TDA4VM: Marvel 88Q2112 on TDA4 hardware switch
Part Number: TDA4VM
We are currently attempting to bring up a Marvel 88Q2112 phy using the hardware switch present on the TDA4. The 88Q2112 only supports configurations through the Clause 45 register set. I saw that there was another post on e2e stating that Clause 45 register bringup on the hardware switch was not supported. I was curious what the state of this support is, if it's still completely not supported or not. Beyond that, I was wondering if there was any extra information you could provide that might help with enabling this device to work on the CPSW switch.
Thanks.
    Sorry for the delay in response
    Current PHY driver does not support clause 45 but read/write heper functions are provided as an example. With the help of it, you should be able to write your own PHY driver. If you are integrating a 3P PHY then this will be required in any case as TI does not support non-TI PHY's directly.
    The steps required are explained in this documentation.
    To see clause 45 helper functions, go to pdk/packages/ti/drv/enet and search for the IOCTL functions ENET_MDIO_IOCTL_C45_READ and ENET_MDIO_IOCTL_C45_WRITE
    Vineet
