Part Number: DRA745
Tool/software: TI-RTOS
Hi, experts,
I encountered an issue that swms link frame drop. I add swms output buffer, but no effect. the log as below: Please help to check. and give some suggestions.
root@dra7xx-evm:~# cd /opt/vision_sdk/
root@dra7xx-evm:/opt/vision_sdk# ls
apps.out bin enableIpu2CCSConectivity.sh memcache_load.sh
autorun.sh disableDssInterruptsOnA15.sh gpufifo vision_sdk_load.sh
root@dra7xx-evm:/opt/vision_sdk# ./apps.out
[HOST] OSA: MEM: 0: Mapped 0x9fc00000 to 0xb6938000 of size 0x00100000
[HOST] OSA: MEM: 1: Mapped 0x84203000 to 0xa9738000 of size 0x0d200000
[HOST] OSA: MEM: 2: Mapped 0x9fd00000 to 0xa9678000 of size 0x00040000
[HOST] OSA: MEM: 3: Mapped 0x9fdc0000 to 0xa96b8000 of size 0x00080000
[HOST] OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000
[HOST] OSA: HOST Remote Log Shared Memory @ 0x9fd4f140
[HOST] OSA: IPU2 Remote Log Shared Memory @ 0x9fe63da0
59.708150] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
[ 59.747615] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
[ HOST] [HOST ] 74.501799 s: SYSTEM: System A15 Init in proress !!!
[HOST] [HOST ] 74.501891 s: SYSTEM: IPC: Init in progress !!!
[HOST] [HOST ] 74.501891 s: SYSTEM: IPC: Notify init in progress !!!
[HOST] [HOST ] 74.502165 s: SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81)
[HOST] [HOST ] 74.502196 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
[HOST] [HOST ] 74.502226 s: SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80)
[HOST] [HOST ] 74.502257 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
[HOST] [HOST ] 74.502409 s: SYSTEM: IPC: Notify init DONE !!!
[HOST] [HOST ] 74.502409 s: SYSTEM: MSGQ: MsgQ init in progress !!!
[HOST] [HOST ] 74.502531 s: SYSTEM: MSGQ: MsgQ init DONE !!!
[HOST] [HOST ] 74.502531 s: SYSTEM: IPC: Init DONE !!!
[HOST] [HOST ] 74.502531 s: SYSTEM: Initializing A15 Links !!!
[HOST] [HOST ] 74.502684 s: IPC_OUT_0 : Init done - linkid-0x2000000
[HOST] [HOST ] 74.502775 s: IPC_OUT_1 : Init done - linkid-0x2000001
[HOST] [HOST ] 74.502897 s: IPC_OUT_2 : Init done - linkid-0x2000002
[HOST] [HOST ] 74.503019 s: IPC_OUT_3 : Init done - linkid-0x2000003
[HOST] [HOST ] 74.503111 s: IPC_OUT_4 : Init done - linkid-0x2000004
[HOST] [HOST ] 74.503263 s: IPC_IN_0 : Init done - linkid-0x200000a
[HOST] [HOST ] 74.503385 s: IPC_IN_1 : Init done - linkid-0x200000b
[HOST] [HOST ] 74.503507 s: IPC_IN_2 : Init done - linkid-0x200000c
[HOST] [HOST ] 74.503629 s: IPC_IN_3 : Init done - linkid-0x200000d
[HOST] [HOST ] 74.503751 s: IPC_IN_4 : Init done - linkid-0x200000e
[HOST] [HOST ] 74.503873 s: IPC_IN_5 : Init done - linkid-0x200000f
[HOST] [HOST ] 74.503965 s: IPC_IN_6 : Init done - linkid-0x2000010
[HOST] [HOST ] 74.504087 s: NULL_0 : Init done - linkid-0x2000014
[HOST] [HOST ] 74.504178 s: NULL_1 : Init done - linkid-0x2000015
[HOST] [HOST ] 74.504331 s: NULL_SRC_0 : Init done - linkid-0x2000039
[HOST] [HOST ] 74.504483 s: DISP_DIST_SRC_0 : Init done - linkid-0x200005c
[HOST] [HOST ] 74.504575 s: DISP_DIST_SRC_1 : Init done - linkid-0x200005d
[HOST] [HOST ] 74.504697 s: DISP_DIST_SRC_2 : Init done - linkid-0x200005e
[HOST] [HOST ] 74.504788 s: DISP_DIST_SRC_3 : Init done - linkid-0x200005f
[HOST] [HOST ] 74.504880 s: DISP_DIST_SRC_4 : Init done - linkid-0x2000060
[HOST] [HOST ] 74.505063 s: DISP_DIST_SRC_5 : Init done - linkid-0x2000061
[HOST] [HOST ] 74.505246 s: DISP_DIST_SRC_6 : Init done - linkid-0x2000062
[HOST] [HOST ] 74.505368 s: DISP_DIST_SRC_7 : Init done - linkid-0x2000063
[HOST] [HOST ] 74.505734 s: ALGORITHM_0 : Init done - linkid-0x2000031
[HOST] [HOST ] 74.505917 s: ALGORITHM_1 : Init done - linkid-0x2000032
[HOST] [HOST ] 74.506100 s: ALGORITHM_2 : Init done - linkid-0x2000033
[HOST] [HOST ] 74.506283 s: ALGORITHM_3 : Init done - linkid-0x2000034
[HOST] [HOST ] 74.506466 s: ALGORITHM_4 : Init done - linkid-0x2000035
[HOST] [HOST ] 74.506649 s: ALGORITHM_5 : Init done - linkid-0x2000036
[HOST] [HOST ] 74.506832 s: ALGORITHM_6 : Init done - linkid-0x2000037
[HOST] [HOST ] 74.506984 s: ALGORITHM_7 : Init done - linkid-0x2000038
[HOST] [HOST ] 74.507228 s: DUP0 : Init done - linkid-0x0
[HOST] [HOST ] 74.507503 s: DUP1 : Init done - linkid-0x0
[HOST] [HOST ] 74.507747 s: DUP2 : Init done - linkid-0x0
[HOST] [HOST ] 74.507960 s: DUP3 : Init done - linkid-0x0
[HOST] [HOST ] 74.508204 s: DUP4 : Init done - linkid-0x0
[HOST] [HOST ] 74.508357 s: SYNC_0 : Init done - linkid-0x0
[HOST] [HOST ] 74.508509 s: SYNC_1 : Init done - linkid-0x0
[HOST] [HOST ] 74.508692 s: SYNC_2 : Init done - linkid-0x0
[HOST] [HOST ] 74.508875 s: SYNC_3 : Init done - linkid-0x0
[HOST] [HOST ] 74.509058 s: MERGE_0 : Init done - linkid-0x0
[HOST] [HOST ] 74.509241 s: MERGE_1 : Init done - linkid-0x0
[HOST] [HOST ] 74.509424 s: MERGE_2 : Init done - linkid-0x0
[HOST] [HOST ] 74.509546 s: MERGE_3 : Init done - linkid-0x0
[HOST] [HOST ] 74.509729 s: MERGE_4 : Init done - linkid-0x0
[HOST] [HOST ] 74.509882 s: SELECT_0 : Init done - linkid-0x0
[HOST] [HOST ] 74.510034 s: SELECT_1 : Init done - linkid-0x0
[HOST] [HOST ] 74.510156 s: GATE_0 : Init done - linkid-0x0
[HOST] [HOST ] 74.510248 s: GATE_1 : Init done - linkid-0x0
[HOST] [HOST ] 74.510370 s: GATE_2 : Init done - linkid-0x0
[HOST] [HOST ] 74.510492 s: GATE_3 : Init done - linkid-0x0
[HOST] [HOST ] 74.510614 s: SGXFRMCPY_0 : Init done - linkid-0x2000044
[HOST] [HOST ] 74.510644 s: SYSTEM: Initializing A15 Links ... DONE !!!
[HOST] [HOST ] 74.511010 s: OSA: Adjusting global time, timeH by 0 units!!!
[HOST] [HOST ] 74.511010 s: SYSTEM: System A15 Init Done !!!
[HOST] [HOST ] 74.511193 s: NETWORK_CTRL: Starting Server (port=5000) !!!
[HOST] [HOST ] 74.511254 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
[HOST] [IPU2 ] 23.254712 s: ***** IPU2 Firmware build time 11:17:50 Apr 10 2019
[HOST] [IPU2 ] 23.254895 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[HOST] [IPU2 ] 23.257091 s: ***** gpio modules enable ***********************
[HOST] [IPU2 ] 23.674403 s: SYSTEM: System Common Init in progress !!!
[HOST] [IPU2 ] 23.684041 s: UTILS: CIO: Init Done !!!
[HOST] [IPU2 ] 23.684133 s: SYSTEM: IPC init in progress !!!
