RTOS: M4 Boot logs messages for early camera usecase.- Need for debug purpose
Tool/software: TI-RTOS
Hello all,
We are using vsdk3.04 version & Dra7xx-J6 target. We have taken patches from Shravan for  handling early camera-usecase
We have applied those patches and testing the below usecase.
UseCase: chains_earlyCaptureLateWeston
Capture -> Display_Video
DispDistSrc_weston -> Display_m4
We don't have u-boot and we are using IPL as bootloader.
We plan to test this usecase with the Linux-boot & without bootloader.
We are getting below messages from trace0.
cat /sys/kernel/debug/remoteproc/remoteproc0/trace0
[0][      0.000] 18 Resource entries at 0x3000
[0][      0.013] registering rpmsg-proto:rpmsg-proto service on 80 with HOST
Is it the above messages are expected ? Can you please check this from your end ?
Gokul
  • Hi Gokul,
    The Vision-SDK firmware directs all logs to a shared buffer which which isn't accessed by the debugfs entry being read.
    The address of this remote buffer can be obtained by referring to the entry REMOTE_LOG_MEM in the map file of the remote-core firmware (e.g vision_sdk_ipu2_release.xem4.map).
    With this address you can connect a debugger and view the memory on the memory browser on CCS (this can be done both when halted in bootloader and when kernel init is complete).
    Shravan
  • Hi Shravan,
    For normal usecase, we were getting the debug messages from the debugfs.
    Why cannot we get the logs for this early usecase alone ?
    Only camera -capture we were starting from rtos link and we are staring display-server as usual.
    how does the tester can check without ccs & debugger ?
    How can we check the IPU is alive or not ?
    From bootloader, How can we validate the image has been booted ?
    Gokul
  • Hi Gokul,
    For normal usecase, we were getting the debug messages from the debugfs. Why cannot we get the logs for this early usecase alone?
    By default on VSDK the logs are directed to the shared buffer and not to the debugfs entry. You can't access these logs even if you run non early boot scenarios.
    How does the tester can check without ccs & debugger ?
    There are many tools available to dump the contents of raw memory (devmem2 / omapconf), you can use this to dump the raw data.
    Again from the logs using devmem2 / omapconf to read logs. You can also read the state in the debugfs entry.
    Using the md command from u-boot.
    processors.wiki.ti.com/.../Early_Boot_and_Late_Attach
    This is for remote-core firmware built as part of Processor-SDK and not Vision-SDK.
    Shravan
  • Thanks Shravan. I got it .
  • Hi Shravan,
    As discussed in yesterday call, Please share your logs from kernel using omapconf. This is for reference.
    Also Please Share your logs from u-boot for reference.
    Gokul
  • Hi Gokul,
    Attached the omapconf dump. We use a single stage boot loader so the dump from u-boot isn't available, however the values is a trimmed version of the omapconf dump (the same buffer is appended to, no overwrites happen).
    Shravan
    root@dra7xx-evm:~# omapconf dump 0xa0440000 0xa0440500
    | Address (hex) | Data (hex) |
    | 0xA0440000    | 0x9EFA2EFB |
    | 0xA0440004    | 0x96B83EF1 |
    | 0xA0440008    | 0x96B92EF9 |
    | 0xA044000C    | 0x96B86EF0 |
    | 0xA0440010    | 0xB6B82EF8 |
    | 0xA0440014    | 0x96380EF0 |
    | 0xA0440018    | 0x96B80FF2 |
    | 0xA044001C    | 0x96A82EF0 |
    | 0xA0440020    | 0x96B826B0 |
    | 0xA0440024    | 0x96B8AEF4 |
    | 0xA0440028    | 0xD6B82EB0 |
    | 0xA044002C    | 0x96B82EF6 |
    | 0xA0440030    | 0x94B82ED0 |
    | 0xA0440034    | 0x96BA2EF0 |
    | 0xA0440038    | 0x96382CF0 |
    | 0xA044003C    | 0x96B82FF0 |
    | 0xA0440040    | 0x97BEBFF4 |
    | 0xA0440044    | 0x16BA2EF0 |
    | 0xA0440048    | 0x96E82FF2 |
    | 0xA044004C    | 0x96B82EB0 |
    | 0xA0440050    | 0xBEFA2EFC |
    | 0xA0440054    | 0x96B826F9 |
    | 0xA0440058    | 0x96B82EF4 |
    | 0xA044005C    | 0x96B82EF0 |
    | 0xA0440060    | 0x96A82EE2 |
    | 0xA0440064    | 0x9CBA6EF0 |
    | 0xA0440068    | 0x96AA2EF0 |
    | 0xA044006C    | 0x96B82EFC |
    | 0xA0440070    | 0x96982ED0 |
    | 0xA0440074    | 0xB6BA3EF1 |
    | 0xA0440078    | 0x83B92EF0 |
    | 0xA044007C    | 0x96BA66F9 |
    | 0xA0440080    | 0x00000000 |
    | 0xA0440084    | 0x00000000 |
    | 0xA0440088    | 0x00000000 |
    | 0xA044008C    | 0x00000000 |
    | 0xA0440090    | 0x00000000 |
    | 0xA0440094    | 0x00000000 |
    | 0xA0440098    | 0x00010000 |
    | 0xA044009C    | 0x00000000 |
    | 0xA04400A0    | 0x00000010 |
    | 0xA04400A4    | 0x00000000 |
    | 0xA04400A8    | 0x00000000 |
    | 0xA04400AC    | 0x00000000 |
    | 0xA04400B0    | 0x00000000 |
    | 0xA04400B4    | 0x00000000 |
    | 0xA04400B8    | 0x00200000 |
    | 0xA04400BC    | 0x00000000 |
    | 0xA04400C0    | 0x00002000 |
    | 0xA04400C4    | 0x00000000 |
    | 0xA04400C8    | 0x00000001 |
    | 0xA04400CC    | 0x00000000 |
    | 0xA04400D0    | 0x00000000 |
    | 0xA04400D4    | 0x00000000 |
    | 0xA04400D8    | 0x00000200 |
    | 0xA04400DC    | 0x00000000 |
    | 0xA04400E0    | 0x00000000 |
    | 0xA04400E4    | 0x00000000 |
    | 0xA04400E8    | 0x00000000 |
    | 0xA04400EC    | 0x00000000 |
    | 0xA04400F0    | 0x00000000 |
    | 0xA04400F4    | 0x00000000 |
    | 0xA04400F8    | 0x00000000 |
    | 0xA04400FC    | 0x00000000 |
    | 0xA0440100    | 0x9EB82EF9 |
    | 0xA0440104    | 0x97582CF0 |
    | 0xA0440108    | 0x97F83FF4 |
    | 0xA044010C    | 0x96BA2EF0 |
    | 0xA0440110    | 0xB6B82EF6 |
    | 0xA0440114    | 0x96B82AF0 |
    | 0xA0440118    | 0xD7B9AEF4 |
    | 0xA044011C    | 0x96F826F0 |
    | 0xA0440120    | 0x82B82EF0 |
    | 0xA0440124    | 0xD6BA3FF0 |
    | 0xA0440128    | 0x96B82E70 |
    | 0xA044012C    | 0xD6B82EF1 |
    | 0xA0440130    | 0xB6B82EF0 |
    | 0xA0440134    | 0xB6B82FF0 |
    | 0xA0440138    | 0x96B82EF0 |
    | 0xA044013C    | 0xB6B86EFA |
    | 0xA0440140    | 0x1FB86EFC |
    | 0xA0440144    | 0x96A82EE0 |
    | 0xA0440148    | 0x94382EEA |
    | 0xA044014C    | 0x34B82E70 |
    | 0xA0440150    | 0x96BC6EF1 |
    | 0xA0440154    | 0x96B82EF0 |
    | 0xA0440158    | 0xB6F82EF4 |
    | 0xA044015C    | 0x9EB82ED0 |
    | 0xA0440160    | 0x96B82FF0 |
    | 0xA0440164    | 0x96B82EFA |
    | 0xA0440168    | 0x96B82EF0 |
    | 0xA044016C    | 0x96B82EF4 |
    | 0xA0440170    | 0x96B82EF0 |
    | 0xA0440174    | 0x97B8AEF1 |
    | 0xA0440178    | 0x96B82C70 |
    | 0xA044017C    | 0xD6B82EF7 |
    | 0xA0440180    | 0x00000000 |
    | 0xA0440184    | 0x00000000 |
    | 0xA0440188    | 0x02000000 |
    | 0xA044018C    | 0x00000400 |
    | 0xA0440190    | 0x00000000 |
    | 0xA0440194    | 0x00000000 |
    | 0xA0440198    | 0x00000000 |
    | 0xA044019C    | 0x00000001 |
    | 0xA04401A0    | 0x00000000 |
    | 0xA04401A4    | 0x00000000 |
    | 0xA04401A8    | 0x00000000 |
    | 0xA04401AC    | 0x00000000 |
    | 0xA04401B0    | 0x00000000 |
    | 0xA04401B4    | 0x00000000 |
    | 0xA04401B8    | 0x00001000 |
    | 0xA04401BC    | 0x00080408 |
    | 0xA04401C0    | 0x00000000 |
    | 0xA04401C4    | 0x00040000 |
    | 0xA04401C8    | 0x00080000 |
    | 0xA04401CC    | 0x00000000 |
    | 0xA04401D0    | 0x00000000 |
    | 0xA04401D4    | 0x00000000 |
    | 0xA04401D8    | 0x00000000 |
    | 0xA04401DC    | 0x04000001 |
    | 0xA04401E0    | 0x00000001 |
    | 0xA04401E4    | 0x00000000 |
    | 0xA04401E8    | 0x00000000 |
    | 0xA04401EC    | 0x00000010 |
    | 0xA04401F0    | 0x00000000 |
    | 0xA04401F4    | 0x00000000 |
    | 0xA04401F8    | 0x00000000 |
    | 0xA04401FC    | 0x00000000 |
    | 0xA0440200    | 0x9EB83EF8 |
    | 0xA0440204    | 0x96B02CB0 |
    | 0xA0440208    | 0x96BA6EF0 |
    | 0xA044020C    | 0xB6B82EF0 |
    | 0xA0440210    | 0x96BB2EF2 |
    | 0xA0440214    | 0x86382EF0 |
    | 0xA0440218    | 0x96B9AEF0 |
    | 0xA044021C    | 0x9EB82EF0 |
    | 0xA0440220    | 0x9EB82EF1 |
    | 0xA0440224    | 0xB6BCAEF5 |
    | 0xA0440228    | 0x96B82EF0 |
