AM4378: Ethernet Driver Crash issue on the Prototype Board
Part Number: AM4378
Other Parts Discussed in Thread: DP83620, AM4372
I am seeing ethernet driver getting crashed when two prototype boards are not connected directly with ethernet cable.
Did a ping from oneboard to otherboard.
[ 731.043587] ------------[ cut here ]------------
[ 731.048276] WARNING: CPU: 0 PID: 10 at net/sched/sch_generic.c:466 dev_watchdog+0x260/0x280
[ 731.056666] NETDEV WATCHDOG: eth0 (cpsw): transmit queue 0 timed out
[ 731.063047] Modules linked in: cfg80211 bnep iptable_filter iptable_mangle iptable_nat nf_nat_ipv le_mangle ip6table_nat nf_nat_ipv6 nf_nat nf_conntrack libcrc32c nf_defrag_ipv4 nf_defrag_ipv6 ip6_t bg ecdh_generic cdc_ether usbnet pru_rproc irq_pruss_intc pruss ti_am335x_adc sha512_generic sha512_ ecb hmac omap_des pvrsrvkm(O) omap_aes_driver md5 des_generic crypto_engine pruss_soc_bus omap_sham c_ts wkup_m3_ipc omap_wdt rtc_omap wkup_m3_rproc remoteproc ti_am335x_tscadc mstp_cmnet(O)
[ 731.117934] CPU: 0 PID: 10 Comm: ktimersoftd/0 Tainted: G O 4.19.160-rt69-gb3a2247
[ 731.127368] Hardware name: Generic AM43 (Flattened Device Tree)
[ 731.133311] Backtrace:
[ 731.135783] [<c0014598>] (dump_backtrace) from [<c00148d8>] (show_stack+0x18/0x1c)
[ 731.143387] r7:00000009 r6:00000000 r5:c0bbfd6c r4:dc489dfc
[ 731.149079] [<c00148c0>] (show_stack) from [<c08e108c>] (dump_stack+0x20/0x28)
[ 731.156342] [<c08e106c>] (dump_stack) from [<c00366fc>] (__warn+0xcc/0xf8)
[ 731.163250] [<c0036630>] (__warn) from [<c00362f4>] (warn_slowpath_fmt+0x4c/0x70)[ 731.170768] r9:00000480 r8:dc6c6800 r7:c0c8b7c0 r6:dc6c742c r5:dc6c6aa8 r4:c0bbfd30
[ 731.178548] [<c00362ac>] (warn_slowpath_fmt) from [<c07d4a2c>] (dev_watchdog+0x260/0x280)
[ 731.186760] r3:dc6c6800 r2:c0bbfd30
[ 731.190348] r5:dc6c6aa8 r4:00000000
[ 731.193960] [<c07d47cc>] (dev_watchdog) from [<c008fb14>] (expire_timers+0x50/0x164)
[ 731.201739] r10:00000000 r9:c0c8b804 r8:00000000 r7:c0c8b800 r6:dc489eac r5:c07d47cc
[ 731.209600] r4:ffffe000
[ 731.212147] [<c008fac4>] (expire_timers) from [<c008fea0>] (run_timer_softirq+0xbc/0x25c)
[ 731.220361] r10:00000020 r9:00000004 r8:c0c8b7c0 r7:c0c8b800 r6:c0c8b800 r5:dc489eac
[ 731.228221] r4:dc489eac
[ 731.230772] [<c008fde4>] (run_timer_softirq) from [<c0039a28>] (do_current_softirqs+0x198/0x268)
[ 731.239596] r8:00000000 r7:04208140 r6:ffffe000 r5:c0c83414 r4:00000001
[ 731.246332] [<c0039890>] (do_current_softirqs) from [<c0039b28>] (run_ksoftirqd+0x30/0x54)
[ 731.254634] r10:dc469df8 r9:00000000 r8:00000000 r7:c0c833e4 r6:00000001 r5:ffffe000
[ 731.262495] r4:ffffe000
[ 731.265053] [<c0039af8>] (run_ksoftirqd) from [<c00580d0>] (smpboot_thread_fn+0x2c0/0x2f4)
[ 731.273350] r5:ffffe000 r4:dc437c80
[ 731.276954] [<c0057e10>] (smpboot_thread_fn) from [<c0053b44>] (kthread+0x188/0x1a0)
[ 731.284733] r8:c0057e10 r7:dc437c80 r6:dc488000 r5:dc437d40 r4:dc437dc0
[ 731.291468] [<c00539bc>] (kthread) from [<c00090e0>] (ret_from_fork+0x14/0x34)
[ 731.298719] Exception stack(0xdc489fb0 to 0xdc489ff8)
[ 731.303793] 9fa0: 00000000 00000000 00000000 00000000
[ 731.312006] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 731.320219] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
[ 731.326865] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c00539bc
[ 731.334725] r4:dc437d40
[ 731.337267] ---[ end trace 0000000000000002 ]---
^C
root@Node0cb2b7c5da5c:~# tcpdump
tcpdump: verbose output suppressed, use -v or -vv for full protocol decode
listening on eth0, link-type EN10MB (Ethernet), capture size 262144 bytes
03:32:36.717127 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:32:36.717335 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
^C
2 packets captured
2 packets received by filter
0 packets dropped by kernel
<debug_uart>
U-Boot SPL 2020.01-gae8ceb7b6e (Apr 22 2021 - 21:08:48 +0530)
WDT:   Not found!
Trying to boot from USB
Bus usb@483d0000: Register 2000440 NbrPorts 2
Starting the controller
USB XHCI 1.00
scanning bus usb@483d0000 for devices... 2 USB Device(s) found
       scanning usb for storage devices... 1 Storage Device(s) found
U-Boot 2020.01-gae8ceb7b6e (Apr 22 2021 - 21:08:48 +0530)
CPU  : AM437X-GP rev 1.2
Model: Carrier FSP
DRAM:  512 MiB
PMIC:  TPS65218
MMC:   OMAP SD/MMC: 0
Loading Environment from FAT... ** No device specified **
Net:   Could not get PHY for ethernet@4a100000: addr 1668115712
Warning: ethernet@4a100000 using MAC address from ROM
eth0: ethernet@4a100000
Hit any key to stop autoboot:  0
starting USB...
USB XHCI 1.00
Device 0: Vendor: SanDisk  Rev: 1.26 Prod: Cruzer Orbit
            Type: Removable Hard Disk
            Capacity: 7633.5 MB = 7.4 GB (15633408 x 512)
... is now current device
## Error: "loadbootenv" not defined
4899328 bytes read in 206 ms (22.7 MiB/s)
49271 bytes read in 6 ms (7.8 MiB/s)
Booting from usb 0...
   Loading Device Tree to 8fff0000, end 8ffff076 ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Linux version 4.19.160-rt69-gb3a2247aae (oe-user@oe-host) (gcc version 8.3.0 (GCC)) #                                  TC 2021
[    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[    0.000000] OF: fdt: Machine model: TI AM437x FSP-SmallPanel-RefHw-Rev-2.0-21-04-2021-2
[    0.000000] Memory policy: Data cache writeback
[    0.000000] efi: Getting EFI parameters from FDT:
[    0.000000] cma: Reserved 48 MiB at 0x9d000000
[    0.000000] CPU: All CPU(s) started in SVC mode.
[    0.000000] AM437x ES1.2 (sgx neon)
[    0.000000] random: get_random_bytes called from start_kernel+0x88/0x44c with crng_init=0
[    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
[    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/sda2 rw rootfstype=ext4 rootwai
[    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[    0.000000] Memory: 456388K/524288K available (9162K kernel code, 385K rwdata, 3216K rodata, 328K                                  49152K cma-reserved, 0K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9163 kB)
[    0.000000]       .init : 0x(ptrval) - 0x(ptrval)   ( 328 kB)
[    0.000000]       .data : 0x(ptrval) - 0x(ptrval)   ( 386 kB)
[    0.000000]        .bss : 0x(ptrval) - 0x(ptrval)   ( 294 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
[    0.000000] rcu: Preemptible hierarchical RCU implementation.
[    0.000000] rcu:     RCU priority boosting: priority 1 delay 500 ms.
[    0.000000]  No expedited grace period (rcu_normal_after_boot).
[    0.000000]  Tasks RCU enabled.
[    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
[    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
[    0.000000] L2C-310 enabling early BRESP for Cortex-A9
[    0.000000] OMAP L2C310: ROM does not support power control setting
[    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
[    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
[    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
[    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
[    0.000015] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
[    0.000028] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7963585194
[    0.000034] OMAP clocksource: timer1 at 24000000 Hz
[    0.000444] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327
[    0.000448] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000838] Console: colour dummy device 80x30
[    0.000964] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000966] This ensures that you still see kernel messages. Please
[    0.000968] update your kernel commandline.
[    0.001001] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
[    0.060184] pid_max: default: 32768 minimum: 301
[    0.060326] Security Framework initialized
[    0.060443] AppArmor: AppArmor initialized
[    0.060508] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.060520] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[    0.061438] CPU: Testing write buffer coherency: ok
[    0.061496] CPU0: Spectre v2: using BPIALL workaround
[    0.062558] Setting up static identity map for 0x80008200 - 0x80008278
[    0.062854] rcu: Hierarchical SRCU implementation.
[    0.063604] EFI services will not be available.
[    0.064280] devtmpfs: initialized
[    0.075679] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
[    0.076138] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 191126044
[    0.076163] futex hash table entries: 256 (order: 1, 8192 bytes)
[    0.079896] pinctrl core: initialized pinctrl subsystem
[    0.080877] DMI not present or invalid.
[    0.081452] NET: Registered protocol family 16
[    0.083380] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.157067] audit: initializing netlink subsys (disabled)
[    0.160394] audit: type=2000 audit(0.150:1): state=initialized audit_enabled=0 res=1
[    0.176295] No ATAGs?
[    0.176317] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
[    0.176337] hw-breakpoint: maximum watchpoint size is 4 bytes.
[    0.194670] edma 49000000.edma: TI EDMA DMA engine driver
[    0.198725] SCSI subsystem initialized
[    0.198995] usbcore: registered new interface driver usbfs
[    0.199052] usbcore: registered new interface driver hub
[    0.199197] usbcore: registered new device driver usb
[    0.199862] media: Linux media interface: v0.10
[    0.199911] videodev: Linux video capture interface: v2.00
[    0.200040] pps_core: LinuxPPS API ver. 1 registered
[    0.200051] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.
[    0.200075] PTP clock support registered
[    0.200111] EDAC MC: Ver: 3.0.0
[    0.201441] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
[    0.202226] Advanced Linux Sound Architecture Driver Initialized.
[    0.203569] clocksource: Switched to clocksource timer1
[    0.204428] AppArmor: AppArmor Filesystem Enabled
[    0.213895] NET: Registered protocol family 2
[    0.214791] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 7168 bytes)
[    0.214848] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[    0.214901] TCP bind hash table entries: 4096 (order: 4, 98304 bytes)
[    0.215182] TCP: Hash tables configured (established 4096 bind 4096)
[    0.215386] UDP hash table entries: 256 (order: 2, 16384 bytes)
[    0.215476] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
[    0.215819] NET: Registered protocol family 1
[    0.216532] RPC: Registered named UNIX socket transport module.
[    0.216547] RPC: Registered udp transport module.
[    0.216553] RPC: Registered tcp transport module.
[    0.216559] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.218952] Initialise system trusted keyrings
[    0.219325] workingset: timestamp_bits=14 max_order=17 bucket_order=3
[    0.225381] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.226258] NFS: Registering the id_resolver key type
[    0.226303] Key type id_resolver registered
[    0.226311] Key type id_legacy registered
[    0.226364] ntfs: driver 2.1.32 [Flags: R/O].