[HOST] [IPU2 ] 23.684224 s: SYSTEM: Notify init done !!!
[HOST] [IPU2 ] 23.685963 s: SYSTEM: MsgQ init done !!!
[HOST] [IPU2 ] 23.686909 s: RpmsgInit in progress...
[HOST] [IPU2 ] 23.687000 s: Connection established with HLOS, calling rpmsgInit
[HOST] [IPU2 ] 23.687610 s: SYSTEM: IPC init DONE !!!
[HOST] [IPU2 ] 23.692704 s: SYSTEM: System Common Init Done !!!
[HOST] [IPU2 ] 23.692856 s: SYSTEM: System Init in progress !!!
[HOST] [IPU2 ] 23.692917 s: SYSTEM: BSP Common Init in progress !!!
[HOST] [IPU2 ] 23.693009 s: SYSTEM: BSP Common Init Done !!!
[HOST] [IPU2 ] 23.693070 s: SYSTEM: BSP Platform Init in progress !!!
[HOST] [IPU2 ] 23.693161 s: SYSTEM: BSP Platform Init Done !!!
[HOST] [IPU2 ] 23.693222 s: SYSTEM: FVID2 Init in progress !!!
[HOST] [IPU2 ] 23.693375 s: SYSTEM: FVID2 Init Done !!!
[HOST] [IPU2 ] 23.693436 s: SYSTEM: VPS Init in progress !!!
[HOST] [IPU2 ] 23.693497 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0xa0000000 -> 0x80000000]
[HOST] [IPU2 ] 23.696455 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 23.696577 s: VPDMA Firmware Address = 0x9fe5c4c0
[HOST] [IPU2 ] 23.696638 s: VPDMA Load Address = 0x4897d004
[HOST] [IPU2 ] 23.696791 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 23.696882 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 23.696974 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 23.697279 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 23.697370 s: VPDMA Firmware Address = 0x9fe5c4c0
[HOST] [IPU2 ] 23.697462 s: VPDMA Load Address = 0x4899d004
[HOST] [IPU2 ] 23.697553 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 23.697645 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 23.697736 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 23.698072 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 23.698163 s: VPDMA Firmware Address = 0x9fe5c4c0
[HOST] [IPU2 ] 23.698255 s: VPDMA Load Address = 0x489bd004
[HOST] [IPU2 ] 23.698346 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 23.698438 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 23.698499 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 23.698834 s: *** VPDMA Firmware Loading... ***
[HOST] [IPU2 ] 23.698926 s: VPDMA Firmware Address = 0x9fe5c4c0
[HOST] [IPU2 ] 23.699017 s: VPDMA Load Address = 0x489dd004
[HOST] [IPU2 ] 23.699109 s: VPDMA Firmware Version = 0x4d0001b8
[HOST] [IPU2 ] 23.699200 s: VPDMA List Busy Status = 0x00000000
[HOST] [IPU2 ] 23.699261 s: *** VPDMA Firmware Load Success ***
[HOST] [IPU2 ] 23.760629 s: SYSTEM: VPS Init Done !!!
[HOST] [IPU2 ] 23.761544 s: UTILS: DMA: HWI Create for INT25 !!!
[HOST] [IPU2 ] 23.761849 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[HOST] [IPU2 ] 23.761941 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 260648 B (254 KB)
[HOST] [IPU2 ] 23.762124 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[HOST] [IPU2 ] 23.762276 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 220200960 B (210 MB), Free size = 220200960 B (210 MB)
[HOST] [IPU2 ] 23.762459 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB)
[HOST] [IPU2 ] 23.762612 s: SYSTEM: Initializing Links !!!
[HOST] [IPU2 ] 24.026444 s: SYSTEM: Initializing Links ... DONE !!!
[HOST] [IPU2 ] 24.026810 s: CHAINS: Application Started !!!
[HOST] [IPU2 ] 24.037638 s: BOARD: Board Init in progress !!!
[HOST] [IPU2 ] 24.038156 s: BOARD: Board Init Done !!!
[HOST] [IPU2 ] 24.046452 s:
find: /sdpath/NORMAL: No such file or directory
[HOST] [HOST ] 75.060300 s: [getLastObject] cmd = find /sdpath/NORMAL -name '20[1-3][0-9]-[01][0-9]-[0-3][0-9]-[0-2][0-9]-[0-5][0-9]-[0-5][0-9].[mM][pP]4' -exec ls {} \; | sort -r
[HOST] [HOST ] 75.233727 s: [checkFlieName] get pTail failed
[HOST] [HOST ] 75.233819 s: [getLastObject] fielname =
[HOST] [HOST ] 75.233819 s: [checkFileTime] Get FileTime ERROR!!!
[HOST] [HOST ] 75.275391 s: [EventRecordInit] eventcache init success
mkdir: can't create directory '/mnt/cbb': File exists
[HOST] [IPU2 ] 75.468889 s: CAPTURE: Create in progress !!!
[HOST] [IPU2 ] 75.469316 s: CAPTURE: VIP2 Slice1 PortA capture mode is [ 8-bit] !!!
[HOST] [IPU2 ] 75.596809 s: CAPTURE: VIP1 Slice1 PortA capture mode is [ 8-bit] !!!
[HOST] [IPU2 ] 75.724547 s: CAPTURE: VIP2 Slice0 PortA capture mode is [ 8-bit] !!!
[HOST] [IPU2 ] 75.852315 s: CAPTURE: VIP1 Slice0 PortA capture mode is [ 8-bit] !!!
[HOST] [IPU2 ] 75.980143 s: CAPTURE: Create Done !!!
[HOST] [IPU2 ] 75.981791 s: VPE: Create in progress !!!
[HOST] [IPU2 ] 76.302751 s: VPE: Loading Down-scaling Co-effs
[HOST] [IPU2 ] 76.302995 s: VPE: Co-effs Loading ... DONE !!!
[HOST] [IPU2 ] 76.303269 s: VPE: Create Done !!!
[HOST] [IPU2 ] 76.304398 s: ALGORITHM: Create in progress (algId = 0) !!!
[HOST] [IPU2 ] 77.058836 s: UTILS: DMA: Allocated CH (TCC) = 32 (32)
[HOST] [IPU2 ] 77.058958 s: UTILS: DMA: 0 of 8: Allocated PaRAM = 32 (0x63304800)
[HOST] [IPU2 ] 77.059080 s: UTILS: DMA: 1 of 8: Allocated PaRAM = 65 (0x63304820)
[HOST] [IPU2 ] 77.059293 s: UTILS: DMA: 2 of 8: Allocated PaRAM = 66 (0x63304840)
[HOST] [IPU2 ] 77.059415 s: UTILS: DMA: 3 of 8: Allocated PaRAM = 67 (0x63304860)
[HOST] [IPU2 ] 77.059537 s: UTILS: DMA: 4 of 8: Allocated PaRAM = 68 (0x63304880)
[HOST] [IPU2 ] 77.059659 s: UTILS: DMA: 5 of 8: Allocated PaRAM = 69 (0x633048A0)
[HOST] [IPU2 ] 77.059781 s: UTILS: DMA: 6 of 8: Allocated PaRAM = 70 (0x633048C0)
[HOST] [IPU2 ] 77.059903 s: UTILS: DMA: 7 of 8: Allocated PaRAM = 71 (0x633048E0)
[HOST] [IPU2 ] 77.060147 s: ALGORITHM: Create Done (algId = 0) !!!
[HOST] [IPU2 ] 77.063563 s: ENCODE: Create in progress ... !!!
[HOST] [IPU2 ] 78.034282 s: ENCODE: Creating CH0 of 2560 x 1440, pitch = (4096, 4096) [1] [0], bitrate = 10000 Kbps ...
loaded module : gbm_pvr.so
found valid GBM backend : gbm_pvr.so
[HOST] [HOST ] 78.289574 s: IPC_IN_0 : Create in progress !!!
[HOST] [HOST ] 78.290184 s: IPC_IN_0 : Create Done !!!
[HOST] [HOST ] 78.290306 s: NULL Link: Create in progress !!!
[HOST] [HOST ] 78.290306 s: NULL Link: Create done !!!
[HOST] [HOST ] 78.291709 s: IPC_IN_1 : Create in progress !!!
[HOST] [HOST ] 78.292106 s: IPC_IN_1 : Create Done !!!
[HOST] [HOST ] 78.292197 s: SGXFRMCPY: Create in progress for resolution: 1280x720 !!!
[HOST] [HOST ] 78.292258 s: SYSTEM_PVRSCOPE: FIFO /opt/vision_sdk/gpufifo opened successfully
[HOST] [IPU2 ] 78.285091 s: ENCODE: CH0: H264EncCreated:H264ENC_TI DEV.500.V.H264AVC.E.IVAHD.02.01.09.01
[HOST] [IPU2 ] 78.285396 s: ENCODE: ERROR: ALGCONTROL FAILED CMD=0x00000001 (status=ffffffff) !!!
