Other Parts Discussed in Thread: AM3358, DA8XX
I am working on a custom design based on AM3358 running android ICS. Followed the steps mentioned in http://processors.wiki.ti.com/index.php/TI-Android-ICS-4.0.3-DevKit-3.0.1_UserGuide#NAND_Booting to flash and found different behavior on 2 similar NAND part from different vendors,
1. Micron MT29F4G08 ABADAWP - Works fine.
2. Hynix H27U4G8F2D - Roofs filesystem mount fails giving following error
Uncompressing Linux... done, booting the kernel.
[ 0.000000] Linux version 3.2.0-g85125c2-dirty (dilip@pc50) (gcc version 4.4.3 (GCC) ) #1 Thu Jan 3 17:29:26 IST 2013
[ 0.000000] CPU: ARMv7 Processor [413fc082] revision 2 (ARMv7), cr=10c53c7d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine: am335xevm
[ 0.000000] Memory policy: ECC disabled, Data cache writeback
[ 0.000000] AM335X ES1.0 (sgx neon )
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 65024
[ 0.000000] Kernel command line: console=ttyO0,115200n8 androidboot.console=ttyO0 mem=256M root=ubi0:rootfs rootfstype=ubifs ubi.mtd=7,2048 rw rootwait init=/init if
[ 0.000000] PID hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000000] Dentry cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Inode-cache hash table entries: 16384 (order: 4, 65536 bytes)
[ 0.000000] Memory: 256MB = 256MB total
[ 0.000000] Memory: 250772k/250772k available, 11372k reserved, 0K highmem
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xfff00000 - 0xfffe0000 ( 896 kB)
[ 0.000000] vmalloc : 0xd0800000 - 0xff000000 ( 744 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xd0000000 ( 256 MB)
[ 0.000000] modules : 0xbf000000 - 0xc0000000 ( 16 MB)
[ 0.000000] .text : 0xc0008000 - 0xc06b6000 (6840 kB)
[ 0.000000] .init : 0xc06b6000 - 0xc0750000 ( 616 kB)
[ 0.000000] .data : 0xc0750000 - 0xc07aae80 ( 364 kB)
[ 0.000000] .bss : 0xc07aaea4 - 0xc08deb10 (1232 kB)
[ 0.000000] NR_IRQS:396
[ 0.000000] IRQ: Found an INTC at 0xfa200000 (revision 5.0) with 128 interrupts
[ 0.000000] Total of 128 interrupts on 1 active controller
[ 0.000000] OMAP clockevent source: GPTIMER2 at 24000000 Hz
[ 0.000000] OMAP clocksource: GPTIMER1 at 32768 Hz
[ 0.000000] sched_clock: 32 bits at 32kHz, resolution 30517ns, wraps every 131071999ms
[ 0.000000] Console: colour dummy device 80x30
[ 0.000152] Calibrating delay loop... 718.02 BogoMIPS (lpj=3590144)
[ 0.058929] pid_max: default: 32768 minimum: 301
[ 0.059051] Security Framework initialized
[ 0.059112] Mount-cache hash table entries: 512
[ 0.059478] CPU: Testing write buffer coherency: ok
[ 0.079376] omap_hwmod: pruss: failed to hardreset
[ 0.080139] print_constraints: dummy:
[ 0.080383] NET: Registered protocol family 16
[ 0.081481] OMAP GPIO hardware version 0.1
[ 0.082366] am335x_evm_init start
[ 0.082519] omap_mux_init: Add partition: #1: core, flags: 0
[ 0.083679] omap_i2c.1: alias fck already exists
[ 0.084045] calling setup_allgo_etab
[ 0.084045] setup_allgo_etab
[ 0.084045]
[ 0.084075] gpio_init
[ 0.084533] da8xx_lcdc.0: alias fck already exists
[ 0.084686] davinci-mcasp.0: alias fck already exists