[    0.641615] NET: Registered protocol family 38
[    0.641644] Key type asymmetric registered
[    0.641653] Asymmetric key parser 'x509' registered
[    0.641744] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[    0.641757] io scheduler noop registered
[    0.641764] io scheduler deadline registered
[    0.642076] io scheduler cfq registered (default)
[    0.642089] io scheduler mq-deadline registered
[    0.642096] io scheduler kyber registered
[    0.646735] pinctrl-single 44e10800.pinmux: 199 pins, size 796
[    0.650603] pwm-backlight backlight: backlight supply power not found, using dummy regulator
[    0.650725] pwm-backlight backlight: Linked as a consumer to regulator.0
[    0.706260] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
[    0.709722] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
[    0.710603] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 31, base_baud = 3000000) is a 8250
[    1.437253] console [ttyS0] enabled
[    1.441454] omap8250 48022000.serial: No clock speed specified: using default: 48000000
[    1.450281] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 32, base_baud = 3000000) is a 8250
[    1.460381] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 33, base_baud = 3000000) is a 8250
[    1.469845] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
[    1.478670] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 34, base_baud = 3000000) is a 8250
[    1.490192] omap_rng 48310000.rng: Random Number Generator ver. 20
[    1.493793] random: fast init done
[    1.494051] random: crng init done
[    1.505702] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    1.515102] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    1.522047] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    1.545364] brd: module loaded
[    1.560164] loop: module loaded
[    1.567508] libphy: Fixed MDIO Bus: probed
[    1.572681] CAN device driver interface
[    1.577885] c_can_platform 481cc000.can: c_can_platform device registered (regs=df9a9553, irq=66)
[    1.587705] c_can_platform 481d0000.can: c_can_platform device registered (regs=e48982b3, irq=67)
[    1.663656] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
[    1.671364] libphy: 4a101000.mdio: probed
[    1.677649] davinci_mdio 4a101000.mdio: phy[2]: device 4a101000.mdio:02, driver TI DP83620 10/100
[    1.687376] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver TI DP83620 10/100
[    1.697944] cpsw 4a100000.ethernet: Missing dual_emac_res_vlan in DT.
[    1.704458] cpsw 4a100000.ethernet: Using 1 as Reserved VLAN for 0 slave
[    1.711227] cpsw 4a100000.ethernet: Missing dual_emac_res_vlan in DT.
[    1.717713] cpsw 4a100000.ethernet: Using 2 as Reserved VLAN for 1 slave
[    1.724463] cpsw 4a100000.ethernet: Detected MACID = 0c:b2:b7:c5:da:5c
[    1.731158] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
[    1.737564] cpsw 4a100000.ethernet: ALE Table size 1024
[    1.742856] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
[    1.750943] cpsw 4a100000.ethernet: cpsw: Detected MACID = 0c:b2:b7:c5:da:5e
[    1.761360] dwc3 48390000.usb: Failed to get clk 'ref': -2
[    1.767372] OF: graph: no port node found in /ocp@44000000/ocp2scp@483a8000/phy@483a8000
[    1.778819] dwc3 483d0000.usb: Failed to get clk 'ref': -2
[    1.786418] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[    1.792988] ehci-pci: EHCI PCI platform driver
[    1.797550] ehci-platform: EHCI generic platform driver
[    1.803056] ehci-omap: OMAP-EHCI Host Controller driver
[    1.808459] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[    1.814709] ohci-pci: OHCI PCI platform driver
[    1.819890] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.825472] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[    1.833739] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002
[    1.843440] xhci-hcd xhci-hcd.0.auto: irq 102, io mem 0x483d0000
[    1.849965] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
[    1.858279] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.865536] usb usb1: Product: xHCI Host Controller
[    1.870434] usb usb1: Manufacturer: Linux 4.19.160-rt69-gb3a2247aae xhci-hcd
[    1.877514] usb usb1: SerialNumber: xhci-hcd.0.auto
[    1.883143] hub 1-0:1.0: USB hub found
[    1.886972] hub 1-0:1.0: 1 port detected
[    1.891369] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[    1.896933] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[    1.904666] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
[    1.911371] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[    1.919650] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
[    1.927956] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[    1.935210] usb usb2: Product: xHCI Host Controller
[    1.940107] usb usb2: Manufacturer: Linux 4.19.160-rt69-gb3a2247aae xhci-hcd
[    1.947186] usb usb2: SerialNumber: xhci-hcd.0.auto
[    1.952736] hub 2-0:1.0: USB hub found
[    1.956556] hub 2-0:1.0: 1 port detected
[    1.961325] usbcore: registered new interface driver cdc_acm
[    1.967044] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[    1.975183] usbcore: registered new interface driver usblp
[    1.981010] usbcore: registered new interface driver uas
[    1.986495] usbcore: registered new interface driver usb-storage
[    1.993970] printer gadget: printer ready
[    1.998903] i2c /dev entries driver
[    2.004261] sdhci: Secure Digital Host Controller Interface driver
[    2.010476] sdhci: Copyright(c) Pierre Ossman
[    2.016438] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.1
[    2.049036] sdhci-pltfm: SDHCI platform and OF driver helper
[    2.064031] NET: Registered protocol family 10
[    2.070247] Segment Routing with IPv6
[    2.074202] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
[    2.080943] NET: Registered protocol family 17
[    2.085475] can: controller area network core (rev 20170425 abi 9)
[    2.091819] NET: Registered protocol family 29
[    2.096717] Key type dns_resolver registered
[    2.101242] omap_voltage_late_init: Voltage driver support not added
[    2.104117] mmc0: new high speed MMC card at address 0001
[    2.114557] mmcblk0: mmc0:0001 IS008G 7.28 GiB
[    2.115426] mmcblk0boot0: mmc0:0001 IS008G partition 1 4.00 MiB
[    2.116311] mmcblk0boot1: mmc0:0001 IS008G partition 2 4.00 MiB
[    2.116638] mmcblk0rpmb: mmc0:0001 IS008G partition 3 4.00 MiB, chardev (242:0)
[    2.146100] Loading compiled-in X.509 certificates
[    2.152022] alg: No test for pkcs1pad(rsa,sha1) (pkcs1pad(rsa-generic,sha1))
[    2.167133] Loaded X.509 cert 'Build time autogenerated kernel key: c8f8b3cbdae17bad8996564f249f6
[    2.178186] AppArmor: AppArmor sha1 policy hashing enabled
[    2.200545] OMAP GPIO hardware version 0.1
[    2.241169] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 400 kHz
[    2.248579] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz
[    2.253688] usb 1-1: new high-speed USB device number 2 using xhci-hcd
[    2.261613] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    2.271020] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    2.277972] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    2.285486] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    2.294879] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    2.301805] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    2.309575] hctosys: unable to open rtc device (rtc0)
[    2.315681] ALSA device list:
[    2.318674]   No soundcards found.
[    2.323410] Waiting for root device /dev/sda2...
[    2.434408] usb 1-1: New USB device found, idVendor=0781, idProduct=557c, bcdDevice= 1.26
[    2.442635] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[    2.449808] usb 1-1: Product: Cruzer Orbit
[    2.453923] usb 1-1: Manufacturer: SanDisk
[    2.458038] usb 1-1: SerialNumber: 4C532000040603102402
[    2.464956] usb-storage 1-1:1.0: USB Mass Storage device detected
[    2.471690] scsi host0: usb-storage 1-1:1.0
[    2.477263] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    2.486706] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    2.493714] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    3.525014] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Orbit     1.26 PQ: 0 ANSI: 5
[    3.534790] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    3.545178] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    3.545660] sd 0:0:0:0: [sda] 15633408 512-byte logical blocks: (8.00 GB/7.45 GiB)
[    3.547438] sd 0:0:0:0: [sda] Write Protect is off
[    3.547792] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or
[    3.558683]  sda: sda1 sda2 sda3 sda4
[    3.561483] sd 0:0:0:0: [sda] Attached SCSI removable disk
[    3.585977] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    4.084343] EXT4-fs (sda2): recovery complete
[    4.090542] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[    4.098320] VFS: Mounted root (ext4 filesystem) on device 8:2.
[    4.104360] devtmpfs: mounted
[    4.107951] Freeing unused kernel memory: 328K
[    4.112412] This architecture does not have kernel memory protection.
[    4.118883] Run /sbin/init as init process
INIT: version 2.88 booting
Framebuffer /dev/fb0 not detected
Boot splashscreen disabled
Starting board_start
 /etc/resolv.conf
net.ipv6.conf.default.hop_limit = 128
net.ipv6.conf.all.hop_limit = 128
Starting udev
[    4.963899] udevd[139]: starting version 3.2.7
[    5.015699] udevd[139]: specified group 'kvm' unknown
[    5.067978] udevd[140]: starting eudev-3.2.7
[    5.241351] mstp_cmnet: loading out-of-tree module taints kernel.
[    5.343859] Initializing MS/TP network device driver version 1.01-016
[    5.684969] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    5.767146] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    5.807508] remoteproc remoteproc0: wkup_m3 is available
[    5.810546] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[    5.814989] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    5.823068] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    5.823178] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    5.834452] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    5.835632] omap_rtc 44e3e000.rtc: registered as rtc0
[    5.850717] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    5.850829] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    5.850952] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    5.872902] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    6.412114] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    6.412245] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    6.412372] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    6.446203] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    6.501110] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    6.501221] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    6.501346] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    6.504388] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
[    6.514591] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    6.706022] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
[    6.713382] omap-aes 53501000.aes: will run requests pump with realtime priority
[    6.834599] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
[    6.850095] omap-des 53701000.des: will run requests pump with realtime priority
[    6.923726] omap_i2c 4802a000.i2c: timeout waiting for bus ready
[    6.923757] pixcir_ts 1-005c: pixcir_set_power_mode: can't read reg 0x33 : -16
[    6.923761] pixcir_ts 1-005c: Failed to set IDLE mode
[    6.929272] pixcir_ts: probe of 1-005c failed with error -16
[    6.960912] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.sgx on minor 0
[    6.961942] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    6.962057] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    6.962180] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    6.967500] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    7.096211] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    7.096326] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    7.096452] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    7.126922] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    7.289111] PM: Cannot get wkup_m3_ipc handle
[    7.573947] net eth1: initializing cpsw version 1.15 (0)
[    7.674703] TI DP83620 10/100 Mbps PHY 4a101000.mdio:02: attached PHY driver [TI DP83620 10/100 M                                  0.mdio:02, irq=POLL)
[    7.681821] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[    7.716579] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    7.716720] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    7.716845] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    7.768634] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    7.769326] PM: Cannot get wkup_m3_ipc handle
[    7.803937] net eth0: initializing cpsw version 1.15 (0)
[    7.904759] TI DP83620 10/100 Mbps PHY 4a101000.mdio:04: attached PHY driver [TI DP83620 10/100 M                                  0.mdio:04, irq=POLL)
[    7.906388] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.154617] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    8.154733] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    8.154858] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    8.165482] wkup_m3_ipc 44e11324.wkup_m3_ipc: could not get rproc handle
[    8.166168] PM: Cannot get wkup_m3_ipc handle
[    9.242832] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    9.252329] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    9.317300] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[    9.459150] PM: Cannot get wkup_m3_ipc handle
[    9.463705] remoteproc remoteproc0: powering up wkup_m3
[    9.487533] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[    9.534966] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[    9.537817] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 242996
[    9.538653] remoteproc remoteproc0: remote processor wkup_m3 is now up
[    9.538804] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
[    9.905447] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[   10.350467] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please ru
[   10.497057] EXT4-fs (sda3): recovery complete
[   10.501476] EXT4-fs (sda3): mounted filesystem with ordered data mode. Opts: (null)
[   10.528950] EXT4-fs (sda4): recovery complete
[   10.530847] EXT4-fs (sda4): mounted filesystem with ordered data mode. Opts: (null)
[   10.997992] device eth1 entered promiscuous mode
[   11.246592] net eth0: promiscuity not disabled as the other interface is still in promiscuity mod
[   11.289469] net eth0: promiscuity not disabled as the other interface is still in promiscuity mod
[   11.375182] device eth0 entered promiscuous mode
[   12.394426] PM: bootloader does not support rtc-only!
