AM3352: Uboot DM video support for splash screen
Part Number: AM3352
Hi
In the past I have used the instructions from: http://software-dl.ti.com/processor-sdk-linux/esd/docs/latest/linux/Foundational_Components_U-Boot.html#u-boot-splash-screen
to incorporate a splash screen in to my u-boot build.
I am now trying to port to a more up to date yocto and find that it's expecting a splash screen to be done using CONFIG_DM_VIDEO
specifically it complains about CONFIG_SYS_EXTRA_OPTIONS="SPLASH",  CONFIG_LCD_NOSTDOUT
are there any updated examples that describe what's necessary to get the am335x lcd driver working in u-boot via dts?
- Richard
  • Hi Richard,
    Unfortunately this piece of documentation is out of date. I'll make a note to have it removed. AFAIK we no longer support this.
    I'm not aware of anybody in the recent past that has implemented this. So I'm not sure as to what the effort would be to resurrect this feature.
    I've seen a recommendation here to instead use Falcon boot, and let the Kernel handle the boot image display. Perhaps that's something worth looking into as an alternative?
    https://lists.denx.de/pipermail/u-boot/2014-July/184871.html
    What specific errors do you get? We can try to bring this up remotely but it might be a tedious effort (we don't have the resources at the moment to provide a readily-ported example in the context of our E2E support).
    Regards, Andreas
  • Thanks Andreas
    That's not going to work unfortunately; the reason for using a splash screen is to get something displayed in much less time than it takes to load the kernel
    I've decided against trying to squeeze the old configs in (which were causing the errors) and am looking at how the DM side of things should work
    I've added the following via config
    CONFIG_CMD_BMP=y
    CONFIG_DM_VIDEO=y
    CONFIG_VIDEO_BPP32=y
    CONFIG_BOARD_LATE_INIT=y
    and inserted
    #define CONFIG_VIDEO_BMP_GZIP
    #define CONFIG_SYS_VIDEO_LOGO_MAX_SIZE (1366*767*4)
    in my /configs/mybaord.h
    At present I can control my backlight via PMIC and I am configuring the screen via GPIO bashed 1 wire spi via the board_late_init function
    I can read a gzipped bmp from SPI NOR and it's parsed happily by the BMP commands
    => bmp info ${loadaddr}
    Image size    : 240 x 360
    Bits per pixel: 24
    Compression   : 0
    What looks to remain to be done is getting the LCD driver and frambuffer (or framebuffer proxy)  in to u-booot
    => dm tree
     Class     Index  Probed  Driver                Name
     root          0  [ + ]   root_driver           root_driver
     rsa_mod_ex    0  [   ]   mod_exp_sw            |-- mod_exp_sw
     simple_bus    0  [ + ]   generic_simple_bus    `-- ocp
     simple_bus    1  [   ]   generic_simple_bus        |-- l4_wkup@44c00000
     simple_bus    2  [   ]   generic_simple_bus        |   |-- prcm@200000
     simple_bus    3  [   ]   generic_simple_bus        |   `-- scm@210000
     simple_bus    4  [   ]   generic_simple_bus        |       `-- scm_conf@0
     gpio          0  [ + ]   gpio_omap                 |-- gpio@44e07000
     gpio          1  [ + ]   gpio_omap                 |-- gpio@4804c000
     gpio          2  [ + ]   gpio_omap                 |-- gpio@481ac000
     gpio          3  [ + ]   gpio_omap                 |-- gpio@481ae000
     serial        0  [ + ]   omap_serial               |-- serial@44e09000
     i2c           0  [ + ]   i2c_omap                  |-- i2c@44e0b000
     i2c_generi    0  [ + ]   i2c_generic_chip_drv      |   `-- generic_24
     mmc           0  [ + ]   omap_hsmmc                |-- mmc@48060000
     blk           0  [ + ]   mmc_blk                   |   `-- mmc@48060000.blk
     mmc           1  [ + ]   omap_hsmmc                |-- mmc@481d8000
     blk           1  [   ]   mmc_blk                   |   `-- mmc@481d8000.blk
     watchdog      0  [ + ]   omap3_wdt                 |-- wdt@44e35000
     timer         0  [ + ]   omap_timer                |-- timer@48040000
     timer         1  [   ]   omap_timer                |-- timer@48042000
     timer         2  [   ]   omap_timer                |-- timer@48044000
     timer         3  [   ]   omap_timer                |-- timer@48046000
     timer         4  [   ]   omap_timer                |-- timer@48048000
     timer         5  [   ]   omap_timer                |-- timer@4804a000
     spi           0  [ + ]   omap3_spi                 |-- spi@48030000
     spi_flash     0  [   ]   spi_flash_std             |   `-- spi-flash@0
     misc          0  [ + ]   ti-musb-wrapper           `-- usb@47400000
     usb           0  [ + ]   ti-musb-peripheral            |-- usb@47401000
     eth           0  [ + ]   usb_ether                     |   `-- usb_ether
     usb           0  [   ]   ti-musb-host                  `-- usb@47401800
    If anyone has any clues to how this might be done I would be very grateful
    All the best,
    - Richard
  • Hi Richard,
    I had another look, looks like both the current official TI U-Boot (based on v2019.01) as well as the ucpoming U-Boot that will be used for our next SDKs (based on v2010.01) do not have support for DTS/DM-based framebuffer access on AM335x. However the current upstream U-Boot does have it, as evident by a new driver called drivers/video/am335x-fb.c that was added (and can be activated through CONFIG_AM335X_LCD) as well as several platforms using it (so there is something to model after in terms of the associated defconfigs, and board-specific init-code). It may require some additional grepping and looking through the source tree but that should be a usable starting point.
