Other Parts Discussed in Thread: PGA460, INA226
Tool/software: TI-RTOS
I am using TDA2Px EVM,Software version is processor-sdk-radar-3.7.
I built the application according to the user guide and loaded the program via SD card and QSPI, which seems to be no problem. But I choose SD card or Ethernet interface for data reading and writing will be wrong.
The build configuration I chose is tda2px_evm_bios_radar, no other files have been changed.The build step is“gmake -s -j depend”,“gmake -s -j”,“gmake -s sbl”,“gmake -s appimage”.
Configuration information is below:
D:\>cd D:\mmWaveRadar\vision_sdk\build
D:\mmWaveRadar\vision_sdk\build>gmake -s showconfig
D:/mmWaveRadar/vision_sdk/apps/configs/autorules_footer_cfg.mk:67: ipc_PATH does
not exist! ()
not exist! ()
# Build Config is [ tda2px_evm_bios_radar ]
# Build Config file is @ D:/mmWaveRadar/vision_sdk/configs/tda2px_evm_bios_radar
/cfg.mk
# Build Config .h file is @ D:/mmWaveRadar/vision_sdk/links_fw/include/config/ap
ps/tda2px_evm_bios_radar/system_cfg.h
# Build CPUs is @ ipu1_0 ipu1_1 dsp1 eve1
# CPUs included in application,
# PROC_IPU1_0_INCLUDE=yes
# PROC_IPU1_1_INCLUDE=yes
# PROC_IPU2_INCLUDE=no
# PROC_DSP1_INCLUDE=yes
# PROC_DSP2_INCLUDE=no
# PROC_EVE1_INCLUDE=yes
# PROC_EVE2_INCLUDE=no
# PROC_EVE3_INCLUDE=no
# PROC_EVE4_INCLUDE=no
# PROC_A15_0_INCLUDE=no
# Platform config,
# VSDK_BOARD_TYPE=TDA2PX_EVM [options: TDA2XX_EVM TDA2EX_EVM TDA3XX_EVM TDA3XX_R
VP TDA2XX_RVP]
# PLATFORM=tda2px-evm
# DUAL_A15_SMP_BIOS=no
# IPU1_SMP_BIOS=no
# DDR_MEM=DDR_MEM_512M [options: DDR_MEM_128M DDR_MEM_512M DDR_MEM_1024M]
# EMIFMODE=SINGLE_EMIF_512MB [options: SINGLE_EMIF_512MB SINGLE_EMIF_1GB ref bui
ld_pdk.mk]
# NDK_PROC_TO_USE=ipu1_1 [options: a15_0 ipu1_0 ipu1_1 ipu2 none]
# NSP_TFDTP_INCLUDE=yes [options: yes no]
# TDA2EX_ETHSRV_BOARD=no [options: yes no]
# FATFS_PROC_TO_USE=ipu1_0 [options: ipu1_0 none]
# RADAR_BOARD=none [options: TDA3XX_AR12_ALPS TDA3XX_AR12_VIB_DAB_BOOSTER TDA3XX
_RADAR_RVP none]
# Build config,
# BUILD_OS=Windows_NT [options: Windows_NT Linux]
# BUILD_DEPENDENCY_ALWAYS=no
# BUILD_ALGORITHMS=no
# BUILD_INFOADAS=no
# PROFILE=release [options: debug release]
# KW_BUILD=no
# CPLUSPLUS_BUILD=no
# IPU_PRIMARY_CORE=ipu1_0 [options: ipu1_0 ipu2]
# IPU_SECONDARY_CORE=ipu2 [options: ipu1_0 ipu2]
# A15_TARGET_OS=Bios [options: Bios Linux Qnx]
# BSP_STW_PACKAGE_SELECT=all [options: all vps-iss-dss-only vps-vip-vpe]
# Safety Module config,
# RTI_INCLUDE=no
# ECC_FFI_INCLUDE=no
# DCC_ESM_INCLUDE=no
# Video Module config,
# IVAHD_INCLUDE=no
# VPE_INCLUDE=no
# CAL_INCLUDE=no
# ISS_INCLUDE=no
# ISS_ENABLE_DEBUG_TAPS=no
# WDR_LDC_INCLUDE=no
# DSS_INCLUDE=yes
# Open Compute config,
# OPENCL_INCLUDE=no
# TARGET_ROOTDIR=D:/mmWaveRadar/vision_sdk/apps/src/rtos/opencl
# ENABLE_OPENCV=no
# ENABLE_OPENCV_TESTS=no
# OPENVX_INCLUDE=no
# Log config,
# ENABLE_UART_LOG=yes
# ENABLE_NETWORK_LOG=no
# ENABLE_CCS_LOG=no
# CIO_REDIRECT=no
# IPC config,
