Can you comment if 66AK2G12 running at 1000Mhz is required to use heat sink mounted on the device ? As you know, heat sink is not being used in EVM environment, but in general, i think it would be required for the custom board. I believe this is based on the actual use case, but do you have any guideline for heat sink ? for example, part number information, air flow recommendation and etc ...
NK
