FFT function in DSPLIB C674x returns wrong result
Other Parts Discussed in Thread: OMAP-L137
Hi all,
I'm using OMAP-L137 evm board.
Starting from example /src/DSPF_sp_fftSPxSP/DSPF_sp_fftSPxSP.pjt distributed with DSPLIB C674x v. 1.1,
I created a new project (attached) for testing purpose, but I don't understand why function returns a wrong fft result.
Project uses a reference function to compute twiddle array, the same included in the demostration app as suggested by http://wiki.davincidsp.com/index.php/C674x_DSPLIB#DSPF_sp_fftSPxSP_.28Mixed_Radix_Forward_FFT_with_Bit_Reversal.29
Any idea or suggestion?
PS: Project includes library and header file.
fft.zip
  • Hi Diego,
    I'm not a fft expert, but here is my suggestion - try using the C equivalent (DSPF_sp_fftSPxSP_cn) instead and see the results. If it is a problem with your inputs, you can step trough the C equivalent code and see what could be wrong.
  • I have run this data through the natural C and legacy ASM functions (both included in the demo project), and they all return the same result.  Without performing alternate calculations (i.e. running an FFT in MATLAB or similar), I won't comment on the accuracy of the result.  Does the result you get from the DSPLIB disagree with some other FFT algorithm?
  • I try the C fft algorithm in Visual C++ platform to verify its correctness and it works:
    It returns the same SCILAB fft result.
    Down here I've pasted a report of various tests ( %i = immaginary unit )
     VISUAL C++
    --INPUT---
    8.5000000000000000 + (0.0000000000000000) * %i
    -0.5000000000000000 + (-2.5136697292327881) * %i
    -0.5000000000000000 + (-1.2071068286895752) * %i
    -0.5000000000000000 + (-0.7483028769493103) * %i
    -0.5000000000000000 + (-0.5000000000000000) * %i
    -0.5000000000000000 + (-0.3340893089771271) * %i
    -0.5000000000000000 + (-0.2071067839860916) * %i
    -0.5000000000000000 + (-0.0994561836123466) * %i
    -0.5000000000000000 + (0.0000000000000000) * %i
    -0.5000000000000000 + (0.0994561836123466) * %i
    -0.5000000000000000 + (0.2071067839860916) * %i
    -0.5000000000000000 + (0.3340893089771271) * %i
    -0.5000000000000000 + (0.5000000000000000) * %i
    -0.5000000000000000 + (0.7483028769493103) * %i
    -0.5000000000000000 + (1.2071068286895752) * %i
    -0.5000000000000000 + (2.5136697292327881) * %i
    --OUTPUT (C function)---
    1.0000000000000000 + (0.0000000000000000) * %i
    2.0000000000000000 + (0.0000002384185791) * %i
    3.0000000000000000 + (0.0000003258413699) * %i
    4.0000004768371582 + (0.0000000000000000) * %i
    5.0000000000000000 + (0.0000000000000000) * %i
    6.0000000000000000 + (0.0000001192092896) * %i
    7.0000000000000000 + (0.0000000317865130) * %i
    8.0000000000000000 + (0.0000000000000000) * %i
    9.0000000000000000 + (0.0000000000000000) * %i
    10.0000000000000000 + (-0.0000002384185791) * %i
    11.0000000000000000 + (-0.0000001509958025) * %i
    12.0000000000000000 + (0.0000000000000000) * %i
    13.0000000000000000 + (0.0000000000000000) * %i
    14.0000000000000000 + (-0.0000001192092896) * %i
    15.0000000000000000 + (-0.0000002066320661) * %i
    16.0000000000000000 + (0.0000000000000000) * %i
    done
     SCILAB
     x  =
        8.5
      - 0.5 - 2.5136697i
      - 0.5 - 1.2071068i
      - 0.5 - 0.7483029i
      - 0.5 - 0.5i
      - 0.5 - 0.3340893i
      - 0.5 - 0.2071068i
      - 0.5 - 0.0994562i
      - 0.5
      - 0.5 + 0.0994562i
      - 0.5 + 0.2071068i
      - 0.5 + 0.3340893i
      - 0.5 + 0.5i
      - 0.5 + 0.7483029i
      - 0.5 + 1.2071068i
      - 0.5 + 2.5136697i
    -->fft(x)
     ans  =
        1.
        2.
        2.9999999
        3.9999999
        5.
        6.0000001 - 2.220D-16i
        7.0000001 - 2.220D-16i
        8.0000001
        9.
        9.9999999
        11.
        12.
        13.
        14. + 2.220D-16i
        15. + 2.220D-16i
        16.
