Part Number: EVMK2H
Other Parts Discussed in Thread: TCI6638K2K
We have recently purchased a number of new EVMK2H REV40 boards and set them up by running the Processor SDK Linux for K2H/K2K v03.01.00.06 setup script.
We are booting up the board using the tftpserver/NFS Server approach, and the host is a Ubuntu 16.04 PC.
The board appears to boot up OK. Although it always shows the 'keystone-rapidio 2900000.rapidio: RIO port register timeout, port mask 0x1 not ready' message at the end, we can still login successfully (please see attached boot output
U-Boot SPL 2016.05-g2f757e5b2c (Oct 03 2016 - 22:35:45)
Trying to boot from SPI
U-Boot 2016.05-g2f757e5b2c (Oct 03 2016 - 22:35:45 -0400)
CPU: 66AK2Hx SR2.0
I2C: ready
DRAM: DDR3A Speed will be configured for 1333 Operation.
Detected SO-DIMM [SQR-SD3T-2G1333SED]
DDR3 speed 1333
DRAM: 2 GiB (includes reported below)
Clear entire DDR3 memory to enable ECC
2 GiB
NAND: 512 MiB
Net: eth0: netcp@2000000
Warning: netcp@slave-1 (eth1) using random MAC address - 32:3f:b5:7d:01:16
, eth1: netcp@slave-1
Warning: netcp@slave-2 (eth2) using random MAC address - 6a:c2:e0:61:ba:87
, eth2: netcp@slave-2
Warning: netcp@slave-3 (eth3) using random MAC address - ca:19:62:05:e3:7a
, eth3: netcp@slave-3
Hit any key to stop autoboot: 0
netcp@2000000 Waiting for SGMII auto negotiation to complete. done
netcp@2000000 Waiting for PHY auto negotiation to complete. done
BOOTP broadcast 1
BOOTP broadcast 2
BOOTP broadcast 3
DHCP client bound to address 10.10.10.30 (758 ms)
Using netcp@2000000 device
TFTP from server 10.10.10.6; our IP address is 10.10.10.30
Filename '/tftpboot/k2-fw-initrd.cpio.gz'.
Load address: 0x88080000
Loading: ##########
1.2 MiB/s
done
Bytes transferred = 49680 (c210 hex)
BOOTP broadcast 1
DHCP client bound to address 10.10.10.30 (2 ms)
Filename '/tftpboot/keystone-k2hk-evm.dtb'.
Load address: 0x88000000
Loading: ###########
1.2 MiB/s
done
Bytes transferred = 54305 (d421 hex)
BOOTP broadcast 1
Filename '/tftpboot/skern-k2hk.bin'.
Load address: 0xc5f0000
Loading: #########
1.2 MiB/s
done
Bytes transferred = 45056 (b000 hex)
BOOTP broadcast 1
Filename '/tftpboot/zImage-k2hk-evm.bin'.
Load address: 0x82000000
Loading: #################################################################
1.3 MiB/s
done
Bytes transferred = 3462344 (34d4c8 hex)
K2_BM_15.07-39-g035329c SoC:k2hk built:21:30:13, Oct 3 2016
## installed monitor, freq [200000000], status 0
Kernel image @ 0x82000000 [ 0x000000 - 0x34d4c8 ]
Loading Ramdisk to 8fff3000, end 8ffff210 ... OK
Loading Device Tree to 8ffe2000, end 8fff2420 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.19-gdb0b54cdad (gtbldadm@ubuntu-16) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Mon Oct 3 21:52:02 EDT 2016
[ 0.000000] CPU: ARMv7 Processor [412fc0f4] revision 4 (ARMv7), cr=30c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: Texas Instruments Keystone 2 Kepler/Hawking EVM
[ 0.000000] Switching physical address space to 0x800000000
[ 0.000000] Reserved memory: OVERLAP DETECTED!
