TDA2HG: How many eves available in TDA2HG?
Part Number: TDA2HG
Hi
One question puzzles me that how many eves are available in TDA2hg series?
I found 4 eves availabe in TDA2xx and only 2eves availabe in TDA2hg from VisionSDK_data_sheet.
However,4 eves defined when creating own usecase.when i check cpu load information,every eve's utilization over 75%.
So,whether there is overclocking if there are only 2 eves?
    Only 2 EVE is available in the TDA2HG.
    Can you share the custom use-case chain?
    Gaviraju
  • Hi
    here is the chain:
    Defination:
    /* TIDL on EVE1 */
    pUcObj->Alg_tidl_Eve1Prm.cacheInvInBuf = 0;
    pUcObj->Alg_tidl_Eve1Prm.cacheWbOutBuf = 0;
    pUcObj->Alg_tidl_Eve1Prm.pAlgCreateParams = pObj->pAlgCreateParams;
    pUcObj->Alg_tidl_Eve1Prm.curCoreId = TIDL_COREID_EVE1;
    pUcObj->Alg_tidl_Eve1Prm.currLayersGroupId = TIDL_LAYER_GROUPID_EVE1;
    pUcObj->Alg_tidl_Eve1Prm.ocmcAddr = OCMC_3_BASE_ADDRESS;
    #endif
    /* TIDL on EVE2 */
    pUcObj->Alg_tidl_Eve2Prm.cacheInvInBuf = 0;
    pUcObj->Alg_tidl_Eve2Prm.cacheWbOutBuf = 0;
    pUcObj->Alg_tidl_Eve2Prm.pAlgCreateParams = pObj->pAlgCreateParams;
    pUcObj->Alg_tidl_Eve2Prm.curCoreId = TIDL_COREID_EVE2;
    pUcObj->Alg_tidl_Eve2Prm.currLayersGroupId = TIDL_LAYER_GROUPID_EVE2;
    pUcObj->Alg_tidl_Eve2Prm.ocmcAddr = OCMC_3_BASE_ADDRESS;//OCMC_3_BASE_ADDRESS + (OCMC_3_SIZE/2);
    pUcObj->Alg_tidl_Eve2Prm.ocmcAddr = OCMC_3_BASE_ADDRESS + (OCMC_3_SIZE/2);
    /* TIDL on EVE3 */
    pUcObj->Alg_tidl_Eve3Prm.cacheInvInBuf = 0;
    pUcObj->Alg_tidl_Eve3Prm.cacheWbOutBuf = 0;
    pUcObj->Alg_tidl_Eve3Prm.pAlgCreateParams = pObj->pAlgCreateParams;
    pUcObj->Alg_tidl_Eve3Prm.curCoreId = TIDL_COREID_EVE3;
    pUcObj->Alg_tidl_Eve3Prm.currLayersGroupId = TIDL_LAYER_GROUPID_EVE3;
    pUcObj->Alg_tidl_Eve3Prm.ocmcAddr = OCMC_1_BASE_ADDRESS;
    /* TIDL on EVE4 */
    pUcObj->Alg_tidl_Eve4Prm.cacheInvInBuf = 0;
    pUcObj->Alg_tidl_Eve4Prm.cacheWbOutBuf = 0;
    pUcObj->Alg_tidl_Eve4Prm.pAlgCreateParams = pObj->pAlgCreateParams;
    pUcObj->Alg_tidl_Eve4Prm.curCoreId = TIDL_COREID_EVE4;
    pUcObj->Alg_tidl_Eve4Prm.currLayersGroupId = TIDL_LAYER_GROUPID_EVE4;
    pUcObj->Alg_tidl_Eve4Prm.ocmcAddr = OCMC_2_BASE_ADDRESS;
    This is expected output & when we run default TIDL_OD use-case in TDA2XX platform having 4 EVE core, we can see the 90% of CPU Load with below configuration
    inputWidth=768
    inputHeight=320
    inputFile=inData_OD
    inputHDRFile=inHeader_OD
    netFileName=tidl_net_jdetNet_ssd.bin
    paramFileName=tidl_param_jdetNet_ssd.bin
    fps=30
    threshold=0.3
    Gaviraju
