Part Number: TDA2SX
Hi, I transplant RTOS TIDL usecase on HLOS like the picture, and changge algtidlpreproc on A15 to DSP1 ,Compile ok,and run without fail。
but only the display link proecess one time,and then there is no Other phenomena。 I want to ask if tidl can run like that。
[HOST] [HOST ] 3.625236 s: SYSTEM: System A15 Init in progress !!! [HOST] [HOST ] 3.625358 s: SYSTEM: IPC: Init in progress !!! [HOST] [HOST ] 3.625358 s: SYSTEM: IPC: Notify init in progress !!! [HOST] [HOST ] 3.625602 s: SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81) [HOST] [HOST ] 3.625632 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!! [HOST] [HOST ] 3.625663 s: SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80) [HOST] [HOST ] 3.625663 s: SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!! [HOST] [HOST ] 3.625815 s: SYSTEM: IPC: [DSP1] socket bind success !!! (dst vproc = 2, endpt = 81) [HOST] [HOST ] 3.625846 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 81) !!! [HOST] [HOST ] 3.625876 s: SYSTEM: IPC: [DSP1] socket connect success !!! (dst vproc = 2, endpt = 80) [HOST] [HOST ] 3.625876 s: SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 1024) !!! [HOST] [HOST ] 3.626029 s: SYSTEM: IPC: [DSP2] socket bind success !!! (dst vproc = 3, endpt = 81) [HOST] [HOST ] 3.626059 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 81) !!! [HOST] [HOST ] 3.626059 s: SYSTEM: IPC: [DSP2] socket connect success !!! (dst vproc = 3, endpt = 80) [HOST] [HOST ] 3.626090 s: SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!! [HOST] [HOST ] 3.626242 s: SYSTEM: IPC: Notify init DONE !!! [HOST] [HOST ] 3.626242 s: SYSTEM: MSGQ: MsgQ init in progress !!! [HOST] [HOST ] 3.626364 s: SYSTEM: MSGQ: MsgQ init DONE !!! [HOST] [HOST ] 3.626364 s: SYSTEM: IPC: Init DONE !!! [HOST] [HOST ] 3.626364 s: SYSTEM: Initializing A15 Links !!! [HOST] [HOST ] 3.626486 s: IPC_OUT_0 : Init done - linkid-0x2000000 [HOST] [HOST ] 3.626608 s: IPC_OUT_1 : Init done - linkid-0x2000001 [HOST] [HOST ] 3.626730 s: IPC_OUT_2 : Init done - linkid-0x2000002 [HOST] [HOST ] 3.626852 s: IPC_OUT_3 : Init done - linkid-0x2000003 [HOST] [HOST ] 3.626974 s: IPC_OUT_4 : Init done - linkid-0x2000004 [HOST] [HOST ] 3.627096 s: IPC_IN_0 : Init done - linkid-0x200000a [HOST] [HOST ] 3.627218 s: IPC_IN_1 : Init done - linkid-0x200000b [HOST] [HOST ] 3.627340 s: IPC_IN_2 : Init done - linkid-0x200000c [HOST] [HOST ] 3.627462 s: IPC_IN_3 : Init done - linkid-0x200000d [HOST] [HOST ] 3.627584 s: IPC_IN_4 : Init done - linkid-0x200000e [HOST] [HOST ] 3.627706 s: IPC_IN_5 : Init done - linkid-0x200000f [HOST] [HOST ] 3.627828 s: IPC_IN_6 : Init done - linkid-0x2000010 [HOST] [HOST ] 3.627950 s: NULL_0 : Init done - linkid-0x2000014 [HOST] [HOST ] 3.628072 s: NULL_1 : Init done - linkid-0x2000015 [HOST] [HOST ] 3.628255 s: NULL_SRC_0 : Init done - linkid-0x2000039 [HOST] [HOST ] 3.628408 s: DISP_DIST_SRC_0 : Init done - linkid-0x2000067 [HOST] [HOST ] 3.628530 s: DISP_DIST_SRC_1 : Init done - linkid-0x2000068 [HOST] [HOST ] 3.628621 s: DISP_DIST_SRC_2 : Init done - linkid-0x2000069 [HOST] [HOST ] 3.628713 s: DISP_DIST_SRC_3 : Init done - linkid-0x200006a [HOST] [HOST ] 3.629079 s: SGX2DSRV_0 : Init done - linkid-0x2000072 [HOST] [HOST ] 3.629170 s: SGX2DSRV_1 : Init done - linkid-0x2000073 [HOST] [HOST ] 3.629262 s: GRPXRENDER_0 : Init done - linkid-0x2000074 (none) [HOST] [HOST ] 3.629353 s: ALGORITHM_0 : Init done - linkid-0x2000031 login: root (automatic login) [HOST] [HOST ] 3.629445 s: ALGORITHM_1 : Init done - linkid-0x2000032 [HOST] [HOST ] 3.629567 s: ALGORITHM_2 : Init done - linkid-0x2000033 [HOST] [HOST ] 3.629659 s: ALGORITHM_3 : Init done - linkid-0x2000034 [HOST] [HOST ] 3.629720 s: ALGORITHM_4 : Init done - linkid-0x2000035 [HOST] [HOST ] 3.629872 s: ALGORITHM_5 : Init done - linkid-0x2000036 [HOST] [HOST ] 3.629994 s: ALGORITHM_6 : Init done - linkid-0x2000037 [HOST] [HOST ] 3.630086 s: ALGORITHM_7 : Init done - linkid-0x2000038 [HOST] [HOST ] 3.630208 s: DUP0 : Init done - linkid-0x0 [HOST] [HOST ] 3.630330 s: DUP1 : Init done - linkid-0x0 [HOST] [HOST ] 3.630482 s: DUP2 : Init done - linkid-0x0 [HOST] [HOST ] 3.630604 s: DUP3 : Init done - linkid-0x0 [HOST] [HOST ] 3.630818 s: DUP4 : Init done - linkid-0x0 [HOST] [HOST ] 3.630940 s: SYNC_0 : Init done - linkid-0x0 [HOST] [HOST ] 3.631031 s: SYNC_1 : Init done - linkid-0x0 [HOST] [HOST ] 3.631123 s: SYNC_2 : Init done - linkid-0x0 [HOST] [HOST ] 3.631214 s: SYNC_3 : Init done - linkid-0x0 [HOST] [HOST ] 3.631306 s: MERGE_0 : Init done - linkid-0x0 [HOST] [HOST ] 3.631428 s: MERGE_1 : Init done - linkid-0x0 [HOST] [HOST ] 3.631519 s: MERGE_2 : Init done - linkid-0x0 [HOST] [HOST ] 3.631611 s: MERGE_3 : Init done - linkid-0x0 [HOST] [HOST ] 3.631733 s: MERGE_4 : Init done - linkid-0x0 [HOST] [HOST ] 3.631824 s: SELECT_0 : Init done - linkid-0x0 [HOST] [HOST ] 3.631916 s: SELECT_1 : Init done - linkid-0x0 [HOST] [HOST ] 3.632007 s: GATE_0 : Init done - linkid-0x0 [HOST] [HOST ] 3.632068 s: GATE_1 : Init done - linkid-0x0 [HOST] [HOST ] 3.632160 s: GATE_2 : Init done - linkid-0x0 [HOST] [HOST ] 3.632251 s: GATE_3 : Init done - linkid-0x0 [HOST] [HOST ] 3.632312 s: SGXFRMCPY_0 : Init done - linkid-0x200004f [HOST] [HOST ] 3.632312 s: SYSTEM: Initializing A15 Links ... DONE !!! [HOST] [HOST ] 3.632648 s: OSA: Adjusting global time, timeH by 0 units!!! [HOST] [HOST ] 3.632648 s: SYSTEM: System A15 Init Done !!! [HOST] [HOST ] 3.632770 s: NETWORK_CTRL: Starting Server (port=5000) !!! [HOST] [HOST ] 3.632861 s: NETWORK_CTRL: Starting Server ... DONE (port=5000) !!! [HOST] [DSP1 ] 1.259318 s: ***** DSP1 Firmware build time 08:45:00 Nov 13 2019 [HOST] [DSP1 ] 1.259409 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 600000000 Hz> [HOST] [DSP1 ] 1.259653 s: SYSTEM: System Common Init in progress !!! [HOST] [DSP1 ] 1.259897 s: UTILS: CIO: Init Done !!! [HOST] [DSP1 ] 1.259958 s: SYSTEM: IPC init in progress !!! [HOST] [DSP1 ] 1.259958 s: SYSTEM: Attaching to [IPU2] ... [HOST] [DSP1 ] 1.374092 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [DSP1 ] 1.379033 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [DSP1 ] 1.404288 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [DSP1 ] 1.424296 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [DSP1 ] 1.444335 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [DSP1 ] 1.464314 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [DSP1 ] 1.464344 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [DSP1 ] 1.464405 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [DSP1 ] 1.464466 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [DSP1 ] 1.464497 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [DSP1 ] 1.464558 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [DSP1 ] 1.464588 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [DSP1 ] 1.464649 s: SYSTEM: Notify init done !!! [HOST] [DSP1 ] 1.464802 s: SYSTEM: MsgQ init done !!! [HOST] [DSP1 ] 1.464954 s: RpmsgInit in progress... [HOST] [DSP1 ] 1.464985 s: SYSTEM: IPC init DONE !!! [HOST] [DSP1 ] 1.465686 s: SYSTEM: System Common Init Done !!! [HOST] [DSP1 ] 1.465717 s: SYSTEM: System DSP Init in progress !!! [HOST] [DSP1 ] 1.465991 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [DSP1 ] 1.466052 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [HOST] [DSP1 ] 1.466083 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516496 B (504 KB) [HOST] [DSP1 ] 1.466113 s: SYSTEM: Initializing Links !!! [HOST] [DSP1 ] 1.476636 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [DSP1 ] 1.476666 s: AlgorithmLink_tidlpreproc_initPluginDsp **************** [HOST] [DSP1 ] 1.476697 s: SYSTEM: System DSP Init Done !!! [HOST] [DSP1 ] 1.818916 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!! [HOST] [DSP1 ] 1.818947 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!! [HOST] [DSP1 ] 2.994936 s: Connection established with HLOS, calling rpmsgInit [HOST] [DSP2 ] 1.333557 s: ***** DSP2 Firmware build time 08:44:59 Nov 13 2019 [HOST] [DSP2 ] 1.333618 s: *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 600000000 Hz> [HOST] [DSP2 ] 1.333892 s: SYSTEM: System Common Init in progress !!! [HOST] [DSP2 ] 1.334136 s: UTILS: CIO: Init Done !!! [HOST] [DSP2 ] 1.334167 s: SYSTEM: IPC init in progress !!! [HOST] [DSP2 ] 1.334197 s: SYSTEM: Attaching to [IPU2] ... [HOST] [DSP2 ] 1.377173 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [DSP2 ] 1.379033 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [DSP2 ] 1.414201 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [DSP2 ] 1.434209 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [DSP2 ] 1.454218 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [DSP2 ] 1.474226 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [DSP2 ] 1.474257 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [DSP2 ] 1.474318 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [DSP2 ] 1.474379 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [DSP2 ] 1.474409 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [DSP2 ] 1.474470 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [DSP2 ] 1.474501 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [DSP2 ] 1.474562 s: SYSTEM: Notify init done !!! [HOST] [DSP2 ] 1.474745 s: SYSTEM: MsgQ init done !!! [HOST] [DSP2 ] 1.474836 s: RpmsgInit in progress... [HOST] [DSP2 ] 1.474867 s: SYSTEM: IPC init DONE !!! [HOST] [DSP2 ] 1.475599 s: SYSTEM: System Common Init Done !!! [HOST] [DSP2 ] 1.475629 s: SYSTEM: System DSP Init in progress !!! [HOST] [DSP2 ] 1.475934 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [DSP2 ] 1.475965 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [HOST] [DSP2 ] 1.476026 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516496 B (504 KB) [HOST] [DSP2 ] 1.476056 s: SYSTEM: Initializing Links !!! [HOST] [DSP2 ] 1.486610 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [DSP2 ] 1.486640 s: AlgorithmLink_tidlpreproc_initPluginDsp **************** [HOST] [DSP2 ] 1.486671 s: SYSTEM: System DSP Init Done !!! [HOST] [DSP2 ] 1.820899 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!! [HOST] [DSP2 ] 1.820929 s: SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!! [HOST] [DSP2 ] 3.003934 s: Connection established with HLOS, calling rpmsgInit [HOST] [EVE1 ] 1.377783 s: ***** EVE Firmware build time 08:44:59 