[ 0.000000] mpm_block_mem@820000000 (0x0000000820000000--0x0000000822000000) overlaps with dsp_reserved_mpm_area (0x0000000820000000--0x0000000840000000)
[ 0.000000] dsp_reserved_mpm_area (0x0000000820000000--0x0000000840000000) overlaps with cmem_block_mem@822000000 (0x0000000822000000--0x0000000829000000)
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000081f800000, size 8 MiB
[ 0.000000] Reserved memory: initialized node dsp_common_cma_pool, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x0000000820000000, size 512 MiB
[ 0.000000] Reserved memory: initialized node dsp_reserved_mpm_area, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x000000087e400000
[ 0.000000] Forcing write-allocate cache policy for SMP
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: Using PSCI v0.1 Function IDs from DT
[ 0.000000] PERCPU: Embedded 11 pages/cpu @de593000 s14784 r8192 d22080 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 391488
[ 0.000000] Kernel command line: console=ttyS0,115200n8 rootwait=1 rootfstype=nfs root=/dev/nfs rw nfsroot=10.10.10.6:/evmk2h_nfs,v3,tcp,rsize=4096,wsize=4096 ip=dhcp
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 1515616K/1572864K available (6535K kernel code, 252K rwdata, 2320K rodata, 284K init, 296K bss, 24480K reserved, 32768K cma-reserved, 1024000K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xf0800000 - 0xff800000 ( 240 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xf0000000 ( 768 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08ae04c (8857 kB)
[ 0.000000] .init : 0xc08af000 - 0xc08f6000 ( 284 kB)
[ 0.000000] .data : 0xc08f6000 - 0xc09352f0 ( 253 kB)
[ 0.000000] .bss : 0xc0937000 - 0xc09810c4 ( 297 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] RCU restricting CPUs from NR_CPUS=8 to nr_cpu_ids=4.
[ 0.000000] RCU: Adjusting geometry for rcu_fanout_leaf=32, nr_cpu_ids=4
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 200.00MHz (virt).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x2e2049d3e8, max_idle_ns: 440795210634 ns
[ 0.000003] sched_clock: 56 bits at 200MHz, resolution 5ns, wraps every 4398046511102ns
[ 0.000010] Switching to timer-based delay loop, resolution 5ns
[ 0.000172] keystone timer clock @200000000 Hz
[ 0.000401] Console: colour dummy device 80x30
[ 0.000420] Calibrating delay loop (skipped), value calculated using timer frequency.. 400.00 BogoMIPS (lpj=2000000)
[ 0.000430] pid_max: default: 32768 minimum: 301
[ 0.000506] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000513] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000946] Initializing cgroup subsys io
[ 0.000960] Initializing cgroup subsys memory
[ 0.000979] Initializing cgroup subsys devices
[ 0.000989] Initializing cgroup subsys freezer
[ 0.000998] Initializing cgroup subsys perf_event
[ 0.001006] Initializing cgroup subsys pids
[ 0.001027] CPU: Testing write buffer coherency: ok
[ 0.001220] /cpus/cpu@0 missing clock-frequency property
[ 0.001247] /cpus/cpu@1 missing clock-frequency property
[ 0.001272] /cpus/cpu@2 missing clock-frequency property
[ 0.001298] /cpus/cpu@3 missing clock-frequency property
[ 0.001307] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001333] Setting up static identity map for 0x800082c0 - 0x800083f0
[ 0.084398] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.114436] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.144477] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.144565] Brought up 4 CPUs
[ 0.144578] SMP: Total of 4 processors activated (1600.00 BogoMIPS).
[ 0.144584] CPU: All CPU(s) started in SVC mode.
[ 0.144955] devtmpfs: initialized
[ 0.156217] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.156441] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.157089] pinctrl core: initialized pinctrl subsystem
[ 0.157648] NET: Registered protocol family 16
[ 0.158321] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.180114] cpuidle: using governor ladder
[ 0.210132] cpuidle: using governor menu
[ 0.215595] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.215783] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.215969] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.216161] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.216351] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.216536] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.216723] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.216911] irq: no irq domain found for /soc/keystone_irq@26202a0 !
[ 0.223233] No ATAGs?
[ 0.223253] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.223259] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.253827] media: Linux media interface: v0.10
[ 0.253870] Linux video capture interface: v2.00
[ 0.253901] pps_core: LinuxPPS API ver. 1 registered
[ 0.253906] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.253925] PTP clock support registered
[ 0.253962] EDAC MC: Ver: 3.0.0
[ 0.254511] Advanced Linux Sound Architecture Driver Initialized.
[ 0.255128] clocksource: Switched to clocksource arch_sys_counter
[ 0.262137] NET: Registered protocol family 2
[ 0.262557] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.262585] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.262633] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.262664] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.262679] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.262783] NET: Registered protocol family 1
[ 0.262947] RPC: Registered named UNIX socket transport module.
[ 0.262953] RPC: Registered udp transport module.
[ 0.262958] RPC: Registered tcp transport module.
[ 0.262963] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.263105] Unpacking initramfs...
