Part Number: TDA2PXEVM
Tool/software: Linux
I'm terence from China. The vision SDK 03 05 that I was using had a system crash, when I executed reboot command. The attachment is the log file,could you help us to have a look.
Thanks!
terence Xia
Thanks!
terence Xia
Hi Shravan,
1.My current development environment refers to the VisionSDK_Linux_UserGuide.pdf. The attachment is the com_2018-11-24_13-47-14.log file of system startup.
2.I'm sorry, but I don't quite understand how to operate,and how to select "z: Exit = AMD SHUTDOWN Remote CPUs". Is there any detailed steps?
Thank you for your sincere reply.
Terence Xia
[BEGIN] 2018/11/24 13:47:19
dra7xx-evm login:
U-Boot 2016.05 (Nov 21 2018 - 19:16:57 -0800)
CPU : DRA762-GP ES1.0
Model: TI DRA762 EVM
Board: DRA74x EVM REV
DRAM: 512 MiB
MMC: mmc@4809c000: fail to find sdr104 mode FDT_ERR_NOTFOUND
no pinctrl for sdr104
mmc@4809c000: fail to find ddr50 mode FDT_ERR_NOTFOUND
no pinctrl for ddr50
mmc@4809c000: fail to find sdr50 mode FDT_ERR_NOTFOUND
no pinctrl for sdr50
mmc@4809c000: fail to find sdr25 mode FDT_ERR_NOTFOUND
no pinctrl for sdr25
mmc@4809c000: fail to find sdr12 mode FDT_ERR_NOTFOUND
no pinctrl for sdr12
OMAP SD/MMC: 0, OMAP SD/MMC: 1
*** Warning - MMC init failed, using default environment
Warning: fastboot.board_rev: unknown board revision
ERROR: invalid mmc device
at arch/arm/cpu/armv7/omap-common/utils.c:193/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI: SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net: Could not get PHY for ethernet@48484000: addr 2
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot: 0
## Error: "board_findfdt" not defined
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
165 bytes read in 4 ms (40 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
3558264 bytes read in 1265 ms (2.7 MiB/s)
108085 bytes read in 77 ms (1.3 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x364b78 ]
Loading Device Tree to 8ffe2000, end 8ffff634 ... OK
Starting kernel ...
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.84 (root@ubuntu) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Wed Nov 21 19:30:38 PST 2018
[ 0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=10c5387d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[ 0.000000] Machine model: TI DRA762 EVM
[ 0.000000] Reserved memory: created DMA memory pool at 0x40300000, size 3 MiB
[ 0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: regions without no-map are not yet supported
[ 0.000000] Reserved memory: created CMA memory pool at 0x96000000, size 32 MiB
[ 0.000000] Reserved memory: initialized node ipu2_cma@96000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x98000000, size 16 MiB
[ 0.000000] Reserved memory: initialized node dsp1_cma@98000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x99000000, size 16 MiB
[ 0.000000] Reserved memory: initialized node dsp2_cma@99000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created CMA memory pool at 0x9a000000, size 16 MiB
[ 0.000000] Reserved memory: initialized node ipu1_cma@9a000000, compatible id shared-dma-pool
[ 0.000000] Reserved memory: created DMA memory pool at 0x9e000000, size 16 MiB
[ 0.000000] Reserved memory: initialized node cmem@9e000000, compatible id shared-dma-pool
[ 0.000000] cma: Reserved 24 MiB at 0x9c800000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] OMAP4: Map 0x9fe00000 to fe600000 for dram barrier
[ 0.000000] DRA762 ES1.0
[ 0.000000] PERCPU: Embedded 11 pages/cpu @df5c9000 s14912 r8192 d21952 u45056
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 124288
[ 0.000000] Kernel command line: console=ttyS9,115200n8 vram=16M root=PARTUUID=7486ae4d-02 rw rootwait ip=none mem=512M
[ 0.000000] PID hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000000] Dentry cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Inode-cache hash table entries: 32768 (order: 5, 131072 bytes)
[ 0.000000] Memory: 198344K/501760K available (6663K kernel code, 319K rwdata, 2392K rodata, 332K init, 286K bss, 196920K reserved, 106496K cma-reserved, 0K highmem)
[ 0.000000] Virtual kernel memory layout:
[ 0.000000] vector : 0xffff0000 - 0xffff1000 ( 4 kB)
[ 0.000000] fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
[ 0.000000] vmalloc : 0xe0800000 - 0xff800000 ( 496 MB)
[ 0.000000] lowmem : 0xc0000000 - 0xe0000000 ( 512 MB)
[ 0.000000] pkmap : 0xbfe00000 - 0xc0000000 ( 2 MB)
[ 0.000000] modules : 0xbf000000 - 0xbfe00000 ( 14 MB)
[ 0.000000] .text : 0xc0008000 - 0xc08e000c (9057 kB)
[ 0.000000] .init : 0xc08e1000 - 0xc0934000 ( 332 kB)
[ 0.000000] .data : 0xc0934000 - 0xc0983e20 ( 320 kB)
[ 0.000000] .bss : 0xc0985000 - 0xc09cc980 ( 287 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[ 0.000000] OMAP clockevent source: timer1 at 32786 Hz
