Linux/TDA2PXEVM: [OpenGl] ARGB Texture support on VisionSDK
Part Number: TDA2PXEVM
Tool/software: Linux
Hi:
  This post in 2016 said will support ARGB texture in 2017, right now it's 2019!!!
In my previous post
we just wondering
  1. when TI will support ARGB texture because it's OpenGL standard?
  2. For now, it's not supported yet, any other way to load the picture to OpenGl and rendering out?
    ARGB texture support is already available on our K4.4 releases (PSDKLA 3.x / VisionSDK 3.x). Please check and let us know if you see any problems in your application.
    There are many options to achieve this. For example:
    1. You can use the standard render to texture option with glTexImage2D.
    2. Render to a pixmap surface and create an EGLImage out of it with the target set to EGL_NATIVE_PIXMAP_KHR.
    #1 should work with all implementations.
    #2 is a bit non-standard and will require the window system to support pixmap as a surface. This is not mandatory and some window systems (like Wayland) call for supporting only window surface.
    Anand
  • Hi Anand:
      Here is the sample code that to show the jpg with ARGB, but no output on screen.
     By using the sgxfrmcopy pluggin.
    Copyright (c) [2012 - 2017] Texas Instruments Incorporated
    All rights reserved not granted herein.
    Limited License.
     Texas Instruments Incorporated grants a world-wide, royalty-free, non-exclusive
     license under copyrights and patents it now or hereafter owns or controls to
     make,  have made, use, import, offer to sell and sell ("Utilize") this software
     subject to the terms herein.  With respect to the foregoing patent license,
     such license is granted  solely to the extent that any such patent is necessary
     to Utilize the software alone.  The patent license shall not apply to any
     combinations which include this software, other than combinations with devices
     manufactured by or for TI ("TI Devices").  No hardware patent is licensed
     hereunder.
     Redistributions must preserve existing copyright notices and reproduce this
     license (including the above copyright notice and the disclaimer and
     (if applicable) source code license limitations below) in the documentation
     and/or other materials provided with the distribution
     Redistribution and use in binary form, without modification, are permitted
     provided that the following conditions are met:
     * No reverse engineering, decompilation, or disassembly of this software
       is permitted with respect to any software provided in binary form.
     * Any redistribution and use are licensed by TI for use only with TI Devices.
     * Nothing shall obligate TI to provide you with source code for the software
       licensed and provided to you in object code.
     If software source code is provided to you, modification and redistribution of
     the source code are permitted provided that the following conditions are met:
     * Any redistribution and use of the source code, including any resulting
       derivative works, are licensed by TI for use only with TI Devices.
     * Any redistribution and use of any object code compiled from the source code
       and any resulting derivative works, are licensed by TI for use only with TI
       Devices.
     Neither the name of Texas Instruments Incorporated nor the names of its
     suppliers may be used to endorse or promote products derived from this software
     without specific prior written permission.
     DISCLAIMER.
     THIS SOFTWARE IS PROVIDED BY TI AND TI�S LICENSORS "AS IS" AND ANY EXPRESS OR
     IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF
     MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE DISCLAIMED.
     IN NO EVENT SHALL TI AND TI�S LICENSORS BE LIABLE FOR ANY DIRECT, INDIRECT,
     INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
     LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE, DATA, OR
     PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY THEORY OF
     LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT (INCLUDING NEGLIGENCE
     OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE OF THIS SOFTWARE, EVEN IF
     ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
    #include "sgxRenderAVM.h"
    #include "avm_gpu.h"
    #include "summ_widget.h"
    #include "surround_widget.h"
    #include <assert.h>
    #include <memory>
    #define BOTTOM_LEFT_W
    #define BOTTOM_LEFT_H  0
    #define SURR_POSITION_X 0
    #define SURR_POSITION_Y 0+BOTTOM_LEFT_H
    #define SURR_WIDTH 790
