[FAQ] TMS320C6678: How to build and run the platform test on C6678 EVM ?
Part Number: TMS320C6678
  • How to build and run the platform test on C6678EVM ?
    Pre-requisite :
    1. Download and install "PROCESSOR-SDK-RTOS-C667x  06_03_00_106"
    from https://software-dl.ti.com/processor-sdk-rtos/esd/C667x/latest/index_FDS.html
    ( Please install the SDK in the recommended path: C:\ti\)
    2. Download and install CCS 9.3 , https://www.ti.com/tool/download/CCSTUDIO/9.3.0.00012
    ( Please install in the recommended path: C:\ti\)
    Step1: Check the Platform-test source code after installation
    a) Platform-test source code will become available once the "processor_sdk_rtos_c667x_6_03_00_106" package (above-step) is installed.
    b) "Platform-Lib" is a dependency for Platform-test.
    c) The location of source code of Platform-test and platform-lib is at
    C:\ti\pdk_c667x_2_0_16\packages\ti\platform\evmc6678l\platform_test\src
    C:\ti\pdk_c667x_2_0_16\packages\ti\platform\evmc6678l\platform_lib\src
    Step 2: Import the "Platform test example" into CCS 9.3 and re-build
    Please follow the video attached and do the steps given below for ease of use.
    a) Import the "Platform-Lib" CCS project located at "C:\ti\pdk_c667x_2_0_16\packages\ti\platform\evmc6678l\platform_lib" into CCS and rebuild
    b) Import the "Platform-Lib" CCS project located at "C:\ti\pdk_c667x_2_0_16\packages\ti\platform\evmc6678l\platform_test" into CCS and rebuild
    Step 3: Run the "Platform test " on the C6678 EVM
    1. Open CCS
    2. Launch the target configuration file for C6678 EVM. ( If new to this, Follow this FAQ
    e2e.ti.com/.../faq-tms320c6678-how-to-create-target-configuration-and-do-test-connection-on-c6678-evm
    3. Do "Connect target and run gel file " ( If new to this, Follow this FAQ :
     https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1062598/faq-tms320c6678-how-to-load-and-run-the-gel-file-on-c6678-evm
    4.  Load the platform_test_evmc6678l.out into core0 of C6678.
    5. Run and observe the output messages, as per the video below.
    Shankari G
