Part Number: TDA2PXEVM
Other Parts Discussed in Thread: PGA460
Tool/software: Linux
After reboot,system will shut down every time.I recorded two logs, one is the system has just finished booting, the other is the system had run ten minutes.Could you help to have a look?
Thanks a lot
Terence
[BEGIN] 2019/1/15 14:43:10
root@dra7xx-evm:~# reboot
[ OK ] Stopped Update UTMP about System Runlevel Changes.
[ OK ] Stopped target Timers.
Stopping Update UTMP about System Boot/Shutdown...
[ OK ] Stopped target Sound Card.
Stopping User Manager for UID 0...
Stopping Load/Save Random Seed...
[ OK ] Closed Load/Save RF Kill Switch Status /dev/rfkill Watch.
Stopping Save/Restore Sound Card State...
[ OK ] Stopped target Swap.
[ OK ] Stopped target Multi-User System.
[ OK ] Stopped target Login Prompts.
Stopping System Logging Service...
Stopping Getty on tty1...
[ OK ] Stopped Serial Getty on ttyO0.
Stopping Serial Getty on ttyS0...
[ OK ] Stopped target System Time Synchronized.
[ 63.527497] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[ 63.527500] ------------[ cut here ]------------
[ 63.527544] WARNING: CPU: 0 PID: 816 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[ 63.527550] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_CFG (Idle): Data Access in Supervisor mode during Functional access
[ 63.527610] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore rpmsg_proto dwc3 bc_example(O) virtio_rpmsg_bus udc_core ahci_platform libahci_platform libahci pvrsrvkm(O) libata omap_aes_driver omap_des extcon_usb_gpio scsi_mod omap_sham dwc3_omap extcon omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 63.527620] CPU: 0 PID: 816 Comm: app_apa Tainted: G O 4.4.84 #1
[ 63.527624] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 63.527628] Backtrace:
[ 63.527652] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 63.527661] r7:c02e0130 r6:20060193 r5:00000000 r4:c0953590
[ 63.527671] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 63.527681] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 63.527687] r7:c02e0130 r6:00000093 r5:00000009 r4:d506ddf0
[ 63.527691] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 63.527698] r8:00000017 r7:c0848884 r6:00000000 r5:c0848944 r4:c08489e8
[ 63.527702] [<c0035850>] (warn_slowpath_fmt) from [<c02e0130>] (l3_interrupt_handler+0x25c/0x368)
[ 63.527706] r3:df20ce40 r2:c08489e8
[ 63.527709] r4:80080003
[ 63.527722] [<c02dfed4>] (l3_interrupt_handler) from [<c0082048>] (handle_irq_event_percpu+0xb4/0x160)
[ 63.527730] r10:c098308b r9:df20e240 r8:00000017 r7:00000000 r6:00000000 r5:df20e2a0
[ 63.527732] r4:df21f3c0
[ 63.527738] [<c0081f94>] (handle_irq_event_percpu) from [<c0082134>] (handle_irq_event+0x40/0x64)
[ 63.527745] r10:b6f81000 r9:00000000 r8:df008000 r7:00000000 r6:c093bc84 r5:df20e2a0
[ 63.527748] r4:df20e240
[ 63.527754] [<c00820f4>] (handle_irq_event) from [<c0085478>] (handle_fasteoi_irq+0xc0/0x194)
[ 63.527761] r7:00000000 r6:c093bc84 r5:df20e2a0 r4:df20e240
[ 63.527765] [<c00853b8>] (handle_fasteoi_irq) from [<c0081674>] (generic_handle_irq+0x2c/0x3c)
[ 63.527771] r7:00000000 r6:00000000 r5:00000017 r4:c093140c
[ 63.527775] [<c0081648>] (generic_handle_irq) from [<c008194c>] (__handle_domain_irq+0x64/0xbc)
[ 63.527781] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 63.527788] r9:00000000 r8:fa213000 r7:fa212000 r6:d506dfb0 r5:fa21200c r4:c09368e4
[ 63.527796] [<c00094b0>] (gic_handle_irq) from [<c0014bb4>] (__irq_usr+0x54/0x80)
[ 63.527797] Exception stack(0xd506dfb0 to 0xd506dff8)
[ 63.527801] dfa0: bedc2cd0 00000001 00000002 00000001
[ 63.527806] dfc0: bedc2d08 00000000 00000000 bedc2cc0 00000000 00000000 b6f81000 00000000
[ 63.527810] dfe0: b6e13d78 bedc2cc0 00056deb 00054ac4 20060030 ffffffff
[ 63.527818] r9:00000000 r8:10c5387d r7:10c5387d r6:ffffffff r5:20060030 r4:00054ac4
[ 63.527820] ---[ end trace 000badc7e67b7d36 ]---
[ 63.811681] pgd = c0004000
[END] 2019/1/15 14:43:34
[BEGIN] 2019/1/15 14:49:28
root@dra7xx-evm:/lib/firmware# reboot
Stopping Sessio[ 312.504702] ------------[ cut here ]------------
[ 312.509360] WARNING: CPU: 0 PID: 651 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[ 312.518877] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_CFG (Idle): Data Access in Supervisor mode during Functional access
[ 312.530661] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore rpmsg_proto dwc3 udc_core virtio_rpmsg_bus bc_example(O) ahci_platform libahci_platform pvrsrvkm(O) libahci libata extcon_usb_gpio omap_aes_driver scsi_mod omap_sham dwc3_omap extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 312.561105] CPU: 0 PID: 651 Comm: login Tainted: G O 4.4.84 #1
[ 312.568091] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 312.574204] Backtrace:
[ 312.576668] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 312.584262] r7:c02e0130 r6:20070193 r5:00000000 r4:c0953590
[ 312.589968] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 312.597218] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 312.605336] r7:c02e0130 r6:00000093 r5:00000009 r4:d5143ac8
[ 312.611037] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 312.619766] r8:00000017 r7:c0848884 r6:00000000 r5:c0848944 r4:c08489e8
[ 312.626520] [<c0035850>] (warn_slowpath_fmt) from [<c02e0130>] (l3_interrupt_handler+0x25c/0x368)
[ 312.635423] r3:df20ce40 r2:c08489e8
[ 312.639018] r4:80080003
[ 312.641564] [<c02dfed4>] (l3_interrupt_handler) from [<c0082048>] (handle_irq_event_percpu+0xb4/0x160)
[ 312.650903] r10:c098308b r9:df20e240 r8:00000017 r7:00000000 r6:00000000 r5:df20e2a0
[ 312.658788] r4:df21f3c0
[ 312.661333] [<c0081f94>] (handle_irq_event_percpu) from [<c0082134>] (handle_irq_event+0x40/0x64)
[ 312.670236] r10:00000000 r9:dbb5f180 r8:df008000 r7:00000000 r6:c093bc84 r5:df20e2a0
[ 312.678119] r4:df20e240
[ 312.680664] [<c00820f4>] (handle_irq_event) from [<c0085478>] (handle_fasteoi_irq+0xc0/0x194)
[ 312.689218] r7:00000000 r6:c093bc84 r5:df20e2a0 r4:df20e240
