Part Number: TMS320C6657
How to wake the second core by the first core in C6657 ? What is Boot-magic Address / Jump boot address ?
Answer:
The aim of the following source code , is to make jump the second core to the program-code-address where the first core points to ......
The first core can write the "program address" into the Boot magic address of the second core and signal / wake up the second core using the IPCGR register.
Once the second core is awake, it jumps to the address ( This address was written by the first core ) and start executing the program from that address.
Please note that the Boot magic addresses are different for C6657 and C6678. If it is for C6657, you can directly use the code.
If it is for C6678, Please change the address of the Boot magic according to the data sheet manual.
(For boot magic address of other devices like K2E,K2H, please see the note, at the bottom)
Steps:
1. First launch the target configuration file of C6657 EVM
--- > You will see core 0 and core 1
2. Right click on core 0 and do connect target.
3. Right click on core 1 and do connect target.
4. Click core 0 and load the ".out"
5. Use "F6" and reach upto the code after the comment /* End code for the second core to jump-boot-address and execute */
Open the Memory browser window and feed the address, "0x118ffffc" and enter, you will see, the value,"0x0C0431E4" written by the first core.
0x0C0431E4 - - > This is the address of the function write_boot_magic_number()
Output log:
[C66xx_0] I am popping out from FIRST core. BOOT Magic Address of second Core is : 118ffffc
6. Important step -- Click core 1 and load symbols --- > select the ".out" to load just the symbols... and not the entire code...
7. Hit Run
8. Open the Memory browser window and feed the address, "0x118ffffc" and enter --> you will see, the new value,"0xBABEFACE" written by the second core.
Output log:
[C66xx_1] Hi, Inside write_boot_magic_number, I am popping out from second core
* Copyright (c) 2011-2012 Texas Instruments Incorporated - http://www.ti.com
* Redistribution and use in source and binary forms, with or without
* modification, are permitted provided that the following conditions
* are met:
* Redistributions of source code must retain the above copyright
* notice, this list of conditions and the following disclaimer.
* Redistributions in binary form must reproduce the above copyright
* notice, this list of conditions and the following disclaimer in the
* documentation and/or other materials provided with the
* distribution.
* Neither the name of Texas Instruments Incorporated nor the names of
* its contributors may be used to endorse or promote products derived
* from this software without specific prior written permission.
* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
* A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
* OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
* SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
* LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
* DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
* THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
* (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
* OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
#include <cerrno>
#include <errno.h>
#include <stdio.h>
#include <stdlib.h>
#include <string.h>
#include "platform.h"
#include "resource_mgr.h"
The inputs to the test application can be controlled
by the following file. User need to create this file in
pdk_#_##_##_##\packages\ti\platform\lib\platform_utils_test\bin