[   12.400369] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[   12.467938] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[   12.500369] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[   12.601017] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[   12.657782] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[   12.670635] remoteproc remoteproc1: 54434000.pru is available
[   12.673875] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[   12.674940] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[   12.675067] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[   12.675178] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[   12.707655] pru-rproc 54434000.pru: PRU rproc node pru@54434000 probed successfully
[   12.715913] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[   12.725097] remoteproc remoteproc2: 54438000.pru is available
[   12.725192] pru-rproc 54438000.pru: PRU rproc node pru@54438000 probed successfully
[   12.726325] remoteproc remoteproc3: 54474000.pru is available
[   12.726434] pru-rproc 54474000.pru: PRU rproc node pru@54474000 probed successfully
[   12.727535] remoteproc remoteproc4: 54478000.pru is available
[   12.727644] pru-rproc 54478000.pru: PRU rproc node pru@54478000 probed successfully
[   12.795028] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[   12.801995] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[   12.809650] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regul
[   12.819054] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
[   12.826012] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
[   12.910614] usbcore: registered new interface driver cdc_ether
modprobe: FATAL: Module g_ether not found in directory /lib/modules/4.19.160-rt69-gb3a2247aae
/etc/rcS.d/S05oneStartScript.sh: line 82: printf: b7: invalid number
/etc/rcS.d/S05oneStartScript.sh: line 83: printf: c5: invalid number
/etc/rcS.d/S05oneStartScript.sh: line 84: printf: da: invalid number
/etc/rcS.d/S05oneStartScript.sh: line 85: printf: 5e: invalid number
net.ipv6.conf.default.autoconf = 0
net.ipv6.conf.all.forwarding = 1
net.ipv6.conf.default.forwarding = 1
sysctl: setting key "net.ipv6.conf.all.mc_forwarding"
sysctl: cannot stat /proc/sys/net/ipv6/conf/wlan1/forwarding: No such file or directory
pim6dd: 00:00:13.198 warning - Got 1048576 byte buffer size in 0 iterations
pim6dd: 00:00:13.199 warning - setsockopt(IPV6_ROUTER_ALERT): Protocol not available
pim6dd: 00:00:13.199 warning - Got 1048576 byte buffer size in 0 iterations
[   13.495162] Bluetooth: Core ver 2.22
[   13.500052] NET: Registered protocol family 31
[   13.504598] Bluetooth: HCI device and connection manager initialized
[   13.511008] Bluetooth: HCI socket layer initialized
[   13.515935] Bluetooth: L2CAP socket layer initialized
[   13.521067] Bluetooth: SCO socket layer initialized
[   13.545747] Bluetooth: RFCOMM TTY layer initialized
[   13.550690] Bluetooth: RFCOMM socket layer initialized
[   13.556105] Bluetooth: RFCOMM ver 1.11
*******Starting Obexdmount: /tmp/bt-inbox: can't find in /etc/fstab.
Directory /lib/modules/4.19.160-rt69-gb3a2247aae/extra exists.
starting /home/root/web/webserver with 5 client
OK
[   14.361644] EXT4-fs (sda2): re-mounted. Opts: (null)
/etc/init.d/rc: line 56: /etc/rcS.d/S18bluez5-obexd: Permission denied
sysctl: cannot stat /proc/sys/net/ipv4/tcp_syncookies: No such file or directory
Fri Apr 23 03:18:46 UTC 2021
ALSA: Restoring mixer settings...
/usr/sbin/alsactl: load_state:1735: No soundcards found...
OK
Error 28 fault detected [no subcode]
"Address already in use"
Detail: bind failed in soap_bind()
Cannot open /run/boot/uboot.env: No such file or directory
mkdir: cannot create directory '/run/media': File exists
mkdir: cannot create directory '/usr/share/Upgrade/Remote': File exists
mkdir: cannot create directory '/usr/share/Upgrade/backup': File exists
mkdir: cannot create directory '/usr/share/Upgrade/backup/App': File exists
INIT: Entering runlevel: 5
Configuring network interfaces... net.ipv6.conf.lo.hop_limit = 128
net.ipv6.conf.default.keep_addr_on_down = 1
net.ipv6.conf.lo.autoconf = 0
net.ipv6.conf.all.keep_addr_on_down = 1
net.ipv6.conf.lo.keep_addr_on_down = 1
net.ipv4.conf.default.rp_filter = 1
net.ipv4.conf.all.rp_filter = 1
net.ipv4.ip_forward = 0
net.ipv4.icmp_echo_ignore_broadcasts = 1
net.ipv4.conf.all.accept_redirects = 0
net.ipv4.conf.all.send_redirects = 0
net.ipv4.conf.all.accept_source_route = 0
net.ipv4.conf.default.accept_source_route = 0
net.ipv4.conf.default.accept_redirects = 0
net.ipv4.conf.default.send_redirects = 0
[   17.804358] device lo entered promiscuous mode
ifup: interface eth0 already configured
ifup: interface eth1 already configured
ifconfig: SIOCGIFFLAGS: No such device
ifup: ignoring unknown interface wlan1
Starting system message bus: dbus.
[   18.126564] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
Loaded PowerVR consumer services.
Setting environment variables...Starting UI app... UI app started.
Starting OpenBSD Secure Shell server: sshd
done.
Starting rpcbind daemon...done.
Starting Quagga daemons: zebra bgpd ripd ripngd ospfd ospf6d isisd.
starting statd: done
Starting advanced power management daemon: apmd.
apmd[948]: apmd 3.2.1 interfacing with apm driver 1.13 and APM BIOS 1.2
Starting bluetooth: bluetoothd.
Starting HOSTAP Daemon: [   20.647827] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[   20.665197] Bluetooth: BNEP filters: protocol multicast
[   20.671488] Bluetooth: BNEP socket layer initialized
Configuration file: /etc/hostapd.conf
[   20.788021] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[   21.506700] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
[   21.517914] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[   21.543881] cfg80211: failed to load regulatory.db
Could not read interface wlan0 flags: No such device
nl80211: Driver does not support authentication/association or connect commands
nl80211: deinit ifname=wlan0 disabled_11b_rates=0
nl80211 driver initialization failed.
wlan0: interface state UNINITIALIZED->DISABLED
wlan0: AP-DISABLED
wlan0: CTRL-EVENT-TERMINATING
hostapd_free_hapd_data: Interface wlan0 wasn't started
MESA-LOADER: failed to open kms_swrast (search paths /usr/lib/dri)
failed to load driver: kms_swrast
MESA-LOADER: failed to open swrast (search paths /usr/lib/dri)
failed to load swrast driver
Could not create GBM device (No such device)
Could not open device /dev/dri/card0 - aborting!
exportfs: can't open /etc/exports for reading
NFS daemon support not enabled in kernel
Starting ntpd: done
starting rsyslogd ... done
 * Starting Avahi mDNS/DNS-SD Daemon: avahi-daemon
Starting LCDproc display server daemon: Could not open driver module /usr/lib/lcdproc/curses.so: /us                                  en shared object file: No such file or directory
Driver [curses] binding failed
Could not load driver curses
There is no output driver
Critical error while initializing, abort.
Starting LCDproc system status monitor: sock_connect: connect failed
Error connecting to LCD server localhost on port 13666.
Check to see that the server is running and operating normally.
Starting crond: OK
Starting AppArmor profiles
Mounting securityfs on /sys/kernel/security
find: '/etc/apparmor.d/cache': No such file or directory
Starting random number generator daemon
Initalizing available sources
Initalizing entropy source hwrng
[   32.483618] vmmcwl_fixed: disabling
Enabling JITTER rng support
Initalizing entropy source jitter
umount: /mnt/.psplash: not mounted.
FSP Distro 2.7.4 Node0cb2b7c5da5c ttyS0
Warning:  Use of this System is Restricted to Authorized Users
This computer system is the private property of the Company and may be
used only by those individuals authorized by the Company, in accordance
with Company policy.  Unauthorized, illegal or improper use may result
in disciplinary action and/or civil or criminal prosecution.
Your use of Company electronic systems is subject to monitoring and
disclosure in accordance with Company policy and applicable law.  By
continuing to access this system, you agree that your use of Company
electronic systems is subject to the foregoing and that you have no
expectation of privacy in regard to any files or data stored, accessed,
transmitted or received on such systems.
