OMAP-L138 RTC SET32COUNTER
I'm having some trouble understanding how the SET32COUNTER bit on the Control Register of the RTC module works.
As I understand, it should replace the current value on the 32 kHz counter with whatever is present on the compensation registers. The problem is, both compensation registers together amount to a 16 bits field, and I imagine that the 32 kHz counter would be a 32 bit register.
So how does this counter set works?
Thank you,
Rafael
