AM5728: VPE with Ducati decoder
Part Number: AM5728
I have some query regarding decoder and VPE. I have listdown it as below:
1). What will be the output image-format of ducati decoder?
2). If i want to convert decoded format to BGR24 usng VPE. How can i do that?
Kishan Patel.
    kishan patel14 said:
    1). What will be the output image-format of ducati decoder?r??
    I guess you are asking for gst ducatih264dec, the format is NV12
    Please check VPE user guide:
    software-dl.ti.com/.../Foundational_Components_Kernel_Drivers.html
    Vpe itself is capable of converting to RGB but gstvpe element does not but you could add this support to gstreamervpe element.
    BR
    Margarita
  • Hello Margarita,
    Thanks for reply.
    "Vpe itself is capable of converting to RGB but gstvpe element does not but you could add this support to gstreamervpe element."
    How can i do?
    Kishan Patel.
  • Hello Kishan,
    Please could you let me know for which one you are asking - VPE m2m IP in the linux kernel or for gstreamer VPE element?
    BR
    Margarita
  • Hello Margarita,
    I simply want to do like convert NV12 data to RGB24. Can i?
    What should be required steps to do that?
    Kishan Patel.
    Please check the VPE guide, there is chapter "Testing the driver" with example.
    But if you want to use Gstreamer VPE element you must add RGB support on the output.
    The Gstreamer VPE element supports on the output NV12, YUY2 and YUYV.
    BR
    Margarita
  • Hello Margarita,
    Thanks for guiding me.
    So, how can i add RGB support on the output?
    Kishan Patel.
  • Hello Margarita,
    Are you talking about like use gstreamer api by including some caps and elements as below:
    "rtspsrc location=rtsp://admin:jenex#2018@192.168.1.108:554 latency=150 sync=false ! rtph264depay ! h264parse ! avdec_h264 ! videoconvert ! video/x-raw,format=(string)BGR ! appsink name=sink sync=false"
    Am i right? or are you talking about something else?
    Kishan Patel.
    Could you provide more details how you want to use VPE? Do you want to use it in gstreamer or you want just to test VPE kernel driver(testvpem2m demo) or to test it with another demo?
    So I could you provide you the right information.
    BR
    Margarita
  • Hello Margarita,
    Actually, i want to make simple application like capture data from the on board-camera(mt9t111 output: "yuv" as till i know) and convert that frame to the "RGB" format.
    So, first i have to test it using demo/command.
    Then we can implement application.
    Kishan Patel.
    Okay.
    1. So first you could try testvpem2m there is an example of just scaling/colorspace-converting a progressive 640x480 nv12 clip to a smaller resolution rgb clip:
    $ ./testvpem2m 640_480p.nv12 640 480 nv12 360_240p.rgb24 360 240 rgb24 0 3
    You could find more information regarding this example here:
    2. Here is e2e thread that you could check :
    e2e.ti.com/.../660340
    This thread is for capturevpedisplay demo and how to add rgb24 support to this demo.
    3. Gstreamer case this support could be add since the default gstreamer VPE element does not support this.
    Hope this informations helps you.
    BR
    Margarita
  • Hello Margarita,
    I have checked above link and following steps as below:
    1)cd ti-processor-sdk-linux-am57xxevm-05.00.00.15/board-support/linux-4.14.40+gitAUTONIC+4796173fc5-g4796173fc5
    2)sudo make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- distclean
    3) sudo make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- tisdk_am57xx-evm_defconfig
    4)sudo make ARCH=arm menuconfig (And enable VPE as per provided steps in a guide)
    5)sudo make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- zImage
    6)sudo make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- modules
    7)sudo make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- headers-install
    But after 5th step i got error as below:
    WARNING: EXPORT symbol "__hyp_stub_vectors" [vmlinux] version generation failed, symbol will not be versioned.
    KSYM .tmp_kallsyms1.o
    KSYM .tmp_kallsyms2.o
    LD vmlinux
    SORTEX vmlinux
    SYSMAP System.map
    OBJCOPY arch/arm/boot/Image
    Kernel: arch/arm/boot/Image is ready
    LDS arch/arm/boot/compressed/vmlinux.lds
    AS arch/arm/boot/compressed/head.o
    LZMA arch/arm/boot/compressed/piggy_data
    lzma: (stdin): Cannot allocate memory
    arch/arm/boot/compressed/Makefile:187: recipe for target 'arch/arm/boot/compressed/piggy_data' failed
    make[2]: *** [arch/arm/boot/compressed/piggy_data] Error 1
    arch/arm/boot/Makefile:53: recipe for target 'arch/arm/boot/compressed/vmlinux' failed
    make[1]: *** [arch/arm/boot/compressed/vmlinux] Error 2
    arch/arm/Makefile:336: recipe for target 'zImage' failed
    make: *** [zImage] Error 2
    Kishan Patel.
    The VPE is enable by default.
    You do not need to execute these steps. Just use the default PSDK.
    You could directly try the vpe test demo.
    Margarita
  • Hello Margarita,
    Okay.
    So, how can i test vpe demo.
    I have also clone code from "git://git.ti.com/vpe_tests/vpe_tests.git".
    Then execute "make install".
    But i got error as below:
    root@am57xx-evm:~/vpe_tests# make install
    gcc -g -Wall -I/uapi -I -c -o vpetest.o vpetest.c
    gcc -g -Wall -I/uapi -I vpetest.o -o testvpem2m
    gcc: fatal error: no input files
    compilation terminated.
    make: *** [Makefile:13: testvpem2m] Error 1
    root@am57xx-evm:
    Kishan Patel.
    NO. Please check under /usr/bin or MACHINE=am57xx-evm bitbake vpe-tests and cp testvpem2m demo.
    After that execute ./testvpem2m 640_480p.nv12 640 480 nv12 360_240p.rgb24 360 240 rgb24 0 3.
    BR
    Margarita
  • Hello Margarita,
    I can find 2 files at /usr/bin.
    They are:
    1)capturevpedisplay
    2)filevpedisplay
    Kishan Patel.
    I am sorry Kishan you were using PSDK5.0 right?
    If yes, please you could use test-v4l2-m2m.
    Here is the command :
    root@am57xx-evm:~# test-v4l2-m2m /dev/video0 /usr/share/ti/video/airshow_p352x288.yuv 352 288 nv12 airshow1.rgb 720 480 rgb24 0 1 40
    root@am57xx-evm:~# ls
    airshow1.rgb tibt
    Margarita
  • Hello Margarita,
    Yes. I have executed above command. Please, check the below log:
    root@am57xx-evm:~# test-v4l2-m2m /dev/video1 /usr/share/ti/video/airshow_p352x288.yuv 352 288 nv12 airshow1.rgb 720 480 rgb24 0 1 40
    Input @ 3 = 352 x 288 , 842094158
    Output @ 4 = 720 x 480 , 859981650
    Cant set color format
    : Invalid argument
    root@am57xx-evm:~# ls /dev/video*
    /dev/video0 /dev/video1 /dev/video10 /dev/video11
    S_CTRL success
    query buf, plane 0 = 101376, plane 1 = 50688
    query buf, plane 0 = 1036800, plane 1 = 50688
    Input Buffers = 6 each of size 101376
    Output Buffers = 6 each of size 1036800
    Total bytes read Y plane = 101376
    Total bytes read UV plane = 50688
    dequeued source buffer with index 0
    dequeued dest buffer with index 0
    Latency = 22718usTotal bytes written Y plane = 1036800
    frames left 39
    dequeued source buffer with index 1
    dequeued dest buffer with index 1
    Latency = 58427usTotal bytes written Y plane = 1036800
    frames left 38
    dequeued source buffer with index 2
    dequeued dest buffer with index 2
    Latency = 91624usTotal bytes written Y plane = 1036800
    frames left 37
    dequeued source buffer with index 3
    dequeued dest buffer with index 3
    Latency = 124302usTotal bytes written Y plane = 1036800
    frames left 36
    dequeued source buffer with index 4
    dequeued dest buffer with index 4
    Latency = 157365usTotal bytes written Y plane = 1036800
    frames left 35
    dequeued source buffer with index 5
    dequeued dest buffer with index 5
    Latency = 190189usTotal bytes written Y plane = 1036800
    frames left 34
    Latency = 225769usTotal bytes written Y plane = 1036800
    frames left 33
    Latency = 223316usTotal bytes written Y plane = 1036800
    frames left 32
    Latency = 222686usTotal bytes written Y plane = 1036800
    frames left 31
    Latency = 222857usTotal bytes written Y plane = 1036800
    frames left 30
    Latency = 222998usTotal bytes written Y plane = 1036800
    frames left 29
    Latency = 222918usTotal bytes written Y plane = 1036800
    frames left 28
    Latency = 223283usTotal bytes written Y plane = 1036800
    frames left 27
    Latency = 223056usTotal bytes written Y plane = 1036800
    frames left 26
    Latency = 223111usTotal bytes written Y plane = 1036800
    frames left 25
    Latency = 223161usTotal bytes written Y plane = 1036800
    frames left 24
    Latency = 222860usTotal bytes written Y plane = 1036800
    frames left 23
    Latency = 222931usTotal bytes written Y plane = 1036800
    frames left 22
    Latency = 223384usTotal bytes written Y plane = 1036800
    frames left 21
    Latency = 222805usTotal bytes written Y plane = 1036800
    frames left 20
    Latency = 1226933usTotal bytes written Y plane = 1036800
    frames left 19
    Latency = 1226732usTotal bytes written Y plane = 1036800
    frames left 18
    Latency = 1226547usTotal bytes written Y plane = 1036800
    frames left 17
    Latency = 1226787usTotal bytes written Y plane = 1036800
    frames left 16
    Latency = 1220590usTotal bytes written Y plane = 1036800
    frames left 15
    Latency = 1226758usTotal bytes written Y plane = 1036800
    frames left 14
    Latency = 223055usTotal bytes written Y plane = 1036800
    frames left 13
    Latency = 223327usTotal bytes written Y plane = 1036800
    frames left 12
    Latency = 223719usTotal bytes written Y plane = 1036800
    frames left 11
    Latency = 223856usTotal bytes written Y plane = 1036800
    frames left 10
    Latency = 223956usTotal bytes written Y plane = 1036800
    frames left 9
    Latency = 223983usTotal bytes written Y plane = 1036800
    frames left 8
    Latency = 223512usTotal bytes written Y plane = 1036800
    frames left 7
    Latency = 223204usTotal bytes written Y plane = 1036800
    frames left 6
    Latency = 222900usTotal bytes written Y plane = 1036800
    frames left 5
    Latency = 221811usTotal bytes written Y plane = 1036800
    frames left 4
    Latency = 221113usTotal bytes written Y plane = 1036800
    frames left 3
    Latency = 255821usTotal bytes written Y plane = 1036800
    frames left 2
    Latency = 256544usTotal bytes written Y plane = 1036800
    frames left 1
    Latency = 255830usTotal bytes written Y plane = 1036800
    frames left 0
    Chapter8_FaceRecognition deploy-ipks people-walking-in-nyc-3_-JLkZ7DgH_lower.mov
    MyVdeoFFmpeg.avi ffmpeg-tutorial test_rtsp_live555_opencv.cpp
    Rtsp-live555-Ffmpeg-opencv ffmpeg_test.cpp tibt
    Testing gst_pipr vpe_tests
    Vim live555 xyz.mp4
    airshow1.rgb output.avi
    root@am57xx-evm:~#
    Kishan Patel.
  • Hello Margarita,
    Thanks for reply.
    Now, how can i use it in a program means like i am capturing raw data in NV12 format and then want to convert it in BGR using VPE. Can i? How can i use it?.
    Kishan Patel.
    You asked how you could test nv12->rgb via VPE. test-v4l2-m2m is just a demo  to test VPE. You could try to check the new .rgb file on PC if you want.
    You could also try capturevpedisplay demo. This demo is under /usr/bin
    But first please check this thread, Manisha's answer.
    https://e2e.ti.com/support/arm/sitara_arm/f/791/t/660340
    and apply changes.
    Here is how you could build this demo:
    MACHINE=am57xx-evm bitbake omapdrmtest
    You could try to use gsreamer vpe plugin but at this moment this plugin does not support rgb on the output. But since the VPE low level driver support it, it is possible to add this support for gstreamer vpe plugin.
    Here is the command how you could build gstreamer vpe plugin :
    MACHINE=am57xx-evm bitbake gstreamer1.0-plugins-vpe
    If you make change in the code you must rebuild and cp to the board. Here is the command for this:
    MACHINE=am57xx-evm bitbake <recipe> --force -c compile
    Hope this helps.
    BR
    Margarita
  • Hello Margarita,
    Thanks.
    So, can i use "ducatih264decvpe" in gstreamer api?
    Meanse if i use below command, its working properly:
    gst-launch-1.0 -v rtspsrc location=rtsp://888888:888888@192.168.1.5:554 ! rtph264depay ! h264parse ! ducatih264dec ! videoconvert ! waylandsnk sync=false
    Now, how can use VPE in this command?
    I have tried as below:
    gst-launch-1.0 -v rtspsrc location=rtsp://888888:888888@192.168.1.5:554 ! rtph264depay ! h264parse ! ducatih264decvpe ! waylandsnk sync=false
    But, i could not.
    Kishan Patel.
    As I said gstreamer vpe element does not support rgb on his output. But You could add this support.
    Margarita
  • Hello Margarita,
    I have also 2 other apis as below:
    1).gst-launch-1.0 -v rtspsrc location=rtsp://888888:888888@192.168.1.5:554 ! rtph264depay ! h264parse ! ducatih264decvpe ! 'video/x-raw, format=(string)NV12, width=(int)800, height=(int)600' ! waylandsink
    2).gst-launch-1.0 -v rtspsrc location=rtsp://888888:888888@192.168.1.5:554 ! rtph264depay ! h264parse ! ducatih264decvpe ! 'video/x-raw, format=(string)BGR, width=(int)800, height=(int)600' ! waylandsink
    So, here 1st one is working properly and 2nd one is not working.
    So, thats why are you saying that BGR is not supported?
    If yes, Then what should i follow the steps?
    Kishan Patel.
    you must add this support in the gstvpe code!
    Look into the gstvpe.c file, there you will see that :
    static GstStaticPadTemplate src_factory = GST_STATIC_PAD_TEMPLATE ("src",
        GST_PAD_SRC,
        GST_PAD_ALWAYS,
        GST_STATIC_CAPS (GST_VIDEO_CAPS_MAKE ("NV12")
            ";" GST_VIDEO_CAPS_MAKE ("YUYV")
            ";" GST_VIDEO_CAPS_MAKE ("YUY2")));
    There is no RGB.
    But you could make changes in gstvpe.c file to support this.
    On first look you must add in this function static GstStaticPadTemplate src_factory  RGB.
    In this one gst_vpe_fourcc_to_pixelformat also.
    Check these function gst_vpe_set_output_caps.
    In gstvpebuffer.c check gst_vpe_buffer_new and gst_vpe_buffer_priv functions.
    I would recommend you to check how the other formats are added and to dig deeper in gstreamer vpe element.
    Hope this helps.
    BR
    Margarita
  • Hello Margarita,
    Thanks for reply.
    Actually, i could not find "gstvpe.c" file.
    Kishan Patel.
  • Hello Margarita,
    I have also one doubt about VPE.
    In gstreamer plugin vpe could not provide output in BGR foremat. So, how can demo-application has convert YUV to RGB format?.
    Means what has been used by that demo-app?
    Kishan Patel.
    /tisdk/build/arago-tmp-external-linaro-toolchain/work/am57xx_evm-linux-gnueabi/gstreamer1.0-plugins-vpe/git-rx.xx/git/src
    The both files are there.
    BR
    Margarita
  • Hello Margarita,
    Okay, I am doing bitbake.
    In parallel time can you provide me actual steps to follow after bitbake,please.
    I have understand that i have to add RGB in one file. But i could not get all steps properly.
    Kishan Patel.
    Please check previous answer again they are two files, gstvpe.c and gstvpebuffer.c not one.
    I have pointed you some of the functions that you could change in order to add this support.
    Note: I will be OoO next week so here is what you could add to debug gstvpe --gst-debug=vpe:3 you could raise the level of debug of course.
    BR
    Margarita
  • Hello Margarita,
    I have completed bitbake process and could not find sorce file.
    I have got 3 ipks as below:
    1)gstreamer1.0-plugins-vpe-dbg_git-r2.19_am57xx_evm.ipk
    2)gstreamer1.0-plugins-vpe-dev_git-r2.19_am57xx_evm.ipk
    3)gstreamer1.0-plugins-vpe_git-r2.19_am57xx_evm.ipk
    Kishan Patel.
    This is the path :
    Please, I already linked this in some of previous posts.
    BR
    Margarita
  • Hello Margarita,
    After completion of bitbake, I have execute opkg install command and installing ipks. Please, check the below log:
    root@am57xx-evm:~/GST_VPE_IPK# opkg install gstreamer1.0-plugins-vpe-dbg_git-r2.19_am57xx_evm.ipk
    Installing gstreamer1.0-plugins-vpe-dbg (git) on root
    Configuring gstreamer1.0-plugins-vpe-dbg.
    root@am57xx-evm:~/GST_VPE_IPK# opkg install gstreamer1.0-plugins-vpe-dev_git-r2.19_am57xx_evm.ipk
    Collected errors:
    * Solver encountered 1 problem(s):
    * Problem 1/1:
    * - nothing provides gstreamer1.0-plugins-vpe = git-r2.19 needed by gstreamer1.0-plugins-vpe-dev-git-r2.19.am57xx_evm
    * Solution 1:
    * - do not ask to install gstreamer1.0-plugins-vpe-dev-git-r2.19.am57xx_evm
    root@am57xx-evm:~/GST_VPE_IPK# opkg install gstreamer1.0-plugins-vpe_git-r2.19_am57xx_evm.ipk
    Installing gstreamer1.0-plugins-vpe (git) on root
    Configuring gstreamer1.0-plugins-vpe.