[ 0.265645] Freeing initrd memory: 52K (cfff3000 - d0000000)
[ 0.265776] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.266328] platform alarmtimer: set dma_pfn_offset00780000
[ 0.266686] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.272331] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.272823] NFS: Registering the id_resolver key type
[ 0.272841] Key type id_resolver registered
[ 0.272847] Key type id_legacy registered
[ 0.272893] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.273879] bounce: pool size: 64 pages
[ 0.273993] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 248)
[ 0.274007] io scheduler noop registered
[ 0.274016] io scheduler deadline registered
[ 0.274043] io scheduler cfq registered (default)
[ 0.274144] keystone_irq soc:keystone_irq@26202a0: irqchip registered, nr_irqs 28
[ 0.274643] ti,keystone-serdes 232a000.phy: init fw ks2_gbe_serdes.bin: version 3.3.0.2c
[ 0.277419] keystone-rapidio 2900000.rapidio: KeyStone RapidIO driver v1.4
[ 0.277461] keystone-rapidio 2900000.rapidio: missing "rx-queue" parameter for mbox 0, using qpend
[ 0.277472] keystone-rapidio 2900000.rapidio: missing "tx-completion-queue" parameter for mbox 0, using qpend
[ 0.277479] keystone-rapidio 2900000.rapidio: missing "tx-garbage-queue" parameter for mbox 0, using qpend
[ 0.277490] keystone-rapidio 2900000.rapidio: missing "rx-queue" parameter for mbox 1, using qpend
[ 0.277500] keystone-rapidio 2900000.rapidio: missing "tx-completion-queue" parameter for mbox 1, using qpend
[ 0.277507] keystone-rapidio 2900000.rapidio: missing "tx-garbage-queue" parameter for mbox 1, using qpend
[ 0.277581] keystone-rapidio 2900000.rapidio: using K2 SerDes
[ 0.277620] keystone-rapidio 2900000.rapidio: initializing 5.00 Gbps interface with port configuration 4
[ 0.495251] keystone-rapidio 2900000.rapidio: packet forwarding disabled
[ 0.605749] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 0, number of queues 8192
[ 0.605871] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 0, num of queues 8192, reg_peek f0a00000, reg_status f0972000, reg_config f0978000, reg_region f097a000, reg_push f0a40000, reg_pop f0a80000
[ 0.605881] keystone-navigator-qmss soc:qmss@2a40000: qmgr start queue 8192, number of queues 8192
[ 0.605984] keystone-navigator-qmss soc:qmss@2a40000: added qmgr start queue 8192, num of queues 8192, reg_peek f0ac0000, reg_status f097c400, reg_config f097e000, reg_region f09c2000, reg_push f0b00000, reg_pop f0b40000
[ 0.606249] keystone-navigator-qmss soc:qmss@2a40000: firmware file ks2_qmss_pdsp_acc48.bin downloaded for pdsp0
[ 0.606312] keystone-navigator-qmss soc:qmss@2a40000: firmware file ks2_qmss_pdsp_qos.bin downloaded for pdsp3
[ 0.606374] keystone-navigator-qmss soc:qmss@2a40000: firmware file ks2_qmss_pdsp_qos.bin downloaded for pdsp7
[ 0.607289] keystone-navigator-qmss soc:qmss@2a40000: qos: sched port @8096, drop sched @8000
[ 0.608726] keystone-navigator-qmss soc:qmss@2a40000: qos: sched port @6496, drop sched @6400
[ 0.610587] keystone-navigator-qmss soc:qmss@2a40000: qos version 0x200010b, magic valid
[ 0.611117] keystone-navigator-qmss soc:qmss@2a40000: qos version 0x200010b, magic valid
[ 0.612081] keystone-navigator-dma soc:knav_dmas@0: DMA dma_gbe registered 41 logical channels, flows 32, tx chans: 9, rx chans: 24
[ 0.612186] keystone-navigator-dma soc:knav_dmas@0: DMA dma_xgbe registered 48 logical channels, flows 32, tx chans: 16, rx chans: 16
[ 0.612285] keystone-navigator-dma soc:knav_dmas@0: DMA dma_srio registered 36 logical channels, flows 20, tx chans: 16, rx chans: 16
[ 0.655640] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.655709] platform serial8250: set dma_pfn_offset00780000
[ 0.657998] console [ttyS0] disabled
[ 0.658041] 2530c00.serial: ttyS0 at MMIO 0x2530c00 (irq = 26, base_baud = 12500000) is a 16550A
[ 1.714825] console [ttyS0] enabled
[ 1.718963] 2531000.serial: ttyS1 at MMIO 0x2531000 (irq = 27, base_baud = 12500000) is a 16550A