directory.
The syntax to the input file is as follows
<input string> = <value 1 => enable, 0 => disable
char input_file_name[] = "../testconfig/platform_test_input.txt";
#define MAX_LINE_LENGTH 40
/* The input strings for the input config file is given below */
/* Input flags */
#define INIT_PLL1 "init_pll"
#define INIT_DDR3 "init_ddr"
#define INIT_UART "init_uart"
#define INIT_TCSL "init_tcsl"
#define INIT_PHY "init_phy"
#define INIT_ECC "init_ecc"
#define PRINT_INFO "print_info"
#define PRINT_CURRENT_CORE_ID "print_current_core_id"
#define PRINT_SWITCH_STATE "print_switch_state"
#define TEST_EEPROM "test_eeprom"
#define TEST_NAND "test_nand"
#define TEST_NOR "test_nor"
#define TEST_LED "test_led"
#define TEST_UART "test_uart"
#define TEST_EXT_MEM "run_external_memory_test"
#define TEST_INT_MEM "run_internal_memory_test"
/* Input parameters */
#define INIT_CONFIG_PLL1_PLLM "init_config_pll1_pllm"
#define INIT_CONFIG_UART_BAUDRATE "init_config_uart_baudrate"
#define NAND_TEST_BLOCK_NUMBER "nand_test_block_number"
#define EEPROM_TEST_SLAVE_ADDRESS "eeprom_test_slave_address"
#define LED_TEST_LOOP_COUNT "led_test_loop_count"
#define LED_TEST_LOOP_DELAY "led_test_loop_delay"
#define EXT_MEM_TEST_BASE_ADDR "ext_mem_test_base_addr"
#define EXT_MEM_TEST_LENGTH "ext_mem_test_length"
#define INT_MEM_TEST_CORE_ID "int_mem_test_core_id"
/* The default values for the input strings are given below */
#define DEF_INIT_CONFIG_PLL1_PLLM 0
#define DEF_INIT_CONFIG_UART_BAUDRATE 0
#define DEF_NAND_TEST_BLOCK_NUMBER 512
#define DEF_NOR_TEST_SECTOR_NUMBER 10
#define DEF_EEPROM_TEST_SLAVE_ADDRESS 0x51
#define DEF_LED_TEST_LOOP_COUNT 1
#define DEF_LED_TEST_LOOP_DELAY 3000000
#define DEF_EXT_MEM_TEST_BASE_ADDR 0x80000000
#define DEF_EXT_MEM_TEST_LENGTH 0x1FFFFFFF
#define DEF_INT_MEM_TEST_CORE_ID 1
#undef TEST_READ_IMAGE
#ifdef TEST_READ_IMAGE
#define IMAGE_STORE_ADDR 0x80000000
#define READ_EEPROM_IMAGE 1
#define READ_NAND_OOB_IMAGE 1
#endif
typedef struct test_config {
uint8_t print_info;
uint8_t print_current_core_id;
uint8_t print_switch_state;
uint8_t test_eeprom;
uint8_t test_nand;
uint8_t test_nor;
uint8_t test_led;
uint8_t test_uart;
uint8_t test_external_mem;
uint8_t test_internal_mem;
uint32_t init_config_pll1_pllm;
uint32_t init_config_uart_baudrate;
uint32_t nand_test_block_number;
uint32_t nor_test_sector_number;
uint32_t eeprom_test_slave_address;
uint32_t led_test_loop_count;
uint32_t led_test_loop_delay;
uint32_t ext_mem_test_base_addr;
uint32_t ext_mem_test_length;
uint32_t int_mem_test_core_id;
} test_config;
#define CHECK_SET_FLAG(ARG1, ARG2) \
do { \
if(strcmp(key, ARG1) == 0) { \
if((strcmp(data, "1") == 0) || \
(strcmp(data, "y") == 0) || \
(strcmp(data, "yes") == 0) || \
(strcmp(data, "true") == 0)){ \
ARG2 = 1; \
} else { \
ARG2 = 0; \
continue; \
} while(0)
#define CHECK_SET_PARAM(ARG1, ARG2) \
do { \
errno = 0; \
temp = (uint32_t) strtol(data, &ep, 0); \
if (errno == 0 && ep != data) { \
ARG2 = temp; \
continue; \
} while(0)
#define PRINT_VARIABLE(F, VAR) platform_write(#VAR"\t= "#F"\n", VAR)
/* OSAL functions for Platform Library */
uint8_t *Osal_platformMalloc (uint32_t num_bytes, uint32_t alignment)
return malloc(num_bytes);
void Osal_platformFree (uint8_t *dataPtr, uint32_t num_bytes)
/* Free up the memory */
if (dataPtr)
free(dataPtr);
void Osal_platformSpiCsEnter(void)
/* Get the hardware semaphore.
* Acquire Multi core CPPI synchronization lock
while ((CSL_semAcquireDirect (PLATFORM_SPI_HW_SEM)) == 0);
return;
void Osal_platformSpiCsExit (void)
/* Release the hardware semaphore
* Release multi-core lock.