    Kishan Patel.
  • Hello Margarita,
    Actually, I had installed ipks after bitbake and i can find that source file also on board.
    Kishan Patel.
    The source code is on your PC.
    You should not install gstreamer-vpe plugin since it is already included in PSDK.
    Please, find the source code in /tisdk/build/arago-tmp-external-linaro-toolchain/work/am57xx_evm-linux-gnueabi/gstreamer1.0-plugins-vpe/git-rx.xx/git/src
    When you make your changes you must rebuild the plugin by using this command:
    MACHINE=am57xx-evm bitbake gstreamer1.0-plugins-vpe --force -c compile
    The new gstvpe lib you could find here:
    /tisdk/build/arago-tmp-external-linaro-toolchain/work/am57xx_evm-linux-gnueabi/gstreamer1.0-plugins-vpe/git-r2.19/git/src/.libs
    The name is libgstvpe.so.
    If you could not find .libs folder please press ctrl+h to see it.
    After that you must copy the new libgstvpe.so lib on the board under this path /usr/lib/gstreamer-1.0
    You could test this with simple pipeline - gst-launch-1.0 videotestsrc ! <capsfilter> ! vpe ! <capsfilter> ! fakesink silent=false -e -v
    BR
    Margarita
  • Hello Margarita,
    Thank you. I can find source file. I have modified "gstvpe.c" file as below:
    GST_PAD_SRC,
    GST_PAD_ALWAYS,
    ";" GST_VIDEO_CAPS_MAKE ("RGB")
    static int
    gst_vpe_fourcc_to_pixelformat (guint32 fourcc)
    switch (fourcc) {
    case GST_MAKE_FOURCC ('Y', 'U', 'Y', '2'):
    case GST_MAKE_FOURCC ('Y', 'U', 'Y', 'V'):
    return V4L2_PIX_FMT_YUYV;
    case GST_MAKE_FOURCC ('N', 'V', '1', '2'):
    return V4L2_PIX_FMT_NV12;
    case GST_MAKE_FOURCC ('B', 'G', 'R', '3'):
    return V4L2_PIX_FMT_BGR24;
    return -1;
    Is it right?
    And i have also checked other function but i am feeling scare to modified other things.
    What should i change like what should i keep size in "gstvpebuffers.c" file?
    Kishan Patel.
  • Hello Margarita,
    I have also modified "gstvpebuffers.c" file as below:
    GstBuffer *
    gst_vpe_buffer_new (GstVpeBufferPool * pool, struct omap_device * dev,
    guint32 fourcc, gint width, gint height, int index, guint32 v4l2_type)
    GstVPEBufferPriv *vpemeta;
    GstVideoCropMeta *crop;
    int size = 0;
    GstBuffer *buf;
    GstAllocator *allocator = gst_drm_allocator_get ();
    buf = gst_buffer_new ();
    if (!buf)
    return NULL;
    switch (fourcc) {
    case GST_MAKE_FOURCC ('A', 'R', '2', '4'):
    size = width * height * 4;
    break;
    size = width * height * 2;
    break;
    size = (width * height * 3) / 2;
    break;
    and followed other steps to force-compile, replace library.
    Then execute below command:
    gst-launch-1.0 -v rtspsrc location=rtsp://888888:888888@192.168.1.5:554 ! rtph264depay ! h264parse ! ducatih264dec ! vpe ! 'video/x-raw, format=(string)BGR, width=(int)800, height=(int)600' ! waylandsink
    But, still its not working.
    Kishan Patel.
     * GStreamer
     * Copyright (c) 2014, Texas Instruments Incorporated
     * This library is free software; you can redistribute it and/or
     * modify it under the terms of the GNU Lesser General Public
     * License as published by the Free Software Foundation
     * version 2.1 of the License.
     * This library is distributed in the hope that it will be useful,
     * but WITHOUT ANY WARRANTY; without even the implied warranty of
     * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU
     * Lesser General Public License for more details.
     * You should have received a copy of the GNU Lesser General Public
     * License along with this library; if not, write to the Free Software
     * Foundation, Inc., 51 Franklin Street, Fifth Floor, Boston, MA  02110-1301  USA
    #ifdef HAVE_CONFIG_H
    #include <config.h>
    #endif
    #include "gstvpe.h"
    #include <stdio.h>
    #include <stdlib.h>
    #include <fcntl.h>
    #include <unistd.h>
    #include <stdint.h>
    #include <string.h>
    #include <errno.h>
    #include <pthread.h>
    #include <sys/mman.h>
    #include <sys/ioctl.h>
    #include <libdce.h>
    #include <sched.h>
    #include <math.h>
    #ifndef MIN
    #define MIN(a,b)     (((a) < (b)) ? (a) : (b))
    #endif
    #define ADD_GST_VPE_RGB_SUPPORT	//Kishan
    static void gst_vpe_class_init (GstVpeClass * klass);
    static void gst_vpe_init (GstVpe * self, gpointer klass);
    static void gst_vpe_base_init (gpointer gclass);
    static GstElementClass *parent_class = NULL;
    static gboolean gst_vpe_set_output_caps (GstVpe * self);
    /*------------------------Kishan-----------------------*/
    #ifdef ADD_GST_VPE_RGB_SUPPORT
    static int
    gst_vpe_video_format_from_fourcc (guint32 fourcc)
      switch (fourcc) {
        case GST_MAKE_FOURCC ('R', 'G', 'B','\0'):
          return GST_VIDEO_FORMAT_RGB;
        default:
    	  return gst_video_format_from_fourcc(fourcc);
      return GST_VIDEO_FORMAT_UNKNOWN;
    #endif
    GType
    gst_vpe_get_type (void)
      static GType vpe_type = 0;
      if (!vpe_type) {
        static const GTypeInfo vpe_info = {
          sizeof (GstVpeClass),
          (GBaseInitFunc) gst_vpe_base_init,
          NULL,
          (GClassInitFunc) gst_vpe_class_init,
          NULL,
          NULL,
          sizeof (GstVpe),
          0,
          (GInstanceInitFunc) gst_vpe_init,
        vpe_type = g_type_register_static (GST_TYPE_ELEMENT,
            "GstVpe", &vpe_info, 0);
      return vpe_type;
        GST_PAD_SRC,
        GST_PAD_ALWAYS,
    //	GST_STATIC_CAPS (GST_VIDEO_CAPS_MAKE ("{ RGB, NV12, YUYV, YUY2}")));
            ";" GST_VIDEO_CAPS_MAKE ("BGR3")
            ";" GST_VIDEO_CAPS_MAKE ("RGB3")
            ";" GST_VIDEO_CAPS_MAKE ("BGR")
    	#endif
    static GstStaticPadTemplate sink_factory = GST_STATIC_PAD_TEMPLATE ("sink",
        GST_PAD_SINK,
        GST_PAD_ALWAYS,
            #endif
    enum
      PROP_0,
      PROP_NUM_INPUT_BUFFERS,
      PROP_NUM_OUTPUT_BUFFERS,
      PROP_DEVICE
    #define MAX_NUM_OUTBUFS   16
    #define MAX_NUM_INBUFS    128
    #define DEFAULT_NUM_OUTBUFS   6
    #define DEFAULT_NUM_INBUFS    12
    #define DEFAULT_DEVICE        "/dev/v4l/by-path/platform-489d0000.vpe-video-index0"
    static gboolean
    gst_vpe_parse_input_caps (GstVpe * self, GstCaps * input_caps)
      gboolean match;
      GstStructure *s;
      gint w, h;
      guint32 fourcc = 0;
      const gchar *fmt = NULL;
      GST_DEBUG_OBJECT (self, "Input caps: %s", gst_caps_to_string (input_caps));
      if (self->input_caps) {
        match = gst_caps_is_strictly_equal (self->input_caps, input_caps);
            "Already set caps comapred with the new caps, returned %s",
            (match == TRUE) ? "TRUE" : "FALSE");
        if (match == TRUE)
          return TRUE;
      s = gst_caps_get_structure (input_caps, 0);
      fmt = gst_structure_get_string (s, "format");
      if (!fmt) {
        return FALSE;
      fourcc = GST_STR_FOURCC (fmt);
      /* For interlaced streams, ducati decoder sets caps without the interlaced
       * at first, and then changes it to set it as true or false, so if interlaced
       * is false, we cannot assume that the stream is pass-through
      self->interlaced = FALSE;
      gst_structure_get_boolean (s, "interlaced", &self->interlaced);
      gst_structure_get_int (s, "max-ref-frames", &self->input_max_ref_frames);
      if (!(gst_structure_get_int (s, "width", &w) &&
              gst_structure_get_int (s, "height", &h))) {
        return FALSE;
      if (self->input_width != 0 &&
          (self->input_width != w || self->input_height != h)) {
            "dynamic changes in height and width are not supported");
        return FALSE;
      self->input_height = h;
      self->input_width = w;
      self->input_fourcc = fourcc;
      /* Keep a copy of input caps */
        gst_caps_unref (self->input_caps);
      self->input_caps = gst_caps_copy (input_caps);
      return TRUE;
    static gboolean
      GstCaps *outcaps;
      GstStructure *s, *out_s;
      gint fps_n, fps_d;
      gint par_width, par_height;
      if (!self->input_caps)
        return FALSE;
      if (self->fixed_caps)
        return TRUE;
      s = gst_caps_get_structure (self->input_caps, 0);
      outcaps = gst_pad_get_allowed_caps (self->srcpad);
      if (outcaps && !(self->output_caps
              && gst_caps_is_strictly_equal (outcaps, self->output_caps))) {
        GST_DEBUG_OBJECT (self, "Downstream allowed caps: %s",
            gst_caps_to_string (outcaps));
        out_s = gst_caps_get_structure (outcaps, 0);
        fmt = gst_structure_get_string (out_s, "format");
        if (out_s &&
            gst_structure_get_int (out_s, "width", &self->output_width) &&
            gst_structure_get_int (out_s, "height", &self->output_height) && fmt) {
          self->output_fourcc = GST_STR_FOURCC (fmt);
          GST_DEBUG_OBJECT (self, "Using downstream caps, fixed_caps = TRUE");
          self->fixed_caps = TRUE;
          self->output_framerate_d = self->output_framerate_n = 0;
          if (gst_structure_get_fraction (out_s, "framerate", &fps_n, &fps_d)) {
            self->output_framerate_d = fps_d;
            self->output_framerate_n = fps_n;
    /*------------------------Kishan------------------------*/
    else {
        if (self->output_caps) {
          out_s = gst_caps_get_structure (self->output_caps, 0);
    #endif
      if (!self->fixed_caps) {
        if (self->input_crop.c.width && self->interlaced) {
          /* Ducati decoder had the habit of setting height as half frame hight for
           * interlaced streams */
          self->output_height =
              (self->interlaced) ? self->input_crop.c.height *
              2 : self->input_crop.c.height;
          self->output_width = self->input_crop.c.width;
        } else if(self->input_crop.c.width) {
          /* This is added to make sure that input and output width/height
             won't match and vpe is not is in passthrough mode. This code
             is added as a workaround for playback with sub-title usecase */
          self->output_height = ALIGN2(self->input_crop.c.height, 1);
          self->output_width = ALIGN2(self->input_crop.c.width, 4);
        } else {
          self->output_height = self->input_height;
          self->output_width = self->input_width;
    	#ifndef ADD_GST_VPE_RGB_SUPPORT
        	self->output_fourcc = GST_MAKE_FOURCC ('N', 'V', '1', '2');
    	#else
    	if (fmt)
        	else
    	#endif
      self->passthrough = !(self->interlaced ||
          self->output_width != self->input_width ||
          self->output_height != self->input_height ||
          self->output_fourcc != self->input_fourcc);
      GST_DEBUG_OBJECT (self, "Passthrough = %s",
          self->passthrough ? "TRUE" : "FALSE");
      gst_caps_unref (outcaps);
      outcaps = gst_caps_new_simple ("video/x-raw",
          "format", G_TYPE_STRING,
          gst_video_format_to_string
          	(gst_video_format_from_fourcc (self->output_fourcc)), NULL);
    	#else
    	(gst_vpe_video_format_from_fourcc (self->output_fourcc)), NULL);			//Kishan
    	#endif
      gst_structure_set (out_s,
          "width", G_TYPE_INT, self->output_width,
          "height", G_TYPE_INT, self->output_height, NULL);
      /* Set interlace-mode in the outcaps to match the capabilities
         with videoscale element when playbin is used.if not set, buffer copy
         happens due to mismatch */
      gst_structure_set (out_s, "interlace-mode", G_TYPE_STRING,
                       "progressive", NULL);
      if (gst_structure_get_fraction (s, "pixel-aspect-ratio",
              &par_width, &par_height))
        gst_structure_set (out_s, "pixel-aspect-ratio", GST_TYPE_FRACTION,
            par_width, par_height, NULL);
      self->input_framerate_d = self->input_framerate_n = 0;
      if (gst_structure_get_fraction (s, "framerate", &fps_n, &fps_d)) {
        self->input_framerate_d = fps_d;
        self->input_framerate_n = fps_n;
      if (self->output_framerate_d == 0) {
        self->output_framerate_d = self->input_framerate_d;
        self->output_framerate_n = self->input_framerate_n;
      if (self->output_framerate_d != 0) {
        gst_structure_set (out_s, "framerate", GST_TYPE_FRACTION,
            self->output_framerate_n, self->output_framerate_d, NULL);
        gst_caps_unref (self->output_caps);
      self->output_caps = outcaps;
      self->output_repeat_rate = 1;
      if (self->output_framerate_n != 0 && self->output_framerate_d != 0
          && self->input_framerate_n != 0 && self->input_framerate_d != 0) {
            (gint) round (((double) self->output_framerate_n *
                (double) self->input_framerate_d) /
            ((double) self->input_framerate_n * (double) self->output_framerate_d));
          "framerate conversion: from %d/%d to %d/%d, repeat_factor: %d\n",
          self->input_framerate_n, self->input_framerate_d,
          self->output_repeat_rate);
      return TRUE;
    static gboolean
    gst_vpe_init_output_buffers (GstVpe * self)
      int i;
      GstBuffer *buf;
      if (!self->output_caps) {
            "Output caps should be set before init output buffer");
        return FALSE;
      self->output_pool =
          gst_vpe_buffer_pool_new (TRUE, self->num_output_buffers,
          self->num_output_buffers, V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE,
          self->output_caps, NULL, NULL);
      if (!self->output_pool) {
        return FALSE;
      self->output_pool->format = &self->output_format;
      for (i = 0; i < self->num_output_buffers; i++) {
        buf = gst_vpe_buffer_new (self->output_pool, self->dev,
            self->output_fourcc,
            self->output_width, self->output_height,
            i, V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE);
        if (!buf) {
          return FALSE;
        gst_vpe_buffer_pool_put (self->output_pool, buf);
        /* gst_vpe_buffer_pool_put keeps a reference of the buffer,
         * so, unref ours
         gst_buffer_unref (GST_BUFFER (buf)); */
      return TRUE;
    static int
      switch (fourcc) {
        case GST_MAKE_FOURCC ('R', 'G', 'B', '3'):
        case GST_MAKE_FOURCC ('R', 'G', 'B', '\0'):
          return V4L2_PIX_FMT_RGB24;
    #endif
      return -1;
    static gboolean
    gst_vpe_output_set_fmt (GstVpe * self)
      struct v4l2_format fmt;
      int ret;
      // V4L2 Stuff
      bzero (&fmt, sizeof (fmt));
      fmt.type = V4L2_BUF_TYPE_VIDEO_CAPTURE_MPLANE;
      fmt.fmt.pix_mp.width = self->output_width;
      fmt.fmt.pix_mp.height = self->output_height;
      fmt.fmt.pix_mp.pixelformat =
          gst_vpe_fourcc_to_pixelformat (self->output_fourcc);
      fmt.fmt.pix_mp.field = V4L2_FIELD_ANY;
      fmt.fmt.pix_mp.num_planes = 1;
      GST_DEBUG_OBJECT (self, "vpe: output S_FMT image: %dx%d",
          fmt.fmt.pix_mp.width, fmt.fmt.pix_mp.height);
      ret = ioctl (self->video_fd, VIDIOC_S_FMT, &fmt);
      if (ret < 0) {
        GST_ERROR_OBJECT (self, "VIDIOC_S_FMT failed");
        return FALSE;
      } else {
        GST_DEBUG_OBJECT (self, "sizeimage[0] = %d, sizeimage[1] = %d",
            fmt.fmt.pix_mp.plane_fmt[0].sizeimage,
            fmt.fmt.pix_mp.plane_fmt[1].sizeimage);
        /* Save a copy of the current format for this pool */
        self->output_format = fmt;
      return TRUE;
    static GstBuffer *
    gst_vpe_alloc_inputbuffer (void *ctx, int index)
      GstVpe *self = (GstVpe *) ctx;
      return gst_vpe_buffer_new (self->input_pool, self->dev,
          self->input_fourcc,
          self->input_width, self->input_height, index,
          V4L2_BUF_TYPE_VIDEO_OUTPUT_MPLANE);
    static gboolean
    gst_vpe_init_input_buffers (GstVpe * self, gint min_num_input_buffers)
      int i;
      GstBuffer *buf;
      if (!self->input_caps) {