    #define SURR_HEIGHT 720
    #define SUMM_POSITION_X SURR_WIDTH
    #define SUMM_POSITION_Y 0+BOTTOM_LEFT_H
    #define SUMM_WIDTH 490
    #define SUMM_HEIGHT 720
    #include <assimp/scene.h>
    #include <assimp/postprocess.h>
    #include <assimp/Importer.hpp>
    #include <IL/il.h>
    std::unique_ptr<TAVMServiceServer> AVMServiceServer;
    std::unique_ptr<TAVMViewControl> AVMViewControl;
    std::unique_ptr<SummWidget> SumAVM;
    std::unique_ptr<SurroundWidget> SurrAVM;
    namespace {
        namespace {
       #define eglCheckGlError(x) \
            GLint error; \
               for (error = glGetError(); error; error = glGetError()) { \
                fprintf(stderr, "func:%s line %d GL: after %s() glError (0x%x)\n", __FUNCTION__,__LINE__,x, error); \
        void Dump2File(const std::string& file, uint8_t* data, uint32_t size)
          FILE* pFile;
          pFile = fopen(file.c_str(), "w");
          if (pFile != NULL) {
            fwrite(data, 1, size, pFile);
            fclose(pFile);
    unsigned char ClipValue(unsigned char x, unsigned char min_val, unsigned char max_val) {
        if (x > max_val) {
            return max_val;
        } else if (x < min_val) {
            return min_val;
        } else {
            return x;
    static const GLfloat gSgxRender1x1_triangleVertices_fullscreen[] = {
            -1.0f, 1.0f, 0.0f,
            -1.0f, -1.0f, 0.0f,
            1.0f, -1.0f, 0.0f,
            1.0f, 1.0f, 0.0f
    GLuint *textureIds ;
    #define ENABLE_TEST
    int SgxRenderAVM_setup(SgxRenderAVM_Obj *pObj)
    #ifdef ENABLE_TEST
        SgxRender1x1_setup(&pObj->render1x1Obj);
    int numTextures = 1;
       // init il, multi init is ok
       ilInit();
       /* create and fill array with DevIL texture ids */
       ILuint* imageIds = new ILuint[numTextures];
       ilGenImages(numTextures, imageIds);
       /* create and fill array with GL texture ids */
       textureIds = new GLuint[numTextures];
       glGenTextures(numTextures, textureIds); /* Texture name generation */
           eglCheckGlError("glGenTextures");
       printf("numTextures %d \n",numTextures);
       /* get iterator */
           ilBindImage(imageIds[0]); /* Binding of DevIL image name */
           ilEnable(IL_ORIGIN_SET);
           ilOriginFunc(IL_ORIGIN_LOWER_LEFT);
           ILboolean success = ilLoadImage((ILstring)"/opt/vision_sdk/avm_qt_app_res/cs11/LK.JPG");
           if (success)
           printf("load jpg ok \n");
               /* Convert image to RGBA */
               ilConvertImage(IL_RGBA, IL_UNSIGNED_BYTE);
                 printf("convert ok \n");
               /* Create and load textures to OpenGL */
               glBindTexture(GL_TEXTURE_EXTERNAL_OES, textureIds[0]);
                eglCheckGlError("glBindTexture");
               glTexImage2D(GL_TEXTURE_2D, 0, GL_RGBA, ilGetInteger(IL_IMAGE_WIDTH),
                   ilGetInteger(IL_IMAGE_HEIGHT), 0, GL_RGBA, GL_UNSIGNED_BYTE,
                   ilGetData());
               printf("glTexImage2D ok \n");
              #ifdef YUV_ENABLE
               std::vector<uint8_t>yuv(0,ilGetInteger(IL_IMAGE_WIDTH)*ilGetInteger(IL_IMAGE_HEIGHT)*2);
                 RGB2YUV420P(ilGetData(),ilGetInteger(IL_IMAGE_WIDTH),ilGetInteger(IL_IMAGE_HEIGHT),yuv.data());
                 glTexImage2D(GL_TEXTURE_2D, 0, GL_LUMINANCE, ilGetInteger(IL_IMAGE_WIDTH),
                     ilGetInteger(IL_IMAGE_HEIGHT), 0, GL_LUMINANCE, GL_UNSIGNED_BYTE,
                     yuv.data());
                 #endif
              //Dump2File("LK.JPG.RGBA",ilGetData(),ilGetInteger(IL_IMAGE_WIDTH)*ilGetInteger(IL_IMAGE_HEIGHT)*4);
               printf("JPEG header %x %x %x %x \n",ilGetData()[0],ilGetData()[1],ilGetData()[2],ilGetData()[3]);
               eglCheckGlError("glTexImage2D");
               glTexParameteri(GL_TEXTURE_EXTERNAL_OES, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
               glTexParameteri(GL_TEXTURE_EXTERNAL_OES, GL_TEXTURE_MIN_FILTER, GL_NEAREST);
                 printf("load ok \n");
             }else
                    printf("failed to load jpg file to texture \n");
      return 0;
    void SgxRenderAVM_renderFrame(SgxRenderAVM_Obj *pObj, System_EglWindowObj *pEglWindowObj, GLuint texYuv[], UInt16 numTex )
        UTILS_assert(numTex==4);
        printf(" textureIds[0] %d \n", textureIds[0]);
         SgxRender1x1_renderFrame1x1(&pObj->render1x1Obj, pEglWindowObj, gSgxRender1x1_triangleVertices_fullscreen,  textureIds[0]);
    (if replace the textureids[0] with texYuv[0] then the camera image can come up on screen.)