[ 1.728291] [drm] Initialized drm 1.1.0 20060810
[ 1.738579] loop: module loaded
[ 1.741976] at24 0-0050: 131072 byte 24c1024 EEPROM, writable, 1 bytes/write
[ 1.750266] spi_davinci 21000400.spi: DMA is not supported (-19)
[ 1.756855] m25p80 spi32766.0: n25q128a11 (16384 Kbytes)
[ 1.762203] 2 ofpart partitions found on MTD device spi32766.0
[ 1.768066] Creating 2 MTD partitions on "spi32766.0":
[ 1.773222] 0x000000000000-0x000000100000 : "u-boot-spl"
[ 1.779295] 0x000000100000-0x000001000000 : "misc"
[ 1.784810] spi_davinci 21000400.spi: Controller at 0xf0a30400
[ 1.790850] spi_davinci 21000600.spi: DMA is not supported (-19)
[ 1.797197] spi_davinci 21000600.spi: Controller at 0xf0a32600
[ 1.803215] spi_davinci 21000800.spi: DMA is not supported (-19)
[ 1.809559] spi_davinci 21000800.spi: Controller at 0xf0a34800
[ 1.815972] platform Fixed MDIO bus.0: set dma_pfn_offset00780000
[ 1.822205] libphy: Fixed MDIO Bus: probed
[ 1.875150] davinci_mdio 2090300.mdio: davinci mdio revision 1.5
[ 1.881175] libphy: 2090300.mdio: probed
[ 1.885777] davinci_mdio 2090300.mdio: phy[0]: device 2090300.mdio:00, driver Marvell 88E1111
[ 1.894334] davinci_mdio 2090300.mdio: phy[1]: device 2090300.mdio:01, driver Marvell 88E1111
[ 1.903484] ti,keystone-serdes 232a000.phy: Requested PHY is disabled
[ 2.421461] ti,keystone-serdes 232a000.phy: Requested PHY is disabled
[ 2.940688] netcp-1.0 2620110.netcp: initialized cpsw ale version 1.3
[ 2.947169] netcp-1.0 2620110.netcp: ALE Table size 1024
[ 2.953800] netcp-1.0 2620110.netcp: module(netcp-xgbe) not used for device
[ 2.961007] netcp-1.0 2620110.netcp: pa_clk_rate(163840000 HZ),mult(25000),shift(12)
[ 2.970270] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.00:0x03000200 on pdsp 0
[ 2.978519] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.00:0x03000200 on pdsp 1
[ 2.986741] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.00:0x03000200 on pdsp 2
[ 2.994947] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.00:0x03000200 on pdsp 3
[ 3.003171] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.00:0x03000200 on pdsp 4
[ 3.011407] netcp-1.0 2620110.netcp: Using PA fw version 03.00.02.00:0x03000200 on pdsp 5
[ 3.019991] netcp-1.0 2620110.netcp: module(netcp-pa2) not used for device
[ 3.027631] 2620738.usb_phy supply vcc not found, using dummy regulator
[ 3.034642] mousedev: PS/2 mouse device common for all mice
[ 3.040572] i2c /dev entries driver
[ 3.046202] ledtrig-cpu: registered to indicate activity on CPUs
[ 3.053758] nand: device found, Manufacturer ID: 0x2c, Chip ID: 0xac
[ 3.060150] nand: Micron MT29F4G08ABBDAHC
[ 3.064170] nand: 512 MiB, SLC, erase size: 128 KiB, page size: 2048, OOB size: 64
[ 3.072068] Bad block table found at page 262080, version 0x01
[ 3.078457] Bad block table found at page 262016, version 0x01
[ 3.084574] nand_read_bbt: bad block at 0x000000c80000
[ 3.089741] nand_read_bbt: bad block at 0x000000ca0000
[ 3.094950] 3 ofpart partitions found on MTD device 30000000.nand
[ 3.101075] Creating 3 MTD partitions on "30000000.nand":
[ 3.106501] 0x000000000000-0x000000100000 : "u-boot"
[ 3.112248] 0x000000100000-0x000000180000 : "params"
[ 3.117962] 0x000000180000-0x000020000000 : "ubifs"
[ 3.123921] davinci_nand 30000000.nand: controller rev. 2.5
[ 3.129902] platform snd-soc-dummy: set dma_pfn_offset00780000
[ 3.136898] NET: Registered protocol family 10
[ 3.141997] sit: IPv6 over IPv4 tunneling driver
[ 3.147056] NET: Registered protocol family 17
[ 3.151653] Key type dns_resolver registered
[ 3.156026] Registering SWP/SWPB emulation handler
[ 3.162204] hctosys: unable to open rtc device (rtc0)
[ 3.255824] netcp-1.0 2620110.netcp eth0: Link is Down
[ 3.261253] pps pps0: new PPS source ptp0
[ 3.265311] cpts rftclk: sel(1),rate(400000000 HZ),mult(2560),shift(10),div(1)
[ 3.277244] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 3.365819] netcp-1.0 2620110.netcp eth1: Link is Down