# WORKQ_INCLUDE=yes
# IPC_LIB_INCLUDE=yes
# AUTOSAR_APP=no
# Surround View config,
# SRV_FAST_BOOT_INCLUDE=no
# Other Module config,
# AVB_INCLUDE=no
# DCAN_INCLUDE=no
# RADAR_ONLY=yes
# RADAR_STUDIO=no
# CPU_IDLE_ENABLED=yes
# FAST_BOOT_INCLUDE=no
# DATA_VIS_INCLUDE=no
# HS_DEVICE=no
# ULTRASONIC_INCLUDE=no
# PGA450=
# PGA460=
# ENABLE_ALL_DEPTH=
# Linux config,
# DEFAULT_UBOOT_CONFIG=dra7xx_evm_vision_config
# DEFAULT_KERNEL_CONFIG=ti_sdk_dra7x_release_defconfig
# DEFAULT_DTB=dra7-evm-infoadas.dtb
# CMEM_INCLUDE=no
# IPUMM_INCLUDE=no
# IPU1_EVELOADER_INCLUDE=no
# ROBUST_RVC_INCLUDE=no
# BUILD_ADAM_CAR=no
# Alg plugins included in build,
# ALG_radarprocess
# Use-cases included in build,
# UC_radar_read_fft_write
not exist! ()
# CPUs that are NOT required but included in config [ tda2px_evm_bios_radar ],
# CPUs that are required but not included in config [ tda2px_evm_bios_radar ],
# Edit D:/mmWaveRadar/vision_sdk/apps/configs/tda2px_evm_bios_radar/cfg.mk to in
clude or exclude CPUs in an application
I choose the SD card boot program, then the sd card inputs the ADC file Input_512x128_4Rx_1Tx_1TS_10Frm.bin, select Write Start, a line of error will occur after about 30 seconds, the URAT log is below:
TDA2Px SBL Boot
DPLL Configuration Completed
Clock Domain Configuration Completed
Module Enable Configuration Completed
TI EVM PAD Config Completed
TDA2Px DDR Configuration
DDR Config Completed
App Image Download Begins
SD Boot - file open completed successfully
IPU1 CPU0 Image Load Completed
IPU1 CPU1 Image Load Completed
DSP1 Image Load Completed
EVE1 Image Load Completed
App Image Download Completed
Putting MPU CPU1 in Off mode
EVE MMU configuration completed
PMCCNTR counts once every 64 clock cycles, multiple by 64 to get actual CPU cycles
SBL Initial Config Cycles - 118128 (10.8 ms)
SOC Init Cycles - 170432 (14.54 ms)
DDR Config Clock Cycles - 89760 (7.65 ms)
App Image Load Cycles - 11110500 (948.9 ms)
Slave Core Bootup Cycles - 91938 (7.84 ms)
SBL Boot-up Cycles - 11581814 (988.31 ms)
Time at which SBL started IPU1_0 - 42153 (1286.40 ms)
Putting MPU in Retention...
[IPU1-0] 1.291099 s: ***** IPU1_0 Firmware build time 17:35:21 Jul 8 2019
[IPU1-0] 1.291313 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-0] 1.293112 s: SYSTEM: System Common Init in progress !!!
[IPU1-0] 1.303178 s: SYSTEM: IPC init in progress !!!
[IPU1-0] 1.303300 s: SYSTEM: IPCLIB init in progress !!!
[IPU1-0] 1.303605 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[IPU1-0] 1.303757 s: SYSTEM: IPCLIB: register to [DSP1] event 15...
[IPU1-0] 1.303818 s: SYSTEM: IPCLIB: register to [EVE1] event 15...
[IPU1-0] 1.303910 s: SYSTEM: IPCLIB init DONE !!!
[IPU1-0] 1.303971 s: SYSTEM: Notify init done !!!
[IPU1-0] 1.305679 s: SYSTEM: MsgQ init done !!!
[IPU1-0] 1.306472 s: SYSTEM: Work Queue init done !!!
[IPU1-0] 1.306563 s: SYSTEM: IPC init DONE !!!
[IPU1-0] 1.310315 s: SYSTEM: System Common Init Done !!!