[ 0.084808] _omap_mux_get_by_name: Could not find signal spi_cs0.gpio0_5
[ 0.085510] omap_hsmmc.0: alias fck already exists
[ 0.085632] omap_hsmmc.2: alias fck already exists
[ 0.085754] am335xevm: bt init
[ 0.086273] omap_i2c.2: alias fck already exists
[ 0.086639] am335x_evm_init end
[ 0.086791] omap2_mcspi.1: alias fck already exists
[ 0.086914] omap2_mcspi.2: alias fck already exists
[ 0.087066] edma.0: alias fck already exists
[ 0.087097] edma.0: alias fck already exists
[ 0.097045] bio: create slab <bio-0> at 0
[ 0.098052] SCSI subsystem initialized
[ 0.098907] usbcore: registered new interface driver usbfs
[ 0.099090] usbcore: registered new interface driver hub
[ 0.099243] usbcore: registered new device driver usb
[ 0.099365] musb-ti81xx musb-ti81xx: musb0, board_mode=0x13, plat_mode=0x3
[ 0.099517] musb-ti81xx musb-ti81xx: musb1, board_mode=0x13, plat_mode=0x1
[ 0.119018] omap_i2c omap_i2c.1: bus 1 rev2.4.0 at 100 kHz
[ 0.138977] omap_i2c omap_i2c.2: bus 2 rev2.4.0 at 100 kHz
[ 0.139556] Advanced Linux Sound Architecture Driver Version 1.0.24.
[ 0.140136] Bluetooth: Core ver 2.16
[ 0.140197] NET: Registered protocol family 31
[ 0.140228] Bluetooth: HCI device and connection manager initialized
[ 0.140228] Bluetooth: HCI socket layer initialized
[ 0.140228] Bluetooth: L2CAP socket layer initialized
[ 0.140258] Bluetooth: SCO socket layer initialized
[ 0.140441] Switching to clocksource gp timer
[ 0.148223] musb-hdrc: version 6.0, ?dma?, otg (peripheral+host)
[ 0.148406] musb-hdrc musb-hdrc.0: dma type: pio
[ 0.148590] MUSB0 controller's USBSS revision = 4ea20800
[ 0.149108] musb-hdrc musb-hdrc.0: USB OTG mode controller at d083c000 using PIO, IRQ 18
[ 0.149353] musb-hdrc musb-hdrc.1: dma type: pio
[ 0.149505] MUSB1 controller's USBSS revision = 4ea20800
[ 0.149627] musb-hdrc musb-hdrc.1: MUSB HDRC host driver
[ 0.149688] musb-hdrc musb-hdrc.1: new USB bus registered, assigned bus number 1
[ 0.149841] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 0.149841] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.149871] usb usb1: Product: MUSB HDRC host driver
[ 0.149871] usb usb1: Manufacturer: Linux 3.2.0-g85125c2-dirty musb-hcd
[ 0.149902] usb usb1: SerialNumber: musb-hdrc.1
[ 0.150360] hub 1-0:1.0: USB hub found
[ 0.150390] hub 1-0:1.0: 1 port detected
[ 0.150848] musb-hdrc musb-hdrc.1: USB Host mode controller at d083e800 using PIO, IRQ 19
[ 0.151184] NET: Registered protocol family 2
[ 0.151397] IP route cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.151763] TCP established hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.151916] TCP bind hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.152008] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.152038] TCP reno registered
[ 0.152038] UDP hash table entries: 256 (order: 0, 4096 bytes)
[ 0.152069] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes)
[ 0.152282] NET: Registered protocol family 1
[ 0.152557] RPC: Registered named UNIX socket transport module.
[ 0.152557] RPC: Registered udp transport module.
[ 0.152587] RPC: Registered tcp transport module.