Node0cb2b7c5da5c login: root
Last login: Fri Apr 23 03:19:55 UTC 2021 on ttyS0
root@Node0cb2b7c5da5c:~# dmseg | grep model
-sh: dmseg: command not found
root@Node0cb2b7c5da5c:~# dmesg | grep model
root@Node0cb2b7c5da5c:~# echo 34 > /sys/class/gpio/export
root@Node0cb2b7c5da5c:~# echo out > /sys/class/gpio/gpio34/direction
root@Node0cb2b7c5da5c:~# echo 1 > /sys/class/gpio/gpio34/value
root@Node0cb2b7c5da5c:~# [  420.804506] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flo
[  420.812533] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
^C
root@Node0cb2b7c5da5c:~# ifconfig
eth0      Link encap:Ethernet  HWaddr 0C:B2:B7:C5:DA:5C
          inet6 addr: fe80::eb2:b7ff:fec5:da5c/64 Scope:Link
          inet6 addr: 2001:db8::eb2:b7ff:fec5:da5c/128 Scope:Global
          UP BROADCAST RUNNING PROMISC MULTICAST  MTU:1500  Metric:1
          RX packets:0 errors:0 dropped:0 overruns:0 frame:0
          TX packets:24 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:3000
          RX bytes:0 (0.0 B)  TX bytes:4170 (4.0 KiB)
          Interrupt:51
eth1      Link encap:Ethernet  HWaddr 0C:B2:B7:C5:DA:5E
          inet6 addr: 2001:db8::eb2:b7ff:fec5:da5e/128 Scope:Global
          UP BROADCAST PROMISC MULTICAST  MTU:1500  Metric:1
          TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:0 (0.0 B)  TX bytes:0 (0.0 B)
lo        Link encap:Local Loopback
          inet addr:127.0.0.1  Mask:255.0.0.0
          inet6 addr: 2001:db8::200:ff:fe00:0/128 Scope:Global
          inet6 addr: ::1/128 Scope:Host
          UP LOOPBACK RUNNING PROMISC  MTU:65536  Metric:1
          RX packets:12 errors:0 dropped:0 overruns:0 frame:0
          TX packets:12 errors:0 dropped:0 overruns:0 carrier:0
          RX bytes:848 (848.0 B)  TX bytes:848 (848.0 B)
root@Node0cb2b7c5da5c:~# [  731.043587] ------------[ cut here ]------------
^C
^C
2 packets captured
03:32:56.747491 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:33:00.753449 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:33:00.753649 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:33:02.165125 IP6 Node0cb2b7c5e560.local.ntp > ff0e::101.ntp: NTPv4, Client, length 48
03:33:03.654608 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:33:04.759585 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:33:06.762704 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:33:08.766045 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:33:12.771919 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:33:12.772570 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:33:13.664681 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:33:16.778808 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:33:18.782311 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:33:20.785818 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
^C
14 packets captured
14 packets received by filter
03:34:52.886639 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:34:53.751021 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:34:54.889781 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:34:56.893274 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:00.898290 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:00.898471 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:03.761114 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:35:04.902960 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:06.906461 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:08.909967 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:12.165087 IP6 Node0cb2b7c5e560.local.ntp > ff0e::101.ntp: NTPv4, Client, length 48
03:35:12.916403 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:12.916983 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:13.771191 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:35:16.923178 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:18.926706 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:20.930159 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:23.781300 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:35:24.936523 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:24.937164 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:28.942474 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:30.946061 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:32.932696 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, router advertisement, length 24
03:35:32.949631 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:33.791390 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:35:36.955984 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:36.956657 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:40.961935 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:42.965459 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:43.801480 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:35:44.969001 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:48.974497 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:48.975160 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:52.980485 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:35:53.811592 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:35:54.984005 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:35:56.987454 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:00.993197 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:00.993806 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:03.821674 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:36:04.999893 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:07.003518 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:09.007005 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:13.012534 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:13.013276 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:13.831757 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:36:16.165073 IP6 Node0cb2b7c5e560.local.ntp > ff0e::101.ntp: NTPv4, Client, length 48
03:36:17.019414 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:19.023039 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:21.026464 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:23.841884 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:36:25.032746 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:25.033518 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:29.038800 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:31.042294 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:33.045731 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:33.851954 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:36:37.052024 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:37.052652 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:41.058067 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:43.061613 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:43.862046 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:36:45.065142 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:49.070597 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:49.071229 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:53.076534 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:36:53.872150 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:36:55.080051 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:36:57.083536 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:01.088989 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:01.089618 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:03.882243 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:37:05.095709 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:07.099207 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:08.101642 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:12.107147 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:12.107784 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:13.892320 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:37:16.113899 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:18.117425 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:20.120860 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:23.165080 IP6 Node0cb2b7c5e560.local.ntp > ff0e::101.ntp: NTPv4, Client, length 48
03:37:23.902420 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:37:24.127103 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:24.127655 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:28.133083 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:30.136560 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:32.140015 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:33.912506 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:37:36.146368 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:36.147012 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:40.152275 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:42.155827 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:43.922594 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:37:44.159322 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:48.164767 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:48.165628 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:52.170931 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
03:37:53.932689 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::5: OSPFv3, Hello, length 36
03:37:54.174477 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::1: ICMP6, multicast listener querymax resp dela
03:37:56.177862 IP6 fe80::eb2:b7ff:fec5:da5c > ff02::d: PIMv2, Hello, length 10
^C
101 packets captured
101 packets received by filter
root@Node0cb2b7c5da5c:~# ip -6 route
2001:db8::200:ff:fe00:0 dev lo proto kernel metric 256 pref medium
2001:db8::eb2:b7ff:fec5:da5c dev eth0 proto kernel metric 256 pref medium
2001:db8::eb2:b7ff:fec5:da5e dev eth1 proto kernel metric 256 linkdown pref medium
fe80::/64 dev eth0 proto kernel metric 256 pref medium
cpsw_default: cpsw_default {
        pinctrl-single,pins = <
            /* Slave 1 */
            AM4372_IOPAD(0x92c, PIN_OUTPUT | MUX_MODE0)    /* (D14) mii1_txclk.gmii1_txclk */
            AM4372_IOPAD(0x914, PIN_OUTPUT | MUX_MODE0)    /* (A13) mii1_txen.gmii1_txen */
            AM4372_IOPAD(0x928, PIN_OUTPUT | MUX_MODE0)    /* (B15) mii1_txd0.gmii1_txd0 */
            AM4372_IOPAD(0x924, PIN_OUTPUT | MUX_MODE0)    /* (A14) mii1_txd1.gmii1_txd1 */
            AM4372_IOPAD(0x920, PIN_OUTPUT | MUX_MODE0)    /* (C13) mii1_txd0.gmii1_txd2 */
            AM4372_IOPAD(0x91c, PIN_OUTPUT | MUX_MODE0)    /* (C16) mii1_txd1.gmii1_txd3 */
            AM4372_IOPAD(0x930, PIN_INPUT | MUX_MODE0)     /* (D13) mii1_rxclk.gmii1_rxclk */
            AM4372_IOPAD(0x918, PIN_INPUT | MUX_MODE0)     /* (A15) mii1_rxdv.gmii1_rxctl */
            AM4372_IOPAD(0x940, PIN_INPUT | MUX_MODE0)     /* (F17) mii1_rxd0.gmii1_rxd0 */
            AM4372_IOPAD(0x93c, PIN_INPUT | MUX_MODE0)     /* (B16) mii1_rxd1.gmii1_rxd1 */
            AM4372_IOPAD(0x938, PIN_INPUT | MUX_MODE0)     /* (E16) mii1_rxd0.gmii1_rxd2 */
            AM4372_IOPAD(0x934, PIN_INPUT | MUX_MODE0)     /* (C14) mii1_rxd1.gmii1_rxd3 */
            /* Slave 2 */
            AM4372_IOPAD(0x858, PIN_OUTPUT | MUX_MODE1)    /* (E8) gpmc_a6.gmii2_tclk */
            AM4372_IOPAD(0x840, PIN_OUTPUT | MUX_MODE1)    /* (C3) gpmc_a0.gmii2_tctl */
            AM4372_IOPAD(0x854, PIN_OUTPUT | MUX_MODE1)    /* (E7) gpmc_a5.gmii2_txd0 */
            AM4372_IOPAD(0x850, PIN_OUTPUT | MUX_MODE1)    /* (D7) gpmc_a4.gmii2_txd1 */
            AM4372_IOPAD(0x84c, PIN_OUTPUT | MUX_MODE1)    /* (A4) gpmc_a3.gmii2_txd2 */
            AM4372_IOPAD(0x848, PIN_OUTPUT | MUX_MODE1)    /* (C6) gpmc_a2.gmii2_txd3 */
            AM4372_IOPAD(0x85c, PIN_INPUT | MUX_MODE1)     /* (F6) gpmc_a7.gmii2_rxclk */
            AM4372_IOPAD(0x844, PIN_INPUT | MUX_MODE1)     /* (C5) gpmc_a1.gmii2_rxtcl */
            AM4372_IOPAD(0x86c, PIN_INPUT | MUX_MODE1)     /* (D8)gpmc_a11.gmii2_rxd0 */
            AM4372_IOPAD(0x868, PIN_INPUT | MUX_MODE1)     /* (G8) gpmc_a10.gmii2_rxd1 */
            AM4372_IOPAD(0x864, PIN_INPUT | MUX_MODE1)     /* (B4) gpmc_a9.gmii2_rxd2 */
            AM4372_IOPAD(0x860, PIN_INPUT | MUX_MODE1)     /* (F7) gpmc_a8.gmii2_rxd3 */
&mac {
    pinctrl-names = "default", "sleep";
    pinctrl-0 = <&cpsw_default>;
    pinctrl-1 = <&cpsw_sleep>;
    dual_emac = <1>;
    status = "okay";
&cpsw_emac0 {
        phy-handle = <&dp83867_0>;
        phy_id = <&davinci_mdio>, <4>;
        phy-mode = "mii";
        ti,dual-emac-pvid = <1>;
&cpsw_emac1 {
        phy-handle = <&dp83867_1>;
        phy_id = <&davinci_mdio>, <2>;
        phy-mode = "mii";
        ti,dual-emac-pvid = <2>;
&davinci_mdio {
    pinctrl-0 = <&davinci_mdio_default>;
    pinctrl-1 = <&davinci_mdio_sleep>;
    status = "okay";
    dp83867_0: ethernet-phy@4 {
        reg = <4>;
        ti,rx-internal-delay = <DP83867_RGMIIDCTL_2_25_NS>;
        ti,tx-internal-delay = <DP83867_RGMIIDCTL_250_PS>;
        ti,fifo-depth = <DP83867_PHYCR_FIFO_DEPTH_8_B_NIB>;
        ti,min-output-impedance;
        ti,dp83867-rxctrl-strap-quirk;
    dp83867_1: ethernet-phy@2 {
        reg = <2>;
Attachment contains crashlog &  dts changes for ethernet.
  • Sorry, Two prototype board are connected directly over ethernet. Did a ping from both sides and a crash was observed on both boards.
  • Your Linux log indicates that a DP83620 is being detected, but your device tree contains configuration data for a DP83867:
            reg = <4>;
            reg = <2>;
    Looking at the Linux source code, the DP83620 support can be found in the file drivers/net/phy/dp83848.c.  It looks to me like the DP83620 is closely related to the DP83848.  I do not see any relationship to the DP83867, so I believe the reference above should be removed.
    I also see some warnings related to the Ethernet:
    I think that pertains to these highlighted lines from your device tree:
    &cpsw_emac0 {
            phy-mode = "mii";
    &cpsw_emac1 {
            phy-mode = "mii";
    I couldn't find anything by that name in kernel 4.19 (Linux SDK 6.03).  I believe those should be replaced with the following respectively:
    dual_emac_res_vlan = <1>;
    dual_emac_res_vlan = <2>;
    Please try out those changes and post your updated dts fragments and boot log.
    Brad
  • Updated the changes and still crash was observed.