            "Input caps should be set before init input buffer");
        return FALSE;
      self->input_pool =
          gst_vpe_buffer_pool_new (FALSE, MAX_NUM_INBUFS, min_num_input_buffers,
          V4L2_BUF_TYPE_VIDEO_OUTPUT_MPLANE, self->input_caps,
          gst_vpe_alloc_inputbuffer, self);
      if (!self->input_pool) {
        return FALSE;
      self->input_pool->format = &self->input_format;
      return TRUE;
    static gboolean
    gst_vpe_input_set_fmt (GstVpe * self)
      int ret;
      struct v4l2_selection sel = {
        .type = V4L2_BUF_TYPE_VIDEO_OUTPUT,
        .target = V4L2_SEL_TGT_CROP_DEFAULT,
      struct v4l2_rect r;
      // V4L2 Stuff
      fmt.type = V4L2_BUF_TYPE_VIDEO_OUTPUT_MPLANE;
      fmt.fmt.pix_mp.width = self->input_width;
          gst_vpe_fourcc_to_pixelformat (self->input_fourcc);
      if (self->interlaced) {
        fmt.fmt.pix_mp.height = (self->input_height);
        fmt.fmt.pix_mp.field = V4L2_FIELD_SEQ_TB;
      } else {
        fmt.fmt.pix_mp.height = self->input_height;
          "input S_FMT field: %d, image: %dx%d, numbufs: %d",
          fmt.fmt.pix_mp.field, fmt.fmt.pix_mp.width,
          fmt.fmt.pix_mp.height, self->num_input_buffers);
      if (ret < 0) {
        return FALSE;
      } else {
        self->input_format = fmt;
      if (self->input_crop.c.width != 0) {
            "Crop values: top: %d, left: %d, width: %d, height: %d",
            self->input_crop.c.top, self->input_crop.c.left,
            self->input_crop.c.width, self->input_crop.c.height);
        ret = ioctl (self->video_fd, VIDIOC_G_SELECTION, &sel);
        if (ret < 0) {
          GST_ERROR_OBJECT (self, "VIDIOC_G_SELECTION for crop failed");
          return FALSE;
        sel.target = V4L2_SEL_TGT_CROP;
        r.width = self->input_crop.c.width;
        r.height = self->input_crop.c.height;
        r.left = self->input_crop.c.left;
        r.top = self->input_crop.c.top;
        sel.r = r;
        ret = ioctl (self->video_fd, VIDIOC_S_SELECTION, &sel);
        if (ret < 0) {
          GST_ERROR_OBJECT (self, "VIDIOC_S_SELECTION for crop failed");
          return FALSE;
      return TRUE;
    static void
    gst_vpe_dequeue_loop (gpointer data)
      GstVpe *self = (GstVpe *) data;
      GstBuffer *buf, *b;
      gint q_cnt;
      while (1) {
        buf = NULL;
        GST_OBJECT_LOCK (self);
        if (self->video_fd >= 0 && self->output_pool)
          (void)
              gst_buffer_pool_acquire_buffer (GST_BUFFER_POOL (self->output_pool),
              &buf, NULL);
        if (buf) {
          self->output_q_processing--;
          g_assert (self->output_q_processing >= 0);
        GST_OBJECT_UNLOCK (self);
        if (buf) {
          for (q_cnt = 1; q_cnt < self->output_repeat_rate; q_cnt++) {
            b = gst_vpe_buffer_ref (self->output_pool, buf);
            if (b)
              gst_pad_push (self->srcpad, GST_BUFFER (b));
          GST_DEBUG_OBJECT (self, "push: %" GST_TIME_FORMAT " (ptr %p)",
              GST_TIME_ARGS (GST_BUFFER_PTS (buf)), buf);
          gst_pad_push (self->srcpad, GST_BUFFER (buf));
        } else
          break;
      if (self->video_fd >= 0 && self->input_pool) {
        while (NULL != (buf = gst_vpe_buffer_pool_dequeue (self->input_pool))) {
          self->input_q_depth--;
          g_assert (self->input_q_depth >= 0);
          gst_buffer_unref (buf);
        while (((MAX_INPUT_Q_DEPTH - self->input_q_depth) >= 1)
            && (NULL != (buf = (GstBuffer *) g_queue_pop_head (&self->input_q)))
            && (TRUE == gst_vpe_buffer_pool_queue (self->input_pool, buf, &q_cnt))) {
          self->input_q_depth += q_cnt;
            self->output_q_processing += q_cnt * 2;
          } else {
            self->output_q_processing += q_cnt;
      usleep (10000);
    static void
    gst_vpe_print_driver_capabilities (GstVpe * self)
      struct v4l2_capability cap;
      if (0 == ioctl (self->video_fd, VIDIOC_QUERYCAP, &cap)) {
        GST_DEBUG_OBJECT (self, "driver:      '%s'", cap.driver);
        GST_DEBUG_OBJECT (self, "card:        '%s'", cap.card);
        GST_DEBUG_OBJECT (self, "bus_info:    '%s'", cap.bus_info);
        GST_DEBUG_OBJECT (self, "version:     %08x", cap.version);
        GST_DEBUG_OBJECT (self, "capabilites: %08x", cap.capabilities);
      } else {
        GST_WARNING_OBJECT (self, "Cannot get V4L2 driver capabilites!");
    static gboolean
    gst_vpe_create (GstVpe * self)
      if (self->dev == NULL) {
        self->dev = dce_init ();
          GST_ERROR_OBJECT (self, "dce_init() failed");
          return FALSE;
        GST_DEBUG_OBJECT (self, "dce_init() done");
      return TRUE;
    static gboolean
    gst_vpe_init_input_bufs (GstVpe * self, GstCaps * input_caps)
      gint min_num_input_buffers;
      if (!gst_vpe_create (self)) {
        return FALSE;
      if (input_caps && !gst_vpe_parse_input_caps (self, input_caps)) {
        GST_ERROR_OBJECT (self, "Could not parse/set caps");
        return FALSE;
      if (self->num_input_buffers) {
        min_num_input_buffers = self->num_input_buffers;
      } else if (self->input_max_ref_frames) {
        min_num_input_buffers = MAX (6, self->input_max_ref_frames);
      } else {
        min_num_input_buffers = DEFAULT_NUM_INBUFS;
      if (min_num_input_buffers > MAX_NUM_INBUFS)
        min_num_input_buffers = MAX_NUM_INBUFS;
      GST_DEBUG_OBJECT (self, "Using min input buffers: %d", min_num_input_buffers);
      GST_DEBUG_OBJECT (self, "parse/set caps done");
      if (self->input_pool == NULL) {
        if (!gst_vpe_init_input_buffers (self, min_num_input_buffers)) {
          GST_ERROR_OBJECT (self, "gst_vpe_init_input_buffers failed");
          return FALSE;
        GST_DEBUG_OBJECT (self, "gst_vpe_init_input_buffers done");
      } else {
        gst_vpe_buffer_pool_set_min_buffer_count (self->input_pool,
      return TRUE;
    static void
    gst_vpe_set_streaming (GstVpe * self, gboolean streaming)
      gboolean ret;
      GstBuffer *buf;
      if (streaming) {
        if (self->video_fd < 0) {
          GST_DEBUG_OBJECT (self, "Calling open(%s)", self->device);
          self->video_fd = open (self->device, O_RDWR | O_NONBLOCK);
            GST_ERROR_OBJECT (self, "Cant open %s", self->device);
            return;
          GST_DEBUG_OBJECT (self, "Opened %s", self->device);
          gst_vpe_print_driver_capabilities (self);
          /* Call V4L2 S_FMT for input and output */
          gst_vpe_input_set_fmt (self);
          gst_vpe_output_set_fmt (self);
          if (!gst_vpe_init_input_bufs (self, NULL)) {
            GST_ERROR_OBJECT (self, "gst_vpe_init_input_bufs failed");
          if (self->input_pool)
            gst_vpe_buffer_pool_set_streaming (self->input_pool,
                self->video_fd, streaming, self->interlaced);
          self->output_q_processing = 0;
            if (!gst_vpe_init_output_buffers (self)) {
              GST_ERROR_OBJECT (self, "gst_vpe_init_output_buffers failed");
            GST_DEBUG_OBJECT (self, "gst_vpe_init_output_buffers done");
          if (self->output_pool)
            gst_vpe_buffer_pool_set_streaming (self->output_pool,
                self->video_fd, streaming, FALSE);
          self->input_q_depth = 0;
        } else {
          GST_DEBUG_OBJECT (self, "streaming already on");
      } else {
        if (self->video_fd >= 0) {
          while (NULL != (buf = (GstBuffer *) g_queue_pop_head (&self->input_q))) {
          close (self->video_fd);
          self->video_fd = -1;
        } else {
          GST_DEBUG_OBJECT (self, "streaming already off");
    static gboolean
    gst_vpe_start (GstVpe * self, GstCaps * input_caps)
      if (!gst_vpe_init_input_bufs (self, input_caps)) {
        return FALSE;
        if (!gst_vpe_set_output_caps (self)) {
          GST_ERROR_OBJECT (self, "gst_vpe_set_output_caps failed");
          return FALSE;
      self->state = GST_VPE_ST_ACTIVE;
      return TRUE;
    static void
    gst_vpe_destroy (GstVpe * self)
      gst_vpe_set_streaming (self, FALSE);
      self->input_caps = NULL;
      self->output_caps = NULL;
      self->fixed_caps = FALSE;
      if (self->input_pool) {
        gst_vpe_buffer_pool_destroy (self->input_pool);
        GST_DEBUG_OBJECT (self, "gst_vpe_buffer_pool_destroy(input) done");
      self->input_pool = NULL;
      if (self->output_pool) {
        gst_vpe_buffer_pool_destroy (self->output_pool);
        GST_DEBUG_OBJECT (self, "gst_vpe_buffer_pool_destroy(output) done");
      self->output_pool = NULL;
      if (self->dev)
        dce_deinit (self->dev);
      GST_DEBUG_OBJECT (self, "dce_deinit done");
      gst_segment_init (&self->segment, GST_FORMAT_UNDEFINED);
      self->dev = NULL;
      self->input_width = 0;
      self->input_height = 0;
      self->input_max_ref_frames = 0;
      self->output_width = 0;
      self->output_height = 0;
      self->input_crop.c.top = 0;
      self->input_crop.c.left = 0;
      self->input_crop.c.width = 0;
      self->input_crop.c.height = 0;
      self->output_framerate_d = 0;
      if (self->device)
        g_free (self->device);
      self->device = NULL;
    static gboolean
    gst_vpe_activate_mode (GstPad * pad, GstObject * parent,
        GstPadMode mode, gboolean active)
      if (mode == GST_PAD_MODE_PUSH) {
        gboolean result = TRUE;
        GstVpe *self;
        self = GST_VPE (parent);
        GST_DEBUG_OBJECT (self, "gst_vpe_activate_mode (active = %d)", active);
        if (!active) {
          result = gst_pad_stop_task (self->srcpad);
          GST_DEBUG_OBJECT (self, "task gst_vpe_dequeue_loop stopped");
        } else {
          result =
              gst_pad_start_task (self->srcpad, gst_vpe_dequeue_loop, self, NULL);
          GST_DEBUG_OBJECT (self, "gst_pad_start_task returned %d", result);
        return result;
      return FALSE;
    static gboolean
    gst_vpe_sink_setcaps (GstPad * pad, GstCaps * caps)
      gboolean ret = TRUE;
      GstStructure *s;
      GstVpe *self = GST_VPE (gst_pad_get_parent (pad));
      if (caps) {
        if (TRUE == (ret = gst_vpe_parse_input_caps (self, caps))) {
          ret = gst_vpe_set_output_caps (self);
        if (TRUE == ret) {
          gst_pad_set_caps (self->srcpad, self->output_caps);
        GST_INFO_OBJECT (self, "set caps done %d", ret);
      gst_object_unref (self);
      return ret;
    static GstCaps *
    gst_vpe_getcaps (GstPad * pad)
      GstCaps *caps = NULL;
      caps = gst_pad_get_current_caps (pad);
      if (caps == NULL) {
        GstCaps *fil = gst_pad_get_pad_template_caps (pad);
        return fil;
      } else {
        return caps;
    static gboolean
    gst_vpe_query (GstPad * pad, GstObject * parent, GstQuery * query)
      GstVpe *self = GST_VPE (parent);
      switch (GST_QUERY_TYPE (query)) {
        case GST_QUERY_CAPS:
          GstCaps *caps;
          caps = gst_vpe_getcaps (pad);
          gst_query_set_caps_result (query, caps);
          return TRUE;
          break;
        case GST_QUERY_ALLOCATION:
          GstCaps *caps;
          gst_query_parse_allocation (query, &caps, NULL);
          if (caps == NULL)
            return FALSE;
          if (G_UNLIKELY (self->state == GST_VPE_ST_DEINIT)) {
            GST_WARNING_OBJECT (self, "Plugin is shutting down, returning FALSE");
            return FALSE;
          if (!gst_vpe_init_input_bufs (self, caps)) {
            return FALSE;
          gst_query_add_allocation_pool (query,
              GST_BUFFER_POOL (self->input_pool), 1, 0, self->num_input_buffers);
          gst_query_add_allocation_param (query, gst_drm_allocator_get (), NULL);
          gst_caps_unref (caps);
          return TRUE;
          break;
        case GST_QUERY_LATENCY:
          /* TODO: */
          break;
        default:
          break;
      return gst_pad_query_default (pad, parent, query);
    static GstFlowReturn
    gst_vpe_chain (GstPad * pad, GstObject * parent, GstBuffer * buf)
      gint q_cnt;
      GstVPEBufferPriv *vpe_buf;
      GST_DEBUG_OBJECT (self, "chain: %" GST_TIME_FORMAT " ( ptr %p)",
      if (G_UNLIKELY (self->state != GST_VPE_ST_ACTIVE &&
              self->state != GST_VPE_ST_STREAMING)) {
        if (self->state == GST_VPE_ST_DEINIT) {
              "Plugin is shutting down, freeing buffer: %p", buf);
          return GST_FLOW_OK;
        } else {
          if (self->input_crop.c.width == 0) {
            GstVideoCropMeta *crop = gst_buffer_get_video_crop_meta (buf);
            if (crop) {
              self->input_crop.c.left = crop->x;
              self->input_crop.c.top = crop->y;
              self->input_crop.c.width = crop->width;
              self->input_crop.c.height = crop->height;
          if (gst_vpe_start (self, gst_pad_get_current_caps (pad))) {
            /* Set output caps, this should be done outside the lock */
          } else {
            return GST_FLOW_ERROR;
      if (self->passthrough) {
        GST_DEBUG_OBJECT (self, "Passthrough for VPE");
        return gst_pad_push (self->srcpad, buf);
      vpe_buf = gst_buffer_get_vpe_buffer_priv (self->input_pool, buf);
      if (!vpe_buf) {
        GST_DEBUG_OBJECT (self, "Importing buffer not allocated by self %p", buf);
        GstBuffer *in = gst_vpe_buffer_pool_import (self->input_pool, buf);
        if (in) {
      if (vpe_buf) {
        if (G_UNLIKELY (self->state != GST_VPE_ST_STREAMING)) {
          gst_vpe_set_streaming (self, TRUE);
          self->state = GST_VPE_ST_STREAMING;
        if ((MAX_INPUT_Q_DEPTH - self->input_q_depth) >= 1) {
          GST_DEBUG_OBJECT (self, "Push the buffer into the V4L2 driver %d",
              self->input_q_depth);
          if (TRUE != gst_vpe_buffer_pool_queue (self->input_pool, buf, &q_cnt)) {
          } else {
        } else {
          g_queue_push_tail (&self->input_q, (gpointer) buf);
      else {
        GST_DEBUG_OBJECT (self, "Unref the buffer if not pushed to driver %p", buf);
        gst_buffer_unref(buf);
      /* Allow dequeue thread to run */
      sched_yield ();
      return GST_FLOW_OK;
    static gboolean
    gst_vpe_event (GstPad * pad, GstObject * parent, GstEvent * event)
      GST_DEBUG_OBJECT (self, "begin: event=%s", GST_EVENT_TYPE_NAME (event));
      switch (GST_EVENT_TYPE (event)) {
        case GST_EVENT_CAPS:
          GstCaps *caps;
          gst_event_parse_caps (event, &caps);
          gst_event_unref (event);
          return gst_vpe_sink_setcaps (pad, caps);
          break;
        case GST_EVENT_SEGMENT:
          gst_event_copy_segment (event, &self->segment);
          if (self->segment.format == GST_FORMAT_TIME &&
              self->segment.rate < (gdouble) 0.0) {
            /* In case of reverse playback, more input buffers
               are required */
          break;
        case GST_EVENT_EOS:
          while (1) {
            if (TRUE != g_queue_is_empty (&self->input_q)) {
                  "Buffers to be pushed into the V4L2 driver %d",
            } else if (0 != self->output_q_processing) {
                  "Buffers to be processed by the V4L2 driver %d",
                  self->output_q_processing);
            } else {
              GST_DEBUG_OBJECT (self, "VPE ready for EOS");
              break;
            usleep (10000);
          break;
        case GST_EVENT_FLUSH_STOP:
          self->state = GST_VPE_ST_INIT;
          break;
        case GST_EVENT_FLUSH_START:
          self->state = GST_VPE_ST_DEINIT;
          break;
        default:
          break;
      ret = gst_pad_push_event (self->srcpad, event);
      GST_DEBUG_OBJECT (self, "end ret=%d", ret);
      return ret;
    static gboolean
    gst_vpe_src_event (GstPad * pad, GstObject * parent, GstEvent * event)
        case GST_EVENT_QOS:
          // TODO or not!!
