Part Number: TDA4VM
If you want to run the EB Tresos Configurator for TDA4VM MCAL, a customer license is required. How can I obtain this?
Part Number: TDA4VM
In order to obtain a license, please request it from mcusw_eb_tresos_license_request@list.ti.com.
The following example template can be used to provide the necessary information to a TI engineer for a new license:
| Name (First and Last) | Company Name | |
You will receive an Activation Key to activate your EB Tresos license. Use this to activate in the Tresos License Manager, input it under "Activation Code":
Then, it is very important that you reply to the same email where you received the activation key with the Fulfillment ID.
Finally, you should be enabled to use EB Tresos Configurator. Please email the same list with any questions regarding this.
