Part Number: TDA4VM
Please provide instructions for building and booting for HS devices on Linux SDK.
wget https://software-dl.ti.com/jacinto7/esd/processor-sdk-linux-jacinto7/08_00_00_08/exports/ti-processor-sdk-linux-j7-evm-08_00_00_08-Linux-x86-Install.bin chmod+x ti-processor-sdk-linux-j7-evm-08_00_00_08-Linux-x86-Install.bin ./ti-processor-sdk-linux-j7-evm-08_00_00_08-Linux-x86-Install.bin
From here on the installation directory will be referred to as $PSDKLA
cd $PSDKLA
Open the file: Rules.make & Change the below variables:
From PLATFORM=j7-evm to PLATFORM=j7-hs-evm
From UBOOT_MACHINE=j721e_evm_a72_defconfig to UBOOT_MACHINE=j721e_hs_evm_a72_defconfig
From UBOOT_MACHINE_R5=j721e_evm_r5_defconfig to UBOOT_MACHINE=j721e_hs_evm_r5_defconfig
Building the u-boot using the below command (this is the same as GP device building):
make u-boot
Output: The above command will generate 3 binaries:
$PSDKLA/board-support/u-boot_build/a72/u-boot.img_HS
$PSDKLA/board-support/u-boot_build/a72/tispl.bin_HS
$PSDKLA/board-support/u-boot_build/r5/tiboot3.bin
cd $PSDKLA make sysfw-image_clean make sysfw-image HS=1 ENABLE_TRACE=1
HS=1 specifies that build is for HS Devices
ENABLE_TRACE=1 enables debug traces that will be useful for any DMSC related debug
Output:
The above command generates the binary:
$PSDKLA/board-support/k3-image-gen-2021.05/sysfw.itb
cp $PSDKLA/board-support/u-boot_build/a72/u-boot.img_HS /media/$USER/boot/u-boot.img cp $PSDKLA/board-support/u-boot_build/a72/tispl.bin_HS /media/$USER/boot/tispl.bin cp $PSDKLA/board-support/u-boot_build/r5/tiboot3.bin /media/$USER/boot/tiboot3.bin cp $PSDKLA/board-support/k3-image-gen-2021.05/sysfw.itb /media/$USER/boot/sysfw.itb
DIP Switch settings for SD boot
SW8: 10000010
SW9: 00000000
Power on the EVM & connect the MAIN_UART micro USB port. You should see the traces on the first instance.
By default the u-boot j721e_hs_evm_a72_defconfig does not support the eMMC. We need to enable eMMC support in the j721e_hs_evm_a72_defconfig.
Apply the below patch:
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/2625.0001_2D00_configs_2D00_j721e_5F00_hs_5F00_evm_5F00_a72_5F00_defconfig_2D00_Enable_2D00_eMMC_2D00_booti.patch
cd $PSDKLA/board-support/u-boot-2021.01+gitAUTOINC+53e79d0e89-g53e79d0e89/ git am 0001-configs-j721e_hs_evm_a72_defconfig-Enable-eMMC-booti.patch cd ../.. make u-boot #Copy binaries to SD card cp $PSDKLA/board-support/u-boot_build/a72/u-boot.img_HS /media/$USER/boot/u-boot.img cp $PSDKLA/board-support/u-boot_build/a72/tispl.bin_HS /media/$USER/boot/tispl.bin cp $PSDKLA/board-support/u-boot_build/r5/tiboot3.bin /media/$USER/boot/tiboot3.bin cp $PSDKLA/board-support/k3-image-gen-2021.05/sysfw.itb /media/$USER/boot/sysfw.itb
mmc dev 0 1
fatload mmc 1 ${loadaddr} tiboot3.bin
mmc write ${loadaddr} 0x0 0x400
fatload mmc 1 ${loadaddr} tispl.bin
mmc write ${loadaddr} 0x400 0x1000
fatload mmc 1 ${loadaddr} u-boot.img
mmc write ${loadaddr} 0x1400 0x2000
fatload mmc 1 ${loadaddr} sysfw.itb
mmc write ${loadaddr} 0x3600 0x800
mmc partconf 0 1 1 1
mmc bootbus 0 2 0 0
#Power OFF the board
Change the dip switch settings for eMMC boot
SW8: 10000000
SW9: 01000000
Copy below binaries to home directory of your Linux machine:
cp $PSDKLA/board-support/u-boot_build/a72/u-boot.img_HS ~/u-boot.img cp $PSDKLA/board-support/u-boot_build/a72/tispl.bin_HS ~/tispl.bin cp $PSDKLA/board-support/u-boot_build/r5/tiboot3.bin ~/tiboot3.bin cp $PSDKLA/board-support/k3-image-gen-2021.05/sysfw.itb ~/sysfw.itb
Follow the FAQ: https://e2e.ti.com/support/processors/f/791/t/1003471
SW8: 00000000
SW9: 01110000
8.0 SDK OSPI boot is broken on HS devices. We need to apply the below patch to get OSPI boot functional.
https://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/8345.0001_2D00_ARM_2D00_mach_2D00_k3_2D00_sysfw_2D00_loader_2D00_Copy_2D00_sysfw.itb_2D00_to_2D00_OCRAM_2D00_in_2D00_.patch
cd $PSDKLA/board-support/u-boot-2021.01+gitAUTOINC+53e79d0e89-g53e79d0e89/ git am 0001-ARM-mach-k3-sysfw-loader-Copy-sysfw.itb-to-OCRAM-in-.patch cd ../.. make u-boot cp $PSDKLA/board-support/u-boot_build/a72/u-boot.img_HS /media/$USER/boot/u-boot.img cp $PSDKLA/board-support/u-boot_build/a72/tispl.bin_HS /media/$USER/boot/tispl.bin cp $PSDKLA/board-support/u-boot_build/r5/tiboot3.bin /media/$USER/boot/tiboot3.bin cp $PSDKLA/board-support/k3-image-gen-2021.05/sysfw.itb /media/$USER/boot/sysfw.itb
Boot using SD card & halt at U-Boot prompt.
Execute the following commands - this will burn the boot images from MMC-SD to OSPI
sf probe
sf erase 0x0 0x4000000
sf probe
sf update $loadaddr 0x0 $filesize
sf update $loadaddr 0x80000 $filesize
sf update $loadaddr 0x280000 $filesize
sf update $loadaddr 0x6C0000 $filesize
Change the dip switch settings for OSPI boot.
SW8: 00000000
SW9: 01000000