          ret = gst_pad_push_event (self->sinkpad, event);
          break;
        default:
          break;
      GST_DEBUG_OBJECT (self, "end");
      return ret;
    static GstStateChangeReturn
    gst_vpe_change_state (GstElement * element, GstStateChange transition)
      GstStateChangeReturn ret = GST_STATE_CHANGE_SUCCESS;
      GstVpe *self = GST_VPE (element);
      gboolean supported;
      GST_DEBUG_OBJECT (self, "begin: changing state %s -> %s",
          gst_element_state_get_name (GST_STATE_TRANSITION_CURRENT
              (transition)),
          gst_element_state_get_name (GST_STATE_TRANSITION_NEXT (transition)));
      switch (transition) {
        case GST_STATE_CHANGE_READY_TO_PAUSED:
          break;
        default:
          break;
      ret = GST_ELEMENT_CLASS (parent_class)->change_state (element, transition);
      GST_DEBUG_OBJECT (self, "parent state change returned: %d", ret);
      if (ret == GST_STATE_CHANGE_FAILURE)
        goto leave;
        case GST_STATE_CHANGE_PAUSED_TO_READY:
          gst_vpe_destroy (self);
          break;
        default:
          break;
    leave:
      return ret;
    /* GObject vmethod implementations */
    static void
    gst_vpe_get_property (GObject * obj,
        guint prop_id, GValue * value, GParamSpec * pspec)
      GstVpe *self = GST_VPE (obj);
      switch (prop_id) {
        case PROP_NUM_INPUT_BUFFERS:
          g_value_set_int (value, self->num_input_buffers);
          break;
        case PROP_NUM_OUTPUT_BUFFERS:
          g_value_set_int (value, self->num_output_buffers);
          break;
        case PROP_DEVICE:
          g_value_set_string (value, self->device);
          break;
        default:
          G_OBJECT_WARN_INVALID_PROPERTY_ID (obj, prop_id, pspec);
          break;
    static void
    gst_vpe_set_property (GObject * obj,
        guint prop_id, const GValue * value, GParamSpec * pspec)
      switch (prop_id) {
          self->num_input_buffers = g_value_get_int (value);
          break;
          self->num_output_buffers = g_value_get_int (value);
          break;
        case PROP_DEVICE:
          self->device = g_value_dup_string (value);
          break;
        default:
          break;
    static void
    gst_vpe_finalize (GObject * obj)
      G_OBJECT_CLASS (parent_class)->finalize (obj);
    static void
      GstElementClass *element_class = GST_ELEMENT_CLASS (gclass);
      gst_element_class_set_static_metadata (element_class,
          "vpe",
          "Filter/Converter/Video",
          "Video processing adapter", "Harinarayan Bhatta <harinarayan@ti.com>");
      gst_element_class_add_pad_template (element_class,
          gst_static_pad_template_get (&src_factory));
          gst_static_pad_template_get (&sink_factory));
    static void
      GObjectClass *gobject_class = G_OBJECT_CLASS (klass);
      GstElementClass *gstelement_class = GST_ELEMENT_CLASS (klass);
      parent_class = g_type_class_peek_parent (klass);
      gobject_class->get_property = GST_DEBUG_FUNCPTR (gst_vpe_get_property);
      gobject_class->set_property = GST_DEBUG_FUNCPTR (gst_vpe_set_property);
      gobject_class->finalize = GST_DEBUG_FUNCPTR (gst_vpe_finalize);
      gstelement_class->change_state = GST_DEBUG_FUNCPTR (gst_vpe_change_state);
      g_object_class_install_property (gobject_class,
          g_param_spec_int ("num-input-buffers",
              "Number of input buffers that are allocated and used by this plugin.",
              "The number if input buffers allocated should be specified based on "
              "the upstream element's requirement. For example, if gst-ducati-plugin "
              "is the upstream element, this value should be based on max-reorder-frames "
              "property of that element. 0 => decide automatically",
              0, MAX_NUM_INBUFS,
              DEFAULT_NUM_INBUFS, G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS));
      g_object_class_install_property (gobject_class, PROP_NUM_OUTPUT_BUFFERS,
          g_param_spec_int ("num-output-buffers",
              "Number of output buffers that are allocated and used by this plugin.",
              "The number if output buffers allocated should be specified based on "
              "the downstream element's requirement. It is generally set to the minimum "
              "value acceptable to the downstream element to reduce memory usage.",
              3, MAX_NUM_OUTBUFS,
              DEFAULT_NUM_OUTBUFS, G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS));
      g_object_class_install_property (gobject_class, PROP_DEVICE,
          g_param_spec_string ("device", "Device", "Device location",
              DEFAULT_DEVICE, G_PARAM_READWRITE | G_PARAM_STATIC_STRINGS));
    static void
      self->sinkpad = gst_pad_new_from_static_template (&sink_factory, "sink");
      gst_pad_set_chain_function (self->sinkpad, GST_DEBUG_FUNCPTR (gst_vpe_chain));
      gst_pad_set_event_function (self->sinkpad, GST_DEBUG_FUNCPTR (gst_vpe_event));
      self->srcpad = gst_pad_new_from_static_template (&src_factory, "src");
      gst_pad_set_event_function (self->srcpad,
          GST_DEBUG_FUNCPTR (gst_vpe_src_event));
      gst_pad_set_query_function (self->srcpad, GST_DEBUG_FUNCPTR (gst_vpe_query));
      gst_pad_set_query_function (self->sinkpad, GST_DEBUG_FUNCPTR (gst_vpe_query));
      gst_pad_set_activatemode_function (self->srcpad, gst_vpe_activate_mode);
      gst_element_add_pad (GST_ELEMENT (self), self->sinkpad);
      gst_element_add_pad (GST_ELEMENT (self), self->srcpad);
      self->input_crop.type = V4L2_BUF_TYPE_VIDEO_OUTPUT_MPLANE;
      self->passthrough = TRUE;
      self->dev = NULL;
      self->num_input_buffers = DEFAULT_NUM_INBUFS;
      self->num_output_buffers = DEFAULT_NUM_OUTBUFS;
      self->device = g_strdup (DEFAULT_DEVICE);
      g_queue_init (&self->input_q);
    GST_DEBUG_CATEGORY (gst_vpe_debug);
    #include "gstvpebins.h"
    static gboolean
    plugin_init (GstPlugin * plugin)
      GST_DEBUG_CATEGORY_INIT (gst_vpe_debug, "vpe", 0, "vpe");
      return (gst_element_register (plugin, "vpe", GST_RANK_NONE, GST_TYPE_VPE))
          && gst_element_register (plugin, "ducatih264decvpe",
          GST_RANK_PRIMARY + 2, gst_vpe_ducatih264dec_get_type ())
          && gst_element_register (plugin, "ducatimpeg2decvpe",
          GST_RANK_PRIMARY + 2, gst_vpe_ducatimpeg2dec_get_type ())
          && gst_element_register (plugin, "ducatimpeg4decvpe",
          GST_RANK_PRIMARY + 2, gst_vpe_ducatimpeg4dec_get_type ())
          && gst_element_register (plugin, "ducatijpegdecvpe",
          GST_RANK_PRIMARY + 2, gst_vpe_ducatijpegdec_get_type ())
          && gst_element_register (plugin, "ducativc1decvpe",
          GST_RANK_PRIMARY + 2, gst_vpe_ducativc1dec_get_type ());
    /* PACKAGE: this is usually set by autotools depending on some _INIT macro
     * in configure.ac and then written into and defined in config.h, but we can
     * just set it ourselves here in case someone doesn't use autotools to
     * compile this code. GST_PLUGIN_DEFINE needs PACKAGE to be defined.
    #ifndef PACKAGE
    #define PACKAGE "vpeplugin"
    #endif
    GST_PLUGIN_DEFINE (GST_VERSION_MAJOR, GST_VERSION_MINOR, vpeplugin,
        "Hardware accelerated video porst-processing using TI VPE (V4L2-M2M) driver on DRA7x SoC",
        plugin_init, VERSION, "LGPL", "GStreamer", "http://gstreamer.net/")
     * GStreamer
    #include <config.h>
    #endif
    #include "gstvpe.h"
    #include <unistd.h>
    #define AD_GST_VPE_RGB_FORMAT	//Kishan
    GstVPEBufferPriv *
    gst_buffer_get_vpe_buffer_priv (GstVpeBufferPool * pool, GstBuffer * buf)
      int fd_copy;
      GstMemory *mem;
      mem = gst_buffer_peek_memory (buf, 0);
      fd_copy = gst_fd_memory_get_fd (mem);
      vpemeta = g_hash_table_lookup (pool->vpebufferpriv, (gpointer) fd_copy);
      return vpemeta;
    GstBuffer *
      int size = 0;
      GstBuffer *buf;
      if (!buf)
        return NULL;
      switch (fourcc) {
          break;
          break;
    #ifdef AD_GST_VPE_RGB_FORMAT
          size = width * height * 3;
          break;
    #endif
          break;
      gst_buffer_append_memory (buf, gst_allocator_alloc (allocator, size, NULL));
      vpemeta = gst_vpe_buffer_priv (pool, dev,
          fourcc, width, height, index, v4l2_type, buf);
      if (!vpemeta) {
        VPE_ERROR ("Failed to add vpe metadata");
        return NULL;
      /* attach dmabuf handle to buffer so that elements from other
       * plugins can access for zero copy hw accel:
      crop = gst_buffer_add_video_crop_meta (buf);
      if (!crop) {
        VPE_DEBUG ("Failed to add crop meta to buffer");
      } else {
        crop->x = 0;
        crop->y = 0;
        crop->height = height;
        crop->width = width;
      VPE_DEBUG ("Allocated a new VPE buffer, %dx%d, index: %d, type: %d",
          width, height, index, v4l2_type);
      return buf;
    GstBuffer *
    gst_vpe_buffer_ref (GstVpeBufferPool * pool, GstBuffer * in)
      GstVideoCropMeta *crop, *incrop;
      int size;
      GstBuffer *buf;
      int fd_copy;
      GstMemory *mem;
      if (!buf)
        return NULL;
      mem = gst_buffer_peek_memory (in, 0);
      if (!vpemeta) {
        VPE_ERROR ("Failed to get vpe metadata");
        return NULL;
      gst_buffer_append_memory (buf, gst_buffer_get_memory (buf, 0));
      incrop = gst_buffer_get_video_crop_meta (in);
      if (incrop) {
        if (!crop) {
        } else {
          crop->x = incrop->x;
          crop->y = incrop->y;
          crop->height = incrop->height;
          crop->width = incrop->width;
      return buf;
    GstBuffer *
    gst_vpe_buffer_import (GstVpeBufferPool * pool, struct omap_device * dev,
        guint32 fourcc, gint width, gint height, int index, guint32 v4l2_type,
        GstBuffer * buf)
      VPE_DEBUG ("Importing buffer");
      if (!vpemeta) {
        return NULL;
      return buf;
    GstVPEBufferPriv *
    gst_vpe_buffer_priv (GstVpeBufferPool * pool, struct omap_device * dev,
        GstBuffer * buf)
      GstVPEBufferPriv *vpebuf = g_malloc0 (sizeof (GstVPEBufferPriv));
      int fd_copy;
      GstMemory *mem;
      if (!vpebuf)
        goto fail;
      vpebuf->size = 0;
      vpebuf->bo = NULL;
      memset (&vpebuf->v4l2_buf, 0, sizeof (vpebuf->v4l2_buf));
      memset (&vpebuf->v4l2_planes, 0, sizeof (vpebuf->v4l2_planes));
      vpebuf->v4l2_buf.type = v4l2_type;
      vpebuf->v4l2_buf.index = index;
      vpebuf->v4l2_buf.m.planes = vpebuf->v4l2_planes;
      vpebuf->v4l2_buf.memory = V4L2_MEMORY_DMABUF;
      switch (fourcc) {
          vpebuf->size = width * height * 4;
          vpebuf->bo = omap_bo_from_dmabuf (dev, fd_copy);
          vpebuf->v4l2_buf.length = 1;
          vpebuf->v4l2_buf.m.planes[0].m.fd = fd_copy;
          break;
          vpebuf->size = width * height * 2;
          break;
          vpebuf->size = width * height * 3;
          break;
    #endif
          vpebuf->size = (width * height * 3) / 2;
          break;
        default:
          VPE_ERROR ("invalid format: 0x%08x", fourcc);
          goto fail;
      g_hash_table_insert (pool->vpebufferpriv, (gpointer) fd_copy, vpebuf);
      return vpebuf;
    fail:
      return NULL;
    Hello Margarita,
               I have modified source file and when execute "" command. I got log as below,which shows that capabilities has been added.But still i could not get output in RGB/BGR/RGB3/BGR3 Format.
    Logs:
    gst-inspect-1.0 vpe
    Factory Details:
     Rank                     none (0)
     Long-name                vpe
     Klass                    Filter/Converter/Video
     Description              Video processing adapter
     Author                   Harinarayan Bhatta <harinarayan@ti.com>
    Plugin Details:
     Name                     vpeplugin
     Description              Hardware accelerated video porst-processing using TI VPE (V4L2-M2M) driver on DRA7x SoC
     Filename                 /usr/lib/gstreamer-1.0/libgstvpe.so
     Version                  1.0.0
     License                  LGPL
     Source module            gst-vpe
     Binary package           GStreamer
     Origin URL
    GObject
    +----GInitiallyUnowned
          +----GstObject
                +----GstElement
                      +----GstVpe
    Pad Templates:
     SINK template: 'sink'
       Availability: Always
       Capabilities:
         video/x-raw
                    format: NV12
                     width: [ 1, 2147483647 ]
                    height: [ 1, 2147483647 ]
                 framerate: [ 0/1, 2147483647/1 ]
         video/x-raw
                    format: YUYV
         video/x-raw
                    format: BGR3
         video/x-raw
                    format: RGB3
         video/x-raw
                    format: BGR
         video/x-raw
                    format: RGB
         video/x-raw
                    format: YUY2
     SRC template: 'src'
       Capabilities:
         video/x-raw
                    format: NV12
         video/x-raw
                    format: YUYV
         video/x-raw
                    format: BGR3
         video/x-raw
                    format: RGB3
         video/x-raw
                    format: BGR
         video/x-raw
                    format: RGB
         video/x-raw
                    format: YUY2
    Element Flags:
     no flags set
    Element Implementation:
     Has change_state() function: gst_vpe_change_state
    Element has no clocking capabilities.
    Element has no URI handling capabilities.
    Pads:
     SINK: 'sink'
       Pad Template: 'sink'
     SRC: 'src'
       Pad Template: 'src'
    Element Properties:
     name                : The name of the object
                           flags: readable, writable
                           String. Default: "vpe0"
     parent              : The parent of the object
                           Object of type "GstObject"
     num-input-buffers   : The number if input buffers allocated should be specified based on the upstream element's requirement. For example, if gst-ducati-plugin is the upstream element, this value should be based on max-reorder-frames property of that element. 0 => decide automatically
                           Integer. Range: 0 - 128 Default: 12
     num-output-buffers  : The number if output buffers allocated should be specified based on the downstream element's requirement. It is generally set to the minimum value acceptable to the downstream element to reduce memory usage.
                           Integer. Range: 3 - 16 Default: 6
     device              : Device location
                           String. Default: "/dev/v4l/by-path/platform-489d0000.vpe-video-index0"
    root@am57xx-evm:~#
    I am also attaching modified source files and debug-log when execute command on machine for "NV12" and "RGB".
    Setting pipeline to PAUSED ...
    Pipeline is live and does not need PREROLL ...
    Progress: (open) Opening Stream
    Progress: (connect) Connecting to rtsp://888888:888888@192.168.1.10:554/cam/realmonitor?channel=1&subtype=1 --live --fps 25
    Progress: (open) Retrieving server options
    Progress: (open) Retrieving media info
    Progress: (request) SETUP stream 0
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: latency = 2000
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: ntp-sync = false
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: rfc7273-sync = false
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: ntp-time-source = NTP time based on realtime clock
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: drop-on-latency = false
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: max-rtcp-rtp-time-diff = 1000
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager: buffer-mode = Slave receiver to sender clock
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 5000000000
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: caps = application/x-rtcp
    Progress: (open) Opened Stream
    Setting pipeline to PLAYING ...