[ 0.152587] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.152862] NetWinder Floating Point Emulator V0.97 (double precision)
[ 0.153076] omap-gpmc omap-gpmc: GPMC revision 6.0
[ 0.153106] Registering NAND on CS0
[ 0.283416] ashmem: initialized
[ 0.283691] VFS: Disk quotas dquot_6.5.2
[ 0.283752] Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.284637] msgmni has been set to 489
[ 0.285705] io scheduler noop registered
[ 0.285705] io scheduler deadline registered
[ 0.285797] io scheduler cfq registered (default)
[ 0.286529] da8xx_lcdc da8xx_lcdc.0: GLCD: Found INNOLUX_AT070TN92 panel
[ 0.286529] innolux_panel_power_ctrl state 1
[ 0.302185] Console: switching to colour frame buffer device 100x30
[ 0.315795] omap_uart.0: ttyO0 at MMIO 0x44e09000 (irq = 72) is a OMAP UART0
[ 0.974731] console [ttyO0] enabled
[ 0.978790] omap_uart.1: ttyO1 at MMIO 0x48022000 (irq = 73) is a OMAP UART1
[ 0.986511] omap_uart.2: ttyO2 at MMIO 0x48024000 (irq = 74) is a OMAP UART2
[ 0.994171] omap_uart.3: ttyO3 at MMIO 0x481a6000 (irq = 44) is a OMAP UART3
[ 1.001831] omap_uart.4: ttyO4 at MMIO 0x481a8000 (irq = 45) is a OMAP UART4
[ 1.009460] omap_uart.5: ttyO5 at MMIO 0x481aa000 (irq = 46) is a OMAP UART5
[ 1.023223] brd: module loaded
[ 1.029541] loop: module loaded
[ 1.033081] i2c-core: driver [tsl2550] using legacy suspend method
[ 1.039550] i2c-core: driver [tsl2550] using legacy resume method
[ 1.046051] (stk) :sysfs entries created
[ 1.050170] (stk) : debugfs entries created
[ 1.054565] _regulator_get: 1-0019 supply Vdd not found, using dummy regulator
[ 1.062347] _regulator_get: 1-0019 supply Vdd_IO not found, using dummy regulator
[ 1.090972] lis3lv02d: 8 bits 3DLH sensor found
[ 1.181365] input: ST LIS3LV02DL Accelerometer as /devices/platform/lis3lv02d/input/input0
[ 1.191619] mtdoops: mtd device (mtddev=name/number) must be supplied
[ 1.198608] omap2-nand driver initializing
[ 1.203216] ONFI flash detected
[ 1.206634] ONFI param page 0 valid
[ 1.210266] NAND device: Manufacturer ID: 0xad, Chip ID: 0xdc (Hynix H27U4G8F2DTR-BC)
[ 1.218933] Creating 8 MTD partitions on "omap2-nand.0":
[ 1.224517] 0x000000000000-0x000000020000 : "SPL"
[ 1.230499] 0x000000020000-0x000000040000 : "SPL.backup1"
[ 1.237091] 0x000000040000-0x000000060000 : "SPL.backup2"
[ 1.243621] 0x000000060000-0x000000080000 : "SPL.backup3"
[ 1.250152] 0x000000080000-0x000000260000 : "U-Boot"
[ 1.256927] 0x000000260000-0x000000280000 : "U-Boot Env"
[ 1.263305] 0x000000280000-0x000000780000 : "Kernel"
[ 1.271362] 0x000000780000-0x000020000000 : "File System"
[ 1.488067] usb 1-1: new high-speed USB device number 2 using musb-hdrc
[ 1.495697] OneNAND driver initializing
[ 1.500152] UBI: attaching mtd7 to ubi0
[ 1.504180] UBI: physical eraseblock size: 131072 bytes (128 KiB)
[ 1.510711] UBI: logical eraseblock size: 126976 bytes
[ 1.516357] UBI: smallest flash I/O unit: 2048
[ 1.521270] UBI: sub-page size: 512
[ 1.526092] UBI: VID header offset: 2048 (aligned 2048)
[ 1.532348] UBI: data offset: 4096
[ 1.672149] usb 1-1: New USB device found, idVendor=0424, idProduct=2512
[ 1.679168] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 1.687225] hub 1-1:1.0: USB hub found
[ 1.691833] hub 1-1:1.0: 2 ports detected
[ 1.971649] usb 1-1.2: new high-speed USB device number 4 using musb-hdrc
[ 2.114044] usb 1-1.2: New USB device found, idVendor=0ac8, idProduct=3450
[ 2.121246] usb 1-1.2: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 2.128845] usb 1-1.2: Product: Venus USB2.0 Camera
[ 2.133941] usb 1-1.2: Manufacturer: Vimicro Corp.