    the dts fragment used is:​
    &mac
    {​​​​​​​     pinctrl-names = "default", "sleep";     \
         status = "okay";
          dual_emac;
    &davinci_mdio
              status = "okay";
             ethphy0: ethernet-phy@2 {​​​​​​​                 reg = <4>;         }​​​​​​​;
             ethphy1: ethernet-phy@4 {​​​​​​​                 reg = <2>;         }​​​​​​​;
    &cpsw_emac0
            phy-handle = <&ethphy0>;
            phy-mode = "mii";
    &cpsw_emac1
    ​​​​​     phy-handle = <&ethphy1>;
         phy-mode = "mii";
    CRASH LOG:
    PING 192.168.1.20 (192.168.1.20): 56 data bytes
    [ 266.083238] ------------[ cut here ]------------
    [ 266.087927] WARNING: CPU: 0 PID: 10 at net/sched/sch_generic.c:466 dev_watchdog+0x260/0x280
    [ 266.096336] NETDEV WATCHDOG: eth0 (cpsw): transmit queue 0 timed out
    [ 266.102716] Modules linked in: cfg80211 bnep iptable_filter iptable_mangle iptable_nat nf_nat_ipv4 ip_tables ip6table_filter ip6table_mangle ip6table_nat nf_nat_ipv6 nf_nat nf_conntrack libcrc32c nf_defrag_ipv4 nf_defrag_ipv6 ip6_tables x_tables rfcomm bluetooth drbg ecdh_generic cdc_ether usbnet pru_rproc irq_pruss_intc pruss ti_am335x_adc ctr cbc ecb sha512_generic sha512_arm sha256_generic hmac pm33xx omap_des pwm_omap_dmtimer pwm_beeper md5 des_generic omap_aes_driver crypto_engine pvrsrvkm(OE) omap_sham pruss_soc_bus omap_crypto ti_emif_sram pixcir_i2c_ts wkup_m3_ipc wkup_m3_rproc omap_wdt rtc_omap ti_am335x_tscadc remoteproc mstp_cmnet(OE)
    [ 266.160224] CPU: 0 PID: 10 Comm: ktimersoftd/0 Tainted: G OE 4.19.160-rt69-gb3a2247aae #1
    [ 266.169659] Hardware name: Generic AM43 (Flattened Device Tree)
    [ 266.175604] Backtrace:
    [ 266.178080] [<c0014598>] (dump_backtrace) from [<c00148d8>] (show_stack+0x18/0x1c)
    [ 266.185686] r7:00000009 r6:00000000 r5:c0bc006c r4:dc489dfc
    [ 266.191379] [<c00148c0>] (show_stack) from [<c08e13ac>] (dump_stack+0x20/0x28)
    [ 266.198643] [<c08e138c>] (dump_stack) from [<c00366fc>] (__warn+0xcc/0xf8)
    [ 266.205553] [<c0036630>] (__warn) from [<c00362f4>] (warn_slowpath_fmt+0x4c/0x70)
    [ 266.213071] r9:00000480 r8:dc6c6800 r7:c0c8b7c0 r6:dc6c742c r5:dc6c6aa8 r4:c0bc0030
    [ 266.220856] [<c00362ac>] (warn_slowpath_fmt) from [<c07d4d4c>] (dev_watchdog+0x260/0x280)
    [ 266.229069] r3:dc6c6800 r2:c0bc0030
    [ 266.232658] r5:dc6c6aa8 r4:00000000
    [ 266.236272] [<c07d4aec>] (dev_watchdog) from [<c008fb14>] (expire_timers+0x50/0x164)
    [ 266.244055] r10:00000000 r9:c0c8b804 r8:00000000 r7:c0c8b800 r6:dc489eac r5:c07d4aec
    [ 266.251918] r4:ffffe000
    [ 266.254471] [<c008fac4>] (expire_timers) from [<c008fea0>] (run_timer_softirq+0xbc/0x25c)
    [ 266.262687] r10:00000020 r9:00000004 r8:c0c8b7c0 r7:c0c8b800 r6:c0c8b800 r5:dc489eac
    [ 266.270551] r4:dc489eac
    [ 266.273105] [<c008fde4>] (run_timer_softirq) from [<c0039a28>] (do_current_softirqs+0x198/0x268)
    [ 266.281930] r8:00000000 r7:04208140 r6:ffffe000 r5:c0c83414 r4:00000001
    [ 266.288666] [<c0039890>] (do_current_softirqs) from [<c0039b28>] (run_ksoftirqd+0x30/0x54)
    [ 266.296968] r10:dc469df8 r9:00000000 r8:00000000 r7:c0c833e4 r6:00000001 r5:ffffe000
    [ 266.304831] r4:ffffe000
    [ 266.307389] [<c0039af8>] (run_ksoftirqd) from [<c00580d0>] (smpboot_thread_fn+0x2c0/0x2f4)
    [ 266.315689] r5:ffffe000 r4:dc437c80
    [ 266.319296] [<c0057e10>] (smpboot_thread_fn) from [<c0053b44>] (kthread+0x188/0x1a0)
    [ 266.327077] r8:c0057e10 r7:dc437c80 r6:dc488000 r5:dc437d40 r4:dc437dc0
    [ 266.333814] [<c00539bc>] (kthread) from [<c00090e0>] (ret_from_fork+0x14/0x34)
    [ 266.341067] Exception stack(0xdc489fb0 to 0xdc489ff8)
    [ 266.346141] 9fa0: 00000000 00000000 00000000 00000000
    [ 266.354356] 9fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
    [ 266.362569] 9fe0: 00000000 00000000 00000000 00000000 00000013 00000000
    [ 266.369215] r10:00000000 r9:00000000 r8:00000000 r7:00000000 r6:00000000 r5:c00539bc
    [ 266.377078] r4:dc437d40
    [ 266.379620] ---[ end trace 0000000000000002 ]---
  • Have you tried taking eth1 down and doing some testing with only eth0?  That might be a better place to start.
    Can you please attach a COMPLETE BOOT LOG.  What you attached is a crash log.  The full boot log would be much more helpful.  Also, it's easier to review if you save the boot log as a text file and attach the file.  It is harder to review inline in the thread.  Thank you!
  • Hi Brad,
    I have attached the log with the new findings.
    As mentioned removed "DP83867" related configuration.
    The DTS fragment is:
    &mac {
    status = "okay";
    dual_emac = <1>;
    &davinci_mdio {
    status = "okay";
    ethphy0: ethernet-phy@4 {
    reg = <4>;
    ethphy1: ethernet-phy@2 {
    reg = <2>;
    &cpsw_emac0 {
    phy-mode = "mii";
    &cpsw_emac1 {
    phy-handle = <&ethphy2>;
    phy-mode = "mii";
    The ifconfig here is:
    root@Node0cb2b7c5c7b0:~# ifconfig
    eth0      Link encap:Ethernet  HWaddr 0C:B2:B7:C5:C7:B0
              inet6 addr: 2001:db8::eb2:b7ff:fec5:c7b0/128 Scope:Global
              Interrupt:50
    eth1      Link encap:Ethernet  HWaddr 0C:B2:B7:C5:C7:B0
    ifconfig
              Interrupt:50
              RX packets:2 errors:0 dropped:0 overruns:0 frame:0
              TX packets:2 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:140 (140.0 B)  TX bytes:140 (140.0 B)
    root@Node0cb2b7c5c7b0:~# [  273.364070] cpsw 4a100000.ethernet eth0: Link is Up - 100Mbps/Full - flow control off
    [  273.372093] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
              inet6 addr: fe80::eb2:b7ff:fec5:c7b0/64 Scope:Link
              RX packets:172 errors:0 dropped:4 overruns:0 frame:0
              TX packets:25 errors:0 dropped:0 overruns:0 carrier:0
              RX bytes:21267 (20.7 KiB)  TX bytes:4517 (4.4 KiB)
              Interrupt:50
    root@Node0cb2b7c5c7b0:~# ethtool -S    eth0
    Settings for eth0:
    	Supported ports: [ TP MII ]
    	Supported link modes:   10baseT/Half 10baseT/Full
    	                        100baseT/Half 100baseT/Full
    	Supported pause frame use: Symmetric Receive-only
    	Supports auto-negotiation: Yes
    	Supported FEC modes: Not reported
    	Advertised link modes:  10baseT/Half 10baseT/Full
    	Advertised pause frame use: No
    	Advertised auto-negotiation: Yes
    	Advertised FEC modes: Not reported
    	Link partner advertised link modes:  10baseT/Half 10baseT/Full
    	Link partner advertised pause frame use: Symmetric Receive-only
    	Link partner advertised auto-negotiation: Yes
    	Link partner advertised FEC modes: Not reported
    	Speed: 100Mb/s
    	Duplex: Full
    	Port: MII
    	PHYAD: 4
    	Transceiver: internal
    	Auto-negotiation: on
    	Supports Wake-on: d
    	Wake-on: d
    	Current message level: 0x00000000 (0)
    	Link detected: yes
    root@Node0cb2b7c5c7b0:~# ethtool eth0 - S
    NIC statistics:
         Good Rx Frames: 214
         Broadcast Rx Frames: 57
         Multicast Rx Frames: 157
         Pause Rx Frames: 0
         Rx CRC Errors: 0
         Rx Align/Code Errors: 0
         Oversize Rx Frames: 0
         Rx Jabbers: 0
         Undersize (Short) Rx Frames: 0
         Rx Fragments: 0
         Rx Octets: 30136
         Good Tx Frames: 0
         Broadcast Tx Frames: 0
         Multicast Tx Frames: 0
         Pause Tx Frames: 0
         Deferred Tx Frames: 0
         Collisions: 0
         Single Collision Tx Frames: 0
         Multiple Collision Tx Frames: 0
         Excessive Collisions: 0
         Late Collisions: 0
         Tx Underrun: 0
         Carrier Sense Errors: 0
         Tx Octets: 0
         Rx + Tx 64 Octet Frames: 19
         Rx + Tx 65-127 Octet Frames: 164
         Rx + Tx 128-255 Octet Frames: 17
         Rx + Tx 256-511 Octet Frames: 0
         Rx + Tx 512-1023 Octet Frames: 14
         Rx + Tx 1024-Up Octet Frames: 0
         Net Octets: 30136
         Rx Start of Frame Overruns: 0
         Rx Middle of Frame Overruns: 0
         Rx DMA Overruns: 0
         Rx DMA chan 0: head_enqueue: 1
         Rx DMA chan 0: tail_enqueue: 341
         Rx DMA chan 0: pad_enqueue: 0
         Rx DMA chan 0: misqueued: 0
         Rx DMA chan 0: desc_alloc_fail: 0
         Rx DMA chan 0: pad_alloc_fail: 0
         Rx DMA chan 0: runt_receive_buf: 0
         Rx DMA chan 0: runt_transmit_bu: 0
         Rx DMA chan 0: empty_dequeue: 0
         Rx DMA chan 0: busy_dequeue: 200
         Rx DMA chan 0: good_dequeue: 214
         Rx DMA chan 0: requeue: 0
         Rx DMA chan 0: teardown_dequeue: 0
         Tx DMA chan 0: head_enqueue: 36
         Tx DMA chan 0: tail_enqueue: 0
         Tx DMA chan 0: pad_enqueue: 0
         Tx DMA chan 0: misqueued: 0
         Tx DMA chan 0: desc_alloc_fail: 0
         Tx DMA chan 0: pad_alloc_fail: 0
         Tx DMA chan 0: runt_receive_buf: 0
         Tx DMA chan 0: runt_transmit_bu: 0
         Tx DMA chan 0: empty_dequeue: 36
         Tx DMA chan 0: busy_dequeue: 0
         Tx DMA chan 0: good_dequeue: 36
         Tx DMA chan 0: requeue: 0
         Tx DMA chan 0: teardown_dequeue: 0
    root@Node0cb2b7c5c7b0:~# ethtool -S eth0S g
    Ring parameters for eth0:
    Pre-set maximums:
    RX:		248
    RX Mini:	0
    RX Jumbo:	0
    TX:		248
    Current hardware settings:
    RX:		128
    RX Mini:	0
    RX Jumbo:	0
    TX:		128
    U-Boot SPL 2019.01-gae9a73a-dirty (Apr 29 2021 - 08:52:06 +0530)
    USB0:   Register 2000440 NbrPorts 2
    USB XHCI 1.00
    scanning bus 0 for devices... 2 USB Device(s) found
    SPL: Please implement spl_start_uboot() for your board
    SPL: Direct Linux boot not active!
    U-Boot 2019.01-gae9a73a-dirty (Apr 29 2021 - 08:52:06 +0530)
    Model: TI AM437x HW PLATFORM
    DRAM:  512 MiB
    PMIC:  TPS65218
    NAND:  0 MiB
    MMC:   OMAP SD/MMC: 0, OMAP SD/MMC: 1
    Net:
    Hit any key to stop autoboot:  2  1  0
    Card did not respond to voltage select!
    starting USB...
    USB XHCI 1.00
    Device 0: Vendor: SanDisk Rev: 1.00 Prod: Cruzer Blade
                Capacity: 14875.0 MB = 14.5 GB (30464000 x 512)
    4899328 bytes read in 205 ms (22.8 MiB/s)
    48902 bytes read in 17 ms (2.7 MiB/s)
       Loading Device Tree to 8fff1000, end 8fffff05 ... OK
    Starting kernel ...
    [    0.000000] Linux version 4.19.160-rt69-gb3a2247aae (oe-user@oe-host) (gcc version 8.3.0 (GCC)) #1 PREEMPT RT Thu Apr 29 13:49:01 UTC 2021
    [    0.000000] OF: fdt: Machine model: TI AM437x FSP-SmallPanel-RefHw-Rev-2.0-30-04-2021-17
    [    0.000000] Kernel command line: console=ttyO0,115200n8 root=/dev/sda2 rw rootfstype=ext4 rootwait
    [    0.000000] Memory: 456392K/524288K available (9162K kernel code, 385K rwdata, 3216K rodata, 328K init, 293K bss, 18744K reserved, 49152K cma-reserved, 0K highmem)
    [    0.000000]       .text : 0x(ptrval) - 0x(ptrval)   (9164 kB)
    [    0.000013] sched_clock: 32 bits at 24MHz, resolution 41ns, wraps every 89478484971ns
    [    0.000024] clocksource: timer1: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 79635851949 ns
    [    0.000031] OMAP clocksource: timer1 at 24000000 Hz
    [    0.000446] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
    [    0.000452] OMAP clocksource: 32k_counter at 32768 Hz
    [    0.000843] Console: colour dummy device 80x30
    [    0.000972] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
    [    0.000974] This ensures that you still see kernel messages. Please
    [    0.000976] update your kernel commandline.
