) out hi gpio-116 ( |sysfs ) out hi
Here the first three GPIO blocks are incorrect. But I am able to control GPIO's 96-127.
DTS:
/dts-v1/; #include "am33xx.dtsi" #include <dt-bindings/pwm/pwm.h> #include <dt-bindings/interrupt-controller/irq.h> / { model = "TI AM335x EVM-SK"; compatible = "ti,am335x-evmsk", "ti,am33xx"; cpus { cpu@0 { cpu0-supply = <&vdd1_reg>; }; }; memory { device_type = "memory"; reg = <0x80000000 0x10000000>; /* 256 MB */ }; vbat: fixedregulator@0 { compatible = "regulator-fixed"; regulator-name = "vbat"; regulator-min-microvolt = <5000000>; regulator-max-microvolt = <5000000>; regulator-boot-on; }; panel { compatible = "ti,tilcdc,panel"; pinctrl-names = "default", "sleep"; pinctrl-0 = <&lcd_pins_default>; status = "okay"; panel-info { ac-bias = <255>; ac-bias-intrpt = <0>; dma-burst-sz = <16>; bpp = <16>; fdd = <0x80>; sync-edge = <0>; sync-ctrl = <1>; raster-order = <0>; fifo-th = <0>; }; display-timings { 320x240 { hactive = <320>; vactive = <240>; hback-porch = <5>; hfront-porch = <58>; hsync-len = <47>; vback-porch = <11>; vfront-porch = <23>; vsync-len = <2>; clock-frequency = <12000000>; hsync-active = <0>; vsync-active = <0>; }; }; }; }; &am33xx_pinmux { lcd_pins_default: pinmux_lcd_pins_default { pinctrl-single,pins = < 0xe0 ( PIN_OUTPUT | MUX_MODE0 ) /* (U5) lcd_vsync.lcd_vsync */ 0xe4 ( PIN_OUTPUT | MUX_MODE0 ) /* (R5) lcd_hsync.lcd_hsync */ 0xe8 ( PIN_OUTPUT | MUX_MODE0 ) /* (V5) lcd_pclk.lcd_pclk */ 0xec ( PIN_OUTPUT | MUX_MODE0 ) /* (R6) lcd_ac_bias_en.lcd_ac_bias_en */ 0xa0 ( PIN_OUTPUT | MUX_MODE0 ) /* (R1) lcd_data0.lcd_data0 */ 0xa4 ( PIN_OUTPUT | MUX_MODE0 ) /* (R2) lcd_data1.lcd_data1 */ 0xa8 ( PIN_OUTPUT | MUX_MODE0 ) /* (R3) lcd_data2.lcd_data2 */ 0xac ( PIN_OUTPUT | MUX_MODE0 ) /* (R4) lcd_data3.lcd_data3 */ 0xb0 ( PIN_OUTPUT | MUX_MODE0 ) /* (T1) lcd_data4.lcd_data4 */ 0xb4 ( PIN_OUTPUT | MUX_MODE0 ) /* (T2) lcd_data5.lcd_data5 */ 0xb8 ( PIN_OUTPUT | MUX_MODE0 ) /* (T3) lcd_data6.lcd_data6 */ 0xbc ( PIN_OUTPUT | MUX_MODE0 ) /* (T4) lcd_data7.lcd_data7 */ 0xc0 ( PIN_OUTPUT | MUX_MODE0 ) /* (U1) lcd_data8.lcd_data8 */ 0xc4 ( PIN_OUTPUT | MUX_MODE0 ) /* (U2) lcd_data9.lcd_data9 */ 0xc8 ( PIN_OUTPUT | MUX_MODE0 ) /* (U3) lcd_data10.lcd_data10 */ 0xcc ( PIN_OUTPUT | MUX_MODE0 ) /* (U4) lcd_data11.lcd_data11 */ 0xd0 ( PIN_OUTPUT | MUX_MODE0 ) /* (V2) lcd_data12.lcd_data12 */ 0xd4 ( PIN_OUTPUT | MUX_MODE0 ) /* (V3) lcd_data13.lcd_data13 */ 0xd8 ( PIN_OUTPUT | MUX_MODE0 ) /* (V4) lcd_data14.lcd_data14 */ 0xdc ( PIN_OUTPUT | MUX_MODE0 ) /* (T5) lcd_data15.lcd_data15 */ >; }; emmc_pins_default: pinmux_emmc_pins_default { pinctrl-single,pins = < 0x80 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */ 0x84 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */ 0x00 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */ 0x04 