[IPU1-0] 1.310406 s: SYSTEM: System Init in progress !!!
[IPU1-0] 1.310498 s: SYSTEM: BSP Common Init in progress !!!
[IPU1-0] 1.310559 s: SYSTEM: BSP Common Init Done !!!
[IPU1-0] 1.310620 s: SYSTEM: BSP Platform Init in progress !!!
[IPU1-0] 1.310742 s: SYSTEM: BSP Platform Init Done !!!
[IPU1-0] 1.310833 s: SYSTEM: FVID2 Init in progress !!!
[IPU1-0] 1.310986 s: SYSTEM: FVID2 Init Done !!!
[IPU1-0] 1.311108 s: SYSTEM: VPS Init in progress !!!
[IPU1-0] 1.311169 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0xa0000000 -> 0x80000000]
[IPU1-0] 1.314127 s: *** VPDMA Firmware Loading... ***
[IPU1-0] 1.314249 s: VPDMA Firmware Address = 0x9fd09600
[IPU1-0] 1.314341 s: VPDMA Load Address = 0x4897d004
[IPU1-0] 1.314432 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0] 1.314493 s: VPDMA List Busy Status = 0x00000000
[IPU1-0] 1.314585 s: *** VPDMA Firmware Load Success ***
[IPU1-0] 1.314921 s: *** VPDMA Firmware Loading... ***
[IPU1-0] 1.315012 s: VPDMA Firmware Address = 0x9fd09600
[IPU1-0] 1.315134 s: VPDMA Load Address = 0x4899d004
[IPU1-0] 1.315256 s: VPDMA Firmware Version = 0x4d0001b8
[IPU1-0] 1.315317 s: VPDMA List Busy Status = 0x00000000
[IPU1-0] 1.315409 s: *** VPDMA Firmware Load Success ***
[IPU1-0] 1.377234 s: SYSTEM: VPS Init Done !!!
[IPU1-0] 1.378088 s: UTILS: DMA: HWI Create for INT34 !!!
[IPU1-0] 1.378271 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-0] 1.378393 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261608 B (255 KB)
[IPU1-0] 1.378576 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0] 1.378728 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x88583000, Total size = 368037888 B (350 MB), Free size = 368037888 B (350 MB)
[IPU1-0] 1.378881 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0x00000000, Total size = 0 B (0 MB), Free size = 0 B (0 MB)
[IPU1-0] 1.379064 s: SYSTEM: Initializing Links !!!
[IPU1-0] 1.537058 s: SYSTEM: Initializing Links ... DONE !!!
[IPU1-0] 1.555877 s: BOARD: Board Init in progress !!!
[IPU1-0] 1.556304 s: BOARD: Board Init Done !!!
[IPU1-0] 1.567101 s:
[IPU1-0] 1.567162 s: Vision SDK Version : [REL_VISION_SDK_03_07_00_00]
[IPU1-0] 1.567223 s: FVID2 Version : [FVID_02_01_00_01]
[IPU1-0] 1.567315 s: BSP Version : [PDK_01_10_03_xx]
[IPU1-0] 1.567376 s: Platform : [EVM]
[IPU1-0] 1.567437 s: SOC : [TDA2PX]
[IPU1-0] 1.567498 s: SOC Revision : [ES1.0]
[IPU1-0] 1.567559 s: Board Detected : [Vision]
[IPU1-0] 1.573293 s: EEPROM Base Board Name: [DRA76/7xP,TDA2P]
[IPU1-0] 1.573354 s: Base Board Revision : [REV A]
[IPU1-0] 1.574666 s: Daughter Card Revision: [REV D]
[IPU1-0] 1.574727 s:
[IPU1-1] 1.302964 s: ***** IPU1_1 Firmware build time 17:33:20 Jul 8 2019
[IPU1-1] 1.303147 s: *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
[IPU1-1] 1.306350 s: UTILS: DMA: HWI Create for INT25 !!!
[IPU1-1] 1.335234 s: SYSTEM: System Common Init in progress !!!
[IPU1-1] 1.335570 s: SYSTEM: IPC init in progress !!!
[IPU1-1] 1.335692 s: SYSTEM: IPCLIB init in progress !!!
[IPU1-1] 1.335966 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[IPU1-1] 1.336149 s: SYSTEM: IPCLIB: register to [DSP1] event 15...
[IPU1-1] 1.336241 s: SYSTEM: IPCLIB: register to [EVE1] event 15...
[IPU1-1] 1.336363 s: SYSTEM: IPCLIB init DONE !!!