    [    0.001011] Calibrating delay loop... 1987.37 BogoMIPS (lpj=9936896)
    [    0.060180] pid_max: default: 32768 minimum: 301
    [    0.060324] Security Framework initialized
    [    0.060437] AppArmor: AppArmor initialized
    [    0.060501] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.060512] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
    [    0.061417] CPU: Testing write buffer coherency: ok
    [    0.061472] CPU0: Spectre v2: using BPIALL workaround
    [    0.062535] Setting up static identity map for 0x80008200 - 0x80008278
    [    0.062835] rcu: Hierarchical SRCU implementation.
    [    0.063586] EFI services will not be available.
    [    0.064262] devtmpfs: initialized
    [    0.075552] VFP support v0.3: implementor 41 architecture 3 part 30 variant 9 rev 4
    [    0.076009] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
    [    0.076037] futex hash table entries: 256 (order: 1, 8192 bytes)
    [    0.079787] pinctrl core: initialized pinctrl subsystem
    [    0.080797] DMI not present or invalid.
    [    0.081363] NET: Registered protocol family 16
    [    0.083263] DMA: preallocated 256 KiB pool for atomic coherent allocations
    [    0.157177] audit: initializing netlink subsys (disabled)
    [    0.160293] audit: type=2000 audit(0.150:1): state=initialized audit_enabled=0 res=1
    [    0.176241] No ATAGs?
    [    0.176264] hw-breakpoint: found 5 (+1 reserved) breakpoint and 1 watchpoint registers.
    [    0.176284] hw-breakpoint: maximum watchpoint size is 4 bytes.
    [    0.194127] edma 49000000.edma: TI EDMA DMA engine driver
    [    0.195388] reg-fixed-voltage amplifier: Failed to allocate supply name
    [    0.195407] reg-fixed-voltage: probe of amplifier failed with error -12
    [    0.198277] SCSI subsystem initialized
    [    0.198534] usbcore: registered new interface driver usbfs
    [    0.198603] usbcore: registered new interface driver hub
    [    0.198733] usbcore: registered new device driver usb
    [    0.199385] media: Linux media interface: v0.10
    [    0.199432] videodev: Linux video capture interface: v2.00
    [    0.199570] pps_core: LinuxPPS API ver. 1 registered
    [    0.199578] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
    [    0.199601] PTP clock support registered
    [    0.199640] EDAC MC: Ver: 3.0.0
    [    0.200979] omap-mailbox 480c8000.mailbox: omap mailbox rev 0x400
    [    0.201784] Advanced Linux Sound Architecture Driver Initialized.
    [    0.203109] clocksource: Switched to clocksource timer1
    [    0.203981] AppArmor: AppArmor Filesystem Enabled
    [    0.213321] NET: Registered protocol family 2
    [    0.214222] tcp_listen_portaddr_hash hash table entries: 256 (order: 0, 7168 bytes)
    [    0.214275] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
    [    0.214327] TCP bind hash table entries: 4096 (order: 4, 98304 bytes)
    [    0.214614] TCP: Hash tables configured (established 4096 bind 4096)
    [    0.214809] UDP hash table entries: 256 (order: 2, 16384 bytes)
    [    0.214887] UDP-Lite hash table entries: 256 (order: 2, 16384 bytes)
    [    0.215224] NET: Registered protocol family 1
    [    0.215940] RPC: Registered named UNIX socket transport module.
    [    0.215955] RPC: Registered udp transport module.
    [    0.215960] RPC: Registered tcp transport module.
    [    0.215966] RPC: Registered tcp NFSv4.1 backchannel transport module.
    [    0.218317] Initialise system trusted keyrings
    [    0.218699] workingset: timestamp_bits=14 max_order=17 bucket_order=3
    [    0.224730] squashfs: version 4.0 (2009/01/31) Phillip Lougher
    [    0.225610] NFS: Registering the id_resolver key type
    [    0.225660] Key type id_resolver registered
    [    0.225667] Key type id_legacy registered
    [    0.225720] ntfs: driver 2.1.32 [Flags: R/O].
    [    0.637878] NET: Registered protocol family 38
    [    0.637907] Key type asymmetric registered
    [    0.637916] Asymmetric key parser 'x509' registered
    [    0.638011] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
    [    0.638023] io scheduler noop registered
    [    0.638030] io scheduler deadline registered
    [    0.638348] io scheduler cfq registered (default)
    [    0.638362] io scheduler mq-deadline registered
    [    0.638369] io scheduler kyber registered
    [    0.642747] pinctrl-single 44e10800.pinmux: 199 pins, size 796
    [    0.646797] pwm-backlight backlight: backlight supply power not found, using dummy regulator
    [    0.646923] pwm-backlight backlight: Linked as a consumer to
    [    3.604361] scsi 0:0:0:0: Direct-Access     SanDisk  Cruzer Blade     1.00 PQ: 0 ANSI: 6
    [    3.614286] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    3.624588] sd 0:0:0:0: [sda] 30464000 512-byte logical blocks: (15.6 GB/14.5 GiB)
    [    3.625628] sd 0:0:0:0: [sda] Write Protect is off
    [    3.626198] sd 0:0:0:0: [sda] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
    [    3.634240]  sda: sda1 sda2
    [    3.637255] sd 0:0:0:0: [sda] Attached SCSI removable disk
    [    3.657411] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    3.664399] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    3.718801] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
    [    3.726592] VFS: Mounted root (ext4 filesystem) on device 8:2.
    [    3.739926] devtmpfs: mounted
    [    3.743621] Freeing unused kernel memory: 328K
    [    3.748086] This architecture does not have kernel memory protection.
    [    3.754554] Run /sbin/init as init process
     /etc/resolv.conf
    Starting udev
    [    4.633973] udevd[138]: starting version 3.2.7
    [    4.686568] udevd[138]: specified group 'kvm' unknown
    [    4.737627] udevd[139]: starting eudev-3.2.7
    [    4.893444] mstp_cmnet: loading out-of-tree module taints kernel.
    [    4.900017] mstp_cmnet: module verification failed: signature and/or required key missing - tainting kernel
    [    5.013483] Initializing MS/TP network device driver version 1.01-016
    [    5.262312] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    5.271778] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    5.380563] omap_wdt: OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
    [    5.403332] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    5.422558] remoteproc remoteproc0: wkup_m3 is available
    [    5.434385] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    5.434527] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    5.434651] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    5.474231] omap_rtc 44e3e000.rtc: registered as rtc0
    [    5.475054] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    5.475169] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    5.475294] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    5.489359] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    5.489467] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    5.489593] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    5.490504] remoteproc remoteproc0: powering up wkup_m3
    [    5.508133] remoteproc remoteproc0: Booting fw image am335x-pm-firmware.elf, size 243020
    [    5.509009] remoteproc remoteproc0: remote processor wkup_m3 is now up
    [    5.509159] wkup_m3_ipc 44e11324.wkup_m3_ipc: CM3 Firmware Version = 0x192
    [    5.593345] pixcir_ts 1-005c: pixcir_set_power_mode: can't read reg 0x33 : -121
    [    5.593352] pixcir_ts 1-005c: Failed to set IDLE mode
    [    5.593667] pixcir_ts: probe of 1-005c failed with error -121
    [    6.101515] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    6.101645] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    6.101771] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    6.202609] omap-sham 53100000.sham: hw accel on OMAP rev 0.0
    [    6.266389] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    6.266508] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    6.266633] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    6.338256] omap-aes 53501000.aes: OMAP AES hw accel rev: 0.1
    [    6.383298] omap-aes 53501000.aes: will run requests pump with realtime priority
    [    6.471443] omap-des 53701000.des: OMAP DES hw accel rev: 0.33
    [    6.509392] omap-des 53701000.des: will run requests pump with realtime priority
    [    6.532368] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    6.532486] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    6.532614] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    6.539282] [drm] Initialized pvr 1.17.4948957 20110701 for 56000000.sgx on minor 0
    [    6.541322] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    6.541456] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    6.541583] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    6.800350] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    6.800506] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    6.800634] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    6.802546] PM: bootloader does not support rtc-only!
    [    6.803412] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    6.803512] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    6.803625] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    7.003482] net eth0: initializing cpsw version 1.15 (0)
    [    7.104361] TI DP83620 10/100 Mbps PHY 4a101000.mdio:04: attached PHY driver [TI DP83620 10/100 Mbps PHY] (mii_bus:phy_addr=4a101000.mdio:04, irq=POLL)
    [    7.123363] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
    [    7.233461] net eth1: initializing cpsw version 1.15 (0)
    [    7.334477] TI DP83620 10/100 Mbps PHY 4a101000.mdio:02: attached PHY driver [TI DP83620 10/100 Mbps PHY] (mii_bus:phy_addr=4a101000.mdio:02, irq=POLL)
    [    7.336098] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
    [    7.546170] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    7.546310] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    7.546433] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    7.887348] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    7.887483] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    7.887609] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    8.973990] EXT4-fs (mmcblk0p2): recovery complete
    [    8.974016] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
    [    8.992878] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [    9.724613] EXT4-fs (mmcblk0p3): recovery complete
    [    9.724637] EXT4-fs (mmcblk0p3): mounted filesystem with ordered data mode. Opts: (null)
    [    9.957036] EXT4-fs (mmcblk0p4): recovery complete
    [    9.957975] EXT4-fs (mmcblk0p4): mounted filesystem with ordered data mode. Opts: (null)
    [    9.981248] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
    [   10.192981] device eth1 entered promiscuous mode
    [   10.234021] net eth0: promiscuity not disabled as the other interface is still in promiscuity mode
    [   10.234586] device eth0 entered promiscuous mode
    [   10.409212] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [   10.431803] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [   10.492538] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [   12.336842] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [   12.378174] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [   12.405083] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [   12.438170] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [   12.528836] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [   12.583865] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [   12.592002] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [   12.604656] remoteproc remoteproc1: 54434000.pru is available
    [   12.604772] pru-rproc 54434000.pru: PRU rproc node pru@54434000 probed successfully
    [   12.613505] remoteproc remoteproc2: 54438000.pru is available
    [   12.613612] pru-rproc 54438000.pru: PRU rproc node pru@54438000 probed successfully
    [   12.614804] remoteproc remoteproc3: 54474000.pru is available
    [   12.614907] pru-rproc 54474000.pru: PRU rproc node pru@54474000 probed successfully
    [   12.616008] remoteproc remoteproc4: 54478000.pru is available
    [   12.616108] pru-rproc 54478000.pru: PRU rproc node pru@54478000 probed successfully
    [   12.695825] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [   12.702788] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [   12.710893] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [   12.720368] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [   12.727330] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [   12.819160] usbcore: registered new interface driver cdc_ether
    /etc/rcS.d/S05oneStartScript.sh: line 84: printf: c7: invalid number
    /etc/rcS.d/S05oneStartScript.sh: line 85: printf: b0: invalid number
    pim6dd: 00:00:13.094 warning - Got 1048576 byte buffer size in 0 iterations
    pim6dd: 00:00:13.094 warning - setsockopt(IPV6_ROUTER_ALERT): Protocol not available
    pim6dd: 00:00:13.095 warning - Got 1048576 byte buffer size in 0 iterations
    [   13.359223] Bluetooth: Core ver 2.22
    [   13.364673] NET: Registered protocol family 31
    [   13.369155] Bluetooth: HCI device and connection manager initialized
    [   13.375584] Bluetooth: HCI socket layer initialized
    [   13.380492] Bluetooth: L2CAP socket layer initialized
    [   13.385667] Bluetooth: SCO socket layer initialized
    [   13.410464] Bluetooth: RFCOMM TTY layer initialized
    [   13.415610] Bluetooth: RFCOMM socket layer initialized
    [   13.420817] Bluetooth: RFCOMM ver 1.11
    OK
    [   14.079162] EXT4-fs (sda2): re-mounted. Opts: (null)
    Thu Apr 29 19:10:25 UTC 2021
    OK
    [   17.668117] device lo entered promiscuous mode
    [   17.986749] PVR_K: UM DDK-(4948957) and KM DDK-(4948957) match. [ OK ]
    done.