    New clock: GstSystemClock
    Progress: (request) Sending PLAY request
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    Progress: (request) Sent PLAY request
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1.GstPad:src: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0.GstProxyPad:proxypad3: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel1.GstFunnelPad:funnelpad1: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtcp_sink_0: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0.GstProxyPad:proxypad2: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel0.GstFunnelPad:funnelpad0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc0: timeout = 0
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:src: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)0164001effe100146764001eace8161fb011000003001e000007080401000468ee3cb0, level=(string)3, profile=(string)high
    /GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:sink: caps = video/x-h264, stream-format=(string)avc, alignment=(string)au, codec_data=(buffer)0164001effe100146764001eace8161fb011000003001e000007080401000468ee3cb0, level=(string)3, profile=(string)high
    /GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_4294945980_96.GstProxyPad:proxypad6: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_src_0_4294945980_96.GstProxyPad:proxypad5: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706155622, seqnum-base=(uint)5194, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstH264Parse:h264parse0.GstPad:src: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3, profile=(string)high, pixel-aspect-ratio=(fraction)1/1, width=(int)352, height=(int)240, framerate=(fraction)0/1, interlace-mode=(string)progressive, parsed=(boolean)true
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3, profile=(string)high, pixel-aspect-ratio=(fraction)1/1, width=(int)352, height=(int)240, framerate=(fraction)0/1, interlace-mode=(string)progressive, parsed=(boolean)true
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0/GstDucatiH264Dec:decoder.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)512, height=(int)336, framerate=(fraction)0/1, pixel-aspect-ratio=(fraction)1/1, drm_mem=(boolean)true
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0/GstVpe:vpe.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)800, height=(int)600, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0.GstGhostPad:src: caps = video/x-raw, format=(string)NV12, width=(int)800, height=(int)600, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1
    /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)800, height=(int)600, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1
    /GstPipeline:pipeline0/GstWaylandSink:waylandsink0.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)800, height=(int)600, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1
    /GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)800, height=(int)600, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0.GstGhostPad:src.GstProxyPad:proxypad1: caps = video/x-raw, format=(string)NV12, width=(int)800, height=(int)600, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0/GstVpe:vpe.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)512, height=(int)336, framerate=(fraction)0/1, pixel-aspect-ratio=(fraction)1/1, drm_mem=(boolean)true
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0/GstDucatiH264Dec:decoder.GstPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3, profile=(string)high, pixel-aspect-ratio=(fraction)1/1, width=(int)352, height=(int)240, framerate=(fraction)0/1, interlace-mode=(string)progressive, parsed=(boolean)true
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0.GstGhostPad:sink: caps = video/x-h264, stream-format=(string)byte-stream, alignment=(string)au, level=(string)3, profile=(string)high, pixel-aspect-ratio=(fraction)1/1, width=(int)352, height=(int)240, framerate=(fraction)0/1, interlace-mode=(string)progressive, parsed=(boolean)true
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0/GstDucatiH264Dec:decoder.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)512, height=(int)336, framerate=(fraction)0/1, pixel-aspect-ratio=(fraction)1/1, drm_mem=(boolean)true, max-ref-frames=(int)18
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0/GstVpe:vpe.GstPad:sink: caps = video/x-raw, format=(string)NV12, width=(int)512, height=(int)336, framerate=(fraction)0/1, pixel-aspect-ratio=(fraction)1/1, drm_mem=(boolean)true, max-ref-frames=(int)18
    0:00:01.352406180  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 0/128, 0
    0:00:01.363504811  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 1/128, 1
    0:00:01.421508537  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 2/128, 2
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1270896741\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)4294945980\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.1.10:20000\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)79680\,\ packets-received\=\(guint64\)73\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)18\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)0\,\ sent-rb-packetslost\=\(int\)0\,\ sent-rb-exthighestseq\=\(uint\)5267\,\ sent-rb-jitter\=\(uint\)18\,\ sent-rb-lsr\=\(uint\)0\,\ sent-rb-dlsr\=\(uint\)0\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:send_rtcp_src: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSink:udpsink1.GstPad:sink: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:send_rtcp_src_0.GstProxyPad:proxypad4: caps = application/x-rtcp
    0:00:02.881509792  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 3/128, 0
    0:00:02.883508294  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 4/128, 1
    0:00:02.951488101  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 5/128, 0
    0:00:02.953499290  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 6/128, 1
    0:00:03.020488630  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 7/128, 0
    0:00:03.022497543  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 8/128, 1
    0:00:03.081519390  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 9/128, 0
    0:00:03.083506830  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 10/128, 1
    0:00:03.151484848  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 11/128, 0
    0:00:03.153497664  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 12/128, 1
    0:00:03.221484141  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 13/128, 0
    0:00:03.224473435  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 14/128, 1
    0:00:03.269532283  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 15/128, 0
    0:00:03.271498903  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 16/128, 1
    0:00:03.351488590  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 17/128, 0
    0:00:03.353489044  2360   0x21fdb0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 18/128, 1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1270896741\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)4294945980\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.1.10:20000\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)312247\,\ packets-received\=\(guint64\)283\,\ bitrate\=\(guint64\)761454\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)17\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)0\,\ sent-rb-packetslost\=\(int\)0\,\ sent-rb-exthighestseq\=\(uint\)5267\,\ sent-rb-jitter\=\(uint\)18\,\ sent-rb-lsr\=\(uint\)0\,\ sent-rb-dlsr\=\(uint\)0\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel1.GstPad:src: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:sync_src: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:rtcp_sink: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtcp_sink: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:rtcp_src_4294945980: caps = application/x-rtcp, ssrc=(uint)4294945980
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink_rtcp: caps = application/x-rtcp, ssrc=(uint)4294945980
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: timeout = 5000000000
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc2: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0.GstProxyPad:proxypad2: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel0.GstFunnelPad:funnelpad0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_sink_0: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc2.GstPad:src: caps = application/x-rtcp
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstUDPSrc:udpsrc1: timeout = 0
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstFunnel:funnel0.GstPad:src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_src: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSsrcDemux:rtpssrcdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0.GstPad:recv_rtp_sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpJitterBuffer:rtpjitterbuffer0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpPtDemux:rtpptdemux0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRtpH264Depay:rtph264depay0.GstPad:sink: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0.GstGhostPad:recv_rtp_src_0_4294945980_96.GstProxyPad:proxypad6: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager.GstGhostPad:recv_rtp_src_0_4294945980_96.GstProxyPad:proxypad5: caps = application/x-rtp, media=(string)video, payload=(int)96, clock-rate=(int)90000, encoding-name=(string)H264, packetization-mode=(string)1, profile-level-id=(string)64001E, sprop-parameter-sets=(string)"Z2QAHqzoFh+wEQAAAwAeAAAHCAQ\=\,aO48sA\=\=", a-packetization-supported=(string)DH, a-recvonly=(string)"", ssrc=(uint)4294945980, clock-base=(uint)706601032, seqnum-base=(uint)5607, npt-start=(guint64)0, play-speed=(double)1, play-scale=(double)1
    (gst-launch-1.0:2374): GStreamer-CRITICAL **: gst_caps_get_structure: assertion 'index < GST_CAPS_LEN (caps)' failed
    (gst-launch-1.0:2374): GStreamer-CRITICAL **: gst_structure_get_string: assertion 'structure != NULL' failed
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0/GstVpe:vpe.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)512, height=(int)336, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1
    0:00:00.913829547  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 0/128, 0
    /GstPipeline:pipeline0/GstDucatiH264decVpe:ducatih264decvpe0/GstVpe:vpe.GstPad:src: caps = video/x-raw, format=(string)NV12, width=(int)352, height=(int)240, interlace-mode=(string)progressive, pixel-aspect-ratio=(fraction)1/1, framerate=(fraction)0/1
    0:00:00.933971700  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 1/128, 0
    0:00:00.984985389  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 2/128, 0
    0:00:01.004976101  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 3/128, 0
    0:00:01.042979844  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 4/128, 0
    0:00:01.074989058  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 5/128, 0
    0:00:01.113972533  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 6/128, 0
    0:00:01.143975437  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 7/128, 0
    0:00:01.185971630  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 8/128, 0
    0:00:01.204978544  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 9/128, 0
    0:00:01.243969827  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 10/128, 0
    0:00:01.274980115  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 11/128, 0
    0:00:01.312968243  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 12/128, 0
    0:00:01.334975513  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 13/128, 0
    0:00:01.385974561  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 14/128, 0
    0:00:01.404975294  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 15/128, 0
    0:00:01.442979038  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 16/128, 0
    0:00:01.467025964  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 17/128, 0
    0:00:01.512976054  2374 0xb59016f0 WARN                     vpe gstvpebufferpool.c:471:gst_vpe_buffer_pool_import: Allocating a new input buffer index: 18/128, 0
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1567166861\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)4294945980\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.1.10:20000\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)206610\,\ packets-received\=\(guint64\)179\,\ bitrate\=\(guint64\)742435\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)19\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)0\,\ sent-rb-packetslost\=\(int\)0\,\ sent-rb-exthighestseq\=\(uint\)5786\,\ sent-rb-jitter\=\(uint\)19\,\ sent-rb-lsr\=\(uint\)0\,\ sent-rb-dlsr\=\(uint\)0\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1567166861\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)4294945980\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.1.10:20000\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)443190\,\ packets-received\=\(guint64\)383\,\ bitrate\=\(guint64\)750584\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)21\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)0\,\ sent-rb-packetslost\=\(int\)0\,\ sent-rb-exthighestseq\=\(uint\)5786\,\ sent-rb-jitter\=\(uint\)19\,\ sent-rb-lsr\=\(uint\)0\,\ sent-rb-dlsr\=\(uint\)0\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(uint\)0\;" >, rtx-count=(uint)0;
    /GstPipeline:pipeline0/GstRTSPSrc:rtspsrc0/GstRtpBin:manager/GstRtpSession:rtpsession0: stats = application/x-rtp-session-stats, rtx-drop-count=(uint)0, sent-nack-count=(uint)0, recv-nack-count=(uint)0, source-stats=(GValueArray)< "application/x-rtp-source-stats\,\ ssrc\=\(uint\)1567166861\,\ internal\=\(boolean\)true\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)false\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)-1\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)0\,\ packets-received\=\(guint64\)0\,\ bitrate\=\(guint64\)0\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)0\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)false\,\ sr-ntptime\=\(guint64\)0\,\ sr-rtptime\=\(uint\)0\,\ sr-octet-count\=\(uint\)0\,\ sr-packet-count\=\(uint\)0\;", "application/x-rtp-source-stats\,\ ssrc\=\(uint\)4294945980\,\ internal\=\(boolean\)false\,\ validated\=\(boolean\)true\,\ received-bye\=\(boolean\)false\,\ is-csrc\=\(boolean\)false\,\ is-sender\=\(boolean\)true\,\ seqnum-base\=\(int\)-1\,\ clock-rate\=\(int\)90000\,\ rtp-from\=\(string\)192.168.1.10:20000\,\ rtcp-from\=\(string\)192.168.1.10:20001\,\ octets-sent\=\(guint64\)0\,\ packets-sent\=\(guint64\)0\,\ octets-received\=\(guint64\)732566\,\ packets-received\=\(guint64\)632\,\ bitrate\=\(guint64\)759751\,\ packets-lost\=\(int\)0\,\ jitter\=\(uint\)24\,\ sent-pli-count\=\(uint\)0\,\ recv-pli-count\=\(uint\)0\,\ sent-fir-count\=\(uint\)0\,\ recv-fir-count\=\(uint\)0\,\ sent-nack-count\=\(uint\)0\,\ recv-nack-count\=\(uint\)0\,\ have-sr\=\(boolean\)true\,\ sr-ntptime\=\(guint64\)16086021561525469184\,\ sr-rtptime\=\(uint\)707029252\,\ sr-octet-count\=\(uint\)9509424\,\ sr-packet-count\=\(uint\)8100\,\ sent-rb\=\(boolean\)true\,\ sent-rb-fractionlost\=\(uint\)0\,\ sent-rb-packetslost\=\(int\)0\,\ sent-rb-exthighestseq\=\(uint\)6239\,\ sent-rb-jitter\=\(uint\)24\,\ sent-rb-lsr\=\(uint\)123863040\,\ sent-rb-dlsr\=\(uint\)197675\,\ have-rb\=\(boolean\)false\,\ rb-fractionlost\=\(uint\)0\,\ rb-packetslost\=\(int\)0\,\ rb-exthighestseq\=\(uint\)0\,\ rb-jitter\=\(uint\)0\,\ rb-lsr\=\(uint\)0\,\ rb-dlsr\=\(uint\)0\,\ rb-round-trip\=\(
    Kishan Patel.
  • Hello Margarita,
               I have modified "grammar.y" file at path "tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0/1.12.2-r0/package/usr/src/debug/gstreamer1.0/1.12.2-r0/gstreamer-1.12.2/gst/parse/grammar.y" in function "static gint
    gst_parse_perform_link (link_t *link, graph_t *graph)".
    I am attaching that modified file.
    Then execute "MACHINE=am57xx-evm bitbake -f -c compile gstreamer1.0".
    Then copy 3 libraries (libgstreamer-1.0.so , libgstreamer-1.0.so.0 , libgstreamer-1.0.so.0.1202.0) on am5728_board at path "/usr/lib".
    And execute commands as Below. Please,check its log:
    Command:
    gst-launch-1.0 --gst-debug=vpe:3 -v rtspsrc location=rtsp://888888:888888@192.168.1.4:554 ! rtph264depay ! h264parse ! ducatih264dec ! vpe ! 'video/x-raw, format=(string)BGR3, width=(int)800, height=(int)600' ! waylandsink
    Log:
    Please,check log file.
    Command:
    gst-launch-1.0 --gst-debug=vpe:3 -v rtspsrc location=rtsp://888888:888888@192.168.1.4:554 ! rtph264depay ! h264parse ! ducatih264dec ! vpe ! 'video/x-raw, format=(string)NV12, width=(int)800, height=(int)600' ! waylandsink
    Log:
    I have modified many things. Can you guide me that what should be wrong to link "VPE" and "waylandsink"?
    Kishan Patel.
    SRC=rtspsrc0
    SINK=rtph264depay0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=0
    Success2
    SRC=rtph264depay0
    SINK=h264parse0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=1
    Success1
    Caps=0
    SRC=h264parse0
    SINK=ducatih264dec0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=1
    Success1
    Caps=0
    SRC=ducatih264dec0
    SINK=vpe0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=1
    Success1
    Caps=0
    SRC=vpe0
    SINK=waylandsink0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=1
    Success1
    Caps=155968
    SRC=rtspsrc0
    SINK=rtph264depay0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=0
    Success2
    SRC=rtph264depay0
    SINK=h264parse0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=1
    Success1
    Caps=0
    SRC=h264parse0
    SINK=ducatih264dec0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=1
    Success1
    Caps=0
    SRC=ducatih264dec0
    SINK=vpe0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=1
    Success1
    Caps=0
    SRC=vpe0
    SINK=waylandsink0
    SRCS=(null)
    srcs:2
    sinks:2
    Found_one=0
    goto error3
    WARNING: erroneous pipeline: 2_could not link vpe0 to waylandsink0, waylandsink0 can't handle caps video/x-raw, format=(string)BGR3, width=(int)800, height=(int)600
    #include "../gst_private.h"
    #include <glib-object.h>
    #include <glib.h>
    #include <stdio.h>
    #include <string.h>
    #include <stdlib.h>
    #include "../gst-i18n-lib.h"
    #include "../gstconfig.h"
    #include "../gstparse.h"
    #include "../gstinfo.h"
    #include "../gsterror.h"
    #include "../gststructure.h"
    #include "../gsturi.h"
    #include "../gstutils.h"
    #include "../gstvalue.h"
    #include "../gstchildproxy.h"
    #include "types.h"
    /* All error messages in this file are user-visible and need to be translated.
     * Don't start the message with a capital, and don't end them with a period,
     * as they will be presented inside a sentence/error.