[HOST] [IPU2 ] 78.285487 s: LINK ERR::linkID:900004f::channelID:0::errorCode:-5::FileName:iva_enc/encLink_h264.c::linuNum:1186::errorCondition:(algStatus == XDM_EOK)
[HOST] [IPU2 ] 78.285731 s: ENCODE: Creating CH1 of 2560 x 1440, pitch = (4096, 4096) [1] [0], bitrate = 10000 Kbps ...
[HOST] [IPU2 ] 78.286799 s: ENCODE: CH1: JPEGDecCreated:@(#)Id:JPEGVENC_TI Ver:01.00.16.01 Released by:500_V_MJPEG_E_01_00 Built:Jul 9 2014 14:46:40
[HOST] [IPU2 ] 78.287012 s: ENCODE: All CH Create ... DONE !!!
[HOST] [IPU2 ] 78.288476 s: ENCODE: Create ... DONE !!!
[HOST] [IPU2 ] 78.288873 s: IPC_OUT_0 : Create in progress !!!
[HOST] [IPU2 ] 78.289208 s: IPC_OUT_0 : Create Done !!!
[HOST] [IPU2 ] 78.291038 s: IPC_OUT_1 : Create in progress !!!
[HOST] [IPU2 ] 78.291435 s: IPC_OUT_1 : Create Done !!!
PVR:(Error): Couldn't load WS module libpvrws_WAYLAND.so [0, ]
[HOST] [HOST ] 78.304947 s: EGL: version 1.4
[HOST] [HOST ] 78.313792 s: EGL: GL Version = (null)
[HOST] [HOST ] 78.313792 s: EGL: GL Vendor = (null)
[HOST] [HOST ] 78.313822 s: EGL: GL Renderer = (null)
[HOST] [HOST ] 78.313822 s: EGL: GL Extensions = (null)
[HOST] [HOST ] 78.341243 s: SGXFRMCPY: Create Done for resolution: 1280x720 !!!
[HOST] [HOST ] 78.341365 s: IPC_OUT_0 : Create in progress !!!
[HOST] [HOST ] 78.341395 s: IPC_OUT_0 : Create Done !!!
[HOST] [IPU2 ] 78.341548 s: IPC_IN_0 : Create in progress !!!
[HOST] [IPU2 ] 78.342798 s: IPC_IN_0 : Create Done !!!
[HOST] [IPU2 ] 78.343164 s: DISPLAY: Create in progress !!!
[HOST] [IPU2 ] 78.343713 s: DISPLAY: Create Done !!!
[HOST] [IPU2 ] 78.444488 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST] [IPU2 ] 78.444610 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 251800 B (245 KB)
[HOST] [IPU2 ] 78.444763 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[HOST] [IPU2 ] 78.444915 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 220200960 B (210 MB), Free size = 16963072 B (16 MB)
[HOST] [IPU2 ] 78.445129 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB)
[HOST] [IPU2 ] 78.445586 s: DISPLAY: Start in progress !!!
[HOST] [IPU2 ] 78.445678 s: DISPLAY: Start Done !!!
[HOST] [HOST ] 78.446318 s: SGXFRMCPY: Start in progress !!!
[HOST] [HOST ] 78.446349 s: SGXFRMCPY: Start Done !!!
[HOST] [IPU2 ] 78.449002 s: CAPTURE: Start in progress !!!
[HOST] [HOST ] 78.457054 s:
[HOST] [HOST ]
[HOST] [HOST ] ===========================
[HOST] [HOST ] Car Black Box Run-time Menu
[HOST] [HOST ]
[HOST] [HOST ] 0: Stop Chain
[HOST] [HOST ]
[HOST] [HOST ] 1: Start Playback
[HOST] [HOST ] 2: Stop Playback
[HOST] [HOST ]
[HOST] [HOST ] p: Print Performance Statistics
[HOST] [HOST ]
[HOST] [HOST ] Enter Choice:
[HOST] [HOST ]
[HOST] [IPU2 ] 78.456536 s: CAPTURE: Start Done !!!
[HOST] [HOST ] 78.525163 s: Objname: /sdpath/NORMAL/2019-01-01-00-00-03.mp4
hMp4File 8f201078
[HOST] [HOST ] 78.527603 s: First IDR frame found
[HOST] [HOST ] 78.555297 s: [getFirstObject] fielname = /sdpath/NORMAL/2019-01-01-00-00-03.mp4
[HOST] [HOST ] 78.555297 s: [objectLoopHandler] ret = 0 fielname = /sdpath/NORMAL/2019-01-01-00-00-03.mp4
[HOST] [HOST ] 78.555328 s: [deleteObject] cmd = rm -r /sdpath/NORMAL/2019-01-01-00-00-03.mp4
[HOST] [HOST ] 78.576770 s: [deleteObject] Remove file /sdpath/NORMAL/2019-01-01-00-00-03.mp4
hMp4File 8f201078
[HOST] [HOST ] 78.629659 s: [checkFlieName] get pTail failed
[HOST] [HOST ] 78.629750 s: [getFirstObject] fielname =
[HOST] [HOST ] 78.629750 s: [objectLoopHandler] ret = -1 fielname =
[HOST] [HOST ] 78.629750 s: CBB_REC: MMC/SD card is FULL, 219072
[HOST] [HOST ] 78.634600 s: FILE_WRITE_TSK: mp4 write size: 21636 pobj size 21636
[HOST] [HOST ] 78.634630 s: FILE_WRITE_TSK:File written 21636 bytes in 5 msec
[HOST] [HOST ] 110.522143 s:
[HOST] [HOST ] Unsupported option '
[HOST] [HOST ] '. Please try again
[HOST] [HOST ] 110.522174 s:
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ] 110.722137 s:
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ] 110.890258 s:
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
p
[HOST] [IPU2 ] 113.076221 s:
[HOST] [IPU2 ] 113.078905 s: CPU [IPU2 ] Statistics,
[HOST] [IPU2 ] 113.079088 s: *************************
[HOST] [IPU2 ] 113.079607 s:
[HOST] [IPU2 ] 113.079698 s: LOAD: CPU: 40.6% HWI: 7.4%, SWI:2.7%, Low Power: 53.7%
[HOST] [IPU2 ] 113.079912 s:
[HOST] [IPU2 ] 113.079973 s: LOAD: TSK: DUP0 : 1.8%
[HOST] [IPU2 ] 113.080125 s: LOAD: TSK: DUP1 : 0.3%
[HOST] [IPU2 ] 113.080308 s: LOAD: TSK: GATE0 : 0.2%
[HOST] [IPU2 ] 113.080461 s: LOAD: TSK: IPC_IN_0 : 0.7%
[HOST] [IPU2 ] 113.080674 s: LOAD: TSK: IPC_OUT_0 : 0.7%
[HOST] [IPU2 ] 113.081376 s: LOAD: TSK: IPC_OUT_1 : 1.6%
[HOST] [IPU2 ] 113.081589 s: LOAD: TSK: MERGE0 : 0.2%
[HOST] [IPU2 ] 113.081772 s: LOAD: TSK: SYNC0 : 2.0%
[HOST] [IPU2 ] 113.081925 s: LOAD: TSK: SYNC1 : 2.4%
[HOST] [IPU2 ] 113.082077 s: LOAD: TSK: DISPLAY0 : 1.3%
[HOST] [IPU2 ] 113.082260 s: LOAD: TSK: ENC0 : 1.3%
[HOST] [IPU2 ] 113.082413 s: LOAD: TSK: CAPTURE : 1.9%
[HOST] [IPU2 ] 113.082565 s: LOAD: TSK: VPE0 : 7.6%
[HOST] [IPU2 ] 113.082718 s: LOAD: TSK: ALGORITHM0 : 1.3%
[HOST] [IPU2 ] 113.082901 s: LOAD: TSK: STAT_COLL : 5.4%
[HOST] [IPU2 ] 113.083053 s: LOAD: TSK: ENC_PROCESS_TSK_0 : 0.9%
[HOST] [IPU2 ] 113.083236 s: LOAD: TSK: MISC : 0.9%
[HOST] [IPU2 ] 113.083358 s:
[HOST] [IPU2 ] 113.083419 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[HOST] [IPU2 ] 113.083572 s:
[HOST] [IPU2 ] 113.083633 s: SYSTEM: Sempahores Objects, 179 of 1050 free
[HOST] [IPU2 ] 113.083755 s: SYSTEM: Task Objects , 18 of 100 free
[HOST] [IPU2 ] 113.083907 s: SYSTEM: Clock Objects , 94 of 100 free
[HOST] [IPU2 ] 113.084029 s: SYSTEM: Hwi Objects , 92 of 100 free
[HOST] [IPU2 ] 113.084456 s:
[HOST] [IPU2 ] 113.084548 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 251792 B (245 KB)
[HOST] [IPU2 ] 113.084822 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[HOST] [IPU2 ] 113.085066 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 220200960 B (210 MB), Free size = 16963072 B (16 MB)
[HOST] [IPU2 ] 113.085371 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xbfc00000, Total size = 1047168 B (0 MB), Free size = 1047168 B (0 MB)