[ 312.694918] [<c00853b8>] (handle_fasteoi_irq) from [<c0081674>] (generic_handle_irq+0x2c/0x3c)
[ 312.703559] r7:00000000 r6:00000000 r5:00000017 r4:c093140c
[ 312.709260] [<c0081648>] (generic_handle_irq) from [<c008194c>] (__handle_domain_irq+0x64/0xbc)
[ 312.717992] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 312.726371] r9:dbb5f180 r8:fa213000 r7:fa212000 r6:d5143c88 r5:fa21200c r4:c09368e4
[ 312.734172] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[ 312.741681] Exception stack(0xd5143c88 to 0xd5143cd0)
[ 312.746748] 3c80: dc0411e0 60070113 dc041180 000002f2 d2c66e40 dc041180
[ 312.754956] 3ca0: dc0411e0 000001cd 60070113 dbb5f180 00000000 d5143ce4 d5143ce8 d5143cd8
[ 312.763163] 3cc0: c0082ad4 c0687aec 60070113 ffffffff
[ 312.768229] r9:dbb5f180 r8:60070113 r7:d5143cbc r6:ffffffff r5:60070113 r4:c0687aec
[ 312.776032] [<c0687ac4>] (_raw_spin_unlock_irqrestore) from [<c0082ad4>] (__free_irq+0x11c/0x2b0)
[ 312.784939] [<c00829b8>] (__free_irq) from [<c0082cfc>] (free_irq+0x44/0x78)
[ 312.792010] r9:00000002 r8:00000000 r7:dbb5f180 r6:000001cd r5:dc041180 r4:00000000
[ 312.799813] [<c0082cb8>] (free_irq) from [<c03f31f0>] (dev_pm_clear_wake_irq+0x6c/0x7c)
[ 312.807844] r7:a0070113 r6:df23e474 r5:df23e410 r4:dbb5f180
[ 312.813546] [<c03f3184>] (dev_pm_clear_wake_irq) from [<c0374018>] (omap_8250_shutdown+0xec/0xf0)
[ 312.822449] r7:00070113 r6:df056088 r5:c09bb880 r4:c09bb880
[ 312.828152] [<c0373f2c>] (omap_8250_shutdown) from [<c036df10>] (serial8250_shutdown+0x1c/0x28)
[ 312.836880] r5:c09bb880 r4:df056000
[ 312.840477] [<c036def4>] (serial8250_shutdown) from [<c0368a24>] (uart_shutdown+0xd4/0x11c)
[ 312.848860] [<c0368950>] (uart_shutdown) from [<c036a814>] (uart_hangup+0x50/0x104)
[ 312.856542] r7:df056064 r6:dbb22200 r5:df056090 r4:df056000
[ 312.862245] [<c036a7c4>] (uart_hangup) from [<c034cb3c>] (__tty_hangup+0x3a4/0x3b4)
[ 312.869927] r9:00000002 r8:00000000 r7:00000001 r6:dbb2235c r5:dbb22200 r4:00000000
[ 312.877730] [<c034c798>] (__tty_hangup) from [<c034d160>] (disassociate_ctty.part.8+0x3c/0x278)
[ 312.886458] r10:d4be9f44 r9:d5097d40 r8:d4bdeff8 r7:d4bdefc0 r6:00000001 r5:dbb22200
[ 312.894343] r4:00000001
[ 312.896886] [<c034d124>] (disassociate_ctty.part.8) from [<c034d3f8>] (disassociate_ctty+0x30/0x34)
[ 312.905964] r9:d5097d40 r8:d4bdeff8 r7:d4bdefc0 r6:00000001 r5:d4944678 r4:d4944200
[ 312.913767] [<c034d3c8>] (disassociate_ctty) from [<c0038880>] (do_exit+0x6e8/0x9b8)
[ 312.921539] [<c0038198>] (do_exit) from [<c0038bd4>] (do_group_exit+0x48/0xc4)
[ 312.928785] r7:d5143edc
[ 312.931328] [<c0038b8c>] (do_group_exit) from [<c0042af8>] (get_signal+0x22c/0x5b0)
[ 312.939010] r7:d5143edc r6:00418004 r5:d5142000 r4:08430000
[ 312.944711] [<c00428cc>] (get_signal) from [<c00131d0>] (do_signal+0xd0/0x414)
[ 312.951957] r10:00000000 r9:d5142000 r8:00000350 r7:b6e9c996 r6:d5143ec8 r5:b6e9c994
[ 312.959843] r4:d5143fb0
[ 312.962387] [<c0013100>] (do_signal) from [<c00136dc>] (do_work_pending+0xa8/0xc0)
[ 312.969982] r10:00000000 r9:d5142000 r8:c000fe24 r7:00000072 r6:d5143fb0 r5:c000fe24
[ 312.977866] r4:d5142000
[ 312.980411] [<c0013634>] (do_work_pending) from [<c000fcb4>] (slow_work_pending+0xc/0x20)
[ 312.988615] r7:00000072 r6:00000350 r5:00000000 r4:000363f0
[ 312.994312] ---[ end trace 38dad09fedf8664c ]---
[ 312.999048] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[ 313.003512] thermal thermal_zone0: failed to read out thermal zone (-5)
[ 313.003542] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[ 313.003544] pgd = dc3b0000
[ 313.003548] [00000000] *pgd=00000000
[ 313.003553] Internal error: : 1406 [#1] PREEMPT SMP ARM
[ 313.003586] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore rpmsg_proto dwc3 udc_core virtio_rpmsg_bus bc_example(O) ahci_platform libahci_platform pvrsrvkm(O) libahci libata extcon_usb_gpio omap_aes_driver scsi_mod omap_sham dwc3_omap extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 313.003591] CPU: 1 PID: 1 Comm: systemd Tainted: G W O 4.4.84 #1
[ 313.003593] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 313.003595] task: df080000 ti: df066000 task.ti: df066000
[ 313.003605] PC is at __percpu_counter_add+0x24/0x118
[ 313.003608] LR is at 0xdf067e28
[ 313.003612] pc : [<c02daa30>] lr : [<df067e28>] psr: 00070013
[ 313.003612] sp : df067e28 ip : df067e58 fp : df067e54
[ 313.003614] r10: 00000001 r9 : dc35b6e0 r8 : df3f2700
[ 313.003616] r7 : 00000001 r6 : 00000001 r5 : c094c0c0 r4 : c09b2800
[ 313.003617] r3 : 00000000 r2 : 00000001 r1 : df066000 r0 : c09b2800
[ 313.003621] Flags: nzcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 313.003624] Control: 10c5387d Table: 9c3b006a DAC: 00000051
[ 313.003626] Process systemd (pid: 1, stack limit = 0xdf066210)
[ 313.003628] Stack: (0xdf067e28 to 0xdf068000)
[ 313.003632] 7e20: 00000001 00000000 c09366f4 c094c0c0 00000001 00000001
[ 313.003637] 7e40: df3f2700 dc35b6e0 df067e84 df067e58 c00fd3f0 c02daa18 00000094 df3f2700
[ 313.003641] 7e60: 00000001 dc35b6f4 b6fab000 dc35b6f0 b6fac000 df3f2700 df067eec df067e88
[ 313.003646] 7e80: c00ff6c8 c00fd3b4 00002000 b6fb0000 00000000 00000000 b6fab000 befff000
[ 313.003650] 7ea0: df067ecc df067eb0 c00fd150 00000001 00000000 00000073 00001000 00000003
[ 313.003654] 7ec0: df067eec 00001000 00000003 00000000 df3f2700 00000001 c09366f4 00000073
[ 313.003658] 7ee0: df067f2c df067ef0 c00ffdf8 c00ff424 000b6fab 00000000 00000000 00000000
[ 313.003662] 7f00: 5b9f7396 df3f2738 00000000 00000022 00000000 00000000 00001000 00000003
[ 313.003666] 7f20: df067f74 df067f30 c00eb978 c00ffad8 00000022 00000000 000b6fab df067f44
[ 313.003670] 7f40: 000000f7 00000000 00000013 00000022 00000000 00001000 00000003 c000fe24
[ 313.003675] 7f60: df066000 00000000 df067fa4 df067f78 c00fe148 c00eb910 00000022 00000000
[ 313.003679] 7f80: 00001000 ffffffff 00000000 00000000 000000c0 c000fe24 00000000 df067fa8
[ 313.003683] 7fa0: c000fc60 c00fe104 ffffffff 00000000 00000000 00001000 00000003 00000022
[ 313.003687] 7fc0: ffffffff 00000000 00000000 000000c0 006581c0 0000002e 0062a208 0062a498