[ 0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[ 0.000005] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[ 0.000016] Switching to timer-based delay loop, resolution 162ns
[ 0.000337] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[ 0.000345] OMAP clocksource: 32k_counter at 32768 Hz
[ 0.000807] Console: colour dummy device 80x30
[ 0.000827] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[ 0.000841] pid_max: default: 32768 minimum: 301
[ 0.000937] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.000947] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes)
[ 0.001486] Initializing cgroup subsys io
[ 0.001503] Initializing cgroup subsys memory
[ 0.001527] Initializing cgroup subsys devices
[ 0.001540] Initializing cgroup subsys freezer
[ 0.001551] Initializing cgroup subsys perf_event
[ 0.001562] Initializing cgroup subsys pids
[ 0.001586] CPU: Testing write buffer coherency: ok
[ 0.001789] /cpus/cpu@0 missing clock-frequency property
[ 0.001806] /cpus/cpu@1 missing clock-frequency property
[ 0.001816] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.001862] Setting up static identity map for 0x80008340 - 0x800083a0
[ 0.080084] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.080152] Brought up 2 CPUs
[ 0.080165] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[ 0.080172] CPU: All CPU(s) started in HYP mode.
[ 0.080177] CPU: Virtualization extensions available.
[ 0.081216] devtmpfs: initialized
[ 0.110632] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[ 0.111587] omap_hwmod: l3_main_2 using broken dt data from ocp
[ 0.227049] omap_hwmod: dcan1: _wait_target_disable failed
[ 0.323845] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.323868] futex hash table entries: 512 (order: 3, 32768 bytes)
[ 0.326006] pinctrl core: initialized pinctrl subsystem
[ 0.326859] NET: Registered protocol family 16
[ 0.327834] DMA: preallocated 256 KiB pool for atomic coherent allocations
[ 0.350195] cpuidle: using governor ladder
[ 0.380220] cpuidle: using governor menu
[ 0.388874] OMAP GPIO hardware version 0.1
[ 0.393051] GPIO line 161 (radio_rst) hogged as output/low
[ 0.395462] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[ 0.420276] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.420287] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.420778] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[ 0.420788] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[ 0.421268] OMAP DMA hardware revision 0.0
[ 0.461560] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[ 0.462721] edma 43300000.edma: memcpy is disabled
[ 0.467548] edma 43300000.edma: TI EDMA DMA engine driver
[ 0.472425] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[ 0.472600] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[ 0.472770] omap-iommu 58882000.mmu: 58882000.mmu registered
[ 0.472927] omap-iommu 55082000.mmu: 55082000.mmu registered
[ 0.473203] omap-iommu 41501000.mmu: 41501000.mmu registered
[ 0.473389] omap-iommu 41502000.mmu: 41502000.mmu registered
[ 0.476433] palmas 0-0058: IRQ missing: skipping irq request
[ 0.490681] palmas 0-0058: Muxing GPIO 51, PWM 0, LED 2
[ 0.541202] irq: no irq domain found for /ocp/i2c@48070000/tps65917@58 !
[ 0.541753] pcf857x: probe of 0-0020 failed with error -121
[ 0.542008] pcf857x: probe of 0-0021 failed with error -121
[ 0.542235] pcf857x: probe of 0-0026 failed with error -121
[ 0.542395] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[ 0.542803] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[ 0.560522] pcf857x: probe of 3-0021 failed with error -121
[ 0.560561] omap_i2c 4807a000.i2c: bus 3 rev0.12 at 400 kHz
[ 0.560758] media: Linux media interface: v0.10
[ 0.560809] Linux video capture interface: v2.00
[ 0.560848] pps_core: LinuxPPS API ver. 1 registered
[ 0.560855] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.560877] PTP clock support registered
[ 0.560921] EDAC MC: Ver: 3.0.0
[ 0.561688] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[ 0.561988] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[ 0.562333] Advanced Linux Sound Architecture Driver Initialized.
[ 0.563172] clocksource: Switched to clocksource arch_sys_counter
[ 0.573564] NET: Registered protocol family 2
[ 0.574061] TCP established hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.574102] TCP bind hash table entries: 4096 (order: 3, 32768 bytes)
[ 0.574168] TCP: Hash tables configured (established 4096 bind 4096)
[ 0.574206] UDP hash table entries: 256 (order: 1, 8192 bytes)
[ 0.574226] UDP-Lite hash table entries: 256 (order: 1, 8192 bytes)
[ 0.574415] NET: Registered protocol family 1
[ 0.574679] RPC: Registered named UNIX socket transport module.
