RTOS/TDA3: Application files to consider when TI-RTOS project configuration file "*.cfg" file had been changed
Part Number: TDA3
Tool/software: TI-RTOS
Gents,
when modification of the central "*.cfg" project file is required even the C/C++ application related source files may need to be re-build (see the RTSC build process attached). Hence, modification of the *.cfg file results in re-build all command.
Can you express/summarize conditions custom specific C/C++ files would not need to be re-build while changes to *.cfg takes place?
In other words, we want to make changes to *.cfg file but do not want to build all application related files again. Do you see risk here?
Thorsten