[IPU1-1] 1.336424 s: SYSTEM: Notify init done !!!
[IPU1-1] 1.338284 s: SYSTEM: MsgQ init done !!!
[IPU1-1] 1.339108 s: SYSTEM: Work Queue init done !!!
[IPU1-1] 1.339199 s: SYSTEM: IPC init DONE !!!
[IPU1-1] 1.343134 s: SYSTEM: System Common Init Done !!!
[IPU1-1] 1.343225 s: SYSTEM: System IPU1_1 Init in progress !!!
[IPU1-1] 1.343286 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[IPU1-1] 1.343408 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 637904 B (622 KB)
[IPU1-1] 1.343622 s: SYSTEM: Initializing Links !!!
[IPU1-1] 1.446593 s: UTILS: PRF: ##### Cannot allocate Object for SYNC1 ####
[IPU1-1] 1.449734 s: UTILS: PRF: ##### Cannot allocate Object for SYNC2 ####
[IPU1-1] 1.452723 s: UTILS: PRF: ##### Cannot allocate Object for SYNC3 ####
[IPU1-1] 1.455621 s: UTILS: PRF: ##### Cannot allocate Object for TFDTPRX ####
[IPU1-1] 1.458579 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM0 ####
[IPU1-1] 1.462178 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM1 ####
[IPU1-1] 1.465564 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM2 ####
[IPU1-1] 1.469102 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM3 ####
[IPU1-1] 1.472457 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM4 ####
[IPU1-1] 1.475965 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM5 ####
[IPU1-1] 1.479533 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM6 ####
[IPU1-1] 1.483133 s: UTILS: PRF: ##### Cannot allocate Object for ALGORITHM7 ####
[IPU1-1] 1.483255 s: SYSTEM: Initializing Links ... DONE !!!
[IPU1-1] 1.484353 s: SYSTEM: System IPU1_1 Init Done !!!
[IPU1-1] 1.606325 s: NSP GMAC: PHY 2 Found on MAC Port 0
[IPU1-1] 1.608735 s: NSP GMAC: PHY 3 Found on MAC Port 1
[DSP1 ] 1.288934 s: SYSTEM: System Common Init Done !!!
[DSP1 ] 1.288964 s: SYSTEM: System DSP Init in progress !!!
[DSP1 ] 1.289147 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[DSP1 ] 1.289178 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP1 ] 1.289239 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 524128 B (511 KB)
[DSP1 ] 1.289269 s: SYSTEM: Initializing Links !!!
[DSP1 ] 1.296956 s: SYSTEM: Initializing Links ... DONE !!!
[DSP1 ] 1.296986 s: SYSTEM: System DSP Init Done !!!
[DSP1 ] 1.544744 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
[DSP1 ] 1.544805 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
[EVE1 ] 1.302110 s: ***** EVE Firmware build time 17:30:05 Jul 8 2019
[EVE1 ] 1.303605 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
[EVE1 ] 1.305801 s: SYSTEM: System Common Init in progress !!!
[EVE1 ] 1.306899 s: SYSTEM: IPC init in progress !!!
[EVE1 ] 1.307661 s: SYSTEM: IPCLIB init in progress !!!
[EVE1 ] 1.308942 s: SYSTEM: IPCLIB: register to [IPU1-0] event 15...
[EVE1 ] 1.309918 s: SYSTEM: IPCLIB: register to [IPU1-1] event 15...
[EVE1 ] 1.310955 s: SYSTEM: IPCLIB: register to [DSP1] event 15...
[EVE1 ] 1.311931 s: SYSTEM: IPCLIB init DONE !!!
[EVE1 ] 1.312694 s: SYSTEM: Notify init done !!!
[EVE1 ] 1.314097 s: SYSTEM: MsgQ init done !!!
[EVE1 ] 1.315226 s: SYSTEM: Work Queue init done !!!
[EVE1 ] 1.316080 s: SYSTEM: IPC init DONE !!!
[EVE1 ] 1.328188 s: SYSTEM: System Common Init Done !!!
[EVE1 ] 1.329012 s: SYSTEM: System EVE Init in progress !!!
[EVE1 ] 1.330262 s: UTILS: DMA: HWI Create for INT8 !!!
[EVE1 ] 1.331269 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
[EVE1 ] 1.332367 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
[EVE1 ] 1.334350 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261952 B (255 KB)
[EVE1 ] 1.336332 s: SYSTEM: Initializing Links !!!
