AM6548: the address for loading the dtb from u-boot
Part Number: AM6548
Hi
It seems that in the TI sdk the dtb file is loaded to the fdtcontroladd. This value is set in uboot. Like to understand how this is calculated in u-boot? I assume it takes some values from the u-boot device tree and calculate teh address where to load the linux device tree.
  • Hi got more info for you gus
    So it looks like in the ./lib/lmb.c file if finds the reserved area but I assume it should look at the dts uboot file. But I can’t match how the calculation for the reserved area is done. I found out that the dtb is not loaded into the fdtcontroladdr but in a different region. I got the below dump from the lmb.c using the #define DEBUG and using lmb_debug function call. My question is how does the reserved areas gets calculated if you anybody can help me with that it would be great.  Below is the dump from when the kernel starts
    lmb_dump_all:
       memory.cnt             = 0x1
       memory.size           = 0x0
       memory.reg[0x0].base   = 0x80000000
                       .size   = 0x80000000
       reserved.cnt           = 0x3
       reserved.size         = 0x0
       reserved.reg[0x0].base = 0x80080000
                         .size = 0xdf0000
       reserved.reg[0x1].base = 0xfddc2000
                         .size = 0x115000
       reserved.reg[0x2].base = 0xfded7a40
                         .size = 0x21285c0
    bootm_mapsize   =80000000   bootm_low     = 80000000
    ## device tree at 0000000082000000 ... 0000000082111fff (len=1134592 [0x115000])
       Loading Device Tree to 00000000fddc2000, end 00000000fded6fff ... OK
  • Hi Mohsen,
    https://gitlab.denx.de/u-boot/u-boot/-/blob/master/README
    fdtcontroladdr- if set this is the address of the control flattened device tree used by U-Boot when CONFIG_OF_CONTROL is defined.
     fdtcontroladdr and that is for u-boot dtb and fdtaddr is used for Linux DTB loading. I believe now your question is more on reserved
    memory regions? Can you just double confirm the exact question you want the answer for.
    Is it how reserved memory regions are allocated?
    - Keerthy
  • Hi Keerthy
    I don't think that is true as i send you the output from u-boot. You can see that the fdt is loaded in section reserved.reg[0x1].base = 0xfddc2000 that is not the fdtcontroladdr. below you can see teh address for the
    fdtaddr=0x82000000
    fdtcontroladdr=fded91f8
    that is why i am asking for the location of the fdt and why the reserved memory is important.
  • Hi Kreeth
    below is what i have in the .config file
    # Device Tree Control
    CONFIG_OF_CONTROL=y
    so what you are talking about is set but still it does not use it. I guess there must be something else that i am missing here. Please take  a look at what i have above, it shows where the fdt is loaded.
  • Hi Mohsen,
    Since we had a call on this topic, do you want to summarize and close this thread?
    Karthik
  • It seems that there is a bug in u-boot for reading the reserved-memory from the dtb file. This is being reviewed and hopefully a patch will be provided. In the mean time we have a work around for this. What needs to happen is to stop from relocating the linux dtb file in u-boot. That can happen by setting the below env in u-boot
    setenv fdt_high 0xffffffffffffffff
    saveenv
    This will keep the dtb in location 0x82000000
    regards
    Mohsen