    | 0xA044022C    | 0x9FBA2FFC |
    | 0xA0440230    | 0x96B82EF0 |
    | 0xA0440234    | 0x96BE2EF0 |
    | 0xA0440238    | 0x97B82EE0 |
    | 0xA044023C    | 0x96BB2EF0 |
    | 0xA0440240    | 0x97F92FF4 |
    | 0xA0440244    | 0x96B92AF0 |
    | 0xA0440248    | 0x96B06EFC |
    | 0xA044024C    | 0x96B92FF0 |
    | 0xA0440250    | 0x9EB8AEF0 |
    | 0xA0440254    | 0x96B82AF0 |
    | 0xA0440258    | 0x96B82EF4 |
    | 0xA044025C    | 0x9FB82CD0 |
    | 0xA0440260    | 0x9EB82EF0 |
    | 0xA0440264    | 0xD6B8BFFC |
    | 0xA0440268    | 0x96B024F0 |
    | 0xA044026C    | 0x9EB86EF3 |
    | 0xA0440270    | 0x9EB82EF0 |
    | 0xA0440274    | 0x96F8AEF0 |
    | 0xA0440278    | 0xB6382CF0 |
    | 0xA044027C    | 0x9EB9AEF5 |
    | 0xA0440280    | 0x00408000 |
    | 0xA0440284    | 0x00000018 |
    | 0xA0440288    | 0x00000008 |
    | 0xA044028C    | 0x00000000 |
    | 0xA0440290    | 0x00000000 |
    | 0xA0440294    | 0x00000000 |
    | 0xA0440298    | 0x00080000 |
    | 0xA044029C    | 0x00000008 |
    | 0xA04402A0    | 0x00000000 |
    | 0xA04402A4    | 0x00000000 |
    | 0xA04402A8    | 0x00000000 |
    | 0xA04402AC    | 0x00000000 |
    | 0xA04402B0    | 0x00000000 |
    | 0xA04402B4    | 0x00000000 |
    | 0xA04402B8    | 0x00000000 |
    | 0xA04402BC    | 0x00000000 |
    | 0xA04402C0    | 0x00000000 |
    | 0xA04402C4    | 0x00800000 |
    | 0xA04402C8    | 0x00000000 |
    | 0xA04402CC    | 0x00000000 |
    | 0xA04402D0    | 0x00000000 |
    | 0xA04402D4    | 0x00000000 |
    | 0xA04402D8    | 0x00000000 |
    | 0xA04402DC    | 0x00000001 |
    | 0xA04402E0    | 0x00800000 |
    | 0xA04402E4    | 0x00040000 |
    | 0xA04402E8    | 0x00000000 |
    | 0xA04402EC    | 0x00000000 |
    | 0xA04402F0    | 0x00000000 |
    | 0xA04402F4    | 0x00000000 |
    | 0xA04402F8    | 0x00000000 |
    | 0xA04402FC    | 0x00000000 |
    | 0xA0440300    | 0xD6BC2FF0 |
    | 0xA0440304    | 0x96B82E72 |
    | 0xA0440308    | 0x96B92EF0 |
    | 0xA044030C    | 0x96B82EE0 |
    | 0xA0440310    | 0x97BA2FF0 |
    | 0xA0440314    | 0x9EB8AEF0 |
    | 0xA0440318    | 0x96BA2EF1 |
    | 0xA044031C    | 0x96B80EF0 |
    | 0xA0440320    | 0x97B86EF0 |
    | 0xA0440324    | 0x96BD2EE2 |
    | 0xA0440328    | 0x97B42EF0 |
    | 0xA044032C    | 0x96B8AEFE |
    | 0xA0440330    | 0x96B82C70 |
    | 0xA0440334    | 0x96B82FF1 |
    | 0xA0440338    | 0x96F82E70 |
    | 0xA044033C    | 0x96B86EF5 |
    | 0xA0440340    | 0xBEB82EF1 |
    | 0xA0440344    | 0x96B02EF0 |
    | 0xA0440348    | 0x96FAFEF3 |
    | 0xA044034C    | 0x94F82EF0 |
    | 0xA0440350    | 0x96BC2EF0 |
    | 0xA0440354    | 0x96382EF0 |
    | 0xA0440358    | 0x96B8AEF1 |
    | 0xA044035C    | 0x96B82EE0 |
    | 0xA0440360    | 0x96B82EF0 |
    | 0xA0440364    | 0xD4B93EF0 |
    | 0xA0440368    | 0x96B82EF0 |
    | 0xA044036C    | 0x96BCAEF4 |
    | 0xA0440370    | 0x96B82EF0 |
    | 0xA0440374    | 0x9EF92EF8 |
    | 0xA0440378    | 0x96B82CF0 |
    | 0xA044037C    | 0x96BAEEF1 |
    | 0xA0440380    | 0x00000000 |
    | 0xA0440384    | 0x00000000 |
    | 0xA0440388    | 0x00000000 |
    | 0xA044038C    | 0x00000000 |
    | 0xA0440390    | 0x00000000 |
    | 0xA0440394    | 0x00080000 |
    | 0xA0440398    | 0x00000000 |
    | 0xA044039C    | 0x00000000 |
    | 0xA04403A0    | 0x00000000 |
    | 0xA04403A4    | 0x00000000 |
    | 0xA04403A8    | 0x00000008 |
    | 0xA04403AC    | 0x00000000 |
    | 0xA04403B0    | 0x00000000 |
    | 0xA04403B4    | 0x00000000 |
    | 0xA04403B8    | 0x00000000 |
    | 0xA04403BC    | 0x00000000 |
    | 0xA04403C0    | 0x00020000 |
    | 0xA04403C4    | 0x00880000 |
    | 0xA04403C8    | 0x00010000 |
    | 0xA04403CC    | 0x00000000 |
    | 0xA04403D0    | 0x00000000 |
    | 0xA04403D4    | 0x00000000 |
    | 0xA04403D8    | 0x00010000 |
    | 0xA04403DC    | 0x00000000 |
    | 0xA04403E0    | 0x00100000 |
    | 0xA04403E4    | 0x00000000 |
    | 0xA04403E8    | 0x00100000 |
    | 0xA04403EC    | 0x00000000 |
    | 0xA04403F0    | 0x00000000 |
    | 0xA04403F4    | 0x00040000 |
    | 0xA04403F8    | 0x00000000 |
    | 0xA04403FC    | 0x00000000 |
    | 0xA0440400    | 0xB6B8BFF0 |
    | 0xA0440404    | 0x96B82ED0 |
    | 0xA0440408    | 0xB6B8AEF4 |
    | 0xA044040C    | 0x96F82EE0 |
    | 0xA0440410    | 0x96B82EF2 |
    | 0xA0440414    | 0x96B80EF0 |
    | 0xA0440418    | 0x96B82EF8 |
    | 0xA044041C    | 0x96FA22F0 |
    | 0xA0440420    | 0x86B82EF0 |
    | 0xA0440424    | 0x96B8EEF0 |
    | 0xA0440428    | 0x96B82EF0 |
    | 0xA044042C    | 0x96B82FF4 |
    | 0xA0440430    | 0x96B82EE0 |
    | 0xA0440434    | 0x96B8AEF6 |
    | 0xA0440438    | 0x86B82EE0 |
    | 0xA044043C    | 0xD6BC2EFB |
    | 0xA0440440    | 0x96BC2EF1 |
    | 0xA0440444    | 0xD6B92ED0 |
    | 0xA0440448    | 0x96B82FF0 |
    | 0xA044044C    | 0x96B82ED0 |
    | 0xA0440450    | 0x96BC6EF0 |
    | 0xA0440454    | 0x96B82AF0 |
    | 0xA0440458    | 0x9EB8AEF0 |
    | 0xA044045C    | 0x96B82EE0 |
    | 0xA0440460    | 0x96B86EF0 |
    | 0xA0440464    | 0xD6F82EF1 |
    | 0xA0440468    | 0x96B86EB0 |
    | 0xA044046C    | 0xF6B12EF8 |
    | 0xA0440470    | 0x96B82EF0 |
    | 0xA0440474    | 0x96B86EF5 |
    | 0xA0440478    | 0x963826B0 |
    | 0xA044047C    | 0x96982EF4 |
    | 0xA0440480    | 0x00000000 |
    | 0xA0440484    | 0x00800000 |
    | 0xA0440488    | 0x00100000 |
    | 0xA044048C    | 0x00000000 |
    | 0xA0440490    | 0x00000000 |
    | 0xA0440494    | 0x00800000 |
    | 0xA0440498    | 0x00000000 |
    | 0xA044049C    | 0x00000000 |
    | 0xA04404A0    | 0x00000000 |
    | 0xA04404A4    | 0x00000000 |
    | 0xA04404A8    | 0x00000000 |
    | 0xA04404AC    | 0x00000000 |
    | 0xA04404B0    | 0x00400000 |
    | 0xA04404B4    | 0x00000000 |
    | 0xA04404B8    | 0x00000000 |
    | 0xA04404BC    | 0x00000000 |
    | 0xA04404C0    | 0x00040000 |
    | 0xA04404C4    | 0x00000002 |
    | 0xA04404C8    | 0x00000000 |
    | 0xA04404CC    | 0x00000000 |
    | 0xA04404D0    | 0x00000000 |
    | 0xA04404D4    | 0x00000000 |
    | 0xA04404D8    | 0x00000000 |
    | 0xA04404DC    | 0x00000000 |
    | 0xA04404E0    | 0x00000000 |
    | 0xA04404E4    | 0x00000000 |
    | 0xA04404E8    | 0x00000000 |
    | 0xA04404EC    | 0x00000000 |
    | 0xA04404F0    | 0x00000000 |
    | 0xA04404F4    | 0x00000000 |
    | 0xA04404F8    | 0x00000000 |
    | 0xA04404FC    | 0x00000000 |
    | 0xA0440500    | 0x9EBA2FF2 |
  • Hi Shravan,
    We could see only hex values. There is no text messages. How to verify it ?
    Gokul
  • Hi Gokul,
    Omapconf gives values in hex, you would need a small script to convert hex to ascii characters(plenty of scripts available online).
    I would recommend using the apps.out feature to read this content you can disable all other features in the app, you can just read the logs from remote cores (refer to functions remotelog_init and OSA_remoteLogClientInit() functions in links_fw/src/hlos/osa/src/osa.c).
    Shravan
    COMPLETE LOGS
    [HOST]  OSA: MEM: 0: Mapped 0xa0100000 to 0xb69d9000 of size 0x00100000
     [HOST]  OSA: MEM: 1: Mapped 0x84203000 to 0xa3dd9000 of size 0x12c00000
     [HOST]  OSA: MEM: 2: Mapped 0xa0200000 to 0xa3d19000 of size 0x00040000
     [HOST]  OSA: MEM: 3: Mapped 0xa02c0000 to 0xa3d59000 of size 0x00080000
     [HOST]  OSA: MEM: 4: Mapped 0x00000000 to 0x00000000 of size 0x00000000
     [HOST]  OSA: HOST Remote Log Shared Memory @ 0xa024f140
     [HOST]  OSA: DSP1 Remote Log Shared Memory @ 0xa02769e0
     [HOST]  OSA: DSP2 Remote Log Shared Memory @ 0xa029e280
     [HOST]  OSA: EVE1 Remote Log Shared Memory @ 0xa02c5b20
     [HOST]  OSA: EVE2 Remote Log Shared Memory @ 0xa02ed3c0
     [HOST]  OSA: EVE3 Remote Log Shared Memory @ 0xa0314c60
     [HOST]  OSA: EVE4 Remote Log Shared Memory @ 0xa033c500
     [HOST]  OSA: IPU2 Remote Log Shared Memory @ 0xa0363da0
     [HOST] [HOST  ]     27.992710 s:  SYSTEM: System A15 Init in progress !!!
     [HOST] [HOST  ]     27.992801 s:  SYSTEM: IPC: Init in progress !!!
     [HOST] [HOST  ]     27.992801 s:  SYSTEM: IPC: Notify init in progress !!!
