RTOS/TDA2PXEVM: I want to change DDR memory map form 1GB to 2GB
Part Number: TDA2PXEVM
Tool/software: TI-RTOS
I made custom board. So, I changed DDR3 2GiB.(1GiB + 1GiB)
I changed the code by referring to the Memory Map for vision SDK application report(Draft v0.3)
so, I try the option Dual_emif_2X512MB and Dual_emif_1GB_512MB. Both of these options will boot normally.
but, I change 2GiB memory map.It stops like the following log.
 TDA2Px SBL Boot
 DPLL Configuration Completed
 Clock Domain Configuration Completed
 Module Enable Configuration Completed
 TI EVM PAD Config Completed
 TDA2Px DDR Configuration
 DDR Config Completed
 App Image Download Begins
 SD Boot - file open completed successfully
 MPU CPU0 Image Load Completed
 IPU1 CPU0 Image Load Completed
 IPU1 CPU1 Image Load Completed
 IPU2 CPU0 and CPU1 Image Load Completed
 DSP1 Image Load Completed
 DSP2 Image Load Completed
 EVE1 Image Load Completed
 EVE2 Image Load Completed
 App Image Download Completed
 Putting MPU CPU1 in Off mode
 EVE MMU configuration completed
 PMCCNTR counts once every 64 clock cycles, multiple by 64 to get actual CPU cycles
 SBL Initial Config Cycles - 116295  (9.92 ms)
 SOC Init Cycles - 171037  (14.59 ms)
 DDR Config Clock Cycles - 89904  (7.67 ms)
 App Image Load Cycles - 153145209  (13068.39 ms)
 Slave Core Bootup Cycles - 130271  (11.11 ms)
 SBL Boot-up Cycles - 153653773  (13111.78 ms)
 Time at which SBL started IPU1_0 - 551351  (47.4 ms)
 Jumping to MPU CPU0 App
And 2GiB was modified as shown below.
diff --git a/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/sbl_utils/src/tda2xx/sbl_utils_tda2px_ddr_config.c b/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/sbl_utils/src/tda2xx/sbl_utils_tda2px_ddr_config.c
index 6151b14..1620eb1 100644
--- a/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/sbl_utils/src/tda2xx/sbl_utils_tda2px_ddr_config.c
+++ b/ti_components/drivers/pdk_01_10_02_07/packages/ti/boot/sbl_auto/sbl_utils/src/tda2xx/sbl_utils_tda2px_ddr_config.c
@@ -484,11 +484,11 @@ static void TDA2Px_set_lisa_maps(void)
         SBLLibPrintf(SBLLIB_TRACE_LEVEL_DEBUG,
                      "       Two EMIFs in non interleaved mode (2GB total)\n");
         /* MA_LISA_MAP_i */
-        HW_WR_REG32(SOC_MA_MPU_CONF_REGS_BASE + LISA_MAP_0, 0x80740300U);
-        HW_WR_REG32(SOC_MA_MPU_CONF_REGS_BASE + LISA_MAP_1, 0xFF020100U);
+        HW_WR_REG32(SOC_MA_MPU_CONF_REGS_BASE + LISA_MAP_0, 0x80700200U);
+        HW_WR_REG32(SOC_MA_MPU_CONF_REGS_BASE + LISA_MAP_1, 0xC0700100U);
         /* DMM_LISA_MAP_i */
-        HW_WR_REG32(SOC_DMM_CONF_REGS_BASE + LISA_MAP_0, 0x80740300U);
-        HW_WR_REG32(SOC_DMM_CONF_REGS_BASE + LISA_MAP_1, 0xFF020100U);
+        HW_WR_REG32(SOC_DMM_CONF_REGS_BASE + LISA_MAP_0, 0x80700200U);
+        HW_WR_REG32(SOC_DMM_CONF_REGS_BASE + LISA_MAP_1, 0xC0700100U);
 #endif
diff --git a/vision_sdk/apps/build/tda2px/mem_segment_definition_bios.xs b/vision_sdk/apps/build/tda2px/mem_segment_definition_bios.xs
index 9a19da1..5e3b7be 100755
--- a/vision_sdk/apps/build/tda2px/mem_segment_definition_bios.xs
+++ b/vision_sdk/apps/build/tda2px/mem_segment_definition_bios.xs
@@ -18,7 +18,7 @@ function getMemSegmentDefinition_external(core)
     MB=KB*KB;
     DDR3_ADDR                   = 0x80000000;
-    DDR3_SIZE                   = 512*MB;
+    DDR3_SIZE                   = 2048*MB;
      * In case of ECC_FFI_INCLUDE, DDR3_BASE_ADDR_1 and DDR3_BASE_SIZE_1
@@ -27,7 +27,7 @@ function getMemSegmentDefinition_external(core)
      * If this DDR3_BASE_SIZE_0 is changed, update  Ipu1_0.cfg
     DDR3_BASE_ADDR_0            = DDR3_ADDR;
-    DDR3_BASE_SIZE_0            = 508*MB;
+    DDR3_BASE_SIZE_0            = 1024*MB;
     /* The start address of the second mem section should be 16MB aligned.