CSL_semReleaseSemaphore (PLATFORM_SPI_HW_SEM);
return;
* Function: parse_input_file
static inline void parse_input_file(FILE * fpr, test_config *args,
platform_init_flags *flags)
char line[MAX_LINE_LENGTH + 1];
char tokens[] = " :=;\n";
char *key, *data, *ep;
uint32_t temp;
memset(line, 0, MAX_LINE_LENGTH + 1);
while (fgets(line, MAX_LINE_LENGTH + 1, fpr)) {
key = (char *)strtok(line, tokens);
data = (char *)strtok(NULL, tokens);
if(strlen(data) == 0) {
continue;
CHECK_SET_FLAG(INIT_PLL1, flags->pll);
CHECK_SET_FLAG(INIT_DDR3, flags->ddr);
CHECK_SET_FLAG(INIT_TCSL, flags->tcsl);
CHECK_SET_FLAG(INIT_PHY, flags->phy);
CHECK_SET_FLAG(INIT_ECC, flags->ecc);
CHECK_SET_FLAG(PRINT_INFO, args->print_info);
CHECK_SET_FLAG(PRINT_CURRENT_CORE_ID, args->print_current_core_id);
CHECK_SET_FLAG(PRINT_SWITCH_STATE, args->print_switch_state);
CHECK_SET_FLAG(TEST_EEPROM, args->test_eeprom);
CHECK_SET_FLAG(TEST_NAND, args->test_nand);
CHECK_SET_FLAG(TEST_NOR, args->test_nor);
CHECK_SET_FLAG(TEST_LED, args->test_led);
CHECK_SET_FLAG(TEST_UART, args->test_uart);
CHECK_SET_FLAG(TEST_EXT_MEM, args->test_external_mem);
CHECK_SET_FLAG(TEST_INT_MEM, args->test_internal_mem);
CHECK_SET_PARAM(INIT_CONFIG_PLL1_PLLM, args->init_config_pll1_pllm);
CHECK_SET_PARAM(INIT_CONFIG_UART_BAUDRATE, args->init_config_uart_baudrate);
CHECK_SET_PARAM(NAND_TEST_BLOCK_NUMBER, args->nand_test_block_number);
CHECK_SET_PARAM(EEPROM_TEST_SLAVE_ADDRESS, args->eeprom_test_slave_address);
CHECK_SET_PARAM(LED_TEST_LOOP_COUNT, args->led_test_loop_count);
CHECK_SET_PARAM(LED_TEST_LOOP_DELAY, args->led_test_loop_delay);
CHECK_SET_PARAM(EXT_MEM_TEST_BASE_ADDR, args->ext_mem_test_base_addr);
CHECK_SET_PARAM(EXT_MEM_TEST_LENGTH, args->ext_mem_test_length);
CHECK_SET_PARAM(INT_MEM_TEST_CORE_ID, args->int_mem_test_core_id);
* Function: print_current_core_id
static void print_current_core_id(void)
platform_write("Current core id is %d\n", platform_get_coreid());
* Function: print_platform_info
static void print_platform_info(platform_info * p_info, test_config * args)
uint32_t i;
PLATFORM_DEVICE_info *p_device;
PLATFORM_EMAC_EXT_info emac_info;
PRINT_VARIABLE(%s, p_info->version);
PRINT_VARIABLE(%d, p_info->cpu.core_count);
PRINT_VARIABLE(%s, p_info->cpu.name);
PRINT_VARIABLE(%d, p_info->cpu.id);
PRINT_VARIABLE(%d, p_info->cpu.revision_id);
PRINT_VARIABLE(%d, p_info->cpu.silicon_revision_major);
PRINT_VARIABLE(%d, p_info->cpu.silicon_revision_minor);
PRINT_VARIABLE(%d, p_info->cpu.megamodule_revision_major);
PRINT_VARIABLE(%d, p_info->cpu.megamodule_revision_minor);
PRINT_VARIABLE(%d, p_info->cpu.endian);
PRINT_VARIABLE(%s, p_info->board_name);
PRINT_VARIABLE(%d, p_info->frequency);
PRINT_VARIABLE(%d, p_info->board_rev);
PRINT_VARIABLE(%d, p_info->led[PLATFORM_USER_LED_CLASS].count);
PRINT_VARIABLE(%d, p_info->led[PLATFORM_SYSTEM_LED_CLASS].count);
PRINT_VARIABLE(%d, p_info->emac.port_count);
for (i = 0; i < PLATFORM_MAX_EMAC_PORT_NUM; i++)
platform_get_emac_info (i, &emac_info);
if (emac_info.mode == PLATFORM_EMAC_PORT_MODE_PHY)
platform_write("EMAC port %d connected to the PHY.\n", emac_info.port_num);
platform_write("MAC Address = %02x:%02x:%02x:%02x:%02x:%02x\n",
emac_info.mac_address[0], emac_info.mac_address[1],
emac_info.mac_address[2], emac_info.mac_address[3],
emac_info.mac_address[4], emac_info.mac_address[5]);
if(args->test_nand) {
p_device = platform_device_open(PLATFORM_DEVID_MT29F1G08ABCHC, 0);
if (p_device) {
platform_write("\nNAND Device: \n");
PRINT_VARIABLE(%d, p_device->device_id);
PRINT_VARIABLE(%d, p_device->manufacturer_id);
PRINT_VARIABLE(%d, p_device->width);
PRINT_VARIABLE(%d, p_device->block_count);
PRINT_VARIABLE(%d, p_device->page_count);
PRINT_VARIABLE(%d, p_device->page_size);
