Part Number: AM5748
Other Parts Discussed in Thread: AM5728, , PROCESSOR-SDK-AM57X
Hi team,
Our customer developed their current system with AM5728BABCXA. For next system, customer is considering to use AM5748ABZXA because customer wants to use “secure boot”. Regarding Hardware-side, customer is able to check the difference between AM5728 & AM5748 by referring “Compatibility Guide” (http://www.ti.com/lit/an/sprabx8e/sprabx8e.pdf)
However, regarding software-side, it is tough to understand what kind of difference there are, except secure-boot. Can I have your Expert’s advice/comments on this, please?
Regarding AM5748 device, as far as I can check, TI is releasing “PROCESSOR-SDK-AM57X”. I mean, it is same for AM5728. If our customer will use AM5748 for next project, could you consider that customer will be able to re-use their current AM5728’s software-environment?
For software-code which relates to CPU, would you expect there are not any change ? If customer needs to take care/ to modify some points, Could you elaborate them, please ?
It is really appreciate if you will be able to share Expert’s comments on this
Miyazaki