    #define DEBUG_ENABLE
    #define YYERROR_VERBOSE 1
    #define YYENABLE_NLS 0
    #ifndef YYLTYPE_IS_TRIVIAL
    #define YYLTYPE_IS_TRIVIAL 0
    #endif
    *** Tracing memory leaks
    #ifdef __GST_PARSE_TRACE
    static guint __strings;
    static guint __links;
    static guint __chains;
    gchar *
    __gst_parse_strdup (gchar *org)
      gchar *ret;
      __strings++;
      ret = g_strdup (org);
      /* g_print ("ALLOCATED STR   (%3u): %p %s\n", __strings, ret, ret); */
      return ret;
    void
    __gst_parse_strfree (gchar *str)
      if (str) {
        /* g_print ("FREEING STR     (%3u): %p %s\n", __strings - 1, str, str); */
        g_free (str);
        g_return_if_fail (__strings > 0);
        __strings--;
    link_t *__gst_parse_link_new (void)
      link_t *ret;
      __links++;
      ret = g_slice_new0 (link_t);
      /* g_print ("ALLOCATED LINK  (%3u): %p\n", __links, ret); */
      return ret;
    void
    __gst_parse_link_free (link_t *data)
      if (data) {
        /* g_print ("FREEING LINK    (%3u): %p\n", __links - 1, data); */
        g_slice_free (link_t, data);
        g_return_if_fail (__links > 0);
        __links--;
    chain_t *
    __gst_parse_chain_new (void)
      chain_t *ret;
      __chains++;
      ret = g_slice_new0 (chain_t);
      /* g_print ("@%p: ALLOCATED CHAIN (%3u):\n", ret, __chains); */
      return ret;
    void
    __gst_parse_chain_free (chain_t *data)
      /* g_print ("@%p: FREEING CHAIN   (%3u):\n", data, __chains - 1); */
      g_slice_free (chain_t, data);
      g_return_if_fail (__chains > 0);
      __chains--;
    #endif /* __GST_PARSE_TRACE */
    *** define SET_ERROR macro/function
    #ifdef G_HAVE_ISO_VARARGS
    #  define SET_ERROR(error, type, ...) \
    G_STMT_START { \
      GST_CAT_ERROR (GST_CAT_PIPELINE, __VA_ARGS__); \
      if ((error) && !*(error)) { \
        g_set_error ((error), GST_PARSE_ERROR, (type), __VA_ARGS__); \
    } G_STMT_END
    #elif defined(G_HAVE_GNUC_VARARGS)
    #  define SET_ERROR(error, type, args...) \
    G_STMT_START { \
      GST_CAT_ERROR (GST_CAT_PIPELINE, args ); \
        g_set_error ((error), GST_PARSE_ERROR, (type), args ); \
    } G_STMT_END
    #else
    static inline void
    SET_ERROR (GError **error, gint type, const char *format, ...)
      if (error) {
        if (*error) {
          g_warning ("error while parsing");
        } else {
          va_list varargs;
          char *string;
          va_start (varargs, format);
          string = g_strdup_vprintf (format, varargs);
          va_end (varargs);
          g_set_error (error, GST_PARSE_ERROR, type, string);
          g_free (string);
    #endif /* G_HAVE_ISO_VARARGS */
    /*** define YYPRINTF macro/function if we're debugging */
    /* bison 1.35 calls this macro with side effects, we need to make sure the
       side effects work - crappy bison */
    #ifndef GST_DISABLE_GST_DEBUG
    #  define YYDEBUG 1
    #  ifdef G_HAVE_ISO_VARARGS
    /* #  define YYFPRINTF(a, ...) GST_CAT_DEBUG (GST_CAT_PIPELINE, __VA_ARGS__) */
    #    define YYFPRINTF(a, ...) \
    G_STMT_START { \
         GST_CAT_LOG (GST_CAT_PIPELINE, __VA_ARGS__); \
    } G_STMT_END
    #  elif defined(G_HAVE_GNUC_VARARGS)
    #    define YYFPRINTF(a, args...) \
    G_STMT_START { \
         GST_CAT_LOG (GST_CAT_PIPELINE, args); \
    } G_STMT_END
    #  else
    static inline void
    YYPRINTF(const char *format, ...)
      va_list varargs;
      gchar *temp;
      temp = g_strdup_vprintf (format, varargs);
      GST_CAT_LOG (GST_CAT_PIPELINE, "%s", temp);
      g_free (temp);
      va_end (varargs);
    #  endif /* G_HAVE_ISO_VARARGS */
    #endif /* GST_DISABLE_GST_DEBUG */
     * include headers generated by bison & flex, after defining (or not defining) YYDEBUG
    #include "grammar.tab.h"
    #include "parse_lex.h"
    *** report missing elements/bins/..
    static void  add_missing_element(graph_t *graph,gchar *name){
      if ((graph)->ctx){
        (graph)->ctx->missing_elements = g_list_append ((graph)->ctx->missing_elements, g_strdup (name));
    *** helpers for pipeline-setup
    #define TRY_SETUP_LINK(l) G_STMT_START { \
       if( (!(l)->src.element) && (!(l)->src.name) ){ \
         SET_ERROR (graph->error, GST_PARSE_ERROR_LINK, _("link has no source [sink=%s@%p]"), \
    	(l)->sink.name ? (l)->sink.name : "", \
    	(l)->sink.element); \
         gst_parse_free_link (l); \
       }else if( (!(l)->sink.element) && (!(l)->sink.name) ){ \
         SET_ERROR (graph->error, GST_PARSE_ERROR_LINK, _("link has no sink [source=%s@%p]"), \
    	(l)->src.name ? (l)->src.name : "", \
    	(l)->src.element); \
       }else{ \
         graph->links = g_slist_append (graph->links, l ); \
    } G_STMT_END
    typedef struct {
      gchar *src_pad;
      gchar *sink_pad;
      GstElement *sink;
      GstCaps *caps;
      gulong pad_added_signal_id, no_more_pads_signal_id;
      gboolean all_pads;
    } DelayedLink;
    typedef struct {
      gchar *name;
      gchar *value_str;
      gulong signal_id;
    } DelayedSet;
    static int  gst_resolve_reference(reference_t *rr, GstElement *pipeline){
      GstBin *bin;
      if(rr->element) return  0;  /* already resolved! */
      if(!rr->name)   return -2;  /* no chance! */
      if (GST_IS_BIN (pipeline)){
        bin = GST_BIN (pipeline);
        rr->element = gst_bin_get_by_name_recurse_up (bin, rr->name);
      } else {
        rr->element = strcmp (GST_ELEMENT_NAME (pipeline), rr->name) == 0 ?
    		gst_object_ref(pipeline) : NULL;
      if(rr->element) return 0; /* resolved */
      else            return -1; /* not found */
    static void gst_parse_free_delayed_set (DelayedSet *set)
      g_free(set->name);
      g_free(set->value_str);
      g_slice_free(DelayedSet, set);
    static void gst_parse_new_child(GstChildProxy *child_proxy, GObject *object,
        const gchar * name, gpointer data);
    static void gst_parse_add_delayed_set (GstElement *element, gchar *name, gchar *value_str)
      DelayedSet *data = g_slice_new0 (DelayedSet);
      GST_CAT_LOG_OBJECT (GST_CAT_PIPELINE, element, "delaying property set %s to %s",
        name, value_str);
      data->name = g_strdup(name);
      data->value_str = g_strdup(value_str);
      data->signal_id = g_signal_connect_data(element, "child-added",
          G_CALLBACK (gst_parse_new_child), data, (GClosureNotify)
          gst_parse_free_delayed_set, (GConnectFlags) 0);
      /* FIXME: we would need to listen on all intermediate bins too */
      if (GST_IS_BIN (element)) {
        gchar **names, **current;
        GstElement *parent, *child;
        current = names = g_strsplit (name, "::", -1);
        parent = gst_bin_get_by_name (GST_BIN_CAST (element), current[0]);
        current++;
        while (parent && current[0]) {
          child = gst_bin_get_by_name (GST_BIN (parent), current[0]);
          if (!child && current[1]) {
            char *sub_name = g_strjoinv ("::", &current[0]);
            gst_parse_add_delayed_set(parent, sub_name, value_str);
            g_free (sub_name);
          gst_object_unref (parent);
          parent = child;
          current++;
        if (parent)
        g_strfreev (names);
      DelayedSet *set = (DelayedSet *) data;
      GParamSpec *pspec;
      GValue v = { 0, };
      GObject *target = NULL;
      GType value_type;
      GST_CAT_LOG_OBJECT (GST_CAT_PIPELINE, child_proxy, "new child %s, checking property %s",
          name, set->name);
      if (gst_child_proxy_lookup (child_proxy, set->name, &target, &pspec)) {
        gboolean got_value = FALSE;
        value_type = pspec->value_type;
        GST_CAT_LOG_OBJECT (GST_CAT_PIPELINE, child_proxy, "parsing delayed property %s as a %s from %s",
          pspec->name, g_type_name (value_type), set->value_str);
        g_value_init (&v, value_type);
        if (gst_value_deserialize (&v, set->value_str))
          got_value = TRUE;
        else if (g_type_is_a (value_type, GST_TYPE_ELEMENT)) {
           GstElement *bin;
           bin = gst_parse_bin_from_description_full (set->value_str, TRUE, NULL,
               GST_PARSE_FLAG_NO_SINGLE_ELEMENT_BINS | GST_PARSE_FLAG_PLACE_IN_BIN, NULL);
           if (bin) {
             g_value_set_object (&v, bin);
             got_value = TRUE;
        g_signal_handler_disconnect (child_proxy, set->signal_id);
        if (!got_value)
    	#ifdef DEBUG_ENABLE
    	printf("\ngoto error1\n");
    	#endif
          goto error;
        g_object_set_property (target, pspec->name, &v);
      } else {
        const gchar *obj_name = GST_OBJECT_NAME(object);
        gint len = strlen (obj_name);
        /* do a delayed set */
        if ((strlen (set->name) > (len + 2)) && !strncmp (set->name, obj_name, len) && !strncmp (&set->name[len], "::", 2)) {
          gst_parse_add_delayed_set (GST_ELEMENT(child_proxy), set->name, set->value_str);
    out:
      if (G_IS_VALUE (&v))
        g_value_unset (&v);
      if (target)
        g_object_unref (target);
      return;
    error:
      GST_CAT_ERROR (GST_CAT_PIPELINE, "could not set property \"%s\" in %"
          GST_PTR_FORMAT, pspec->name, target);
      goto out;
    static void gst_parse_element_set (gchar *value, GstElement *element, graph_t *graph)
      GParamSpec *pspec = NULL;
      gchar *pos = value;
      GValue v = { 0, };
      GType value_type;
      /* do nothing if assignment is for missing element */
      if (element == NULL)
        goto out;
      /* parse the string, so the property name is null-terminated and pos points
         to the beginning of the value */
      while (!g_ascii_isspace (*pos) && (*pos != '=')) pos++;
      if (*pos == '=') {
        *pos = '\0';
      } else {
        *pos = '\0';
        pos++;
        while (g_ascii_isspace (*pos)) pos++;
      pos++;
      /* truncate a string if it is delimited with double quotes */
      if (*pos == '"' && pos[strlen (pos) - 1] == '"') {
        pos++;
        pos[strlen (pos) - 1] = '\0';
      gst_parse_unescape (pos);
      if (GST_IS_CHILD_PROXY (element)) {
        if (!gst_child_proxy_lookup (GST_CHILD_PROXY (element), value, &target, &pspec)) {
          gst_parse_add_delayed_set (element, value, pos);
      } else {
        pspec = g_object_class_find_property (G_OBJECT_GET_CLASS (element), value);
        if (pspec != NULL) {
          target = g_object_ref (element);
          GST_CAT_LOG_OBJECT (GST_CAT_PIPELINE, target, "found %s property", value);
        } else {
          SET_ERROR (graph->error, GST_PARSE_ERROR_NO_SUCH_PROPERTY, \
              _("no property \"%s\" in element \"%s\""), value, \
              GST_ELEMENT_NAME (element));
      if (pspec != NULL && target != NULL) {
        GST_CAT_LOG_OBJECT (GST_CAT_PIPELINE, element, "parsing property %s as a %s",
            pspec->name, g_type_name (value_type));
        if (gst_value_deserialize (&v, pos))
          got_value = TRUE;
           GstElement *bin;
           bin = gst_parse_bin_from_description_full (pos, TRUE, NULL,
           if (bin) {
             got_value = TRUE;
        if (!got_value)
    	#ifdef DEBUG_ENABLE
    	printf("\ngoto error2\n");
    	#endif
          goto error;
    out:
      gst_parse_strfree (value);
        g_value_unset (&v);
      if (target)
      return;
    error:
      SET_ERROR (graph->error, GST_PARSE_ERROR_COULD_NOT_SET_PROPERTY,
             _("could not set property \"%s\" in element \"%s\" to \"%s\""),
    	 value, GST_ELEMENT_NAME (element), pos);
      goto out;
    static void gst_parse_free_reference (reference_t *rr)
      if(rr->element) gst_object_unref(rr->element);
      gst_parse_strfree (rr->name);
      g_slist_foreach (rr->pads, (GFunc) gst_parse_strfree, NULL);
      g_slist_free (rr->pads);
    static void gst_parse_free_link (link_t *link)
    	#ifdef DEBUG_ENABLE
    	//printf("\nsrc=%s\nsink=%s\n",GST_ELEMENT_NAME (src), GST_ELEMENT_NAME (sink));
    	#endif
      gst_parse_free_reference (&(link->src));
      gst_parse_free_reference (&(link->sink));
      if (link->caps) gst_caps_unref (link->caps);
      gst_parse_link_free (link);
    static void gst_parse_free_chain (chain_t *ch)
      GSList *walk;
      gst_parse_free_reference (&(ch->first));
      gst_parse_free_reference (&(ch->last));
      for(walk=ch->elements;walk;walk=walk->next)
        gst_object_unref (walk->data);
      g_slist_free (ch->elements);
      gst_parse_chain_free (ch);
    static void gst_parse_free_delayed_link (DelayedLink *link)
      g_free (link->src_pad);
      g_free (link->sink_pad);
      g_slice_free (DelayedLink, link);
    #define PRETTY_PAD_NAME_FMT "%s %s of %s named %s"
    #define PRETTY_PAD_NAME_ARGS(elem, pad_name) \
      (pad_name ? "pad " : "some"), (pad_name ? pad_name : "pad"), \
      G_OBJECT_TYPE_NAME(elem), GST_STR_NULL (GST_ELEMENT_NAME (elem))
    static void gst_parse_no_more_pads (GstElement *src, gpointer data)
      DelayedLink *link = data;
      /* Don't warn for all-pads links, as we expect those to
       * still be active at no-more-pads */
      if (!link->all_pads) {
        GST_ELEMENT_WARNING(src, PARSE, DELAYED_LINK,
          (_("Delayed linking failed.")),
          ("failed delayed linking " PRETTY_PAD_NAME_FMT " to " PRETTY_PAD_NAME_FMT,
              PRETTY_PAD_NAME_ARGS (src, link->src_pad),
              PRETTY_PAD_NAME_ARGS (link->sink, link->sink_pad)));
      /* we keep the handlers connected, so that in case an element still adds a pad
       * despite no-more-pads, we will consider it for pending delayed links */
    static void gst_parse_found_pad (GstElement *src, GstPad *pad, gpointer data)
      GST_CAT_INFO (GST_CAT_PIPELINE,
                    "trying delayed linking %s " PRETTY_PAD_NAME_FMT " to " PRETTY_PAD_NAME_FMT,
    		            link->all_pads ? "all pads" : "one pad",
                    PRETTY_PAD_NAME_ARGS (link->sink, link->sink_pad));
      if (gst_element_link_pads_filtered (src, link->src_pad, link->sink,
          link->sink_pad, link->caps)) {
        /* do this here, we don't want to get any problems later on when
         * unlocking states */
                       "delayed linking %s " PRETTY_PAD_NAME_FMT " to " PRETTY_PAD_NAME_FMT " worked",
        g_signal_handler_disconnect (src, link->no_more_pads_signal_id);
        /* releases 'link' */
          g_signal_handler_disconnect (src, link->pad_added_signal_id);
    /* both padnames and the caps may be NULL */
    static gboolean
    gst_parse_perform_delayed_link (GstElement *src, const gchar *src_pad,
                                    GstElement *sink, const gchar *sink_pad,
                                    GstCaps *caps, gboolean all_pads)
      GList *templs = gst_element_class_get_pad_template_list (
          GST_ELEMENT_GET_CLASS (src));
      for (; templs; templs = templs->next) {
        GstPadTemplate *templ = (GstPadTemplate *) templs->data;
        if ((GST_PAD_TEMPLATE_DIRECTION (templ) == GST_PAD_SRC) &&
            (GST_PAD_TEMPLATE_PRESENCE(templ) == GST_PAD_SOMETIMES))
          DelayedLink *data = g_slice_new (DelayedLink);
          data->all_pads = all_pads;
          /* TODO: maybe we should check if src_pad matches this template's names */
                         "trying delayed link " PRETTY_PAD_NAME_FMT " to " PRETTY_PAD_NAME_FMT,
                         PRETTY_PAD_NAME_ARGS (src, src_pad),
                         PRETTY_PAD_NAME_ARGS (sink, sink_pad));
          data->src_pad = g_strdup (src_pad);
          data->sink = sink;
          data->sink_pad = g_strdup (sink_pad);
          if (caps) {
          	data->caps = gst_caps_copy (caps);
          } else {
          	data->caps = NULL;
          data->pad_added_signal_id = g_signal_connect_data (src, "pad-added",
              G_CALLBACK (gst_parse_found_pad), data,
              (GClosureNotify) gst_parse_free_delayed_link, (GConnectFlags) 0);
          data->no_more_pads_signal_id = g_signal_connect (src, "no-more-pads",
              G_CALLBACK (gst_parse_no_more_pads), data);
          return TRUE;
      return FALSE;
    static gboolean
    gst_parse_element_can_do_caps (GstElement * e, GstPadDirection dir,
        GstCaps * link_caps)
      gboolean can_do = FALSE, done = FALSE;
      GstIterator *it;
      it = (dir == GST_PAD_SRC) ? gst_element_iterate_src_pads (e) : gst_element_iterate_sink_pads (e);
      while (!done && !can_do) {
        GValue v = G_VALUE_INIT;
        GstPad *pad;
        GstCaps *caps;
        switch (gst_iterator_next (it, &v)) {
          case GST_ITERATOR_OK:
            pad = g_value_get_object (&v);
            caps = gst_pad_get_current_caps (pad);
            if (caps == NULL)
              caps = gst_pad_query_caps (pad, NULL);
            can_do = gst_caps_can_intersect (caps, link_caps);
            GST_TRACE ("can_do: %d for %" GST_PTR_FORMAT " and %" GST_PTR_FORMAT,
                can_do, caps, link_caps);
            gst_caps_unref (caps);
            g_value_unset (&v);
            break;
          case GST_ITERATOR_DONE:
          case GST_ITERATOR_ERROR:
            done = TRUE;
            break;
          case GST_ITERATOR_RESYNC:
            gst_iterator_resync (it);
            break;
      gst_iterator_free (it);
      return can_do;
     * performs a link and frees the struct. src and sink elements must be given
     * return values   0 - link performed
     *                 1 - link delayed
     *                <0 - error
    static gint
      GstElement *src = link->src.element;
      GstElement *sink = link->sink.element;
      GSList *srcs = link->src.pads;
      GSList *sinks = link->sink.pads;
      g_assert (GST_IS_ELEMENT (src));
      g_assert (GST_IS_ELEMENT (sink));
          "linking " PRETTY_PAD_NAME_FMT " to " PRETTY_PAD_NAME_FMT " (%u/%u) with caps \"%" GST_PTR_FORMAT "\"",
          PRETTY_PAD_NAME_ARGS (src, link->src.name),
          PRETTY_PAD_NAME_ARGS (sink, link->sink.name),
          g_slist_length (srcs), g_slist_length (sinks), link->caps);
      if (!srcs || !sinks) {
    	#ifdef DEBUG_ENABLE
    	//printf("\nHere\n");