     [HOST] [HOST  ]     27.994692 s:  SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81)
     [HOST] [HOST  ]     27.994723 s:  SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
     [HOST] [HOST  ]     27.994753 s:  SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80)
     [HOST] [HOST  ]     27.994753 s:  SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
     [HOST] [HOST  ]     27.996583 s:  SYSTEM: IPC: [DSP1] socket bind success !!! (dst vproc = 2, endpt = 81)
     [HOST] [HOST  ]     27.996583 s:  SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
     [HOST] [HOST  ]     27.996614 s:  SYSTEM: IPC: [DSP1] socket connect success !!! (dst vproc = 2, endpt = 80)
     [HOST] [HOST  ]     27.996614 s:  SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
     [HOST] [HOST  ]     27.997986 s:  SYSTEM: IPC: [DSP2] socket bind success !!! (dst vproc = 3, endpt = 81)
     [HOST] [HOST  ]     27.998017 s:  SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
     [HOST] [HOST  ]     27.998017 s:  SYSTEM: IPC: [DSP2] socket connect success !!! (dst vproc = 3, endpt = 80)
     [HOST] [HOST  ]     27.998047 s:  SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
     [HOST] [HOST  ]     27.998169 s:  SYSTEM: IPC: Notify init DONE !!!
     [HOST] [HOST  ]     27.998169 s:  SYSTEM: MSGQ: MsgQ init in progress !!!
     [HOST] [HOST  ]     27.998261 s:  SYSTEM: MSGQ: MsgQ init DONE !!!
     [HOST] [HOST  ]     27.998261 s:  SYSTEM: IPC: Init DONE !!!
     [HOST] [HOST  ]     27.998291 s:  SYSTEM: Initializing A15 Links !!!
     [HOST] [HOST  ]     27.998383 s:  IPC_OUT_0 : Init done - linkid-0x2000000
     [HOST] [HOST  ]     27.998474 s:  IPC_OUT_1 : Init done - linkid-0x2000001
     [HOST] [HOST  ]     27.998535 s:  IPC_OUT_2 : Init done - linkid-0x2000002
     [HOST] [HOST  ]     27.998627 s:  IPC_OUT_3 : Init done - linkid-0x2000003
     [HOST] [HOST  ]     27.998718 s:  IPC_OUT_4 : Init done - linkid-0x2000004
     [HOST] [HOST  ]     27.998810 s:  IPC_IN_0 : Init done - linkid-0x200000a
     [HOST] [HOST  ]     27.998871 s:  IPC_IN_1 : Init done - linkid-0x200000b
     [HOST] [HOST  ]     27.998962 s:  IPC_IN_2 : Init done - linkid-0x200000c
     [HOST] [HOST  ]     27.999054 s:  IPC_IN_3 : Init done - linkid-0x200000d
     [HOST] [HOST  ]     27.999145 s:  IPC_IN_4 : Init done - linkid-0x200000e
     [HOST] [HOST  ]     27.999206 s:  IPC_IN_5 : Init done - linkid-0x200000f
     [HOST] [HOST  ]     27.999298 s:  IPC_IN_6 : Init done - linkid-0x2000010
     [HOST] [HOST  ]     27.999389 s:  NULL_0 : Init done - linkid-0x2000014
     [HOST] [HOST  ]     27.999450 s:  NULL_1 : Init done - linkid-0x2000015
     [HOST] [HOST  ]     27.999603 s:  NULL_SRC_0 : Init done - linkid-0x2000039
     [HOST] [HOST  ]     27.999725 s:  DISP_DIST_SRC_0 : Init done - linkid-0x200005e
     [HOST] [HOST  ]     27.999816 s:  DISP_DIST_SRC_1 : Init done - linkid-0x200005f
     [HOST] [HOST  ]     27.999877 s:  DISP_DIST_SRC_2 : Init done - linkid-0x2000060
     [HOST] [HOST  ]     27.999969 s:  DISP_DIST_SRC_3 : Init done - linkid-0x2000061
     [HOST] [HOST  ]     28.000030 s:  DISP_DIST_SRC_4 : Init done - linkid-0x2000062
     [HOST] [HOST  ]     28.000091 s:  DISP_DIST_SRC_5 : Init done - linkid-0x2000063
     [HOST] [HOST  ]     28.000183 s:  DISP_DIST_SRC_6 : Init done - linkid-0x2000064
     [HOST] [HOST  ]     28.000244 s:  DISP_DIST_SRC_7 : Init done - linkid-0x2000065
     [HOST] [HOST  ]     28.000366 s:  SGX3DSRV_0 : Init done - linkid-0x2000047
     [HOST] [HOST  ]     28.000488 s:  ALGORITHM_0 : Init done - linkid-0x2000031
     [HOST] [HOST  ]     28.000579 s:  ALGORITHM_1 : Init done - linkid-0x2000032
     [HOST] [HOST  ]     28.000640 s:  ALGORITHM_2 : Init done - linkid-0x2000033
     [HOST] [HOST  ]     28.000762 s:  ALGORITHM_3 : Init done - linkid-0x2000034
     [HOST] [HOST  ]     28.000854 s:  ALGORITHM_4 : Init done - linkid-0x2000035
     [HOST] [HOST  ]     28.000915 s:  ALGORITHM_5 : Init done - linkid-0x2000036
     [HOST] [HOST  ]     28.001006 s:  ALGORITHM_6 : Init done - linkid-0x2000037
     [HOST] [HOST  ]     28.001098 s:  ALGORITHM_7 : Init done - linkid-0x2000038
     [HOST] [HOST  ]     28.001281 s:  DUP0 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.001403 s:  DUP1 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.001555 s:  DUP2 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.001708 s:  DUP3 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.001830 s:  DUP4 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.001921 s:  SYNC_0 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.002013 s:  SYNC_1 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.002074 s:  SYNC_2 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.002165 s:  SYNC_3 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.002257 s:  MERGE_0 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.002379 s:  MERGE_1 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.002470 s:  MERGE_2 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.002562 s:  MERGE_3 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.002653 s:  MERGE_4 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.008692 s:  SELECT_0 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.009485 s:  SELECT_1 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.009577 s:  GATE_0 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.009638 s:  GATE_1 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.009699 s:  GATE_2 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.009790 s:  GATE_3 : Init done - linkid-0x0
     [HOST] [HOST  ]     28.009851 s:  SGXFRMCPY_0 : Init done - linkid-0x2000046
     [HOST] [HOST  ]     28.009943 s:  SGX3DSFM_0 : Init done - linkid-0x2000048
     [HOST] [HOST  ]     28.009973 s:  SYSTEM: Initializing A15 Links ... DONE !!!
     [HOST] [HOST  ]     28.010675 s:  OSA: Adjusting global time, timeH by 0 units!!!
     [HOST] [HOST  ]     28.010675 s:  SYSTEM: System A15 Init Done !!!
     [HOST] [HOST  ]     28.010797 s:  NETWORK_CTRL: Starting Server (port=5000) !!!
     [HOST] [HOST  ]     28.010858 s:  NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
     [HOST] [HOST  ]     28.011773 s: Enter 'e' to exit
     [HOST] [HOST  ]     28.098548 s:  IPC_OUT_0   : Create in progress !!!
     [HOST] [HOST  ]     28.098639 s:  IPC_OUT_0   : Create Done !!!
     [HOST] [DSP1  ]      1.363325 s:  ***** DSP1 Firmware build time 17:47:32 Jan 22 2019
     [HOST] [DSP1  ]      1.363417 s:  *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 600000000 Hz>
     [HOST] [DSP1  ]      1.363691 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [DSP1  ]      1.363935 s:  UTILS: CIO: Init Done !!!
     [HOST] [DSP1  ]      1.363966 s:  SYSTEM: IPC init in progress !!!
     [HOST] [DSP1  ]      1.363996 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP1  ]      1.365887 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [DSP1  ]      1.609497 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [DSP1  ]      1.638382 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [DSP1  ]      1.658390 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [DSP1  ]      1.678429 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [DSP1  ]      1.698377 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [DSP1  ]      1.698407 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [DSP1  ]      1.698468 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [DSP1  ]      1.698529 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [DSP1  ]      1.698590 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [DSP1  ]      1.698651 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [DSP1  ]      1.698712 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [DSP1  ]      1.698773 s:  SYSTEM: Notify init done !!!
     [HOST] [DSP1  ]      1.698926 s:  SYSTEM: MsgQ init done !!!
     [HOST] [DSP1  ]      1.699048 s: RpmsgInit in progress...
     [HOST] [DSP1  ]      1.699109 s:  SYSTEM: IPC init DONE !!!
     [HOST] [DSP1  ]      1.699810 s:  SYSTEM: System Common Init Done !!!
     [HOST] [DSP1  ]      1.699841 s:  SYSTEM: System DSP Init in progress !!!
     [HOST] [DSP1  ]      1.700115 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [DSP1  ]      1.700146 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
     [HOST] [DSP1  ]      1.700207 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516496 B (504 KB)
     [HOST] [DSP1  ]      1.700237 s:  SYSTEM: Initializing Links !!!
     [HOST] [DSP1  ]      1.710150 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [DSP1  ]      1.710211 s: lz4CompDecomp Init
     [HOST] [DSP1  ]      1.710211 s:  SYSTEM: System DSP Init Done !!!
     [HOST] [DSP1  ]      2.040383 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
     [HOST] [DSP1  ]      2.040413 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
     [HOST] [DSP1  ]      7.888549 s: Connection established with HLOS, calling rpmsgInit
     [HOST] [DSP2  ]      1.605014 s: ***** DSP2 Firmware build time 17:47:31 Jan 22 2019
     [HOST] [DSP2  ]      1.605105 s:  *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 600000000 Hz>
     [HOST] [DSP2  ]      1.605380 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [DSP2  ]      1.605624 s:  UTILS: CIO: Init Done !!!
     [HOST] [DSP2  ]      1.605654 s:  SYSTEM: IPC init in progress !!!
     [HOST] [DSP2  ]      1.605685 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]      1.607576 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [DSP2  ]      1.609497 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [DSP2  ]      1.648264 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [DSP2  ]      1.668273 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [DSP2  ]      1.688312 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [DSP2  ]      1.708290 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [DSP2  ]      1.708351 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [DSP2  ]      1.708412 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [DSP2  ]      1.708473 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [DSP2  ]      1.708534 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [DSP2  ]      1.708595 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [DSP2  ]      1.708656 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [DSP2  ]      1.708717 s:  SYSTEM: Notify init done !!!
     [HOST] [DSP2  ]      1.708900 s:  SYSTEM: MsgQ init done !!!
     [HOST] [DSP2  ]      1.708991 s: RpmsgInit in progress...
     [HOST] [DSP2  ]      1.709052 s:  SYSTEM: IPC init DONE !!!
     [HOST] [DSP2  ]      1.709754 s:  SYSTEM: System Common Init Done !!!
     [HOST] [DSP2  ]      1.709815 s:  SYSTEM: System DSP Init in progress !!!
     [HOST] [DSP2  ]      1.710059 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [DSP2  ]      1.710120 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
     [HOST] [DSP2  ]      1.710150 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516496 B (504 KB)
     [HOST] [DSP2  ]      1.710211 s:  SYSTEM: Initializing Links !!!
     [HOST] [DSP2  ]      1.720154 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [DSP2  ]      1.720215 s: lz4CompDecomp Init
     [HOST] [DSP2  ]      1.720215 s:  SYSTEM: System DSP Init Done !!!
