Part Number: TMDSEVM6678
Tool/software: TI-RTOS
I have installed on Windowa 8.1
- ccs_setup_7.3.0.00019
- ti-processor-sdk-rtos-c667x-evm-04.01.00.06-Windows-x86-Install
I am trying to rebuild the PDK (C:\ti\PDK_C6~1\packages) using these files:
- pdksetupenv.bat
- pdkProjectCreate
The steps I am following are here: processors.wiki.ti.com/.../Rebuilding_The_PDK
When I run the first file, the folders are not correct. For example, there isn't /ccsv7/tools/compiler/gcc-arm-none-eabi...
C:\ti\PDK_C6~1\packages>pdksetupenv.bat Optional parameter not configured : CG_XML_BIN_INSTALL_PATH REQUIRED for xdc release build Example: set CG_XML_BIN_INSTALL_PATH=C:/ti/cg_xml/bin Optional parameter not configured : DOXYGEN_INSTALL_PATH REQUIRED for xdc release build Example: set DOXYGEN_INSTALL_PATH=C:/ti/Doxygen/doxygen/1.5.1-p1/bin ************************************************************************** Environment Configuration: LIMIT_SOCS : c6678 LIMIT_BOARDS : evmC6678 PDK_INSTALL_PATH : /ti/PDK_C6~1/packages C6X_GEN_INSTALL_PATH : C:/ti/ti-cgt-c6000_8.1.3 TOOLCHAIN_PATH_GCC : C:/ti/gcc-arm-none-eabi-4_9-2015q3 TOOLCHAIN_PATH_A15 : C:/ti/gcc-arm-none-eabi-4_9-2015q3 TOOLCHAIN_PATH_A8 : C:/ti/gcc-arm-none-eabi-4_9-2015q3 TOOLCHAIN_PATH_A9 : C:/ti/gcc-arm-none-eabi-4_9-2015q3 TOOLCHAIN_PATH_M4 : C:/ti/ti-cgt-arm_16.9.3.LTS TOOLCHAIN_PATH_Arm9 : C:/ti/ti-cgt-arm_16.9.3.LTS TOOLCHAIN_PATH_EVE : C:/ti/arp32_1.0.8 CL_PRU_INSTALL_PATH : C:/ti/ti-cgt-pru_2.1.5 UTILS_INSTALL_DIR : C:/ti/xdctools_3_32_01_22_core/bin FPULIB_PATH : C:/ti/gcc-arm-none-eabi-4_9-2015q3/lib/gcc/arm-n one-eabi/4.9.3/fpu CROSS_TOOL_PRFX : arm-none-eabi- XDC_INSTALL_PATH : C:/ti/xdctools_3_32_01_22_core BIOS_INSTALL_PATH : C:/ti/bios_6_46_05_55 IPC_INSTALL_PATH : C:/ti/ipc_3_46_02_04 EDMA3LLD_BIOS6_INSTALLDIR : C:/ti/edma3_lld_2_12_05_29 NDK_INSTALL_PATH : C:/ti/ndk_2_25_01_11 IMGLIB_INSTALL_PATH : C:/ti/imglib_c66x_3_1_1_0 DSPLIB_INSTALL_PATH : C:/ti/dsplib_c66x_3_4_0_0 MATHLIB_INSTALL_PATH : C:/ti/mathlib_c66x_3_1_1_0 UIA_INSTALL_PATH : C:/ti/uia_2_00_06_52 ************************************************************************** Changing to short name to support directory names containing spaces current directory: /ti/PDK_C6~1/packages PDK BUILD ENVIRONMENT CONFIGURED **************************************************************************
Then, I run the second file and the test projects are never detected. Help me please!