[ 3.373875] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 7.255519] netcp-1.0 2620110.netcp eth0: Link is Up - 1Gbps/Full - flow control off
[ 7.275153] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.295207] Sending DHCP requests .., OK
[ 10.855141] IP-Config: Got DHCP answer from 10.10.10.1, my address is 10.10.10.30
[ 11.245483] IP-Config: Complete:
[ 11.248722] device=eth0, hwaddr=b4:99:4c:b7:0e:de, ipaddr=10.10.10.30, mask=255.255.255.0, gw=10.10.10.1
[ 11.258702] host=TI-k2hevm-Joy, domain=, nis-domain=(none)
[ 11.264640] bootserver=0.0.0.0, rootserver=10.10.10.6, rootpath=
[ 11.270958] nameserver0=10.10.10.1
[ 11.284966] ALSA device list:
[ 11.287952] No soundcards found.
[ 11.310700] VFS: Mounted root (nfs filesystem) on device 0:14.
[ 11.316876] devtmpfs: mounted
[ 11.319985] Freeing unused kernel memory: 284K (c08af000 - c08f6000)
[ 11.326394] This architecture does not have kernel memory protection.
[ 11.418777] systemd[1]: System time before build time, advancing clock.
[ 11.444326] random: systemd: uninitialized urandom read (16 bytes read, 38 bits of entropy available)
[ 11.456593] random: systemd: uninitialized urandom read (16 bytes read, 39 bits of entropy available)
[ 11.467853] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT -GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 11.486253] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.08!
[ 11.516190] systemd[1]: Set hostname to <k2hk-evm>.
[ 11.585581] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 48 bits of entropy available)
[ 11.602293] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 49 bits of entropy available)
[ 11.621147] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 50 bits of entropy available)
[ 11.681127] random: systemd: uninitialized urandom read (16 bytes read, 55 bits of entropy available)
[ 11.690600] random: systemd: uninitialized urandom read (16 bytes read, 55 bits of entropy available)
[ 11.706677] random: systemd: uninitialized urandom read (16 bytes read, 56 bits of entropy available)
[ 11.716378] random: systemd: uninitialized urandom read (16 bytes read, 56 bits of entropy available)
[ 11.740095] random: systemd: uninitialized urandom read (16 bytes read, 59 bits of entropy available)
[ 11.823664] systemd[1]: [/lib/systemd/system/syslog-ng.service:6] Executable path is not absolute, ignoring: @SBINDIR@/syslog-ng -F -p @LOCALSTATEDIR@/run/syslogd.pid
[ 11.838703] systemd[1]: [/lib/systemd/system/syslog-ng.service:7] Executable path is not absolute, ignoring: @BASEBINDIR@/kill -HUP $MAINPID
[ 11.851559] systemd[1]: syslog-ng.service: Service lacks both ExecStart= and ExecStop= setting. Refusing.
[ 11.947788] systemd[1]: syslog-ng.service: Cannot add dependency job, ignoring: Unit syslog-ng.service is not loaded properly: Invalid argument.
[ 11.961184] systemd[1]: sysinit.target: Found ordering cycle on sysinit.target/start
[ 11.969024] systemd[1]: sysinit.target: Found dependency on alignment.service/start
[ 11.976741] systemd[1]: sysinit.target: Found dependency on basic.target/start
[ 11.983993] systemd[1]: sysinit.target: Found dependency on sockets.target/start
[ 11.991428] systemd[1]: sysinit.target: Found dependency on dbus.socket/start
[ 11.998605] systemd[1]: sysinit.target: Found dependency on sysinit.target/start
[ 12.006042] systemd[1]: sysinit.target: Breaking ordering cycle by deleting job alignment.service/start
[ 12.015486] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with sysinit.target/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 12.047068] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 12.076084] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 12.105394] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 12.135623] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 12.155405] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 12.186404] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 12.235310] systemd[1]: Mounting POSIX Message Queue File System...
