[FAQ] 66AK2E05: How to build and run the platform test on K2E EVM ?
Part Number: 66AK2E05
  • How to build and run the platform test on K2H EVM ?
    Pre-requisite :
    1. Download and install PROCESSOR-SDK-RTOS-K2E  06_03_00_106 from http://software-dl.ti.com/processor-sdk-rtos/esd/K2E/latest/index_FDS.html
    ( Please install the SDK in the recommended path: C:\ti\)
    2. Download and install CCS 9.3 , https://www.ti.com/tool/download/CCSTUDIO/9.3.0.00012
    ( Please install in the recommended path: C:\ti\)
    3. Rebuild the PDK and SDK which in turn will build all the necessary CSL library components etc. Follow the steps given below.
    https://e2e.ti.com/support/processors-group/processors/f/processors-forum/1137599/faq-66ak2e05-how-to-re-build-the-pdk-and-sdk-of-processor-sdk-rtos-k2e-6-3-for-k2e
    Step1: Check the Platform-test source code after installation
    a) Platform-test source code will become available once the " processor_sdk_rtos_k2e_6_03_00_106 " package (above-step) is installed.
    b) "Platform-Lib" is a dependency for Platform-test.
    c) The location of source code of Platform-test and platform-lib is at
    C:\ti\pdk_k2e_4_0_16\packages\ti\platform\evmc6657l\platform_test\src
    C:\ti\pdk_k2e_4_0_16\packages\ti\platform\evmc6657l\platform_lib\src
    d)  Open the platform.c located at C:\ti\pdk_k2e_4_0_16\packages\ti\platform\evmk2h\platform_lib\src\platform.c
           Go to line number : 530  comment the initialization and configuration code of serdes and SGMII
    if (p_flags->phy) {
    configSerdes();
    Init_SGMII(0);
    //Init_SGMII(1);
    e) save and close.
    Step 2: Import the "Platform test example" into CCS 9.3 and re-build
    Please follow the video attached and do the steps given below for ease of use.
    a) Import the "Platform-Lib" CCS project located at "C:\ti\pdk_k2e_4_0_16\packages\ti\platform\evmk2h\platform_lib" into CCS and rebuild
    b) Import the "Platform-Lib" CCS project located at "C:\ti\pdk_k2e_4_0_16\packages\ti\platform\evmk2h\platform_test" into CCS and rebuild
    If face any error in building the platform lib or platform test, please follow the steps given in the below FAQs.
    [FAQ] 66AK2E05: How to re-solve the build Errors in the Platform test example of PDK in Processor SDK 6.3 for K2E ? - Processors forum - Processors - TI E2E support forums
    Step 3: Run the "Platform test " on the C6657 EVM
            In your evmkEh  - board ----> You should put the DIP Switch settings in "No boot mode"  to connect to the CCS.
            That is  ------> DIP SW1 : 1 1 1 1
    Connection details:
    1. Power cord
    2. XDS- Emulator - Mini usb cable between usb port - J3 -  k2H EVM and PC-running Windows-10
    1. Open CCS
    2. Launch the target configuration file for evmK2E . ( If new to this, Follow this FAQ )
    [FAQ] 66AK2E05: How to create "Target configuration" and do "Test connection" on K2E EVM. - Processors forum - Processors - TI E2E support forums
    3. Do "Connect target and run gel file " ( If new to this, Follow this FAQ :
    [FAQ] 66AK2E05: How to load and run the DSP gel file on K2E EVM - Processors forum - Processors - TI E2E support forums
    4.  Load the platform_test_evmk2h.out into core0 of k2E-evm -- ( FOLLOW THE STEPS IN THE VIDEO BELOW )
    5. Run and observe the output messages, as per the video below.
    Console output messages in CCS
    [C66xx_0] p_info->version	= 3.00.00.09
    p_info->cpu.core_count	= 1
    p_info->cpu.name	= TCI6636K2E
    p_info->cpu.id	= 21
    p_info->cpu.revision_id	= 0
    p_info->cpu.silicon_revision_major	= 0
    p_info->cpu.silicon_revision_minor	= 0
    p_info->cpu.megamodule_revision_major	= 9
    p_info->cpu.megamodule_revision_minor	= 3
    p_info->cpu.endian	= 0
    p_info->board_name	= TMDXEVM6636K2E
    p_info->frequency	= 1000
    p_info->board_rev	= 0
    p_info->led[PLATFORM_USER_LED_CLASS].count	= 4
    p_info->led[PLATFORM_SYSTEM_LED_CLASS].count	= 0
    p_info->emac.port_count	= 2
    EMAC port 0 connected to the PHY.
    MAC Address = b4:99:4c:09:60:28
    EMAC port 1 connected to the PHY.
    NAND Device:
    p_device->device_id	= 172
    p_device->manufacturer_id	= 44
    p_device->width	= 8
    p_device->block_count	= 4096
    p_device->page_count	= 64
    p_device->page_size	= 2048
    p_device->spare_size	= 64
    p_device->column	= 2048
    p_device->handle	= 11484
    p_device->flags	= 0
    p_device->bboffset	= 5
    Bad Block Table (only bad block numbers shown):
    NOR Device:
    p_device->device_id	= 47896
    p_device->manufacturer_id	= 32
    p_device->width	= 8
    p_device->block_count	= 256
    p_device->page_count	= 256
    p_device->page_size	= 256
    p_device->spare_size	= 0
    p_device->handle	= 47896
    p_device->flags	= 0
    p_device->bboffset	= 0
    EEPROM Device (@ 0x50):
    p_device->device_id	= 80
    p_device->manufacturer_id	= 1
    p_device->width	= 8
    p_device->block_count	= 1
    p_device->page_count	= 1
    p_device->page_size	= 65536
    p_device->handle	= 80
    p_device->flags	= 0
    EEPROM Device (@ 0x51):
    p_device->device_id	= 81
    p_device->width	= 8
    p_device->handle	= 81
    p_device->flags	= 0
    Current core id is 0
    User switch 1 state is OFF
    EEPROM test start
    test_eeprom: passed
    EEPROM test complete
    NAND test start
    test_nand: passed
    NAND test complete
    NOR test start
    test_nor: passed
    NOR test complete
    LED test start
    LED 0 ON
    LED 0 OFF
    LED 0 ON
    LED 1 ON
    LED 1 OFF
    LED 1 ON
    LED 2 ON
    LED 2 OFF
    LED 2 ON
    LED 3 ON
    LED 3 OFF
    LED 3 ON
    LED test complete
    External memory test start
    External memory test passed
    External memory test complete
    Shankari G