     [HOST] [DSP2  ]      2.042396 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
     [HOST] [DSP2  ]      2.042426 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
     [HOST] [DSP2  ]      7.908528 s: Connection established with HLOS, calling rpmsgInit
     [HOST] [EVE1  ]      1.291831 s:  ***** EVE Firmware build time 17:46:41 Jan 22 2019
     [HOST] [EVE1  ]      1.293478 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
     [HOST] [EVE1  ]      1.296376 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [EVE1  ]      1.298755 s:  UTILS: CIO: Init Done !!!
     [HOST] [EVE1  ]      1.299609 s:  SYSTEM: IPC init in progress !!!
     [HOST] [EVE1  ]      1.300463 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [EVE1  ]      1.628682 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [EVE1  ]      1.638382 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [EVE1  ]      1.648264 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [EVE1  ]      1.688464 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [EVE1  ]      1.718416 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [EVE1  ]      1.738455 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [EVE1  ]      1.739431 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [EVE1  ]      1.740590 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [EVE1  ]      1.741719 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [EVE1  ]      1.742847 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [EVE1  ]      1.744006 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [EVE1  ]      1.745135 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [EVE1  ]      1.746294 s:  SYSTEM: Notify init done !!!
     [HOST] [EVE1  ]      1.747941 s:  SYSTEM: MsgQ init done !!!
     [HOST] [EVE1  ]      1.748703 s:  SYSTEM: IPC init DONE !!!
     [HOST] [EVE1  ]      1.761239 s:  SYSTEM: System Common Init Done !!!
     [HOST] [EVE1  ]      1.762093 s:  SYSTEM: System EVE Init in progress !!!
     [HOST] [EVE1  ]      1.763374 s:  UTILS: DMA: HWI Create for INT8 !!!
     [HOST] [EVE1  ]      1.764411 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [EVE1  ]      1.765509 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE1  ]      1.767675 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB)
     [HOST] [EVE1  ]      1.769657 s:  SYSTEM: Initializing Links !!!
     [HOST] [EVE1  ]      1.857073 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [EVE1  ]      1.858171 s:  SYSTEM: System EVE Init Done !!!
     [HOST] [EVE2  ]      1.292075 s:  ***** EVE Firmware build time 17:46:42 Jan 22 2019
     [HOST] [EVE2  ]      1.293753 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
     [HOST] [EVE2  ]      1.297139 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [EVE2  ]      1.299274 s:  UTILS: CIO: Init Done !!!
     [HOST] [EVE2  ]      1.300158 s:  SYSTEM: IPC init in progress !!!
     [HOST] [EVE2  ]      1.301043 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [EVE2  ]      1.648752 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [EVE2  ]      1.658390 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [EVE2  ]      1.668273 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [EVE2  ]      1.688464 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [EVE2  ]      1.738302 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [EVE2  ]      1.758280 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [EVE2  ]      1.759226 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [EVE2  ]      1.760446 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [EVE2  ]      1.761636 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [EVE2  ]      1.762856 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [EVE2  ]      1.764045 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [EVE2  ]      1.765235 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [EVE2  ]      1.766424 s:  SYSTEM: Notify init done !!!
     [HOST] [EVE2  ]      1.768102 s:  SYSTEM: MsgQ init done !!!
     [HOST] [EVE2  ]      1.768925 s:  SYSTEM: IPC init DONE !!!
     [HOST] [EVE2  ]      1.781858 s:  SYSTEM: System Common Init Done !!!
     [HOST] [EVE2  ]      1.782742 s:  SYSTEM: System EVE Init in progress !!!
     [HOST] [EVE2  ]      1.784084 s:  UTILS: DMA: HWI Create for INT8 !!!
     [HOST] [EVE2  ]      1.785152 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [EVE2  ]      1.786311 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE2  ]      1.788690 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB)
     [HOST] [EVE2  ]      1.790703 s:  SYSTEM: Initializing Links !!!
     [HOST] [EVE2  ]      1.879491 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [EVE2  ]      1.880375 s:  SYSTEM: System EVE Init Done !!!
     [HOST] [EVE3  ]      1.292075 s:  ***** EVE Firmware build time 17:46:43 Jan 22 2019
     [HOST] [EVE3  ]      1.293753 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
     [HOST] [EVE3  ]      1.297139 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [EVE3  ]      1.299213 s:  UTILS: CIO: Init Done !!!
     [HOST] [EVE3  ]      1.300067 s:  SYSTEM: IPC init in progress !!!
     [HOST] [EVE3  ]      1.300951 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [EVE3  ]      1.668730 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [EVE3  ]      1.678429 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [EVE3  ]      1.688312 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [EVE3  ]      1.718416 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [EVE3  ]      1.738302 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [EVE3  ]      1.778289 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [EVE3  ]      1.779235 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [EVE3  ]      1.780516 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [EVE3  ]      1.781766 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [EVE3  ]      1.783017 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [EVE3  ]      1.784298 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [EVE3  ]      1.785579 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [EVE3  ]      1.786829 s:  SYSTEM: Notify init done !!!
     [HOST] [EVE3  ]      1.788659 s:  SYSTEM: MsgQ init done !!!
     [HOST] [EVE3  ]      1.789513 s:  SYSTEM: IPC init DONE !!!
     [HOST] [EVE3  ]      1.802568 s:  SYSTEM: System Common Init Done !!!
     [HOST] [EVE3  ]      1.803422 s:  SYSTEM: System EVE Init in progress !!!
     [HOST] [EVE3  ]      1.804764 s:  UTILS: DMA: HWI Create for INT8 !!!
     [HOST] [EVE3  ]      1.805862 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [EVE3  ]      1.807051 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE3  ]      1.809247 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB)
     [HOST] [EVE3  ]      1.811260 s:  SYSTEM: Initializing Links !!!
     [HOST] [EVE3  ]      1.898218 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [EVE3  ]      1.899103 s:  SYSTEM: System EVE Init Done !!!
     [HOST] [EVE4  ]      1.292106 s:  ***** EVE Firmware build time 17:46:41 Jan 22 2019
     [HOST] [EVE4  ]      1.293783 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
     [HOST] [EVE4  ]      1.297139 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [EVE4  ]      1.299274 s:  UTILS: CIO: Init Done !!!
     [HOST] [EVE4  ]      1.300128 s:  SYSTEM: IPC init in progress !!!
     [HOST] [EVE4  ]      1.301012 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [EVE4  ]      1.688769 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [EVE4  ]      1.698377 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [EVE4  ]      1.708290 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [EVE4  ]      1.738455 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [EVE4  ]      1.758280 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [EVE4  ]      1.778289 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [EVE4  ]      1.779235 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [EVE4  ]      1.780516 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [EVE4  ]      1.781766 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [EVE4  ]      1.783017 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [EVE4  ]      1.784298 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [EVE4  ]      1.785548 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [EVE4  ]      1.786799 s:  SYSTEM: Notify init done !!!
     [HOST] [EVE4  ]      1.788629 s:  SYSTEM: MsgQ init done !!!
     [HOST] [EVE4  ]      1.789452 s:  SYSTEM: IPC init DONE !!!
     [HOST] [EVE4  ]      1.802568 s:  SYSTEM: System Common Init Done !!!
     [HOST] [EVE4  ]      1.803452 s:  SYSTEM: System EVE Init in progress !!!
     [HOST] [EVE4  ]      1.804794 s:  UTILS: DMA: HWI Create for INT8 !!!
     [HOST] [EVE4  ]      1.805892 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [EVE4  ]      1.807051 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE4  ]      1.809278 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB)
     [HOST] [EVE4  ]      1.811291 s:  SYSTEM: Initializing Links !!!
     [HOST] [EVE4  ]      1.898310 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [EVE4  ]      1.899194 s:  SYSTEM: System EVE Init Done !!!
     [HOST] [IPU2  ]      1.183401 s:
     [HOST] [IPU2  ]  EVE1 Image Load Completed
     [HOST] [IPU2  ]      1.214451 s:
     [HOST] [IPU2  ]  EVE2 Image Load Completed
     [HOST] [IPU2  ]      1.245379 s:
     [HOST] [IPU2  ]  EVE3 Image Load Completed
     [HOST] [IPU2  ]      1.276367 s:
     [HOST] [IPU2  ]  EVE4 Image Load Completed
     [HOST] [IPU2  ]      1.276489 s:
     [HOST] [IPU2  ]  EVE MMU configuration completed
     [HOST] [IPU2  ]      1.276581 s:
     [HOST] [IPU2  ]      1.276642 s:
     [HOST] [IPU2  ]      1.276733 s:
     [HOST] [IPU2  ]      1.276794 s:  ***** IPU2 Firmware build time 17:48:43 Jan 22 2019
     [HOST] [IPU2  ]      1.276947 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 16393 Hz>
     [HOST] [IPU2  ]      1.280028 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [IPU2  ]      1.290916 s:  UTILS: CIO: Init Done !!!
     [HOST] [IPU2  ]      1.291069 s:  SYSTEM: IPC init in progress !!!
     [HOST] [IPU2  ]      1.291160 s:  SYSTEM: Attaching to [DSP1] ...
     [HOST] [IPU2  ]      1.365887 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [IPU2  ]      1.607576 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [IPU2  ]      1.628682 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [IPU2  ]      1.648752 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [IPU2  ]      1.668730 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [IPU2  ]      1.688769 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [IPU2  ]      1.688861 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [IPU2  ]      1.689013 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [IPU2  ]      1.689135 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [IPU2  ]      1.689257 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [IPU2  ]      1.689440 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [IPU2  ]      1.689562 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [IPU2  ]      1.689684 s:  SYSTEM: Notify init done !!!
     [HOST] [IPU2  ]      1.691453 s:  SYSTEM: MsgQ init done !!!
     [HOST] [IPU2  ]      1.692399 s: RpmsgInit in progress...
     [HOST] [IPU2  ]      1.692521 s:  SYSTEM: IPC init DONE !!!
     [HOST] [IPU2  ]      1.697706 s:  SYSTEM: System Common Init Done !!!
     [HOST] [IPU2  ]      1.697828 s:  SYSTEM: System Init in progress !!!
     [HOST] [IPU2  ]      1.697889 s:  SYSTEM: BSP Common Init in progress !!!
     [HOST] [IPU2  ]      1.697950 s:  SYSTEM: BSP Common Init Done !!!
     [HOST] [IPU2  ]      1.698011 s:  SYSTEM: BSP Platform Init in progress !!!
     [HOST] [IPU2  ]      1.698102 s:  SYSTEM: BSP Platform Init Done !!!
     [HOST] [IPU2  ]      1.698163 s:  SYSTEM: FVID2 Init in progress !!!
     [HOST] [IPU2  ]      1.698316 s:  SYSTEM: FVID2 Init Done !!!
     [HOST] [IPU2  ]      1.698438 s:  SYSTEM: VPS Init in progress !!!