[HOST] [IPU2 ] 113.085646 s:
[HOST] [IPU2 ] 113.086225 s:
[HOST] [IPU2 ] 113.086317 s: Statistics Collector,
[HOST] [IPU2 ] 113.086408 s:
[HOST] [IPU2 ] 113.086469 s: STATISTIC Avg Data Peak Data
[HOST] [IPU2 ] 113.086591 s: COLLECTOR MB/s MB/s
[HOST] [IPU2 ] 113.086744 s: --------------------------------------------------
[HOST] [IPU2 ] 113.086866 s: SCI_EMIF1 RD+WR | 2105.688033 2634.936195
[HOST] [IPU2 ] 113.087049 s: SCI_EMIF2 RD+WR | 0.000000 0.000000
[HOST] [IPU2 ] 113.087262 s: SCI_EMIF1 RD ONLY | 1526.074366 1866.310037
[HOST] [IPU2 ] 113.087445 s: SCI_EMIF1 WR ONLY | 581.915997 995.373942
[HOST] [IPU2 ] 113.087598 s: SCI_EMIF2 RD ONLY | 0.000000 0.000000
[HOST] [IPU2 ] 113.087750 s: SCI_EMIF2 WR ONLY | 0.000000 0.000000
[HOST] [IPU2 ] 113.087903 s: SCI_MA_MPU_P1 | 0.681584 64.332391
[HOST] [IPU2 ] 113.088055 s: SCI_MA_MPU_P2 | 0.000000 0.000000
[HOST] [IPU2 ] 113.088238 s: SCI_DSS | 239.274084 311.338976
[HOST] [IPU2 ] 113.088391 s: SCI_IPU1 | 0.000000 0.000000
[HOST] [IPU2 ] 113.088543 s: SCI_VIP1_P1 | 23.191749 42.591549
[HOST] [IPU2 ] 113.088726 s: SCI_VIP1_P2 | 45.469019 71.455219
[HOST] [IPU2 ] 113.088879 s: SCI_VPE_P1 | 150.167395 428.443371
[HOST] [IPU2 ] 113.089031 s: SCI_VPE_P2 | 150.275172 428.520619
[HOST] [IPU2 ] 113.089489 s: SCI_DSP1_MDMA | 0.000000 0.000000
[HOST] [IPU2 ] 113.089672 s: SCI_DSP1_EDMA | 0.000000 0.000000
[HOST] [IPU2 ] 113.089824 s: SCI_DSP2_MDMA | 0.000000 0.000000
[HOST] [IPU2 ] 113.089977 s: SCI_DSP2_EDMA | 0.000000 0.000000
[HOST] [IPU2 ] 113.090190 s: SCI_EVE1_TC0 | 0.000000 0.000000
[HOST] [IPU2 ] 113.090373 s: SCI_EVE1_TC1 | 0.000000 0.000000
[HOST] [IPU2 ] 113.090526 s: SCI_EVE2_TC0 | 0.000000 0.000000
[HOST] [IPU2 ] 113.090678 s: SCI_EVE2_TC1 | 0.000000 0.000000
[HOST] [IPU2 ] 113.090831 s: SCI_EDMA_TC0_RD | 0.000000 0.000000
[HOST] [IPU2 ] 113.090983 s: SCI_EDMA_TC0_WR | 0.000000 0.000000
[HOST] [IPU2 ] 113.091136 s: SCI_EDMA_TC1_RD | 102.725293 608.334573
[HOST] [IPU2 ] 113.091319 s: SCI_EDMA_TC1_WR | 102.750779 608.493354
[HOST] [IPU2 ] 113.091471 s: SCI_VIP2_P1 | 24.519911 41.327700
[HOST] [IPU2 ] 113.093027 s: SCI_VIP2_P2 | 43.992559 75.010073
[HOST] [IPU2 ] 113.093424 s: SCI_VIP3_P1 | 0.000000 0.000000
[HOST] [IPU2 ] 113.093576 s: SCI_VIP3_P2 | 0.000000 0.000000
[HOST] [IPU2 ] 113.093759 s: SCI_EVE3_TC0 | 0.000000 0.000000
[HOST] [IPU2 ] 113.093912 s: SCI_EVE3_TC1 | 0.000000 0.000000
[HOST] [IPU2 ] 113.094064 s: SCI_EVE4_TC0 | 0.000000 0.000000
[HOST] [IPU2 ] 113.094613 s: SCI_EVE4_TC1 | 0.000000 0.000000
[HOST] [IPU2 ] 113.097877 s: SCI_IVA | 1015.091367 1549.282243
[HOST] [IPU2 ] 113.098151 s: SCI_GPU_P1 | 119.142178 571.590366
[HOST] [IPU2 ] 113.098426 s: SCI_GPU_P2 | 119.175800 571.171827
[HOST] [IPU2 ] 113.098609 s: SCI_GMAC_SW | 0.000000 0.000000
[HOST] [IPU2 ] 113.098761 s: SCI_OCMC_RAM1 | 0.000000 0.000000
[HOST] [IPU2 ] 113.098944 s: SCI_OCMC_RAM2 | 0.000000 0.000000
[HOST] [IPU2 ] 113.099097 s: SCI_OCMC_RAM3 | 0.000000 0.000000
[HOST] [IPU2 ] 113.205758 s:
[HOST] [IPU2 ] 113.205911 s:
[HOST] [IPU2 ] 113.206460 s: CAPTURE: VIP2 Slice1 PortA FRAME MODE
[HOST] [IPU2 ] 113.206612 s: CAPTURE: VIP1 Slice1 PortA FRAME MODE
[HOST] [IPU2 ] 113.206734 s: CAPTURE: VIP2 Slice0 PortA FRAME MODE
[HOST] [IPU2 ] 113.206887 s: CAPTURE: VIP1 Slice0 PortA FRAME MODE
[HOST] [IPU2 ] 113.207039 s:
[HOST] [IPU2 ] 113.207100 s: [ CAPTURE ] Link Statistics,
[HOST] [IPU2 ] 113.207253 s: ******************************
[HOST] [IPU2 ] 113.207375 s:
[HOST] [IPU2 ] 113.207436 s: Elapsed time = 34737 msec
[HOST] [IPU2 ] 113.207558 s:
[HOST] [IPU2 ] 113.207619 s: New data Recv = 100.3 fps
[HOST] [IPU2 ] 113.207741 s: Get Full Buf Cb = 100.6 fps
[HOST] [IPU2 ] 113.207863 s: Put Empty Buf Cb = 88.0 fps
[HOST] [IPU2 ] 113.207985 s: Driver/Notify Cb = 100.3 fps
[HOST] [IPU2 ] 113.208107 s:
[HOST] [IPU2 ] 113.208168 s: Input Statistics,
[HOST] [IPU2 ] 113.208259 s:
[HOST] [IPU2 ] 113.208320 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.208473 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.208595 s: --------------------------------------------------
[HOST] [IPU2 ] 113.208747 s: 0 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.208961 s: 1 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.209144 s: 2 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.209357 s: 3 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.209571 s:
[HOST] [IPU2 ] 113.209632 s: Output Statistics,
[HOST] [IPU2 ] 113.209693 s:
[HOST] [IPU2 ] 113.209754 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 113.209876 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 113.210028 s: ---------------------------------------------
[HOST] [IPU2 ] 113.210181 s: 0 | 0 25. 1 0. 0 0. 0
[HOST] [IPU2 ] 113.210364 s: 1 | 0 25. 1 0. 0 0. 0
[HOST] [IPU2 ] 113.210547 s: 2 | 0 25. 1 0. 0 0. 0
[HOST] [IPU2 ] 113.210699 s: 3 | 0 25. 1 0. 0 0. 0
[HOST] [IPU2 ] 113.210974 s:
[HOST] [IPU2 ] 113.211065 s: [VIP2 Slice1 PortA] Statistics
[HOST] [IPU2 ] 113.211218 s: ==============================
[HOST] [IPU2 ] 113.211309 s: Number of request queued : 870
[HOST] [IPU2 ] 113.211431 s: Number of request dequeued: 869
[HOST] [IPU2 ] 113.211523 s: Overflow Count : 0
[HOST] [IPU2 ] 113.211645 s:
[HOST] [IPU2 ] 113.211706 s: CH | Q DQ Total Top Bot Total Top Bot Min/Max Min/Max Dropped Repeat Fid Desc
[HOST] [IPU2 ] 113.211950 s: (I/S/CH) | Count Count Fields Fields Fields FPS FPS FPS Width Height Frames Frames Repeat Error
[HOST] [IPU2 ] 113.212194 s: ---------------------------------------------------------------------------------------------------------------------------
[HOST] [IPU2 ] 113.212651 s: 06.0.00 | 875 869 869 869 0 25 25 0 1/1280 303/720 0 0 0 0
[HOST] [IPU2 ] 113.212895 s:
[HOST] [IPU2 ] 113.212956 s:
[HOST] [IPU2 ] 113.213017 s: [VIP1 Slice1 PortA] Statistics
[HOST] [IPU2 ] 113.213139 s: ==============================
[HOST] [IPU2 ] 113.213231 s: Number of request queued : 870
[HOST] [IPU2 ] 113.213353 s: Number of request dequeued: 869
[HOST] [IPU2 ] 113.213475 s: Overflow Count : 0
[HOST] [IPU2 ] 113.213566 s:
[HOST] [IPU2 ] 113.213627 s: CH | Q DQ Total Top Bot Total Top Bot Min/Max Min/Max Dropped Repeat Fid Desc
