AM3352: NAND boot issue
Part Number: AM3352
we already have a working design with this NAND chip:
www.cypress.com/.../s34ml04g100bhi000
Due to availability issues we tried its newer cousin on two devices:
www.cypress.com/.../s34ml04g200bhi000
Once the bootloader starts from Ethernet (SYSBOOT[4:0] is 10100, i.e. NAND first, Ethernet last), flashing the new NAND works without errors (using the ECC option BCH8) and the flashed Linux can also be booted successfully.
But after a reboot the device boots from Ethernet again, i.e. the RBL doesn't seem to find the bootloader on the NAND.
I suspect that the different amount of spare bytes (here called "OOB size") of the two chips could be the issue:
nand: NAND device: Manufacturer ID: 0x01, Chip ID: 0xdc (AMD/Spansion S34ML04G1), 512MiB, page size: 2048, OOB size: 64
nand: NAND device: Manufacturer ID: 0x01, Chip ID: 0xdc (AMD/Spansion S34ML04G2), 512MiB, page size: 2048, OOB size: 128
Because according to the AM335x Technical Reference Manual 26.1.7.4.1:
Support for large page size (2048 bytes + 64 spare bytes)
I am I correct and are we out of luck with the newer NAND or might something else be the issue here?
Thanks in advance!
    The ROM bootloader configures the GPMC ELM module for ECC calculation according to the OOB size. The algorithm used is this:
    Thus for OOB=64b BCH8 is applied, while for OOB=128b it's BCH16. What you need to do is flash the new NAND with BCH16.
  • Hello Biser,
    sorry for the late reply and thanks for your answer.
    One reason for the delay is that our bootloader (Barebox) doesn't handle BCH16 and I haven't managed to get it working yet.
    While I went through the code, I noticed why a Micron flash with 4K pages also didn't work: The driver is configuring a fixed page size of 2K...
    I expect the fixes to take a while. I'll let you know once I'm actually finished.
    Thanks again.