Nov 13 2019 [HOST] [EVE1 ] 1.379430 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [HOST] [EVE1 ] 1.382419 s: SYSTEM: System Common Init in progress !!! [HOST] [EVE1 ] 1.384432 s: UTILS: CIO: Init Done !!! [HOST] [EVE1 ] 1.385255 s: SYSTEM: IPC init in progress !!! [HOST] [EVE1 ] 1.386109 s: SYSTEM: Attaching to [IPU2] ... [HOST] [EVE1 ] 1.394619 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [EVE1 ] 1.404318 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [EVE1 ] 1.414201 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [EVE1 ] 1.454401 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [EVE1 ] 1.484353 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [EVE1 ] 1.504361 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [EVE1 ] 1.505337 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [EVE1 ] 1.506496 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [EVE1 ] 1.507625 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [EVE1 ] 1.508753 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [EVE1 ] 1.509882 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [EVE1 ] 1.511041 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [EVE1 ] 1.512169 s: SYSTEM: Notify init done !!! [HOST] [EVE1 ] 1.513847 s: SYSTEM: MsgQ init done !!! [HOST] [EVE1 ] 1.514640 s: SYSTEM: IPC init DONE !!! [HOST] [EVE1 ] 1.527115 s: SYSTEM: System Common Init Done !!! [HOST] [EVE1 ] 1.527969 s: SYSTEM: System EVE Init in progress !!! [HOST] [EVE1 ] 1.529250 s: UTILS: DMA: HWI Create for INT8 !!! [HOST] [EVE1 ] 1.530287 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [EVE1 ] 1.531446 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE1 ] 1.533642 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB) [HOST] [EVE1 ] 1.535655 s: SYSTEM: Initializing Links !!! [HOST] [EVE1 ] 1.634478 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [EVE1 ] 1.635393 s: AlgorithmLink_tidl_initPluginEve ******************* [HOST] [EVE1 ] 1.636399 s: SYSTEM: System EVE Init Done !!! [HOST] [EVE2 ] 1.377935 s: ***** EVE Firmware build time 08:44:59 Nov 13 2019 [HOST] [EVE2 ] 1.379582 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [HOST] [EVE2 ] 1.383090 s: SYSTEM: System Common Init in progress !!! [HOST] [EVE2 ] 1.385103 s: UTILS: CIO: Init Done !!! [HOST] [EVE2 ] 1.385957 s: SYSTEM: IPC init in progress !!! [HOST] [EVE2 ] 1.386841 s: SYSTEM: Attaching to [IPU2] ... [HOST] [EVE2 ] 1.414689 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [EVE2 ] 1.424327 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [EVE2 ] 1.434209 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [EVE2 ] 1.454401 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [EVE2 ] 1.504209 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [EVE2 ] 1.524217 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [EVE2 ] 1.525163 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [EVE2 ] 1.526383 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [EVE2 ] 1.527603 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [EVE2 ] 1.528792 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [EVE2 ] 1.530012 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [EVE2 ] 1.531202 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [EVE2 ] 1.532452 s: SYSTEM: Notify init done !!! [HOST] [EVE2 ] 1.534160 s: SYSTEM: MsgQ init done !!! [HOST] [EVE2 ] 1.534984 s: SYSTEM: IPC init DONE !!! [HOST] [EVE2 ] 1.548038 s: SYSTEM: System Common Init Done !!! [HOST] [EVE2 ] 1.548923 s: SYSTEM: System EVE Init in progress !!! [HOST] [EVE2 ] 1.550295 s: UTILS: DMA: HWI Create for INT8 !!! [HOST] [EVE2 ] 1.551424 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [EVE2 ] 1.552644 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE2 ] 1.555145 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB) [HOST] [EVE2 ] 1.557189 s: SYSTEM: Initializing Links !!! [HOST] [EVE2 ] 1.656042 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [EVE2 ] 1.656957 s: AlgorithmLink_tidl_initPluginEve ******************* [HOST] [EVE2 ] 1.657902 s: SYSTEM: System EVE Init Done !!! [HOST] [EVE3 ] 1.377905 s: ***** EVE Firmware build time 08:45:00 Nov 13 2019 [HOST] [EVE3 ] 1.379582 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [HOST] [EVE3 ] 1.382571 s: SYSTEM: System Common Init in progress !!! [HOST] [EVE3 ] 1.384584 s: UTILS: CIO: Init Done !!! [HOST] [EVE3 ] 1.385408 s: SYSTEM: IPC init in progress !!! [HOST] [EVE3 ] 1.386262 s: SYSTEM: Attaching to [IPU2] ... [HOST] [EVE3 ] 1.434636 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [EVE3 ] 1.444335 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [EVE3 ] 1.454218 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [EVE3 ] 1.484353 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [EVE3 ] 1.504209 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [EVE3 ] 1.544226 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [EVE3 ] 1.545202 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [EVE3 ] 1.546452 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [EVE3 ] 1.547733 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [EVE3 ] 1.549014 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [EVE3 ] 1.550295 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [EVE3 ] 1.551607 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [EVE3 ] 1.552918 s: SYSTEM: Notify init done !!! [HOST] [EVE3 ] 1.554840 s: SYSTEM: MsgQ init done !!! [HOST] [EVE3 ] 1.555664 s: SYSTEM: IPC init DONE !!! [HOST] [EVE3 ] 1.569206 s: SYSTEM: System Common Init Done !!! [HOST] [EVE3 ] 1.570182 s: SYSTEM: System EVE Init in progress !!! [HOST] [EVE3 ] 1.571646 s: UTILS: DMA: HWI Create for INT8 !!! [HOST] [EVE3 ] 1.572927 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [EVE3 ] 1.574330 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE3 ] 1.576740 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB) [HOST] [EVE3 ] 1.578966 s: SYSTEM: Initializing Links !!! [HOST] [EVE3 ] 1.674525 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [EVE3 ] 1.675379 s: AlgorithmLink_tidl_initPluginEve ******************* [HOST] [EVE3 ] 1.676294 s: SYSTEM: System EVE Init Done !!! [HOST] [EVE4 ] 1.377966 s: ***** EVE Firmware build time 08:44:59 Nov 13 2019 [HOST] [EVE4 ] 1.379613 s: *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz> [HOST] [EVE4 ] 1.383090 s: SYSTEM: System Common Init in progress !!! [HOST] [EVE4 ] 1.385103 s: UTILS: CIO: Init Done !!! [HOST] [EVE4 ] 1.385957 s: SYSTEM: IPC init in progress !!! [HOST] [EVE4 ] 1.386811 s: SYSTEM: Attaching to [IPU2] ... [HOST] [EVE4 ] 1.454675 s: SYSTEM: Attaching to [IPU2] ... SUCCESS !!! [HOST] [EVE4 ] 1.464314 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [EVE4 ] 1.474226 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [EVE4 ] 1.504361 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [EVE4 ] 1.524217 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [EVE4 ] 1.544226 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [EVE4 ] 1.545202 s: SYSTEM: Notify register to [IPU2] line 0, event 15... [HOST] [EVE4 ] 1.546452 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [EVE4 ] 1.547733 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [EVE4 ] 1.549014 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [EVE4 ] 1.550295 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [EVE4 ] 1.551607 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [EVE4 ] 1.552888 s: SYSTEM: Notify init done !!! [HOST] [EVE4 ] 1.554809 s: SYSTEM: MsgQ init done !!! [HOST] [EVE4 ] 1.555633 s: SYSTEM: IPC init DONE !!! [HOST] [EVE4 ] 1.569236 s: SYSTEM: System Common Init Done !!! [HOST] [EVE4 ] 1.570212 s: SYSTEM: System EVE Init in progress !!! [HOST] [EVE4 ] 1.571707 s: UTILS: DMA: HWI Create for INT8 !!! [HOST] [EVE4 ] 1.572988 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [EVE4 ] 1.574391 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB) [HOST] [EVE4 ] 1.576831 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB) [HOST] [EVE4 ] 1.579058 s: SYSTEM: Initializing Links !!! [HOST] [EVE4 ] 1.674739 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [EVE4 ] 1.675623 s: AlgorithmLink_tidl_initPluginEve ******************* [HOST] [EVE4 ] 1.676538 s: SYSTEM: System EVE Init Done !!! [HOST] [IPU2 ] 1.194778 s: M4 System_First start [HOST] [IPU2 ] 1.257762 s: [HOST] [IPU2 ] EVE1 Image Load Completed [HOST] [IPU2 ] 1.292380 s: [HOST] [IPU2 ] EVE2 Image Load Completed [HOST] [IPU2 ] 1.327212 s: [HOST] [IPU2 ] EVE3 Image Load Completed [HOST] [IPU2 ] 1.362136 s: [HOST] [IPU2 ] EVE4 Image Load Completed [HOST] [IPU2 ] 1.362227 s: [HOST] [IPU2 ] EVE MMU configuration completed [HOST] [IPU2 ] 1.362319 s: [HOST] [IPU2 ] EVE MMU configuration completed [HOST] [IPU2 ] 1.362380 s: [HOST] [IPU2 ] EVE MMU configuration completed [HOST] [IPU2 ] 1.362471 s: [HOST] [IPU2 ] EVE MMU configuration completed [HOST] [IPU2 ] 1.362532 s: SYSTEM: System Common Init in progress !!! [HOST] [IPU2 ] 1.371561 s: UTILS: CIO: Init Done !!! [HOST] [IPU2 ] 1.371652 s: SYSTEM: IPC init in progress !!! [HOST] [IPU2 ] 1.371744 s: SYSTEM: Attaching to [DSP1] ... [HOST] [IPU2 ] 1.374123 s: SYSTEM: Attaching to [DSP1] ... SUCCESS !!! [HOST] [IPU2 ] 1.377173 s: SYSTEM: Attaching to [DSP2] ... SUCCESS !!! [HOST] [IPU2 ] 1.394619 s: SYSTEM: Attaching to [EVE1] ... SUCCESS !!! [HOST] [IPU2 ] 1.414689 s: SYSTEM: Attaching to [EVE2] ... SUCCESS !!! [HOST] [IPU2 ] 1.434667 s: SYSTEM: Attaching to [EVE3] ... SUCCESS !!! [HOST] [IPU2 ] 1.454675 s: SYSTEM: Attaching to [EVE4] ... SUCCESS !!! [HOST] [IPU2 ] 1.454797 s: SYSTEM: Notify register to [DSP1] line 0, event 15... [HOST] [IPU2 ] 1.454919 s: SYSTEM: Notify register to [DSP2] line 0, event 15... [HOST] [IPU2 ] 1.455041 s: SYSTEM: Notify register to [EVE1] line 0, event 15... [HOST] [IPU2 ] 1.455194 s: SYSTEM: Notify register to [EVE2] line 0, event 15... [HOST] [IPU2 ] 1.455285 s: SYSTEM: Notify register to [EVE3] line 0, event 15... [HOST] [IPU2 ] 1.455407 s: SYSTEM: Notify register to [EVE4] line 0, event 15... [HOST] [IPU2 ] 1.455529 s: SYSTEM: Notify init done !!! [HOST] [IPU2 ] 1.457268 s: SYSTEM: MsgQ init done !!! [HOST] [IPU2 ] 1.458183 s: RpmsgInit in progress... [HOST] [IPU2 ] 1.458305 s: SYSTEM: IPC init DONE !!! [HOST] [IPU2 ] 1.463460 s: SYSTEM: System Common Init Done !!! [HOST] [IPU2 ] 1.463551 s: SYSTEM: System Init in progress !!! [HOST] [IPU2 ] 1.463612 s: SYSTEM: BSP Common Init in progress !!! [HOST] [IPU2 ] 1.463673 s: SYSTEM: BSP Common Init Done !!! [HOST] [IPU2 ] 1.463734 s: SYSTEM: BSP Platform Init in progress !!! [HOST] [IPU2 ] 1.463826 s: SYSTEM: BSP Platform Init Done !!! [HOST] [IPU2 ] 1.463887 s: SYSTEM: FVID2 Init in progress !!! [HOST] [IPU2 ] 1.464039 s: SYSTEM: FVID2 Init Done !!! [HOST] [IPU2 ] 1.464100 s: SYSTEM: VPS Init in progress !!! [HOST] [IPU2 ] 1.464192 s: SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000] [HOST] [IPU2 ] 1.467211 s: *** VPDMA Firmware Loading... *** [HOST] [IPU2 ] 1.467333 s: VPDMA Firmware Address = 0xa03dc4c0 [HOST] [IPU2 ] 1.467425 s: VPDMA Load Address = 0x4897d004 [HOST] [IPU2 ] 1.467516 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU2 ] 1.467608 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU2 ] 1.467669 s: *** VPDMA Firmware Load Success *** [HOST] [IPU2 ] 1.468004 s: *** VPDMA Firmware Loading... *** [HOST] [IPU2 ] 1.468065 s: VPDMA Firmware Address = 0xa03dc4c0 [HOST] [IPU2 ] 1.468248 s: VPDMA Load Address = 0x4899d004 [HOST] [IPU2 ] 1.468370 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU2 ] 1.468431 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU2 ] 1.468523 s: *** VPDMA Firmware Load Success *** [HOST] [IPU2 ] 1.468858 s: *** VPDMA Firmware Loading... *** [HOST] [IPU2 ] 1.468919 s: VPDMA Firmware Address = 0xa03dc4c0 [HOST] [IPU2 ] 1.469011 s: VPDMA Load Address = 0x489bd004 [HOST] [IPU2 ] 1.469133 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU2 ] 1.469224 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU2 ] 1.469316 s: *** VPDMA Firmware Load Success *** [HOST] [IPU2 ] 1.469621 s: *** VPDMA Firmware Loading... *** [HOST] [IPU2 ] 1.469712 s: VPDMA Firmware Address = 0xa03dc4c0 [HOST] [IPU2 ] 1.469804 s: VPDMA Load Address = 0x489dd004 [HOST] [IPU2 ] 1.469895 s: VPDMA Firmware Version = 0x4d0001b8 [HOST] [IPU2 ] 1.469956 s: VPDMA List Busy Status = 0x00000000 [HOST] [IPU2 ] 1.470048 s: *** VPDMA Firmware Load Success *** [HOST] [IPU2 ] 1.526810 s: SYSTEM: VPS Init Done !!! [HOST] [IPU2 ] 1.527725 s: UTILS: DMA: HWI Create for INT25 !!! [HOST] [IPU2 ] 1.527969 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024 [HOST] [IPU2 ] 1.528060 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254016 B (248 KB) [HOST] [IPU2 ] 1.528335 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [HOST] [IPU2 ] 1.528487 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 314572800 B (300 MB) [HOST] [IPU2 ] 1.528701 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 861056 B (0 MB) [HOST] [IPU2 ] 1.528853 s: SYSTEM: Initializing Links !!! [HOST] [IPU2 ] 1.810010 s: SYSTEM: Initializing Links ... DONE !!! [HOST] [IPU2 ] 1.893186 s: Chains_tidlOD enter######### [HOST] [IPU2 ] 2.988165 s: Connection established with HLOS, calling rpmsgInit root@(none):~# [HOST] [HOST ] 6.904440 s: NULLSRC LINK SYSTEM_RTOS_OPENFILE [HOST] [HOST ] 6.904532 s: name:./tidl_net_jdetNet_ssd.bin RTOS_FILE_op.mode:2 [HOST] [HOST ] 6.904745 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 6.904745 s: SYSTEM_RTOS_READFILE read:76024 [HOST] [HOST ] 6.922405 s: NULLSRC LINK SYSTEM_RTOS_CLOSEFILE [HOST] [IPU2 ] 6.922100 s: RTOS_FILE_op.mode:2 0-4:HEX:2d 0 0 0 1 [HOST] [HOST ] 7.007991 s: NULLSRC LINK SYSTEM_RTOS_OPENFILE [HOST] [HOST ] 7.010461 s: name:./tidl_param_jdetNet_ssd.bin RTOS_FILE_op.mode:2 [HOST] [HOST ] 7.010736 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.010736 s: SYSTEM_RTOS_READFILE read:3 [HOST] [HOST ] 7.011590 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.011590 s: SYSTEM_RTOS_READFILE read:6 [HOST] [HOST ] 7.011925 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.011925 s: SYSTEM_RTOS_READFILE read:960 [HOST] [HOST ] 7.012505 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.012535 s: SYSTEM_RTOS_READFILE read:40 [HOST] [HOST ] 7.012871 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.012901 s: SYSTEM_RTOS_READFILE read:900 [HOST] [HOST ] 7.013511 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.013542 s: SYSTEM_RTOS_READFILE read:40 [HOST] [HOST ] 7.013908 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.013908 s: SYSTEM_RTOS_READFILE read:4800 [HOST] [IPU2 ] 7.011346 s: RTOS_ReadFile 0-4:HEX:ff ff ff 0 1 [HOST] [IPU2 ] 7.011712 s: RTOS_ReadFile 0-4:HEX:0 80 0 80 0 [HOST] [IPU2 ] 7.012078 s: RTOS_ReadFile 0-4:HEX:7a 93 c3 93 7e [HOST] [IPU2 ] 7.012627 s: RTOS_ReadFile 0-4:HEX:84 9c a4 78 30 [HOST] [IPU2 ] 7.013084 s: RTOS_ReadFile 0-4:HEX:9b 90 90 81 8a [HOST] [IPU2 ] 7.013633 s: RTOS_ReadFile 0-4:HEX:e9 ee 31 10 2f [HOST] [IPU2 ] 7.014457 s: RTOS_ReadFile 0-4:HEX:92 92 92 92 92 [HOST] [HOST ] 7.016195 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.016195 s: SYSTEM_RTOS_READFILE read:80 [HOST] [HOST ] 7.016653 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.016653 s: SYSTEM_RTOS_READFILE read:2400 [HOST] [HOST ] 7.017934 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.017934 s: SYSTEM_RTOS_READFILE read:80 [HOST] [HOST ] 7.018330 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.018330 s: SYSTEM_RTOS_READFILE read:12000 [HOST] [IPU2 ] 7.016348 s: RTOS_ReadFile 0-4:HEX:a4 4d 71 1b e1 [HOST] [IPU2 ] 7.016927 s: RTOS_ReadFile 0-4:HEX:94 94 94 94 94 [HOST] [IPU2 ] 7.018056 s: RTOS_ReadFile 0-4:HEX:58 1f 80 23 68 [HOST] [IPU2 ] 7.020191 s: RTOS_ReadFile 0-4:HEX:9e 8c 8c 8c 8c [HOST] [HOST ] 7.026505 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.026505 s: SYSTEM_RTOS_READFILE read:100 [HOST] [HOST ] 7.026962 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.026962 s: SYSTEM_RTOS_READFILE read:9000 [HOST] [HOST ] 7.031232 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.031263 s: SYSTEM_RTOS_READFILE read:100 [HOST] [HOST ] 7.031690 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.031690 s: SYSTEM_RTOS_READFILE read:48000 [HOST] [IPU2 ] 7.026657 s: RTOS_ReadFile 0-4:HEX:76 1e 37 eb 92 [HOST] [IPU2 ] 7.027969 s: RTOS_ReadFile 0-4:HEX:51 6e 88 33 33 [HOST] [IPU2 ] 7.031385 s: RTOS_ReadFile 0-4:HEX:70 51 f8 2c 99 [HOST] [IPU2 ] 7.039163 s: RTOS_ReadFile 0-4:HEX:46 46 46 46 46 [HOST] [HOST ] 7.063838 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.063838 s: SYSTEM_RTOS_READFILE read:200 [HOST] [HOST ] 7.064295 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.064326 s: SYSTEM_RTOS_READFILE read:24000 [HOST] [IPU2 ] 7.063960 s: RTOS_ReadFile 0-4:HEX:c1 fb a7 fa 1d [HOST] [IPU2 ] 7.067803 s: RTOS_ReadFile 0-4:HEX:3e 54 4c 5a 67 [HOST] [HOST ] 7.080125 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.080156 s: SYSTEM_RTOS_READFILE read:200 [HOST] [HOST ] 7.080644 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.080644 s: SYSTEM_RTOS_READFILE read:120000 [HOST] [IPU2 ] 7.080308 s: RTOS_ReadFile 0-4:HEX:6c 29 d9 28 37 [HOST] [IPU2 ] 7.110900 s: RTOS_ReadFile 0-4:HEX:69 70 70 62 66 [HOST] [HOST ] 7.206826 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.206826 s: SYSTEM_RTOS_READFILE read:400 [HOST] [IPU2 ] 7.206978 s: RTOS_ReadFile 0-4:HEX:d8 f7 c5 36 93 [HOST] [HOST ] 7.207466 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.207466 s: SYSTEM_RTOS_READFILE read:90000 [HOST] [IPU2 ] 7.223022 s: RTOS_ReadFile 0-4:HEX:86 8e 86 86 77 [HOST] [HOST ] 7.271121 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.271121 s: SYSTEM_RTOS_READFILE read:400 [HOST] [HOST ] 7.271670 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.271701 s: SYSTEM_RTOS_READFILE read:10000 [HOST] [IPU2 ] 7.271304 s: RTOS_ReadFile 0-4:HEX:8b 2e 50 5 4c [HOST] [IPU2 ] 7.273256 s: RTOS_ReadFile 0-4:HEX:96 7e 84 8c 7d [HOST] [HOST ] 7.278869 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.278869 s: SYSTEM_RTOS_READFILE read:200 [HOST] [HOST ] 7.279326 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.279357 s: SYSTEM_RTOS_READFILE read:20000 [HOST] [IPU2 ] 7.278991 s: RTOS_ReadFile 0-4:HEX:c9 11 13 16 9d [HOST] [IPU2 ] 7.282468 s: RTOS_ReadFile 0-4:HEX:cc 8a 86 96 73 [HOST] [HOST ] 7.293417 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.293417 s: SYSTEM_RTOS_READFILE read:200 [HOST] [HOST ] 7.293905 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.293905 s: SYSTEM_RTOS_READFILE read:20000 [HOST] [IPU2 ] 7.293570 s: RTOS_ReadFile 0-4:HEX:5d 2b 40 14 58 [HOST] [IPU2 ] 7.297017 s: RTOS_ReadFile 0-4:HEX:a5 a1 8e 95 91 [HOST] [HOST ] 7.307936 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.307966 s: SYSTEM_RTOS_READFILE read:200 [HOST] [IPU2 ] 7.308088 s: RTOS_ReadFile 0-4:HEX:49 ff 61 5 d3 [HOST] [HOST ] 7.308454 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.308454 s: SYSTEM_RTOS_READFILE read:20000 [HOST] [IPU2 ] 7.311596 s: RTOS_ReadFile 0-4:HEX:99 87 76 99 9b [HOST] [HOST ] 7.322546 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.322546 s: SYSTEM_RTOS_READFILE read:200 [HOST] [HOST ] 7.323034 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.323034 s: SYSTEM_RTOS_READFILE read:20000 [HOST] [IPU2 ] 7.322698 s: RTOS_ReadFile 0-4:HEX:ee 4e 1e e 75 [HOST] [IPU2 ] 7.326267 s: RTOS_ReadFile 0-4:HEX:79 88 7d 84 88 [HOST] [HOST ] 7.337186 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.337217 s: SYSTEM_RTOS_READFILE read:200 [HOST] [HOST ] 7.337705 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.337705 s: SYSTEM_RTOS_READFILE read:1000 [HOST] [HOST ] 7.338467 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.338467 s: SYSTEM_RTOS_READFILE read:20 [HOST] [IPU2 ] 7.337369 s: RTOS_ReadFile 0-4:HEX:72 bc d2 e 2d [HOST] [IPU2 ] 7.337888 s: RTOS_ReadFile 0-4:HEX:76 83 75 79 79 [HOST] [IPU2 ] 7.338589 s: RTOS_ReadFile 0-4:HEX:db 7 96 9 b [HOST] [HOST ] 7.338894 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.338894 s: SYSTEM_RTOS_READFILE read:5400 [HOST] [HOST ] 7.341456 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.341456 s: SYSTEM_RTOS_READFILE read:a8 [HOST] [HOST ] 7.341883 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.341883 s: SYSTEM_RTOS_READFILE read:1800 [HOST] [HOST ] 7.342890 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.342890 s: SYSTEM_RTOS_READFILE read:30 [HOST] [HOST ] 7.343256 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.343256 s: SYSTEM_RTOS_READFILE read:7e00 [HOST] [HOST ] 7.347068 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.347068 s: SYSTEM_RTOS_READFILE read:fc [HOST] [HOST ] 7.347526 