[HOST] [IPU2 ] 113.213871 s: (I/S/CH) | Count Count Fields Fields Fields FPS FPS FPS Width Height Frames Frames Repeat Error
[HOST] [IPU2 ] 113.214085 s: ---------------------------------------------------------------------------------------------------------------------------
[HOST] [IPU2 ] 113.214542 s: 02.0.00 | 875 869 869 869 0 25 25 0 1/1280 214/720 0 0 0 0
[HOST] [IPU2 ] 113.215152 s:
[HOST] [IPU2 ] 113.215305 s:
[HOST] [IPU2 ] 113.215366 s: [VIP2 Slice0 PortA] Statistics
[HOST] [IPU2 ] 113.215457 s: ==============================
[HOST] [IPU2 ] 113.215579 s: Number of request queued : 870
[HOST] [IPU2 ] 113.215671 s: Number of request dequeued: 869
[HOST] [IPU2 ] 113.215793 s: Overflow Count : 0
[HOST] [IPU2 ] 113.215884 s:
[HOST] [IPU2 ] 113.215945 s: CH | Q DQ Total Top Bot Total Top Bot Min/Max Min/Max Dropped Repeat Fid Desc
[HOST] [IPU2 ] 113.216220 s: (I/S/CH) | Count Count Fields Fields Fields FPS FPS FPS Width Height Frames Frames Repeat Error
[HOST] [IPU2 ] 113.216464 s: ---------------------------------------------------------------------------------------------------------------------------
[HOST] [IPU2 ] 113.217104 s: 04.0.00 | 875 869 869 869 0 25 25 0 1/1280 281/720 0 0 0 0
[HOST] [IPU2 ] 113.217409 s:
[HOST] [IPU2 ] 113.217501 s:
[HOST] [IPU2 ] 113.217592 s: [VIP1 Slice0 PortA] Statistics
[HOST] [IPU2 ] 113.217684 s: ==============================
[HOST] [IPU2 ] 113.217775 s: Number of request queued : 870
[HOST] [IPU2 ] 113.217958 s: Number of request dequeued: 869
[HOST] [IPU2 ] 113.218294 s: Overflow Count : 0
[HOST] [IPU2 ] 113.218416 s:
[HOST] [IPU2 ] 113.218477 s: CH | Q DQ Total Top Bot Total Top Bot Min/Max Min/Max Dropped Repeat Fid Desc
[HOST] [IPU2 ] 113.218721 s: (I/S/CH) | Count Count Fields Fields Fields FPS FPS FPS Width Height Frames Frames Repeat Error
[HOST] [IPU2 ] 113.218934 s: ---------------------------------------------------------------------------------------------------------------------------
[HOST] [IPU2 ] 113.219392 s: 00.0.00 | 875 869 869 869 0 25 25 0 1/1280 274/720 0 0 0 0
[HOST] [IPU2 ] 113.219910 s:
[HOST] [IPU2 ] 113.224028 s:
[HOST] [IPU2 ] 113.224272 s: [ VPE ] Link Statistics,
[HOST] [IPU2 ] 113.224394 s: ******************************
[HOST] [IPU2 ] 113.224486 s:
[HOST] [IPU2 ] 113.224547 s: Elapsed time = 34753 msec
[HOST] [IPU2 ] 113.224638 s:
[HOST] [IPU2 ] 113.224699 s: New data Recv = 65.72 fps
[HOST] [IPU2 ] 113.224821 s: Get Full Buf Cb = 93.11 fps
[HOST] [IPU2 ] 113.224943 s: Put Empty Buf Cb = 24.97 fps
[HOST] [IPU2 ] 113.225065 s: Driver/Notify Cb = 62.95 fps
[HOST] [IPU2 ] 113.225187 s:
[HOST] [IPU2 ] 113.225248 s: Input Statistics,
[HOST] [IPU2 ] 113.225340 s:
[HOST] [IPU2 ] 113.225401 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.225523 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.225645 s: --------------------------------------------------
[HOST] [IPU2 ] 113.225797 s: 0 | 25. 0 0. 0 0. 0 25. 0
[HOST] [IPU2 ] 113.225980 s: 1 | 25. 0 0. 0 0. 0 25. 0
[HOST] [IPU2 ] 113.226194 s: 2 | 25. 0 0. 0 0. 0 25. 0
[HOST] [IPU2 ] 113.226377 s: 3 | 25. 0 0. 0 0. 0 25. 0
[HOST] [IPU2 ] 113.226560 s:
[HOST] [IPU2 ] 113.226621 s: Output Statistics,
[HOST] [IPU2 ] 113.226682 s:
[HOST] [IPU2 ] 113.226743 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 113.226865 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 113.226987 s: ---------------------------------------------
[HOST] [IPU2 ] 113.227109 s: 0 | 0 25. 0 0. 0 0. 0
[HOST] [IPU2 ] 113.227292 s: 1 | 0 25. 0 0. 0 0. 0
[HOST] [IPU2 ] 113.227444 s: 2 | 0 25. 0 0. 0 0. 0
[HOST] [IPU2 ] 113.227688 s: 3 | 0 25. 0 0. 0 0. 0
[HOST] [IPU2 ] 113.227841 s:
[HOST] [IPU2 ] 113.227902 s: [ VPE ] LATENCY,
[HOST] [IPU2 ] 113.227963 s: ********************
[HOST] [IPU2 ] 113.228024 s: Local Link Latency : Avg = 8056 us, Min = 3782 us, Max = 12383 us,
[HOST] [IPU2 ] 113.228176 s: Source to Link Latency : Avg = 12155 us, Min = 4117 us, Max = 19032 us,
[HOST] [IPU2 ] 113.228329 s:
[HOST] [IPU2 ] 113.228695 s:
[HOST] [IPU2 ] 113.228756 s: [ SYNC_LINK_0 ] Link Statistics,
[HOST] [IPU2 ] 113.228817 s: ******************************
[HOST] [IPU2 ] 113.228908 s:
[HOST] [IPU2 ] 113.228939 s: Elapsed time = 34754 msec
[HOST] [IPU2 ] 113.229030 s:
[HOST] [IPU2 ] 113.229061 s: New data Recv = 93.11 fps
[HOST] [IPU2 ] 113.229213 s: Get Full Buf Cb = 25.0 fps
[HOST] [IPU2 ] 113.229305 s: Put Empty Buf Cb = 24.97 fps
[HOST] [IPU2 ] 113.229396 s: Driver/Notify Cb = 30.29 fps
[HOST] [IPU2 ] 113.229488 s:
[HOST] [IPU2 ] 113.229518 s: Input Statistics,
[HOST] [IPU2 ] 113.229579 s:
[HOST] [IPU2 ] 113.229610 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.229701 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.229823 s: --------------------------------------------------
[HOST] [IPU2 ] 113.229915 s: 0 | 25. 0 0. 0 0. 0 25. 0
[HOST] [IPU2 ] 113.230067 s: 1 | 25. 0 0. 0 0. 0 25. 0
[HOST] [IPU2 ] 113.230220 s: 2 | 25. 0 0. 0 0. 0 25. 0
[HOST] [IPU2 ] 113.230372 s: 3 | 25. 0 0. 0 0. 0 25. 0
[HOST] [IPU2 ] 113.230494 s:
[HOST] [IPU2 ] 113.230555 s: Output Statistics,
[HOST] [IPU2 ] 113.230677 s:
[HOST] [IPU2 ] 113.230708 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 113.230799 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 113.230860 s: ---------------------------------------------
[HOST] [IPU2 ] 113.230952 s: 0 | 0 25. 0 0. 0 0. 0
[HOST] [IPU2 ] 113.231104 s:
[HOST] [IPU2 ] 113.231135 s: [ SYNC_LINK_0 ] LATENCY,
[HOST] [IPU2 ] 113.231226 s: ********************
[HOST] [IPU2 ] 113.231287 s: Local Link Latency : Avg = 5161 us, Min = 61 us, Max = 17904 us,
[HOST] [IPU2 ] 113.231409 s: Source to Link Latency : Avg = 17842 us, Min = 12773 us, Max = 20459 us,
[HOST] [IPU2 ] 113.231531 s:
[HOST] [IPU2 ] 113.236076 s:
[HOST] [IPU2 ] 113.236381 s: [ ALG_DMA_SWMS ] Link Statistics,
[HOST] [IPU2 ] 113.236503 s: ******************************
[HOST] [IPU2 ] 113.236625 s:
[HOST] [IPU2 ] 113.236686 s: Elapsed time = 34750 msec
[HOST] [IPU2 ] 113.236808 s:
[HOST] [IPU2 ] 113.236869 s: Out Buf Error Count = 222 frames
[HOST] [IPU2 ] 113.236991 s: New data Recv = 24.97 fps
[HOST] [IPU2 ] 113.237113 s:
[HOST] [IPU2 ] 113.237235 s: Input Statistics,
[HOST] [IPU2 ] 113.237326 s:
[HOST] [IPU2 ] 113.237387 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.237540 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.237692 s: --------------------------------------------------
[HOST] [IPU2 ] 113.237845 s: 0 | 25. 0 6.38 0. 0 18.61
[HOST] [IPU2 ] 113.238058 s:
[HOST] [IPU2 ] 113.238119 s: Output Statistics,
[HOST] [IPU2 ] 113.238241 s:
[HOST] [IPU2 ] 113.238302 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 113.238424 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 113.238577 s: ---------------------------------------------
[HOST] [IPU2 ] 113.238699 s: 0 | 0 18.61 6.38 0. 0
[HOST] [IPU2 ] 113.238973 s:
[HOST] [IPU2 ] 113.239034 s: [ ALG_DMA_SWMS ] LATENCY,
[HOST] [IPU2 ] 113.239156 s: ********************
[HOST] [IPU2 ] 113.239644 s:
[HOST] [IPU2 ] 113.241505 s:
[HOST] [IPU2 ] 113.241658 s: [ ENCODE ] Link Statistics,
[HOST] [IPU2 ] 113.241749 s: ******************************
[HOST] [IPU2 ] 113.241871 s:
[HOST] [IPU2 ] 113.241932 s: Elapsed time = 34745 msec
[HOST] [IPU2 ] 113.242054 s:
[HOST] [IPU2 ] 113.242115 s: New data Recv = 18.62 fps
[HOST] [IPU2 ] 113.242298 s: Release data Recv = 18.53 fps
[HOST] [IPU2 ] 113.242451 s: Get Full Buf Cb = 37.15 fps
[HOST] [IPU2 ] 113.242573 s: Put Empty Buf Cb = 18.53 fps
[HOST] [IPU2 ] 113.242695 s:
[HOST] [IPU2 ] 113.242756 s: Input Statistics,
[HOST] [IPU2 ] 113.242847 s:
[HOST] [IPU2 ] 113.242908 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.243061 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.243213 s: --------------------------------------------------
[HOST] [IPU2 ] 113.243366 s: 0 | 18.62 0. 0 0. 0 18.62
[HOST] [IPU2 ] 113.243579 s:
[HOST] [IPU2 ] 113.243640 s: Output Statistics,
[HOST] [IPU2 ] 113.243732 s:
[HOST] [IPU2 ] 113.243793 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 113.243915 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 113.244067 s: ---------------------------------------------
[HOST] [IPU2 ] 113.244250 s: 0 | 0 18.62 0. 0 0. 0
[HOST] [IPU2 ] 113.244494 s: ENCODE: Num process reqest count for chId: 0 = 647
[HOST] [IPU2 ] 113.244647 s: ENCODE: Num process complete count for chId: 0 = 644
[HOST] [IPU2 ] 113.244799 s: ENCODE: Num process reqest count for chId: 1 = 0
[HOST] [IPU2 ] 113.244952 s: ENCODE: Num process complete count for chId: 1 = 0
[HOST] [IPU2 ] 113.245104 s:
[HOST] [IPU2 ] 113.245196 s: [ ENCODE ] LATENCY,
[HOST] [IPU2 ] 113.245287 s: ********************
[HOST] [IPU2 ] 113.245379 s: Local Link Latency : Avg = 180179 us, Min = 26811 us, Max = 200756 us,
[HOST] [IPU2 ] 113.245592 s: Source to Link Latency : Avg = 212178 us, Min = 49587 us, Max = 234628 us,
[HOST] [IPU2 ] 113.245806 s:
[HOST] [IPU2 ] 113.245928 s: HDVICP-ID: 0
[HOST] [IPU2 ] 113.246019 s: All percentage figures are based of totalElapsedTime
[HOST] [IPU2 ] 113.246202 s:
[HOST] [IPU2 ] totalAcquire2Wait :0 %
[HOST] [IPU2 ] totalWait2Isr :98 %
[HOST] [IPU2 ] totalIsr2Done :0 %
[HOST] [IPU2 ] totalWait2Done :98 %
[HOST] [IPU2 ] totalDone2Release :0 %
[HOST] [IPU2 ] totalAcquire2Release :99 %
[HOST] [IPU2 ] totalRelease2AcquireDelay :0 %
[HOST] [IPU2 ] totalElapsedTime in msec : 34736
[HOST] [IPU2 ] numAccessCnt: 644
[HOST] [IPU2 ] 113.248429 s: IVA-FPS : 18
[HOST] [IPU2 ] 113.248764 s: Average time spent per frame in microsec: 52858
[HOST] [IPU2 ] 113.248886 s:
[HOST] [IPU2 ] 113.249527 s:
[HOST] [IPU2 ] 113.249618 s: [ IPC_OUT_0 ] Link Statistics,
[HOST] [IPU2 ] 113.249710 s: ******************************
[HOST] [IPU2 ] 113.249832 s:
[HOST] [IPU2 ] 113.249893 s: Elapsed time = 34726 msec
[HOST] [IPU2 ] 113.249984 s:
[HOST] [IPU2 ] 113.250076 s: New data Recv = 18.54 fps
[HOST] [IPU2 ] 113.250259 s: Release data Recv = 18.57 fps
[HOST] [IPU2 ] 113.250381 s: Driver/Notify Cb = 118.55 fps
[HOST] [IPU2 ] 113.250503 s:
[HOST] [IPU2 ] 113.250564 s: Input Statistics,
[HOST] [IPU2 ] 113.250655 s:
[HOST] [IPU2 ] 113.250686 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.250838 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.250960 s: --------------------------------------------------
[HOST] [IPU2 ] 113.251113 s: 0 | 18.54 0. 0 0. 0 18.54
[HOST] [IPU2 ] 113.251326 s:
[HOST] [IPU2 ] 113.251418 s: Output Statistics,
[HOST] [IPU2 ] 113.251479 s:
[HOST] [IPU2 ] 113.251540 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 113.251662 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 113.251814 s: ---------------------------------------------
[HOST] [IPU2 ] 113.251936 s: 0 | 0 18.54 0. 0 0. 0
[HOST] [IPU2 ] 113.252180 s:
[HOST] [IPU2 ] 113.252241 s: [ IPC_OUT_0 ] LATENCY,
[HOST] [IPU2 ] 113.252333 s: ********************
[HOST] [IPU2 ] 113.252424 s: Local Link Latency : Avg = 14 us, Min = 0 us, Max = 244 us,
[HOST] [IPU2 ] 113.252638 s: Source to Link Latency : Avg = 212490 us, Min = 49953 us, Max = 234903 us,
[HOST] [IPU2 ] 113.252821 s:
[HOST] [IPU2 ] 113.255535 s:
[HOST] [IPU2 ] 113.255596 s: [ SYNC_LINK_1 ] Link Statistics,
[HOST] [IPU2 ] 113.255718 s: ******************************
[HOST] [IPU2 ] 113.255810 s:
[HOST] [IPU2 ] 113.255871 s: Elapsed time = 34785 msec
[HOST] [IPU2 ] 113.255962 s:
[HOST] [IPU2 ] 113.256054 s: New data Recv = 129.62 fps
[HOST] [IPU2 ] 113.256206 s: Get Full Buf Cb = 25.1 fps
[HOST] [IPU2 ] 113.256328 s: Put Empty Buf Cb = 25.1 fps
[HOST] [IPU2 ] 113.256450 s: Driver/Notify Cb = 30.30 fps
[HOST] [IPU2 ] 113.256572 s:
[HOST] [IPU2 ] 113.256847 s: Input Statistics,
[HOST] [IPU2 ] 113.256938 s:
[HOST] [IPU2 ] 113.256999 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.257121 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.257335 s: --------------------------------------------------
[HOST] [IPU2 ] 113.257487 s: 0 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.257670 s: 1 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.257853 s: 2 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.258036 s: 3 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.258250 s:
[HOST] [IPU2 ] 113.258311 s: Output Statistics,
[HOST] [IPU2 ] 113.258402 s:
[HOST] [IPU2 ] 113.258463 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 113.258585 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 113.258707 s: ---------------------------------------------
[HOST] [IPU2 ] 113.258829 s: 0 | 0 25. 1 0. 0 0. 0
[HOST] [IPU2 ] 113.259073 s:
[HOST] [IPU2 ] 113.259134 s: [ SYNC_LINK_1 ] LATENCY,
[HOST] [IPU2 ] 113.259256 s: ********************
[HOST] [IPU2 ] 113.259348 s: Local Link Latency : Avg = 3324 us, Min = 61 us, Max = 7961 us,
[HOST] [IPU2 ] 113.259531 s: Source to Link Latency : Avg = 3785 us, Min = 1068 us, Max = 4697 us,
[HOST] [IPU2 ] 113.259897 s:
[HOST] [IPU2 ] 113.260538 s:
[HOST] [IPU2 ] 113.260599 s: [ IPC_OUT_1 ] Link Statistics,
[HOST] [IPU2 ] 113.260690 s: ******************************
[HOST] [IPU2 ] 113.260812 s:
[HOST] [IPU2 ] 113.260873 s: Elapsed time = 34783 msec
[HOST] [IPU2 ] 113.260965 s:
[HOST] [IPU2 ] 113.261026 s: New data Recv = 25.1 fps
[HOST] [IPU2 ] 113.261148 s: Release data Recv = 25.4 fps
[HOST] [IPU2 ] 113.261575 s: Driver/Notify Cb = 125.0 fps
[HOST] [IPU2 ] 113.261727 s:
[HOST] [IPU2 ] 113.261788 s: Input Statistics,
[HOST] [IPU2 ] 113.261849 s:
[HOST] [IPU2 ] 113.261910 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.262032 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.262215 s: --------------------------------------------------
[HOST] [IPU2 ] 113.262368 s: 0 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.262551 s:
[HOST] [IPU2 ] 113.262612 s: Output Statistics,
[HOST] [IPU2 ] 113.262703 s:
[HOST] [IPU2 ] 113.262764 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 113.262886 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 113.263008 s: ---------------------------------------------
[HOST] [IPU2 ] 113.263130 s: 0 | 0 25. 1 0. 0 0. 0
[HOST] [IPU2 ] 113.263374 s:
[HOST] [IPU2 ] 113.263435 s: [ IPC_OUT_1 ] LATENCY,
[HOST] [IPU2 ] 113.263527 s: ********************
[HOST] [IPU2 ] 113.263649 s: Local Link Latency : Avg = 19 us, Min = 0 us, Max = 153 us,
[HOST] [IPU2 ] 113.263954 s: Source to Link Latency : Avg = 4020 us, Min = 1282 us, Max = 4941 us,
[HOST] [IPU2 ] 113.264228 s:
[HOST] [IPU2 ] 113.268010 s:
[HOST] [IPU2 ] 113.268102 s: [ IPC_IN_0 ] Link Statistics,
[HOST] [IPU2 ] 113.268285 s: ******************************
[HOST] [IPU2 ] 113.268376 s:
[HOST] [IPU2 ] 113.268437 s: Elapsed time = 34783 msec
[HOST] [IPU2 ] 113.268559 s:
[HOST] [IPU2 ] 113.268620 s: Get Full Buf Cb = 25.1 fps
[HOST] [IPU2 ] 113.268742 s: Put Empty Buf Cb = 24.98 fps
[HOST] [IPU2 ] 113.268864 s: Driver/Notify Cb = 24.98 fps
[HOST] [IPU2 ] 113.268956 s:
[HOST] [IPU2 ] 113.269017 s: Input Statistics,
[HOST] [IPU2 ] 113.269108 s:
[HOST] [IPU2 ] 113.269169 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.269322 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.269444 s: --------------------------------------------------
[HOST] [IPU2 ] 113.269596 s: 0 | 25. 1 0. 0 0. 0 25. 1
[HOST] [IPU2 ] 113.269779 s:
[HOST] [IPU2 ] 113.269840 s: Output Statistics,
[HOST] [IPU2 ] 113.269901 s:
[HOST] [IPU2 ] 113.269962 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [IPU2 ] 113.270084 s: | ID | FPS | FPS | FPS
[HOST] [IPU2 ] 113.270237 s: ---------------------------------------------
[HOST] [IPU2 ] 113.270389 s: 0 | 0 25. 1 0. 0 0. 0
[HOST] [IPU2 ] 113.270572 s:
[HOST] [IPU2 ] 113.270633 s: [ IPC_IN_0 ] LATENCY,
[HOST] [IPU2 ] 113.270725 s: ********************
[HOST] [IPU2 ] 113.270816 s: Local Link Latency : Avg = 53 us, Min = 0 us, Max = 244 us,
[HOST] [IPU2 ] 113.270999 s: Source to Link Latency : Avg = 21709 us, Min = 10157 us, Max = 41901 us,
[HOST] [IPU2 ] 113.271213 s:
[HOST] [IPU2 ] 113.271304 s: [ IPC_IN_0 ] Detailed IPC Latency Statistics [ HOST -> IPU2 ] ,
[HOST] [IPU2 ] 113.271457 s: ***************************************************************
[HOST] [IPU2 ] 113.271609 s: IPC One-way Buffer Passing Latency (usecs) : Avg = 488, Min = 183, Max = 1128
[HOST] [IPU2 ] 113.271823 s: IPC One-way Notify Interrupt Latency (usecs) : Avg = 357, Min = 152, Max = 946
[HOST] [IPU2 ] 113.273531 s:
[HOST] [IPU2 ] 113.273683 s: [ DISPLAY ] Link Statistics,
[HOST] [IPU2 ] 113.273775 s: ******************************
[HOST] [IPU2 ] 113.273897 s:
[HOST] [IPU2 ] 113.273958 s: Elapsed time = 34788 msec
[HOST] [IPU2 ] 113.274080 s:
[HOST] [IPU2 ] 113.274141 s: New data Recv = 24.97 fps
[HOST] [IPU2 ] 113.274324 s: Driver/Notify Cb = 65.56 fps
[HOST] [IPU2 ] 113.274476 s:
[HOST] [IPU2 ] 113.274507 s: Input Statistics,
[HOST] [IPU2 ] 113.274598 s:
[HOST] [IPU2 ] 113.274659 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [IPU2 ] 113.274812 s: | FPS | FPS | FPS | FPS
[HOST] [IPU2 ] 113.274934 s: --------------------------------------------------
[HOST] [IPU2 ] 113.275086 s: 0 | 25. 0 0. 0 0. 0 25. 0
[HOST] [IPU2 ] 113.275330 s:
[HOST] [IPU2 ] 113.275391 s: [ DISPLAY ] LATENCY,
[HOST] [IPU2 ] 113.275483 s: ********************
[HOST] [IPU2 ] 113.275574 s: Local Link Latency : Avg = 137 us, Min = 30 us, Max = 1738 us,
[HOST] [IPU2 ] 113.275788 s: Source to Link Latency : Avg = 22085 us, Min = 10310 us, Max = 44219 us,
[HOST] [IPU2 ] 113.275971 s:
[HOST] [IPU2 ] 113.276093 s:
[HOST] [IPU2 ] 113.276215 s: [ DISPLAY VID1 ] Additional Statistics,
[HOST] [IPU2 ] 113.276337 s: ************************************
[HOST] [IPU2 ] 113.276459 s: Driver Queued = 870 frames
[HOST] [IPU2 ] 113.276550 s: Driver De-Queued = 869 frames
[HOST] [IPU2 ] 113.276672 s: Driver Displayed = 2280 frames
[HOST] [IPU2 ] 113.276794 s: Driver Repeated = 1411 frames
[HOST] [IPU2 ] 113.276916 s:
[HOST] [IPU2 ] 113.276977 s: ##### DSS DISPC Underflow Count = 0 #####
[HOST] [IPU2 ] 113.277099 s:
[HOST] [IPU2 ] 113.283291 s: [CAPTURE] Buffer Q Status,
[HOST] [IPU2 ] 113.283474 s: Empty Q : Elements in Q = 0, Write Idx = 0, Read Idx = 0
[HOST] [IPU2 ] 113.283657 s: Full Q : Elements in Q = 0, Write Idx = 28, Read Idx = 28
[HOST] [IPU2 ] 113.288659 s: [VPE OUT0] Buffer Q Status,
[HOST] [IPU2 ] 113.288781 s: Empty Q : Elements in Q = 0, Write Idx = 0, Read Idx = 0
[HOST] [IPU2 ] 113.288903 s: Full Q : Elements in Q = 0, Write Idx = 28, Read Idx = 28
[HOST] [IPU2 ] 113.289117 s: [VPE OUT1] Buffer Q Status,