PRINT_VARIABLE(%d, p_device->spare_size);
PRINT_VARIABLE(%d, p_device->column);
PRINT_VARIABLE(%d, p_device->handle);
PRINT_VARIABLE(%d, p_device->flags);
PRINT_VARIABLE(%d, p_device->bboffset);
if (p_device->bblist) {
platform_write("Bad Block Table (only bad block numbers shown): \n");
for (i=0; i < p_device->block_count; i++) {
if (p_device->bblist[i] == 0x00) {
platform_write("%d \n", i);
platform_device_close(p_device->handle);
else {
platform_write("Could not open the NAND device errno = 0x%x\n", platform_errno);
if(args->test_nor) {
p_device = platform_device_open(PLATFORM_DEVID_NORN25Q032A, 0);
if (p_device) {
platform_write("\nNOR Device: \n");
platform_write("%d ", i);
} else {
platform_write("Could not open the NOR device errno = 0x%x\n", platform_errno);
if(args->test_eeprom) {
p_device = platform_device_open(PLATFORM_DEVID_EEPROM50, 0);
if (p_device) {
platform_write("\nEEPROM Device (@ 0x50): \n");
else {
platform_write("Could not open the EEPROM @50 device errno = 0x%x\n", platform_errno);
p_device = platform_device_open(PLATFORM_DEVID_EEPROM51, 0);
if (p_device) {
platform_write("\nEEPROM Device (@ 0x51): \n");
else {
platform_write("Could not open the EEPROM @51 device errno = 0x%x\n", platform_errno);
return;
* Function: print_switch_state
static void print_switch_state(void)
platform_write("User switch 1 state is %s\n",
platform_get_switch_state(1) ? "ON" : "OFF");
* Function: test_eeprom
static void test_eeprom(test_config * args)
uint8_t test_buf[12] = {0x00, 0x01, 0x02, 0x03, 0x04, 0x05, 0x06, 0x07, 0x08, 0x09, 0x0a, 0x0b};
uint8_t * test_buf1;
uint8_t * orig_buf;
if (args->eeprom_test_slave_address == 0x50) {
else {
if (p_device == NULL) {
platform_write("test_eeprom: Could not open EEPROM device %x errno = 0x%x \n", args->eeprom_test_slave_address, platform_errno);
return;
test_buf1 = malloc(12);
orig_buf = malloc(12);
if(platform_device_read(p_device->handle, 0, orig_buf, 12) != Platform_EOK) {
platform_write("test_eeprom: Read failed, errno = 0x%x\n", platform_errno);
goto free;
if(platform_device_write(p_device->handle,0, test_buf, 12) != Platform_EOK) {
platform_write("test_eeprom: Write test data failed, errno = 0x%x\n", platform_errno);
goto free;
if(platform_device_read(p_device->handle, 0, test_buf1, 12) != Platform_EOK) {
platform_write("test_eeprom: Read test data failed, errno = 0x%x\n",platform_errno);
goto free;
if (memcmp(test_buf, test_buf1, 12) != 0) {
platform_write("test_eeprom: Data verification failed\n");
goto free;
} else {
platform_write("test_eeprom: passed\n");
if(platform_device_write(p_device->handle,0, orig_buf, 12) != Platform_EOK) {
platform_write("test_eeprom: Write back original data failed, errno = 0x%x\n", platform_errno);
free:
free(test_buf1);
free(orig_buf);
* Function: test_nand
static void test_nand(test_config * args)
uint8_t * buf1, * buf2, * buf_orig;
/*uint16_t i, sp_flag = 0;*/
uint32_t offset;
buf1 = NULL; buf2 = NULL; buf_orig = NULL;
/* Open the device */
platform_write("test_nand: Could not open NAND device errno = 0x%x \n", platform_errno);
goto NAND_TEST_DONE;
/* We need a buffer to read a page in */
buf_orig = (uint8_t *) malloc(p_device->page_size);
if (buf_orig == NULL) {
platform_write("test_nand: Can't allocate %d bytes for buf_orig\n", p_device->page_size);
/* Read the test block page 0 - save the contents so we can write back */
platform_blocknpage_to_offset(p_device->handle, &offset, args->nand_test_block_number, 0 );
if (platform_device_read(p_device->handle, offset, buf_orig, p_device->page_size) != Platform_EOK) {
platform_write("test_nand: Unable to read block %d page %d errno = 0x%x\n", args->nand_test_block_number, 0, platform_errno );
/* Get a new buffer so we can test writing some values */
