TDA4VM: openvx convert vx_tensor to vx_image
Part Number: TDA4VM
Hi
In the following demo http://software-dl.ti.com/jacinto7/esd/processor-sdk-rtos-jacinto7/latest/exports/docs/vision_apps/docs/user_guide/group_apps_dl_demos_app_tidl_seg.html
I want to just display the output of the segmentation model without combining it with the input image.
to do that I need to convert the output of the model which is of type vx_tensor to vx_image. I checked the documentation of openvx and found a function called vxCreateImageObjectArrayFromTensor.
Documentation link: https://www.khronos.org/registry/OpenVX/specs/1.2/html/d7/d0f/group__group__object__tensor.html#ga64427e7cf4935ceb204a18b8675dbbe3
however, I couldn't find it in the tiovx library. So how can I convert from vx_tensor to vx_image?
Regards.
    On TDA4x we support OpenVx 1.1 spec and not OpenVx 1.2 so you will not find vxCreateImageObjectArrayFromTensor api.
    Also the output of TIDL in app_tidl_seg will be an 8 bit plane where each value will be class-id's. So if you have 10 classes it will be from 0 to 9.
    You will not be able to "display" this on the screen, unless you scale it appropriately.
    If your intention is to just access the TIDL output then you have 2 options,
    1. Make the TIDL node output tensor as a graph parameter and enqueue/dequeue similar to scaler node's input imgae.
    2. You can attach a companion fileio node to TIDL node which accepts the output tensor as an argument and execute the node on A72. One example of this is done in app_multi_cam where we have tapped intermediate outputs of each node in the pipeline. You can take a look at vision_apps/kernel/fileio module and look at writing tensor data formats to media.
    Shyam