    	//printf("\nSRC=%d\n",src);
    	//printf("\nSINK=%d\n",sink);
    	printf("\nSRC=%s\nSINK=%s",GST_ELEMENT_NAME (src), GST_ELEMENT_NAME (sink));
    	printf("\nSRCS=%s\n",srcs);	//->data);
    	#endif
    	srcs ? printf("\nsrcs:1\n") : printf("\nsrcs:2\n");
    	sinks ? printf("\nsinks:1\n") : printf("\nsinks:2\n");
        gboolean found_one = gst_element_link_pads_filtered (src,
            srcs ? (const gchar *) srcs->data : NULL, sink,
            sinks ? (const gchar *) sinks->data : NULL, link->caps);
    	#ifdef DEBUG_ENABLE
    	printf("\nFound_one=%d\n",found_one);
    	#endif
        if (found_one) {
    	#ifdef DEBUG_ENABLE
    	printf("\nSuccess1\n");
    	printf("\nCaps=%x\n",link->caps);
    	#endif
            goto success; /* Linked one, and not an all-pads link = we're done */
          /* Try and link more available pads */
          while (gst_element_link_pads_filtered (src,
            sinks ? (const gchar *) sinks->data : NULL, link->caps));
        /* We either didn't find any static pads, or this is a all-pads link,
         * in which case watch for future pads and link those. Not a failure
         * in the all-pads case if there's no sometimes pads to watch */
        if (gst_parse_perform_delayed_link (src,
              sink, sinks ? (const gchar *) sinks->data : NULL, link->caps,
    	  link->all_pads) || link->all_pads) {
    	#ifdef DEBUG_ENABLE
    	printf("\nSuccess2\n");
    	#endif
          goto success;
        } else {
    	#ifdef DEBUG_ENABLE
    	printf("\ngoto error3\n");
    	#endif
          goto error;
      if (g_slist_length (link->src.pads) != g_slist_length (link->sink.pads)) {
    	#ifdef DEBUG_ENABLE
    	printf("\ngoto error4\n");
    	#endif
        goto error;
      while (srcs && sinks) {
        const gchar *src_pad = (const gchar *) srcs->data;
        const gchar *sink_pad = (const gchar *) sinks->data;
        srcs = g_slist_next (srcs);
        sinks = g_slist_next (sinks);
        if (gst_element_link_pads_filtered (src, src_pad, sink, sink_pad,
            link->caps)) {
          continue;
        } else {
          if (gst_parse_perform_delayed_link (src, src_pad,
                                              sink, sink_pad,
    					  link->caps, link->all_pads))
    	#ifdef DEBUG_ENABLE
    	printf("\nSuccess\n");
    	#endif
    	continue;
    	else
    	#ifdef DEBUG_ENABLE
    	printf("\nNot Success\n");
    	#endif
            goto error;
    success:
      gst_parse_free_link (link);
      return 0;
    error:
      if (link->caps != NULL) {
        gboolean src_can_do_caps, sink_can_do_caps;
        gchar *caps_str = gst_caps_to_string (link->caps);
        src_can_do_caps =
            gst_parse_element_can_do_caps (src, GST_PAD_SRC, link->caps);
        sink_can_do_caps =
            gst_parse_element_can_do_caps (sink, GST_PAD_SINK, link->caps);
        if (!src_can_do_caps && sink_can_do_caps) {
              _("1_could not link %s to %s, %s can't handle caps %s"),
              GST_ELEMENT_NAME (src), GST_ELEMENT_NAME (sink),
              GST_ELEMENT_NAME (src), caps_str);
        } else if (src_can_do_caps && !sink_can_do_caps) {
              _("2_could not link %s to %s, %s can't handle caps %s"),
              GST_ELEMENT_NAME (sink), caps_str);
        } else if (!src_can_do_caps && !sink_can_do_caps) {
              _("could not link %s to %s, neither element can handle caps %s"),
              GST_ELEMENT_NAME (src), GST_ELEMENT_NAME (sink), caps_str);
        } else {
              _("could not link %s to %s with caps %s"),
        g_free (caps_str);
      } else {
            _("could not link %s to %s"), GST_ELEMENT_NAME (src),
      return -1;
    static int yyerror (void *scanner, graph_t *graph, const char *s);
    %union {
        gchar *ss;
        chain_t *cc;
        link_t *ll;
        reference_t rr;
        GstElement *ee;
        GSList *pp;
        graph_t *gg;
    /* No grammar ambiguities expected, FAIL otherwise */
    %expect 0
    %token <ss> PARSE_URL
    %token <ss> IDENTIFIER
    %left  <ss> REF PADREF BINREF
    %token <ss> ASSIGNMENT
    %token <ss> LINK
    %token <ss> LINK_ALL
    %type <ss> binopener
    %type <gg> graph
    %type <cc> chain bin chainlist openchain elementary
    %type <rr> reference
    %type <ll> link
    %type <ee> element
    %type <pp> morepads pads assignments
    %destructor {	gst_parse_strfree ($$);		} <ss>
    %destructor {	if($$)
    		  gst_parse_free_chain($$);	} <cc>
    %destructor {	gst_parse_free_link ($$);	} <ll>
    %destructor {	gst_parse_free_reference(&($$));} <rr>
    %destructor {	gst_object_unref ($$);		} <ee>
    %destructor {	GSList *walk;
    		for(walk=$$;walk;walk=walk->next)
    		  gst_parse_strfree (walk->data);
    		g_slist_free ($$);		} <pp>
    %left '(' ')'
    %left ','
    %right '.'
    %left '!' '=' ':'
    %lex-param { void *scanner }
    %parse-param { void *scanner }
    %parse-param { graph_t *graph }
    %pure-parser
    %start graph
    * Grammar explanation:
    *   _element_s are specified by an identifier of their type.
    *   a name can be give in the optional property-assignments
    *	coffeeelement
    *	fakesrc name=john
    *	identity silence=false name=frodo
    *   (cont'd)
    element:	IDENTIFIER     		      { $$ = gst_element_factory_make ($1, NULL);
    						if ($$ == NULL) {
    						  add_missing_element(graph, $1);
    						  SET_ERROR (graph->error, GST_PARSE_ERROR_NO_SUCH_ELEMENT, _("no element \"%s\""), $1);
    						gst_parse_strfree ($1);
    	|	element ASSIGNMENT	      { gst_parse_element_set ($2, $1, graph);
    						$$ = $1;
    * Grammar explanation: (cont'd)
    *   a graph has (pure) _element_s, _bin_s and _link_s.
    *   since bins are special elements, bins and elements can
    *   be generalized as _elementary_.
    *   The construction of _bin_s will be discussed later.
    *   (cont'd)
    elementary:
    	element				      { $$ = gst_parse_chain_new ();
    						/* g_print ("@%p: CHAINing elementary\n", $$); */
    						$$->first.element = $1? gst_object_ref($1) : NULL;
    						$$->last.element = $1? gst_object_ref($1) : NULL;
    						$$->first.name = $$->last.name = NULL;
    						$$->first.pads = $$->last.pads = NULL;
    						$$->elements = $1 ? g_slist_prepend (NULL, $1) : NULL;
    	| bin				      { $$=$1; }
    *   a _chain_ is a list of _elementary_s that have _link_s inbetween
    *   which are represented through infix-notation.
    *	fakesrc ! sometransformation ! fakesink
    *   every _link_ can be augmented with _pads_.
    *	coffeesrc .sound ! speakersink
    *	multisrc  .movie,ads ! .projector,smallscreen multisink
    *   and every _link_ can be setup to filter media-types
    *	mediasrc ! audio/x-raw, signed=TRUE ! stereosink
    * User HINT:
    *   if the lexer does not recognize your media-type it
    *   will make it an element name. that results in errors
    *   like
    *	NO SUCH ELEMENT: no element audio7x-raw
    *   '7' vs. '/' in https://en.wikipedia.org/wiki/QWERTZ
    * Parsing HINT:
    *   in the parser we need to differ between chains that can
    *   be extended by more elementaries (_openchain_) and others
    *   that are syntactically closed (handled later in this file).
    *	(e.g. fakesrc ! sinkreferencename.padname)
    chain:	openchain			      { $$=$1;
    						if($$->last.name){
    							SET_ERROR (graph->error, GST_PARSE_ERROR_SYNTAX,
    							_("unexpected reference \"%s\" - ignoring"), $$->last.name);
    							gst_parse_strfree($$->last.name);
    							$$->last.name=NULL;
    						if($$->last.pads){
    							_("unexpected pad-reference \"%s\" - ignoring"), (gchar*)$$->last.pads->data);
    							g_slist_foreach ($$->last.pads, (GFunc) gst_parse_strfree, NULL);
    							g_slist_free ($$->last.pads);
    							$$->last.pads=NULL;
    openchain:
    	elementary pads			      { $$=$1;
    						$$->last.pads = g_slist_concat ($$->last.pads, $2);
    						/* g_print ("@%p@%p: FKI elementary pads\n", $1, $$->last.pads); */
    	| openchain link pads elementary pads
    						$2->src  = $1->last;
    						$2->sink = $4->first;
    						$2->sink.pads = g_slist_concat ($3, $2->sink.pads);
    						TRY_SETUP_LINK($2);
    						$4->first = $1->first;
    						$4->elements = g_slist_concat ($1->elements, $4->elements);
    						gst_parse_chain_free($1);
    						$$ = $4;
    						$$->last.pads = g_slist_concat ($$->last.pads, $5);
    link:	LINK				      { $$ = gst_parse_link_new ();
    						$$->all_pads = FALSE;
    						if ($1) {
    						  $$->caps = gst_caps_from_string ($1);
    						  if ($$->caps == NULL)
    						    SET_ERROR (graph->error, GST_PARSE_ERROR_LINK, _("could not parse caps \"%s\""), $1);
    	| LINK_ALL		              { $$ = gst_parse_link_new ();
    						$$->all_pads = TRUE;
    						if ($1) {
    pads:		/* NOP */		      { $$ = NULL; }
    	|	PADREF morepads		      { $$ = $2;
    						$$ = g_slist_prepend ($$, $1);
    morepads:	/* NOP */		      { $$ = NULL; }
    	|	',' IDENTIFIER morepads	      { $$ = g_slist_prepend ($3, $2); }
    *   the first and last elements of a _chain_ can be give
    *   as URL. This creates special elements that fit the URL.
    *	fakesrc ! http://fake-sink.org
    *       http://somesource.org ! fakesink
    chain:	openchain link PARSE_URL	      { GstElement *element =
    							  gst_element_make_from_uri (GST_URI_SINK, $3, NULL, NULL);
    						/* FIXME: get and parse error properly */
    						if (!element) {
    							  _("no sink element for URI \"%s\""), $3);
    						$$ = $1;
    						$2->sink.element = element?gst_object_ref(element):NULL;
    						$2->src = $1->last;
    						TRY_SETUP_LINK($2);
    						$$->last.element = NULL;
    						if(element) $$->elements = g_slist_append ($$->elements, element);
    						g_free ($3);
    openchain:
    							  gst_element_make_from_uri (GST_URI_SRC, $1, NULL, NULL);
    						if (!element) {
    						    _("no source element for URI \"%s\""), $1);
    						/* g_print ("@%p: CHAINing srcURL\n", $$); */
    						$$->first.element = NULL;
    						$$->first.name = NULL;
    						$$->first.pads = NULL;
    						$$->last.element = element ? gst_object_ref(element):NULL;
    						$$->elements = element ? g_slist_prepend (NULL, element)  : NULL;
    						g_free($1);
    *   the first and last elements of a _chain_ can be linked
    *   to a named _reference_ (with optional pads).
    *	fakesrc ! nameOfSinkElement.
    *	fakesrc ! nameOfSinkElement.Padname
    *	fakesrc ! nameOfSinkElement.Padname, anotherPad
    *	nameOfSource.Padname ! fakesink
    chain:	openchain link reference	      { $$ = $1;
    						$2->sink= $3;
    						$2->src = $1->last;
    						TRY_SETUP_LINK($2);
    openchain:
    	reference 			      { $$ = gst_parse_chain_new ();
    						$$->last=$1;
    						$$->elements = NULL;
    reference:	REF morepads		      {
    						gchar *padname = $1;
    						GSList *pads = $2;
    						if (padname) {
    						  while (*padname != '.') padname++;
    						  *padname = '\0';
    						  padname++;
    						  if (*padname != '\0')
    						    pads = g_slist_prepend (pads, gst_parse_strdup (padname));
    						$$.element=NULL;
    						$$.name=$1;
    						$$.pads=pads;
    *   a _chainlist_ is just a list of _chain_s.
    *   You can specify _link_s with named
    *   _reference_ on each side. That
    *   works already after the explanations above.
    *	someSourceName.Pad ! someSinkName.
    *	someSourceName.Pad,anotherPad ! someSinkName.Apad,Bpad
    *   If a syntax error occurs, the already finished _chain_s
    *   and _links_ are kept intact.
    chainlist: /* NOP */			      { $$ = NULL; }
    	| chainlist chain		      { if ($1){
    						  gst_parse_free_reference(&($1->last));
    						  gst_parse_free_reference(&($2->first));
    						  $2->first = $1->first;
    						  $2->elements = g_slist_concat ($1->elements, $2->elements);
    						  gst_parse_chain_free ($1);
    						$$ = $2;
    	| chainlist error		      { $$=$1;
    						GST_CAT_DEBUG (GST_CAT_PIPELINE,"trying to recover from syntax error");
    						SET_ERROR (graph->error, GST_PARSE_ERROR_SYNTAX, _("syntax error"));
    *   _bins_
    assignments:	/* NOP */		      { $$ = NULL; }
    	|	ASSIGNMENT assignments 	      { $$ = g_slist_prepend ($2, $1); }
    binopener:	'('			      { $$ = gst_parse_strdup("bin"); }
    	|	BINREF			      { $$ = $1; }
    bin:	binopener assignments chainlist ')'   {
    						chain_t *chain = $3;
    						GSList *walk;
    						GstBin *bin = (GstBin *) gst_element_factory_make ($1, NULL);
    						if (!chain) {
    						  SET_ERROR (graph->error, GST_PARSE_ERROR_EMPTY_BIN,
    						    _("specified empty bin \"%s\", not allowed"), $1);
    						  chain = gst_parse_chain_new ();
    						  chain->first.element = chain->last.element = NULL;
    						  chain->first.name    = chain->last.name    = NULL;
    						  chain->first.pads    = chain->last.pads    = NULL;
    						  chain->elements = NULL;
    						if (!bin) {
    						    _("no bin \"%s\", unpacking elements"), $1);
    						  /* clear property-list */
    						  g_slist_foreach ($2, (GFunc) gst_parse_strfree, NULL);
    						  g_slist_free ($2);
    						  $2 = NULL;
    						} else {
    						  for (walk = chain->elements; walk; walk = walk->next )
    						    gst_bin_add (bin, GST_ELEMENT (walk->data));
    						  g_slist_free (chain->elements);
    						  chain->elements = g_slist_prepend (NULL, bin);
    						$$ = chain;
    						/* set the properties now
    						 * HINT: property-list cleared above, if bin==NULL
    						for (walk = $2; walk; walk = walk->next)
    						  gst_parse_element_set ((gchar *) walk->data,
    							GST_ELEMENT (bin), graph);
    						g_slist_free ($2);
    *   _graph_
    graph:	chainlist			      { $$ = graph;
    						$$->chain = $1;
    						if(!$1) {
    						  SET_ERROR (graph->error, GST_PARSE_ERROR_EMPTY, _("empty pipeline not allowed"));
    static int
      /* FIXME: This should go into the GError somehow, but how? */
      GST_WARNING ("Error during parsing: %s", s);
      return -1;
    GstElement *
    priv_gst_parse_launch (const gchar *str, GError **error, GstParseContext *ctx,
        GstParseFlags flags)
      graph_t g;
      gchar *dstr;
      GSList *walk;
      GstBin *bin = NULL;
      GstElement *ret;
      yyscan_t scanner;
      g_return_val_if_fail (str != NULL, NULL);
      g_return_val_if_fail (error == NULL || *error == NULL, NULL);
      g.chain = NULL;
      g.links = NULL;
      g.error = error;
      g.ctx = ctx;
      g.flags = flags;
      GST_CAT_DEBUG (GST_CAT_PIPELINE, "TRACE: tracing enabled");
      __strings = __chains = __links = 0;
      /* g_print("Now scanning: %s\n", str); */
      dstr = g_strdup (str);
      priv_gst_parse_yylex_init (&scanner);
      priv_gst_parse_yy_scan_string (dstr, scanner);
    #if YYDEBUG
      yydebug = 1;
    #endif
      if (yyparse (scanner, &g) != 0) {
        SET_ERROR (error, GST_PARSE_ERROR_SYNTAX,
            "Unrecoverable syntax error while parsing pipeline %s", str);
        priv_gst_parse_yylex_destroy (scanner);
        g_free (dstr);
        goto error1;
      g_free (dstr);
      GST_CAT_DEBUG (GST_CAT_PIPELINE, "got %u elements and %u links",
          g.chain ? g_slist_length (g.chain->elements) : 0,
          g_slist_length (g.links));
      /* ensure chain is not NULL */
      if (!g.chain){
        g.chain=gst_parse_chain_new ();
        g.chain->elements=NULL;
        g.chain->first.element=NULL;
        g.chain->first.name=NULL;
        g.chain->first.pads=NULL;
        g.chain->last.element=NULL;
        g.chain->last.name=NULL;
        g.chain->last.pads=NULL;
      /* ensure elements is not empty */
      if(!g.chain->elements){
        g.chain->elements= g_slist_prepend (NULL, NULL);
      /* put all elements in our bin if necessary */
      if(g.chain->elements->next){
        if (flags & GST_PARSE_FLAG_PLACE_IN_BIN)
          bin = GST_BIN (gst_element_factory_make ("bin", NULL));
        else
          bin = GST_BIN (gst_element_factory_make ("pipeline", NULL));
        g_assert (bin);
        for (walk = g.chain->elements; walk; walk = walk->next) {
          if (walk->data != NULL)
        g_slist_free (g.chain->elements);
        g.chain->elements = g_slist_prepend (NULL, bin);
      ret = (GstElement *) g.chain->elements->data;
      if (GST_IS_BIN (ret))
        bin = GST_BIN (ret);
      gst_parse_free_chain (g.chain);
      g.chain = NULL;
      /* resolve and perform links */
      for (walk = g.links; walk; walk = walk->next) {
        link_t *l = (link_t *) walk->data;
        int err;
        err=gst_resolve_reference( &(l->src), ret);
        if (err) {
           if(-1==err){
              SET_ERROR (error, GST_PARSE_ERROR_NO_SUCH_ELEMENT,
                  "No src-element named \"%s\" - omitting link", l->src.name);
           }else{
              /* probably a missing element which we've handled already */
                  "No src-element found - omitting link");
           continue;
        err=gst_resolve_reference( &(l->sink), ret);
        if (err) {
           if(-1==err){
                  "No sink-element named \"%s\" - omitting link", l->src.name);
           }else{
                  "No sink-element found - omitting link");
           continue;
        gst_parse_perform_link (l, &g);
      g_slist_free (g.links);
    out:
          "TRACE: %u strings, %u chains and %u links left", __strings, __chains,
          __links);
      if (__strings || __chains || __links) {
        g_warning ("TRACE: %u strings, %u chains and %u links left", __strings,
            __chains, __links);
      return ret;
    error1:
      if (g.chain) {
        g.chain=NULL;
      g_slist_foreach (g.links, (GFunc)gst_parse_free_link, NULL);
      if (error)
        g_assert (*error);
      ret = NULL;
      goto out;
    I do not understand why you are modifing the grammer_y file at all.
