Part Number: TDA4VM
Hi Gang,
I'm doing distortion correction on TDA4 using DCC tool, and I have found your workflow instruction: https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1058565/faq-tda4vm-how-to-create-a-ldc-mesh-lut-for-fisheye-distortion-correction-on-tda4?tisearch=e2e-sitesearch&keymatch=TDA4%252520LDC%252520FAQ#
But in the instruction, I have some questions about the Matlab script.
In the instruction, the Lens distortion spec file has two columns, in which the first is the FoV degree and the second is in mm. I'm confused about the second column, is it the Ref. Height or Real Height, or some other parameters? (attached file is the Lens Distortion specc file provided by manufacturer)
Field angle Ref. Height Real Height DISTORTION: 0.0 0.0000 0.0000 0.00% 0.1 0.0038 0.0038 0.00% 0.2 0.0077 0.0077 0.00% 0.3 0.0115 0.0115 0.00% 0.4 0.0153 0.0153 0.00% 0.5 0.0192 0.0192 0.00% 0.6 0.0230 0.0230 0.00% 0.7 0.0268 0.0268 -0.01% 0.8 0.0307 0.0307 -0.01% 0.9 0.0345 0.0345 -0.01% 1.0 0.0383 0.0383 -0.01% 1.1 0.0422 0.0422 -0.01% 1.2 0.0460 0.0460 -0.02% 1.3 0.0498 0.0498 -0.02% 1.4 0.0537 0.0536 -0.02% 1.5 0.0575 0.0575 -0.03% 1.6 0.0613 0.0613 -0.03% 1.7 0.0652 0.0651 -0.03% 1.8 0.0690 0.0690 -0.04% 1.9 0.0728 0.0728 -0.04% 2.0 0.0767 0.0766 -0.05% 2.1 0.0805 0.0805 -0.05% 2.2 0.0843 0.0843 -0.06% 2.3 0.0882 0.0881 -0.06% 2.4 0.0920 0.0920 -0.07% 2.5 0.0959 0.0958 -0.07% 2.6 0.0997 0.0996 -0.08% 2.7 0.1035 0.1035 -0.09% 2.8 0.1074 0.1073 -0.09% 2.9 0.1112 0.1111 -0.10% 3.0 0.1151 0.1149 -0.11% 3.1 0.1189 0.1188 -0.11% 3.2 0.1228 0.1226 -0.12% 3.3 0.1266 0.1264 -0.13% 3.4 0.1304 0.1303 -0.14% 3.5 0.1343 0.1341 -0.14% 3.6 0.1381 0.1379 -0.15% 3.7 0.1420 0.1418 -0.16% 3.8 0.1458 0.1456 -0.17% 3.9 0.1497 0.1494 -0.18% 4.0 0.1535 0.1532 -0.19% 4.1 0.1574 0.1571 -0.20% 4.2 0.1612 0.1609 -0.21% 4.3 0.1651 0.1647 -0.22% 4.4 0.1689 0.1686 -0.23% 4.5 0.1728 0.1724 -0.24% 4.6 0.1767 0.1762 -0.25% 4.7 0.1805 0.1800 -0.26% 4.8 0.1844 0.1839 -0.27% 4.9 0.1882 0.1877 -0.28% 5.0 0.1921 0.1915 -0.30% 5.1 0.1960 0.1953 -0.31% 5.2 0.1998 0.1992 -0.32% 5.3 0.2037 0.2030 -0.33% 5.4 0.2075 0.2068 -0.35% 5.5 0.2114 0.2107 -0.36% 5.6 0.2153 0.2145 -0.37% 5.7 0.2191 0.2183 -0.38% 5.8 0.2230 0.2221 -0.40% 5.9 0.2269 0.2260 -0.41% 6.0 0.2308 0.2298 -0.43% 6.1 0.2346 0.2336 -0.44% 6.2 0.2385 0.2374 -0.45% 6.3 0.2424 0.2413 -0.47% 6.4 0.2463 0.2451 -0.48% 6.5 0.2502 0.2489 -0.50% 6.6 0.2540 0.2527 -0.52% 6.7 0.2579 0.2566 -0.53% 6.8 0.2618 0.2604 -0.55% 6.9 0.2657 0.2642 -0.56% 7.0 0.2696 0.2680 -0.58% 7.1 0.2735 0.2718 -0.60% 7.2 0.2774 0.2757 -0.61% 7.3 0.2813 0.2795 -0.63% 7.4 0.2852 0.2833 -0.65% 7.5 0.2891 0.2871 -0.67% 7.6 0.2930 0.2909 -0.68% 7.7 0.2969 0.2948 -0.70% 7.8 0.3008 0.2986 -0.72% 7.9 0.3047 0.3024 -0.74% 8.0 0.3086 0.3062 -0.76% 8.1 0.3125 0.3100 -0.78% 8.2 0.3164 0.3139 -0.80% 8.3 0.3203 0.3177 -0.82% 8.4 0.3242 0.3215 -0.84% 8.5 0.3281 0.3253 -0.86% 8.6 0.3320 0.3291 -0.88% 8.7 0.3360 0.3330 -0.90% 8.8 0.3399 0.3368 -0.92% 8.9 0.3438 0.3406 -0.94% 9.0 0.3477 0.3444 -0.96% 9.1 0.3517 0.3482 -0.98% 9.2 0.3556 0.3520 -1.00% 9.3 0.3595 0.3559 -1.02% 9.4 0.3635 0.3597 -1.05% 9.5 0.3674 0.3635 -1.07% 9.6 0.3714 0.3673 -1.09% 9.7 0.3753 0.3711 -1.11% 9.8 0.3792 0.3749 -1.14% 9.9 0.3832 0.3787 -1.16% 10.0 0.3871 0.3826 -1.18% 10.1 0.3911 0.3864 -1.21% 10.2 0.3950 0.3902 -1.23% 10.3 0.3990 0.3940 -1.26% 10.4 0.4030 0.3978 -1.28% 10.5 0.4069 0.4016 -1.31% 10.6 0.4109 0.4054 -1.33% 10.7 0.4149 0.4092 -1.36% 10.8 0.4188 0.4130 -1.38% 10.9 0.4228 0.4169 -1.41% 11.0 0.4268 0.4207 -1.43% 11.1 0.4308 0.4245 -1.46% 11.2 0.4347 0.4283 -1.49% 11.3 0.4387 0.4321 -1.51% 11.4 0.4427 0.4359 -1.54% 11.5 