    You cannot use GL_TEXTURE_EXTERNAL_OES when you use glTexImage2D.
    The TEXTURE_OES is defined as part of EGLImage OpenGLES extension. This may or may not be supported on all OpenGLES implementations. Even if supported, there could be restrictions. TI supports only YUV images as part of EGLImage.
    www.khronos.org/.../OES_EGL_image_external.txt
    You need to use the standard OpenGLES render to texture technique for rendering to an ARGB buffer and using it as a texture. For example:
    opengles2learning.blogspot.com/.../render-to-texture-rtt.html
    If you face any issues when you start using RTT, please provide a standalone self contained OpenGLES application like the following:
    git.ti.com/.../kmscube
    You can run the kmscube application on either PSDKLA (with omapdrm) or VisionSDK (with virtualdrm).
    Anand
    Yes, the TI link is also relevant here. As I mentioned earlier, RTT (Render To Texture) is a standard technique long in practice for Graphics. I did not mention the TI link in earlier posts because the reference to PBuffers is sub-optimal for newer generation GPUs.
    I assume the question is answered. We will mark the thread closed. Please open a new thread or repost if you have any related questions.
    Anand
  • HI:
      Reopen for further discussion.
      we finished the render to texture code and run on visionSDK by sgxFrmcpy. please check the code in attachment.
    0020.sgxRenderAVM.cpp8358.TRenderToTexture.cpp
    The problem right now, the render to texture can not be bind.
    func:SgxRender1x1_renderFrame1x1 line 235 GL: after glBindTexture() glError (0x502)
    and the source code is in sgxRender1x1.c
    void SgxRender1x1_renderFrame1x1(SgxRender1x1_Obj *pObj, System_EglWindowObj *pEglWindowObj, const GLfloat *vertices, GLuint texYuv)
        glVertexAttribPointer(pObj->vPositionHandle, 3, GL_FLOAT, GL_FALSE, 0, vertices);
        eglCheckGlError("glVertexAttribPointer");
        glEnableVertexAttribArray(pObj->vPositionHandle);
        eglCheckGlError("glEnableVertexAttribArray");
        glVertexAttribPointer(pObj->vTexHandle, 2, GL_FLOAT, GL_FALSE, 0, gSgxRender1x1_texCoords);
        glEnableVertexAttribArray(pObj->vTexHandle);
        glUniform1i(pObj->yuvTexSamplerHandle, 0);
        eglCheckGlError("glUniform1i");
        glBindTexture(GL_TEXTURE_EXTERNAL_OES, texYuv);
        glDrawArrays(GL_TRIANGLE_FAN, 0, 4);
        eglCheckGlError("glDrawArrays");
    As mentioned in earlier post:
    Anand
  • Hi Anand:
    It will take much time to move to that repo and it can't prove anything.
    we do not have the experience with virtualdrm.
    And also consider the difference between kmscube and visionSDK sgxFrmCpy that:
    1. sgxFrmCpy use GL_TEXTURE_EXTERNAL_OES
    2. the shader program use "samplerExternalOES"
    we can't see any connection of the kmscube with this issue.
    and We're wondering does visionSDK have any sample to display picture by OpenGL?
    The main intent is to create an OpenGLES application that can be built separately without VisionSDK. We need to have a sample application that can reproduce the problem on TI EVM.
    This problem is specific to Graphics. For that, VisionSDK components are unnecessary. kmscube is an example OpenGLES application that can be built standalone. We would like you to give us an example application that is similar to kmscube that can reproduce the problem.
    Anand
  • Hi  Anand:
       please share the document how to cross build the kmscue to run on tda2px.