[ 0.574688] RPC: Registered udp transport module.
[ 0.574694] RPC: Registered tcp transport module.
[ 0.574701] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.575689] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[ 0.584653] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.585287] NFS: Registering the id_resolver key type
[ 0.585315] Key type id_resolver registered
[ 0.585323] Key type id_legacy registered
[ 0.585391] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.586798] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[ 0.586813] io scheduler noop registered
[ 0.586824] io scheduler deadline registered
[ 0.586855] io scheduler cfq registered (default)
[ 0.589246] vsys_5v0: supplied by vsys_12v0
[ 0.589295] ldo3: supplied by vsys_5v0
[ 0.592963] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[ 0.596271] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[ 0.596283] No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[ 0.596316] IO 0x20003000..0x20012fff -> 0x00000000
[ 0.596337] MEM 0x20013000..0x2fffffff -> 0x20013000
[ 0.626056] dra7-pcie 51000000.pcie_rc: link is not up
[ 0.626220] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[ 0.626233] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 0.626244] pci_bus 0000:00: root bus resource [io 0x0000-0xffff]
[ 0.626253] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[ 0.626663] PCI: bus0: Fast back to back transfers disabled
[ 0.626781] PCI: bus1: Fast back to back transfers enabled
[ 0.626864] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[ 0.626878] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[ 0.626891] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 0.627118] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[ 0.687400] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[ 0.690789] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 301, base_baud = 3000000) is a 8250
[ 0.691658] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 302, base_baud = 3000000) is a 8250
[ 0.692509] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 303, base_baud = 3000000) is a 8250
[ 0.693344] console [ttyS9] disabled
[ 0.693393] 4ae2b000.serial: ttyS9 at MMIO 0x4ae2b000 (irq = 304, base_baud = 3000000) is a 8250
[ 1.734025] console [ttyS9] enabled
[ 1.738734] [drm] Initialized drm 1.1.0 20060810
[ 1.744263] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[ 1.750906] [drm] No driver support for vblank timestamp query.
[ 1.757068] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
[ 1.770118] loop: module loaded
[ 1.776056] vmemexp device MAJOR num = 245
[ 1.780184] vmemexp class registered
[ 1.783920] /dev/vmemexp device registered
[ 1.788035] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[ 1.796308] m25p80 spi32766.0: unrecognized JEDEC id bytes: 00, 0, 0
[ 1.804016] libphy: Fixed MDIO Bus: probed
[ 1.853203] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[ 1.859327] libphy: 48485000.mdio: probed
[ 1.866789] davinci_mdio 48485000.mdio: phy[3]: device 48485000.mdio:03, driver RTL9000A Gigabit Ethernet
[ 1.877063] cpsw 48484000.ethernet: Detected MACID = f4:84:4c:14:9b:7e
[ 1.883758] cpsw 48484000.ethernet: cpts: overflow check period 800
[ 1.890702] cpsw 48484000.ethernet: cpsw: Detected MACID = f4:84:4c:14:9b:7f
[ 1.899376] mousedev: PS/2 mouse device common for all mice
[ 1.905624] i2c /dev entries driver
[ 1.914369] omap_hsmmc 4809c000.mmc: Got CD GPIO
[ 1.919205] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr104 mode
[ 1.925712] omap_hsmmc 4809c000.mmc: no pinctrl state for ddr50 mode
[ 1.932095] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr50 mode
[ 1.938496] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr25 mode
[ 1.944899] omap_hsmmc 4809c000.mmc: no pinctrl state for sdr12 mode
[ 1.951536] vsys_3v3: supplied by vsys_12v0
[ 1.955805] vio_3v3: supplied by vsys_3v3
[ 1.959864] vio_3v3_sd: supplied by vio_3v3
[ 1.964320] ldo4: supplied by vsys_5v0
[ 2.013617] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[ 2.020003] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[ 2.033494] smps5: supplied by vsys_3v3
[ 2.037565] vio_1v8: supplied by smps5
[ 2.074046] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.085179] hwspinlock_user gatemp: requested 20 hwspinlocks
[ 2.092090] aic_dvdd: supplied by vio_3v3
[ 2.097389] davinci-mcasp 48464000.mcasp: DAI is shared
[ 2.103501] davinci-mcasp 48474000.mcasp: DAI is shared
[ 2.109996] NET: Registered protocol family 10
[ 2.125330] sit: IPv6 over IPv4 tunneling driver
[ 2.130523] NET: Registered protocol family 17
[ 2.135249] Key type dns_resolver registered
[ 2.139647] omap_voltage_late_init: Voltage driver support not added
[ 2.146533] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.152742] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.159035] buck10: supplied by vsys_3v3
[ 2.163598] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[ 2.169807] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[ 2.177174] Power Management for TI OMAP4+ devices.