[ 313.003691] 7fe0: 00000000 bed4947c b6ecc477 b6f16ef8 40070030 00000000 00000000 00000000
[ 313.003694] Backtrace:
[ 313.003705] [<c02daa0c>] (__percpu_counter_add) from [<c00fd3f0>] (__vm_enough_memory+0x48/0x168)
[ 313.003713] r9:dc35b6e0 r8:df3f2700 r7:00000001 r6:00000001 r5:c094c0c0 r4:c09366f4
[ 313.003719] [<c00fd3a8>] (__vm_enough_memory) from [<c00ff6c8>] (mmap_region+0x2b0/0x6b4)
[ 313.003725] r8:df3f2700 r7:b6fac000 r6:dc35b6f0 r5:b6fab000 r4:dc35b6f4
[ 313.003730] [<c00ff418>] (mmap_region) from [<c00ffdf8>] (do_mmap+0x32c/0x3ac)
[ 313.003738] r10:00000073 r9:c09366f4 r8:00000001 r7:df3f2700 r6:00000000 r5:00000003
[ 313.003740] r4:00001000
[ 313.003746] [<c00ffacc>] (do_mmap) from [<c00eb978>] (vm_mmap_pgoff+0x74/0xa4)
[ 313.003754] r10:00000003 r9:00001000 r8:00000000 r7:00000000 r6:00000022 r5:00000000
[ 313.003756] r4:df3f2738
[ 313.003761] [<c00eb904>] (vm_mmap_pgoff) from [<c00fe148>] (SyS_mmap_pgoff+0x50/0xc8)
[ 313.003768] r10:00000000 r9:df066000 r8:c000fe24 r7:00000003 r6:00001000 r5:00000000
[ 313.003771] r4:00000022
[ 313.003777] [<c00fe0f8>] (SyS_mmap_pgoff) from [<c000fc60>] (ret_fast_syscall+0x0/0x3c)
[ 313.003784] r8:c000fe24 r7:000000c0 r6:00000000 r5:00000000 r4:ffffffff
[ 313.003788] Code: e3ce1d7f e1a04000 e3c1103f e14b22fc (e591c004)
[ 313.003793] ---[ end trace 38dad09fedf8664d ]---
[ 313.377303] pgd = dbb4c000
[ 313.380015] [00000000] *pgd=00000000
[ 313.383639] ------------[ cut here ]------------
[ 313.388276] WARNING: CPU: 0 PID: 4 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[ 313.397617] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_CFG (Read): Data Access in User mode during Functional access
[ 313.408874] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore rpmsg_proto dwc3 udc_core virtio_rpmsg_bus bc_example(O) ahci_platform libahci_platform pvrsrvkm(O) libahci libata extcon_usb_gpio omap_aes_driver scsi_mod omap_sham dwc3_omap extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 313.439308] CPU: 0 PID: 4 Comm: kworker/0:0 Tainted: G D W O 4.4.84 #1
[ 313.446642] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 313.452760] Backtrace:
[ 313.455222] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 313.462817] r7:c02e0130 r6:200e0193 r5:00000000 r4:c0953590
[ 313.468523] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 313.475771] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 313.483889] r7:c02e0130 r6:00000093 r5:00000009 r4:df093b30
[ 313.489590] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 313.498320] r8:00000017 r7:c0848884 r6:00000002 r5:c0848944 r4:c08489e8
[ 313.505075] [<c0035850>] (warn_slowpath_fmt) from [<c02e0130>] (l3_interrupt_handler+0x25c/0x368)
[ 313.513978] r3:df20ce40 r2:c08489e8
[ 313.517571] r4:80080003
[ 313.520120] [<c02dfed4>] (l3_interrupt_handler) from [<c0082048>] (handle_irq_event_percpu+0xb4/0x160)
[ 313.529458] r10:c098308b r9:df20e240 r8:00000017 r7:00000000 r6:00000000 r5:df20e2a0
[ 313.537345] r4:df21f3c0
[ 313.539890] [<c0081f94>] (handle_irq_event_percpu) from [<c0082134>] (handle_irq_event+0x40/0x64)
[ 313.548794] r10:00000000 r9:00000021 r8:df008000 r7:00000000 r6:c093bc84 r5:df20e2a0
[ 313.556681] r4:df20e240
[ 313.559225] [<c00820f4>] (handle_irq_event) from [<c0085478>] (handle_fasteoi_irq+0xc0/0x194)
[ 313.567780] r7:00000000 r6:c093bc84 r5:df20e2a0 r4:df20e240
[ 313.573482] [<c00853b8>] (handle_fasteoi_irq) from [<c0081674>] (generic_handle_irq+0x2c/0x3c)
[ 313.582123] r7:00000000 r6:df093e08 r5:00000017 r4:c093140c
[ 313.587825] [<c0081648>] (generic_handle_irq) from [<c008194c>] (__handle_domain_irq+0x64/0xbc)
[ 313.596558] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 313.604938] r9:00000021 r8:fa213000 r7:fa212000 r6:df093cf0 r5:fa21200c r4:c09368e4
[ 313.612738] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[ 313.620246] Exception stack(0xdf093cf0 to 0xdf093d38)
[ 313.625315] 3ce0: 00000000 c09862c0 00000000 00000000
[ 313.633523] 3d00: 00000282 00000012 df092000 00000000 df008000 00000021 00000000 df093d9c
[ 313.641729] 3d20: df093da0 df093d40 c00399e4 c0039550 600e0113 ffffffff
[ 313.648365] r9:00000021 r8:df008000 r7:df093d24 r6:ffffffff r5:600e0113 r4:c0039550
[ 313.656166] [<c00394bc>] (__do_softirq) from [<c00399e4>] (irq_exit+0xbc/0x11c)
[ 313.663499] r10:00000000 r9:00000021 r8:df008000 r7:00000000 r6:00000000 r5:00000012
[ 313.671384] r4:ffffe000
[ 313.673929] [<c0039928>] (irq_exit) from [<c0081950>] (__handle_domain_irq+0x68/0xbc)
[ 313.681785] r5:00000012 r4:c093140c
[ 313.685382] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 313.693762] r9:00000021 r8:fa213000 r7:fa212000 r6:df093e08 r5:fa21200c r4:c09368e4
[ 313.701564] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[ 313.709072] Exception stack(0xdf093e08 to 0xdf093e50)
[ 313.714140] 3e00: df5cbe40 00000002 00000000 00008779 df5cbe40 00000000
[ 313.722348] 3e20: dc26bc00 df081200 c0683a4c 00000021 00000000 df093e64 df093e68 df093e58
[ 313.730554] 3e40: c005638c c0687b48 600e0113 ffffffff
[ 313.735620] r9:00000021 r8:c0683a4c r7:df093e3c r6:ffffffff r5:600e0113 r4:c0687b48
[ 313.743426] [<c0687b20>] (_raw_spin_unlock_irq) from [<c005638c>] (finish_task_switch+0x78/0x1fc)
[ 313.752332] [<c0056314>] (finish_task_switch) from [<c0683a4c>] (__schedule+0x2e4/0x66c)
[ 313.760451] r10:00000000 r9:00000021 r8:d4bdf880 r7:d4bdf880 r6:d3f98600 r5:df081200
[ 313.768336] r4:df5cbe40
[ 313.770881] [<c0683768>] (__schedule) from [<c0683e28>] (schedule+0x54/0xc4)
[ 313.777953] r10:df5cb9c0 r9:df05e000 r8:00000008 r7:df092000 r6:df5cb9d4 r5:df5cb9c0
[ 313.785837] r4:df092000
[ 313.788384] [<c0683dd4>] (schedule) from [<c004bc58>] (worker_thread+0xd8/0x524)
[ 313.795804] r5:df5cb9c0 r4:df5cb9c0
[ 313.799402] [<c004bb80>] (worker_thread) from [<c0051704>] (kthread+0x100/0x118)
[ 313.806823] r10:00000000 r9:00000000 r8:c004bb80 r7:df05e000 r6:df092000 r5:df05b940
[ 313.814707] r4:00000000