     OMAP-L137
    --INPUT---
    --OUTPUT (asm function)---
    1.7807149887084961 + (-0.3204739093780518) * %i
    3.9001204967498779 + (0.0845487117767334) * %i
    5.9226493835449219 + (0.1669408082962036) * %i
    6.5571165084838867 + (-0.0000000874227766) * %i
    8.0845489501953125 + (-0.1215617656707764) * %i
    9.9978437423706055 + (0.0990324020385742) * %i
    11.8784379959106445 + (0.1368930339813232) * %i
    14.2987918853759766 + (0.0545006990432739) * %i
    15.4428834915161133 + (-0.0000000874227766) * %i
    16.1368923187255859 + (-0.0998799800872803) * %i
    --OUTPUT (asm legacy function)---
    done
    As you can see, DSP error affects first decimal digit.
    I chose this particular input vector because of its discrete fourier trasform is simple to visualize and verify.
    I first noted this problem of the DSP code execution for a real sequence (imaginary part to zero): fft of a real sequence must have simmetric real part and anti-simmetric imaginary part, except for the first bin (DC value).
    Debugging step by step, I found the origin of value mismatch: when tw_gen() function calls cos(theta), for some angles it returns wrong value.
    For example, I try this code on a new project
    int main()
     int i;
     double theta;
     const double PI = 3.141592654;
     double c0, s0;
     float c[N], s[N];
     for (i=0; i<N; i++)
      theta = 2 * PI * i / N;
      c0 = cos (theta);
      s0 = sin (theta);
      c[i] = c0;
      s[i] = s0;
      printf("\ncos(%f) = %f;  sin(%f) = %f;", theta, c[i], theta, s[i]);
     return 0;
    output:
    cos(0.000000) = 1.000000;  sin(0.000000) = 0.000000;
    cos(0.196350) = 1.000000;  sin(0.196350) = 0.195090;
    cos(0.392699) = 1.000000;  sin(0.392699) = 0.382683;
    cos(0.589049) = 1.000000;  sin(0.589049) = 0.555570;
    cos(0.785398) = 1.000000;  sin(0.785398) = 0.707107;
    cos(0.981748) = 1.000000;  sin(0.981748) = 0.831470;
    cos(1.178097) = 1.000000;  sin(1.178097) = 0.923880;
    cos(1.374447) = 1.000000;  sin(1.374447) = 0.980785;
    cos(1.570796) = -1.000000;  sin(1.570796) = 1.000000;
    cos(1.767146) = -1.000000;  sin(1.767146) = 0.980785;
    cos(1.963495) = -1.000000;  sin(1.963495) = 0.923880;
    cos(2.159845) = -1.000000;  sin(2.159845) = 0.831470;
    cos(2.356194) = -1.000000;  sin(2.356194) = 0.707107;
    cos(2.552544) = -1.000000;  sin(2.552544) = 0.555570;
    cos(2.748894) = -1.000000;  sin(2.748894) = 0.382683;
    cos(2.945243) = -1.000000;  sin(2.945243) = 0.195090;
    cos(3.141593) = -1.000000;  sin(3.141593) = -0.000000;
    cos(3.337942) = -0.980785;  sin(3.337942) = -0.195090;
    cos(3.534292) = -0.923880;  sin(3.534292) = -0.382683;
    cos(3.730641) = -0.831470;  sin(3.730641) = -0.555570;
    cos(3.926991) = -0.707107;  sin(3.926991) = -0.707107;
    cos(4.123340) = -0.555570;  sin(4.123340) = -0.831470;
    cos(4.319690) = -0.382683;  sin(4.319690) = -0.923880;
    cos(4.516039) = -0.195090;  sin(4.516039) = -0.980785;
    cos(4.712389) = 0.000000;  sin(4.712389) = -1.000000;
    cos(4.908739) = 0.195090;  sin(4.908739) = -0.980785;
    cos(5.105088) = 0.382683;  sin(5.105088) = -0.923880;
    cos(5.301438) = 0.555570;  sin(5.301438) = -0.831470;
    cos(5.497787) = 0.707107;  sin(5.497787) = -0.707107;
    cos(5.694137) = 0.831470;  sin(5.694137) = -0.555570;
    cos(5.890486) = 0.923880;  sin(5.890486) = -0.382683;
    cos(6.086836) = 0.980785;  sin(6.086836) = -0.195090;
    for 0 < theta < PI, function cos(theta) returns only two values: +/-1
    Is the bug only on my system or anyone has got it too?
  • Replacing cos(theta) with sin(PI / 2 - theta) all works fine.