[EVE1 ] 1.415177 s: SYSTEM: Initializing Links ... DONE !!!
[EVE1 ] 1.416092 s: SYSTEM: System EVE Init Done !!!
[IPU1-0] 2.611938 s: UTILS_PRCM_STATS: INA226 Setup Failed. Check if INA226 is connected on I2C3 Lines
[IPU1-0] 2.612090 s: QSPI Init Started
[IPU1-0] 2.612304 s: MID - 1
[IPU1-0] 2.612365 s: DID - 18
[IPU1-0] 2.612426 s: QSPI Init Completed Sucessfully
[IPU1-0] 2.617733 s:
[IPU1-0] 2.617794 s: Current System Settings,
[IPU1-0] 2.617824 s: ========================
[IPU1-0] 2.617885 s: Display Type : HDMI 1920x1080 @ 60fps
[IPU1-0] 2.617946 s: My IP address for interface 1 : 192.168.1.200
[IPU1-0] 2.618038 s: My IP address for interface 2 : 0.0.0.0
[IPU1-0] 2.618129 s:
[IPU1-0] 2.618160 s: ============
[IPU1-0] 2.618190 s: Usecase Menu
[IPU1-0] 2.618251 s: ============
[IPU1-0] 2.618282 s:
[IPU1-0]
[IPU1-0] Vision SDK Usecases,
[IPU1-0] --------------------
[IPU1-0]
[IPU1-0] 1: RADAR Usecases
[IPU1-0] 2: MISC Tests
[IPU1-0]
[IPU1-0] s: System Settings
[IPU1-0]
[IPU1-0] x: Exit
[IPU1-0]
[IPU1-0] Enter Choice:
[IPU1-0]
[IPU1-1] 3.407033 s: NDK: Link Status: 100Mb/s Full Duplex on PHY 2
[IPU1-1] 6.484170 s: NETWORK_CTRL: Starting Server (port=5000) !!!
[IPU1-1] 6.484444 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
[IPU1-0] 7.490758 s:
[IPU1-0] 7.490880 s:
[IPU1-0]
[IPU1-0] RADAR Usecases
[IPU1-0]
[IPU1-0] 6: Null Source (SD/Network) Input + Radar FFT (EVE1) + Null (SD/Network)
[IPU1-0]
[IPU1-0] x: Exit
[IPU1-0]
[IPU1-0]
[IPU1-0] 9.008662 s:
[IPU1-0] 9.008723 s:
[IPU1-0]
[IPU1-0] Select Data Read/Write Mode,
[IPU1-0] 1: SD CARD
[IPU1-0] 2: NETWORK
[IPU1-0]
[IPU1-0]
[IPU1-0] 11.309095 s: IPC_OUT_0 : Create in progress !!!
[IPU1-0] 11.309461 s: IPC_OUT_0 : Create Done !!!
[DSP1 ] 11.309644 s: IPC_IN_0 : Create in progress !!!
[DSP1 ] 11.309979 s: IPC_IN_0 : Create Done !!!
[DSP1 ] 11.310132 s: ALGORITHM: Create in progress (algId = 11) !!!
[DSP1 ] 12.815531 s: ALG: ti.radar.fft: CH0 BUF0: 0x88a8d000 ( 1048576 B )
[DSP1 ] 12.817879 s: ALG: ti.radar.fft: CH0 BUF1: 0x88b8d200 ( 1048576 B )
[DSP1 ] 12.817940 s: ALGORITHM: Create Done (algId = 11) !!!
[DSP1 ] 12.818276 s: IPC_OUT_0 : Create in progress !!!
[DSP1 ] 12.818367 s: IPC_OUT_0 : Create Done !!!
[DSP1 ] 12.820014 s: ALGORITHM: Create in progress (algId = 11) !!!
[DSP1 ] 12.837186 s: UTILS: DMA: Allocated CH (TCC) = 24 (24)
[DSP1 ] 12.837217 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 24 (0x43305200)
[DSP1 ] 12.845726 s: ALG: ti.radar.drawfftheatmap: CH0 BUF0: 0x89476400 ( 4147200 B )
[DSP1 ] 12.854175 s: ALG: ti.radar.drawfftheatmap: CH0 BUF1: 0x8986ac00 ( 4147200 B )
[DSP1 ] 12.862654 s: ALG: ti.radar.drawfftheatmap: CH0 BUF2: 0x89c5f400 ( 4147200 B )
[DSP1 ] 12.862715 s: ALGORITHM: Create Done (algId = 11) !!!
