AM5728: Shared Region Doesn't Reliably Pass Data From DSP to ARM
Part Number: AM5728
Starting with the Big Data IPC example, I am trying to create a system where the DSP loads data in a circular buffer and the ARM retrieves the data.  I am trying to do this without passing messages back and forth for every transaction.
The 64K shared region is comprised of (16) 4K buffers, each of which contains 1024 ints (32 records/buffer * 32 int-values/record).
The simplified data flow is:
ARM        DSP
Configure CMEM
Configure SharedRegion
Send Message w/ SharedRegion pointer  ---------------->  Receive message, translate SharedRegion pointer
Receive reply and first record      <---------------------------    Reply to message with first record
Loop        Loop
    Retrieve records as they are filled                                        Load buffer records when they are available
     Mark buffer as available (empty)                                          Mark buffer as filled (ready for consumption)
End loop        End loop
In general, this works; however, some data doesn't make the trip from the DSP to the ARM.  The output capture  shown below shows 0's where there should be data in a few records of buffers 13 and 14.  The dumped data field is encoded as follows:
      0xbb0rr0nn,  where bb is the buffer #, rr is the record # and nn is the value # (so the 4th entry in the record is value #3)
buffer  record         int[3]
  13       21       0d015003
  13       22       0d016003
  13       23       0d017003
  13       24       0d018003
  13       25       0d019003
  13       26       0d01a003
  13       27       00000000
  13       28       00000000
  13       29       00000000
  13       30       0d01e003
  13       31       0d01f003
  14       00       00000000
The zeroes aren't always in the same place.
To simplify the code and reduce the chance of contention, each of the 16 buffers is filled one time only.
The code for App.c (ARM side), Server.c (DSP side) and the key include file are attached.
Beer's on me for anyone who can answer why all the data isn't making to the ARM.
 * Copyright (c) 2013-2017, Texas Instruments Incorporated
 * All rights reserved.
 * Redistribution and use in source and binary forms, with or without
 * modification, are permitted provided that the following conditions
 * are met:
 * *  Redistributions of source code must retain the above copyright
 * *  Redistributions in binary form must reproduce the above copyright
 *    documentation and/or other materials provided with the distribution.
 * *  Neither the name of Texas Instruments Incorporated nor the names of
 * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS "AS IS"
 * AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO,
 * THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR
 * PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT OWNER OR
 * CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL,
 * EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT LIMITED TO,
 * PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR PROFITS;
 * OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY,
 * WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR
 * OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE,
 * EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
 *  ======== App.c ========
/* host header files */
#include <stdio.h>
#include <unistd.h>
#include <stdint.h>
#include <stdlib.h>
#include <unistd.h>
#include <string.h>
#include <ti/cmem.h>
/* package header files */
#include <ti/ipc/Std.h>
#include "Std.h"
#include <ti/ipc/MessageQ.h>
//#include "HeapMem.h"
#include "SharedRegion.h"
#include "MemoryDefs.h"
#include <ti/ipc/GateMP.h>
#include "Cache.h"
/* local header files */