buf1 = (uint8_t *) malloc(p_device->page_size);
if (buf1 == NULL) {
platform_write("test_nand: Can't allocate %d bytes for buf1\n", p_device->page_size);
/* Erase our test block so we can write to it */
if (platform_device_erase_block(p_device->handle, args->nand_test_block_number) != Platform_EOK) {
platform_write("test_nand: Unable to erase (%d) block %d errno = 0x%x\n", args->nand_test_block_number, platform_errno);
/* Fill in a test pattern */
memset(buf1, 0x6d, p_device->page_size);
/* Write the test pattern to the test block */
if (platform_device_write(p_device->handle, offset, buf1, p_device->page_size) != Platform_EOK) {
platform_write("test_nand: Unable to write (%d) block %d page %d errno = 0x%x \n", args->nand_test_block_number, 0, platform_errno);
platform_delay(1000);
/* Get another buffer to read back in the test pattern so we can compare it */
buf2 = (uint8_t *) malloc(p_device->page_size);
if (buf2 == NULL) {
platform_write("test_nand: Can't allocate %d bytes for buf2\n", p_device->page_size);
/* save back the original page */
platform_blocknpage_to_offset(p_device->handle, &offset, args->nand_test_block_number, 0);
platform_device_write(p_device->handle, offset, buf_orig, p_device->page_size);
memset(buf2, 0xff, p_device->page_size);
if (platform_device_read(p_device->handle, offset, buf2, p_device->page_size) != Platform_EOK) {
/* Compare to see if what we wrote is what we read */
if(memcmp(buf1, buf2, p_device->page_size))
platform_write("test_nand: failed for block %d. What we wrote is not what we read. \n", args->nand_test_block_number);
} else {
platform_write("test_nand: passed\n");
/* Restore the original buffer */
platform_write("test_nand: Unable to erase block %d errno = 0x%x \n", args->nand_test_block_number,platform_errno);
NAND_TEST_DONE:
if (buf1)
free(buf1);
if (buf2)
free(buf2);
if (buf_orig)
free(buf_orig);
return;
* Function: test_nor
static void test_nor(test_config * args, platform_info * p_info)
uint8_t * test_buf0;
uint8_t * orig_buf;
uint32_t i;
uint32_t address;
#define SPI_NOR_TEST_SIZE (64*1024)
platform_init_flags flags;
platform_init_config config;
memset(&flags, 0, sizeof(platform_init_flags));
memset(&config, 0, sizeof(platform_init_config));
platform_write("test_nor: Could not open NOR device errno = 0x%x \n", platform_errno);
return;
test_buf0 = malloc(SPI_NOR_TEST_SIZE);
test_buf1 = malloc(SPI_NOR_TEST_SIZE);
orig_buf = malloc(SPI_NOR_TEST_SIZE);
/* Initialize the test pattern */
for (i=0; i < SPI_NOR_TEST_SIZE; i++) {
test_buf0[i] ^= 0xAB;
address = args->nor_test_sector_number * 64 * 1024; /* each sector is 64kb */
if(platform_device_read(p_device->handle, address, orig_buf, SPI_NOR_TEST_SIZE) != Platform_EOK) {
platform_write("test_nor: Read failed errno = 0x%x\n", platform_errno);
goto free;
if(platform_device_erase_block (p_device->handle, args->nor_test_sector_number) != Platform_EOK) {
platform_write("test_nor: Erase Failed for sector %d errno = 0x%x\n", args->nor_test_sector_number, platform_errno);
if(platform_device_read(p_device->handle, address, test_buf1, SPI_NOR_TEST_SIZE) != Platform_EOK) {
platform_write("test_nor: Read test data failed errno = 0x%x\n", platform_errno);
if(platform_device_write(p_device->handle, address, test_buf0, SPI_NOR_TEST_SIZE) != Platform_EOK) {
platform_write("test_nor: Write test data failed errno = 0x%x\n", platform_errno);
if (memcmp(test_buf0, test_buf1, SPI_NOR_TEST_SIZE) != 0) {
platform_write("test_nor: Data verification failed\n");
} else {
platform_write("test_nor: passed\n");
platform_write("test_nor: Erase Failed errno = 0x%x\n", platform_errno);
if(platform_device_write(p_device->handle, address, orig_buf, SPI_NOR_TEST_SIZE) != Platform_EOK) {