     [HOST] [IPU2  ]      1.698499 s:  SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
     [HOST] [IPU2  ]      1.701579 s: *** VPDMA Firmware Loading... ***
     [HOST] [IPU2  ]      1.701701 s: VPDMA Firmware Address = 0xa03dc4c0
     [HOST] [IPU2  ]      1.701793 s: VPDMA Load Address     = 0x4897d004
     [HOST] [IPU2  ]      1.701884 s: VPDMA Firmware Version = 0x4d0001b8
     [HOST] [IPU2  ]      1.701976 s: VPDMA List Busy Status = 0x00000000
     [HOST] [IPU2  ]      1.702037 s: *** VPDMA Firmware Load Success ***
     [HOST] [IPU2  ]      1.702464 s: *** VPDMA Firmware Loading... ***
     [HOST] [IPU2  ]      1.702586 s: VPDMA Firmware Address = 0xa03dc4c0
     [HOST] [IPU2  ]      1.702647 s: VPDMA Load Address     = 0x4899d004
     [HOST] [IPU2  ]      1.702738 s: VPDMA Firmware Version = 0x4d0001b8
     [HOST] [IPU2  ]      1.702830 s: VPDMA List Busy Status = 0x00000000
     [HOST] [IPU2  ]      1.702921 s: *** VPDMA Firmware Load Success ***
     [HOST] [IPU2  ]      1.703226 s: *** VPDMA Firmware Loading... ***
     [HOST] [IPU2  ]      1.703348 s: VPDMA Firmware Address = 0xa03dc4c0
     [HOST] [IPU2  ]      1.703440 s: VPDMA Load Address     = 0x489bd004
     [HOST] [IPU2  ]      1.703562 s: VPDMA Firmware Version = 0x4d0001b8
     [HOST] [IPU2  ]      1.703623 s: VPDMA List Busy Status = 0x00000000
     [HOST] [IPU2  ]      1.703715 s: *** VPDMA Firmware Load Success ***
     [HOST] [IPU2  ]      1.704020 s: *** VPDMA Firmware Loading... ***
     [HOST] [IPU2  ]      1.704111 s: VPDMA Firmware Address = 0xa03dc4c0
     [HOST] [IPU2  ]      1.704203 s: VPDMA Load Address     = 0x489dd004
     [HOST] [IPU2  ]      1.704294 s: VPDMA Firmware Version = 0x4d0001b8
     [HOST] [IPU2  ]      1.704416 s: VPDMA List Busy Status = 0x00000000
     [HOST] [IPU2  ]      1.704508 s: *** VPDMA Firmware Load Success ***
     [HOST] [IPU2  ]      1.762185 s:  SYSTEM: VPS Init Done !!!
     [HOST] [IPU2  ]      1.763161 s:  UTILS: DMA: HWI Create for INT25 !!!
     [HOST] [IPU2  ]      1.763496 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [IPU2  ]      1.763618 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254056 B (248 KB)
     [HOST] [IPU2  ]      1.763771 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
     [HOST] [IPU2  ]      1.763923 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 314572800 B (300 MB)
     [HOST] [IPU2  ]      1.764106 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 861056 B (0 MB)
     [HOST] [IPU2  ]      1.764259 s:  SYSTEM: Initializing Links !!!
     [HOST] [IPU2  ]      2.033154 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [IPU2  ]      2.117245 s:  CHAINS: Application Started !!!
     [HOST] [IPU2  ]      2.128469 s:  BOARD: Board Init in progress !!!
     [HOST] [IPU2  ]      2.128926 s:  BOARD: Board Init Done !!!
     [HOST] [IPU2  ]      2.135027 s: Initializing Multi-Deserializer Setup ...!!
     [HOST] [IPU2  ]      2.137284 s:  MultiDes Board Init Done
     [HOST] [IPU2  ]      2.137375 s:
     [HOST] [IPU2  ]      2.137467 s: Display width 1920, Display height 1080
     [HOST] [IPU2  ]      2.137558 s:  CHAINS: ChainsCommon_MultiCam_StartCaptureDevice
     [HOST] [IPU2  ]      2.138046 s:  VIDEO_SENSOR: INST1 : I2C1 : I2C Addr = 0x38
     [HOST] [IPU2  ]      2.487799 s:  VIDEO_SENSOR: VIP 0: DRV ID 1205 (I2C ADDR 0x38): a635:0000:7fa2
     [HOST] [IPU2  ]      2.492893 s:  CAPTURE: Create in progress !!!
     [HOST] [IPU2  ]      2.493137 s:  CAPTURE: VIP1 Slice0 PortA capture mode is [ 8-bit] !!!
     [HOST] [IPU2  ]      2.494296 s:  CAPTURE: Create Done !!!
     [HOST] [IPU2  ]      2.494540 s:  DISPLAY: Create in progress !!!
     [HOST] [IPU2  ]      2.495119 s:  DISPLAY: Create Done !!!
     [HOST] [IPU2  ]      2.495272 s:  DISPLAY: Start in progress !!!
     [HOST] [IPU2  ]      2.495394 s:  DISPLAY: Start Done !!!
     [HOST] [IPU2  ]      2.495516 s:  CAPTURE: Start in progress !!!
     [HOST] [IPU2  ]      2.497681 s:  CAPTURE: Start Done !!!
     [HOST] [IPU2  ]      8.872628 s: Connection established with HLOS, calling rpmsgInit
     [HOST] [IPU2  ]     28.098761 s:  IPC_IN_0   : Create in progress !!!
     [HOST] [IPU2  ]     28.099829 s:  IPC_IN_0   : Create Done !!!
     [HOST] [IPU2  ]     28.100103 s:  DISPLAY: Create in progress !!!
     [HOST] [IPU2  ]     28.100622 s:  DISPLAY: Create Done !!!
     [HOST] [IPU2  ]     28.100774 s:  DISPLAY: Start in progress !!!
     [HOST] [IPU2  ]     28.100835 s:  DISPLAY: Start Done !!!
     [HOST] [HOST  ]     40.147837 s: Enter 'e' to exit
    SPLIT UP OF LOGS
    EARLY BOOT LOGS
    LOGS AFTER LATE ATTACH (NOTICE DIFFERENCE IN TIMESTAMP (~5-6s difference)
    LOGS AFTER APPS.OUT IS RUN (THIS INDICATES WESTON BACKGROUND CAN START)
    (NOTICE DIFFERENCE IN TIMESTAMP ~20s more this is dependent on how soon apps.out is run)
    BELOW ARE A15 LOGS WHICH ARE PRINTED ONLY AFTER APPS.OUT IS RUN
    Hi Gokul,
    Please find attached logs which clearly indicate the split-up based on where each log is printed.
    Shravan
  • Hi Shravan,
    I tried with the online tool onlinehextools.com/convert-hex-to-ascii .  From the earlier mail  I have the file 0871.omapconf.txt.We tried for address 0xA0440000 -value "0x9EFA2EFB". I couldn't see proper text.
    Gokul
  • Hi Gokul,
    I'm assuming the following:
    1. You are in kernel, you have reached Linux prompt
    2. You have built the firmware using Vision-SDK (which also generates an apps.out binary which runs on Linux)
    3. Your end goal is to dump the logs from IPU and other remote-cores.
    If the above assumptions are correct, then:
    Why aren't you running apps.out?
    If you've applied my patches, the apps.out serves only as a tool to drain the remotelog buffers. While it also sends a message to IPU to begin the late part of the chain, this can be easily disabled (just diable the APP_CTRL_LINK_CMD_LINUX_INIT_COMPLETE call in 'main' function in apps/src/hlos/adas/src/common/chains_main.c).
    Hence if my three assumptions are valid, I recommend using apps.out to drain your buffers, and not omapconf.
    Shravan
  • Hi Shravan,
    In our case, apps.out will be launched from systemd service (not manual).
    Usually we will get logs from /sys/kernel/debug/remoteproc/remoteproc0/trace0 for other usecase.
    But for this earlycamera-usecase, I am not seeing logs from this trace0 file
    Can I conclude like this "omapconf will not work".? or I am doing mistake in converting hex to text. I am not sure.
    Thanks & Regards,
    Gokul
  • Hi Gokul,
    I did look at the CCS memory browser and yes, you're correct the trace-buffer is showing non ASCII values. I'm sorry about the earlier dump.
    For the time being can you work off the logs from apps.out (even if its a system-d service you can get the logs of the service using journalctl -u <service_name>).
    Shravan
  • Hi Gokul,
    Please find the logs (with the trace0 entries) for non early boot use-case scenario. As indicated as part of our SDK the trace0 entries aren't enabled (irrespective of early boot or non early boot). The logs for early boot were posted earlier in this thread.
    Shravan
    root@dra7xx-evm:~# cat /sys/kernel/debug/remoteproc/remoteproc1/trace0
    [0][      0.000] 19 Resource entries at 0x99000000
    [1][      0.001] IPU2 starting..
    [1][      0.006] OMAPRPC: registered channel: rpmsg-dce
    [1][      0.007] OMAPRPC: Returning Object @99804028
    [1][      0.008] OMAPRPC: registered channel: dce-callback
    [1][      0.008] OMAPRPC: Returning Object @99809980
    [1][      0.009] OMAPRPC: connecting from local endpoint 101 to port 101
    [1][      0.009] registering rpmsg-rpc:rpmsg-dce service on 101 with HOST
    [1][      0.009] OMAPRPC: started channel rpmsg-dce on port: 101
    [1][      0.010] OMAPRPC: connecting from local endpoint 102 to port 102
    [1][      0.010] registering rpmsg-rpc:dce-callback service on 102 with HOST
    [1][      0.010] OMAPRPC: started channel dce-callback on port: 102
    [1][      0.010] loadTask: started
    [1][      0.010]   SLEEP_TICKS: 1000
    [1][      0.010]   Load_hwiEnabled: 1
    [1][      0.010]   Load_swiEnabled: 1
    [1][      0.010]   Load_taskEnabled: 1
    [1][      0.010]   Load_updateInIdle: 1
    [1][      0.010]   Load_windowInMs: 11
    [1][      0.063] OMAPRPC: received msg type: 0 len: 8 from addr: 1024
    [1][      0.063] OMAPRPC: channel info query - name rpmsg-dce fxns 9
    [1][      0.064] OMAPRPC: Replying with msg type: 1 to addr: 1024  from: 101 len: 12
    [1][      0.065] OMAPRPC: received msg type: 2 len: 216 from addr: 1024
    [1][      0.065] OMAPRPC: function query of type 1
    [1][      0.065] OMAPRPC: Replying with msg type: 3 to addr: 1024  from: 101 len: 216
    [1][      0.066] OMAPRPC: received msg type: 2 len: 216 from addr: 1024
    [1][      0.066] OMAPRPC: function query of type 1
    [1][      0.066] OMAPRPC: Replying with msg type: 3 to addr: 1024  from: 101 len: 216
    [1][      0.067] OMAPRPC: received msg type: 2 len: 216 from addr: 1024
    [1][      0.067] OMAPRPC: function query of type 1
    [1][      0.067] OMAPRPC: Replying with msg type: 3 to addr: 1024  from: 101 len: 216
    [1][      0.068] OMAPRPC: received msg type: 2 len: 216 from addr: 1024
    [1][      0.068] OMAPRPC: function query of type 1
    [1][      0.068] OMAPRPC: Replying with msg type: 3 to addr: 1024  from: 101 len: 216
    [1][      0.069] OMAPRPC: received msg type: 2 len: 216 from addr: 1024
    [1][      0.069] OMAPRPC: function query of type 1
    [1][      0.069] OMAPRPC: Replying with msg type: 3 to addr: 1024  from: 101 len: 216
    [0][      0.076] OMAPRPC: received msg type: 0 len: 8 from addr: 1025
    [0][      0.077] OMAPRPC: channel info query - name dce-callback fxns 4
    [0][      0.077] OMAPRPC: Replying with msg type: 1 to addr: 1025  from: 102 len: 12
    [1][      0.084] OMAPRPC: received msg type: 2 len: 216 from addr: 1025
    [1][      0.084] OMAPRPC: function query of type 1
    [1][      0.084] OMAPRPC: Replying with msg type: 3 to addr: 1025  from: 102 len: 216
    [1][      0.085] OMAPRPC: received msg type: 2 len: 216 from addr: 1025
    [1][      0.085] OMAPRPC: function query of type 1
    [1][      0.085] OMAPRPC: Replying with msg type: 3 to addr: 1025  from: 102 len: 216
    [0][      0.091] registering rpmsg-proto:rpmsg-proto service on 80 with HOST
    root@dra7xx-evm:~# cat /sys/kernel/debug/remoteproc/remoteproc2/trace0
    [      0.000] 25 Resource entries at 0xa1000000
    [      0.590] registering rpmsg-proto:rpmsg-proto service on 80 with HOST
    root@dra7xx-evm:~# cat /sys/kernel/debug/remoteproc/remoteproc3/trace0
    [      0.000] 25 Resource entries at 0xa3000000
    [      0.479] registering rpmsg-proto:rpmsg-proto service on 80 with HOST
    remoteproc0/ remoteproc1/ remoteproc2/ remoteproc3/
    root@dra7xx-evm:~# cd /opt/vision_sdk/
    root@dra7xx-evm:/opt/vision_sdk# ./vision_sdk_load.sh
    [   75.152883] DMA: Module install successful, device major num = 241
    [   75.159404] DRV: Module install successful
    insmod: ERROR: could not load module ./bin/cmemk.ko: No such file or directory
    ./disableDssInterruptsOnA15.sh: line 11: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 12: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 13: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 14: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 15: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 16: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 17: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 18: COMMANDS: command not found
