Part Number: DRA74
Tool/software: Linux
Hello Team,
We use custom h/w and software based on DRA746 and SDK 3.02.00.03.
We are facing issue with trick mode for couple of files. Normal playback is fine, but trick mode is failing.
I have tried with gst-play as well and trick mode hanging with this as well.
gst-play-1.0 --videosink=waylandsink <file path>.
Use ARROW LEFT/RIGHT for Seek back/forward.
Sharing the file through portal.
One more query related to video hand issues:
As we have multiple video hang issues. Upon further debugging, it is found that hang is happening in gst_buffer_pool_acquire_buffer in hardware video decoder plugin. We observed that even if normal playback is done, the video hangs after few seconds at the same function “gst_buffer_pool_acquire_buffer” inside hardware video decoder.
Please provide your inputs for this as well.
Ikshwaku