[ 2.182261] Registering SWP/SWPB emulation handler
[ 2.188384] dmm 4e000000.dmm: workaround for errata i878 in use
[ 2.195777] dmm 4e000000.dmm: initialized all PAT entries
[ 2.202184] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
[ 2.210249] asoc-simple-card sound0: tlv320aic3x-hifi <-> 48468000.mcasp mapping ok
[ 2.220776] hctosys: unable to open rtc device (rtc0)
[ 2.228853] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.237050] mmc0: new SDHC card at address 0001
[ 2.242052] aic_dvdd: disabling
[ 2.245451] ALSA device list:
[ 2.248432] #0: DRA7xx-EVM
[ 2.252122] mmcblk0: mmc0:0001 SD8GB 7.28 GiB
[ 2.257885] mmcblk0: p1 p2
[ 2.262062] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[ 2.271033] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[ 2.327701] mmc1: MAN_BKOPS_EN bit is not set
[ 2.339659] mmc1: mmc_select_hs200 failed, error -74
[ 2.344670] : switch to mmc1 failed
[ 2.349665] mmc1: new MMC card at address 0001
[ 2.354629] mmcblk1: mmc1:0001 DG4008 7.28 GiB
[ 2.360236] mmcblk1boot0: mmc1:0001 DG4008 partition 1 4.00 MiB
[ 2.366433] mmcblk1boot1: mmc1:0001 DG4008 partition 2 4.00 MiB
[ 2.606869] EXT4-fs (mmcblk0p2): recovery complete
[ 2.617962] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.626168] VFS: Mounted root (ext4 filesystem) on device 179:2.
[ 2.636851] devtmpfs: mounted
[ 2.640038] Freeing unused kernel memory: 332K
[ 2.644522] This architecture does not have kernel memory protection.
[ 3.013684] systemd[1]: System time before build time, advancing clock.
[ 3.102755] random: systemd: uninitialized urandom read (16 bytes read, 15 bits of entropy available)
[ 3.115926] random: systemd: uninitialized urandom read (16 bytes read, 15 bits of entropy available)
[ 3.133579] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[ 3.152162] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.12!
[ 3.174627] systemd[1]: Set hostname to <dra7xx-evm>.
[ 3.240575] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 16 bits of entropy available)
[ 3.292806] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 3.302003] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 3.303881] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[ 3.322968] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
[ 3.454345] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 3.463902] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 3.474063] random: systemd: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[ 4.019898] systemd[1]: dbus.socket: Found ordering cycle on dbus.socket/start
[ 4.027200] systemd[1]: dbus.socket: Found dependency on sysinit.target/start
[ 4.034453] systemd[1]: dbus.socket: Found dependency on alignment.service/start
[ 4.041891] systemd[1]: dbus.socket: Found dependency on basic.target/start
[ 4.048937] systemd[1]: dbus.socket: Found dependency on sockets.target/start
[ 4.056131] systemd[1]: dbus.socket: Found dependency on dbus.socket/start
[ 4.063043] systemd[1]: dbus.socket: Breaking ordering cycle by deleting job alignment.service/start
[ 4.072240] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with dbus.socket/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[ 4.105472] systemd[1]: Reached target Swap.
[ OK ] Reached target Swap.
[ 4.123426] systemd[1]: Listening on udev Control Socket.
[ OK ] Listening on udev Control Socket.
[ 4.143385] systemd[1]: Listening on Syslog Socket.
[ OK ] Listening on Syslog Socket.
[ 4.163434] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ OK ] Listening on /dev/initctl Compatibility Named Pipe.
[ 4.193409] systemd[1]: Listening on Journal Socket.
[ OK ] Listening on Journal Socket.
[ 4.213436] systemd[1]: Listening on Journal Socket (/dev/log).
[ OK ] Listening on Journal Socket (/dev/log).
[ 4.233322] systemd[1]: Reached target Remote File Systems.
[ OK ] Reached target Remote File Systems.
[ 4.270494] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ OK ] Started Forward Password Requests to Wall Directory Watch.
[ 4.303529] systemd[1]: Listening on Network Service Netlink Socket.
[ OK ] Listening on Network Service Netlink Socket.
[ 4.333385] systemd[1]: Listening on udev Kernel Socket.
[ OK ] Listening on udev Kernel Socket.
[ 4.353521] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ OK ] Started Dispatch Password Requests to Console Directory Watch.
[ 4.383309] systemd[1]: Reached target Paths.
[ OK ] Reached target Paths.