    You should not do this.
    Your problem is this :
    As you could see waylandsink can not handle the caps filter.
    I already wrote you that with gst-inspect-1.0 waylandsink what are the formats that it accepts.
    Look every gstreamer element has input and output.
    The input is called sink the output is src. When you link two gstreamer elements the src of first one and sink of the second must match.
    For example, YUY2 to vpe's input -> capsfilter (NV12) -> waylandsink. When you have in the capsfilter NV12 it "tells" to vpe to convert the format from YUY2 to NV12 in this exmaple. In this case waylandsink accepts on his input NV12 so all works.
    Gst-inspect command displays what capabilities the elements has, properties etc..
    However please check this thread:
    e2e.ti.com/.../610113
    BR
    Margarita
  • Hello Margarita,
            Actually, i want to debug errors. So, i have modified "grammar.y" file.
    And i have already checked "gst-inspect-1.0 waylandsink" log. Plese, check as below:
    root@am57xx-evm:~/Testing# gst-inspect-1.0 waylandsink
    Factory Details:
      Rank                     marginal (64)
      Long-name                wayland video sink
      Klass                    Sink/Video
      Description              Output to wayland surface
      Author                   Sreerenj Balachandran <sreerenj.balachandran@intel.com>, George Kiagiadakis <george.kiagiadakis@collabora.com>
    Plugin Details:
      Name                     waylandsink
      Description              Wayland Video Sink
      Filename                 /usr/lib/gstreamer-1.0/libgstwaylandsink.so
      Version                  1.12.2
      License                  LGPL
      Source module            gst-plugins-bad
      Source release date      2017-07-14
      Binary package           GStreamer Bad Plug-ins source release
      Origin URL               Unknown package origin
    GObject
     +----GInitiallyUnowned
           +----GstObject
                 +----GstElement
                       +----GstBaseSink
                             +----GstVideoSink
                                   +----GstWaylandSink
    Implemented Interfaces:
      GstVideoOverlay
      GstWaylandVideo
    Pad Templates:
      SINK template: 'sink'
        Availability: Always
        Capabilities:
          video/x-raw
                     format: { (string)BGRx, (string)BGRA, (string)RGBx, (string)xBGR, (string)xRGB, (string)RGBA, (string)ABGR, (string)ARGB, (string)RGB, (string)BGR, (string)RGB16, (string)BGR16, (string)YUY2, (string)YVYU, (string)UYVY, (string)AYUV, (string)NV12, (string)NV21, (string)NV16, (string)YUV9, (string)YVU9, (string)Y41B, (string)I420, (string)YV12, (string)Y42B, (string)v308 }
                      width: [ 1, 2147483647 ]
                     height: [ 1, 2147483647 ]
                  framerate: [ 0/1, 2147483647/1 ]
          video/x-raw(memory:DMABuf)
    Element Flags:
      no flags set
    Element Implementation:
      Has change_state() function: gst_wayland_sink_change_state
    Element has no clocking capabilities.
    Element has no URI handling capabilities.
    Pads:
      SINK: 'sink'
        Pad Template: 'sink'
    Element Properties:
      name                : The name of the object
                            flags: readable, writable
                            String. Default: "waylandsink0"
      parent              : The parent of the object
                            Object of type "GstObject"
      sync                : Sync on the clock
                            Boolean. Default: true
      max-lateness        : Maximum number of nanoseconds that a buffer can be late before it is dropped (-1 unlimited)
                            Integer64. Range: -1 - 9223372036854775807 Default: 20000000
      qos                 : Generate Quality-of-Service events upstream
      async               : Go asynchronously to PAUSED
      ts-offset           : Timestamp offset in nanoseconds
                            Integer64. Range: -9223372036854775808 - 9223372036854775807 Default: 0
      enable-last-sample  : Enable the last-sample property
      last-sample         : The last sample received in the sink
                            flags: readable
                            Boxed pointer of type "GstSample"
      blocksize           : Size in bytes to pull per buffer (0 = default)
                            Unsigned Integer. Range: 0 - 4294967295 Default: 4096
      render-delay        : Additional render delay of the sink in nanoseconds
                            Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 0
      throttle-time       : The time to keep between rendered buffers (0 = disabled)
      max-bitrate         : The maximum bits per second to render (0 = disabled)
      show-preroll-frame  : Whether to render video frames during preroll
      display             : Wayland display name to connect to, if not supplied via the GstContext
                            String. Default: null
      use-drm             : Wayland Use DRM based memory for allocation
                            flags: writable
                            Boolean. Default: false Write only
      window-resolution   : resolution of video widthxheight
                            flags: writable
                            String. Default: "NULL" Write only
    Kishan Patel.
  • Hello Margarita,
    Anything wrong in modified sorce files which i have shared you?. If any suggestion,please comment to me.
    Kishan Patel.
    E2e thread update:
    In PSDK 5.0, waylandsink supports NV12, YUY2 and BGRA on the input.
    arago-project.org/.../
    In previous PSDK version waylandsink supports NV12.
    BR
    Margarita
  • src.zipHello Margarita,
               I have to make changes in source code as listed below and i can capable to use below pipelines:
    Pipelines:
    1).gst-launch-1.0 --gst-debug=vpe:3 -v rtspsrc location=rtsp://888888:888888@192.168.1.7:554 ! rtph264depay ! h264parse ! ducatih264dec ! vpe ! 'video/x-raw, format=(string)BGR, width=(int)640, height=(int)480' ! filesink location=test.bgr -v
    2).gst-launch-1.0 --gst-debug=vpe:3 -v rtspsrc location=rtsp://888888:888888@192.168.1.7:554 ! rtph264depay ! h264parse ! ducatih264dec ! vpe ! 'video/x-raw, format=(string)RGB, width=(int)640, height=(int)480' ! filesink location=test.rgb -v
    Please check the modified files for VPE which i am attaching.
    Path:(VPE)
    tisdk/build/arago-tmp-external-linaro-toolchain/work/am57xx_evm-linux-gnueabi/gstreamer1.0-plugins-vpe/git-r2.19/git/src
    Bitbake:
    MACHINE=am57xx-evm bitbake gstreamer1.0-plugins-vpe --force -c compile
    Replace Library:
    scp tisdk/build/arago-tmp-external-linaro-toolchain/work/am57xx_evm-linux-gnueabi/gstreamer1.0-plugins-vpe/git-r2.19/git/src/.libs/libgstvpe.so root@192.168.1.9:/usr/lib/gstreamer-1.0
    Path:(Base)
    tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/gst-plugins-base-1.12.2/gst-libs/gst/video/video-format.c
    Add:
            case GST_MAKE_FOURCC ('R', 'G', 'B', '\0'):
        return GST_VIDEO_FORMAT_RGB;
    case GST_MAKE_FOURCC ('B', 'G', 'R', '\0'):
        return GST_VIDEO_FORMAT_BGR;
    Bitbake:
    MACHINE=am57xx-evm bitbake gstreamer1.0-plugins-base --force -c compile
    Replace Library:
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst/videoconvert/.libs/libgstvideoconvert.so root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst/typefind/.libs/libgsttypefindfunctions.so root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst/videotestsrc/.libs/libgstvideotestsrc.so root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst/rawparse/.libs/libgstrawparse.so root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst/pbtypes/.libs/libgstpbtypes.so root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst/encoding/.libs/libgstencoding.so root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst/playback/.libs/libgstplayback.so root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst/videoscale/.libs/libgstvideoscale.so root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst/videorate/.libs/libgstvideorate.so root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst-libs/gst/pbutils/.libs/libgstpbutils-1.0.so.0.1202.0 root@192.168.1.9:/usr/lib
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/gst-libs/gst/video/.libs/libgstvideo-1.0.so.0.1202.0 root@192.168.1.9:/usr/lib
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/ext/theora/.libs/libgsttheora.so  root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/ext/ogg/.libs/libgstogg.so  root@192.168.1.9:/usr/lib/gstreamer-1.0/
    -scp tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/build/ext/pango/.libs/libgstpango.so  root@192.168.1.9:/usr/lib/gstreamer-1.0/
    Kishan Patel.
  • Hello Margarita,
    Now, i have one doubt about to use RGB3/BGR3. To use RGB/BGR, i have add file "video-format.c" as below:
    "case GST_MAKE_FOURCC ('R', 'G', 'B', '\0'):
    return GST_VIDEO_FORMAT_BGR;"
    Here i can see format options as (GST_VIDEO_FORMAT_RGBx, GST_VIDEO_FORMAT_BGRx). So, would i have add lines as below to use RGB3(RGB24)/BGR3(BGR24):
    "case GST_MAKE_FOURCC ('R', 'G', 'B', '3'):
    return GST_VIDEO_FORMAT_RGBx;
    case GST_MAKE_FOURCC ('B', 'G', 'R', '3'):
    return GST_VIDEO_FORMAT_BGRx;"
    Kishan Patel.
  • FILE_PATH:
    tisdk/build/arago-tmp-external-linaro-toolchain/work/armv7ahf-neon-linux-gnueabi/gstreamer1.0/1.12.2-r0/gstreamer-1.12.2/gst/gstquery.c
    Function_name(With Debug Modification):
    void
    gst_query_parse_caps_result (GstQuery * query, GstCaps ** caps)
      GstStructure *structure;
      g_return_if_fail (GST_QUERY_TYPE (query) == GST_QUERY_CAPS);
      g_return_if_fail (caps != NULL);
      structure = GST_QUERY_STRUCTURE (query);
            printf("\n\ngstquery.c:structure:\n%s\n\n",gst_structure_to_string(structure));
      *caps = g_value_get_boxed (gst_structure_id_get_value (structure,
              GST_QUARK (CAPS)));
    Pipeline:
    gst-launch-1.0 -v rtspsrc location=rtsp://888888:888888@192.168.1.6:554 ! rtph264depay ! h264parse ! ducatih264dec ! vpe ! 'video/x-raw, format=(string)YUY2, width=(int)640, height=(int)480' ! waylandsink
    Debug_Issue:
    GstQueryCaps, filter=(GstCaps)"video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)YUYV\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)BGR3\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)RGB3\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)BGR\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)YUY2\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]", caps=(GstCaps)"video/x-raw\,\ format\=\(string\)YUY2\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]";
    Comments:
    -In last of debug print, we can see that caps=(GstCaps)"video/x-raw\,\ format\=\(string\)YUY2\,\ width\=\(int\)640\,\ height\=\(int\)480\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]";
    Pipeline:
    gst-launch-1.0 -v rtspsrc location=rtsp://888888:888888@192.168.1.6:554 ! rtph264depay ! h264parse ! ducatih264dec ! vpe ! 'video/x-raw, format=(string)RGB, width=(int)640, height=(int)480' ! waylandsink
    Debug_Issue:
    GstQueryCaps, filter=(GstCaps)"video/x-raw\,\ format\=\(string\)NV12\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)YUYV\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)BGR3\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)RGB3\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)BGR\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)RGB\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]\;\ video/x-raw\,\ format\=\(string\)YUY2\,\ width\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ height\=\(int\)\[\ 1\,\ 2147483647\ \]\,\ framerate\=\(fraction\)\[\ 0/1\,\ 2147483647/1\ \]", caps=(GstCaps)EMPTY;
    Comments:
    -In last of debug print, we can see that caps=(GstCaps)EMPTY;
    Hello Margarita,
               I am attaching one file which can provide details of current issue with including debug_print, file_path, Modified function's definition, all i have mention in this file.
    Please, check this file and if you can know what should i add to solve this issue,Please tell me.
  • Hello Kishan,
    Please use this pipeline with this caps:
    gst-launch-1.0 -v videotestsrc ! video/x-raw, format=NV12, width=1280, height=720 ! vpe ! 'video/x-raw, format=(string)GBR, width=(int)640, height=(int)480' ! waylandsink
    the log that you shared does not work for me.
    Please verify that you have added gbr correctly to the waylandsink by using this pipeline:
    gst-launch-1.0 -v videotestsrc ! video/x-raw, format=NV12, width=1280, height=720 ! videoconvert ! 'video/x-raw, format=(string)BGR, width=(int)640, height=(int)480' ! waylandsink
    Please use the default armv7ahf-neon-linux-gnueabi/gstreamer1.0-plugins-base/1.12.2-r0/gst-plugins-base-1.12.2/gst-libs/gst/video/video-format.c file.
    BR
    Margarita
  • Hello Margarita,
    I have tested above pipelines. But it could not work and got output log as below:
    1).WARNING: erroneous pipeline: could not link vpe0 to waylandsink0, neither element can handle caps video/x-raw, format=(string)GBR, width=(int)640, height=(int)480
    2).WARNING: erroneous pipeline: could not link videoconvert0 to waylandsink0, videoconvert0 can't handle caps video/x-raw, format=(string)BGR, width=(int)640, height=(int)480
    Kishan Patel.
    I am sorry I was OoO.
    I am sorry it is normal this gst-launch-1.0 -v videotestsrc ! video/x-raw, format=NV12, width=1280, height=720 ! videoconvert ! 'video/x-raw, format=(string)BGR, width=(int)640, height=(int)480' ! waylandsink
     to fails with this error since the resolution is different on the videoconvert input and output. You must add videoscale or change the resolution to be the same like this:
    gst-launch-1.0 -v videotestsrc ! video/x-raw, format=NV12, width=1280, height=720 ! videoconvert ! 'video/x-raw, format=(string)BGR, width=(int)1280, height=(int)720' ! fakesink
    Please try to replace waylandsink with fakesink
    If this is working, please recheck the changes what you have made for waylandsink.
    Please use default video-format.c not the file with your changes.
    BR
    Margarita
  • Hello Margarita,
    I have checked above pipeline with fakesink, i dont get any error for this but waylandsink is not working for this pipelines.
    Please, check below pipelines, its working fine.
    1)gst-launch-1.0 videotestsrc ! video/x-raw, format=BGRx ! waylandsink
    2)gst-launch-1.0 videotestsrc ! video/x-raw, format=BGRA ! waylandsink
    3)gst-launch-1.0 videotestsrc ! video/x-raw, format=RGB16 ! waylandsink
    Means, waylandsink working with these formats. But we can not use it with VPE. Right?(VPE support RGB24/BGR24)
    And we have tested VPE with filesink, and its working properly.
    I am revising these all things, because i have doubt is that is waylandsink support format which we have added(GST_VIDEO_FORMAT_RGB).
    Kishan Patel.
    Kishan try to open this file in opencv. Resolution is 640x480.
    Remove txt at the end.
    1.rgb.txt
    BR
    Margarita
  • Hello Margarita,
    I got output as below:
    [IMGUTILS @ 0x7ffe6f738640] Picture size 0x0 is invalid
    (app:5465): GLib-GObject-CRITICAL **: g_object_set: assertion 'G_IS_OBJECT (object)' failed
    Kishan Patel.