    ./disableDssInterruptsOnA15.sh: line 19: COMMANDS: command not found
    updated  value is
    COMMANDS
            ### WARNING ###: use the following [read | write | set bit | clear bit | dump] commands at your own risk!
            No address check done, may generate:
              - bus error (invalid or not accessible <physical address>,
              - platform crash/hang (bad <value>).
                Read any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
                Write <value> at any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
                Set bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
                Clear bit at <position> into any OMAP memory address (register), given its <physical address> or <name> as listed in TRM.
                Dump a range of OMAP memory addresses, from <start address> to <end address>.
                Note all addresses within given range must be valid and accessible.
            ### WARNING ###: use the following I2C [read | write] commands at your own risk!
              - I2C bus error (invalid or not accessible <physical address>,
                Read I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
                Write <value> in I2C register at address <addr> from I2C chip at <chip-addr> on I2C <bus>.
    root@dra7xx-evm:/opt/vision_sdk# ./apps.out
     [HOST]  OSA: MEM: 0: Mapped 0xa0100000 to 0xb6964000 of size 0x00100000
     [HOST]  OSA: MEM: 1: Mapped 0x84203000 to 0xa3d64000 of size 0x12c00000
     [HOST]  OSA: MEM: 2: Mapped 0xa0200000 to 0xa3ca4000 of size 0x00040000
     [HOST]  OSA: MEM: 3: Mapped 0xa02c0000 to 0xa3ce4000 of size 0x00080000
      77.297007] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
    [   77.356979] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
    [ HOST] [HOST  ]     84.332397 s:  SYSTEM: System A15 Init in proress !!!
     [HOST] [HOST  ]     84.332519 s:  SYSTEM: IPC: Init in progress !!!
     [HOST] [HOST  ]     84.332519 s:  SYSTEM: IPC: Notify init in progress !!!
     [HOST] [HOST  ]     84.333740 s:  SYSTEM: IPC: [IPU2] socket bind success !!! (dst vproc = 1, endpt = 81)
     [HOST] [HOST  ]     84.333770 s:  SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
     [HOST] [HOST  ]     84.333801 s:  SYSTEM: IPC: [IPU2] socket connect success !!! (dst vproc = 1, endpt = 80)
     [HOST] [HOST  ]     84.333831 s:  SYSTEM: IPC: [IPU2] socket info (family = 41, dst proc id = -1, endpt = 1026) !!!
     [HOST] [HOST  ]     84.334990 s:  SYSTEM: IPC: [DSP1] socket bind success !!! (dst vproc = 2, endpt = 81)
     [HOST] [HOST  ]     84.335021 s:  SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
     [HOST] [HOST  ]     84.335021 s:  SYSTEM: IPC: [DSP1] socket connect success !!! (dst vproc = 2, endpt = 80)
     [HOST] [HOST  ]     84.335051 s:  SYSTEM: IPC: [DSP1] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
     [HOST] [HOST  ]     84.336027 s:  SYSTEM: IPC: [DSP2] socket bind success !!! (dst vproc = 3, endpt = 81)
     [HOST] [HOST  ]     84.336058 s:  SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 81) !!!
     [HOST] [HOST  ]     84.336088 s:  SYSTEM: IPC: [DSP2] socket connect success !!! (dst vproc = 3, endpt = 80)
     [HOST] [HOST  ]     84.336088 s:  SYSTEM: IPC: [DSP2] socket info (family = 41, dst proc id = -1, endpt = 1024) !!!
     [HOST] [HOST  ]     84.336241 s:  SYSTEM: IPC: Notify init DONE !!!
     [HOST] [HOST  ]     84.336271 s:  SYSTEM: MSGQ: MsgQ init in progress !!!
     [HOST] [HOST  ]     84.336393 s:  SYSTEM: MSGQ: MsgQ init DONE !!!
     [HOST] [HOST  ]     84.336393 s:  SYSTEM: IPC: Init DONE !!!
     [HOST] [HOST  ]     84.336393 s:  SYSTEM: Initializing A15 Links !!!
     [HOST] [HOST  ]     84.336515 s:  IPC_OUT_0 : Init done - linkid-0x2000000
     [HOST] [HOST  ]     84.336637 s:  IPC_OUT_1 : Init done - linkid-0x2000001
     [HOST] [HOST  ]     84.336759 s:  IPC_OUT_2 : Init done - linkid-0x2000002
     [HOST] [HOST  ]     84.336851 s:  IPC_OUT_3 : Init done - linkid-0x2000003
     [HOST] [HOST  ]     84.336973 s:  IPC_OUT_4 : Init done - linkid-0x2000004
     [HOST] [HOST  ]     84.337125 s:  IPC_IN_0 : Init done - linkid-0x200000a
     [HOST] [HOST  ]     84.337308 s:  IPC_IN_1 : Init done - linkid-0x200000b
     [HOST] [HOST  ]     84.337491 s:  IPC_IN_2 : Init done - linkid-0x200000c
     [HOST] [HOST  ]     84.337644 s:  IPC_IN_3 : Init done - linkid-0x200000d
     [HOST] [HOST  ]     84.337827 s:  IPC_IN_4 : Init done - linkid-0x200000e
     [HOST] [HOST  ]     84.337979 s:  IPC_IN_5 : Init done - linkid-0x200000f
     [HOST] [HOST  ]     84.338132 s:  IPC_IN_6 : Init done - linkid-0x2000010
     [HOST] [HOST  ]     84.338284 s:  NULL_0 : Init done - linkid-0x2000014
     [HOST] [HOST  ]     84.338406 s:  NULL_1 : Init done - linkid-0x2000015
     [HOST] [HOST  ]     84.338589 s:  NULL_SRC_0 : Init done - linkid-0x2000039
     [HOST] [HOST  ]     84.338772 s:  DISP_DIST_SRC_0 : Init done - linkid-0x200005e
     [HOST] [HOST  ]     84.338894 s:  DISP_DIST_SRC_1 : Init done - linkid-0x200005f
     [HOST] [HOST  ]     84.339016 s:  DISP_DIST_SRC_2 : Init done - linkid-0x2000060
     [HOST] [HOST  ]     84.339169 s:  DISP_DIST_SRC_3 : Init done - linkid-0x2000061
     [HOST] [HOST  ]     84.339291 s:  DISP_DIST_SRC_4 : Init done - linkid-0x2000062
     [HOST] [HOST  ]     84.339443 s:  DISP_DIST_SRC_5 : Init done - linkid-0x2000063
     [HOST] [HOST  ]     84.339596 s:  DISP_DIST_SRC_6 : Init done - linkid-0x2000064
     [HOST] [HOST  ]     84.339748 s:  DISP_DIST_SRC_7 : Init done - linkid-0x2000065
     [HOST] [HOST  ]     84.339931 s:  SGX3DSRV_0 : Init done - linkid-0x2000047
     [HOST] [HOST  ]     84.340114 s:  ALGORITHM_0 : Init done - linkid-0x2000031
     [HOST] [HOST  ]     84.340267 s:  ALGORITHM_1 : Init done - linkid-0x2000032
     [HOST] [HOST  ]     84.340419 s:  ALGORITHM_2 : Init done - linkid-0x2000033
     [HOST] [HOST  ]     84.340602 s:  ALGORITHM_3 : Init done - linkid-0x2000034
     [HOST] [HOST  ]     84.340724 s:  ALGORITHM_4 : Init done - linkid-0x2000035
     [HOST] [HOST  ]     84.340877 s:  ALGORITHM_5 : Init done - linkid-0x2000036
     [HOST] [HOST  ]     84.341029 s:  ALGORITHM_6 : Init done - linkid-0x2000037
     [HOST] [HOST  ]     84.341182 s:  ALGORITHM_7 : Init done - linkid-0x2000038
     [HOST] [HOST  ]     84.341365 s:  DUP0 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.341578 s:  DUP1 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.341792 s:  DUP2 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.342005 s:  DUP3 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.342219 s:  DUP4 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.342371 s:  SYNC_0 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.342554 s:  SYNC_1 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.342707 s:  SYNC_2 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.342859 s:  SYNC_3 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.343012 s:  MERGE_0 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.343195 s:  MERGE_1 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.343347 s:  MERGE_2 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.343561 s:  MERGE_3 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.343713 s:  MERGE_4 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.343896 s:  SELECT_0 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.344049 s:  SELECT_1 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.344201 s:  GATE_0 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.344354 s:  GATE_1 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.344506 s:  GATE_2 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.344598 s:  GATE_3 : Init done - linkid-0x0
     [HOST] [HOST  ]     84.344720 s:  SGXFRMCPY_0 : Init done - linkid-0x2000046
     [HOST] [HOST  ]     84.348136 s:  SGX3DSFM_0 : Init done - linkid-0x2000048
     [HOST] [HOST  ]     84.348136 s:  SYSTEM: Initializing A15 Links ... DONE !!!
     [HOST] [HOST  ]     84.350210 s:  OSA: Adjusting global time, timeH by 0 units!!!
     [HOST] [HOST  ]     84.350210 s:  SYSTEM: System A15 Init Done !!!
     [HOST] [HOST  ]     84.350393 s:  NETWORK_CTRL: Starting Server (port=5000) !!!
     [HOST] [HOST  ]     84.350454 s:  NETWORK_CTRL: Starting Server ... DONE (port=5000) !!!