0.4467 0.4397 -1.57% 11.6 0.4507 0.4435 -1.59% 11.7 0.4547 0.4473 -1.62% 11.8 0.4587 0.4511 -1.65% 11.9 0.4627 0.4549 -1.68% 12.0 0.4667 0.4587 -1.71% 12.1 0.4707 0.4625 -1.73% 12.2 0.4747 0.4663 -1.76% 12.3 0.4787 0.4701 -1.79% 12.4 0.4827 0.4739 -1.82% 12.5 0.4867 0.4777 -1.85% 12.6 0.4908 0.4815 -1.88% 12.7 0.4948 0.4853 -1.91% 12.8 0.4988 0.4891 -1.94% 12.9 0.5029 0.4929 -1.97% 13.0 0.5069 0.4967 -2.00% 13.1 0.5109 0.5005 -2.03% 13.2 0.5150 0.5043 -2.06% 13.3 0.5190 0.5081 -2.10% 13.4 0.5231 0.5119 -2.13% 13.5 0.5271 0.5157 -2.16% 13.6 0.5312 0.5195 -2.19% 13.7 0.5352 0.5233 -2.22% 13.8 0.5393 0.5271 -2.26% 13.9 0.5434 0.5309 -2.29% 14.0 0.5474 0.5347 -2.32% 14.1 0.5515 0.5385 -2.36% 14.2 0.5556 0.5423 -2.39% 14.3 0.5596 0.5461 -2.42% 14.4 0.5637 0.5499 -2.46% 14.5 0.5678 0.5537 -2.49% 14.6 0.5719 0.5575 -2.53% 14.7 0.5760 0.5613 -2.56% 14.8 0.5801 0.5650 -2.60% 14.9 0.5842 0.5688 -2.63% 15.0 0.5883 0.5726 -2.67% 15.1 0.5924 0.5764 -2.70% 15.2 0.5965 0.5802 -2.74% 15.3 0.6006 0.5840 -2.77% 15.4 0.6048 0.5878 -2.81% 15.5 0.6089 0.5916 -2.85% 15.6 0.6130 0.5953 -2.88% 15.7 0.6171 0.5991 -2.92% 15.8 0.6213 0.6029 -2.96% 15.9 0.6254 0.6067 -3.00% 16.0 0.6296 0.6105 -3.03% 16.1 0.6337 0.6143 -3.07% 16.2 0.6379 0.6180 -3.11% 16.3 0.6420 0.6218 -3.15% 16.4 0.6462 0.6256 -3.19% 16.5 0.6504 0.6294 -3.23% 16.6 0.6545 0.6332 -3.27% 16.7 0.6587 0.6369 -3.31% 16.8 0.6629 0.6407 -3.35% 16.9 0.6671 0.6445 -3.39% 17.0 0.6713 0.6483 -3.43% 17.1 0.6754 0.6520 -3.47% 17.2 0.6796 0.6558 -3.51% 17.3 0.6838 0.6596 -3.55% 17.4 0.6881 0.6634 -3.59% 17.5 0.6923 0.6671 -3.63% 17.6 0.6965 0.6709 -3.67% 17.7 0.7007 0.6747 -3.71% 17.8 0.7049 0.6784 -3.76% 17.9 0.7092 0.6822 -3.80% 18.0 0.7134 0.6860 -3.84% 18.1 0.7176 0.6898 -3.88% 18.2 0.7219 0.6935 -3.93% 18.3 0.7261 0.6973 -3.97% 18.4 0.7304 0.7011 -4.01% 18.5 0.7346 0.7048 -4.06% 18.6 0.7389 0.7086 -4.10% 18.7 0.7432 0.7123 -4.15% 18.8 0.7474 0.7161 -4.19% 18.9 0.7517 0.7199 -4.24% 19.0 0.7560 0.7236 -4.28% 19.1 0.7603 0.7274 -4.33% 19.2 0.7646 0.7312 -4.37% 19.3 0.7689 0.7349 -4.42% 19.4 0.7732 0.7387 -4.46% 19.5 0.7775 0.7424 -4.51% 19.6 0.7818 0.7462 -4.56% 19.7 0.7861 0.7499 -4.60% 19.8 0.7905 0.7537 -4.65% 19.9 0.7948 0.7575 -4.70% 20.0 0.7991 0.7612 -4.74% 20.1 0.8035 0.7650 -4.79% 20.2 0.8078 0.7687 -4.84% 20.3 0.8122 0.7725 -4.89% 20.4 0.8165 0.7762 -4.94% 20.5 0.8209 0.7800 -4.99% 20.6 0.8253 0.7837 -5.03% 20.7 0.8296 0.7875 -5.08% 20.8 0.8340 0.7912 -5.13% 20.9 0.8384 0.7950 -5.18% 21.0 0.8428 0.7987 -5.23% 21.1 0.8472 0.8025 -5.28% 21.2 0.8516 0.8062 -5.33% 21.3 0.8560 0.8099 -5.38% 21.4 0.8604 0.8137 -5.43% 21.5 0.8649 0.8174 -5.48% 21.6 0.8693 0.8212 -5.54% 21.7 0.8737 0.8249 -5.59% 21.8 0.8782 0.8286 -5.64% 21.9 0.8826 0.8324 -5.69% 22.0 0.8871 0.8361 -5.74% 22.1 0.8915 0.8399 -5.80% 22.2 0.8960 0.8436 -5.85% 22.3 0.9005 0.8473 -5.90% 22.4 0.9050 0.8511 -5.95% 22.5 0.9094 0.8548 -6.01% 22.6 0.9139 0.8585 -6.06% 22.7 0.9184 0.8623 -6.12% 22.8 0.9229 0.8660 -6.17% 22.9 0.9274 0.8697 -6.22% 23.0 0.9320 0.8734 -6.28% 23.1 0.9365 0.8772 -6.33% 23.2 0.9410 0.8809 -6.39% 23.3 0.9456 0.8846 -6.44% 23.4 0.9501 0.8884 -6.50% 23.5 0.9547 0.8921 -6.56% 23.6 0.9592 0.8958 -6.61% 23.7 0.9638 0.8995 -6.67% 23.8 0.9684 0.9032 -6.72% 23.9 0.9729 0.9070 -6.78% 24.0 0.9775 0.9107 -6.84% 24.1 0.9821 0.9144 -6.90% 24.2 0.9867 0.9181 -6.95% 24.3 0.9913 0.9218 -7.01% 24.4 0.9960 0.9255 -7.07% 24.5 1.0006 0.9293 -7.13% 24.6 1.0052 0.9330 -7.19% 24.7 1.0099 0.9367 -7.24% 24.8 1.0145 0.9404 -7.30% 24.9 1.0192 0.9441 -7.36% 25.0 1.0238 0.9478 -7.42% 25.1 1.0285 0.9515 -7.48% 25.2 1.0332 0.9552 -7.54% 25.3 1.0378 0.9589 -7.60% 25.4 1.0425 0.9626 -7.66% 25.5 1.0472 0.9664 -7.72% 25.6 1.0519 0.9701 -7.78% 25.7 1.0567 0.9738 -7.85% 25.8 1.0614 0.9775 -7.91% 25.9 1.0661 0.9812 -7.97% 26.0 1.0709 0.9849 -8.03% 26.1 1.0756 0.9886 -8.09% 26.2 1.0804 0.9923 -8.16% 26.3 1.0851 0.9959 -8.22% 26.4 1.0899 0.9996 -8.28% 26.5 1.0947 1.0033 -8.34% 26.6 1.0995 1.0070 -8.41% 26.7 1.1043 1.0107 -8.47% 26.8 1.1091 1.0144 -8.53% 26.9 1.1139 1.0181 -8.60% 27.0 1.1187 1.0218 -8.66% 27.1 1.1235 1.0255 -8.73% 27.2 1.1284 1.0292 -8.79% 27.3 1.1332 1.0328 -8.86% 27.4 1.1381 1.0365 -8.92% 27.5 1.1429 1.0402 -8.99% 27.6 1.1478 1.0439 -9.05% 27.7 1.1527 1.0476 -9.12% 27.8 1.1576 1.0513 -9.19% 27.9 1.1625 1.0549 -9.25% 28.0 1.1674 1.0586 -9.32% 28.1 1.1723 1.0623 -9.39% 28.2 1.1773 1.0660 -9.45% 28.3 1.1822 1.0696 -9.52% 28.4 1.1871 1.0733 -9.59% 28.5 1.1921 1.0770 -9.66% 28.6 1.1971 1.0807 -9.73% 28.7 1.2020 1.0843 -9.79% 28.8 1.2070 1.0880 -9.86% 28.9 1.2120 1.0917 -9.93% 29.0 1.2170 1.0953 -10.00% 29.1 1.2220 1.0990 -10.07% 29.2 1.2271 1.1026 -10.14% 29.3 1.2321 1.1063 -10.21% 29.4 1.2371 1.1100 -10.28% 29.5 1.2422 1.1136 -10.35% 29.6 1.2473 1.1173 -10.42% 29.7 1.2523 1.1209 -10.49% 29.8 1.2574 1.1246 -10.56% 29.9 1.2625 1.1283 -10.63% 30.0 1.2676 1.1319 -10.71% 30.1 1.2727 1.1356 -10.78% 30.2 1.2779 1.1392 -10.85% 30.3 1.2830 1.1429 -10.92% 30.4 1.2881 1.1465 -10.99% 30.5 1.2933 1.1502 -11.07% 30.6 1.2985 1.1538 -11.14% 30.7 1.3036 1.1575 -11.21% 30.8 1.3088 1.1611 -11.29% 30.9 1.3140 1.1647 -11.36% 31.0 1.3192 1.1684 -11.44% 31.1 1.3245 1.1720 -11.51% 31.2 1.3297 1.1757 -11.58% 31.3 1.3349 1.1793 -11.66% 31.4 1.3402 1.1829 -11.73% 31.5 1.3455 1.1866 -11.81% 31.6 1.3507 1.1902 -11.88% 31.7 1.3560 1.1938 -11.96% 31.8 1.3613 1.1975 -12.04% 31.9 1.3666 1.2011 -12.11% 32.0 1.3719 1.2047 -12.19% 32.1 1.3773 1.2083 -12.27% 32.2 1.3826 1.2120 -12.34% 32.3 1.3880 1.2156 -12.42% 32.4 1.3934 1.2192 -12.50% 32.5 1.3987 1.2228 -12.58% 32.6 1.4041 1.2265 -12.65% 32.7 1.4095 1.2301 -12.73% 32.8 1.4150 1.2337 -12.81% 32.9 1.4204 1.2373 -12.89% 33.0 1.4258 1.2409 -12.97% 33.1 1.4313 1.2445 -13.05% 33.2 1.4367 1.2481 -13.13% 33.3 1.4422 1.2518 -13.21% 33.4 1.4477 1.2554 -13.29% 33.5 1.4532 1.2590 -13.37% 33.6 1.4587 1.2626 -13.45% 33.7 1.4643 1.2662 -13.53% 33.8 1.4698 1.2698 -13.61% 33.9 1.4754 1.2734 -13.69% 34.0 1.4809 1.2770 -13.77% 34.1 1.4865 1.2806 -13.85% 34.2 1.4921 1.2842 -13.93% 34.3 1.4977 1.2878 -14.02% 34.4 1.5033 1.2914 -14.10% 34.5 1.5090 1.2950 -14.18% 34.6 1.5146 1.2986 -14.26% 34.7 1.5203 1.3022 -14.35% 34.8 1.5260 1.3057 -14.43% 34.9 1.5317 1.3093 -14.52% 35.0 1.5374 1.3129 -14.60% 35.1 1.5431 1.3165 -14.68% 35.2 1.5488 1.3201 -14.77% 35.3 1.5546 1.3237 -14.85% 35.4 1.5603 1.3273 -14.94% 35.5 1.5661 1.3308 -15.02% 35.6 1.5719 1.3344 -15.11% 35.7 1.5777 1.3380 -15.19% 35.8 1.5835 1.3416 -15.28% 35.9 1.5893 1.3451 -15.37% 36.0 1.5952 1.3487 -15.45% 36.1 1.6010 1.3523 -15.54% 36.2 1.6069 1.3558 -15.62% 36.3 1.6128 1.3594 -15.71% 36.4 1.6187 1.3630 -15.80% 36.5 1.6246 1.3665 -15.89% 36.6 1.6306 1.3701 -15.97% 36.7 1.6365 1.3737 -16.06% 36.8 1.6425 1.3772 -16.15% 36.9 1.6485 1.3808 -16.24% 37.0 1.6545 1.3843 -16.33% 37.1 1.6605 1.3879 -16.42% 37.2 1.6665 1.3914 -16.51% 37.3 1.6726 1.3950 -16.60% 37.4 1.6786 1.3985 -16.69% 37.5 1.6847 1.4021 -16.78% 37.6 1.6908 1.4056 -16.87% 37.7 1.6969 1.4092 -16.96% 37.8 1.7031 1.4127 -17.05% 37.9 1.7092 1.4163 -17.14% 38.0 1.7154 1.4198 -17.23% 38.1 1.7216 1.4233 -17.32% 38.2 1.7277 1.4269 -17.41% 38.3 1.7340 1.4304 -17.51% 38.4 1.7402 1.4339 -17.60% 38.5 1.7464 1.4375 -17.69% 38.6 1.7527 1.4410 -17.78% 38.7 1.7590 1.4445 -17.88% 38.8 1.7653 1.4481 -17.97% 38.9 1.7716 1.4516 -18.06% 39.0 1.7779 1.4551 -18.16% 39.1 1.7843 1.4586 -18.25% 39.2 1.7907 