#include "../shared/ipcCommon.h"
#include "App.h"
/* Application specific defines */
#define DEBUG                                   1
#define BIG_DATA_POOL_SIZE              0x1000000
//#define HIGH_SPEED_STREAMING_BUFFERS        128
//#define STREAMING_BUFFER_SIZE   HIGH_SPEED_FLAGS_PER_BUFFER * 4         // 4K
// #define NEXT_GEN_STREAMING
/* round up the value 'size' to the next 'align' boundary */
#define ROUNDUP(size, align) \
    (UInt32)(((UInt32)(size) + ((UInt32)(align) - 1)) & ~((UInt32)(align) - 1))
/* module structure */
typedef struct {
    MessageQ_Handle         hostQue;    // created locally
    MessageQ_QueueId        slaveQue;   // opened remotely
    UInt16                  heapId;     // MessageQ heapId
    UInt32                  msgSize;
} App_Module;
/* private data */
static App_Module Module;
 *  ======== App_create ========
Int App_create(UInt16 remoteProcId)
    Int                 status = 0;
    MessageQ_Params     msgqParams;
    char                msgqName[32];
    printf("--> App_create:\n");
    /* setting default values */
    Module.hostQue = NULL;
    Module.slaveQue = MessageQ_INVALIDMESSAGEQ;
    Module.heapId = App_MsgHeapId;
    Module.msgSize = sizeof(App_Msg);
    /* create local message queue (inbound messages) */
    MessageQ_Params_init(&msgqParams);
    Module.hostQue = MessageQ_create(App_HostMsgQueName, &msgqParams);
    if (Module.hostQue == NULL) {
        printf("App_create: Failed creating MessageQ\n");
        status = -1;
        goto leave;
    /* open the remote message queue */
    sprintf(msgqName, App_SlaveMsgQueName, MultiProc_getName(remoteProcId));
    printf("     - remoteProcId, msgqName: %d, %s\n", remoteProcId, msgqName);
    do {
        status = MessageQ_open(msgqName, &Module.slaveQue);
        sleep(1);
    printf ("MessageQ_open status = %d\n", status);
    } while (status == MessageQ_E_NOTFOUND);
    if (status < 0) {
        printf("App_create: Failed opening MessageQ\n");
        goto leave;
    printf("App_create: Host is ready\n");
leave:
    printf("<-- App_create:\n");
    return(status);
 *  ======== App_delete ========
Int App_delete(Void)
    Int         status;
    printf("--> App_delete:\n");
    /* close remote resources */
    status = MessageQ_close(&Module.slaveQue);
    if (status < 0) {
        goto leave;
    /* delete the host message queue */
    status = MessageQ_delete(&Module.hostQue);
    if (status < 0) {
        goto leave;
leave:
    printf("<-- App_delete:\n");
    return(status);
 *  ======== App_exec ========
Int App_exec(Void)
    Int                     errorCtr = 0;
//  Int                     expectedDspCtr = 1;
    Int                     i,j, k;
    Int                     msgID = 0;
    Int                     pool_id;
    Int                     retVal;
//  Int                     sbPtr = 0;
    Int                     status;
    Int                     streamingBuffer[HIGH_SPEED_NUMBER_OF_BUFFERS][HIGH_SPEED_FLAGS_PER_BUFFER];
//  Int                     streamingBuffer2[STREAMING_BUFFER_SIZE];
    Int                     diagBuffer[500][6];
//  Int                     diagBuffCtr = 0;
    Int                     start, count;
    Int                     timer;
//  UInt32                  errorCount=0;
    UInt16                  regionId;
    UInt16                  regionId1=1;
    Bool                    getFlags         = TRUE;
    Bool                    streamingStarted = FALSE;
    Shared_Mem              *shmem;
//  UInt32         *bigDataLocalPtr;
    App_Msg *               msg;
    SharedRegion_Entry      *pSrEntry;
    void                    *sharedRegionAllocPtr=NULL;
    CMEM_AllocParams        cmemAttrs;
//  HeapMem_Handle          sr1Heap;
    bigDataLocalDesc_t      bigDataLocalDesc;
    SharedRegion_Config     sharedRegionConfig;
    SharedRegion_Entry      srEntry;
//  HeapMem_Config          HeapMemConfig;
//  HeapMem_Params          heapMem_params;
    Memory_Stats            stats;
//  HeapMem_ExtendedStats   extStats;
    GateMP_Params           gparams;
    GateMP_Handle           gateHandle;
    IArg                    gateKey;
    printf("--> App_exec-4:\n");
    /* CMEM: contiguous memory manager for HLOS */
    /* initialised here */
    status = CMEM_init();
    if (status < 0) {
        printf("CMEM_init failed\n");
        goto leave;
    else {
        printf("CMEM_init success\n");
    pool_id = CMEM_getPool(BIG_DATA_POOL_SIZE);
    if (pool_id < 0) {
        printf("CMEM_getPool failed\n");
        goto leave;
    printf("CMEM_getPool success\n");
    cmemAttrs.type = CMEM_HEAP;
    cmemAttrs.flags =  CMEM_CACHED;
    cmemAttrs.alignment = 0;
    sharedRegionAllocPtr = CMEM_allocPool(pool_id, &cmemAttrs);
    if (sharedRegionAllocPtr == NULL) {
        printf("CMEM_allocPool failed\n");
        goto leave;
    printf("CMEM_allocPool success: Allocated buffer %p\n", sharedRegionAllocPtr);
    /* Create shared region */
    SharedRegion_getConfig (&sharedRegionConfig);
    status = SharedRegion_setup (&sharedRegionConfig);
    if (status < 0) {
        printf("SharedRegion_setup failed\n");
        goto leave;
    printf("SharedRegion_setup success\n");
    /* Configure srEntry */
    srEntry.base = sharedRegionAllocPtr;
    srEntry.len = BIG_DATA_POOL_SIZE;
    srEntry.ownerProcId = MultiProc_self();
    /* Make sure this is enabled if using Cached memory */
    srEntry.isValid = TRUE;
    srEntry.cacheEnable = TRUE;
    srEntry.createHeap = FALSE;
    srEntry.cacheLineSize = 128;
    srEntry.name = "SR1";
    status = SharedRegion_setEntry (regionId1, &srEntry);
    pSrEntry = SharedRegion_getEntryPtr(regionId1);
    printf("App_taskFxn: SR_1, base 0x%x, len=%x\n", (UInt32)pSrEntry->base, pSrEntry->len);
    regionId = regionId1;
    /* fill process pipeline */
    for (i = 1; i <= 3; i++) {
        /* allocate message */
        msg = (App_Msg *)MessageQ_alloc(Module.heapId, Module.msgSize);
        if (msg == NULL) {
            status = -1;
            goto leave;
        /* set the return address in the message header */
        MessageQ_setReplyQueue(Module.hostQue, (MessageQ_Msg)msg);
        if ( i == 1) {
            printf("App_exec: sending message %d (REGION_INIT)\n", i);
            /* fill in message payload for Shared region init*/
            msg->cmd = App_CMD_SHARED_REGION_INIT;
            msg->id = i;
            msg->regionId = regionId;
            /* Passing the local shared memory address to the remote */
            /* Actually this can be any allocated buffer for the used for the heap */
            msg->u.sharedRegionInitCfg.base = CMEM_getPhys(pSrEntry->base);
            printf("Shared memory phys Addr %llx\n", msg->u.sharedRegionInitCfg.base);
            if (!msg->u.sharedRegionInitCfg.base) {
                printf("CMEM_getPhys failed\n");
            msg->u.sharedRegionInitCfg.size = (UInt64)(pSrEntry->len);
        } else {
            printf("App_exec: sending message %d (NOP)\n", i);
            /* fill in message payload */
            msg->cmd = App_CMD_NOP;
            msg->id = i;
        /* send message */
        MessageQ_put(Module.slaveQue, (MessageQ_Msg)msg);
    msgID            = 4;
    // Retrieve & send 4 messages
    //      read-1 SHARED_REGION_INIT / send-4 BIGDATA
    //      read-2 NOP                / send-5 NOP
    //      read-3 NOP                / send-6 NOP
    //      read-4 BIGDATA            / send-7 SHUTDOWN
    while (streamingStarted == FALSE) {
        /* Now this section of code starts receiving messages
           See the next section for the code for sending further messages */
        /* Receive messages: Start <======================================= */
        /* wait for return message */
        status = MessageQ_get (Module.hostQue, (MessageQ_Msg *)&msg, MessageQ_FOREVER);
        if (status < 0) {
            goto leave;
        printf("App_exec (v1.0): message received %d\n", msg->id);
        if (msg->cmd == App_CMD_BIGDATA) {
            streamingStarted = TRUE;
        /* free the message */
        MessageQ_free((MessageQ_Msg)msg);
        printf("App_exec: Preparing message %d\n", i);
        /* Receive messages: End =======================================> */
        /* Send messages: Start  <======================================= */
        if (msg == NULL) {
            status = -1;
            printf("MessageQ_alloc failed\n");
            goto leave;
        if (msgID == 4) {
            printf("App_exec: sending message %d (BIGDATA)\n", msgID);
            // Send Big data messages
            msg->cmd = App_CMD_BIGDATA;
            msg->id  = msgID++;
            /* Allocate buffer from HeapMem */
            shmem = (Shared_Mem *) pSrEntry->base;
            if (!shmem) {
                status = -1;
                printf("HeapMem_alloc failed\n");
                goto leave;
            // Initialized pointers for continuous operation
            shmem->dspBuffPtr   = 0;                                    // initialize the pointer to the first buffer
            shmem->armBuffPtr   = 0;                                    // initialize the pointer to the first buffer
            // Initialize data buffers to zero
            for (j=0; j<HIGH_SPEED_NUMBER_OF_BUFFERS; j++) {
                shmem->bufferFilled[j] = 0;                                    // all buffers available
                for (k=0; k<HIGH_SPEED_FLAGS_PER_BUFFER; k++) {
                    shmem->buffer[j][k]   = 0;
                    streamingBuffer[j][k] = 0;
            // Populate the Local descriptor
            bigDataLocalDesc.localPtr = (void *)shmem;
            bigDataLocalDesc.size     = BIGDATA_BUF_SIZE;
            Cache_wb (bigDataLocalDesc.localPtr, bigDataLocalDesc.size, Cache_Type_ALL, TRUE);
            msg->u.bigDataSharedDesc.sharedPtr = SharedRegion_getSRPtr (bigDataLocalDesc.localPtr, regionId);
            msg->u.bigDataSharedDesc.size      = bigDataLocalDesc.size;
        } else {
            if (msgID == 7) {
                printf("App_exec: sending message %d (SHUTDOWN)\n", msgID);
                msg->cmd = App_CMD_SHUTDOWN;                            // Last message will tell the slave to shutdown
                msg->id  = msgID++;
            } else {
                printf("App_exec: sending message %d (NOP)\n", msgID);
                msg->cmd = App_CMD_NOP;                                    // Send dummy NOP messages before shutdown
                msg->id  = msgID++;
        /* send message */
        /* Send messages: End  =======================================> */
    // Process streaming data & flags (goes on forever)
    if (streamingStarted) {
        Cache_inv(bigDataLocalDesc.localPtr, bigDataLocalDesc.size, Cache_Type_ALL, TRUE);
        // Process the first streaming packet
        diagBuffer[0][0] = shmem->bufferFilled[shmem->armBuffPtr];
        // Retrieve the first buffer
        if ( shmem->bufferFilled[shmem->armBuffPtr] == 1 ) {           // if the DSP has filled this buffer
            memcpy ((void *) (  streamingBuffer[shmem->armBuffPtr]),
                                (void *) (shmem->buffer[shmem->armBuffPtr]),
                                STREAMING_BUFFER_SIZE );