     [HOST] [DSP1  ]     16.256938 s:  ***** DSP1 Firmware build time 13:46:06 Dec 18 2018
     [HOST] [DSP1  ]     16.257030 s:  *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
     [HOST] [DSP1  ]     16.257274 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [DSP1  ]     16.257518 s:  UTILS: CIO: Init Done !!!
     [HOST] [DSP1  ]     16.257548 s:  SYSTEM: IPC init in progress !!!
     [HOST] [DSP1  ]     16.257548 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP1  ]     16.766851 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [DSP1  ]     16.771762 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [DSP1  ]     16.788812 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [DSP1  ]     16.808820 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [DSP1  ]     16.828890 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [DSP1  ]     16.848837 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [DSP1  ]     16.848868 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [DSP1  ]     16.848929 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [DSP1  ]     16.848990 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [DSP1  ]     16.849020 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [DSP1  ]     16.849081 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [DSP1  ]     16.849142 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [DSP1  ]     16.849173 s:  SYSTEM: Notify init done !!!
     [HOST] [DSP1  ]     16.849356 s:  SYSTEM: MsgQ init done !!!
     [HOST] [DSP1  ]     16.849447 s: RpmsgInit in progress...
     [HOST] [DSP1  ]     16.849478 s: Connection established with HLOS, calling rpmsgInit
     [HOST] [DSP1  ]     16.849691 s:  SYSTEM: IPC init DONE !!!
     [HOST] [DSP1  ]     16.850301 s:  SYSTEM: System Common Init Done !!!
     [HOST] [DSP1  ]     16.850332 s:  SYSTEM: System DSP Init in progress !!!
     [HOST] [DSP1  ]     16.850545 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [DSP1  ]     16.850606 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
     [HOST] [DSP1  ]     16.850667 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516216 B (504 KB)
     [HOST] [DSP1  ]     16.850698 s:  SYSTEM: Initializing Links !!!
     [HOST] [DSP1  ]     16.859421 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [DSP1  ]     16.859482 s: lz4CompDecomp Init
     [HOST] [DSP1  ]     16.859482 s:  SYSTEM: System DSP Init Done !!!
     [HOST] [DSP1  ]     17.097633 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
     [HOST] [DSP1  ]     17.097694 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
     [HOST] [DSP2  ]     16.379308 s: ***** DSP2 Firmware build time 13:46:07 Dec 18 2018
     [HOST] [DSP2  ]     16.379369 s:  *** SYSTEM: CPU Frequency <ORG = 600000000 Hz>, <NEW = 750000000 Hz>
     [HOST] [DSP2  ]     16.379643 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [DSP2  ]     16.379857 s:  UTILS: CIO: Init Done !!!
     [HOST] [DSP2  ]     16.379887 s:  SYSTEM: IPC init in progress !!!
     [HOST] [DSP2  ]     16.379918 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [DSP2  ]     16.769810 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [DSP2  ]     16.771762 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [DSP2  ]     16.798725 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [DSP2  ]     16.818733 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [DSP2  ]     16.838742 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [DSP2  ]     16.858750 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [DSP2  ]     16.858781 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [DSP2  ]     16.858842 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [DSP2  ]     16.858903 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [DSP2  ]     16.858933 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [DSP2  ]     16.858994 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [DSP2  ]     16.859055 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [DSP2  ]     16.859086 s:  SYSTEM: Notify init done !!!
     [HOST] [DSP2  ]     16.859269 s:  SYSTEM: MsgQ init done !!!
     [HOST] [DSP2  ]     16.859360 s: RpmsgInit in progress...
     [HOST] [DSP2  ]     16.859391 s: Connection established with HLOS, calling rpmsgInit
     [HOST] [DSP2  ]     16.859604 s:  SYSTEM: IPC init DONE !!!
     [HOST] [DSP2  ]     16.860214 s:  SYSTEM: System Common Init Done !!!
     [HOST] [DSP2  ]     16.860245 s:  SYSTEM: System DSP Init in progress !!!
     [HOST] [DSP2  ]     16.860489 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [DSP2  ]     16.860550 s:  SYSTEM: Heap = LOCAL_L2             @ 0x00800000, Total size = 227264 B (221 KB), Free size = 227264 B (221 KB)
     [HOST] [DSP2  ]     16.860580 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 524288 B (512 KB), Free size = 516216 B (504 KB)
     [HOST] [DSP2  ]     16.860611 s:  SYSTEM: Initializing Links !!!
     [HOST] [DSP2  ]     16.869456 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [DSP2  ]     16.869517 s: lz4CompDecomp Init
     [HOST] [DSP2  ]     16.869517 s:  SYSTEM: System DSP Init Done !!!
     [HOST] [DSP2  ]     17.099646 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after boot !!!
     [HOST] [DSP2  ]     17.099676 s:  SYSTEM: CACHE: L1P = 32 KB, L1D = 32 KB, L2 = 32 KB ... after update by APP !!!
     [HOST] [EVE1  ]     16.761880 s:  ***** EVE Firmware build time 13:45:16 Dec 18 2018
     [HOST] [EVE1  ]     16.763588 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
     [HOST] [EVE1  ]     16.766302 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [EVE1  ]     16.768498 s:  UTILS: CIO: Init Done !!!
     [HOST] [EVE1  ]     16.769444 s:  SYSTEM: IPC init in progress !!!
     [HOST] [EVE1  ]     16.770420 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [EVE1  ]     16.779143 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [EVE1  ]     16.788812 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [EVE1  ]     16.798725 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [EVE1  ]     16.838894 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [EVE1  ]     16.868846 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [EVE1  ]     16.888885 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [EVE1  ]     16.889953 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [EVE1  ]     16.891173 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [EVE1  ]     16.892393 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [EVE1  ]     16.893613 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [EVE1  ]     16.894863 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [EVE1  ]     16.896114 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [EVE1  ]     16.897303 s:  SYSTEM: Notify init done !!!
     [HOST] [EVE1  ]     16.898981 s:  SYSTEM: MsgQ init done !!!
     [HOST] [EVE1  ]     16.899835 s:  SYSTEM: IPC init DONE !!!
     [HOST] [EVE1  ]     16.912340 s:  SYSTEM: System Common Init Done !!!
     [HOST] [EVE1  ]     16.913286 s:  SYSTEM: System EVE Init in progress !!!
     [HOST] [EVE1  ]     16.914658 s:  UTILS: DMA: HWI Create for INT8 !!!
     [HOST] [EVE1  ]     16.915756 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [EVE1  ]     16.916915 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE1  ]     16.919203 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB)
     [HOST] [EVE1  ]     16.921246 s:  SYSTEM: Initializing Links !!!
     [HOST] [EVE1  ]     17.007930 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [EVE1  ]     17.008906 s:  SYSTEM: System EVE Init Done !!!
     [HOST] [EVE2  ]     16.762368 s:  ***** EVE Firmware build time 13:45:17 Dec 18 2018
     [HOST] [EVE2  ]     16.764106 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
     [HOST] [EVE2  ]     16.767614 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [EVE2  ]     16.769749 s:  UTILS: CIO: Init Done !!!
     [HOST] [EVE2  ]     16.770725 s:  SYSTEM: IPC init in progress !!!
     [HOST] [EVE2  ]     16.771670 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [EVE2  ]     16.799182 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [EVE2  ]     16.808820 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [EVE2  ]     16.818733 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [EVE2  ]     16.838894 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [EVE2  ]     16.888732 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [EVE2  ]     16.908711 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [EVE2  ]     16.909748 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [EVE2  ]     16.910998 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [EVE2  ]     16.912310 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [EVE2  ]     16.913621 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [EVE2  ]     16.914902 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [EVE2  ]     16.916153 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [EVE2  ]     16.917434 s:  SYSTEM: Notify init done !!!
     [HOST] [EVE2  ]     16.919203 s:  SYSTEM: MsgQ init done !!!
     [HOST] [EVE2  ]     16.920118 s:  SYSTEM: IPC init DONE !!!
     [HOST] [EVE2  ]     16.933020 s:  SYSTEM: System Common Init Done !!!
     [HOST] [EVE2  ]     16.934026 s:  SYSTEM: System EVE Init in progress !!!
     [HOST] [EVE2  ]     16.935521 s:  UTILS: DMA: HWI Create for INT8 !!!
     [HOST] [EVE2  ]     16.936649 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [EVE2  ]     16.937961 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE2  ]     16.940370 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB)
     [HOST] [EVE2  ]     16.942444 s:  SYSTEM: Initializing Links !!!
     [HOST] [EVE2  ]     17.029768 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [EVE2  ]     17.030683 s:  SYSTEM: System EVE Init Done !!!
     [HOST] [EVE3  ]     16.762185 s:  ***** EVE Firmware build time 13:45:15 Dec 18 2018
     [HOST] [EVE3  ]     16.763923 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
     [HOST] [EVE3  ]     16.766729 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [EVE3  ]     16.768864 s:  UTILS: CIO: Init Done !!!
     [HOST] [EVE3  ]     16.769779 s:  SYSTEM: IPC init in progress !!!
     [HOST] [EVE3  ]     16.770725 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [EVE3  ]     16.819160 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [EVE3  ]     16.828890 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [EVE3  ]     16.838742 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [EVE3  ]     16.868846 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [EVE3  ]     16.888732 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [EVE3  ]     16.928719 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [EVE3  ]     16.929787 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [EVE3  ]     16.931098 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [EVE3  ]     16.932471 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [EVE3  ]     16.933843 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [EVE3  ]     16.935216 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [EVE3  ]     16.936588 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [EVE3  ]     16.938022 s:  SYSTEM: Notify init done !!!
     [HOST] [EVE3  ]     16.939882 s:  SYSTEM: MsgQ init done !!!
     [HOST] [EVE3  ]     16.940797 s:  SYSTEM: IPC init DONE !!!
     [HOST] [EVE3  ]     16.953821 s:  SYSTEM: System Common Init Done !!!
     [HOST] [EVE3  ]     16.954797 s:  SYSTEM: System EVE Init in progress !!!
     [HOST] [EVE3  ]     16.956231 s:  UTILS: DMA: HWI Create for INT8 !!!
     [HOST] [EVE3  ]     16.957420 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [EVE3  ]     16.958732 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE3  ]     16.960958 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB)
     [HOST] [EVE3  ]     16.963063 s:  SYSTEM: Initializing Links !!!
     [HOST] [EVE3  ]     17.049197 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [EVE3  ]     17.050143 s:  SYSTEM: System EVE Init Done !!!
     [HOST] [EVE4  ]     16.762398 s:  ***** EVE Firmware build time 13:45:16 Dec 18 2018
     [HOST] [EVE4  ]     16.764106 s:  *** SYSTEM: CPU Frequency <ORG = 267500000 Hz>, <NEW = 267500000 Hz>
     [HOST] [EVE4  ]     16.767614 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [EVE4  ]     16.769749 s:  UTILS: CIO: Init Done !!!
     [HOST] [EVE4  ]     16.770694 s:  SYSTEM: IPC init in progress !!!
     [HOST] [EVE4  ]     16.771670 s:  SYSTEM: Attaching to [IPU2] ...
     [HOST] [EVE4  ]     16.839199 s:  SYSTEM: Attaching to [IPU2] ... SUCCESS !!!