1.4621 -18.35% 39.3 1.7971 1.4657 -18.44% 39.4 1.8035 1.4692 -18.54% 39.5 1.8099 1.4727 -18.63% 39.6 1.8163 1.4762 -18.73% 39.7 1.8228 1.4797 -18.82% 39.8 1.8293 1.4832 -18.92% 39.9 1.8358 1.4867 -19.01% 40.0 1.8423 1.4902 -19.11% 40.1 1.8488 1.4938 -19.21% 40.2 1.8554 1.4973 -19.30% 40.3 1.8620 1.5008 -19.40% 40.4 1.8686 1.5043 -19.50% 40.5 1.8752 1.5078 -19.60% 40.6 1.8818 1.5112 -19.69% 40.7 1.8885 1.5147 -19.79% 40.8 1.8952 1.5182 -19.89% 40.9 1.9019 1.5217 -19.99% 41.0 1.9086 1.5252 -20.09% 41.1 1.9153 1.5287 -20.19% 41.2 1.9221 1.5322 -20.29% 41.3 1.9289 1.5357 -20.38% 41.4 1.9357 1.5392 -20.48% 41.5 1.9425 1.5426 -20.58% 41.6 1.9493 1.5461 -20.68% 41.7 1.9562 1.5496 -20.79% 41.8 1.9631 1.5531 -20.89% 41.9 1.9700 1.5565 -20.99% 42.0 1.9769 1.5600 -21.09% 42.1 1.9839 1.5635 -21.19% 42.2 1.9908 1.5669 -21.29% 42.3 1.9978 1.5704 -21.39% 42.4 2.0048 1.5739 -21.50% 42.5 2.0119 1.5773 -21.60% 42.6 2.0189 1.5808 -21.70% 42.7 2.0260 1.5842 -21.81% 42.8 2.0331 1.5877 -21.91% 42.9 2.0403 1.5912 -22.01% 43.0 2.0474 1.5946 -22.12% 43.1 2.0546 1.5981 -22.22% 43.2 2.0618 1.6015 -22.32% 43.3 2.0690 1.6050 -22.43% 43.4 2.0763 1.6084 -22.53% 43.5 2.0835 1.6118 -22.64% 43.6 2.0908 1.6153 -22.74% 43.7 2.0981 1.6187 -22.85% 43.8 2.1055 1.6222 -22.96% 43.9 2.1129 1.6256 -23.06% 44.0 2.1202 1.6290 -23.17% 44.1 2.1277 1.6325 -23.27% 44.2 2.1351 1.6359 -23.38% 44.3 2.1426 1.6393 -23.49% 44.4 2.1501 1.6427 -23.60% 44.5 2.1576 1.6462 -23.70% 44.6 2.1651 1.6496 -23.81% 44.7 2.1727 1.6530 -23.92% 44.8 2.1803 1.6564 -24.03% 44.9 2.1879 1.6598 -24.14% 45.0 2.1956 1.6632 -24.25% 45.1 2.2033 1.6666 -24.36% 45.2 2.2110 1.6701 -24.46% 45.3 2.2187 1.6735 -24.57% 45.4 2.2264 1.6769 -24.68% 45.5 2.2342 1.6803 -24.79% 45.6 2.2420 1.6837 -24.90% 45.7 2.2499 1.6871 -25.02% 45.8 2.2578 1.6905 -25.13% 45.9 2.2657 1.6939 -25.24% 46.0 2.2736 1.6973 -25.35% 46.1 2.2815 1.7006 -25.46% 46.2 2.2895 1.7040 -25.57% 46.3 2.2975 1.7074 -25.68% 46.4 2.3056 1.7108 -25.80% 46.5 2.3137 1.7142 -25.91% 46.6 2.3218 1.7176 -26.02% 46.7 2.3299 1.7209 -26.14% 46.8 2.3381 1.7243 -26.25% 46.9 2.3462 1.7277 -26.36% 47.0 2.3545 1.7311 -26.48% 47.1 2.3627 1.7344 -26.59% 47.2 2.3710 1.7378 -26.71% 47.3 2.3793 1.7412 -26.82% 47.4 2.3877 1.7445 -26.94% 47.5 2.3961 1.7479 -27.05% 47.6 2.4045 1.7512 -27.17% 47.7 2.4129 1.7546 -27.28% 47.8 2.4214 1.7580 -27.40% 47.9 2.4299 1.7613 -27.52% 48.0 2.4384 1.7647 -27.63% 48.1 2.4470 1.7680 -27.75% 48.2 2.4556 1.7714 -27.87% 48.3 2.4643 1.7747 -27.98% 48.4 2.4729 1.7780 -28.10% 48.5 2.4816 1.7814 -28.22% 48.6 2.4904 1.7847 -28.34% 48.7 2.4992 1.7880 -28.45% 48.8 2.5080 1.7914 -28.57% 48.9 2.5168 1.7947 -28.69% 49.0 2.5257 1.7980 -28.81% 49.1 2.5346 1.8014 -28.93% 49.2 2.5436 1.8047 -29.05% 49.3 2.5526 1.8080 -29.17% 49.4 2.5616 1.8113 -29.29% 49.5 2.5707 1.8146 -29.41% 49.6 2.5798 1.8179 -29.53% 49.7 2.5889 1.8213 -29.65% 49.8 2.5981 1.8246 -29.77% 49.9 2.6073 1.8279 -29.89% 50.0 2.6166 1.8312 -30.02% 50.1 2.6259 1.8345 -30.14% 50.2 2.6352 1.8378 -30.26% 50.3 2.6446 1.8411 -30.38% 50.4 2.6540 1.8444 -30.51% 50.5 2.6634 1.8477 -30.63% 50.6 2.6729 1.8510 -30.75% 50.7 2.6825 1.8542 -30.88% 50.8 2.6920 1.8575 -31.00% 50.9 2.7017 1.8608 -31.12% 51.0 2.7113 1.8641 -31.25% 51.1 2.7210 1.8674 -31.37% 51.2 2.7307 1.8706 -31.50% 51.3 2.7405 1.8739 -31.62% 51.4 2.7504 1.8772 -31.75% 51.5 2.7602 1.8805 -31.87% 51.6 2.7701 1.8837 -32.00% 51.7 2.7801 1.8870 -32.12% 51.8 2.7901 1.8903 -32.25% 51.9 2.8001 1.8935 -32.38% 52.0 2.8102 1.8968 -32.50% 52.1 2.8203 1.9000 -32.63% 52.2 2.8305 1.9033 -32.76% 52.3 2.8407 1.9065 -32.89% 52.4 2.8510 1.9098 -33.01% 52.5 2.8613 1.9130 -33.14% 52.6 2.8717 1.9163 -33.27% 52.7 2.8821 1.9195 -33.40% 52.8 2.8926 1.9227 -33.53% 52.9 2.9031 1.9260 -33.66% 53.0 2.9136 1.9292 -33.79% 53.1 2.9242 1.9324 -33.92% 53.2 2.9349 1.9356 -34.05% 53.3 2.9456 1.9389 -34.18% 53.4 2.9563 1.9421 -34.31% 53.5 2.9672 1.9453 -34.44% 53.6 2.9780 1.9485 -34.57% 53.7 2.9889 1.9517 -34.70% 53.8 2.9999 1.9550 -34.83% 53.9 3.0109 1.9582 -34.96% 54.0 3.0220 1.9614 -35.10% 54.1 3.0331 1.9646 -35.23% 54.2 3.0442 1.9678 -35.36% 54.3 3.0555 1.9710 -35.49% 54.4 3.0668 1.9742 -35.63% 54.5 3.0781 1.9774 -35.76% 54.6 3.0895 1.9805 -35.89% 54.7 3.1009 1.9837 -36.03% 54.8 3.1124 1.9869 -36.16% 54.9 3.1240 1.9901 -36.30% 55.0 3.1356 1.9933 -36.43% 55.1 3.1473 1.9965 -36.57% 55.2 3.1590 1.9996 -36.70% 55.3 3.1708 2.0028 -36.84% 55.4 3.1827 2.0060 -36.97% 55.5 3.1946 2.0091 -37.11% 55.6 3.2066 2.0123 -37.24% 55.7 3.2186 2.0155 -37.38% 55.8 3.2307 2.0186 -37.52% 55.9 3.2429 2.0218 -37.65% 56.0 3.2551 2.0249 -37.79% 56.1 3.2674 2.0281 -37.93% 56.2 3.2797 2.0312 -38.07% 56.3 3.2921 2.0344 -38.21% 56.4 3.3046 2.0375 -38.34% 56.5 3.3172 2.0406 -38.48% 56.6 3.3298 2.0438 -38.62% 56.7 3.3424 2.0469 -38.76% 56.8 3.3552 2.0500 -38.90% 56.9 3.3680 2.0532 -39.04% 57.0 3.3809 2.0563 -39.18% 57.1 3.3938 2.0594 -39.32% 57.2 3.4069 2.0625 -39.46% 57.3 3.4200 2.0656 -39.60% 57.4 3.4331 2.0687 -39.74% 57.5 3.4464 2.0719 -39.88% 57.6 3.4597 2.0750 -40.02% 57.7 3.4731 2.0781 -40.17% 57.8 3.4865 2.0812 -40.31% 57.9 3.5001 2.0843 -40.45% 58.0 3.5137 2.0874 -40.59% 58.1 3.5273 2.0905 -40.74% 58.2 3.5411 2.0935 -40.88% 58.3 3.5549 2.0966 -41.02% 58.4 3.5689 2.0997 -41.17% 58.5 3.5829 2.1028 -41.31% 58.6 3.5969 2.1059 -41.45% 58.7 3.6111 2.1089 -41.60% 58.8 3.6253 2.1120 -41.74% 58.9 3.6397 2.1151 -41.89% 59.0 3.6541 2.1182 -42.03% 59.1 3.6685 2.1212 -42.18% 59.2 3.6831 2.1243 -42.32% 59.3 3.6978 2.1273 -42.47% 59.4 3.7125 2.1304 -42.62% 59.5 3.7274 2.1334 -42.76% 59.6 3.7423 2.1365 -42.91% 59.7 3.7573 2.1395 -43.06% 59.8 3.7724 2.1426 -43.20% 59.9 3.7876 2.1456 -43.35% 60.0 3.8029 2.1486 -43.50% 60.1 3.8182 2.1517 -43.65% 60.2 3.8337 2.1547 -43.80% 60.3 3.8493 2.1577 -43.94% 60.4 3.8649 2.1608 -44.09% 60.5 3.8807 2.1638 -44.24% 60.6 3.8965 2.1668 -44.39% 60.7 3.9125 2.1698 -44.54% 60.8 3.9285 2.1728 -44.69% 60.9 3.9447 2.1758 -44.84% 61.0 3.9609 2.1788 -44.99% 61.1 3.9773 2.1818 -45.14% 61.2 3.9937 2.1848 -45.29% 61.3 4.0103 2.1878 -45.44% 61.4 4.0270 2.1908 -45.60% 61.5 4.0438 2.1938 -45.75% 61.6 4.0606 2.1968 -45.90% 61.7 4.0776 2.1998 -46.05% 61.8 4.0947 2.2028 -46.21% 61.9 4.1120 2.2057 -46.36% 62.0 4.1293 2.2087 -46.51% 62.1 4.1467 2.2117 -46.66% 62.2 4.1643 2.2146 -46.82% 62.3 4.1820 2.2176 -46.97% 62.4 4.1998 2.2206 -47.13% 62.5 4.2177 2.2235 -47.28% 62.6 4.2357 2.2265 -47.44% 62.7 4.2539 2.2294 -47.59% 62.8 4.2721 2.2324 -47.75% 62.9 4.2905 2.2353 -47.90% 63.0 4.3091 2.2383 -48.06% 63.1 4.3277 2.2412 -48.21% 63.2 4.3465 2.2441 -48.37% 63.3 4.3654 2.2471 -48.53% 63.4 4.3845 2.2500 -48.68% 63.5 4.4036 2.2529 -48.84% 63.6 4.4230 2.2558 -49.00% 63.7 4.4424 2.2587 -49.15% 63.8 4.4620 2.2617 -49.31% 63.9 4.4817 2.2646 -49.47% 64.0 4.5016 2.2675 -49.63% 64.1 4.5216 2.2704 -49.79% 64.2 4.5418 2.2733 -49.95% 64.3 4.5621 2.2762 -50.11% 64.4 4.5825 2.2791 -50.27% 64.5 4.6031 2.2820 -50.43% 64.6 4.6239 2.2848 -50.59% 64.7 4.6448 2.2877 -50.75% 64.8 4.6658 2.2906 -50.91% 64.9 4.6871 2.2935 -51.07% 65.0 4.7084 2.2964 -51.23% 65.1 4.7300 2.2992 -51.39% 65.2 4.7517 2.3021 -51.55% 65.3 4.7735 2.3050 -51.71% 65.4 4.7956 2.3078 -51.88% 65.5 4.8178 2.3107 -52.04% 65.6 4.8401 2.3135 -52.20% 65.7 4.8627 2.3164 -52.36% 65.8 4.8854 2.3192 -52.53% 65.9 4.9083 2.3221 -52.69% 66.0 4.9313 2.3249 -52.85% 66.1 4.9546 2.3277 -53.02% 66.2 4.9780 2.3306 -53.18% 