[ 313.817252] [<c0051604>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 313.824498] r8:00000000 r7:00000000 r6:00000000 r5:c0051604 r4:df05b940
[ 313.831250] ---[ end trace 38dad09fedf8664e ]---
[ 313.839940] ------------[ cut here ]------------
[ 313.843484] thermal thermal_zone0: failed to read out thermal zone (-5)
[ 313.843574] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[ 313.843576] pgd = dbb9c000
[ 313.843584] [00000000] *pgd=94dd0831, *pte=00000000, *ppte=00000000
[ 313.867303] WARNING: CPU: 0 PID: 4 at drivers/bus/omap_l3_noc.c:147 l3_interrupt_handler+0x25c/0x368()
[ 313.876644] 44000000.ocp:L3 Custom Error: MASTER MPU TARGET L4_CFG (Read): Data Access in User mode during Functional access
[ 313.887902] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore rpmsg_proto dwc3 udc_core virtio_rpmsg_bus bc_example(O) ahci_platform libahci_platform pvrsrvkm(O) libahci libata extcon_usb_gpio omap_aes_driver scsi_mod omap_sham dwc3_omap extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 313.918348] CPU: 0 PID: 4 Comm: kworker/0:0 Tainted: G D W O 4.4.84 #1
[ 313.925683] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 313.931802] Workqueue: events_freezable thermal_zone_device_check
[ 313.937919] Backtrace:
[ 313.940381] [<c0013b1c>] (dump_backtrace) from [<c0013d18>] (show_stack+0x18/0x1c)
[ 313.947977] r7:c02e0130 r6:20070193 r5:00000000 r4:c0953590
[ 313.953682] [<c0013d00>] (show_stack) from [<c02b39a8>] (dump_stack+0x8c/0xa0)
[ 313.960931] [<c02b391c>] (dump_stack) from [<c003581c>] (warn_slowpath_common+0x88/0xb8)
[ 313.969048] r7:c02e0130 r6:00000093 r5:00000009 r4:df093be8
[ 313.974748] [<c0035794>] (warn_slowpath_common) from [<c0035884>] (warn_slowpath_fmt+0x38/0x40)
[ 313.983477] r8:00000017 r7:c0848884 r6:00000002 r5:c0848944 r4:c08489e8
[ 313.990230] [<c0035850>] (warn_slowpath_fmt) from [<c02e0130>] (l3_interrupt_handler+0x25c/0x368)
[ 313.999134] r3:df20ce40 r2:c08489e8
[ 314.002728] r4:80080003
[ 314.005276] [<c02dfed4>] (l3_interrupt_handler) from [<c0082048>] (handle_irq_event_percpu+0xb4/0x160)
[ 314.014616] r10:c098308b r9:df20e240 r8:00000017 r7:00000000 r6:00000000 r5:df20e2a0
[ 314.022502] r4:df21f3c0
[ 314.025048] [<c0081f94>] (handle_irq_event_percpu) from [<c0082134>] (handle_irq_event+0x40/0x64)
[ 314.033951] r10:df5cb9c0 r9:00000000 r8:df008000 r7:00000000 r6:c093bc84 r5:df20e2a0
[ 314.041836] r4:df20e240
[ 314.044380] [<c00820f4>] (handle_irq_event) from [<c0085478>] (handle_fasteoi_irq+0xc0/0x194)
[ 314.052935] r7:00000000 r6:c093bc84 r5:df20e2a0 r4:df20e240
[ 314.058633] [<c00853b8>] (handle_fasteoi_irq) from [<c0081674>] (generic_handle_irq+0x2c/0x3c)
[ 314.067275] r7:00000000 r6:00000000 r5:00000017 r4:c093140c
[ 314.072978] [<c0081648>] (generic_handle_irq) from [<c008194c>] (__handle_domain_irq+0x64/0xbc)
[ 314.081709] [<c00818e8>] (__handle_domain_irq) from [<c00094f0>] (gic_handle_irq+0x40/0x7c)
[ 314.090089] r9:00000000 r8:fa213000 r7:fa212000 r6:df093da8 r5:fa21200c r4:c09368e4
[ 314.097888] [<c00094b0>] (gic_handle_irq) from [<c0014854>] (__irq_svc+0x54/0x90)
[ 314.105397] Exception stack(0xdf093da8 to 0xdf093df0)
[ 314.110466] 3da0: dc258ed0 c0971d8c 00000001 00000000 00000090 dc258ed0
[ 314.118674] 3dc0: 00000020 00000004 00000000 00000000 df5cb9c0 df093e1c df093e20 df093df8
[ 314.126880] 3de0: c04cfd24 c04ce584 40070013 ffffffff
[ 314.131946] r9:00000000 r8:00000000 r7:df093ddc r6:ffffffff r5:40070013 r4:c04ce584
[ 314.139748] [<c04ce530>] (ti_bandgap_force_single_read) from [<c04cfd24>] (ti_bandgap_read_temperature+0xb8/0xf8)
[ 314.150046] r9:00000000 r8:dc258ed0 r7:dc2774d0 r6:df093e40 r5:00000004 r4:dc258ed0
[ 314.157846] [<c04cfc6c>] (ti_bandgap_read_temperature) from [<c04d00f4>] (__ti_thermal_get_temp+0x3c/0xd4)
[ 314.167534] r7:dc2774d0 r6:c06f33d0 r5:df093eb4 r4:00000004
[ 314.173237] [<c04d00b8>] (__ti_thermal_get_temp) from [<c04cb4f4>] (of_thermal_get_temp+0x28/0x34)
[ 314.182227] r9:00000000 r8:df5cf300 r7:df093eb4 r6:df33be0c r5:df33bc00 r4:df33bc00
[ 314.190029] [<c04cb4cc>] (of_thermal_get_temp) from [<c04c7b84>] (thermal_zone_get_temp+0x5c/0x118)
[ 314.199111] [<c04c7b28>] (thermal_zone_get_temp) from [<c04c9368>] (thermal_zone_device_update.part.4+0x1c/0x98)
[ 314.209322] r8:df5cf300 r7:00000000 r6:df5cb9c0 r5:df33bc00 r4:df33be2c
[ 314.216075] [<c04c934c>] (thermal_zone_device_update.part.4) from [<c04c9454>] (thermal_zone_device_check+0x38/0x3c)
[ 314.226635] r5:df05e000 r4:df33be2c
[ 314.230235] [<c04c941c>] (thermal_zone_device_check) from [<c004b8b0>] (process_one_work+0x124/0x3f4)
[ 314.239490] [<c004b78c>] (process_one_work) from [<c004bbcc>] (worker_thread+0x4c/0x524)
[ 314.247608] r10:df5cb9c0 r9:df05e000 r8:00000008 r7:df092000 r6:df5cb9d4 r5:df05e018
[ 314.255493] r4:df5cb9c0
[ 314.258038] [<c004bb80>] (worker_thread) from [<c0051704>] (kthread+0x100/0x118)
[ 314.265459] r10:00000000 r9:00000000 r8:c004bb80 r7:df05e000 r6:df092000 r5:df05b940
[ 314.273343] r4:00000000
[ 314.275888] [<c0051604>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 314.283133] r8:00000000 r7:00000000 r6:00000000 r5:c0051604 r4:df05b940
[ 314.289885] ---[ end trace 38dad09fedf8664f ]---
[ 314.294627] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[ 314.301709] pgd = c0004000
[ 314.304423] [00000000] *pgd=00000000
[ 314.308016] Internal error: : 1406 [#2] PREEMPT SMP ARM
[ 314.313256] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore rpmsg_proto dwc3 udc_core virtio_rpmsg_bus bc_example(O) ahci_platform libahci_platform pvrsrvkm(O) libahci libata extcon_usb_gpio omap_aes_driver scsi_mod omap_sham dwc3_omap extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 314.343695] CPU: 0 PID: 4 Comm: kworker/0:0 Tainted: G D W O 4.4.84 #1
[ 314.351030] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 314.357146] Workqueue: events_freezable thermal_zone_device_check
[ 314.363265] task: df081200 ti: df092000 task.ti: df092000
[ 314.368682] PC is at ti_bandgap_force_single_read+0x54/0x188
[ 314.374360] LR is at ti_bandgap_read_temperature+0xb8/0xf8
