Part Number: DRA718
Hi:
Now I assume that the payload on our custom board is so heavy , so I want to measure the bandwidth of DDR on L3_MAIN_BUS,is there any tool to help us?
if any,Please notify me !
thanks
regard
Part Number: DRA718
Hi:
thanks
regard
Vision-SDK 2.09 included GLSDK 7.03 as the Linux SDK. There's a tool available in the file-system to calculate DDR bandwidth. You can find information on how to use the tool using the link below.
downloads.ti.com/.../DRA7xx_GLSDK_Software_Developers_Guide.html
Shravan
Hi Karthik,
I had meet the same problem now.
I use tda2hx with vision sdk 2.12 ( linux kernel 4.4). the glsdkstallcoll use config file as follow, which are default file from filesystem.
initiators.cfghttps://e2e.ti.com/cfs-file/__key/communityserver-discussions-components-files/791/config.ini
Sid