            shmem->bufferFilled[shmem->armBuffPtr] = 0;                 // clear flag to indicate buffer is free
            shmem->armBuffPtr    = (shmem->armBuffPtr+1)%HIGH_SPEED_NUMBER_OF_BUFFERS;
            errorCtr             = 0;
                printf ("1...\n");
        // Next gen streaming data
        j = 1;
        while (j<HIGH_SPEED_NUMBER_OF_BUFFERS) {
            diagBuffer[j][0] = shmem->bufferFilled[shmem->armBuffPtr];
                // Retrieve the next buffer
                memcpy ( (void *) (streamingBuffer[shmem->armBuffPtr]),
                shmem->bufferFilled[shmem->armBuffPtr] = 0;             // clear this buffer's full bit => ready to fill
                shmem->armBuffPtr    = (shmem->armBuffPtr+1) % HIGH_SPEED_NUMBER_OF_BUFFERS;
                j++;                                                // increment buffer pointer
            } else {
                errorCtr++;
            usleep (1000);                                          // delay in micro-seconds (10^-6)
        }    // while
    }   // if streamingStarted
    /* drain process pipeline */
        status = MessageQ_get(Module.hostQue, (MessageQ_Msg *)&msg,
            MessageQ_FOREVER);
        if (status < 0) {
            printf("MessageQ_get failed\n");
            goto leave;
        printf("App_exec: message received-3: %d\n", msg->id);
        /* extract message payload */
leave:
    if (sharedRegionAllocPtr) {
        CMEM_free(sharedRegionAllocPtr, &cmemAttrs);
    printf ("# of sweeps that a buffer wasn't ready from DSP: %d\nReceived buffer: \n", errorCtr);
    printf (" buffer\t\trecord\t\tdspCtr\t\t    [3]\t\t BuffReady \n");
    for (i=0; i<HIGH_SPEED_NUMBER_OF_BUFFERS; i++) {
        for (j=0; j<HIGH_SPEED_NUMBER_OF_RECORDS; j++) {
            printf (" %2.2d\t\t  %2.2d\t\t %2.2d \t\t%8.8x\t\t%8.8x \n", i, j, streamingBuffer[i][j*32],
        streamingBuffer[i][j*32+3],
        diagBuffer[i][0]);
    status = 0;
    printf("<-- App_exec: %d\n", status);
    return(status);
 * Copyright (c) 2017, Texas Instruments Incorporated
 * are met:
 *  ======== Server.c ========
/* this define must precede inclusion of any xdc header file */
#define Registry_CURDESC Test__Desc
#define MODULE_NAME "Server"
/* xdctools header files */
#include <xdc/std.h>
#include <xdc/runtime/Assert.h>
#include <xdc/runtime/Diags.h>
#include <xdc/runtime/Log.h>
#include <xdc/runtime/Registry.h>
#include <stdio.h>
#include <stdlib.h>
#include <time.h>
#include <ti/ipc/MultiProc.h>
#include <ti/ipc/SharedRegion.h>
#include <ti/ipc/HeapMemMP.h>
#include <ti/ipc/remoteproc/Resource.h>
#include <ti/sysbios/hal/Cache.h>
#include <xdc/runtime/IHeap.h>
#include <xdc/runtime/Memory.h>
#include <ti/sysbios/BIOS.h>
#include <ti/sysbios/knl/Task.h>
// local defines
//   #define NEXT_GEN_STREAMING_SERVICE        // Un-comment to use next gen
/* module header file */
#include "../shared/dsp.h"
typedef struct {
    UInt16              hostProcId;         // host processor id
    MessageQ_Handle     slaveQue;           // created locally
} Server_Module;
/* private data */
Registry_Desc               Registry_CURDESC;
static Server_Module        Module;
 *  ======== Server_init ========
Void Server_init(Void)
    Registry_Result result;
    /* register with xdc.runtime to get a diags mask */
    result = Registry_addModule(&Registry_CURDESC, MODULE_NAME);
    Assert_isTrue(result == Registry_SUCCESS, (Assert_Id)NULL);
    /* initialize module object state */
    Module.hostProcId = MultiProc_getId("HOST");
 *  ======== Server_create ========
Int Server_create()
    Int                 status = 0;
    char                msgqName[32];
    /* enable some log events */
    Diags_setMask(MODULE_NAME"+EXF");