[ 314.379863] pc : [<c04ce584>] lr : [<c04cfd24>] psr: 40070013
[ 314.379863] sp : df093df8 ip : df093e20 fp : df093e1c
[ 314.391383] r10: df5cb9c0 r9 : 00000000 r8 : 00000000
[ 314.396623] r7 : 00000004 r6 : 00000020 r5 : dc258ed0 r4 : 00000090
[ 314.403172] r3 : 00000000 r2 : 00000001 r1 : c0971d8c r0 : dc258ed0
[ 314.409723] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 314.416883] Control: 10c5387d Table: 9bb9c06a DAC: 00000051
[ 314.422647] Process kworker/0:0 (pid: 4, stack limit = 0xdf092210)
[ 314.428848] Stack: (0xdf093df8 to 0xdf094000)
[ 314.433217] 3de0: dc258ed0 00000004
[ 314.441426] 3e00: df093e40 dc2774d0 dc258ed0 00000000 df093e3c df093e20 c04cfd24 c04ce53c
[ 314.449634] 3e20: 00000004 df093eb4 c06f33d0 dc2774d0 df093e6c df093e40 c04d00f4 c04cfc78
[ 314.457841] 3e40: df5cbe80 df093e68 df33bc00 df33bc00 df33be0c df093eb4 df5cf300 00000000
[ 314.466048] 3e60: df093e7c df093e70 c04cb4f4 c04d00c4 df093eac df093e80 c04c7b84 c04cb4d8
[ 314.474256] 3e80: 7fffffff df5c93c0 df093ec4 df33be2c df33bc00 df5cb9c0 00000000 df5cf300
[ 314.482463] 3ea0: df093ecc df093eb0 c04c9368 c04c7b34 df093edc df093ec0 df33be2c df05e000
[ 314.490670] 3ec0: df093edc df093ed0 c04c9454 c04c9358 df093f1c df093ee0 c004b8b0 c04c9428
[ 314.498879] 3ee0: df5cb9c0 df5cb9d4 df092000 00000008 df05e000 df5cb9c0 df05e018 df5cb9d4
[ 314.507086] 3f00: df092000 00000008 df05e000 df5cb9c0 df093f54 df093f20 c004bbcc c004b798
[ 314.515293] 3f20: df5cbb24 c0936100 00000000 00000000 df05b940 df092000 df05e000 c004bb80
[ 314.523501] 3f40: 00000000 00000000 df093fac df093f58 c0051704 c004bb8c 00000000 00000000
[ 314.531708] 3f60: 00000000 df05e000 00000000 00000000 df093f70 df093f70 00000000 00000000
[ 314.539915] 3f80: df093f80 df093f80 df093fac df05b940 c0051604 00000000 00000000 00000000
[ 314.548123] 3fa0: 00000000 df093fb0 c000fd18 c0051610 00000000 00000000 00000000 00000000
[ 314.556330] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 314.564537] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 314.572743] Backtrace:
[ 314.575201] [<c04ce530>] (ti_bandgap_force_single_read) from [<c04cfd24>] (ti_bandgap_read_temperature+0xb8/0xf8)
[ 314.585499] r9:00000000 r8:dc258ed0 r7:dc2774d0 r6:df093e40 r5:00000004 r4:dc258ed0
[ 314.593301] [<c04cfc6c>] (ti_bandgap_read_temperature) from [<c04d00f4>] (__ti_thermal_get_temp+0x3c/0xd4)
[ 314.602989] r7:dc2774d0 r6:c06f33d0 r5:df093eb4 r4:00000004
[ 314.608692] [<c04d00b8>] (__ti_thermal_get_temp) from [<c04cb4f4>] (of_thermal_get_temp+0x28/0x34)
[ 314.617682] r9:00000000 r8:df5cf300 r7:df093eb4 r6:df33be0c r5:df33bc00 r4:df33bc00
[ 314.625482] [<c04cb4cc>] (of_thermal_get_temp) from [<c04c7b84>] (thermal_zone_get_temp+0x5c/0x118)
[ 314.634564] [<c04c7b28>] (thermal_zone_get_temp) from [<c04c9368>] (thermal_zone_device_update.part.4+0x1c/0x98)
[ 314.644774] r8:df5cf300 r7:00000000 r6:df5cb9c0 r5:df33bc00 r4:df33be2c
[ 314.651530] [<c04c934c>] (thermal_zone_device_update.part.4) from [<c04c9454>] (thermal_zone_device_check+0x38/0x3c)
[ 314.662090] r5:df05e000 r4:df33be2c
[ 314.665688] [<c04c941c>] (thermal_zone_device_check) from [<c004b8b0>] (process_one_work+0x124/0x3f4)
[ 314.674945] [<c004b78c>] (process_one_work) from [<c004bbcc>] (worker_thread+0x4c/0x524)
[ 314.683063] r10:df5cb9c0 r9:df05e000 r8:00000008 r7:df092000 r6:df5cb9d4 r5:df05e018
[ 314.690948] r4:df5cb9c0
[ 314.693491] [<c004bb80>] (worker_thread) from [<c0051704>] (kthread+0x100/0x118)
[ 314.700912] r10:00000000 r9:00000000 r8:c004bb80 r7:df05e000 r6:df092000 r5:df05b940
[ 314.708797] r4:00000000
[ 314.711341] [<c0051604>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 314.718587] r8:00000000 r7:00000000 r6:00000000 r5:c0051604 r4:df05b940
[ 314.725341] Code: e5928000 f57ff04f e5913008 e3a02001 (e5919000)
[ 314.731456] ---[ end trace 38dad09fedf86650 ]---
[ 314.736189] Unable to handle kernel paging request at virtual address ffffffec
[ 314.743255] Unhandled fault: imprecise external abort (0x1406) at 0x00000000
[ 314.743258] pgd = c0004000
[ 314.743261] [00000000] *pgd=00000000
[ 314.743266] Internal error: : 1406 [#3] PREEMPT SMP ARM
[ 314.743300] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore rpmsg_proto dwc3 udc_core virtio_rpmsg_bus bc_example(O) ahci_platform libahci_platform pvrsrvkm(O) libahci libata extcon_usb_gpio omap_aes_driver scsi_mod omap_sham dwc3_omap extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 314.743304] CPU: 1 PID: 858 Comm: kworker/1:0 Tainted: G D W O 4.4.84 #1
[ 314.743306] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 314.743318] Workqueue: events_freezable thermal_zone_device_check
[ 314.743322] task: dbb7d400 ti: d4b6a000 task.ti: d4b6a000
[ 314.743325] PC is at ti_bandgap_force_single_read+0x4c/0x188
[ 314.743329] LR is at ti_bandgap_read_temperature+0xb8/0xf8
[ 314.743332] pc : [<c04ce57c>] lr : [<c04cfd24>] psr: 400e0013
[ 314.743332] sp : d4b6bdf8 ip : d4b6be20 fp : d4b6be1c
[ 314.743335] r10: df5d69c0 r9 : 00000000 r8 : 00000000
[ 314.743336] r7 : 00000000 r6 : 00000000 r5 : dc258ed0 r4 : 00000000
[ 314.743338] r3 : 0000014c r2 : fc00232c r1 : c0971cf8 r0 : dc258ed0
[ 314.743342] Flags: nZcv IRQs on FIQs on Mode SVC_32 ISA ARM Segment none
[ 314.743344] Control: 10c5387d Table: 9290806a DAC: 00000051
[ 314.743346] Process kworker/1:0 (pid: 858, stack limit = 0xd4b6a210)
[ 314.743349] Stack: (0xd4b6bdf8 to 0xd4b6c000)
[ 314.743352] bde0: dc258ed0 00000000
[ 314.743357] be00: d4b6be40 dc2773d0 dc258ed0 00000000 d4b6be3c d4b6be20 c04cfd24 c04ce53c
[ 314.743360] be20: 00000000 d4b6beb4 c06f33d0 dc2773d0 d4b6be6c d4b6be40 c04d00f4 c04cfc78
[ 314.743365] be40: df5d6e80 c0932e40 df33ac00 df33ac00 df33ae0c d4b6beb4 df5da300 00000000
[ 314.743369] be60: d4b6be7c d4b6be70 c04cb4f4 c04d00c4 d4b6beac d4b6be80 c04c7b84 c04cb4d8
[ 314.743372] be80: 7fffffff df5d6e40 dbb7d400 df33ae2c df33ac00 df5d69c0 00000000 df5da300
[ 314.743377] bea0: d4b6becc d4b6beb0 c04c9368 c04c7b34 d4b6bedc d4b6bec0 df33ae2c d30f1d00