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */ 0x08 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */ 0x0c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */ 0x10 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad4.mmc1_dat4 */ 0x14 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad5.mmc1_dat5 */ 0x18 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad6.mmc1_dat6 */ 0x1c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad7.mmc1_dat7 */ >; //0x74 (PIN_INPUT_PULLUP | MUX_MODE7) /* gpmc_wpn.gpio0_31 */ //0x80 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn1.mmc1_clk */ //0x84 (PIN_INPUT_PULLUP | MUX_MODE2) /* gpmc_csn2.mmc1_cmd */ //0x00 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad0.mmc1_dat0 */ //0x04 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad1.mmc1_dat1 */ //0x08 (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad2.mmc1_dat2 */ //0x0c (PIN_INPUT_PULLUP | MUX_MODE1) /* gpmc_ad3.mmc1_dat3 */ }; cpsw_default: cpsw_default { pinctrl-single,pins = < /* Slave 1 */ 0x110 (PIN_INPUT_PULLUP | MUX_MODE0) /* mii1_rxerr.mii1_rxerr */ 0x114 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mii1_txen.mii1_txen */ 0x118 (PIN_INPUT_PULLUP | MUX_MODE0) /* mii1_rxdv.mii1_rxdv */ 0x11c (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mii1_txd3.mii1_txd3 */ 0x120 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mii1_txd2.mii1_txd2 */ 0x124 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mii1_txd1.mii1_txd1 */ 0x128 (PIN_OUTPUT_PULLDOWN | MUX_MODE0) /* mii1_txd0.mii1_txd0 */ 0x12c (PIN_INPUT_PULLUP | MUX_MODE0) /* mii1_txclk.mii1_txclk */ 0x130 (PIN_INPUT_PULLUP | MUX_MODE0) /* mii1_rxclk.mii1_rxclk */ 0x134 (PIN_INPUT_PULLUP | MUX_MODE0) /* mii1_rxd3.mii1_rxd3 */ 0x138 (PIN_INPUT_PULLUP | MUX_MODE0) /* mii1_rxd2.mii1_rxd2 */ 0x13c (PIN_INPUT_PULLUP | MUX_MODE0) /* mii1_rxd1.mii1_rxd1 */ 0x140 (PIN_INPUT_PULLUP | MUX_MODE0) /* mii1_rxd0.mii1_rxd0 */ >; }; davinci_mdio_default: davinci_mdio_default { pinctrl-single,pins = < /* MDIO */ 0x148 (PIN_INPUT_PULLUP | SLEWCTRL_FAST | MUX_MODE0) /* mdio_data.mdio_data */ 0x14c (PIN_OUTPUT_PULLUP | MUX_MODE0) /* mdio_clk.mdio_clk */ >; }; mmc1_pins: pinmux_mmc1_pins { pinctrl-single,pins = < 0x160 (PIN_INPUT | MUX_MODE7) /* GPIO0_6 */ >; }; microsd_pins_default: pinmux_microsd_pins_default { pinctrl-single,pins = < 0x100 ( PIN_INPUT | MUX_MODE0 ) /* (G17) mmc0_clk.mmc0_clk */ 0x104 ( PIN_OUTPUT | MUX_MODE0 ) /* (G18) mmc0_cmd.mmc0_cmd */ 0xfc ( PIN_INPUT | MUX_MODE0 ) /* (G16) mmc0_dat0.mmc0_dat0 */ 0xf8 ( PIN_INPUT | MUX_MODE0 ) /* (G15) mmc0_dat1.mmc0_dat1 */ 0xf4 ( PIN_INPUT | MUX_MODE0 ) /* (F18) mmc0_dat2.mmc0_dat2 */ 0xf0 ( PIN_INPUT | MUX_MODE0 ) /* (F17) mmc0_dat3.mmc0_dat3 */ 0x160 ( PIN_INPUT | MUX_MODE5 ) /* (C15) spi0_cs1.mmc0_sdcd */ >; }; i2c0_pins_default: pinmux_i2c0_pins_default { pinctrl-single,pins = < 0x18c ( PIN_INPUT | MUX_MODE0 ) /* (C16) I2C0_SCL.I2C0_SCL */ 0x188 ( PIN_INPUT | MUX_MODE0 ) /* (C17) I2C0_SDA.I2C0_SDA */ >; }; uart0_pins_default: pinmux_uart0_pins_default { pinctrl-single,pins = < 0x170 ( PIN_INPUT | MUX_MODE0 ) /* (E15) uart0_rxd.uart0_rxd */ 0x174 ( PIN_OUTPUT | MUX_MODE0 ) /* (E16) uart0_txd.uart0_txd */ >; }; uart1_pins_default: pinmux_uart1_pins_default { pinctrl-single,pins = < 0x180 ( PIN_INPUT | MUX_MODE0 ) /* (D16) uart1_rxd.uart1_rxd */ 0x184 ( PIN_OUTPUT | MUX_MODE0 ) /* (D15) uart1_txd.uart1_txd */ >; }; uart2_pins_default: pinmux_uart2_pins_default { pinctrl-single,pins = < 0x150 ( PIN_INPUT | MUX_MODE1 ) /* (A17) spi0_sclk.uart2_rxd */ 0x154 ( PIN_OUTPUT | MUX_MODE1 ) /* (B17) spi0_d0.uart2_txd */ >; }; uart4_pins_default: pinmux_uart4_pins_default { pinctrl-single,pins = < 0x70 ( PIN_INPUT | MUX_MODE6 ) /* (T17) gpmc_wait0.uart4_rxd */ 0x74 ( PIN_OUTPUT | MUX_MODE6 ) /* (U17) gpmc_wpn.uart4_txd */ >; }; gpio0_pins_default: pinmux_gpio0_pins_default { pinctrl-single,pins = < 0x20 ( PIN_INPUT | MUX_MODE7 ) /* (U10) gpmc_ad8.gpio0[22] */ 0x24 ( PIN_INPUT | MUX_MODE7 ) /* (T10) gpmc_ad9.gpio0[23] */ 0x28 ( PIN_INPUT | MUX_MODE7 ) /* (T11) gpmc_ad10.gpio0[26] */ 0x2c ( PIN_INPUT | MUX_MODE7 ) /* (U12) gpmc_ad11.gpio0[27] */ >; }; gpio1_pins_default: pinmux_gpio1_pins_default { pinctrl-single,pins = < 0x30 ( PIN_INPUT | MUX_MODE7 ) /* (T12) gpmc_ad12.gpio1[12] */ 0x34 ( PIN_INPUT | MUX_MODE7 ) /* (R12) gpmc_ad13.gpio1[13] */ 0x38 ( PIN_INPUT | MUX_MODE7 ) /* (V13) gpmc_ad14.gpio1[14] */ 0x3c ( PIN_INPUT | MUX_MODE7 ) /* (U13) gpmc_ad15.gpio1[15] */ 0x40 ( PIN_INPUT | MUX_MODE7 ) /* (R13) gpmc_a0.gpio1[16] */ 0x48 ( PIN_INPUT | MUX_MODE7 ) /* (U14) gpmc_a2.gpio1[18] */ 0x78 ( PIN_INPUT | MUX_MODE7 ) /* (U18) gpmc_be1n.gpio1[28] */ >; }; gpio3_pins_default: pinmux_gpio3_pins_default { pinctrl-single,pins = < 0x1a0 ( PIN_INPUT | MUX_MODE7 ) /* (B12) mcasp0_aclkr.gpio3[18] */ 0x1a4 ( PIN_INPUT | MUX_MODE7 ) /* (C13) mcasp0_fsr.gpio3[19] */ 0x1a8 ( PIN_INPUT | MUX_MODE7 ) /* (D13) mcasp0_axr1.gpio3[20] */ >; }; spi1_pins_default: pinmux_spi1_pins_default { pinctrl-single,pins = < 0x190 ( PIN_OUTPUT | MUX_MODE3 ) /* (A13) mcasp0_aclkx.spi1_sclk */ 0x194 ( PIN_OUTPUT | MUX_MODE3 ) /* (B13) mcasp0_fsx.spi1_d0 */ 0x198 ( PIN_OUTPUT | MUX_MODE3 ) /* (D12) mcasp0_axr0.spi1_d1 */ 0x19c ( PIN_OUTPUT | MUX_MODE3 ) /* (C12) mcasp0_ahclkr.spi1_cs0 */ >; }; }; &spi1 { pinctrl-names = "default"; pinctrl-0 = <&spi1_pins_default>; status = "okay"; lcd-control@0 { compatible = "linux,spidev"; spi-max-frequency = <1000000>; reg = <0>; }; }; &gpio0 { pinctrl-names = "default"; pinctrl-0 = <&gpio0_pins_default>; status = "okay"; }; &gpio1 { pinctrl-names = "default"; pinctrl-0 = <&gpio1_pins_default>; status = "okay"; }; &gpio3 { pinctrl-names = "default"; pinctrl-0 = <&gpio3_pins_default>; status = "okay"; }; &uart0 { pinctrl-names = "default"; pinctrl-0 = <&uart0_pins_default>; status = "okay"; }; &uart1 { pinctrl-names = "default"; pinctrl-0 = <&uart1_pins_default>; status = "okay"; }; &uart2 { pinctrl-names = "default"; pinctrl-0 = <&uart2_pins_default>; status = "okay"; }; &uart4 { pinctrl-names = "default"; pinctrl-0 = <&uart4_pins_default>; status = "okay"; }; &i2c0 { pinctrl-names = "default"; pinctrl-0 = <&i2c0_pins_default>; status = "okay"; clock-frequency = <400000>; tps: tps@2d { reg = <0x2d>; }; }; &wkup_m3_ipc { ti,needs-vtt-toggle; ti,vtt-gpio-pin = <7>; ti,scale-data-fw = "am335x-evm-scale-data.bin"; }; #include "tps65910.dtsi" &tps { vcc1-supply = <&vbat>; vcc2-supply = <&vbat>; vcc3-supply = <&vbat>; vcc4-supply = <&vbat>; vcc5-supply = <&vbat>; vcc6-supply = <&vbat>; vcc7-supply = <&vbat>; vccio-supply = <&vbat>; regulators { vrtc_reg: regulator@0 { regulator-always-on; }; vio_reg: regulator@1 { regulator-always-on; }; vdd1_reg: regulator@2 { /* VDD_MPU voltage limits 0.95V - 1.26V with +/-4% tolerance */ regulator-name = "vdd_mpu"; regulator-min-microvolt = <912500>; regulator-max-microvolt = <1351500>; regulator-boot-on; regulator-always-on; }; vdd2_reg: regulator@3 { /* VDD_CORE voltage limits 0.95V - 1.1V with +/-4% tolerance */ regulator-name = "vdd_core"; regulator-min-microvolt = <912500>; regulator-max-microvolt = <1150000>; regulator-boot-on; regulator-always-on; }; vdd3_reg: regulator@4 { regulator-always-on; }; vdig1_reg: regulator@5 { regulator-always-on; }; vdig2_reg: regulator@6 { regulator-always-on; }; vpll_reg: regulator@7 { regulator-always-on; }; vdac_reg: regulator@8 { regulator-always-on; }; vaux1_reg: regulator@9 { regulator-always-on; }; vaux2_reg: regulator@10 { regulator-always-on; }; vaux33_reg: regulator@11 { regulator-always-on; }; vmmc_reg: regulator@12 { regulator-min-microvolt = <3300000>; regulator-max-microvolt = <3300000>; regulator-always-on; }; }; }; &cpsw_emac0 { phy_id = <&davinci_mdio>, <0>; phy-mode = "mii"; }; &mac { pinctrl-names = "default"; pinctrl-0 = <&cpsw_default>; status = "okay"; }; &davinci_mdio { pinctrl-names = "default"; pinctrl-0 = <&davinci_mdio_default>; status = "okay"; }; &mmc1 { vmmc-supply = <&vmmc_reg>; bus-width = <0x4>; pinctrl-names = "default"; pinctrl-0 = <&mmc1_pins>; cd-gpios = <&gpio0 6 GPIO_ACTIVE_LOW>; status = "okay"; }; &mmc2 { vmmc-supply = <&vmmc_reg>; bus-width = <8>; pinctrl-names = "default"; pinctrl-0 = <&emmc_pins_default>; status = "okay"; }; &sham { status = "okay"; }; &aes { status = "okay"; }; &lcdc { status = "okay"; }; &rtc { system-power-controller; };
The other pins that I have muxed also work, The LCD, SPI, I2C0, and uarts have no problem. I it must be something with my dts and the GPIO's.
Any help or advice is greatly appreciated, and thank in advance.