66.3 5.0017 2.3334 -53.35% 66.4 5.0255 2.3362 -53.51% 66.5 5.0495 2.3390 -53.68% 66.6 5.0737 2.3418 -53.84% 66.7 5.0981 2.3447 -54.01% 66.8 5.1227 2.3475 -54.17% 66.9 5.1475 2.3503 -54.34% 67.0 5.1725 2.3531 -54.51% 67.1 5.1977 2.3559 -54.67% 67.2 5.2231 2.3587 -54.84% 67.3 5.2487 2.3615 -55.01% 67.4 5.2745 2.3642 -55.18% 67.5 5.3006 2.3670 -55.34% 67.6 5.3269 2.3698 -55.51% 67.7 5.3534 2.3726 -55.68% 67.8 5.3801 2.3753 -55.85% 67.9 5.4071 2.3781 -56.02% 68.0 5.4342 2.3809 -56.19% 68.1 5.4617 2.3836 -56.36% 68.2 5.4893 2.3864 -56.53% 68.3 5.5172 2.3891 -56.70% 68.4 5.5454 2.3919 -56.87% 68.5 5.5738 2.3946 -57.04% 68.6 5.6025 2.3974 -57.21% 68.7 5.6314 2.4001 -57.38% 68.8 5.6605 2.4029 -57.55% 68.9 5.6900 2.4056 -57.72% 69.0 5.7197 2.4083 -57.89% 69.1 5.7496 2.4110 -58.07% 69.2 5.7799 2.4137 -58.24% 69.3 5.8104 2.4165 -58.41% 69.4 5.8412 2.4192 -58.58% 69.5 5.8723 2.4219 -58.76% 69.6 5.9037 2.4246 -58.93% 69.7 5.9354 2.4273 -59.11% 69.8 5.9674 2.4300 -59.28% 69.9 5.9997 2.4327 -59.45% 70.0 6.0323 2.4354 -59.63% 70.1 6.0652 2.4380 -59.80% 70.2 6.0985 2.4407 -59.98% 70.3 6.1320 2.4434 -60.15% 70.4 6.1659 2.4460 -60.33% 70.5 6.2001 2.4487 -60.51% 70.6 6.2347 2.4513 -60.68% 70.7 6.2696 2.4540 -60.86% 70.8 6.3048 2.4566 -61.04% 70.9 6.3404 2.4592 -61.21% 71.0 6.3764 2.4619 -61.39% 71.1 6.4128 2.4645 -61.57% 71.2 6.4495 2.4671 -61.75% 71.3 6.4866 2.4698 -61.92% 71.4 6.5240 2.4724 -62.10% 71.5 6.5619 2.4750 -62.28% 71.6 6.6001 2.4776 -62.46% 71.7 6.6388 2.4802 -62.64% 71.8 6.6779 2.4828 -62.82% 71.9 6.7174 2.4854 -63.00% 72.0 6.7573 2.4880 -63.18% 72.1 6.7976 2.4906 -63.36% 72.2 6.8384 2.4932 -63.54% 72.3 6.8797 2.4958 -63.72% 72.4 6.9213 2.4983 -63.90% 72.5 6.9635 2.5009 -64.09% 72.6 7.0061 2.5035 -64.27% 72.7 7.0492 2.5060 -64.45% 72.8 7.0928 2.5086 -64.63% 72.9 7.1368 2.5111 -64.81% 73.0 7.1814 2.5137 -65.00% 73.1 7.2265 2.5162 -65.18% 73.2 7.2721 2.5188 -65.36% 73.3 7.3182 2.5213 -65.55% 73.4 7.3649 2.5238 -65.73% 73.5 7.4121 2.5264 -65.92% 73.6 7.4599 2.5289 -66.10% 73.7 7.5083 2.5314 -66.28% 73.8 7.5572 2.5339 -66.47% 73.9 7.6068 2.5364 -66.66% 74.0 7.6569 2.5390 -66.84% 74.1 7.7076 2.5415 -67.03% 74.2 7.7590 2.5440 -67.21% 74.3 7.8110 2.5464 -67.40% 74.4 7.8637 2.5489 -67.59% 74.5 7.9170 2.5514 -67.77% 74.6 7.9710 2.5539 -67.96% 74.7 8.0257 2.5564 -68.15% 74.8 8.0811 2.5588 -68.34% 74.9 8.1372 2.5613 -68.52% 75.0 8.1940 2.5638 -68.71% 75.1 8.2516 2.5662 -68.90% 75.2 8.3099 2.5687 -69.09% 75.3 8.3690 2.5711 -69.28% 75.4 8.4290 2.5736 -69.47% 75.5 8.4897 2.5760 -69.66% 75.6 8.5512 2.5784 -69.85% 75.7 8.6136 2.5809 -70.04% 75.8 8.6768 2.5833 -70.23% 75.9 8.7410 2.5857 -70.42% 76.0 8.8060 2.5881 -70.61% 76.1 8.8719 2.5906 -70.80% 76.2 8.9388 2.5930 -70.99% 76.3 9.0066 2.5954 -71.18% 76.4 9.0754 2.5978 -71.38% 76.5 9.1452 2.6002 -71.57% 76.6 9.2161 2.6025 -71.76% 76.7 9.2879 2.6049 -71.95% 76.8 9.3609 2.6073 -72.15% 76.9 9.4349 2.6097 -72.34% 77.0 9.5101 2.6121 -72.53% 77.1 9.5864 2.6144 -72.73% 77.2 9.6639 2.6168 -72.92% 77.3 9.7425 2.6191 -73.12% 77.4 9.8224 2.6215 -73.31% 77.5 9.9036 2.6238 -73.51% 77.6 9.9861 2.6262 -73.70% 77.7 10.0698 2.6285 -73.90% 77.8 10.1549 2.6309 -74.09% 77.9 10.2415 2.6332 -74.29% 78.0 10.3294 2.6355 -74.49% 78.1 10.4188 2.6378 -74.68% 78.2 10.5096 2.6401 -74.88% 78.3 10.6020 2.6424 -75.08% 78.4 10.6960 2.6448 -75.27% 78.5 10.7916 2.6471 -75.47% 78.6 10.8889 2.6493 -75.67% 78.7 10.9878 2.6516 -75.87% 78.8 11.0885 2.6539 -76.07% 78.9 11.1910 2.6562 -76.26% 79.0 11.2953 2.6585 -76.46% 79.1 11.4015 2.6608 -76.66% 79.2 11.5096 2.6630 -76.86% 79.3 11.6198 2.6653 -77.06% 79.4 11.7320 2.6675 -77.26% 79.5 11.8463 2.6698 -77.46% 79.6 11.9628 2.6720 -77.66% 79.7 12.0815 