[ 314.743380] bec0: d4b6bedc d4b6bed0 c04c9454 c04c9358 d4b6bf1c d4b6bee0 c004b8b0 c04c9428
[ 314.743384] bee0: df5d69c0 df5d69d4 d4b6a000 00000008 d30f1d00 df5d69c0 d30f1d18 df5d69d4
[ 314.743389] bf00: d4b6a000 00000008 d30f1d00 df5d69c0 d4b6bf54 d4b6bf20 c004bbcc c004b798
[ 314.743393] bf20: d30f1d00 c0936100 00000000 00000000 d33c7d80 d4b6a000 d30f1d00 c004bb80
[ 314.743397] bf40: 00000000 00000000 d4b6bfac d4b6bf58 c0051704 c004bb8c 00000000 00000000
[ 314.743401] bf60: 00000000 d30f1d00 00000000 00000000 d4b6bf70 d4b6bf70 00000000 00000000
[ 314.743405] bf80: d4b6bf80 d4b6bf80 d4b6bfac d33c7d80 c0051604 00000000 00000000 00000000
[ 314.743409] bfa0: 00000000 d4b6bfb0 c000fd18 c0051610 00000000 00000000 00000000 00000000
[ 314.743413] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 314.743417] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 9faca861 9facac61
[ 314.743419] Backtrace:
[ 314.743424] [<c04ce530>] (ti_bandgap_force_single_read) from [<c04cfd24>] (ti_bandgap_read_temperature+0xb8/0xf8)
[ 314.743432] r9:00000000 r8:dc258ed0 r7:dc2773d0 r6:d4b6be40 r5:00000000 r4:dc258ed0
[ 314.743438] [<c04cfc6c>] (ti_bandgap_read_temperature) from [<c04d00f4>] (__ti_thermal_get_temp+0x3c/0xd4)
[ 314.743448] r7:dc2773d0 r6:c06f33d0 r5:d4b6beb4 r4:00000000
[ 314.743452] [<c04d00b8>] (__ti_thermal_get_temp) from [<c04cb4f4>] (of_thermal_get_temp+0x28/0x34)
[ 314.743460] r9:00000000 r8:df5da300 r7:d4b6beb4 r6:df33ae0c r5:df33ac00 r4:df33ac00
[ 314.743465] [<c04cb4cc>] (of_thermal_get_temp) from [<c04c7b84>] (thermal_zone_get_temp+0x5c/0x118)
[ 314.743470] [<c04c7b28>] (thermal_zone_get_temp) from [<c04c9368>] (thermal_zone_device_update.part.4+0x1c/0x98)
[ 314.743478] r8:df5da300 r7:00000000 r6:df5d69c0 r5:df33ac00 r4:df33ae2c
[ 314.743483] [<c04c934c>] (thermal_zone_device_update.part.4) from [<c04c9454>] (thermal_zone_device_check+0x38/0x3c)
[ 314.743487] r5:d30f1d00 r4:df33ae2c
[ 314.743495] [<c04c941c>] (thermal_zone_device_check) from [<c004b8b0>] (process_one_work+0x124/0x3f4)
[ 314.743500] [<c004b78c>] (process_one_work) from [<c004bbcc>] (worker_thread+0x4c/0x524)
[ 314.743508] r10:df5d69c0 r9:d30f1d00 r8:00000008 r7:d4b6a000 r6:df5d69d4 r5:d30f1d18
[ 314.743510] r4:df5d69c0
[ 314.743516] [<c004bb80>] (worker_thread) from [<c0051704>] (kthread+0x100/0x118)
[ 314.743523] r10:00000000 r9:00000000 r8:c004bb80 r7:d30f1d00 r6:d4b6a000 r5:d33c7d80
[ 314.743525] r4:00000000
[ 314.743530] [<c0051604>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 314.743537] r8:00000000 r7:00000000 r6:00000000 r5:c0051604 r4:d33c7d80
[ 314.743541] Code: e5913000 e0822003 e5928000 f57ff04f (e5913008)
[ 314.743544] ---[ end trace 38dad09fedf86651 ]---
[ 314.743569] Unable to handle kernel paging request at virtual address ffffffec
[ 314.743573] pgd = c0004000
[ 314.743579] [ffffffec] *pgd=9faca861, *pte=00000000, *ppte=00000000
[ 314.743582] Internal error: Oops: 37 [#4] PREEMPT SMP ARM
[ 314.743611] Modules linked in: memcache(O) xhci_plat_hcd xhci_hcd usbcore rpmsg_proto dwc3 udc_core virtio_rpmsg_bus bc_example(O) ahci_platform libahci_platform pvrsrvkm(O) libahci libata extcon_usb_gpio omap_aes_driver scsi_mod omap_sham dwc3_omap extcon omap_des omap_rng rng_core omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[ 314.743615] CPU: 1 PID: 858 Comm: kworker/1:0 Tainted: G D W O 4.4.84 #1
[ 314.743617] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 314.743625] task: dbb7d400 ti: d4b6a000 task.ti: d4b6a000
[ 314.743629] PC is at kthread_data+0x10/0x18
[ 314.743633] LR is at wq_worker_sleeping+0x14/0xd8
[ 314.743636] pc : [<c0051b54>] lr : [<c004c97c>] psr: 200e0193
[ 314.743636] sp : d4b6bba0 ip : d4b6bbb0 fp : d4b6bbac
[ 314.743637] r10: 00000001 r9 : df5d6e40 r8 : dbb7d7a8
[ 314.743639] r7 : c09366d4 r6 : c0932e40 r5 : dbb7d400 r4 : 00000001
[ 314.743641] r3 : 00000000 r2 : 00000000 r1 : 00000001 r0 : dbb7d400
[ 314.743643] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[ 314.743646] Control: 10c5387d Table: 9290806a DAC: 00000051
[ 314.743648] Process kworker/1:0 (pid: 858, stack limit = 0xd4b6a210)
[ 314.743650] Stack: (0xd4b6bba0 to 0xd4b6c000)
[ 314.743655] bba0: d4b6bbc4 d4b6bbb0 c004c97c c0051b50 df5d6e40 dbb7d400 d4b6bc1c d4b6bbc8
[ 314.743660] bbc0: c0683bf0 c004c974 c0985e14 d5096b40 d4b6bbec d4b6bbe0 c008de78 c008dbfc
[ 314.743664] bbe0: d4b6bc34 c0683e28 00000000 c008de6c c0036880 d4b6a000 d4b6b904 df080000
[ 314.743668] bc00: d4b6bc40 dbb7d720 c04ce57e c081abd4 d4b6bc34 d4b6bc20 c0683e28 c0683774
[ 314.743672] bc20: dbb7d400 d4b6b904 d4b6bc5c d4b6bc38 c00387d8 c0683de0 00000001 00000000
[ 314.743676] bc40: d4b6bc40 d4b6bc40 c0035928 c04ce580 d4b6bce4 d4b6bc60 c0013f68 c00381a4
[ 314.743680] bc60: d4b6a210 0000000b c081abdc 00000008 00000000 d4b6a000 00000000 600e0193
[ 314.743684] bc80: 65b6bca4 33313935 20303030 32383065 33303032 39356520 30303832 35662030
[ 314.743688] bca0: 30666637 28206634 31393565 38303033 c0002029 c0004000 d4b6bcf4 c093afb4
[ 314.743692] bcc0: 00001406 00000007 00000000 d4b6bda8 00000000 df5d69c0 d4b6bcf4 d4b6bce8
[ 314.743696] bce0: c0014198 c0013d28 d4b6bda4 d4b6bcf8 c0009370 c0014184 00000000 d4b6bd08
[ 314.743700] bd00: 00000007 00000000 00030003 00000000 00003a76 00000000 00003a76 00000000
[ 314.743704] bd20: d4b6bd54 d4b6bd30 c0063708 c0078d24 df5d6e80 dbb7d448 df5d6e80 dbb7d448
[ 314.743708] bd40: 00000001 00000000 d4b6bdd4 d4b6bd58 c006548c c0063790 c0099108 c04fd884
[ 314.743712] bd60: ffffffff 00ffffff 31d74ae5 00269e7f 00000049 df5d4e50 00000001 dc297a80
[ 314.743716] bd80: 00001000 c04ce57c 400e0013 ffffffff d4b6bddc 00000000 d4b6be1c d4b6bda8
[ 314.743720] bda0: c00147e0 c00092c0 dc258ed0 c0971cf8 fc00232c 0000014c 00000000 dc258ed0
[ 314.743724] bdc0: 00000000 00000000 00000000 00000000 df5d69c0 d4b6be1c d4b6be20 d4b6bdf8
[ 314.743728] bde0: c04cfd24 c04ce57c 400e0013 ffffffff 00000051 00000000 dc258ed0 00000000
[ 314.743732] be00: d4b6be40 dc2773d0 dc258ed0 00000000 d4b6be3c d4b6be20 c04cfd24 c04ce53c
[ 314.743736] be20: 00000000 d4b6beb4 c06f33d0 dc2773d0 d4b6be6c d4b6be40 c04d00f4 c04cfc78