[ 4.510070] UBI: max. sequence number: 0
[ 4.528228] UBI error: vtbl_check: bad CRC at record 8: 0x4b8de38, not 0xf116c36b
[ 4.536102] UBI error: vtbl_check: bad CRC at record 8: 0x4b8de38, not 0xf116c36b
[ 4.543914] UBI error: process_lvol: both volume tables are corrupted
[ 4.551971] UBI error: ubi_init: cannot attach mtd7
[ 4.557342] CAN device driver interface
[ 4.561370] CAN bus driver for Bosch D_CAN controller 1.0
[ 4.611145] davinci_mdio davinci_mdio.0: davinci mdio revision 1.6
[ 4.617614] davinci_mdio davinci_mdio.0: detected phy mask fffffffe
[ 4.624938] davinci_mdio.0: probed
[ 4.628540] davinci_mdio davinci_mdio.0: phy[0]: device 0:00, driver SMSC LAN8710/LAN8720
[ 4.637145] PPP generic driver version 2.4.2
[ 4.641815] PPP BSD Compression module registered
[ 4.646728] PPP Deflate Compression module registered
[ 4.652160] usbcore: registered new interface driver cdc_ether
[ 4.658294] usbcore: registered new interface driver cdc_eem
[ 4.664276] usbcore: registered new interface driver dm9601
[ 4.670135] usbcore: registered new interface driver cdc_subset
[ 4.676361] cdc_ncm: 04-Aug-2011
[ 4.679779] usbcore: registered new interface driver cdc_ncm
[ 4.685821] usbcore: registered new interface driver cdc_acm
[ 4.691741] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
[ 4.700073] Initializing USB Mass Storage driver...
[ 4.705352] usbcore: registered new interface driver usb-storage
[ 4.711639] USB Mass Storage support registered.
[ 4.716613] usbcore: registered new interface driver usbserial
[ 4.722747] USB Serial support registered for generic
[ 4.728179] usbcore: registered new interface driver usbserial_generic
[ 4.734985] usbserial: USB Serial Driver core
[ 4.739562] USB Serial support registered for GSM modem (1-port)
[ 4.746124] usbcore: registered new interface driver option
[ 4.751953] option: v0.7.2:USB Driver for GSM modems
[ 4.758972] gadget: Mass Storage Function, version: 2009/09/11
[ 4.765197] gadget: Number of LUNs=1
[ 4.769012] lun0: LUN: removable file: (no medium)
[ 4.774353] gadget: android_usb ready
[ 4.778289] musb-hdrc musb-hdrc.0: MUSB HDRC host driver
[ 4.783905] musb-hdrc musb-hdrc.0: new USB bus registered, assigned bus number 2
[ 4.791748] usb usb2: New USB device found, idVendor=1d6b, idProduct=0002
[ 4.798828] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 4.806365] usb usb2: Product: MUSB HDRC host driver
[ 4.811553] usb usb2: Manufacturer: Linux 3.2.0-g85125c2-dirty musb-hcd
[ 4.818450] usb usb2: SerialNumber: musb-hdrc.0
[ 4.823669] hub 2-0:1.0: USB hub found
[ 4.827606] hub 2-0:1.0: 1 port detected
[ 4.832336] mousedev: PS/2 mouse device common for all mice
[ 4.838836] ts_dev is cf35b740 cf35b768
[ 4.843750] using rtc device, omap_rtc, for alarms
[ 4.848602] omap_rtc omap_rtc: rtc core: registered omap_rtc as rtc0
[ 4.855499] omap_rtc: already running
[ 4.859375] i2c /dev entries driver
[ 4.863311] Linux video capture interface: v2.00
[ 4.868316] uvcvideo: Found UVC 1.00 device Venus USB2.0 Camera (0ac8:3450)
[ 4.877685] input: Venus USB2.0 Camera as /devices/platform/omap/musb-ti81xx/musb-hdrc.1/usb1/1-1/1-1.2/1-1.2:1.0/input/input1
[ 4.889892] usbcore: registered new interface driver uvcvideo
[ 4.895904] USB Video Class driver (1.1.1)
[ 4.903686] OMAP Watchdog Timer Rev 0x01: initial timeout 60 sec
[ 4.910217] device-mapper: uevent: version 1.0.3
[ 4.915283] device-mapper: ioctl: 4.22.0-ioctl (2011-10-19) initialised: dm-devel@redhat.com
[ 4.924102] Bluetooth: HCI UART driver ver 2.2
[ 4.928741] Bluetooth: HCI H4 protocol initialized
[ 4.933746] Bluetooth: HCILL protocol initialized
[ 4.938659] Bluetooth: Bluetooth Driver for TI WiLink - Version 1.0
[ 4.946105] _regulator_get: deviceless supply vdd_mpu not found, using dummy regulator
[ 4.954589] cpuidle: using governor ladder
[ 4.959014] cpuidle: using governor menu
[ 4.966796] usbcore: registered new interface driver usbhid
[ 4.972686] usbhid: USB HID core driver
[ 4.977172] logger: created 256K log 'log_main'
[ 4.982055] logger: created 256K log 'log_events'
[ 4.987060] logger: created 256K log 'log_radio'
[ 4.992004] logger: created 256K log 'log_system'
[ 4.997467] usbcore: registered new interface driver snd-usb-audio
[ 5.273437] Completed adding dapm widgets size = 24
[ 5.283447] Completed adding DAPM routes = 32
[ 5.296020] widgets updated
[ 5.301513] asoc: tlv320aic31xx-dai <-> davinci-mcasp.0 mapping ok
[ 5.308715] ALSA device list:
[ 5.311859] #0: AM335X EVM
[ 5.314849] oprofile: hardware counters not available
[ 5.320098] oprofile: using timer interrupt.
[ 5.324737] Netfilter messages via NETLINK v0.30.
[ 5.329772] nf_conntrack version 0.5.0 (3918 buckets, 15672 max)
[ 5.336395] ctnetlink v0.93: registering with nfnetlink.
[ 5.342010] NF_TPROXY: Transparent proxy support initialized, version 4.1.0
[ 5.349273] NF_TPROXY: Copyright (c) 2006-2007 BalaBit IT Ltd.
[ 5.355712] xt_time: kernel timezone is -0000
[ 5.360473] ip_tables: (C) 2000-2006 Netfilter Core Team
[ 5.366241] arp_tables: (C) 2002 David S. Miller
[ 5.371185] TCP cubic registered
[ 5.374725] NET: Registered protocol family 10
[ 5.380157] Mobile IPv6
[ 5.382781] ip6_tables: (C) 2000-2006 Netfilter Core Team
[ 5.388641] IPv6 over IPv4 tunneling driver
[ 5.393646] NET: Registered protocol family 17
[ 5.398315] NET: Registered protocol family 15
[ 5.402954] can: controller area network core (rev 20090105 abi 8)
[ 5.409545] NET: Registered protocol family 29
[ 5.414184] can: raw protocol (rev 20090105)
[ 5.418640] can: broadcast manager protocol (rev 20090105 t)
[ 5.424804] Bluetooth: RFCOMM TTY layer initialized
[ 5.429901] Bluetooth: RFCOMM socket layer initialized
[ 5.435302] Bluetooth: RFCOMM ver 1.11
[ 5.439208] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 5.444732] Bluetooth: BNEP filters: protocol multicast
[ 5.450195] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[ 5.456512] Registering the dns_resolver key type
[ 5.461517] VFP support v0.3: implementor 41 architecture 3 part 30 variant c rev 3
[ 5.469512] ThumbEE CPU extension supported.
[ 5.474029] mux: Failed to setup hwmod io irq -22
[ 5.479644] Power Management for AM33XX family
[ 5.484527] Trying to load am335x-pm-firmware.bin (60 secs timeout)
[ 5.491210] Copied the M3 firmware to UMEM
[ 5.500335] clock: disabling unused clocks to save power
[ 5.507446] Detected MACID=0:18:31:8d:c8:b4
[ 5.513824] input: gpio-keys as /devices/platform/gpio-keys/input/input2
[ 5.521209]
[ 5.521209]
[ 5.521240] goodix_ts_init
[ 5.521240]
[ 5.539459] mmc0: host does not support reading read-only switch. assuming write-enable.
[ 5.547973] mmc0: new SDHC card at address aaaa
[ 5.553283] mmcblk0: mmc0:aaaa SU04G 3.69 GiB
[ 5.558868] input: Goodix TouchScreen of GT80X as /devices/virtual/input/input3
[ 5.568298] mmcblk0: p1 p2
[ 5.661132] enabling irq
[ 5.661132]
[ 5.685638] mmc1: card claims to support voltages below the defined range. These will be ignored.
[ 5.702239] Goodix-TS 2-0055: Guitar Version: GT801_1R07_2011081501_Goodix_Tech
[ 5.713043] mmc1: queuing unknown CIS tuple 0x91 (3 bytes)
[ 5.719940] mmc1: new SDIO card at address 0001
[ 6.101135] (stk) :line disc installation timed out
[ 6.211120] Goodix-TS 2-0055: Start Goodix TouchScreen of GT80X in Interrupt mode
[ 6.219299] omap_rtc omap_rtc: setting system clock to 2000-01-01 00:04:10 UTC (946685050)
[ 6.228424] VFS: Cannot open root device "ubi0:rootfs" or unknown-block(0,0)
[ 6.235809] Please append a correct "root=" boot option; here are the available partitions:
[ 6.244598] 1f00 128 mtdblock0 (driver?)
[ 6.249877] 1f01 128 mtdblock1 (driver?)
[ 6.255157] 1f02 128 mtdblock2 (driver?)
[ 6.260437] 1f03 128 mtdblock3 (driver?)
[ 6.265716] 1f04 1920 mtdblock4 (driver?)
[ 6.270965] 1f05 128 mtdblock5 (driver?)
[ 6.276275] 1f06 5120 mtdblock6 (driver?)
[ 6.281555] 1f07 516608 mtdblock7 (driver?)
[ 6.286804] b300 3872256 mmcblk0 driver: mmcblk
[ 6.292388] b301 200781 mmcblk0p1 00000000-0000-0000-0000-000000000000mmcblk0p1
[ 6.300994] b302 3670852 mmcblk0p2 00000000-0000-0000-0000-000000000000mmcblk0p2
[ 6.309631] Kernel panic - not syncing: VFS: Unable to mount root fs on unknown-block(0,0)
[ 6.318267] Backtrace:
[ 6.320831] [<c00180dc>] (dump_backtrace+0x0/0x10c) from [<c05185fc>] (dump_stack+0x18/0x1c)
[ 6.329650] r7:c06e6910 r6:00008000 r5:c07abe50 r4:c07abe50
[ 6.335571] [<c05185e4>] (dump_stack+0x0/0x1c) from [<c0518664>] (panic+0x64/0x198)
[ 6.343597] [<c0518600>] (panic+0x0/0x198) from [<c06b6d80>] (mount_block_root+0x174/0x228)
[ 6.352294] r3:00000000 r2:00000000 r1:cf81df78 r0:c06126a8
[ 6.358245] [<c06b6c0c>] (mount_block_root+0x0/0x228) from [<c06b6f94>] (prepare_namespace+0x94/0x1c0)
[ 6.367950] [<c06b6f00>] (prepare_namespace+0x0/0x1c0) from [<c06b62f8>] (kernel_init+0xf0/0x124)
[ 6.377227] r5:c074fc58 r4:c07aaec0
[ 6.380981] [<c06b6208>] (kernel_init+0x0/0x124) from [<c003ffc4>] (do_exit+0x0/0x6ac)
[ 6.389221] r5:c06b6208 r4:00000000
[ 7.851654] battery adc: failed to queue the work
[ 8.851715] battery adc: failed to queue the work
Both NAND are similar part with only change in vendor. Any idea what is going wrong?
Dilip