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.347556 s: SYSTEM_RTOS_READFILE read:1800 [HOST] [HOST ] 7.348502 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.348502 s: SYSTEM_RTOS_READFILE read:30 [HOST] [HOST ] 7.349020 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.349051 s: SYSTEM_RTOS_READFILE read:7e00 [HOST] [HOST ] 7.352742 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.352772 s: SYSTEM_RTOS_READFILE read:fc [HOST] [HOST ] 7.353199 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.353199 s: SYSTEM_RTOS_READFILE read:1800 [HOST] [HOST ] 7.354206 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.354206 s: SYSTEM_RTOS_READFILE read:30 [HOST] [HOST ] 7.354633 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.354633 s: SYSTEM_RTOS_READFILE read:7e00 [HOST] [HOST ] 7.358293 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.358293 s: SYSTEM_RTOS_READFILE read:fc [HOST] [HOST ] 7.358720 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.358720 s: SYSTEM_RTOS_READFILE read:1000 [HOST] [HOST ] 7.359482 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.359513 s: SYSTEM_RTOS_READFILE read:20 [HOST] [HOST ] 7.359848 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.359879 s: SYSTEM_RTOS_READFILE read:5400 [HOST] [HOST ] 7.362471 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.362502 s: SYSTEM_RTOS_READFILE read:a8 [HOST] [HOST ] 7.362898 s: NULLSRC LINK SYSTEM_RTOS_READFILE [HOST] [HOST ] 7.362929 s: SYSTEM_RTOS_READFILE read:1c4 [HOST] [HOST ] 7.363295 s: NULLSRC LINK SYSTEM_RTOS_CLOSEFILE [HOST] [DSP1 ] 7.586835 s: IPC_IN_0 : Create in progress !!! [HOST] [DSP1 ] 7.587415 s: IPC_IN_0 : Create Done !!! [HOST] [DSP1 ] 7.587598 s: ALGORITHM: Create in progress (algId = 40) !!! [HOST] [DSP1 ] 7.603367 s: UTILS: DMA: Allocated CH (TCC) = 56 (56) [HOST] [DSP1 ] 7.603397 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 56 (0x43305200) [HOST] [DSP1 ] 7.603428 s: ALGORITHM: Create Done (algId = 40) !!! [HOST] [DSP1 ] 7.603641 s: IPC_OUT_3 : Create in progress !!! [HOST] [DSP1 ] 7.603733 s: IPC_OUT_3 : Create Done !!! [HOST] [EVE4 ] 7.604068 s: IPC_IN_0 : Create in progress !!! [HOST] [EVE4 ] 7.604922 s: IPC_IN_0 : Create Done !!! [HOST] [EVE4 ] 7.605654 s: ALGORITHM: Create in progress (algId = 14) !!! [HOST] [IPU2 ] 7.339443 s: RTOS_ReadFile 0-4:HEX:8d 8d 94 91 88 [HOST] [IPU2 ] 7.341578 s: RTOS_ReadFile 0-4:HEX:54 78 4f f5 a2 [HOST] [IPU2 ] 7.342127 s: RTOS_ReadFile 0-4:HEX:81 69 82 76 45 [HOST] [IPU2 ] 7.342981 s: RTOS_ReadFile 0-4:HEX:e4 b dd 15 81 [HOST] [IPU2 ] 7.344171 s: RTOS_ReadFile 0-4:HEX:a6 a3 b0 ad a3 [HOST] [IPU2 ] 7.347190 s: RTOS_ReadFile 0-4:HEX:59 72 37 f5 a0 [HOST] [IPU2 ] 7.347739 s: RTOS_ReadFile 0-4:HEX:74 80 bb 78 7e [HOST] [IPU2 ] 7.348593 s: RTOS_ReadFile 0-4:HEX:84 4 61 11 10 [HOST] [IPU2 ] 7.349844 s: RTOS_ReadFile 0-4:HEX:aa 90 a1 a5 b1 [HOST] [IPU2 ] 7.352894 s: RTOS_ReadFile 0-4:HEX:9c 69 b3 f1 75 [HOST] [IPU2 ] 7.353474 s: RTOS_ReadFile 0-4:HEX:88 87 8d 83 88 [HOST] [IPU2 ] 7.354358 s: RTOS_ReadFile 0-4:HEX:46 f8 6c fd 22 [HOST] [IPU2 ] 7.355426 s: RTOS_ReadFile 0-4:HEX:a4 84 bc a9 bc [HOST] [IPU2 ] 7.358415 s: RTOS_ReadFile 0-4:HEX:dd 5d bf ee b3 [HOST] [IPU2 ] 7.358903 s: RTOS_ReadFile 0-4:HEX:7e 8b 89 83 85 [HOST] [IPU2 ] 7.359604 s: RTOS_ReadFile 0-4:HEX:db fc 9d 7 72 [HOST] [IPU2 ] 7.360458 s: RTOS_ReadFile 0-4:HEX:a6 a5 92 94 ac [HOST] [IPU2 ] 7.362624 s: RTOS_ReadFile 0-4:HEX:22 60 76 f2 13 [HOST] [IPU2 ] 7.363020 s: RTOS_ReadFile 0-4:HEX:0 0 a0 40 0 [HOST] [IPU2 ] 7.363630 s: ChainsCommon_MultiCam_SetCapturePrms enter [HOST] [IPU2 ] 7.367717 s: ChainsCommon_StartDisplayCtrl ************* [HOST] [IPU2 ] 7.367870 s: CAPTURE: Create in progress !!! [HOST] [IPU2 ] 7.368083 s: CAPTURE: VIP1 Slice1 PortA capture mode is [ 8-bit] !!! [HOST] [IPU2 ] 7.494967 s: CAPTURE: Create Done !!! [HOST] [IPU2 ] 7.495150 s: VPE: Create in progress !!! [HOST] [IPU2 ] 7.584853 s: VPE: Loading Down-scaling Co-effs [HOST] [IPU2 ] 7.585097 s: VPE: Co-effs Loading ... DONE !!! [HOST] [IPU2 ] 7.585310 s: VPE: Create Done !!! [HOST] [IPU2 ] 7.586225 s: IPC_OUT_0 : Create in progress !!! [HOST] [IPU2 ] 7.586591 s: IPC_OUT_0 : Create Done !!! [HOST] [DSP1 ] 9.604404 s: IPC_IN_3 : Create in progress !!! [HOST] [DSP1 ] 9.604892 s: IPC_IN_3 : Create Done !!! [HOST] [DSP1 ] 9.605075 s: IPC_OUT_2 : Create in progress !!! [HOST] [DSP1 ] 9.605166 s: IPC_OUT_2 : Create Done !!! [HOST] [EVE3 ] 9.605502 s: IPC_IN_0 : Create in progress !!! [HOST] [EVE3 ] 9.606508 s: IPC_IN_0 : Create Done !!! [HOST] [EVE3 ] 9.607088 s: ALGORITHM: Create in progress (algId = 14) !!! [HOST] [EVE4 ] 9.602879 s: ALGORITHM: Create Done (algId = 14) !!! [HOST] [EVE4 ] 9.603580 s: IPC_OUT_0 : Create in progress !!! [HOST] [EVE4 ] 9.603977 s: IPC_OUT_0 : Create Done !!! [HOST] [DSP1 ] 11.604190 s: IPC_IN_2 : Create in progress !!! [HOST] [DSP1 ] 11.604678 s: IPC_IN_2 : Create Done !!! [HOST] [DSP1 ] 11.604861 s: IPC_OUT_1 : Create in progress !!! [HOST] [DSP1 ] 11.604953 s: IPC_OUT_1 : Create Done !!! [HOST] [EVE2 ] 11.605288 s: IPC_IN_0 : Create in progress !!! [HOST] [EVE3 ] 11.602665 s: ALGORITHM: Create Done (algId = 14) !!! [HOST] [EVE3 ] 11.603275 