[ 12.267833] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 12.295615] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 12.365397] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 12.395881] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 12.425806] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 12.462907] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 12.485210] systemd[1]: syslog.socket: Socket service syslog-ng.service not loaded, refusing.
[ 12.493783] systemd[1]: Failed to listen on Syslog Socket.
[FAILED] Failed to listen on Syslog Socket.
See 'systemctl status syslog.socket' for details.
[ 12.535731] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 12.565272] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 12.625315] systemd[1]: Mounting Debug File System...
[ 12.647064] systemd[1]: Starting Setup Virtual Console...
[ 12.679838] systemd[1]: Starting Load Kernel Modules...
[ 12.689602] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 12.703032] CMEMK module: reference Linux version 4.4.19
[ 12.708785] allocated heap buffer 0xc100000 of size 0x480000
[ 12.714496] allocated heap buffer 0x822000000 of size 0x7000000
[ 12.722553] systemd[1]: Starting Journal Service...
[ 12.723927] cmemk initialized
[ 12.730059] cryptodev: driver 1.8 loaded.
[ 12.755358] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 12.777036] NET: Registered protocol family 41
[ 12.787348] uio_module_drv soc:mpax: registered misc device mpax
[ 12.793567] uio_module_drv soc:edma3: registered misc device edma3
[ 12.800071] uio_module_drv soc:secmgr: registered misc device secmgr
[ 12.806664] uio_module_drv soc:qmss: registered misc device qmss
[ 12.818286] uio_module_drv soc:hyperlink0: registered misc device hyperlink0
[ 12.825349] systemd[1]: Mounting Temporary Directory...
[ 12.831220] uio_module_drv soc:hyperlink1: registered misc device hyperlink1
Mounting Tempora[ 12.839591] uio_module_drv soc:srio: registered misc device srio
ry Directory...
[ 12.865462] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 12.895234] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 12.948949] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 12.975275] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 12.995295] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 13.015431] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Load Kernel Modules.
Starting Apply Kernel Variables...
Starting udev Coldplug all Devices...
Starting Create Static Device Nodes in /dev...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Apply Kernel Variables.
[ OK ] Started Create Static Device Nodes in /dev.
[ 13.556226] systemd-journald[124]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Pers[ 13.575145] random: nonblocking pool is initialized
istent Storage.
Starting udev Kernel Device Manager...
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
[ OK ] Started udev Coldplug all Devices.
[ 13.885799] keystone-rproc 10800000.dsp0: assigned reserved memory node dsp_common_cma_pool
[ 13.894237] remoteproc0: 10800000.dsp0 is available
[ 13.899963] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ 13.909208] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 13.928003] keystone-rproc 11800000.dsp1: assigned reserved memory node dsp_common_cma_pool
[ 13.938267] remoteproc1: 11800000.dsp1 is available
[ 13.944011] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 13.954357] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 13.968689] keystone-rproc 12800000.dsp2: assigned reserved memory node dsp_common_cma_pool
[ 13.978406] remoteproc2: 12800000.dsp2 is available
[ 13.983581] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 13.992671] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 14.005254] keystone-rproc 13800000.dsp3: assigned reserved memory node dsp_common_cma_pool
[ 14.013791] remoteproc3: 13800000.dsp3 is available
[ 14.018966] remoteproc3: Note: remoteproc is still under development and considered experimental.
[ 14.028386] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 14.046116] keystone-rproc 14800000.dsp4: assigned reserved memory node dsp_common_cma_pool
[ 14.055074] remoteproc4: 14800000.dsp4 is available
[ 14.061512] remoteproc4: Note: remoteproc is still under development and considered experimental.
[ 14.071219] remoteproc4: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 14.084999] davinci-wdt 22f0080.wdt: heartbeat 60 sec
[ 14.094634] keystone-rproc 15800000.dsp5: assigned reserved memory node dsp_common_cma_pool
[ 14.107904] remoteproc5: 15800000.dsp5 is available
[ 14.112934] remoteproc5: Note: remoteproc is still under development and considered experimental.
[ 14.122030] remoteproc5: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 14.134588] keystone-rproc 16800000.dsp6: assigned reserved memory node dsp_common_cma_pool
[ 14.143120] remoteproc6: 16800000.dsp6 is available
[ 14.148173] remoteproc6: Note: remoteproc is still under development and considered experimental.