platform_write("test_nor: Write back original data failed errno = 0x%x\n", platform_errno);
free:
free(test_buf0);
free(test_buf1);
free(orig_buf);
* Function: test_led
static void test_led(test_config * args, platform_info * p_info)
int32_t i,j;
int32_t max_loop = args->led_test_loop_count;
do {
for (j = PLATFORM_USER_LED_CLASS; j < PLATFORM_END_LED_CLASS; j++) {;
for (i = 0; i < p_info->led[j].count; i++) {
platform_write("LED %d ON\n", i);
platform_led(i, PLATFORM_LED_ON, (LED_CLASS_E)j);
platform_delay(args->led_test_loop_delay);
platform_write("LED %d OFF\n", i);
platform_led(i, PLATFORM_LED_OFF, (LED_CLASS_E) j);
} while (--max_loop);
/* turn on all the LEDS (default state) after the test */
* Function: test_internal_memory
static void test_internal_memory(test_config * args)
if(platform_internal_memory_test(args->int_mem_test_core_id) != Platform_EOK) {
platform_write("Internal memory test failed for core %d at address 0x%x \n",
args->int_mem_test_core_id, platform_errno);
} else {
platform_write("Internal memory test (for core %d) passed\n",
* Function: test_external_memory
static void test_external_memory(test_config * args)
int32_t status;
status = platform_external_memory_test(args->ext_mem_test_base_addr,
(args->ext_mem_test_base_addr + args->ext_mem_test_length));
if (status == PLATFORM_ERRNO_INVALID_ARGUMENT) {
platform_write("Invalid Arguments passed for the test\n");
} else if (status != Platform_EOK) {
platform_write("External memory test failed at address = 0x%x \n", platform_errno);
} else {
platform_write("External memory test passed\n");
* Function: test_uart
static void test_uart(test_config * args)
uint8_t message[] = "\r\nThis is a Platform UART API unit test ...\r\n";
int length = strlen((char *)message);
uint8_t buf;
int i;
WRITE_info setting;
platform_uart_set_baudrate(args->init_config_uart_baudrate);
/* Don't echo to the uart since we are testing on it */
setting = platform_write_configure (PLATFORM_WRITE_PRINTF);
platform_write("Open a serial port console in a PC connected to\n");
platform_write("the board using UART and set its baudrate to %d\n", args->init_config_uart_baudrate);
platform_write("You should see following message --- %s", message);
platform_write("Type 10 characters in serial console\n");
for (i = 0; i < length; i++) {
platform_uart_write(message[i]);
for (i = 0; i < 10; i++) {
platform_errno = PLATFORM_ERRNO_RESET;
if (platform_uart_read(&buf, 30 * 10000000) == Platform_EOK) {
platform_write("Char %d = %c\n", i, buf);
} else {
platform_write("Char %d = %c (errno: 0x%x)\n", i, buf, platform_errno);
platform_write_configure (setting);
#if READ_EEPROM_IMAGE
#define MAX_EEPROM_SIZE 0x10000
uint32_t write_eeprom_image = 0;
void
read_eeprom_image(void)
FILE *fp;
char *eeprom50 = "eeprom50.bin";
char *eeprom51 = "eeprom51.bin";
uint8_t *buf;
uint32_t size;
/* Read 64KB from EEPROM 0x50 and save it to eeprom50.bin */
fp = fopen(eeprom50, "wb");
if (fp == NULL)
printf("Error in opening %s file\n", eeprom50);
return;
platform_write("read_eeprom_image: Could not open EEPROM device 0x50 errno = 0x%x \n", platform_errno);
return;
buf = (uint8_t *)IMAGE_STORE_ADDR;
/* Read 64K bytes from EEPROM 0x50, and store in external memory */
if(platform_device_read(p_device->handle, 0, buf, MAX_EEPROM_SIZE) != Platform_EOK)
platform_write("read_eeprom_image: Read failed on 0x50, errno = 0x%x\n", platform_errno);
return;
/* Write the data to a binary file */
size = fwrite(buf, 1, MAX_EEPROM_SIZE, fp);
if (size != MAX_EEPROM_SIZE)
platform_write("read_eeprom_image: write to binary failed\n");
fclose(fp);
/* Read 64KB from EEPROM 0x51 and save it to eeprom51.bin */
fp = fopen(eeprom51, "wb");
if (fp == NULL)
