hi,
I want to run 3.125Gbps SRIO,I have 250MHz reference clock. lane0 and lane1 is X2 ;lane2 and lane3 is X2.
I use SRIO_LoopbackDioIsrexampleproject in pdk6678.
I modify some code of function int32_t SrioDevice_init (void) in device_srio_loopback.c .
// CSL_SRIO_SetLoopbackMode(hSrio, 0); // CSL_SRIO_SetLoopbackMode(hSrio, 1); // CSL_SRIO_SetLoopbackMode(hSrio, 2); // CSL_SRIO_SetLoopbackMode(hSrio, 3); CSL_SRIO_SetNormalMode(hSrio, 0); CSL_SRIO_SetNormalMode(hSrio, 1); CSL_SRIO_SetNormalMode(hSrio, 2); CSL_SRIO_SetNormalMode(hSrio, 3);
// /* Assuming the link rate is 2500; program the PLL accordingly. */ // CSL_BootCfgSetSRIOSERDESConfigPLL (0x233); // // /* Configure the SRIO SERDES Receive Configuration. */ // CSL_BootCfgSetSRIOSERDESRxConfig (0, 0x004404a5); // CSL_BootCfgSetSRIOSERDESRxConfig (1, 0x004404a5); // CSL_BootCfgSetSRIOSERDESRxConfig (2, 0x004404a5); // CSL_BootCfgSetSRIOSERDESRxConfig (3, 0x004404a5); // // /* Configure the SRIO SERDES Transmit Configuration. */ // CSL_BootCfgSetSRIOSERDESTxConfig (0, 0x001807a5); // CSL_BootCfgSetSRIOSERDESTxConfig (1, 0x001807a5); // CSL_BootCfgSetSRIOSERDESTxConfig (2, 0x001807a5); // CSL_BootCfgSetSRIOSERDESTxConfig (3, 0x001807a5); // Set the link rate is 3.125G; program the PLL accordingly. */ CSL_BootCfgSetSRIOSERDESConfigPLL (0x065); /* Configure the SRIO SERDES Receive Configuration. */ CSL_BootCfgSetSRIOSERDESRxConfig (0, 0x004404a5); CSL_BootCfgSetSRIOSERDESRxConfig (1, 0x004404a5); CSL_BootCfgSetSRIOSERDESRxConfig (2, 0x004404a5); CSL_BootCfgSetSRIOSERDESRxConfig (3, 0x004404a5); /* Configure the SRIO SERDES Transmit Configuration. */ CSL_BootCfgSetSRIOSERDESTxConfig (0, 0x001807a5); CSL_BootCfgSetSRIOSERDESTxConfig (1, 0x001807a5); CSL_BootCfgSetSRIOSERDESTxConfig (2, 0x001807a5); CSL_BootCfgSetSRIOSERDESTxConfig (3, 0x001807a5);
/* Configure the path mode for the ports. */ for(i = 0; i < 4; i++) CSL_SRIO_SetPLMPortPathControlMode (hSrio, i, 3);
#ifndef SIMULATOR_SUPPORT /* This code checks if the ports are operational or not. The functionality is not supported * on the simulator. */ //for(i = 0; i < 4; i++) //Tj : set lane A and B is X2; set lane C and D is X2; while (CSL_SRIO_IsPortOk (hSrio, 0) != TRUE); // while (CSL_SRIO_IsPortOk (hSrio, i) != TRUE); #endif
the function will stuck in
I read
For example, for 3.125Gbps data, a refclk of 312.5Mhz or 156.25Mhz or 125MHz is needed.
in page 36 in KeyStone Architecture Serial Rapid IO (SPRUGW1B).
Can 6670 run SRIO 3.125Gbps with SRIOSGMIICLK 250MHz?