[ 4.407461] systemd[1]: Created slice User and Session Slice.
[ OK ] Created slice User and Session Slice.
[ 4.434010] systemd[1]: Created slice System Slice.
[ OK ] Created slice System Slice.
[ 4.483601] systemd[1]: Starting Journal Service...
[ 4.505857] systemd[1]: Mounting POSIX Message Queue File System...
[ 4.537874] systemd[1]: Starting Load Kernel Modules...
[ 4.564192] systemd[1]: Created slice system-getty.slice.
[ OK ] Created slice system-getty.slice.
[ 4.613507] systemd[1]: Mounting Debug File System...
[ 4.635851] systemd[1]: Starting Remount Root and Kernel File Systems...
[ 4.664405] systemd[1]: Created slice system-serial\x2dgetty.slice.
[ 4.665534] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ OK ] Created slice system-serial\x2dgetty.slice.
[ 4.695863] systemd[1]: Starting Setup Virtual Console...
[ 4.713355] systemd[1]: Reached target Slices.
[ OK ] Reached target Slices.
[ 4.736356] systemd[1]: Starting Create list of required static device nodes for the current kernel...
Starting Create list of required st... nodes for the current kernel...
[ 4.766915] systemd[1]: Mounting Temporary Directory...
[ 4.801158] systemd[1]: Mounted POSIX Message Queue File System.
[ OK ] Mounted POSIX Message Queue File System.
[ 4.823452] systemd[1]: Mounted Debug File System.
[ OK ] Mounted Debug File System.
[ 4.843379] systemd[1]: Mounted Temporary Directory.
[ OK ] Mounted Temporary Directory.
[ 4.863592] systemd[1]: Started Journal Service.
[ OK ] Started Journal Service.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[ OK ] Started Remount Root and Kernel File Systems.
[ OK ] Started Setup Virtual Console.
[ OK ] Started Create list of required sta...ce nodes for the current kernel.
Starting Create Static Device Nodes in /dev...
Starting udev Coldplug all Devices...
Starting Apply Kernel Variables...
Starting Flush Journal to Persistent Storage...
[ OK ] Started Create Static Device Nodes in /dev.
[ OK ] Started Apply Kernel Variables.
[ 5.577513] systemd-journald[87]: Received request to flush runtime journal from PID 1
[ OK ] Started Flush Journal to Persistent Storage.
[ OK ] Reached target Local File Systems (Pre).
Mounting /media/ram...
Mounting /var/volatile...
Starting udev Kernel Device Manager...
[ OK ] Mounted /var/volatile.
[ OK ] Mounted /media/ram.
[ OK ] Started udev Kernel Device Manager.
Starting Load/Save Random Seed...
[ OK ] Reached target Local File Systems.
Starting Create Volatile Files and Directories...
[ OK ] Started Load/Save Random Seed.
[ OK ] Started Create Volatile Files and Directories.
[ 6.252709] omap-rproc 58820000.ipu: assigned reserved memory node ipu1_cma@9a000000
[ 6.264331] remoteproc0: 58820000.ipu is available
[ 6.269237] remoteproc0: Note: remoteproc is still under development and considered experimental.
[ OK ] Started udev Coldplug all Devices.
[ 6.293262] remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.314415] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@96000000
[ 6.334353] remoteproc1: 55020000.ipu is available
[ 6.339262] remoteproc1: Note: remoteproc is still under development and considered experimental.
[ 6.385407] remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.396183] remoteproc0: registered virtio0 (type 7)
[ 6.426025] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@98000000
[ 6.464959] remoteproc2: 40800000.dsp is available
[ 6.475481] remoteproc2: Note: remoteproc is still under development and considered experimental.
[ 6.515932] remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[ 6.540646] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@99000000
Starting Update UTMP about System Boot/Shutdown...
Starting Network Time Synchronization...
[ 6.599868] remoteproc3: 41000000.dsp is available
[ 6.614799] remoteproc3: Note: remoteproc is still under development and considered experimental.
[[ 6.658431] remoteproc3: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
OK ] Found device /dev/ttyS0.
[ OK ] Started Update UTMP about System Boot/Shutdown.
[ OK ] Started Network Time Synchronization.
[ OK ] Reached target System Time Synchronized.
Starting Synchronize System and HW clocks...
[ OK ] Found device /dev/ttyS9.
[ 7.857421] remoteproc2: registered virtio1 (type 7)
[ 8.286347] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[ 8.305633] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[ 8.314252] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[FAILED] Failed to start Synchronize System and HW clocks.
See 'systemctl status sync-clocks.service' for details.
[ 8.854942] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[ 8.967924] remoteproc1: registered virtio2 (type 7)
[ OK ] Reached target Sound Card.
[ OK ] Reached target System Initialization.