[DSP1 ] 12.862898 s: IPC_OUT_1 : Create in progress !!!
[DSP1 ] 12.862959 s: IPC_OUT_1 : Create Done !!!
[DSP1 ] 14.545293 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[DSP1 ] 14.545324 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
[DSP1 ] 14.545385 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 478408 B (467 KB)
[EVE1 ] 14.546025 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[EVE1 ] 14.546361 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 18304 B (17 KB)
[EVE1 ] 14.546910 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 261408 B (255 KB)
[IPU1-0] 12.818581 s: IPC_IN_0 : Create in progress !!!
[IPU1-0] 12.819496 s: IPC_IN_0 : Create Done !!!
[IPU1-0] 12.863051 s: IPC_IN_1 : Create in progress !!!
[IPU1-0] 12.863966 s: IPC_IN_1 : Create Done !!!
[IPU1-0] 12.864423 s: DISPLAY: Create in progress !!!
[IPU1-0] 12.864881 s: DISPLAY: Create Done !!!
[IPU1-0] 12.865125 s: GRPXSRC: Create in progress !!!
[IPU1-0] 14.542396 s: GRPXSRC: Create Done !!!
[IPU1-0] 14.542792 s: DISPLAY: Create in progress !!!
[IPU1-0] 14.543250 s: DISPLAY: Create Done !!!
[IPU1-0] 14.543494 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1022
[IPU1-0] 14.543616 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 258488 B (252 KB)
[IPU1-0] 14.543768 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
[IPU1-0] 14.543921 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x88583000, Total size = 368037888 B (350 MB), Free size = 335772672 B (320 MB)
[IPU1-0] 14.544073 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0x00000000, Total size = 0 B (0 MB), Free size = 0 B (0 MB)
[IPU1-0] 14.547520 s: DISPLAY: Start in progress !!!
[IPU1-0] 14.547611 s: DISPLAY: Start Done !!!
[IPU1-0] 14.548282 s: *** UTILS: CPU KHz = 20000 Khz ***
[IPU1-0] 14.558653 s: DISPLAY: Start in progress !!!
[IPU1-0] 14.558744 s: DISPLAY: Start Done !!!
[IPU1-0] 14.559995 s:
[IPU1-0]
[IPU1-0] ====================
[IPU1-0] Chains Run-time Menu
[IPU1-0]
[IPU1-0] 0: Stop Chain
[IPU1-0]
[IPU1-0] p: Print Performance Statistics
[IPU1-0]
[IPU1-0] f: File IO Menu
[IPU1-0]
[IPU1-0]
[IPU1-1] 14.544836 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023
[IPU1-1] 14.544958 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 655360 B (640 KB), Free size = 637648 B (622 KB)
[IPU1-0] 17.232111 s:
[IPU1-0]
[IPU1-0] FILE IO Run-time Menu
[IPU1-0]
[IPU1-0] a: Write Start
[IPU1-0] b: Write Pause
[IPU1-0] c: Write Resume
[IPU1-0] d: Write Stop
[IPU1-0] e: Write One Frame
[IPU1-0]
[IPU1-0] x: Exit from FileIOMenu
[IPU1-0]
[IPU1-0]
[IPU1-0] 20.138778 s: FILE_IO: File Write Start
[IPU1-0] 20.138870 s: FILE_IO: File Write Start
[IPU1-0] 20.138900 s: FILE_IO: File Write Start
[IPU1-0] 20.138961 s: FILE_IO: File Write Start
[IPU1-0] 20.139022 s: FILE_IO: File Write Start
[IPU1-0] 20.139083 s: FILE_IO: File Write Start
[IPU1-0] 20.139144 s:
[IPU1-0]
[IPU1-0]
[IPU1-0]
[IPU1-0]
[IPU1-0]
[DSP1 ] 45.669950 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.699932 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.729945 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.759958 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.789940 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.819953 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.849935 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.879948 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.909961 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.939943 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.969956 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 45.999938 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.029951 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.059964 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.089946 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.119959 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.149972 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.179954 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.209967 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.239949 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.269962 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.299975 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.329957 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.359970 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.389953 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.419965 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.449978 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.479960 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.509973 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.539956 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.569968 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.599981 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.629964 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.659976 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.689959 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.719971 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
[DSP1 ] 46.749984 s: UTILS: MBX: Utils_mbxSendCmd(): Msg Alloc Failed (0)!!!
At what step might there be an error?