    sprintf(msgqName, App_SlaveMsgQueName, MultiProc_getName(MultiProc_self()));
    Module.slaveQue = MessageQ_create(msgqName, &msgqParams);
    if (Module.slaveQue == NULL) {
        status = -1;
        goto leave;
    Log_print0(Diags_INFO,"Server_create: server is ready");
leave:
    Log_print1(Diags_EXIT, "<-- Server_create: %d", (IArg)status);
    return (status);
 *  ======== Server_exec ========
Int Server_exec()
    Int                 dspCtr = 1;
    Int                 i, j, k;
    Int                 recPtr = 0;
    Int                 retryCount;
    Int                 retryLimit = 100;
    Int                 retVal;
    Int                 status;
//  Int32               streamingBuffer[HIGH_SPEED_NUMBER_OF_BUFFERS][HIGH_SPEED_FLAGS_PER_BUFFER];
    Int32               *streamingBuffer;
    float               dlyVal = 0.0;
    volatile int        dlyCtr = 0;
//  Uint32 *bigDataLocalPtr;
    Shared_Mem          *shmem;
    clock_t             startTime;
    Bool                running   = TRUE;
    Bool                firstPass = TRUE;
    App_Msg *           msg;
    MessageQ_QueueId    queId;
    UInt16              regionId1  = 1;
    UInt32              errorCount = 0;
    void                *sharedRegionAllocPtr = NULL;
    IArg                gateKey;
//    struct timespec {        ts;
    Log_print0(Diags_ENTRY | Diags_INFO, "--> Server_exec-C:");
//    startTime = clock();
//    clock_gettime (CLOCK_REALTIME, &ts);
//    startTime = ts.tv_nsec;
//    startTime = Clock_getTicks();
//    startTime = -1;
    streamingBuffer = (Int32 *) malloc(HIGH_SPEED_FLAGS_PER_BUFFER*4);
    while (running) {
        /* wait for inbound message */
        status = MessageQ_get(Module.slaveQue, (MessageQ_Msg *)&msg,
            MessageQ_FOREVER);
        if (status < 0) {
            goto leave;
        Log_print1(Diags_ENTRY | Diags_INFO, "Message received...%d", msg->id);
        switch (msg->cmd) {
        case App_CMD_SHARED_REGION_INIT:  // <=============================================================
            // Create Shared region with information from init message
            status = Resource_physToVirt((UInt32)msg->u.sharedRegionInitCfg.base, (UInt32 *)&sharedRegionAllocPtr);
            if(status != Resource_S_SUCCESS) {
                printf("Resource_physToVirt failed\n");
                goto leave;
            srEntry.len           = msg->u.sharedRegionInitCfg.size;
            Log_print0(Diags_ENTRY | Diags_INFO, "Shared region entry configured...");
            break;
        case App_CMD_BIGDATA:        // <=============================================================
            firstPass = TRUE;
            for (k=0; k<HIGH_SPEED_NUMBER_OF_BUFFERS+1; k++) {
                // Translate to local descriptor
                retVal = bigDataXlatetoLocalAndSync(regionId1, &msg->u.bigDataSharedDesc, &bigDataLocalDesc);
                if (retVal) {
                    status = -1;
                    goto leave;
                shmem = (Shared_Mem *) bigDataLocalDesc.localPtr;
                i = shmem->dspBuffPtr;
                if ( shmem->bufferFilled[i] == 0) {                     // make sure buffer is ready to be filled
                    // test loop to get enough sweeps' data to fill a buffer
                    for (recPtr = 0; recPtr<HIGH_SPEED_NUMBER_OF_RECORDS; recPtr++) {
                        // Normal loop processing ===============================================================
                        for (j=0; j<HIGH_SPEED_NUMBER_OF_FLAGS; j++) {
                            if (j==0) {
                                streamingBuffer[recPtr*32+j] = dspCtr++;
                            } else if (j==1) {
                                streamingBuffer[recPtr*32+j] = 0xbad0dad;