[ OK ] Started Daily Cleanup of Temporary Directories.
[ OK ] Reached target Timers.
[ OK ] Listening on D-Bus System Message Bus Socket.
[ OK ] Reached target Sockets.
[ OK ] Reached target Basic System.
Starting Login Service...
Starting Permit User Sessions...
[ 9.217530] SCSI subsystem initialized
[ 9.297829] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
[ 9.316687] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
[ 9.729290] remoteproc3: registered virtio3 (type 7)
[ 9.852259] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[ OK ] Started System Logging Service.
Starting rc.pvr.service...
[ 9.878496] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[ 9.889813] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[ OK ] Started Kernel Logging Service.
[ 9.929375] scsi host0: ahci
Starting Save/Restore Sound Card State...
[ 9.933000] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 342
[ OK ] Started D-Bus System Message Bus.
[ 10.186340] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
Starting Network Service...
[ OK ] Started Permit User Sessions.
[ OK ] Started Save/Restore Sound Card State.
[ 10.353278] ata1: SATA link down (SStatus 0 SControl 300)
[ 10.452866] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 10.514611] net eth1: initializing cpsw version 1.15 (0)
[ 10.542653] net eth0: initialized cpsw ale version 1.4
[ 10.565925] net eth0: ALE Table size 1024
[ OK ] Started Network Service.
[ OK ] Started rc.pvr.service.
[ 10.704664] remoteproc0: powering up 58820000.ipu
[ 10.712913] remoteproc0: Booting fw image dra7-ipu1-fw.xem4, size 573264
[ 10.731190] omap-iommu 58882000.mmu: 58882000.mmu: version 2.1
[ 10.744867] net eth1: phy found : id is : 0x1ccb00
[ 10.750782] remoteproc0: remote processor 58820000.ipu is now up
[ 10.758044] virtio_rpmsg_bus virtio0: rpmsg host is online
[ 10.766203] remoteproc2: powering up 40800000.dsp
[ 10.774757] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[ 10.778821] remoteproc2: Booting fw image dra7-dsp1-fw.xe66, size 5583951
[ 10.785935] omap_hwmod: mmu0_dsp1: _wait_target_disable failed
[ 10.785970] omap-iommu 40d01000.mmu: 40d01000.mmu: version 3.0
[ 10.786097] omap-iommu 40d02000.mmu: 40d02000.mmu: version 3.0
[ 10.819847] remoteproc2: remote processor 40800000.dsp is now up
[ 10.827281] virtio_rpmsg_bus virtio1: rpmsg host is online
[ 10.836800] remoteproc1: powering up 55020000.ipu
[ 10.856602] net eth0: initializing cpsw version 1.15 (0)
[ 10.864264] remoteproc1: Booting fw image dra7-ipu2-fw.xem4, size 9388276
[ 10.868149] libphy: PHY 48485000.mdio:01 not found
[ 10.868159] net eth0: phy "48485000.mdio:01" not found on slave 0, err -19
[ 10.893200] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 10.899529] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[ 10.984196] remoteproc1: remote processor 55020000.ipu is now up
[ 11.003704] virtio_rpmsg_bus virtio2: rpmsg host is online
[ 11.011264] remoteproc3: powering up 41000000.dsp
[ 11.029992] remoteproc3: Booting fw image dra7-dsp2-fw.xe66, size 5583951
[ 11.060328] omap_hwmod: mmu0_dsp2: _wait_target_disable failed
[ 11.066222] omap-iommu 41501000.mmu: 41501000.mmu: version 3.0
[ 11.072161] omap-iommu 41502000.mmu: 41502000.mmu: version 3.0
[ 11.101128] remoteproc3: remote processor 41000000.dsp is now up
[ 11.108411] virtio_rpmsg_bus virtio2: creating channel rpmsg-proto addr 0x50
[ 11.118024] virtio_rpmsg_bus virtio3: rpmsg host is online
[ 11.133262] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
[ 11.140697] virtio_rpmsg_bus virtio1: creating channel rpmsg-proto addr 0x50
[ 11.164172] virtio_rpmsg_bus virtio3: creating channel rpmsg-proto addr 0x50
[ 11.182872] NET: Registered protocol family 41
[ OK ] Started Login Service.
[ OK ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[ 11.684071] usbcore: registered new interface driver usbfs
[ 11.689656] usbcore: registered new interface driver hub
Starting weston.service...
[ 11.703075] usbcore: registered new device driver usb
[ OK ] Reached target Network.
Starting Network Name Resolution...
[ OK ] Started Getty on tty1.
[ OK ] Started Serial Getty on ttyS9.
[ OK ] Started Serial Getty on ttyS0.
[ OK ] Started weston.service.