[ 14.157181] remoteproc6: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 14.171384] keystone-rproc 17800000.dsp7: assigned reserved memory node dsp_common_cma_pool
[ 14.180076] remoteproc7: 17800000.dsp7 is available
[ 14.185081] remoteproc7: Note: remoteproc is still under development and considered experimental.
[ 14.194137] remoteproc7: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 14.273235] keystone-dsp-mem c000000.dspmem: registered misc device dspmem
[ OK ] Found device /dev/ttyS0.
[ 14.752540] keystone-crypto soc:subsys@20c0000:crypto@0: crypto accelerator enabled
[ 15.096077] platform xhci-hcd.0.auto: set dma_pfn_offset00780000
[ 15.123193] usbcore: registered new interface driver usbfs
[ 15.129504] usbcore: registered new interface driver hub
[ 15.135328] usbcore: registered new device driver usb
[ 15.148074] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 15.153594] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1
[ 15.162438] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f06d hci version 0x100 quirks 0x00010010
[ 15.171235] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0x02690000
[ 15.177840] hub 1-0:1.0: USB hub found
[ 15.181627] hub 1-0:1.0: 1 port detected
[ 15.185924] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller
[ 15.191436] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2
[ 15.199197] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ 15.207868] hub 2-0:1.0: USB hub found
[ 15.211651] hub 2-0:1.0: 1 port detected
[ 15.565436] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd
[ 15.638722] SCSI subsystem initialized
[ 15.647876] usb-storage 2-1:1.0: USB Mass Storage device detected
[ 15.654375] scsi host0: usb-storage 2-1:1.0
[ 15.659732] usbcore: registered new interface driver usb-storage
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ OK ] Started Network Time Synchronization.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Reached target System Time Synchronized.
Starting Synchronize System and HW clocks...
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ OK ] Reached target System Initialization.
[ OK ] Listening on RPCbind Server Activation Socket.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on dropbear.socket.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting softhsm-daemon.service...
Starting telnetd.service...
Starting Login Service...
Starting Print notice about GPLv3 packages...
[ OK ] Started D-Bus System Message [ 16.831482] scsi 0:0:0:0: Direct-Access Samsung Flash Drive 1100 PQ: 0 ANSI: 6
Bus.
[ 16.869045] sd 0:0:0:0: [sda] 125337600 512-byte logical blocks: (64.2 GB/59.8 GiB)
[ 16.879665] sd 0:0:0:0: [sda] Write Protect is off
[ 16.888104] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[ 16.902818] sda: sda1 sda2
[ 16.912005] sd 0:0:0:0: [sda] Attached SCSI removable disk
Starting Network Service...
Starting run_srss_tc.service...
[ OK ] Started System Logging Service.
Starting Permit User Sessions...
[ OK ] Started strongSwan IPsec IKEv1/IKEv2 daemon using ipsec.conf.
Starting tiipclad-daemon.service...
[ OK ] Started Kernel Logging Service.
Starting Ethernet Bridge Filtering Tables...
Starting TI Multiproc Manager...
[ OK ] Started softhsm-daemon.service.
[ OK ] Started telnetd.service.
[ OK ] Started Permit User Sessions.
[ OK ] Started run_srss_tc.service.
[ OK ] Started Ethernet Bridge Filtering Tables.
[ OK ] Started tiipclad-daemon.service.
[ OK ] Started Network Service.
[ OK 17.247866] NET: Registered protocol family 15
m] Started TI Multiproc Manager.
[ 17.313676] IPsec: esp4_init: can't add xfrm type
[ 17.354982] uio_module_drv soc:secmgr: request address 0x0 is not in the allowed ranges
[ 17.460957] Initializing XFRM netlink socket
[ OK ] Reached target Network.
[ 17.505604] EXT4-fs (sda2): recovery complete
[ 17.510067] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
Starting Network Name Resolution[ 17.522623] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null)
[ OK ] Started Vsftpd ftp daemon.
Starting Lightning Fast Webserver With Light System Requirements...
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started Getty on tty1.
Starting thttpd.service...
[ OK ] Started Lightning Fast Webserver With Light System Requirements.
[ OK ] Started thttpd.service.
[ OK ] Started Network Name Resolution.
[ OK ] Started Login Service.
Starting rng-tools.service...
[ OK ] Started rng-tools.service.
Starting gdbserverproxy.service...
[ OK ] Started gdbserverproxy.service.
Starting matrix-gui-2.0.service...