    a0797059@jiji:~/git/u-boot (HEAD detached at upstream/master)
    $ git grep ti,tilcdc,panel
    arch/arm/dts/am335x-brppt1-mmc.dts:             compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-brppt1-nand.dts:            compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-brppt1-spi.dts:             compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-brsmarc1.dts:               compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-brxre1.dts:         compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-evm.dts:            compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-evmsk.dts:          compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-guardian.dts:               compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-pdu001.dts:         compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-pxm50.dts:                  compatible = "ti,tilcdc,panel";
    arch/arm/dts/am335x-rut.dts:            compatible = "ti,tilcdc,panel";
    arch/arm/dts/da850-evm.dts:             compatible = "ti,tilcdc,panel";
    arch/arm/dts/da850-evm.dts:      * To enable VPIF, disable the ti,tilcdc,panel then
    doc/device-tree-bindings/video/tilcdc/panel.txt: - compatible: value should be "ti,tilcdc,panel".
    doc/device-tree-bindings/video/tilcdc/panel.txt:                compatible = "ti,tilcdc,panel";
    drivers/video/am335x-fb.c:      { .compatible = "ti,tilcdc,panel" },
    $ grep am335x-fb drivers/video/Makefile
    obj-$(CONFIG_AM335X_LCD) += am335x-fb.o
    What I'd probably try in your place is to re-base (via git rebase) your current U-Boot port work on top of the latest upstream U-Boot. Support for AM335x is pretty mature in upstream, so in almost all cases you should be able to use this instead of the SDK provided. This might be easier than trying to backport DM/DTS-based FB support to a v2019.01 based U-Boot such as the one in our current AM335x Linux SDK v6.3.
    Regards, Andreas
  • Hi Andreas
    that driver has been around for a while (it's the one i used in my previous u-boot)
    the code I'm looking at just now is based on v2020.01 and if I compile in CONFIG_AM335X_LCD it starts looking for structures/definitions that have been elided in other platforms by CONFIG_DM_VIDEO (e.g in lcd.h)
    so it looks as though the support is in limbo at the moment
    I'll have a look through the notes on transitioning to the DM_VIDEO model once I've sorted out my device tree porting to the new kernel
    - I get the impression from the other drivers that it should be quite simple (given that's the idea of the DTS model)
    All the best
    - Richard
  • Hi Richard,
    Yes, but there have been changes in upstream since 2020.01, for example there's a commit that adds support for DM/DTS. Sounds like something you'd want to use.
    $ git log --oneline v2020.01... drivers/video/am335x-fb.c
    c05ed00afb common: Drop linux/delay.h from common header
    f7ae49fc4f common: Drop log.h from common header
    295ab882d9 video: omap: change include order
    0aff8e2615 video: omap: fix pixel-per-line bitfield setting
    96b109ba74 video: omap: add support for DM/DTS
    a9df3c50ed video: omap: create two routines to set the pixel clock rate
    9d7f53c1e5 video: omap: add loop exit conditions to the dpll setup
    9aead9ae09 video: omap: fix debug message
    41f76a01f3 video: omap: rename LCD controller registers
    017295f31d video: omap: fix bitfields order
    3af43750df video: omap: fix coding style on use of spaces
    e3f82b80cd video: omap: add missing bitfield masks
    a2f4706479 video: omap: use BIT() and GENMASK() macros
    Let us know once you get there and need anything else on that.
    Regards, Andreas
  • Thanks Andreas
    I had fetched and pulled but not looked in master
    - I can see the changes you refer to now and I'll use them as a reference when I next look at this
    Thanks for the help
    - Richard