2.6743 -77.86% 79.8 12.2025 2.6765 -78.07% 79.9 12.3259 2.6788 -78.27% 80.0 12.4517 2.6810 -78.47% 80.1 12.5801 2.6832 -78.67% 80.2 12.7110 2.6855 -78.87% 80.3 12.8447 2.6877 -79.08% 80.4 12.9810 2.6899 -79.28% 80.5 13.1203 2.6921 -79.48% 80.6 13.2624 2.6943 -79.68% 80.7 13.4076 2.6965 -79.89% 80.8 13.5559 2.6988 -80.09% 80.9 13.7074 2.7010 -80.30% 81.0 13.8623 2.7031 -80.50% 81.1 14.0207 2.7053 -80.70% 81.2 14.1826 2.7075 -80.91% 81.3 14.3482 2.7097 -81.11% 81.4 14.5176 2.7119 -81.32% 81.5 14.6910 2.7140 -81.53% 81.6 14.8684 2.7162 -81.73% 81.7 15.0501 2.7184 -81.94% 81.8 15.2363 2.7205 -82.14% 81.9 15.4269 2.7227 -82.35% 82.0 15.6223 2.7248 -82.56% 82.1 15.8227 2.7270 -82.77% 82.2 16.0281 2.7291 -82.97% 82.3 16.2388 2.7312 -83.18% 82.4 16.4551 2.7334 -83.39% 82.5 16.6771 2.7355 -83.60% 82.6 16.9050 2.7376 -83.81% 82.7 17.1392 2.7397 -84.01% 82.8 17.3798 2.7418 -84.22% 82.9 17.6271 2.7439 -84.43% 83.0 17.8815 2.7460 -84.64% 83.1 18.1433 2.7481 -84.85% 83.2 18.4127 2.7502 -85.06% 83.3 18.6901 2.7523 -85.27% 83.4 18.9758 2.7544 -85.48% 83.5 19.2703 2.7564 -85.70% 83.6 19.5740 2.7585 -85.91% 83.7 19.8873 2.7606 -86.12% 83.8 20.2106 2.7626 -86.33% 83.9 20.5445 2.7647 -86.54% 84.0 20.8895 2.7667 -86.76% 84.1 21.2462 2.7688 -86.97% 84.2 21.6151 2.7708 -87.18% 84.3 21.9968 2.7728 -87.39% 84.4 22.3922 2.7749 -87.61% 84.5 22.8019 2.7769 -87.82% 84.6 23.2268 2.7789 -88.04% 84.7 23.6676 2.7809 -88.25% 84.8 24.1253 2.7829 -88.46% 84.9 24.6010 2.7849 -88.68% 85.0 25.0956 2.7869 -88.89% 85.1 25.6103 2.7889 -89.11% 85.2 26.1464 2.7909 -89.33% 85.3 26.7053 2.7929 -89.54% 85.4 27.2885 2.7949 -89.76% 85.5 27.8975 2.7968 -89.97% 85.6 28.5341 2.7988 -90.19% 85.7 29.2002 2.8007 -90.41% 85.8 29.8981 2.8027 -90.63% 85.9 30.6299 2.8047 -90.84% 86.0 31.3982 2.8066 -91.06% 86.1 32.2059 2.8085 -91.28% 86.2 33.0560 2.8105 -91.50% 86.3 33.9520 2.8124 -91.72% 86.4 34.8977 2.8143 -91.94% 86.5 35.8974 2.8162 -92.15% 86.6 36.9558 2.8181 -92.37% 86.7 38.0782 2.8201 -92.59% 86.8 39.2708 2.8220 -92.81% 86.9 40.5402 2.8239 -93.03% 87.0 41.8941 2.8257 -93.26% 87.1 43.3413 2.8276 -93.48% 87.2 44.8918 2.8295 -93.70% 87.3 46.5571 2.8314 -93.92% 87.4 48.3504 2.8332 -94.14% 87.5 50.2870 2.8351 -94.36% 87.6 52.3849 2.8370 -94.58% 87.7 54.6651 2.8388 -94.81% 87.8 57.1525 2.8407 -95.03% 87.9 59.8767 2.8425 -95.25% 88.0 62.8731 2.8443 -95.48% 88.1 66.1848 2.8462 -95.70% 88.2 69.8644 2.8480 -95.92% 88.3 73.9767 2.8498 -96.15% 88.4 78.6029 2.8516 -96.37% 88.5 83.8457 2.8534 -96.60% 88.6 89.8373 2.8552 -96.82% 88.7 96.7506 2.8570 -97.05% 88.8 104.8158 2.8588 -97.27% 88.9 114.3472 2.8606 -97.50% 89.0 125.7845 2.8624 -97.72% 89.1 139.7633 2.8642 -97.95% 89.2 157.2364 2.8659 -98.18% 89.3 179.7015 2.8677 -98.40% 89.4 209.6545 2.8695 -98.63% 89.5 251.5883 2.8712 -98.86% 89.6 314.4882 2.8730 -99.09% 89.7 403.3576 2.8747 -99.29% 89.8 314.4882 2.8764 -99.49% 89.9 225.6187 2.8765 -99.69% 90.0 136.7493 2.8765 -99.89% 90.1 47.8799 2.8833 -100.09% 90.2 -40.9896 2.8833 -100.29% 90.3 -403.3576 2.8850 -100.72% 90.4 -314.4882 2.8866 -100.92% 90.5 -251.5883 2.8883 -101.15% 90.6 -209.6545 2.8900 -101.38% 90.7 -179.7015 2.8916 -101.61% 90.8 -157.2364 2.8933 -101.84% 90.9 -139.7633 2.8949 -102.07% 91.0 -125.7845 2.8966 -102.30% 91.1 -114.3472 2.8982 -102.53% 91.2 -104.8158 2.8998 -102.77% 91.3 -96.7506 2.9014 -103.00% 91.4 -89.8373 2.9031 -103.23% 91.5 -83.8457 2.9047 -103.46% 91.6 -78.6029 2.9063 -103.70% 91.7 -73.9767 2.9079 -103.93% 91.8 -69.8644 2.9095 -104.16% 91.9 -66.1848 2.9110 -104.40% 92.0 -62.8731 2.9126 -104.63% 92.1 -59.8767 2.9142 -104.87% 92.2 -57.1525 2.9158 -105.10% 92.3 -54.6651 2.9173 -105.34% 92.4 -52.3849 2.9189 -105.57% 92.5 -50.2870 2.9204 -105.81% 92.6 -48.3504 2.9220 -106.04% 92.7 -46.5571 2.9235 -106.28% 92.8 -44.8918 2.9251 -106.52% 92.9 -43.3413 2.9266 -106.75% 93.0 -41.8941 2.9281 -106.99% 93.1 -40.5402 2.9296 -107.23% 93.2 -39.2708 2.9311 -107.46% 93.3 -38.0782 2.9326 -107.70% 93.4 -36.9558 2.9341 -107.94% 93.5 -35.8974 2.9356 -108.18% 93.6 -34.8977 2.9371 -108.42% 93.7 -33.9520 2.9386 -108.66% 93.8 -33.0560 2.9401 -108.89% 93.9 -32.2059 2.9415 -109.13% 94.0 -31.3982 2.9430 -109.37% 94.1 -30.6299 2.9445 -109.61% 94.2 -29.8981 2.9459 -109.85% 94.3 -29.2002 2.9474 -110.09% 94.4 -28.5341 2.9488 -110.33% 94.5 -27.8975 2.9502 -110.58% 94.6 -27.2885 2.9517 -110.82% 94.7 -26.7053 2.9531 -111.06% 94.8 -26.1464 2.9545 -111.30% 94.9 -25.6103 2.9559 -111.54% 95.0 -25.0956 2.9573 -111.78% 95.1 -24.6010 2.9587 -112.03% 95.2 -24.1253 2.9601 -112.27% 95.3 -23.6676 2.9615 -112.51% 95.4 -23.2268 2.9629 -112.76% 95.5 -22.8019 2.9642 -113.00% 95.6 -22.3922 2.9656 -113.24% 95.7 -21.9968 2.9670 -113.49% 95.8 -21.6151 2.9683 -113.73% 95.9 -21.2462 2.9697 -113.98% 96.0 -20.8895 2.9710 -114.22% 96.1 -20.5445 2.9723 -114.47% 96.2 -20.2106 2.9737 -114.71% 96.3 -19.8873 2.9750 -114.96% 96.4 -19.5740 2.9763 -115.21% 96.5 -19.2703 2.9776 -115.45% 96.6 -18.9758 2.9789 -115.70% 96.7 -18.6901 2.9802 -115.95% 96.8 -18.4127 2.9815 -116.19% 96.9 -18.1433 2.9828 -116.44% 97.0 -17.8815 2.9841 -116.69% 97.1 -17.6271 2.9854 -116.94% 97.2 -17.3798 2.9866 -117.18% 97.3 -17.1392 2.9879 -117.43% 97.4 -16.9050 2.9892 -117.68% 97.5 -16.6771 2.9904 -117.93% 97.6 -16.4551 2.9917 -118.18% 97.7 -16.2388 2.9929 -118.43% 97.8 -16.0281 2.9941 -118.68% 97.9 -15.8227 2.9954 -118.93% 98.0 -15.6223 2.9966 -119.18% 98.1 -15.4269 2.9978 -119.43% 98.2 -15.2363 2.9990 -119.68% 98.3 -15.0501 3.0002 -119.93% 98.4 -14.8684 3.0014 -120.19% 98.5 -14.6910 3.0026 -120.44% 98.6 -14.5176 3.0038 -120.69% 98.7 -14.3482 3.0050 -120.94% 98.8 -14.1826 3.0061 -121.20% 98.9 -14.0207 3.0073 -121.45% 99.0 -13.8623 3.0085 -121.70% 99.1 -13.7074 3.0096 -121.96% 99.2 -13.5559 3.0108 -122.21% 99.3 -13.4076 3.0119 -122.46% 99.4 -13.2624 3.0131 -122.72% 99.5 -13.1203 3.0142 -122.97% 99.6 -12.9810 3.0153 -123.23% 99.7 -12.8447 3.0165 -123.48% 99.8 -12.7110 3.0176 -123.74% 99.9 -12.5801 3.0187 -124.00% 100.0 -12.4517 3.0198 -124.25% 100.1 -12.3259 3.0209 -124.51% 100.2 -12.2025 3.0220 -124.77% 100.3 -12.0815 3.0231 -125.02% 100.4 -11.9628 3.0241 -125.28% 100.5 -11.8463 3.0252 -125.54% 100.6 -11.7320 3.0263 -125.80% 100.7 -11.6198 3.0273 -126.05% 100.8 -11.5096 3.0284 -126.31% 100.9 -11.4015 3.0294 -126.57% 101.0 -11.2953 3.0305 -126.83% 101.1 -11.1910 3.0315 -127.09% 101.2 -11.0885 3.0326 -127.35% 101.3 -10.9878 3.0336 -127.61% 101.4 -10.8889 3.0346 -127.87% 101.5 -10.7916 3.0356 -128.13% 101.6 -10.6960 3.0366 -128.39% 101.7 -10.6020 3.0376 -128.65% 101.8 -10.5096 3.0386 -128.91% 101.9 -10.4188 3.0396 -129.17% 102.0 -10.3294 3.0406 -129.44% 102.1 -10.2415 3.0416 -129.70% 102.2 -10.1549 3.0425 -129.96% 102.3 -10.0698 3.0435 -130.22% 102.4 -9.9861 3.0445 -130.49% 102.5 -9.9036 3.0454 -130.75% 102.6 -9.8224 3.0464 -131.01% 102.7 -9.7425 3.0473 -131.28% 102.8 -9.6639 3.0483 -131.54% 102.9 -9.5864 3.0492 -131.81% 103.0 -9.5101 3.0501 -132.07% 103.1 -9.4349 3.0510 -132.34% 103.2 -9.3609 3.0519 -132.60% 103.3 -9.2879 3.0529 -132.87% 103.4 -9.2161 3.0538 -133.14% 103.5 -9.1452 3.0547 -133.40% 103.6 -9.0754 3.0555 -133.67% 103.7 -9.0066 3.0564 -133.94% 103.8 -8.9388 3.0573 -134.20% 103.9 -8.8719 3.0582 -134.47% 104.0 -8.8060 3.0590 -134.74%
In addition, I'm also confused about the parameters "s", "m", "pitch_in_mm", "f_in_mm", could you tell me what are these parameters stand for?
Jianxiong Hua