[ OK ] Started matrix-gui-2.0.service.
Starting parse-ip.service...
Starting thermal-zone-init.service...
[ OK ] Started thermal-zone-init.service.
NOTICE: This file system contains the following GPLv3 packages:
autoconf
binutils-dev
binutils
bison-dev
bison
cpp-symlinks
cpp
dosfstools
g++-symlinks
g++
gawk-dev
gawk
gcc-symlinks
gcc
gdb
gdbc6x
gdbserver
gstreamer1.0-libav
hidapi
libcairo-perf-utils
libgmp10
libidn11
libmpc3
libmpfr4
make
nettle
swig-dev
swig
If you do not wish to distribute GPLv3 components please remove
the above packages prior to distribution. This can be done using
the opkg remove command. i.e.:
opkg remove <package>
Where <package> is the name printed in the list above
NOTE: If the package is a dependency of another package you
will be notified of the dependent packages. You should
use the --force-removal-of-dependent-packages option to
also remove the dependent packages as well
[ OK ] Started Print notice about GPLv3 packages.
#>>>>> LCD 12
IP Address:
10.10.10.30
[ OK ] Started parse-ip.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org k2hk-evm ttyS0
Arago 2016.08 k2hk-evm ttyS0
k2hk-evm login: [ 31.805161] keystone-rapidio 2900000.rapidio: RIO port register timeout, port mask 0x1 not ready
[ 15.638349] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 15.643870] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 1 [ 15.652083] xhci-hcd xhci-hcd.0.auto: hcc params 0x0298f06d hci version 0x100 quirks 0x00010010 [ 15.660851] xhci-hcd xhci-hcd.0.auto: irq 34, io mem 0x02690000 [ 15.667435] hub 1-0:1.0: USB hub found [ 15.671222] hub 1-0:1.0: 1 port detected [ 15.675509] xhci-hcd xhci-hcd.0.auto: xHCI Host Controller [ 15.681021] xhci-hcd xhci-hcd.0.auto: new USB bus registered, assigned bus number 2 [ 15.688802] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM. [ 15.697475] hub 2-0:1.0: USB hub found [ 15.701256] hub 2-0:1.0: 1 port detected [ 16.055408] usb 2-1: new SuperSpeed USB device number 2 using xhci-hcd [ 16.126142] SCSI subsystem initialized [ 16.135744] usb-storage 2-1:1.0: USB Mass Storage device detected [ 16.152244] scsi host0: usb-storage 2-1:1.0 [ 16.156796] usbcore: registered new interface driver usb-storage [ 17.299235] NET: Registered protocol family 15 [ 17.330027] IPsec: esp4_init: can't add xfrm type [ 17.334954] scsi 0:0:0:0: Direct-Access Samsung Flash Drive 1100 PQ: 0 ANSI: 6 [ 17.354614] sd 0:0:0:0: [sda] 125337600 512-byte logical blocks: (64.2 GB/59.8 GiB) [ 17.363070] sd 0:0:0:0: [sda] Write Protect is off [ 17.368205] sd 0:0:0:0: [sda] Mode Sense: 43 00 00 00 [ 17.368688] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA [ 17.386017] sda: sda1 sda2 [ 17.393802] sd 0:0:0:0: [sda] Attached SCSI removable disk [ 17.549062] Initializing XFRM netlink socket [ 17.853016] uio_module_drv soc:secmgr: request address 0x0 is not in the allowed ranges [ 17.890001] FAT-fs (sda1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck. [ 17.968755] EXT4-fs (sda2): recovery complete [ 17.973138] EXT4-fs (sda2): mounted filesystem with ordered data mode. Opts: (null) [ 31.805158] keystone-rapidio 2900000.rapidio: RIO port register timeout, port mask 0x1 not ready [ 5241.445648] netcp-1.0 2620110.netcp eth0: Link is Down [ 5242.245965] netcp-1.0 2620110.netcp eth0: Link is Up - 1Gbps/Full - flow control off [ 5242.245965] netcp-1.0 2620110.netcp eth0: Link is Up - 1Gbps/Full - flow control off [ 5888.244394] netcp-1.0 2620110.netcp eth0: Link is Down [ 6068.393996] nfs: server 10.10.10.6 not responding, still trying [ 6068.393998] nfs: server 10.10.10.6 not responding, still trying
We never ran into this issue with the MCSDK-HPC. We are wondering whether there are any known issues in this area with the Processor SDK. Any advice will be much appreciated.
Kathy