[ 314.743740] be40: df5d6e80 c0932e40 df33ac00 df33ac00 df33ae0c d4b6beb4 df5da300 00000000
[ 314.743744] be60: d4b6be7c d4b6be70 c04cb4f4 c04d00c4 d4b6beac d4b6be80 c04c7b84 c04cb4d8
[ 314.743748] be80: 7fffffff df5d6e40 dbb7d400 df33ae2c df33ac00 df5d69c0 00000000 df5da300
[ 314.743752] bea0: d4b6becc d4b6beb0 c04c9368 c04c7b34 d4b6bedc d4b6bec0 df33ae2c d30f1d00
[ 314.743756] bec0: d4b6bedc d4b6bed0 c04c9454 c04c9358 d4b6bf1c d4b6bee0 c004b8b0 c04c9428
[ 314.743759] bee0: df5d69c0 df5d69d4 d4b6a000 00000008 d30f1d00 df5d69c0 d30f1d18 df5d69d4
[ 314.743764] bf00: d4b6a000 00000008 d30f1d00 df5d69c0 d4b6bf54 d4b6bf20 c004bbcc c004b798
[ 314.743768] bf20: d30f1d00 c0936100 00000000 00000000 d33c7d80 d4b6a000 d30f1d00 c004bb80
[ 314.743772] bf40: 00000000 00000000 d4b6bfac d4b6bf58 c0051704 c004bb8c 00000000 00000000
[ 314.743776] bf60: 00000000 d30f1d00 00000000 00000000 d4b6bf70 d4b6bf70 00000001 00010001
[ 314.743780] bf80: d4b6bf80 d4b6bf80 d4b6bfac d33c7d80 c0051604 00000000 00000000 00000000
[ 314.743784] bfa0: 00000000 d4b6bfb0 c000fd18 c0051610 00000000 00000000 00000000 00000000
[ 314.743787] bfc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 314.743792] bfe0: 00000000 00000000 00000000 00000000 00000013 00000000 9faca861 9facac61
[ 314.743794] Backtrace:
[ 314.743799] [<c0051b44>] (kthread_data) from [<c004c97c>] (wq_worker_sleeping+0x14/0xd8)
[ 314.743809] [<c004c968>] (wq_worker_sleeping) from [<c0683bf0>] (__schedule+0x488/0x66c)
[ 314.743813] r5:dbb7d400 r4:df5d6e40
[ 314.743817] [<c0683768>] (__schedule) from [<c0683e28>] (schedule+0x54/0xc4)
[ 314.743825] r10:c081abd4 r9:c04ce57e r8:dbb7d720 r7:d4b6bc40 r6:df080000 r5:d4b6b904
[ 314.743827] r4:d4b6a000
[ 314.743834] [<c0683dd4>] (schedule) from [<c00387d8>] (do_exit+0x640/0x9b8)
[ 314.743837] r5:d4b6b904 r4:dbb7d400
[ 314.743840] [<c0038198>] (do_exit) from [<c0013f68>] (die+0x24c/0x45c)
[ 314.743843] r7:c04ce580
[ 314.743846] [<c0013d1c>] (die) from [<c0014198>] (arm_notify_die+0x20/0x58)
[ 314.743853] r10:df5d69c0 r9:00000000 r8:d4b6bda8 r7:00000000 r6:00000007 r5:00001406
[ 314.743855] r4:c093afb4
[ 314.743858] [<c0014178>] (arm_notify_die) from [<c0009370>] (do_DataAbort+0xbc/0xc0)
[ 314.743863] [<c00092b4>] (do_DataAbort) from [<c00147e0>] (__dabt_svc+0x40/0x60)
[ 314.743865] Exception stack(0xd4b6bda8 to 0xd4b6bdf0)
[ 314.743869] bda0: dc258ed0 c0971cf8 fc00232c 0000014c 00000000 dc258ed0
[ 314.743872] bdc0: 00000000 00000000 00000000 00000000 df5d69c0 d4b6be1c d4b6be20 d4b6bdf8
[ 314.743875] bde0: c04cfd24 c04ce57c 400e0013 ffffffff
[ 314.743883] r8:00000000 r7:d4b6bddc r6:ffffffff r5:400e0013 r4:c04ce57c
[ 314.743887] [<c04ce530>] (ti_bandgap_force_single_read) from [<c04cfd24>] (ti_bandgap_read_temperature+0xb8/0xf8)
[ 314.743894] r9:00000000 r8:dc258ed0 r7:dc2773d0 r6:d4b6be40 r5:00000000 r4:dc258ed0
[ 314.743898] [<c04cfc6c>] (ti_bandgap_read_temperature) from [<c04d00f4>] (__ti_thermal_get_temp+0x3c/0xd4)
[ 314.743903] r7:dc2773d0 r6:c06f33d0 r5:d4b6beb4 r4:00000000
[ 314.743908] [<c04d00b8>] (__ti_thermal_get_temp) from [<c04cb4f4>] (of_thermal_get_temp+0x28/0x34)
[ 314.743915] r9:00000000 r8:df5da300 r7:d4b6beb4 r6:df33ae0c r5:df33ac00 r4:df33ac00
[ 314.743920] [<c04cb4cc>] (of_thermal_get_temp) from [<c04c7b84>] (thermal_zone_get_temp+0x5c/0x118)
[ 314.743925] [<c04c7b28>] (thermal_zone_get_temp) from [<c04c9368>] (thermal_zone_device_update.part.4+0x1c/0x98)
[ 314.743932] r8:df5da300 r7:00000000 r6:df5d69c0 r5:df33ac00 r4:df33ae2c
[ 314.743937] [<c04c934c>] (thermal_zone_device_update.part.4) from [<c04c9454>] (thermal_zone_device_check+0x38/0x3c)
[ 314.743939] r5:d30f1d00 r4:df33ae2c
[ 314.743945] [<c04c941c>] (thermal_zone_device_check) from [<c004b8b0>] (process_one_work+0x124/0x3f4)
[ 314.743950] [<c004b78c>] (process_one_work) from [<c004bbcc>] (worker_thread+0x4c/0x524)
[ 314.743957] r10:df5d69c0 r9:d30f1d00 r8:00000008 r7:d4b6a000 r6:df5d69d4 r5:d30f1d18
[ 314.743959] r4:df5d69c0
[ 314.743963] [<c004bb80>] (worker_thread) from [<c0051704>] (kthread+0x100/0x118)
[ 314.743970] r10:00000000 r9:00000000 r8:c004bb80 r7:d30f1d00 r6:d4b6a000 r5:d33c7d80
[ 314.743972] r4:00000000
[ 314.743976] [<c0051604>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 314.743982] r8:00000000 r7:00000000 r6:00000000 r5:c0051604 r4:d33c7d80
[ 314.743986] Code: e1a0c00d e92dd800 e24cb004 e5903378 (e5130014)
[ 314.743989] ---[ end trace 38dad09fedf86652 ]---
[ 314.743992] Fixing recursive fault but reboot is needed!
[ 315.896176] pgd = c0004000
[ 315.898886] [ffffffec] *pgd=9faca861, *pte=00000000, *ppte=00000000
[ 315.905192] Internal error: Oops: 37 [#5] PREEMPT SMP ARM
del
[ 315.941036] CPU: 0 PID: 4 Comm: kworker/0:0 Tainted: G D W O 4.4.84 #1
[ 315.948370] Hardware name: Generic DRA74X (Flattened Device Tree)
[ 315.954487] task: df081200 ti: df092000 task.ti: df092000
[ 315.959904] PC is at kthread_data+0x10/0x18
[ 315.964100] LR is at wq_worker_sleeping+0x14/0xd8
[ 315.968818] pc : [<c0051b54>] lr : [<c004c97c>] psr: 20070193
[ 315.968818] sp : df093ba0 ip : df093bb0 fp : df093bac
[ 315.980337] r10: 00000000 r9 : df5cbe40 r8 : df0815a8
[ 315.985578] r7 : c09366d4 r6 : c0932e40 r5 : df081200 r4 : 00000000
[ 315.992126] r3 : 00000000 r2 : 00000000 r1 : 00000000 r0 : df081200
[ 315.998674] Flags: nzCv IRQs off FIQs on Mode SVC_32 ISA ARM Segment none
[ 316.005920] Control: 10c5387d Table: 9bb9c06a DAC: 00000051
[ 316.011684] Process kworker/0:0 (pid: 4, stack limit = 0xdf092210)
[ 316.017884] Stack: (0xdf093ba0 to 0xdf094000)
[ 316.022254] 3ba0: df093bc4 df093bb0 c004c97c c0051b50 df5cbe40 df081200 df093c1c df093bc8
[ 316.030462] 3bc0: c0683bf0 c004c974 c0985e14 df0886c0 df093bec df093be0 c008de78 c008dbfc
[ 316.038669] 3be0: df093c34 c0683e28 00000000 c008de6c c0036880 df092000 df093904 df080000
[ 316.046876] 3c00: df093c40 df081520 c04ce586 c081abd4 df093c34 df093c20 c0683e28 c0683774
[ 316.055084] 3c20: df081200 df093904 df093c5c df093c38 c00387d8 c0683de0 00000001 00000000