[ 11.878551] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 11.885652] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 1
[ 11.894014] xhci-hcd xhci-hcd.2.auto: hcc params 0x0220f04c hci version 0x100 quirks 0x00210010
[ 11.903581] xhci-hcd xhci-hcd.2.auto: irq 462, io mem 0x488d0000
[ 11.913765] hub 1-0:1.0: USB hub found
[ 11.917579] hub 1-0:1.0: 1 port detected
[ 11.924251] xhci-hcd xhci-hcd.2.auto: xHCI Host Controller
[ 11.929782] xhci-hcd xhci-hcd.2.auto: new USB bus registered, assigned bus number 2
Starting telnetd.service...
Starting tiipclad-daemon.service...
[ 11.949565] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[ OK ] Started Network Name Resolution.
[ 11.974970] hub 2-0:1.0: USB hub found
[ 11.979017] hub 2-0:1.0: 1 port detected
[ OK ] Started telnetd.service.
[ OK ] Started tiipclad-daemon.service.
Starting ecarxinit.service...
[ OK ] Started ecarxinit.service.
_____ _____ _ _
| _ |___ ___ ___ ___ | _ |___ ___ |_|___ ___| |_
| | _| .'| . | . | | __| _| . | | | -_| _| _|
|__|__|_| |__,|_ |___| |__| |_| |___|_| |___|___|_|
|___| |___|
Arago Project http://arago-project.org dra7xx-evm ttyS9
Arago 2016.12 dra7xx-evm ttyS9
dra7xx-evm login: root
root@dra7xx-evm:~#
root@dra7xx-evm:~# [ 391.043213] random: nonblocking pool is initialized
root@dra7xx-evm:~# reboot
Stopping Load/Save Random Seed...
Stopping User Manager for UID 0...
[ OK ] Stopped Stopping Session c1 of user root.
[ OK ] Stopped Create Static Device Nodes in /dev.
[ OK ] Stopped target Timers.
[ OK ] Stopped Daily Cleanup of Temporary Directories.
Stopping Network Time Synchronization...
Stopping Update UTMP about System Boot/Shutdown...
[ OK ] Stopped target Multi-User System.
Stopping ecarxinit.service...
[ OK ] Stopped target Login Prompts.
Stopping Getty on tty1...
Stopping Serial Getty on ttyS9...
[ 774.93210] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[ 774.934214] ------------[ cut here ]------------
[ 774.934231] WARNING: CPU: 0 PID: 1 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[ 774.934236] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_CFG (Idle): Data Access in Supervisor mode during Functional access
[ 774.934300] Modules linked in: xhci_plat_hcd xhci_hcd usbcore rpmsg_proto dwc3 udc_core virtio_rpmsg_bus bc_example(O) ahci_platform libahci_platform libahci libata omap_des pvrsrvkm(O) scsi_mod omap_rng rng_core omap_aes_driver omap_sham extcon_usb_gpio dwc3_omap extcon omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 774.934309] CPU: 0 PID: 1 Comm: systemd Tainted: G O 4.4.84 #1
[ 774.934312] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 774.934317] Backtrace:
Stopping Serial Getty on ttyS0...[ 774.934333] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 774.934344] r7:c02e0130 r6:200d0193 r5:00000000 r4:c0953590
[ 774.934354] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 774.934363] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 774.934372] r7:c02e0130 r6:00000093 r5:00000009 r4:df067a58
[ 774.934379] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 774.934392] r8:00000017 r7:c0848844 r6:00000000 r5:c0848904 r4:c08489a8
[ 774.934399] [<c0035850>] (warn_slowpath_fmt) from [<c02e0130>] (l3_interrupt_handler+0x25c/0x368)
[ 774.934407] r3:df20ce40 r2:c08489a8
[ 774.934411] r4:80080003
[ 774.934421] [<c02dfed4>] (l3_interrupt_handler) from [<c0082048>] (handle_irq_event_percpu+0xb4/0x160)
[ 774.934434] r10:c098308b r9:df20e240 r8:00000017 r7:00000000 r6:00000000 r5:df20e2a0
[ 774.934438] r4:df21f3c0
[ 774.934447] [<c0081f94>] (handle_irq_event_percpu) from [<c0082134>] (handle_irq_event+0x40/0x64)
