Part Number: AM5728
Tool/software: TI-RTOS
hi, base on AM5728 and rtos,I want use the dsp or M4 to use dmtimer,is there any demo or datum can be refered, thank you.
The timer test example is under pdk_am57xx_1_0_x\packages\ti\csl\example\timer, it is bare metal. In RTOS, the timer may be integrated into some driver for functionality, but not separate RTOS examples.
Attached is a standalone one we used on A15, the timer is setup in the .cfg file:
var Timer = xdc.useModule('ti.sysbios.timers.dmtimer.Timer');
var IntXbar = xdc.useModule('ti.sysbios.family.shared.vayu.IntXbar');
var TimerSupport = xdc.useModule('ti.sysbios.family.shared.vayu.TimerSupport');
TimerSupport.availMask = 0xF0FF;
var timer0Params = new Timer.Params();
timer0Params.instance.name = "timerTest";
timer0Params.period = 100000;
timer0Params.extFreq.lo = 20000000;
timer0Params.periodType = xdc.module("ti.sysbios.interfaces.ITimer").PeriodType_MICROSECS;
Program.global.timerOwn = Timer.create(5, "&TimerFunction", timer0Params); // ok
You can use the same for DSP or IPU.
Regards, Eric