[HOST] [IPU2 ] 113.289208 s: Empty Q : Elements in Q = 0, Write Idx = 0, Read Idx = 0
[HOST] [IPU2 ] 113.289330 s: Full Q : Elements in Q = 0, Write Idx = 0, Read Idx = 0
[HOST] [IPU2 ] 113.309125 s: ENCODE Out BufExt Q Status
[HOST] [IPU2 ] 113.309979 s: Empty Q 0 -> count 4, wrPtr 269, rdPtr 265
[HOST] [IPU2 ] 113.310254 s: Full Q -> count 0, wrPtr 261, rdPtr 261
[HOST] [HOST ] 113.253766 s:
[HOST] [HOST ] 113.253766 s: [ IPC_IN_0 ] Link Statistics,
[HOST] [HOST ] 113.253797 s: ******************************
[HOST] [HOST ] 113.253797 s: Elapsed time = 34729 msec
[HOST] [HOST ] 113.253827 s: Get Full Buf Cb = 18.54 fps
[HOST] [HOST ] 113.253827 s: Put Empty Buf Cb = 18.54 fps
[HOST] [HOST ] 113.253827 s: Driver/Notify Cb = 18.51 fps
[HOST] [HOST ] 113.253858 s:
[HOST] [HOST ] 113.253858 s: Input Statistics,
[HOST] [HOST ] 113.253858 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [HOST ] 113.253888 s: | FPS | FPS | FPS | FPS
[HOST] [HOST ] 113.253888 s: --------------------------------------------------
[HOST] [HOST ] 113.253919 s: 0 | 18.54 0. 0 0. 0 18.54
[HOST] [HOST ] 113.253919 s: Output Statistics,
[HOST] [HOST ] 113.253949 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [HOST ] 113.253949 s: | ID | FPS | FPS | FPS
[HOST] [HOST ] 113.253949 s: ---------------------------------------------
[HOST] [HOST ] 113.253980 s: 0 | 0 18.54 0. 0 0. 0
[HOST] [HOST ] 113.253980 s: [ IPC_IN_0 ] LATENCY,
[HOST] [HOST ] 113.253980 s: ********************
[HOST] [HOST ] 113.254010 s: Local Link Latency : Avg = 18 us, Min = 0 us, Max = 793 us,
[HOST] [HOST ] 113.254010 s: Source to Link Latency : Avg = 212771 us, Min = 51051 us, Max = 235383 us,
[HOST] [HOST ] 113.254041 s: [ IPC_IN_0 ] Detailed IPC Latency Statistics [ IPU2 -> HOST ] ,
[HOST] [HOST ] 113.254041 s: ***************************************************************
[HOST] [HOST ] 113.254041 s: IPC One-way Buffer Passing Latency (usecs) : Avg = 325, Min = 183, Max = 5429
[HOST] [HOST ] 113.254071 s: IPC One-way Notify Interrupt Latency (usecs) : Avg = 213, Min = 122, Max = 5338
[HOST] [HOST ] 113.265143 s:
[HOST] [HOST ] 113.265143 s: [ IPC_IN_1 ] Link Statistics,
[HOST] [HOST ] 113.265174 s: ******************************
[HOST] [HOST ] 113.265174 s: Elapsed time = 34788 msec
[HOST] [HOST ] 113.265204 s: Get Full Buf Cb = 25.0 fps
[HOST] [HOST ] 113.265204 s: Put Empty Buf Cb = 25.0 fps
[HOST] [HOST ] 113.265204 s: Driver/Notify Cb = 24.97 fps
[HOST] [HOST ] 113.265235 s: Input Statistics,
[HOST] [HOST ] 113.265235 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [HOST ] 113.265235 s: | FPS | FPS | FPS | FPS
[HOST] [HOST ] 113.265265 s: --------------------------------------------------
[HOST] [HOST ] 113.265265 s: 0 | 25. 0 0. 0 0. 0 25. 0
[HOST] [HOST ] 113.265296 s: Output Statistics,
[HOST] [HOST ] 113.265296 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [HOST ] 113.265296 s: | ID | FPS | FPS | FPS
[HOST] [HOST ] 113.265326 s: ---------------------------------------------
[HOST] [HOST ] 113.265326 s: 0 | 0 25. 0 0. 0 0. 0
[HOST] [HOST ] 113.265326 s: [ IPC_IN_1 ] LATENCY,
[HOST] [HOST ] 113.265357 s: ********************
[HOST] [HOST ] 113.265357 s: Local Link Latency : Avg = 25 us, Min = 0 us, Max = 732 us,
[HOST] [HOST ] 113.265357 s: Source to Link Latency : Avg = 4420 us, Min = 1709 us, Max = 10364 us,
[HOST] [HOST ] 113.265387 s:
[HOST] [HOST ] 113.265387 s: [ IPC_IN_1 ] Detailed IPC Latency Statistics [ IPU2 -> HOST ] ,
[HOST] [HOST ] 113.265387 s: ***************************************************************
[HOST] [HOST ] 113.265418 s: IPC One-way Buffer Passing Latency (usecs) : Avg = 453, Min = 213, Max = 6436
[HOST] [HOST ] 113.265418 s: IPC One-way Notify Interrupt Latency (usecs) : Avg = 247, Min = 122, Max = 5642
[HOST] [HOST ] 113.266028 s:
[HOST] [HOST ] 113.266028 s: [ SGXFRMCPY ] Link Statistics,
[HOST] [HOST ] 113.266058 s: ******************************
[HOST] [HOST ] 113.266058 s: Elapsed time = 34788 msec
[HOST] [HOST ] 113.266089 s: New data Recv = 24.97 fps
[HOST] [HOST ] 113.266089 s: Input Statistics,
[HOST] [HOST ] 113.266119 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [HOST ] 113.266119 s: | FPS | FPS | FPS | FPS
[HOST] [HOST ] 113.266119 s: --------------------------------------------------
[HOST] [HOST ] 113.266119 s: 0 | 25. 0 0. 0 0. 0 25. 0
[HOST] [HOST ] 113.266150 s:
[HOST] [HOST ] 113.266150 s: [ SGXFRMCPY ] LATENCY,
[HOST] [HOST ] 113.266150 s: ********************
[HOST] [HOST ] 113.266180 s: Local Link Latency : Avg = 107 us, Min = 61 us, Max = 9151 us,
[HOST] [HOST ] 113.266180 s: Source to Link Latency : Avg = 4560 us, Min = 1831 us, Max = 18110 us,
[HOST] [HOST ] 113.266821 s:
[HOST] [HOST ] 113.266821 s: [ IPC_OUT_0 ] Link Statistics,
[HOST] [HOST ] 113.266821 s: ******************************
[HOST] [HOST ] 113.266851 s:
[HOST] [HOST ] 113.266851 s: Elapsed time = 34787 msec
[HOST] [HOST ] 113.266882 s: New data Recv = 25.0 fps
[HOST] [HOST ] 113.266882 s: Release data Recv = 24.95 fps
[HOST] [HOST ] 113.266882 s: Driver/Notify Cb = 24.98 fps
[HOST] [HOST ] 113.266912 s: Input Statistics,
[HOST] [HOST ] 113.266943 s:
[HOST] [HOST ] 113.266943 s: CH | In Recv | In Drop | In User Drop | In Process
[HOST] [HOST ] 113.266943 s: | FPS | FPS | FPS | FPS
[HOST] [HOST ] 113.266943 s: --------------------------------------------------
[HOST] [HOST ] 113.266973 s: 0 | 25. 0 0. 0 0. 0 25. 0
[HOST] [HOST ] 113.266973 s: Output Statistics,
[HOST] [HOST ] 113.267004 s:
[HOST] [HOST ] 113.267004 s: CH | Out | Out | Out Drop | Out User Drop
[HOST] [HOST ] 113.267004 s: | ID | FPS | FPS | FPS
[HOST] [HOST ] 113.267004 s: ---------------------------------------------
[HOST] [HOST ] 113.267034 s: 0 | 0 25. 0 0. 0 0. 0
[HOST] [HOST ] 113.267034 s: [ IPC_OUT_0 ] LATENCY,
[HOST] [HOST ] 113.267065 s: ********************
[HOST] [HOST ] 113.267065 s: Local Link Latency : Avg = 1 us, Min = 0 us, Max = 31 us,
[HOST] [HOST ] 113.267065 s: Source to Link Latency : Avg = 21241 us, Min = 8815 us, Max = 41413 us,
[HOST] [HOST ] 113.267095 s:
[HOST] [HOST ] 113.326633 s:
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
[HOST] [HOST ]
Widic