    apmd[973]: apmd 3.2.1 interfacing with apm driver 1.13 and APM BIOS 1.2
    Starting HOSTAP Daemon: [   20.624787] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
    [   20.639116] Bluetooth: BNEP filters: protocol multicast
    [   20.646241] Bluetooth: BNEP socket layer initialized
    [   20.832970] cfg80211: Loading compiled-in X.509 certificates for regulatory database
    [   21.450963] cfg80211: Loaded X.509 cert 'sforshee: 00b28ddf47aef9cea7'
    [   21.457780] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
    [   21.474632] cfg80211: failed to load regulatory.db
    wlan0: AP-DISABLED
    Starting ntpd: done
    Starting crond: OK
    [   33.763152] vmmcwl_fixed: disabling
    FSP Distro 2.7.4 Node0cb2b7c5c7b0 ttyS0
    Node0cb2b7c5c7b0 login:
              Interrupt:50
    NIC statistics:
         Good Rx Frames: 0
         Broadcast Rx Frames: 0
         Multicast Rx Frames: 0
         Pause Rx Frames: 0
         Rx CRC Errors: 0
         Rx Jabbers: 0
         Rx Fragments: 0
         Rx Octets: 0
         Good Tx Frames: 0
         Pause Tx Frames: 0
         Collisions: 0
         Late Collisions: 0
         Tx Underrun: 0
         Tx Octets: 0
         Rx + Tx 64 Octet Frames: 0
         Rx + Tx 65-127 Octet Frames: 0
         Rx + Tx 128-255 Octet Frames: 0
         Rx + Tx 512-1023 Octet Frames: 0
         Net Octets: 0
         Rx DMA Overruns: 0
         Rx DMA chan 0: tail_enqueue: 127
         Rx DMA chan 0: busy_dequeue: 0
         Rx DMA chan 0: good_dequeue: 0
         Tx DMA chan 0: head_enqueue: 0
         Tx DMA chan 0: empty_dequeue: 0
         Tx DMA chan 0: good_dequeue: 0
    root@Node0cb2b7c5c7b0:~# ethtool -S eth0 g
    Pre-set maximums:
    RX:		248
    RX Mini:	0
    RX Jumbo:	0
    TX:		248
    RX:		128
    RX Mini:	0
    RX Jumbo:	0
    TX:		128
    [    0.000000] Booting Linux on physical CPU 0x0
    [    0.000000] CPU: ARMv7 Processor [412fc09a] revision 10 (ARMv7), cr=10c53c7d
    [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
    [    0.000000] Memory policy: Data cache writeback
    [    0.000000] efi: Getting EFI parameters from FDT:
    [    0.000000] cma: Reserved 48 MiB at 0x9d000000
    [    0.000000] On node 0 totalpages: 131072
    [    0.000000]   Normal zone: 1152 pages used for memmap
    [    0.000000]   Normal zone: 0 pages reserved
    [    0.000000]   Normal zone: 131072 pages, LIFO batch:31
    [    0.000000] CPU: All CPU(s) started in SVC mode.
    [    0.000000] AM437x ES1.2 (sgx neon)
    [    0.000000] random: get_random_bytes called from start_kernel+0x88/0x44c with crng_init=0
    [    0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=1*32768
    [    0.000000] pcpu-alloc: [0] 0
    [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 129920
    [    0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
    [    0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
    [    0.000000] Virtual kernel memory layout:
                       vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                       fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                       vmalloc : 0xe0800000 - 0xff800000   ( 496 MB)
                       lowmem  : 0xc0000000 - 0xe0000000   ( 512 MB)
                       pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
                       modules : 0xbf000000 - 0xbfe00000   (  14 MB)
                         .init : 0x(ptrval) - 0x(ptrval)   ( 328 kB)
                         .data : 0x(ptrval) - 0x(ptrval)   ( 386 kB)
                          .bss : 0x(ptrval) - 0x(ptrval)   ( 294 kB)
    [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
    [    0.000000] rcu: Preemptible hierarchical RCU implementation.
    [    0.000000] rcu: 	RCU priority boosting: priority 1 delay 500 ms.
    [    0.000000] 	No expedited grace period (rcu_normal_after_boot).
    [    0.000000] 	Tasks RCU enabled.
    [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
    [    0.000000] L2C: platform modifies aux control register: 0x0e030000 -> 0x3e430000
    [    0.000000] L2C: DT/platform modifies aux control register: 0x0e030000 -> 0x3e430000
    [    0.000000] L2C-310 enabling early BRESP for Cortex-A9
    [    0.000000] OMAP L2C310: ROM does not support power control setting
    [    0.000000] L2C-310 dynamic clock gating disabled, standby mode disabled
    [    0.000000] L2C-310 cache controller enabled, 16 ways, 256 kB
    [    0.000000] L2C-310: CACHE_ID 0x410000c9, AUX_CTRL 0x4e430000
    [    0.000000] OMAP clockevent source: timer2 at 24000000 Hz
    [    0.194875] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/fixedregulator-v3_3d[0]'
    [    0.195377] of_get_named_gpiod_flags: can't parse 'gpio' property of node '/amplifier[0]'
    [    0.215981] PCI: CLS 0 bytes, default 64
    [    0.646714] pwm-backlight backlight: GPIO lookup for consumer enable
    [    0.646725] pwm-backlight backlight: using device tree for GPIO lookup
    [    0.646748] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/backlight[0]'
    [    0.646759] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/backlight[0]'
    [    0.646768] pwm-backlight backlight: using lookup tables for GPIO lookup
    [    0.646776] pwm-backlight backlight: No GPIO consumer enable found
    [    0.646923] pwm-backlight backlight: Linked as a consumer to regulator.0
    [    0.701654] Serial: 8250/16550 driver, 10 ports, IRQ sharing enabled
    [    0.705409] omap8250 44e09000.serial: No clock speed specified: using default: 48000000
    [    0.706286] 44e09000.serial: ttyS0 at MMIO 0x44e09000 (irq = 31, base_baud = 3000000) is a 8250
    [    1.446253] console [ttyS0] enabled
    [    1.450476] omap8250 48022000.serial: No clock speed specified: using default: 48000000
    [    1.459311] 48022000.serial: ttyS1 at MMIO 0x48022000 (irq = 32, base_baud = 3000000) is a 8250
    [    1.469387] 48024000.serial: ttyS2 at MMIO 0x48024000 (irq = 33, base_baud = 3000000) is a 8250
    [    1.478826] omap8250 481a6000.serial: No clock speed specified: using default: 48000000
    [    1.487662] 481a6000.serial: ttyS3 at MMIO 0x481a6000 (irq = 34, base_baud = 3000000) is a 8250
    [    1.499188] omap_rng 48310000.rng: Random Number Generator ver. 20
    [    1.503340] random: fast init done
    [    1.503595] random: crng init done
    [    1.514663] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    1.524049] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    1.530998] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    1.554134] brd: module loaded
    [    1.568922] loop: module loaded
    [    1.576167] mdio_bus fixed-0: GPIO lookup for consumer reset
    [    1.576179] mdio_bus fixed-0: using lookup tables for GPIO lookup
    [    1.576187] mdio_bus fixed-0: No GPIO consumer reset found
    [    1.576214] libphy: Fixed MDIO Bus: probed
    [    1.581331] CAN device driver interface
    [    1.586484] c_can_platform 481cc000.can: c_can_platform device registered (regs=a20c9269, irq=65)
    [    1.596297] c_can_platform 481d0000.can: c_can_platform device registered (regs=b5b60b8c, irq=66)
    [    1.620589] mdio_bus 4a101000.mdio: GPIO lookup for consumer reset
    [    1.620599] mdio_bus 4a101000.mdio: using device tree for GPIO lookup
    [    1.620620] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/ethernet@4a100000/mdio@4a101000[0]'
    [    1.620633] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/ethernet@4a100000/mdio@4a101000[0]'
    [    1.620640] mdio_bus 4a101000.mdio: using lookup tables for GPIO lookup
    [    1.620647] mdio_bus 4a101000.mdio: No GPIO consumer reset found
    [    1.673199] davinci_mdio 4a101000.mdio: davinci mdio revision 1.6, bus freq 1000000
    [    1.680909] libphy: 4a101000.mdio: probed
    [    1.685904] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/ethernet@4a100000/mdio@4a101000/ethernet-phy@4[0]'
    [    1.686954] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/ethernet@4a100000/mdio@4a101000/ethernet-phy@2[0]'
    [    1.687141] davinci_mdio 4a101000.mdio: phy[2]: device 4a101000.mdio:02, driver TI DP83620 10/100 Mbps PHY
    [    1.696858] davinci_mdio 4a101000.mdio: phy[4]: device 4a101000.mdio:04, driver TI DP83620 10/100 Mbps PHY
    [    1.707466] cpsw 4a100000.ethernet: Detected MACID = 0c:b2:b7:c5:c7:b0
    [    1.714208] cpsw 4a100000.ethernet: initialized cpsw ale version 1.4
    [    1.720595] cpsw 4a100000.ethernet: ALE Table size 1024
    [    1.725911] cpsw 4a100000.ethernet: cpts: overflow check period 500 (jiffies)
    [    1.734076] cpsw 4a100000.ethernet: cpsw: Detected MACID = 0c:b2:b7:c5:c7:b0
    [    1.744704] dwc3 48390000.usb: Failed to get clk 'ref': -2
    [    1.750707] OF: graph: no port node found in /ocp@44000000/ocp2scp@483a8000/phy@483a8000
    [    1.762136] dwc3 483d0000.usb: Failed to get clk 'ref': -2
    [    1.769726] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
    [    1.776303] ehci-pci: EHCI PCI platform driver
    [    1.780837] ehci-platform: EHCI generic platform driver
    [    1.786398] ehci-omap: OMAP-EHCI Host Controller driver
    [    1.791786] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
    [    1.798033] ohci-pci: OHCI PCI platform driver
    [    1.803287] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.808865] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
    [    1.817052] xhci-hcd xhci-hcd.0.auto: hcc params 0x0238f06d hci version 0x100 quirks 0x0000000002010010
    [    1.826763] xhci-hcd xhci-hcd.0.auto: irq 101, io mem 0x483d0000
    [    1.833348] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 4.19
    [    1.841660] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.848917] usb usb1: Product: xHCI Host Controller
    [    1.853817] usb usb1: Manufacturer: Linux 4.19.160-rt69-gb3a2247aae xhci-hcd
    [    1.860895] usb usb1: SerialNumber: xhci-hcd.0.auto
    [    1.866520] hub 1-0:1.0: USB hub found
    [    1.870341] hub 1-0:1.0: 1 port detected
    [    1.874749] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
    [    1.880279] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
    [    1.888024] xhci-hcd xhci-hcd.0.auto: Host supports USB 3.0 SuperSpeed
    [    1.894688] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
    [    1.902972] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 4.19
    [    1.911278] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
    [    1.918535] usb usb2: Product: xHCI Host Controller
    [    1.923434] usb usb2: Manufacturer: Linux 4.19.160-rt69-gb3a2247aae xhci-hcd
    [    1.930513] usb usb2: SerialNumber: xhci-hcd.0.auto
    [    1.936044] hub 2-0:1.0: USB hub found