printf("Error in opening %s file\n", eeprom51);
return;
platform_write("read_eeprom_image: Could not open EEPROM device 0x51 errno = 0x%x \n", platform_errno);
return;
buf = (uint8_t *)(IMAGE_STORE_ADDR + MAX_EEPROM_SIZE);
/* Read 64K bytes from EEPROM 0x51, and store in external memory */
return;
fclose(fp);
if (!write_eeprom_image)
return;
/* Read eeprom50.bin and write it to EEPROM 0x50 */
fp = fopen(eeprom50, "rb");
if (fp == NULL)
return;
size = fread(buf, 1, MAX_EEPROM_SIZE, fp);
fclose(fp);
platform_write("read_eeprom_image: read binary failed\n");
return;
return;
if(platform_device_write(p_device->handle, 0, buf, MAX_EEPROM_SIZE) != Platform_EOK)
platform_write("read_eeprom_image: write failed on 0x50, errno = 0x%x\n", platform_errno);
return;
/* Read eeprom51.bin and write it to EEPROM 0x51 */
fp = fopen(eeprom51, "rb");
if (fp == NULL)
return;
fclose(fp);
return;
return;
platform_write("read_eeprom_image: write failed on 0x51, errno = 0x%x\n", platform_errno);
return;
#endif
#if READ_NAND_OOB_IMAGE
#define NAND_READ_START_OFFSET (16384) /* start byte address of block 1 */
#define NAND_READ_SIZE 0xA00000
void
read_nand_oob_image(void)
FILE *fp = 0;
char *nand_oob = "nand_oob.bin";
uint8_t *buf, *buf2;
PLATFORM_DEVICE_info *p_device = 0;
uint32_t start_block, end_block;
uint32_t start_page, end_page;
uint32_t offset_start, offset_end;
uint32_t i, j, write_idx;
uint32_t size;
fp = fopen(nand_oob, "wb");
if (fp == NULL)
printf("Error in opening %s file\n", nand_oob);
return;
platform_write("read_nand_oob_image: Could not open NAND device errno = 0x%x \n", platform_errno);
buf = (uint8_t *) IMAGE_STORE_ADDR;
offset_start = NAND_READ_START_OFFSET;
offset_end = NAND_READ_START_OFFSET + NAND_READ_SIZE;
platform_offset_to_blocknpage(p_device->handle, offset_start, &start_block, &start_page);
platform_offset_to_blocknpage(p_device->handle, offset_end, &end_block, &end_page);
write_idx = 0;
for (i = start_block; i < end_block; i++)
while (p_device->bblist[i] != 0xff)
i++;
end_block++;
for (j = 0; j < p_device->page_count; j++) {
if(platform_device_read_spare_data (p_device->handle, i, j, &buf[write_idx]) != Platform_EOK) {
platform_write("read_nand_oob_image: Spare read failed on NAND, errno = 0x%x\n", platform_errno);
write_idx += p_device->spare_size;
size = fwrite(&buf[write_idx-(p_device->spare_size*p_device->page_count)], 1, p_device->spare_size * p_device->page_count, fp);
if (size != (p_device->spare_size * p_device->page_count))
platform_write("read_nand_oob_image: write to binary (spare) failed\n");
NAND_TEST_DONE:
if (p_device) platform_device_close(p_device->handle);
if(fp) fclose(fp);
fp = fopen(nand_oob, "rb");
if (fp == NULL)
platform_write("Error in opening %s file\n", nand_oob);
return;
buf2 = (uint8_t *) (IMAGE_STORE_ADDR + 0x100000);
size = fread(buf2, 1, write_idx, fp);
fclose(fp);
platform_write("read_nand_oob_image: read binary failed\n");
return;
for (i=0; i<write_idx; i++)
if(buf[i] != buf2[i])
platform_write("read_nand_oob_image: memory compare failed\n");
return;
#endif
/* Adding code for the second core to jump-boot-address and execute */
#define DEVICE_REG32_W(x,y) *(volatile uint32_t *)(x)=(y)
#define MAGIC_ADDR 0x8ffffc
#define BOOT_MAGIC_ADDR(x) (MAGIC_ADDR + (1<<28) + (x<<24))
#define IPCGR(x) (0x02620240 + x*4)
#define BOOT_MAGIC_NUMBER 0xBABEFACE
void
void
uint32_t counter = 0;
DEVICE_REG32_W(0x118ffffC, 0xBABEFACE);
// DEVICE_REG32_W(0x118ffffC, (uint32_t)write_boot_magic_number);
memset(&counter, 0x00, sizeof(uint32_t));
while(1)
counter++;
if( counter == 10000 )
printf("Hi, Inside write_boot_magic_number, I am popping out from second core \n");
counter = 0;
* Function: main
void main (int argc, char *argv[])
platform_init_flags init_flags;
