TDA3: Frame drop Issue in TDA3x RVP
Part Number: TDA3
Hi ,
We are stuck with issue and Unable to proceed. Need immediate help on this.
Description:
Board : TDA3x RVP,
Vision SDK version: 2.10
Use case:
UseCase: chains_SingleCam_DHTSDisplay
IssCapture -> IssM2mIsp -> Dup_alg -> Merge_DHTS
Dup_alg -> Alg_EveDHTS (EVE1) -> Alg_DHTS (DSP1) -> Merge_DHTS -> Sync_DHTS -> Alg_DHTSDraw -> Dup_Output
Dup_Output -> Display_Video
Dup_Output -> Null (IPU1_1)
GrpxSrc -> Display_Grpx
When we completely disable our algorithm process in DSP1 , we do not see any frame drops and all links are processing at 30fps.
Even small amount processing is carried out in DSP1,the frames are getting dropped in IssM2mIsp link to 15.
Our algorithm processing on EVE and DSP1 is taking 21ms which is within limit(33ms).
Please find below Statics for Reference
More details can be found in the attached file.
IssCapture is at 30 fps
The processing time taken in EVE1 is 12 ms(aprox)
The processing time taken in DSP1 is 9 ms(aprox)
 DSM_EVE_2.txt
Roja
