Part Number: TDA2HG
Hi Sir,
My HW is TDA2x EVM and SDK is PROCESSOR_SDK_VISION_03_06_00_00, system is RTOS
I insert OpenCVCanny link into AVB use-case.
The link structure is following:
AvbRx (IPU1_1) -> Decode -> Alg_OpenCVCanny (A15) -> VPE -> Sync -> Alg_DmaSwMs -> Dup -> Alg_OpenCVCanny (A15) -> Display_Video
When I set one AVB camera as input, this case is runing OK.
When I set 4 AVB cameras as input and execute use case, it shows below error message:
[IPU1-0] Select Use-case Config,
[IPU1-0] --------------------
[IPU1-0] 1: AVB TX Only
[IPU1-0] 2: HDMI Display + AVB TX
[IPU1-0]
[IPU1-0] Enter Choice:
[IPU1-0]
[IPU1-0] 23.033947 s:
[IPU1-0] Codec is MJPEG
[IPU1-0] 24.405569 s: IPC_IN_0 : Create in progress !!!
[IPU1-0] 24.406789 s: IPC_IN_0 : Create Done !!!
[IPU1-0] 24.406972 s: DECODE: Create in progress ... !!!
[IPU1-0] 24.409961 s: declink_codec_set_ch_alg_create_params: Set CH=0 ALG Parameter format=24 ... !!!
[IPU1-0] 24.467120 s: DECODE: Creating CH0 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0] 24.468004 s: declink_codec_set_ch_alg_create_params: Set CH=1 ALG Parameter format=24 ... !!!
[IPU1-0] 24.524797 s: DECODE: Creating CH1 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0] 24.525712 s: declink_codec_set_ch_alg_create_params: Set CH=2 ALG Parameter format=24 ... !!!
[IPU1-0] 24.583297 s: DECODE: Creating CH2 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0] 24.584243 s: declink_codec_set_ch_alg_create_params: Set CH=3 ALG Parameter format=24 ... !!!
[IPU1-0] 24.640913 s: DECODE: Creating CH3 of 1280 x 720 [1] [0],target bitrate = 10000 Kbps ...
[IPU1-0] 24.641737 s: DECODE: All CH Create ... DONE !!!
[IPU1-0] 24.643750 s: DECODE: Create ... DONE !!!
[IPU1-0] 24.644390 s: IPC_OUT_0 : Create in progress !!!
[IPU1-0] 24.644817 s: IPC_OUT_0 : Create Done !!!
[IPU1-1] 24.404928 s: IPC_OUT_0 : Create in progress !!!
[IPU1-1] 24.405264 s: IPC_OUT_0 : Create Done !!!
[HOST ] 24.645031 s: IPC_IN_0 : Create in progress !!!
[HOST ] 24.645366 s: IPC_IN_0 : Create Done !!!
[HOST ] 24.645610 s: ALGORITHM: Create in progress (algId = 15) !!!
[HOST ] 24.649942 s: Assertion @ Line: 420 in algorithmLink_algPluginSupport.c: status == SYSTEM_LINK_STATUS_SOK : failed !!!
What did it go wrong and what should I do, please help.
Ranny.
