RTOS/TMDXLCDK6748: Internal exception: IERR=0x1 Instruction fetch exception ti.sysbios.family.c64p.Exception: line 256
Part Number: TMDXLCDK6748
Other Parts Discussed in Thread: SYSBIOS, OMAPL138
Tool/software: TI-RTOS
Recently my program often die with "ti.sysbios.family.c64p.Exception: line 256: E_exceptionMax: pc = 0xc0112df4, sp = 0xc0115110." when it run for a long time.
I have check the hwi stack size and task stack size. Both are free space available.
I have no experience debug this sort of error. Can someone help me out? thx
    Please share which SDK version are yo using?
    Under what circumstances did you get this error? Which SDK driver were you utilizing?
    Yordan
  • Sorry for mention that, Yordan Kovachev. I am using Process SDK RTOS OMAPL138 LCDK 4.00.00.04 on my custom C6746 board.
    Recently I add system stack size in my app.cfg
    The problem occur more often. Even when i start my app application.
    I guess this is caused by memory issue. this is piece of my app.cfg
    ** Create a Heap.
    var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
    var heapMemParams = new HeapMem.Params();
    heapMemParams.size = 0x20000;
    heapMemParams.sectionName = "systemHeap";
    Program.global.heap0 = HeapMem.create(heapMemParams);
    var heapMem0Params = new HeapMem.Params();
    heapMem0Params.instance.name = "MyHeap";
    heapMem0Params.size = 91392;
    heapMem0Params.align = 8;
    heapMem0Params.sectionName = "MyHeap";
    Program.global.MyHeap = HeapMem.create(heapMem0Params);
    var heapMem1Params = new HeapMem.Params();
    heapMem1Params.instance.name = "TcpHeap";
    heapMem1Params.size = 15232;
    heapMem1Params.sectionName = "TcpHeap";
    Program.global.TcpHeap = HeapMem.create(heapMem1Params);
    /* This is the default memory heap. */
    Memory.defaultHeapInstance  =   Program.global.heap0;
    Program.sectMap["sharedL2"] = "DDR";
    Program.sectMap["systemHeap"] = "DDR";
    Program.sectMap["MyHeap"] = "DDR";
    Program.sectMap["TcpHeap"] = "DDR";
    Program.sectMap[".sysmem"]  = "DDR";
    Program.sectMap[".args"]    = "DDR";
    Program.sectMap[".cio"]     = "DDR";
    Program.sectMap[".far"] 	= 	"DDR";
    Program.sectMap[".rodata"] 	= 	"DDR";
    Program.sectMap[".neardata"] 	= 	"DDR";
    Program.sectMap[".cppi"] 	= 	"DDR";
    Program.sectMap[".init_array"] 	= 	"DDR";
    Program.sectMap[".qmss"] 	= 	"DDR";
    Program.sectMap[".cinit"] 	= 	"DDR";
    Program.sectMap[".bss"]		=	"DDR";
    Program.sectMap[".const"]	=	"DDR";
    Program.sectMap[".text"]	=	"DDR";
    Program.sectMap[".code"]	=	"DDR";
    Program.sectMap[".switch"]	=	"DDR";
    Program.sectMap[".data"]	=	"DDR";
    Program.sectMap[".fardata"] = 	"DDR";
    Program.sectMap[".vecs"] 	= 	"DDR";
    Program.sectMap["emacComm"]          = "DDR"
    Program.sectMap[".far:taskStackSection"] = "DDR";
    Program.sectMap[".stack"]	=	"DDR";
    Program.sectMap[".far:IMAGEDATA"] = {loadSegment: "DDR", loadAlign: 8};
    Program.sectMap[".far:NDK_OBJMEM"] = {loadSegment: "DDR", loadAlign: 8};
    Program.sectMap[".far:NDK_PACKETMEM"] = {loadSegment: "DDR", loadAlign: 128};
    Program.stack = 0x4000;
    I am not familar with low level memory issue.
    Can someone help me?
  • I found i didn't call I2c_init() before i called other i2c interface. After i fixed this bug. The error doesn't occur till now. I suggest it as the answer of this question. Thank u anyway for replying my question.