     [HOST] [EVE4  ]     16.848837 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [EVE4  ]     16.858750 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [EVE4  ]     16.888885 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [EVE4  ]     16.908711 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [EVE4  ]     16.928719 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [EVE4  ]     16.929756 s:  SYSTEM: Notify register to [IPU2] line 0, event 15...
     [HOST] [EVE4  ]     16.931098 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [EVE4  ]     16.932471 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [EVE4  ]     16.933843 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [EVE4  ]     16.935185 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [EVE4  ]     16.936588 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [EVE4  ]     16.938022 s:  SYSTEM: Notify init done !!!
     [HOST] [EVE4  ]     16.939882 s:  SYSTEM: MsgQ init done !!!
     [HOST] [EVE4  ]     16.940797 s:  SYSTEM: IPC init DONE !!!
     [HOST] [EVE4  ]     16.953913 s:  SYSTEM: System Common Init Done !!!
     [HOST] [EVE4  ]     16.954858 s:  SYSTEM: System EVE Init in progress !!!
     [HOST] [EVE4  ]     16.956292 s:  UTILS: DMA: HWI Create for INT8 !!!
     [HOST] [EVE4  ]     16.957451 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [EVE4  ]     16.958762 s:  SYSTEM: Heap = LOCAL_L2             @ 0x40020000, Total size = 22528 B (22 KB), Free size = 22528 B (22 KB)
     [HOST] [EVE4  ]     16.960989 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 262144 B (256 KB), Free size = 254320 B (248 KB)
     [HOST] [EVE4  ]     16.963094 s:  SYSTEM: Initializing Links !!!
     [HOST] [EVE4  ]     17.049380 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [EVE4  ]     17.050356 s:  SYSTEM: System EVE Init Done !!!
     [HOST] [IPU2  ]     16.654822 s:
     [HOST] [IPU2  ]     16.685414 s:
     [HOST] [IPU2  ]     16.715945 s:
     [HOST] [IPU2  ]     16.746660 s:
     [HOST] [IPU2  ]     16.746782 s:
     [HOST] [IPU2  ]     16.746873 s:
     [HOST] [IPU2  ]     16.746965 s:
     [HOST] [IPU2  ]     16.747026 s:
     [HOST] [IPU2  ]     16.748734 s:  ***** IPU2 Firmware build time 13:47:22 Dec 18 2018
     [HOST] [IPU2  ]     16.748947 s:  *** SYSTEM: CPU Frequency <ORG = 212800000 Hz>, <NEW = 212800000 Hz>
     [HOST] [IPU2  ]     16.751997 s:  SYSTEM: System Common Init in progress !!!
     [HOST] [IPU2  ]     16.763405 s:  UTILS: CIO: Init Done !!!
     [HOST] [IPU2  ]     16.763496 s:  SYSTEM: IPC init in progress !!!
     [HOST] [IPU2  ]     16.763588 s:  SYSTEM: Attaching to [DSP1] ...
     [HOST] [IPU2  ]     16.766851 s:  SYSTEM: Attaching to [DSP1] ... SUCCESS !!!
     [HOST] [IPU2  ]     16.769840 s:  SYSTEM: Attaching to [DSP2] ... SUCCESS !!!
     [HOST] [IPU2  ]     16.779143 s:  SYSTEM: Attaching to [EVE1] ... SUCCESS !!!
     [HOST] [IPU2  ]     16.799182 s:  SYSTEM: Attaching to [EVE2] ... SUCCESS !!!
     [HOST] [IPU2  ]     16.819160 s:  SYSTEM: Attaching to [EVE3] ... SUCCESS !!!
     [HOST] [IPU2  ]     16.839199 s:  SYSTEM: Attaching to [EVE4] ... SUCCESS !!!
     [HOST] [IPU2  ]     16.839321 s:  SYSTEM: Notify register to [DSP1] line 0, event 15...
     [HOST] [IPU2  ]     16.839474 s:  SYSTEM: Notify register to [DSP2] line 0, event 15...
     [HOST] [IPU2  ]     16.839596 s:  SYSTEM: Notify register to [EVE1] line 0, event 15...
     [HOST] [IPU2  ]     16.839687 s:  SYSTEM: Notify register to [EVE2] line 0, event 15...
     [HOST] [IPU2  ]     16.839809 s:  SYSTEM: Notify register to [EVE3] line 0, event 15...
     [HOST] [IPU2  ]     16.839931 s:  SYSTEM: Notify register to [EVE4] line 0, event 15...
     [HOST] [IPU2  ]     16.840023 s:  SYSTEM: Notify init done !!!
     [HOST] [IPU2  ]     16.841761 s:  SYSTEM: MsgQ init done !!!
     [HOST] [IPU2  ]     16.842707 s: RpmsgInit in progress...
     [HOST] [IPU2  ]     16.842798 s: Connection established with HLOS, calling rpmsgInit
     [HOST] [IPU2  ]     16.843134 s:  SYSTEM: IPC init DONE !!!
     [HOST] [IPU2  ]     16.847892 s:  SYSTEM: System Common Init Done !!!
     [HOST] [IPU2  ]     16.848014 s:  SYSTEM: System Init in progress !!!
     [HOST] [IPU2  ]     16.848075 s:  SYSTEM: BSP Common Init in progress !!!
     [HOST] [IPU2  ]     16.848136 s:  SYSTEM: BSP Common Init Done !!!
     [HOST] [IPU2  ]     16.848197 s:  SYSTEM: BSP Platform Init in progress !!!
     [HOST] [IPU2  ]     16.848288 s:  SYSTEM: BSP Platform Init Done !!!
     [HOST] [IPU2  ]     16.848410 s:  SYSTEM: FVID2 Init in progress !!!
     [HOST] [IPU2  ]     16.848563 s:  SYSTEM: FVID2 Init Done !!!
     [HOST] [IPU2  ]     16.848624 s:  SYSTEM: VPS Init in progress !!!
     [HOST] [IPU2  ]     16.848685 s:  SYSTEM: VPDMA Descriptor Memory Address translation ENABLED [0x80000000 -> 0x80000000]
     [HOST] [IPU2  ]     16.851735 s: *** VPDMA Firmware Loading... ***
     [HOST] [IPU2  ]     16.851826 s: VPDMA Firmware Address = 0xa03dc4c0
     [HOST] [IPU2  ]     16.851918 s: VPDMA Load Address     = 0x4897d004
     [HOST] [IPU2  ]     16.852040 s: VPDMA Firmware Version = 0x4d0001b8
     [HOST] [IPU2  ]     16.852101 s: VPDMA List Busy Status = 0x00000000
     [HOST] [IPU2  ]     16.852193 s: *** VPDMA Firmware Load Success ***
     [HOST] [IPU2  ]     16.852589 s: *** VPDMA Firmware Loading... ***
     [HOST] [IPU2  ]     16.852681 s: VPDMA Firmware Address = 0xa03dc4c0
     [HOST] [IPU2  ]     16.852772 s: VPDMA Load Address     = 0x4899d004
     [HOST] [IPU2  ]     16.852864 s: VPDMA Firmware Version = 0x4d0001b8
     [HOST] [IPU2  ]     16.852955 s: VPDMA List Busy Status = 0x00000000
     [HOST] [IPU2  ]     16.853016 s: *** VPDMA Firmware Load Success ***
     [HOST] [IPU2  ]     16.853382 s: *** VPDMA Firmware Loading... ***
     [HOST] [IPU2  ]     16.853474 s: VPDMA Firmware Address = 0xa03dc4c0
     [HOST] [IPU2  ]     16.853565 s: VPDMA Load Address     = 0x489bd004
     [HOST] [IPU2  ]     16.853657 s: VPDMA Firmware Version = 0x4d0001b8
     [HOST] [IPU2  ]     16.853748 s: VPDMA List Busy Status = 0x00000000
     [HOST] [IPU2  ]     16.853809 s: *** VPDMA Firmware Load Success ***
     [HOST] [IPU2  ]     16.854145 s: *** VPDMA Firmware Loading... ***
     [HOST] [IPU2  ]     16.854236 s: VPDMA Firmware Address = 0xa03dc4c0
     [HOST] [IPU2  ]     16.854358 s: VPDMA Load Address     = 0x489dd004
     [HOST] [IPU2  ]     16.854450 s: VPDMA Firmware Version = 0x4d0001b8
     [HOST] [IPU2  ]     16.854541 s: VPDMA List Busy Status = 0x00000000
     [HOST] [IPU2  ]     16.854602 s: *** VPDMA Firmware Load Success ***
     [HOST] [IPU2  ]     16.913896 s:  SYSTEM: VPS Init Done !!!
     [HOST] [IPU2  ]     16.914811 s:  UTILS: DMA: HWI Create for INT25 !!!
     [HOST] [IPU2  ]     16.915024 s:  SYSTEM: SW Message Box Msg Pool, Free Msg Count = 1024
     [HOST] [IPU2  ]     16.915146 s:  SYSTEM: Heap = LOCAL_DDR            @ 0x00000000, Total size = 41943040 B (40960 KB), Free size = 41873776 B (40892 KB)
     [HOST] [IPU2  ]     16.915360 s:  SYSTEM: Heap = SR_OCMC              @ 0x00000000, Total size = 0 B (0 KB), Free size = 0 B (0 KB)
     [HOST] [IPU2  ]     16.915512 s:  SYSTEM: Heap = SR_DDR_CACHED        @ 0x84203000, Total size = 314572800 B (300 MB), Free size = 314572800 B (300 MB)
     [HOST] [IPU2  ]     16.915695 s:  SYSTEM: Heap = SR_DDR_NON_CACHED    @ 0xa0100000, Total size = 1045376 B (0 MB), Free size = 861056 B (0 MB)
     [HOST] [IPU2  ]     16.915848 s:  SYSTEM: Initializing Links !!!
     [HOST] [IPU2  ]     17.089489 s:  SYSTEM: Initializing Links ... DONE !!!
     [HOST] [IPU2  ]     17.177697 s:  CHAINS: Application Started !!!
     [HOST] [IPU2  ]     17.187732 s:  BOARD: Board Init in progress !!!
     [HOST] [IPU2  ]     17.188190 s:  BOARD: Board Init Done !!!
     [HOST] [IPU2  ]     17.193710 s: Initializing Multi-Deserializer Setup ...!!
     [HOST] [IPU2  ]     17.195113 s:  MultiDes Board Init Done
     [HOST] [IPU2  ]     17.195174 s:
     [HOST] [HOST  ]     84.921216 s:
     [HOST] [HOST  ]
     [HOST] [HOST  ]  ====================
     [HOST] [HOST  ]  Vision SDK Usecases
     [HOST] [HOST  ]  1: Single Camera Usecases
     [HOST] [HOST  ]  2: Multi-Camera LVDS Usecases
     [HOST] [HOST  ]  3: Open-Compute Usecases
     [HOST] [HOST  ]  6: Radar Usecases
     [HOST] [HOST  ]
     [HOST] [HOST  ]  p: CPU Status
     [HOST] [HOST  ]  i: Show IP Addr (IPU + NDK + AVB)
     [HOST] [HOST  ]
     [HOST] [HOST  ]  s: System Settings
     [HOST] [HOST  ]
     [HOST] [HOST  ]  x: Exit
     [HOST] [HOST  ]  z: Exit - AND SHUTDOWN Remote CPUs
     [HOST] [HOST  ]
     [HOST] [HOST  ]  Enter Choice:
