How to set AM335x in I2C slave mode
I am trying to create a I2C slave device using TI's AM335x board(only reception required)by means of modifying the  i2c-omap.c,unfortunately I failed.I  don't know how to do it.I know this question has been solved possibly in Ti E2E Community,
 e2e.ti.com/.../34910
 "Hi Youssef,
spontaneously I haven't found the 2.6.29-rc3-omap1 kernel source code - so a driver patch might break because of little differences between your actual kernel and my version. I have adapted my current driver version to the interfaces provided by the 2.6.29-omap1 driver (which are probably / hopefully compatible to your rc3-version). You can download the driver file, a little application example and a readme from www-user.tu-chemnitz.de/.../i2c_omap_slave.tar.gz . Just try whether it compiles without errors... If you notice a bug please post again"
I want to download i2c_omap_slave.tar.gz. but don't find it .the interlinkage is disable .please reuploading it .I need it .In addition to this.If someone is solved the problem, please Leave your footprint.
Thank you very much