[ 774.934459] r10:df0cf288 r9:ffffffe0 r8:df008000 r7:00000000 r6:c093bc84 r5:df20e2a0
[ 774.934463] r4:df20e240
[ 774.934470] [<c00820f4>] (handle_irq_event) from [<c0085478>] (handle_fasteoi_irq+0xc0/0x194)
[ 774.934482] r7:00000000 r6:c093bc84 r5:df20e2a0 r4:df20e240
[ 774.934489] [<c00853b8>] (handle_fasteoi_irq) from [<c0081674>] (generic_handle_irq+0x2c/0x3c)
[ 774.934500] r7:00000000 r6:00000000 r5:00000017 r4:c093140c
[ 774.934508] [<c0081648>] (generic_handle_irq) from [<c008194c>] (__handle_domain_irq+0x64/0xbc)
[ 774.934515] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 774.934527] r9:ffffffe0 r8:fa213000 r7:fa212000 r6:df067c18 r5:fa21200c r4:c09368e4
[ 774.934533] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[ 774.934537] Exception stack(0xdf067c18 to 0xdf067c60)
[ 774.934541] 7c00: dc101760 00000000
[ 774.934549] 7c20: 00002905 dc10176c dc101964 dc101760 c034addc dc101760 c03e9550 ffffffe0
[ 774.934556] 7c40: df0cf288 df067c8c df067c90 df067c68 c0680b30 c06808c4 a00d0013 ffffffff
[ 774.934569] r9:ffffffe0 r8:c03e9550 r7:df067c4c r6:ffffffff r5:a00d0013 r4:c06808c4
[ 774.934578] [<c06808a8>] (klist_dec_and_del) from [<c0680b30>] (klist_next+0x34/0x138)
[ 774.934590] r9:ffffffe0 r8:c03e9550 r7:dc101760 r6:c034addc r5:df067cdc r4:dc101964
[ 774.934597] [<c0680afc>] (klist_next) from [<c03e9894>] (class_dev_iter_next+0x28/0x48)
[ 774.934609] r9:ffffffe0 r8:00000009 r7:00000009 r6:c034addc r5:df067d0c r4:df067cdc
[ 774.934615] [<c03e986c>] (class_dev_iter_next) from [<c03e9cc8>] (class_find_device+0x64/0xc0)
[ 774.934622] r5:df067d0c r4:dc101600
[ 774.934632] [<c03e9c64>] (class_find_device) from [<c034ed88>] (alloc_tty_struct+0x1a4/0x1b4)
[ 774.934642] r6:00000000 r5:00000004 r4:d50e2c00
[ 774.934649] [<c034ebe4>] (alloc_tty_struct) from [<c034edd8>] (tty_init_dev+0x40/0x188)
[ 774.934662] r9:00500001 r8:df066000 r7:c09adedc r6:00000009 r5:dc145a00 r4:00000000
[ 774.934671] [<c034ed98>] (tty_init_dev) from [<c034f448>] (tty_open+0x528/0x6b0)
[ 774.934679] r6:00000001 r5:dc39b240 r4:00000000
[ 774.934688] [<c034ef20>] (tty_open) from [<c0124540>] (chrdev_open+0xac/0x180)
[ 774.934701] r10:df067f5c r9:dc416000 r8:c09bab38 r7:dc39b240 r6:df0cf288 r5:c09bab38
[ 774.934705] r4:c06c4014
[ 774.934714] [<c0124494>] (chrdev_open) from [<c011e55c>] (do_dentry_open+0x1e0/0x300)
[ 774.934725] r8:00000000 r7:df0cf288 r6:c0124494 r5:dc39b248 r4:dc39b240
[ 774.934734] [<c011e37c>] (do_dentry_open) from [<c011f68c>] (vfs_open+0x60/0x88)
[ 774.934747] r9:dc416000 r8:00000000 r7:00000000 r6:df067eb0 r5:dc39b240 r4:df067eb0
[ 774.934754] [<c011f62c>] (vfs_open) from [<c012ce48>] (path_openat+0x17c/0xfb0)
[ 774.934760] r5:00000000 r4:00020101
[ 774.934766] [<c012cccc>] (path_openat) from [<c012ee0c>] (do_filp_open+0x6c/0xd0)
[ 774.934777] r10:00000000 r9:df066000 r8:c000fe24 r7:00000001 r6:df067f5c r5:df067eb0
[ 774.934781] r4:00000025
[ 774.934788] [<c012eda0>] (do_filp_open) from [<c011f9f8>] (do_sys_open+0x11c/0x1e0)
[ 774.934798] r7:fffff000 r6:db899000 r5:ffffff9c r4:00000025
[ 774.934806] [<c011f8dc>] (do_sys_open) from [<c011fadc>] (SyS_open+0x20/0x24)
[ 774.934818] r9:df066000 r8:c000fe24 r7:00000005 r6:00080101 r5:005b3a3c r4:00080101
[ 774.934828] [<c011fabc>] (SyS_open) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
[ 774.934832] ---[ end trace fbd1a70ff56bc929 ]---
[ 775.419163] pgd = c0004000
[END] 2018/11/24 14:02:26
Hi Shravan,
It is confirmed that our colleagues in the team had deleted this menu, because our products do not need this app's menu.I'm sorry that the crash may be caused by this reason.
thank you very much
Terence Xia from China
