AM6548: V4L2 camera driver
Part Number: AM6548
I'm working on a V4l2 driver for a MIPI camera to work on the AM65X platform using kernel 4.19.38 and I have some questions:
1. Do you have like a developer's guide in order to create V4l2 drivers for this platform?
2. Do you have a V4l2 driver that it's already working and tested on the AM65X? Can you share the reference?
3. Do we need to developed the driver using The Camera Adaptation Layer is designed (CAL)?
4. Is CAL support Media Controller?
5. Is there any other different software to control the capture subsystem than CAL (using Media Controller)?
-Enrique
    You query has been assigned to a TI engineer. Please note that response may be delayed due to Christmas and New Year holidays.
    Please refer to this document
    Yes, the v4l2 CAL driver is already supported for AM654x device. Above document hasn't been updated to add AM654x device to the list but the content is applicable for the driver on this device. Regarding the sensor driver,  you can refer to ov5640 sensor driver to work with CAL.
    Please refer to the document
    It doesn't support media controller
    Thanks for your answers.
    It seems that the documentation is not very updated.
    Reviewing the ov5640 driver I found media controller definitions so I'm confused. If CAL do not support media controller, why the ov5640 driver has media controller definitions?
    Do you have a this sensor (ov5640) working on the AM654x?
    -Enrique
  • Hi Enrique,
    The CAL driver documentation is updated now.
    ov5640 driver is from open source kernel and might be getting used with other CSI-2 drivers that support media controller. The CAL driver in AM654x device doesn't support media controller and hence having the support on the sensor driver won't make difference.
    Manisha