                            } else if (j==2) {
                                streamingBuffer[recPtr*32+j] = k;
                            } else if (j== (HIGH_SPEED_NUMBER_OF_FLAGS-1) ) {
                                streamingBuffer[recPtr*32+j] = (int) (dlyVal*100.);
                            } else {
                                streamingBuffer[recPtr*32+j] = i * 0x1000000 + recPtr * 0x1000 + j;
                        // Do some calculations here to simulate normal DSP operation
                        for (dlyCtr = 0; dlyCtr<100000; dlyCtr++); {
                            dlyVal = (float) (dlyCtr % 0x1fffffff) * 0.9;
                memcpy ((void *) (shmem->buffer[i]), (void *) streamingBuffer, STREAMING_BUFFER_SIZE);
                shmem->bufferFilled[shmem->dspBuffPtr] = 1;             // set buffer's bit to indicate it's full
                shmem->dspBuffPtr    = (shmem->dspBuffPtr+1) % HIGH_SPEED_NUMBER_OF_BUFFERS;
                // Translate to Shared Descriptor and Sync
                retVal = bigDataXlatetoGlobalAndSync(regionId1, &bigDataLocalDesc, &msg->u.bigDataSharedDesc);
                if (retVal) {
                    status = -1;
                    goto leave;
                // send message back (on first buffer fill only)
                if (firstPass) {
                    queId = MessageQ_getReplyQueue(msg);
                    MessageQ_put(queId, (MessageQ_Msg)msg);
                    firstPass = FALSE;
                Log_print1(Diags_ENTRY | Diags_INFO, "Checking buffer %d for invalid records", k);
                for (i=0; i<HIGH_SPEED_NUMBER_OF_RECORDS; i++) {
                    if (streamingBuffer[i*32+1] != 0xbad0dad ) {
                        Log_print1(Diags_ENTRY | Diags_INFO, "record %d is bad", i);
            break;
        case App_CMD_SHUTDOWN:        // <=============================================================
            running = FALSE;
//          GateMP_close(&gateHandle);
            break;
        default:
            break;
        /* process the message */
        Log_print2(Diags_INFO, "Server_exec: processed id %d, cmd=0x%x", msg->id, msg->cmd);
        /* send message back */
        if (msg->cmd != App_CMD_BIGDATA) {
    } /* while (running) */
leave:
    /* Print error count if non-zero */
    if (errorCount) {
        Log_print1(Diags_INFO, "Server_exec: Error Count %d", errorCount);
        status = -1;
    else
        Log_print0(Diags_INFO, "Server_exec: Data check clean");
    Log_print1(Diags_EXIT, "<-- Server_exec: %d", (IArg)status);
    return(status);
 *  ======== Server_delete ========
Int Server_delete()
    Int         status;
    Log_print0(Diags_ENTRY, "--> Server_delete:");
    /* delete the video message queue */
    status = MessageQ_delete(&Module.slaveQue);
    if (status < 0) {
        goto leave;
leave:
    if (status < 0) {
        Log_error1("Server_finish: error=0x%x", (IArg)status);
    /* disable log events */
    Log_print1(Diags_EXIT, "<-- Server_delete: %d", (IArg)status);
    Diags_setMask(MODULE_NAME"-EXF");
    return(status);
 *  ======== Server_exit ========
Void Server_exit(Void)
     * Note that there isn't a Registry_removeModule() yet:
     *     https://bugs.eclipse.org/bugs/show_bug.cgi?id=315448
     * ... but this is where we'd call it.
ipcCommon.h
  • The issue is here
    --- a/host_linux/simple_buffer_example/host/App.c
    +++ b/host_linux/simple_buffer_example/host/App.c
    @@ -436,7 +436,7 @@ Int App_exec(Void)
    -            bigDataLocalDesc.size     = BIGDATA_BUF_SIZE;
    +            bigDataLocalDesc.size     = sizeof(Shared_Mem);
                 fp = fopen("buffer_before_dsp.bin", "wb");
                 if (fp != NULL) {