platform_init_config init_config;
platform_info p_info;
test_config args;
FILE * fpr = NULL;
// Boot magic
#if 1
uint32_t core;
#endif
/* Set default values */
memset(&args, 0x01, sizeof(test_config));
memset(&init_flags, 0x01, sizeof(platform_init_flags));
args.init_config_pll1_pllm = DEF_INIT_CONFIG_PLL1_PLLM;
args.init_config_uart_baudrate = DEF_INIT_CONFIG_UART_BAUDRATE;
args.nand_test_block_number = DEF_NAND_TEST_BLOCK_NUMBER;
args.nor_test_sector_number = DEF_NOR_TEST_SECTOR_NUMBER;
args.eeprom_test_slave_address = DEF_EEPROM_TEST_SLAVE_ADDRESS;
args.led_test_loop_count = DEF_LED_TEST_LOOP_COUNT;
args.led_test_loop_delay = DEF_LED_TEST_LOOP_DELAY;
args.ext_mem_test_base_addr = DEF_EXT_MEM_TEST_BASE_ADDR;
args.ext_mem_test_length = DEF_EXT_MEM_TEST_LENGTH;
args.int_mem_test_core_id = DEF_INT_MEM_TEST_CORE_ID;
if (argc > 1) {
fpr = fopen(argv[1], "r");
if (fpr == NULL) {
printf("Error in opening %s input file\n", argv[1]);
} else {
fpr = fopen(input_file_name, "r");
if (fpr == NULL) {
printf("Error in opening %s input file\n", input_file_name);
if (fpr) {
parse_input_file(fpr, &args, &init_flags);
fclose(fpr);
init_config.pllm = args.init_config_pll1_pllm;
if (platform_init(&init_flags, &init_config) != Platform_EOK) {
printf("Platform failed to initialize, errno = 0x%x \n", platform_errno);
platform_write_configure(PLATFORM_WRITE_PRINTF);
platform_uart_init();
platform_uart_set_baudrate(args.init_config_uart_baudrate);
platform_get_info(&p_info);
#if 1
if( args.print_current_core_id == 1 ) {
/* Unlock the chip registers */
// kick 0 AND kick 1
DEVICE_REG32_W(0x02620038, 0x83e70b13);
DEVICE_REG32_W(0x0262003C, 0x95a4f1e0);
/* Writing the entry address to other cores */
for (core = 1; core < p_info.cpu.core_count; core++)
printf("I am popping out from FIRST core. BOOT Magic Address of second Core is : %x\n", BOOT_MAGIC_ADDR(core));
DEVICE_REG32_W(BOOT_MAGIC_ADDR(core), (uint32_t)write_boot_magic_number);
/* Delay 1us sec */
platform_delay(1);
/* IPC interrupt other cores */
DEVICE_REG32_W(IPCGR(core), 1);
else write_boot_magic_number();
// while (1);
#endif
if(args.print_info) {
print_platform_info(&p_info, &args);
if(args.print_current_core_id) {
print_current_core_id();
if(args.print_switch_state) {
print_switch_state();
if(args.test_uart) {
platform_write("UART test start\n");
test_uart(&args);
platform_write("UART test complete\n");
if(args.test_eeprom) {
platform_write("EEPROM test start\n");
test_eeprom(&args);
platform_write("EEPROM test complete\n");
if(args.test_nand) {
platform_write("NAND test start\n");
test_nand(&args);
platform_write("NAND test complete\n");
if(args.test_nor) {
platform_write("NOR test start\n");
test_nor(&args, &p_info);
platform_write("NOR test complete\n");
if(args.test_led) {
platform_write("LED test start\n");
test_led(&args, &p_info);
platform_write("LED test complete\n");
if(args.test_internal_mem) {
platform_write("Internal memory test start\n");
test_internal_memory(&args);
platform_write("Internal memory test complete\n");
if(args.test_external_mem) {
platform_write("External memory test start\n");
test_external_memory(&args);
platform_write("External memory test complete\n");
read_eeprom_image();
#endif
read_nand_oob_image();
#endif
platform_write("Test completed\n");
The same steps are done in this video:
For C6678, K2E and K2H, please use the appropriate processor SDK of individual devices. Integrate just the code snippets required for waking up the cores( given above) in the platform_test.c code.
For C6678:
#ifdef _EVMC6678L_
#define MAGIC_ADDR 0x87fffc
#endif
For K2E:
The boot magic address is 0x87fffc - Datasheet page no: 155
For K2H:
The boot magic address is 0x8ffffc - Datasheet page no: 182
Shankari G