[ 316.063292] 3c40: df093c40 df093c40 c0035928 c04ce588 df093ce4 df093c60 c0013f68 c00381a4
[ 316.071498] 3c60: df092210 0000000b c081abdc 00000008 00000000 df092000 00000000 60070193
[ 316.079706] 3c80: 65093ca4 38323935 20303030 66373566 66343066 39356520 30303331 33652038
[ 316.087913] 3ca0: 30323061 28203130 31393565 30303039 c0002029 c0004000 df093cf4 c093afb4
[ 316.096121] 3cc0: 00001406 00000007 00000000 df093da8 00000000 df5cb9c0 df093cf4 df093ce8
[ 316.104328] 3ce0: c0014198 c0013d28 df093da4 df093cf8 c0009370 c0014184 00000000 00000002
[ 316.112536] 3d00: 00000007 00000000 00030003 00000000 df081200 dbb7aa00 d4bdf880 d4bde380
[ 316.120743] 3d20: 00000022 00000000 df093d8c df093d38 c0683a4c c0056320 c00399c8 c008ef48
[ 316.128951] 3d40: c093140c 00000012 1250aa1d 00000049 c0081950 c0684324 2d6aa84d 00000049
[ 316.137158] 3d60: df093da8 df092000 40070013 ffffffff df093ddc c0014874 df092000 df5cb9c0
[ 316.145366] 3d80: df093da4 c04ce584 40070013 ffffffff df093ddc 00000000 df093e1c df093da8
[ 316.153573] 3da0: c00147e0 c00092c0 dc258ed0 c0971d8c 00000001 00000000 00000090 dc258ed0
[ 316.161781] 3dc0: 00000020 00000004 00000000 00000000 df5cb9c0 df093e1c df093e20 df093df8
[ 316.169988] 3de0: c04cfd24 c04ce584 40070013 ffffffff 00000051 00000021 dc258ed0 00000004
[ 316.178196] 3e00: df093e40 dc2774d0 dc258ed0 00000000 df093e3c df093e20 c04cfd24 c04ce53c
[ 316.186403] 3e20: 00000004 df093eb4 c06f33d0 dc2774d0 df093e6c df093e40 c04d00f4 c04cfc78
[ 316.194610] 3e40: df5cbe80 df093e68 df33bc00 df33bc00 df33be0c df093eb4 df5cf300 00000000
[ 316.202817] 3e60: df093e7c df093e70 c04cb4f4 c04d00c4 df093eac df093e80 c04c7b84 c04cb4d8
[ 316.211024] 3e80: 7fffffff df5c93c0 df093ec4 df33be2c df33bc00 df5cb9c0 00000000 df5cf300
[ 316.219231] 3ea0: df093ecc df093eb0 c04c9368 c04c7b34 df093edc df093ec0 df33be2c df05e000
[ 316.227438] 3ec0: df093edc df093ed0 c04c9454 c04c9358 df093f1c df093ee0 c004b8b0 c04c9428
[ 316.235646] 3ee0: df5cb9c0 df5cb9d4 df092000 00000008 df05e000 df5cb9c0 df05e018 df5cb9d4
[ 316.243853] 3f00: df092000 00000008 df05e000 df5cb9c0 df093f54 df093f20 c004bbcc c004b798
[ 316.252060] 3f20: df5cbb24 c0936100 00000000 00000000 df05b940 df092000 df05e000 c004bb80
[ 316.260267] 3f40: 00000000 00000000 df093fac df093f58 c0051704 c004bb8c 00000000 00000000
[ 316.268475] 3f60: 00000000 df05e000 00000000 00000000 df093f70 df093f70 00000001 00010001
[ 316.276682] 3f80: df093f80 df093f80 df093fac df05b940 c0051604 00000000 00000000 00000000
[ 316.284889] 3fa0: 00000000 df093fb0 c000fd18 c0051610 00000000 00000000 00000000 00000000
[ 316.293097] 3fc0: 00000000 00000000 00000000 00000000 00000000 00000000 00000000 00000000
[ 316.301304] 3fe0: 00000000 00000000 00000000 00000000 00000013 00000000 00000000 00000000
[ 316.309509] Backtrace:
[ 316.311967] [<c0051b44>] (kthread_data) from [<c004c97c>] (wq_worker_sleeping+0x14/0xd8)
[ 316.320089] [<c004c968>] (wq_worker_sleeping) from [<c0683bf0>] (__schedule+0x488/0x66c)
[ 316.328207] r5:df081200 r4:df5cbe40
[ 316.331803] [<c0683768>] (__schedule) from [<c0683e28>] (schedule+0x54/0xc4)
[ 316.338874] r10:c081abd4 r9:c04ce586 r8:df081520 r7:df093c40 r6:df080000 r5:df093904
[ 316.346759] r4:df092000
[ 316.349302] [<c0683dd4>] (schedule) from [<c00387d8>] (do_exit+0x640/0x9b8)
[ 316.356286] r5:df093904 r4:df081200
[ 316.359882] [<c0038198>] (do_exit) from [<c0013f68>] (die+0x24c/0x45c)
[ 316.366430] r7:c04ce588
[ 316.368974] [<c0013d1c>] (die) from [<c0014198>] (arm_notify_die+0x20/0x58)
[ 316.375957] r10:df5cb9c0 r9:00000000 r8:df093da8 r7:00000000 r6:00000007 r5:00001406
[ 316.383843] r4:c093afb4
[ 316.386386] [<c0014178>] (arm_notify_die) from [<c0009370>] (do_DataAbort+0xbc/0xc0)
[ 316.394157] [<c00092b4>] (do_DataAbort) from [<c00147e0>] (__dabt_svc+0x40/0x60)
[ 316.401578] Exception stack(0xdf093da8 to 0xdf093df0)
[ 316.406646] 3da0: dc258ed0 c0971d8c 00000001 00000000 00000090 dc258ed0
[ 316.414853] 3dc0: 00000020 00000004 00000000 00000000 df5cb9c0 df093e1c df093e20 df093df8
[ 316.423058] 3de0: c04cfd24 c04ce584 40070013 ffffffff
[ 316.428123] r8:00000000 r7:df093ddc r6:ffffffff r5:40070013 r4:c04ce584
[ 316.434881] [<c04ce530>] (ti_bandgap_force_single_read) from [<c04cfd24>] (ti_bandgap_read_temperature+0xb8/0xf8)
[ 316.445179] r9:00000000 r8:dc258ed0 r7:dc2774d0 r6:df093e40 r5:00000004 r4:dc258ed0
[ 316.452980] [<c04cfc6c>] (ti_bandgap_read_temperature) from [<c04d00f4>] (__ti_thermal_get_temp+0x3c/0xd4)
[ 316.462668] r7:dc2774d0 r6:c06f33d0 r5:df093eb4 r4:00000004
[ 316.468372] [<c04d00b8>] (__ti_thermal_get_temp) from [<c04cb4f4>] (of_thermal_get_temp+0x28/0x34)
[ 316.477362] r9:00000000 r8:df5cf300 r7:df093eb4 r6:df33be0c r5:df33bc00 r4:df33bc00
[ 316.485163] [<c04cb4cc>] (of_thermal_get_temp) from [<c04c7b84>] (thermal_zone_get_temp+0x5c/0x118)
[ 316.494244] [<c04c7b28>] (thermal_zone_get_temp) from [<c04c9368>] (thermal_zone_device_update.part.4+0x1c/0x98)
[ 316.504455] r8:df5cf300 r7:00000000 r6:df5cb9c0 r5:df33bc00 r4:df33be2c
[ 316.511210] [<c04c934c>] (thermal_zone_device_update.part.4) from [<c04c9454>] (thermal_zone_device_check+0x38/0x3c)
[ 316.521770] r5:df05e000 r4:df33be2c
[ 316.525368] [<c04c941c>] (thermal_zone_device_check) from [<c004b8b0>] (process_one_work+0x124/0x3f4)
[ 316.534624] [<c004b78c>] (process_one_work) from [<c004bbcc>] (worker_thread+0x4c/0x524)
[ 316.542741] r10:df5cb9c0 r9:df05e000 r8:00000008 r7:df092000 r6:df5cb9d4 r5:df05e018
[ 316.550625] r4:df5cb9c0
[ 316.553169] [<c004bb80>] (worker_thread) from [<c0051704>] (kthread+0x100/0x118)
[ 316.560589] r10:00000000 r9:00000000 r8:c004bb80 r7:df05e000 r6:df092000 r5:df05b940
[ 316.568473] r4:00000000
[ 316.571017] [<c0051604>] (kthread) from [<c000fd18>] (ret_from_fork+0x14/0x3c)
[ 316.578263] r8:00000000 r7:00000000 r6:00000000 r5:c0051604 r4:df05b940
[ 316.585014] Code: e1a0c00d e92dd800 e24cb004 e5903378 (e5130014)
[ 316.591128] ---[ end trace 38dad09fedf86653 ]---
[ 316.595758] Fixing recursive fault but reboot is needed!
[END] 2019/1/15 14:49:46