    [    1.939862] hub 2-0:1.0: 1 port detected
    [    1.944617] usbcore: registered new interface driver cdc_acm
    [    1.950309] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
    [    1.958457] usbcore: registered new interface driver usblp
    [    1.964308] usbcore: registered new interface driver uas
    [    1.969767] usbcore: registered new interface driver usb-storage
    [    1.977038] printer gadget: printer ready
    [    1.981949] i2c /dev entries driver
    [    1.987176] gpio-wdt watchdog: GPIO lookup for consumer (null)
    [    1.987185] gpio-wdt watchdog: using device tree for GPIO lookup
    [    1.987214] gpio-wdt watchdog: No GPIO consumer (null) found
    [    1.987617] sdhci: Secure Digital Host Controller Interface driver
    [    1.993838] sdhci: Copyright(c) Pierre Ossman
    [    1.999017] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer cd
    [    1.999025] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
    [    1.999048] of_get_named_gpiod_flags: can't parse 'cd-gpios' property of node '/ocp@44000000/mmc@481d8000[0]'
    [    1.999059] of_get_named_gpiod_flags: can't parse 'cd-gpio' property of node '/ocp@44000000/mmc@481d8000[0]'
    [    1.999067] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup
    [    1.999074] omap_hsmmc 481d8000.mmc: No GPIO consumer cd found
    [    1.999082] omap_hsmmc 481d8000.mmc: GPIO lookup for consumer wp
    [    1.999087] omap_hsmmc 481d8000.mmc: using device tree for GPIO lookup
    [    1.999098] of_get_named_gpiod_flags: can't parse 'wp-gpios' property of node '/ocp@44000000/mmc@481d8000[0]'
    [    1.999108] of_get_named_gpiod_flags: can't parse 'wp-gpio' property of node '/ocp@44000000/mmc@481d8000[0]'
    [    1.999113] omap_hsmmc 481d8000.mmc: using lookup tables for GPIO lookup
    [    1.999118] omap_hsmmc 481d8000.mmc: No GPIO consumer wp found
    [    1.999754] omap_hsmmc 481d8000.mmc: Linked as a consumer to regulator.1
    [    2.032365] sdhci-pltfm: SDHCI platform and OF driver helper
    [    2.046743] NET: Registered protocol family 10
    [    2.052993] Segment Routing with IPv6
    [    2.057070] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
    [    2.064150] NET: Registered protocol family 17
    [    2.068648] can: controller area network core (rev 20170425 abi 9)
    [    2.075017] NET: Registered protocol family 29
    [    2.079893] Key type dns_resolver registered
    [    2.084516] omap_voltage_late_init: Voltage driver support not added
    [    2.088154] mmc0: new high speed MMC card at address 0001
    [    2.094042] mmcblk0: mmc0:0001 IS008G 7.28 GiB
    [    2.094883] mmcblk0boot0: mmc0:0001 IS008G partition 1 4.00 MiB
    [    2.095693] mmcblk0boot1: mmc0:0001 IS008G partition 2 4.00 MiB
    [    2.096019] mmcblk0rpmb: mmc0:0001 IS008G partition 3 4.00 MiB, chardev (242:0)
    [    2.098023]  mmcblk0: p1 p2 p3 p4
    [    2.132380] Loading compiled-in X.509 certificates
    [    2.138316] alg: No test for pkcs1pad(rsa,sha1) (pkcs1pad(rsa-generic,sha1))
    [    2.153389] Loaded X.509 cert 'Build time autogenerated kernel key: 87120a1d9d5365c3e37e8d0fabb9a6d0ec90a957'
    [    2.164380] AppArmor: AppArmor sha1 policy hashing enabled
    [    2.187265] gpio gpiochip0: (gpio-0-31): added GPIO chardev (254:0)
    [    2.187370] gpiochip_setup_dev: registered GPIOs 0 to 31 on device: gpiochip0 (gpio-0-31)
    [    2.187667] OMAP GPIO hardware version 0.1
    [    2.192519] gpio gpiochip1: (gpio-32-63): added GPIO chardev (254:1)
    [    2.192610] gpiochip_setup_dev: registered GPIOs 32 to 63 on device: gpiochip1 (gpio-32-63)
    [    2.193823] gpio gpiochip2: (gpio-64-95): added GPIO chardev (254:2)
    [    2.193922] gpiochip_setup_dev: registered GPIOs 64 to 95 on device: gpiochip2 (gpio-64-95)
    [    2.194910] gpio gpiochip3: (gpio-96-127): added GPIO chardev (254:3)
    [    2.195023] gpiochip_setup_dev: registered GPIOs 96 to 127 on device: gpiochip3 (gpio-96-127)
    [    2.196019] gpio gpiochip4: (gpio-128-159): added GPIO chardev (254:4)
    [    2.196113] gpiochip_setup_dev: registered GPIOs 128 to 159 on device: gpiochip4 (gpio-128-159)
    [    2.197058] gpio gpiochip5: (gpio-160-191): added GPIO chardev (254:5)
    [    2.197147] gpiochip_setup_dev: registered GPIOs 160 to 191 on device: gpiochip5 (gpio-160-191)
    [    2.197604] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-vtt[0]' - status (0)
    [    2.198025] of_get_named_gpiod_flags: parsed 'gpio' property of node '/fixedregulator-mmcwl[0]' - status (0)
    [    2.333151] usb 1-1: new high-speed USB device number 2 using xhci-hcd
    [    2.514117] usb 1-1: New USB device found, idVendor=0781, idProduct=5567, bcdDevice= 1.00
    [    2.522340] usb 1-1: New USB device strings: Mfr=1, Product=2, SerialNumber=3
    [    2.529513] usb 1-1: Product: Cruzer Blade
    [    2.533630] usb 1-1: Manufacturer: SanDisk
    [    2.537745] usb 1-1: SerialNumber: 4C530001300313116280
    [    2.544963] usb-storage 1-1:1.0: USB Mass Storage device detected
    [    2.551722] scsi host0: usb-storage 1-1:1.0
    [    3.213130] omap_i2c 44e0b000.i2c: timeout waiting for bus ready
    [    3.219193] tps65218 0-0024: Failed to set masks in 0x3: -16
    [    3.225047] tps65218: probe of 0-0024 failed with error -16
    [    3.230803] omap_i2c 44e0b000.i2c: bus 0 rev0.12 at 400 kHz
    [    3.238246] omap_i2c 4802a000.i2c: bus 1 rev0.12 at 400 kHz
    [    3.244544] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    3.253949] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    3.260891] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    3.268255] gpio-wdt watchdog: GPIO lookup for consumer (null)
    [    3.268264] gpio-wdt watchdog: using device tree for GPIO lookup
    [    3.268308] of_get_named_gpiod_flags: parsed 'gpios' property of node '/watchdog[0]' - status (0)
    [    3.268383] gpio gpiochip2: Persistence not supported for GPIO 3
    [    3.268425] gpio-wdt: probe of watchdog failed with error -22
    [    3.274791] omapdss_dss 4832a000.dss: 4832a000.dss supply vdda_video not found, using dummy regulator
    [    3.284187] omapdss_dss 4832a000.dss: Linked as a consumer to regulator.0
    [    3.291120] omapdss_dss 4832a000.dss: Dropping the link to regulator.0
    [    3.298766] hctosys: unable to open rtc device (rtc0)
    [    3.304853] ALSA device list:
    [    3.307849]   No soundcards found.
    [    3.312584] Waiting for root device /dev/sda2...
    [    3.625637] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00
    [    5.474207] omap_rtc 44e3e000.rtc: char device (253:0)
    [    5.563891] pixcir_ts 1-005c: GPIO lookup for consumer attb
    [    5.563899] pixcir_ts 1-005c: using device tree for GPIO lookup
    [    5.563933] of_get_named_gpiod_flags: can't parse 'attb-gpios' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
    [    5.563965] of_get_named_gpiod_flags: parsed 'attb-gpio' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]' - status (0)
    [    5.563986] gpio gpiochip1: Persistence not supported for GPIO 3
    [    5.563994] pixcir_ts 1-005c: GPIO lookup for consumer reset
    [    5.563998] pixcir_ts 1-005c: using device tree for GPIO lookup
    [    5.564010] of_get_named_gpiod_flags: can't parse 'reset-gpios' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
    [    5.564022] of_get_named_gpiod_flags: can't parse 'reset-gpio' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
    [    5.564029] pixcir_ts 1-005c: using lookup tables for GPIO lookup
    [    5.564036] pixcir_ts 1-005c: No GPIO consumer reset found
    [    5.564043] pixcir_ts 1-005c: GPIO lookup for consumer wake
    [    5.564046] pixcir_ts 1-005c: using device tree for GPIO lookup
    [    5.564058] of_get_named_gpiod_flags: can't parse 'wake-gpios' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
    [    5.564069] of_get_named_gpiod_flags: can't parse 'wake-gpio' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
    [    5.564074] pixcir_ts 1-005c: using lookup tables for GPIO lookup
    [    5.564078] pixcir_ts 1-005c: No GPIO consumer wake found
    [    5.564083] pixcir_ts 1-005c: GPIO lookup for consumer enable
    [    5.564087] pixcir_ts 1-005c: using device tree for GPIO lookup
    [    5.564098] of_get_named_gpiod_flags: can't parse 'enable-gpios' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
    [    5.564108] of_get_named_gpiod_flags: can't parse 'enable-gpio' property of node '/ocp@44000000/i2c@4802a000/pixcir_ts@5c[0]'
    [    5.564112] pixcir_ts 1-005c: using lookup tables for GPIO lookup
    [    5.564116] pixcir_ts 1-005c: No GPIO consumer enable found
    [  216.273752] gpio gpiochip1: Persistence not supported for GPIO 2
  • From the above ifconfig the MACID are same for both the interfaces.
  • Hi Brad,
    The New thing we tried is tried to disable the eth1 from the DTS file.
    The Crash is not seen,but the ping does not happen.
    Please find the logs attached for this scenario.Ethernet-issue.zip
    Thank you for collection of data regarding the issue you have.  The tcpdump at the end of the third log file is the most the interesting. The log shows the ARP-Request arriving from the ping source and then it shows the ARP-Reply.  The last step is to make sure the ARP-Reply is received by the device sending it. I would recommend either tcpdump on the sender or better wireshark if you have that installed.
    Since you are getting a NETDEV Watchdog warning would seem to indicate that the packets are remaining queued and never being sent. To verify that your board is able to send packets I would try a ping from your custom board using wireshark using a direct connection with your board and using the static IPs like you are using.
    Schuyler
  • Ethernet-logs.zipHi Schuyler,
    On the PC (windows) connected  to the target there is no packet seen on the wireshark, it was just blank.
    I have the ethtool datat  and the kernel trace while ping is running on the Target and the PC.
  • 8231.Ethernet-logs.zipHi Schuyler,
    Here is a link to a similar issue:
    e2e.ti.com/.../dp83826i-imx8qxp-linux-5-4-no-tx-and-rx-packets
    I reviewed the pin mux and if it matches the first post it looks like the tx_clk pin direction is reversed what is needed. Please try matching this line pin direction
    AM4372_IOPAD(0x92c, PIN_INPUT | MUX_MODE0) /* (D14) mii1_tx_clk.gmii1_txclk */
    In MII the PHY sources both tx and rx clks to the MAC interface.
    Schuyler
  • Hi Schuyler and Brad,
    Thanks for the timely inputs.
    These recommendations worked for us.
    We are able to ping on both the eth0 and eth1 interfaces, as TX is operational.