s: IPC_OUT_0 : Create in progress !!! [HOST] [EVE3 ] 11.603763 s: IPC_OUT_0 : Create Done !!! [HOST] [EVE2 ] 11.606325 s: IPC_IN_0 : Create Done !!! [HOST] [EVE2 ] 11.606905 s: ALGORITHM: Create in progress (algId = 14) !!! [HOST] [DSP1 ] 13.619288 s: IPC_IN_1 : Create in progress !!! [HOST] [DSP1 ] 13.619776 s: IPC_IN_1 : Create Done !!! [HOST] [DSP1 ] 13.619959 s: IPC_OUT_0 : Create in progress !!! [HOST] [DSP1 ] 13.620051 s: IPC_OUT_0 : Create Done !!! [HOST] [EVE1 ] 13.620356 s: IPC_IN_0 : Create in progress !!! [HOST] [EVE2 ] 13.617824 s: ALGORITHM: Create Done (algId = 14) !!! [HOST] [EVE2 ] 13.618465 s: IPC_OUT_0 : Create in progress !!! [HOST] [EVE2 ] 13.618861 s: IPC_OUT_0 : Create Done !!! [HOST] [EVE1 ] 13.621423 s: IPC_IN_0 : Create Done !!! [HOST] [EVE1 ] 13.622003 s: ALGORITHM: Create in progress (algId = 14) !!! [HOST] [DSP1 ] 15.629506 s: ALGORITHM: Create in progress (algId = 36) !!! [HOST] [EVE1 ] 15.627676 s: ALGORITHM: Create Done (algId = 14) !!! [HOST] [EVE1 ] 15.628286 s: IPC_OUT_0 : Create in progress !!! [HOST] [EVE1 ] 15.628713 s: IPC_OUT_0 : Create Done !!! [HOST] [DSP1 ] 15.643811 s: ALGORITHM: Create Done (algId = 36) !!! [HOST] [DSP1 ] 15.646617 s: IPC_IN_4 : Create in progress !!! [HOST] [DSP1 ] 15.647044 s: IPC_IN_4 : Create Done !!! [HOST] [DSP1 ] 15.647257 s: ALGORITHM: Create in progress (algId = 39) !!! [HOST] [IPU2 ] 15.644085 s: IPC_IN_0 : Create in progress !!! [HOST] [IPU2 ] 15.645061 s: IPC_IN_0 : Create Done !!! [HOST] [IPU2 ] 15.646098 s: IPC_OUT_1 : Create in progress !!! [HOST] [IPU2 ] 15.646373 s: IPC_OUT_1 : Create Done !!! [HOST] [DSP1 ] 15.649637 s: ALGORITHM: Create Done (algId = 39) !!! [HOST] [DSP1 ] 15.649820 s: IPC_OUT_4 : Create in progress !!! [HOST] [DSP1 ] 15.649911 s: IPC_OUT_4 : Create Done !!! [HOST] [IPU2 ] 15.650033 s: IPC_IN_1 : Create in progress !!! [HOST] [IPU2 ] 15.651009 s: IPC_IN_1 : Create Done !!! [HOST] [IPU2 ] 15.651223 s: ALGORITHM: Create in progress (algId = 1) !!! [HOST] [IPU2 ] 15.652199 s: UTILS: DMA: Allocated CH (TCC) = 32 (32) [HOST] [IPU2 ] 15.652321 s: UTILS: DMA: 0 of 1: Allocated PaRAM = 32 (0x63304800) [HOST] [DSP1 ] 15.669035 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [DSP1 ] 15.669096 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 65312 B (63 KB) [HOST] [DSP1 ] 15.669127 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 484256 B (472 KB) [HOST] [DSP2 ] 15.669340 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [DSP2 ] 15.669401 s: SYSTEM: Heap = LOCAL_L2 @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB) [HOST] [DSP2 ] 15.669432 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516016 B (503 KB) [HOST] [EVE1 ] 15.669798 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [EVE1 ] 15.670103 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB) [HOST] [EVE1 ] 15.670621 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 237464 B (231 KB) [HOST] [EVE2 ] 15.671475 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [EVE2 ] 15.671780 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB) [HOST] [EVE2 ] 15.672299 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 237464 B (231 KB) [HOST] [EVE3 ] 15.673153 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [EVE3 ] 15.673519 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB) [HOST] [EVE3 ] 15.674037 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 237464 B (231 KB) [HOST] [EVE4 ] 15.674922 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [EVE4 ] 15.675196 s: SYSTEM: Heap = LOCAL_L2 @ 0x40020000, Total size = 22528 B (22 KB), Free size = 1280 B (1 KB) [HOST] [EVE4 ] 15.675715 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 237464 B (231 KB) [HOST] [IPU2 ] 15.668029 s: ALGORITHM: Create Done (algId = 1) !!! [HOST] [IPU2 ] 15.668242 s: DISPLAY: Create in progress !!! [HOST] [IPU2 ] 15.668822 s: DISPLAY: Create Done !!! [HOST] [IPU2 ] 15.676386 s: SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1023 [HOST] [IPU2 ] 15.676538 s: SYSTEM: Heap = LOCAL_DDR @ 0x00000000, Total size = 262144 B (256 KB), Free size = 244768 B (239 KB) [HOST] [IPU2 ] 15.676691 s: SYSTEM: Heap = SR_OCMC @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB) [HOST] [IPU2 ] 15.676843 s: SYSTEM: Heap = SR_DDR_CACHED @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 134788096 B (128 MB) [HOST] [IPU2 ] 15.677026 s: SYSTEM: Heap = SR_DDR_NON_CACHED @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 851840 B (0 MB) [HOST] [IPU2 ] 15.677240 s: chains_tidlOD_Start********************* [HOST] [IPU2 ] 15.677331 s: DISPLAY: Start in progress !!! [HOST] [IPU2 ] 15.677392 s: DISPLAY: Start Done !!! [HOST] [IPU2 ] 15.684194 s: CAPTURE: Start in progress !!! [HOST] [IPU2 ] 15.685811 s: CAPTURE: Start Done !!! [HOST] [IPU2 ] 15.979747 s: DisplayLink_drvProcessData [HOST] [IPU2 ] 15.979838 s: bufList.numBuf:1 [HOST] [IPU2 ] 15.979960 s: DisplayLink_drvProcessData 333333333333333333 [HOST] [IPU2 ] 15.980143 s: freeBufList.numBuf:0 [HOST] [IPU2 ] 15.980204 s: DisplayLink_drvProcessData end [HOST] [IPU2 ] 20.687671 s: test OD ****************** [HOST] [IPU2 ] 20.687763 s: [HOST] [IPU2 ] [HOST] [IPU2 ] ====================
