Part Number: DRA745
Tool/software: Linux
Evm log as below:
dra7xx-evm login:
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dra7xx-evm ttyS0
Arago 2016.12 dra7xx-evm ttyS0
dra7xx-evm login: root
root@dra7xx-evm:~# modetest
trying to open device 'i915'...failed
trying to open device 'radeon'...failed
trying to open device 'nouveau'...failed
trying to open device 'vmwgfx'...failed
trying to open device 'omapdrm'...done
Encoders:
id crtc type possible crtcs possible clones
31 34 TMDS 0x00000001 0x00000000
35 0 TMDS 0x00000002 0x00000000
Connectors:
id encoder status name size (mm) modes encoders
32 31 connected unknown-1 0x0 1 31
modes:
name refresh (Hz) hdisp hss hse htot vdisp vss vse vtot)
1920x1200 60 1920 2032 2048 2080 1200 1216 1218 1234 flags: nhsync, nvsync; type: preferred, driver
props:
1 EDID:
flags: immutable blob
blobs:
value:
2 DPMS:
flags: enum
enums: On=0 Standby=1 Suspend=2 Off=3
value: 0
36 0 disconnected HDMI-A-1 0x0 0 35
props:
1 EDID:
blobs:
value:
2 DPMS:
flags: enum
value: 0
CRTCs:
id fb pos size
34 46 (0,0) (1920x1200)
props:
27 trans-key-mode:
flags: enum
enums: disable=0 gfx-dst=1 vid-src=2
value: 0
28 trans-key:
flags: range
values: 0 16777215
value: 0
29 background:
flags: range
values: 0 16777215
value: 0
30 alpha_blender:
flags: range
values: 0 1
value: 0
21 GAMMA_LUT:
flags: blob
blobs:
value:
22 GAMMA_LUT_SIZE:
flags: immutable range
values: 0 4294967295
value: 256
23 rotation:
flags: bitmask
values: rotate-0=0x1 rotate-90=0x2 rotate-180=0x4 rotate-270=0x8 reflect-x=0x10 reflect-y=0x20
value: 1
24 zorder:
flags: range
values: 0 3
value: 0
38 0 (0,0) (0x0)
0 0 0 0 0 0 0 0 0 flags: ; type:
props:
27 trans-key-mode:
flags: enum
value: 0
28 trans-key:
flags: range
values: 0 16777215
value: 0
29 background:
flags: range
values: 0 16777215
value: 0
30 alpha_blender:
flags: range
values: 0 1
value: 0
21 GAMMA_LUT:
flags: blob
blobs:
value:
22 GAMMA_LUT_SIZE:
value: 256
23 rotation:
flags: bitmask
value: 1
24 zorder:
flags: range
values: 0 3
value: 0
Planes:
id crtc fb CRTC x,y x,y gamma size possible crtcs
33 34 46 0,0 0,0 0 0x00000001
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24
props:
5 type:
flags: immutable enum
enums: Overlay=0 Primary=1 Cursor=2
value: 1
23 rotation:
flags: bitmask
value: 1
24 zorder:
flags: range
values: 0 3
value: 0
25 global_alpha:
flags: range
values: 0 255
value: 255
26 pre_mult_alpha:
flags: range
values: 0 1
value: 0
37 0 0 0,0 0,0 0 0x00000002
formats: RG16 RX12 XR12 RA12 AR12 XR15 AR15 RG24 RX24 XR24 RA24 AR24 NV12 YUYV UYVY
props:
5 type:
value: 1
23 rotation:
flags: bitmask
value: 1
24 zorder:
flags: range
values: 0 3
value: 0
25 global_alpha:
flags: range
values: 0 255
value: 255
26 pre_mult_alpha:
flags: range
values: 0 1
value: 0
39 0 0 0,0 0,0 0 0x00000003
props:
5 type:
value: 0
23 rotation:
flags: bitmask
value: 1
24 zorder:
flags: range
values: 0 3
value: 2
25 global_alpha:
flags: range
values: 0 255
value: 255
26 pre_mult_alpha:
flags: range
values: 0 1
value: 0
40 0 0 0,0 0,0 0 0x00000003
props:
5 type:
value: 0
23 rotation:
flags: bitmask
value: 1
24 zorder:
flags: range
values: 0 3
value: 3
25 global_alpha:
flags: range
values: 0 255
value: 255
26 pre_mult_alpha:
flags: range
values: 0 1
value: 0
Frame buffers:
id size pitch
root@dra7xx-evm:~# kmscube
trying to load module omapdrm...success.
### Display [0]: CRTC = 34, Connector = 32, format = 0x34325258
Mode chosen [1920x1200] : Clock => 154000, Vertical refresh => 60, Type => 72
Horizontal => 1920, 2032, 2048, 2080, 0
Vertical => 1200, 1216, 1218, 1234, 0
### Primary display => ConnectorId = 32, Resolution = 1920x1200
loaded module : gbm_pvr.so
found valid GBM backend : gbm_pvr.so
Using display 0x1 with EGL version 1.4
EGL Version "1.4 build 1.14@3699939 (MAIN)"
EGL Vendor "Imagination Technologies"
EGL Extensions "EGL_IMG_client_api_ogl EGL_KHR_image EGL_KHR_image_base EGL_KHR_gl_texture_2D_image EGL_KHR_gl_texture_cubemap_image EGL_KHR_gl_renderbuffer_image EGL_KHR_vg_parent_image EGL_IMG_cl_image EGL_KHR_fence_sync EGL_IMG_context_priority EGL_IMG_hibernate_process EGL_IMG_image_plane_attribs EGL_KHR_surfaceless_context EGL_KHR_wait_sync EGL_KHR_create_context EGL_WL_bind_wayland_display EGL_EXT_image_dma_buf_import"
display 0 failed to set mode: Permission denied
root@dra7xx-evm:~#
