Tool/software: Linux
Dear Team,
I need continuous clock to card even out of transaction period from MMC1 & MMC3 in UHS mode of operation
MMC1 base clock selected to 128MHz, MMC3 base clock selected to 192MHz
I have configured
I have set CLKEXTFREE (1 << 16) of CON register in omap_hsmmc.c driver probe.
//Setting free-running clock
OMAP_HSMMC_WRITE(host->base, CON,
(OMAP_HSMMC_READ(host->base, CON) | (1 << 16)));
When I probe the clock signal I could not see continuous clock on the bus. Clock is observed only when there is transaction on the bus.
I have also tried to disable "AUTOIDLE" but no luck
val = OMAP_HSMMC_READ(host->base, HL_SYSCONFIG);
val &= ~( 1 << 0);
OMAP_HSMMC_WRITE(host->base, HL_SYSCONFIG, val);
Register details below:
# cat /sys/kernel/debug/mmc*/regs
mmc0:
sdio irq mode polling
ctx_loss: 1
regs:
CON: 0x00110680
PSTATE: 0x00010000
HCTL: 0x00000b12
SYSCTL: 0x000c0047
IE: 0x00000000
ISE: 0x00000000
CAPA: 0x26e90080
SYSCON: 0x0000301c
mmc1:
ctx_loss: 1
regs:
CON: 0x00180620
PSTATE: 0x01f00000
HCTL: 0x00000d10
SYSCTL: 0x000e0087
IE: 0x00000000
ISE: 0x00000000
CAPA: 0x22e90080
SYSCON: 0x0000301d
mmc2:
ctx_loss: 1
regs:
CON: 0x00010680
PSTATE: 0x01f10000
HCTL: 0x00000b02
SYSCTL: 0x000e00c7
IE: 0x00000000
ISE: 0x00000000
CAPA: 0x26e10080
SYSCON: 0x0000301c
# cat /sys/kernel/debug/mmc*/ios
s
clock: 128000000 Hz
vdd: 21 (3.3 ~ 3.4 V)
bus mode: 2 (push-pull)
chip select: 0 (don't care)
power mode: 2 (on)
bus width: 2 (4 bits)
timing spec: 6 (sd uhs SDR104)
signal voltage: 0 (1.80 V)
driver type: 0 (driver type B)
clock: 52000000 Hz
power mode: 2 (on)
bus width: 3 (8 bits)
timing spec: 8 (mmc DDR52)
signal voltage: 0 (3.30 V)
clock: 64000000 Hz
power mode: 2 (on)
timing spec: 5 (sd uhs SDR50)
Please help how this can be resolved.
Vamshi G.