  • Interesting.  My results (using your code as provided) are a pretty good match for your Visual C++ and SCILAB results:
    --OUTPUT---
    2.0000000000000000 + (0.0000001192092896) * %i
    3.0000000000000000 + (0.0000000874227766) * %i
    4.0000000000000000 + (0.0000000000000000) * %i
    6.0000004768371582 + (0.0000000000000000) * %i
    7.0000000000000000 + (-0.0000000874227766) * %i
    10.0000000000000000 + (-0.0000001192092896) * %i
    11.0000000000000000 + (0.0000000874227766) * %i
    14.0000000000000000 + (0.0000000000000000) * %i
    15.0000000000000000 + (-0.0000000874227766) * %i
    I wonder if we could be using different versions of the RTS libraries.  What version are your codegen tools?  (To check this in CCS, go to Help->About.)  I am using version 6.1.10.
  • Hi Joe,
    my Code Generation Tools version is 6.1.5, how can I update it to the latest version?
  • Diego,
    The codegen tools are available on the CCS Update Advisor website.  Try this URL:
    https://www-a.ti.com/downloads/sds_support/CodeGenerationTools.htm
    If that doesn't work, try going through Help->Update Advisor->Check for Updates in CCS.
    You should close CCS before installing the codegen tools.  Then, go to the CCS component manager (accessed through the Help->About screen, bizarrely) and select the new codegen tools under Build Tools->TMS32067XX.  You'll probably need to restart CCS again after that.
  • In Component manager, you need to select the CGT you downloaded for both TMS320C64XX and TMS320C67XX for C674x.
  • Thank you all,
       with new version of Code Generation Tools cos() function works fine.
  • Hi Diego,
    Glad to hear it. I can confirm that this was a known issue fixed in CGT v6.1.8, but I am having trouble finding the specific bug number for your reference. If I come across it I will edit this post as an FYI.
  • Hy.
    Can anyone send me the "DSPF_sp_fftSPxSP_cn.c" used in this post?
    I need the "DSPLIB C674x v. 1.1" because i'm still using CCS 3.3.
    Thanks! André Águas.
  • Please find the C files in the attachment.
    /* DSPF_sp_fftSPxSP_cn.c -- Forward FFT with Mixed Radix                   */
    /*                 Natural C Implementation                                */
    /* Rev 0.0.3                                                               */
    /* Copyright (C) 2011 Texas Instruments Incorporated - http://www.ti.com/  */
    /*  Redistribution and use in source and binary forms, with or without     */
    /*  modification, are permitted provided that the following conditions     */
    /*  are met:                                                               */
    /*    Redistributions of source code must retain the above copyright       */
    /*    notice, this list of conditions and the following disclaimer.        */
    /*    Redistributions in binary form must reproduce the above copyright    */
    /*    notice, this list of conditions and the following disclaimer in the  */
    /*    documentation and/or other materials provided with the               */
    /*    distribution.                                                        */
    /*    Neither the name of Texas Instruments Incorporated nor the names of  */
    /*    its contributors may be used to endorse or promote products derived  */
    /*    from this software without specific prior written permission.        */
    /*  THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS    */
    /*  "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT      */
    /*  LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR  */
    /*  A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT   */
    /*  OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,  */
    /*  SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT       */
    /*  LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,  */
    /*  DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY  */
    /*  THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT    */
    /*  (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE  */
    /*  OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.   */
    #pragma CODE_SECTION(DSPF_sp_fftSPxSP_cn, ".text:natural");
    #include "DSPF_sp_fftSPxSP_cn.h"
    #ifndef _TMS320C6x
    unsigned int _bitr(unsigned int a)
        unsigned int i, b=0;
        for(i=0; i<32; i++)
            b |=  (((a >> i) & 0x1) << (31 -i));
        return(b);
    #endif
    void DSPF_sp_fftSPxSP_cn (int N, float *ptr_x, float *ptr_w, float *ptr_y,
        unsigned char *brev, int n_min, int offset, int n_max)
        int i, j, k, l1, l2, h2, predj;
        int tw_offset, stride, fft_jmp;
        float x0, x1, x2, x3, x4, x5, x6, x7;
        float xt0, yt0, xt1, yt1, xt2, yt2, yt3;
        float yt4, yt5, yt6, yt7;
        float si1, si2, si3, co1, co2, co3;