    Now we configure like:
    ./autogen.sh  CC=/mnt/workshop/GK-APA/apa-tda2/base/ti_vision_sdk_v3.4/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ --with-sysroot=/mnt/workshop/GK-APA/apa-tda2/dist/apa/targetfs/ --host --host-alias=arm
    but got the error as:
    checking if /mnt/workshop/GK-APA/apa-tda2/base/ti_vision_sdk_v3.4/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ supports -fno-rtti -fno-exceptions... yes
    checking for /mnt/workshop/GK-APA/apa-tda2/base/ti_vision_sdk_v3.4/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ option to produce PIC... -fPIC -DPIC
    checking if /mnt/workshop/GK-APA/apa-tda2/base/ti_vision_sdk_v3.4/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ PIC flag -fPIC -DPIC works... yes
    checking if /mnt/workshop/GK-APA/apa-tda2/base/ti_vision_sdk_v3.4/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ static flag -static works... yes
    checking if /mnt/workshop/GK-APA/apa-tda2/base/ti_vision_sdk_v3.4/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ supports -c -o file.o... yes
    checking if /mnt/workshop/GK-APA/apa-tda2/base/ti_vision_sdk_v3.4/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ supports -c -o file.o... (cached) yes
    checking whether the /mnt/workshop/GK-APA/apa-tda2/base/ti_vision_sdk_v3.4/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin/arm-linux-gnueabihf-g++ linker (/mnt/workshop/GK-APA/apa-tda2/base/ti_vision_sdk_v3.4/ti_components/os_tools/linux/linaro/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/arm-linux-gnueabihf/bin/ld) supports shared libraries... yes
    checking whether -lc should be explicitly linked in... no
    checking dynamic linker characteristics... no
    checking how to hardcode library paths into programs... immediate
    checking whether stripping libraries is possible... yes
    checking if libtool supports shared libraries... no
    checking whether to build shared libraries... no
    checking whether to build static libraries... yes
    checking for --host-alias=arm-pkg-config... no
    checking for pkg-config... /usr/bin/pkg-config
    checking pkg-config is at least version 0.9.0... yes
    checking for DRM... yes
    checking for GBM... no
    configure: error: Package requirements (gbm) were not met:
    No package 'gbm' found
    Consider adjusting the PKG_CONFIG_PATH environment variable if you
    installed software in a non-standard prefix.
    Alternatively, you may set the environment variables GBM_CFLAGS
    and GBM_LIBS to avoid the need to call pkg-config.
    See the pkg-config man page for more details.
    configure: WARNING: cache variable ac_cv_host contains a newline
    I used this steps to build kmscube with Vision-SDK's targetfs. Can you please try this and let me know.
    git clone git://git.ti.com/glsdk/kmscube.git
    cd kmscube
    export PSDKLA=/home/PROCESSOR_SDK_VISION_03_04_00_00/targetfs
    export PATH=/home/gcc-linaro-5.3-2016.02-x86_64_arm-linux-gnueabihf/bin:$PATH
    export PKG_CONFIG_PATH=$PSDKLA/usr/lib/pkgconfig
    export DRM_CFLAGS="-I$PSDKLA/usr/include -I$PSDKLA/usr/include/libdrm/ -I$PSDKLA/usr/include/omap"
    export DRM_LIBS="-L$PSDKLA/usr/lib -L$PSDKLA/lib -lattr -ldrm -ldrm_omap"
    export GBM_CFLAGS=-I$PSDKLA/usr/include/gbm
    export GBM_LIBS="-L$PSDKLA/usr/lib -lgbm"
    export LIBUDEV_CFLAGS=-I$PSDKLA/usr/include
    export LIBUDEV_LIBS="-L$PSDKLA/usr/lib -ludev"
    ./autogen.sh --host=arm-linux-gnueabihf --target=arm-linux-gnueabihf --prefix=$INSTALL_PATH --with-sysroot=$PSDKLA
    cp targetfs/lib/libudev* targetfs/usr/lib/
    make
    Please check if you can build kmscube with this setting.
    TI has not tested kmscube with vDRM since this is a KMS application and only wayland client applications like simple-egl have been tested.
    TI will make changes if anything is required to run this on VISION_SDK setup and update you.
    Ramprasad
  • Hi:
     Add comments:
     1. This issues related with  which we want to attach the car picture(JPG) to 3D car model.
    2. we'are working on VisionSDK with sgxfrmcpy plugin for rendering.
  • Hi Andy,
    How are you planning to decode jpeg to YUV.? IVAHD can decode and output NV12 which can be attached as a texture. This has been demonstrated in display-kmscube example of omapdrmtest.
    Are you able to build kmscube with VisionSDK?
    Ramprasad
     Yes, it's the another way to attach as a texture, we already have the software code that convert JPG to ARGB and ARGB to YUV
     we'are working on it.
    Will update ASAP
    Thanks.
  • Hi :
    we now succeed to render the JPG to screen by:
    1. use DevIL convert JPG to RGB
    2. manual convert RGB to yuv420
    3. export yuv420 data as DMAfd
    4. use EGLImageKHR load as texture.
    but we got another issue that unexpected color block on screen, will rise another ticket to discuss.
