AM5718: AM5718 IDK PMIC IC Issue - Reg
Part Number: AM5718
Dear Team,
We have been using AM5718 IDK for our development activities. During the development, while connecting the
5V Adapter, 3.3V output Lane (VSMPS9) from the PMIC IC TPS6590377 got shorted to Ground. We have replaced the IC
with TPS6590379 using BGA Rework Station. .After BGA is replaced, we are getting 6 Ohm Impedance shown across
VMAIN and GND. 3.3V Short has gone. Xray of the IC does not any short
What could be the cause of this issue and if any changes to be done in the circuit if we need to use TPS6590379 in place of
TPS6590377 . Highly appreciate your feedback on the same.
With Best Regards,
Vikram.
  • Vikram,
    It's tough for me to speculate.  If the supply has been shorted any number of additional components may have been damaged.
    Kyle
  • Dear Kyle,
    Thanks for the reply.
    When we removed the PMIC from the board, 3.3V short also has gone. Also, there is no short in any other power supply too.
    But when we replaced the IC with new PMIC, impedance between VMAIN (5V) and GND is showing around 6 Ohm.  Also, we have
    checked after desoldering each and individual component associated with VMAIN line.
    It is very difficult for us to understand as well
    Please note that, we have used TPS6590379 IC. Please advise.
    With Best Regards,
    Vikram.
  • Vikram,
    TPS6590377 and TPS6590379 are pin-to-pin compatible so there should be no issue using the updated part number. If you have an additional working board to spare, you can try to swap a TPS6590377 and a new TPS6590379 device and verify the correct power up behavior.
    With the shorted board, there could damage on the external components around the PMIC as well as the original TPS6590377 PMIC. DId you also check for any damage on the pre-regulator?
    Nastasha