        float xh0, xh1, xh20, xh21, xl0, xl1, xl20, xl21;
        float x_0, x_1, x_l1, x_l1p1, x_h2, x_h2p1, x_l2, x_l2p1;
        float xl0_0, xl1_0, xl0_1, xl1_1;
        float xh0_0, xh1_0, xh0_1, xh1_1;
        float *x, *w;
        int l0, radix;
        float *y0, *ptr_x0, *ptr_x2;
        radix = n_min;
        stride = N;                                                /* n is the number of complex samples */
        tw_offset = 0;
        while (stride > radix)
            j = 0;
            fft_jmp = stride + (stride >> 1);
            h2 = stride >> 1;
            l1 = stride;
            l2 = stride + (stride >> 1);
            x = ptr_x;
            w = ptr_w + tw_offset;
            for (i = 0; i < N; i += 4)
                co1 = w[j];
                si1 = w[j + 1];
                co2 = w[j + 2];
                si2 = w[j + 3];
                co3 = w[j + 4];
                si3 = w[j + 5];
                x_0 = x[0];
                x_1 = x[1];
                x_h2 = x[h2];
                x_h2p1 = x[h2 + 1];
                x_l1 = x[l1];
                x_l1p1 = x[l1 + 1];
                x_l2 = x[l2];
                x_l2p1 = x[l2 + 1];
                xh0 = x_0 + x_l1;
                xh1 = x_1 + x_l1p1;
                xl0 = x_0 - x_l1;
                xl1 = x_1 - x_l1p1;
                xh20 = x_h2 + x_l2;
                xh21 = x_h2p1 + x_l2p1;
                xl20 = x_h2 - x_l2;
                xl21 = x_h2p1 - x_l2p1;
                ptr_x0 = x;
                ptr_x0[0] = xh0 + xh20;
                ptr_x0[1] = xh1 + xh21;
                ptr_x2 = ptr_x0;
                x += 2;
                j += 6;
                predj = (j - fft_jmp);
                if (!predj)
                    x += fft_jmp;
                if (!predj)
                    j = 0;
                xt0 = xh0 - xh20;
                yt0 = xh1 - xh21;
                xt1 = xl0 + xl21;
                yt2 = xl1 + xl20;
                xt2 = xl0 - xl21;
                yt1 = xl1 - xl20;
                ptr_x2[l1] = xt1 * co1 + yt1 * si1;
                ptr_x2[l1 + 1] = yt1 * co1 - xt1 * si1;
                ptr_x2[h2] = xt0 * co2 + yt0 * si2;
                ptr_x2[h2 + 1] = yt0 * co2 - xt0 * si2;
                ptr_x2[l2] = xt2 * co3 + yt2 * si3;
                ptr_x2[l2 + 1] = yt2 * co3 - xt2 * si3;
            tw_offset += fft_jmp;
            stride = stride >> 2;
        }                                                        /* end while */
        j = offset >> 2;
        ptr_x0 = ptr_x;
        y0 = ptr_y;
        /* l0 = _norm(n_max) +3; get size of fft */
        l0 = 0;
        for (k = 30; k >= 0; k--)
            if ((n_max & (1 << k)) == 0)
                l0++;
            else
                break;
        l0 = l0 + 3;
        if (radix <= 4)
                /* reversal computation */
                k = _bitr(j) >> l0;
                j++;                                            /* multiple of 4 index */
                x0 = ptr_x0[0];
                x1 = ptr_x0[1];
                x2 = ptr_x0[2];
                x3 = ptr_x0[3];
                x4 = ptr_x0[4];
                x5 = ptr_x0[5];
                x6 = ptr_x0[6];
                x7 = ptr_x0[7];
                ptr_x0 += 8;
                xh0_0 = x0 + x4;
                xh1_0 = x1 + x5;
                xh0_1 = x2 + x6;
                xh1_1 = x3 + x7;
                if (radix == 2)
                    xh0_0 = x0;
                    xh1_0 = x1;
                    xh0_1 = x2;
                    xh1_1 = x3;
                yt0 = xh0_0 + xh0_1;
                yt1 = xh1_0 + xh1_1;
                yt4 = xh0_0 - xh0_1;
                yt5 = xh1_0 - xh1_1;
                xl0_0 = x0 - x4;
                xl1_0 = x1 - x5;
                xl0_1 = x2 - x6;
                xl1_1 = x3 - x7;
                if (radix == 2)
                    xl0_0 = x4;
                    xl1_0 = x5;
                    xl1_1 = x6;
                    xl0_1 = x7;
                yt2 = xl0_0 + xl1_1;
                yt3 = xl1_0 - xl0_1;
                yt6 = xl0_0 - xl1_1;
                yt7 = xl1_0 + xl0_1;
                if (radix == 2)
                    yt7 = xl1_0 - xl0_1;
                    yt3 = xl1_0 + xl0_1;
                y0[k] = yt0;
                y0[k + 1] = yt1;
                k += n_max >> 1;
                y0[k] = yt2;
                y0[k + 1] = yt3;
                k += n_max >> 1;
                y0[k] = yt4;
                y0[k + 1] = yt5;
                k += n_max >> 1;
                y0[k] = yt6;
                y0[k + 1] = yt7;
    /*  End of file:  DSPF_sp_fftSPxSP_cn.c                                    */
    /*            Copyright (c) 2011 Texas Instruments, Incorporated.          */
    /*                           All Rights Reserved.                          */