      * This alignment is a must as a single 16MB mapping is used for EVE
@@ -42,7 +42,7 @@ function getMemSegmentDefinition_external(core)
          *  in non-cached virtual address of
          *  DDR3_BASE_ADDR_1 + 512*MB
-        DDR3_BASE_ADDR_1        = DDR3_BASE_ADDR_1+512*MB;
+/*        DDR3_BASE_ADDR_1        = DDR3_BASE_ADDR_1+512*MB; */
     DSP1_L2_SRAM_ADDR           = 0x40800000;
diff --git a/vision_sdk/apps/configs/tda2px_evm_bios_all/cfg.mk b/vision_sdk/apps/configs/tda2px_evm_bios_all/cfg.mk
index 9bc797c..479221a 100755
--- a/vision_sdk/apps/configs/tda2px_evm_bios_all/cfg.mk
+++ b/vision_sdk/apps/configs/tda2px_evm_bios_all/cfg.mk
@@ -31,7 +31,7 @@ VSDK_BOARD_TYPE=TDA2PX_EVM
 DUAL_A15_SMP_BIOS=no
 # Supported values: DDR_MEM_512M
-DDR_MEM=DDR_MEM_512M
+DDR_MEM=DDR_MEM_1024M
 EMIFMODE=DUAL_EMIF_1GB_1GB
 # Supported values: ipu1_0 ipu1_1 a15_0 none
diff --git a/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/a15_0/a15_0.cfg b/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/a15_0/a15_0.cfg
index efa9900..e287d61 100755
--- a/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/a15_0/a15_0.cfg
+++ b/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/a15_0/a15_0.cfg
@@ -146,7 +146,7 @@ attrs1.shareable = 2;                      // sharerable
 attrs1.attrIndx = 2;                       // Cached, normal memory
 // Set the descriptor for each entry in the address range
-for (var i=0x80000000; i < 0xA0000000; i = i + 0x00200000) {
+for (var i=0x80000000; i < 0xC0000000; i = i + 0x00200000) {
     // Each 'BLOCK' descriptor entry spans a 2MB address range
     Mmu.setSecondLevelDescMeta(i, i, attrs1);
@@ -160,9 +160,9 @@ attrs2.shareable = 2;                      // sharerable
 attrs2.attrIndx = 0;                       // Non-cache, normal memory
-for (var i=0xA0000000; i < 0xC0000000; i = i + 0x00200000) {
+for (var i=0xC0000000; i <= 0xFFFFFFFF; i = i + 0x00200000) {
-    Mmu.setSecondLevelDescMeta(i, i-0x20000000, attrs2);
+    Mmu.setSecondLevelDescMeta(i, i, attrs2);
 // Region for NDK packet data buffers.
diff --git a/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu1_0/Ammu1_bios.cfg b/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu1_0/Ammu1_bios.cfg
index a5b6652..46da588 100755
--- a/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu1_0/Ammu1_bios.cfg
+++ b/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu1_0/Ammu1_bios.cfg
@@ -204,13 +204,14 @@ function init()
     entry.pageEnabled = AMMU.Enable_YES;
     entry.translationEnabled = AMMU.Enable_YES;
     entry.logicalAddress = 0xA0000000;
-    entry.translatedAddress = 0x80000000;
+    entry.translatedAddress = 0xA0000000;
     entry.size = AMMU.Large_512M;
     entry.L1_cacheable = AMMU.CachePolicy_NON_CACHEABLE;
     entry.L1_posted = AMMU.PostedPolicy_NON_POSTED;
     entry.L2_cacheable = AMMU.CachePolicy_NON_CACHEABLE;
     entry.L2_posted = AMMU.PostedPolicy_NON_POSTED;
     var entry = AMMU.largePages[3];
@@ -221,6 +222,6 @@ function init()
diff --git a/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu2/Ammu2_bios.cfg b/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu2/Ammu2_bios.cfg
index f7ca5f8..60aa355 100755
--- a/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu2/Ammu2_bios.cfg
+++ b/vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu2/Ammu2_bios.cfg
@@ -204,13 +204,13 @@ function init()
@@ -221,5 +221,5 @@ function init()
\ No newline at end of file
There is a normal 1.5GiB.
index 9a19da1..139434e 100755
     MB=KB*KB;
+    DDR3_SIZE                   = (1024+512)*MB;
+    DDR3_BASE_SIZE_0            = 512*MB;
index efa9900..4dd1e55 100755
@@ -162,7 +162,7 @@ attrs2.attrIndx = 0;                       // Non-cache, normal memory
Thanks.
    Can you try to connect to all CPUs using CCS (make sure configuration has no gel) and see their states.
    You might need to load symbols to identify the CPU that has crashed.
    Rishabh
    I haven't heard back from you, I'm assuming you were able to resolve your issue.
    If not, just post a reply below (or create a new thread if the thread has locked due to time-out).
    Rishabh
    Our company system has blocked file updates.
    So, I would like to receive a guide from the Vision SDK that changed the DDR memory map from 512MB to 2GB.
    kyungtae
    I am not asking for file updates. You can check for CPU states using CCS.
    Also did you update vpsLibInitPrms.isAddrTransReq to FALSE for changing the memory map to 2 GB?
    Rishabh
    I am sorry. I misunderstood your comment.
    I set isAddrTransReq to FALSE in the file below.
    vision_sdk/links_fw/src/rtos/links_ipu/system/system_bsp_init.c
    290 line
    /* This one to one mapping is required for the 1GB builds */
    vpsInitPrms.virtBaseAddr = 0x80000000U;
    vpsInitPrms.physBaseAddr = 0x80000000U;
    vpsInitPrms.isAddrTransReq = FALSE;
    kyungtae
    Can you please update on the state of different CPUs in order to progress on this issue.
    Also did the VPS change have any effect on the boot?
    Rishabh
    1. Can you please update on the state of different CPUs in order to progress on this issue.
    - CortexA15_0 is follows.
    main_common_a15_0.c(168 line, BIOS start())-->system_common.c(752 line, memset(&gSystem_objCommon, 0, sizeof(gSystem_objCommon));)
    -> system_ipc_bios_ipc.c(474 line)
    Void System_ipcStart(void)
        Int32 status = Ipc_S_SUCCESS;
        do
            status = Ipc_start();
        } while (status != Ipc_S_SUCCESS);   ---> this point hang
        /* In case of fast boot System_ipcStart() will be called late,
         * after all cores are up & Notify_registerEvent is not called
         * under System_ipcNotifyInit(), so needs to be called here.
        if(ti_sdo_ipc_Ipc_procSync == ti_sdo_ipc_Ipc_ProcSync_ALL)
            System_ipcNotifyRegister();
    IPC.c(698 line)
        /* Check whether Ipc_start has been called.  If so, succeed. */
        if (Ipc_module->ipcSharedAddr != NULL) {
            return (Ipc_S_ALREADYSETUP);
    - M4_IPU1_C0 is follows.
    ti_sysbios_family_arm_m3_Hwi_excHandler_I -> ti_sysbios_family_arm_m3_Hwi_excHandlerMax_I -> ti_sysbios_BIOS_exitFunc_I
    -> xdc_runtime_System_exit_E -> exit -> abort
    - M4_IPU1_C1 is follows.
    main_ipu1_1.c
    - M4_IPU2_C0 is follows.
    ti_sysbios_BIOS_errorRaiseHook_I -> Utils_commonErrorRaiseHook -> vpsprint -> RemoteLog_serverPustring
    2. Also did the VPS change have any effect on the boot?
    Sorry, I don't know.
    kyungtae
    Can you check the board schematics to make sure that you have indeed got 1 GB memory each connected on EMIF1 and EMIF2 port.
    Rishabh
    I check the board schematics. our schematics two MT41K256M16TW in EMIF1 and two MT41K256M16TW in EMIF2.
    Thanks.
    kyungtae
    Sorry for the delayed response.
    Can you shared the modified files i.e. xs file, a15 cfg and ipu cfg.
    Rishabh
    1. vision_sdk/apps/build/tda2px/mem_segment_definition_bios.xs
     * Copyright (C) 2013 Texas Instruments Incorporated - http://www.ti.com/
     * ALL RIGHTS RESERVED
     *  ======== mem_segment_definition.xs ========
     *  ======== Single file for the memory map configuration of all cores =========
        KB=1024;
        MB=KB*KB;
        DDR3_SIZE                   = (1024+1024)*MB;
         * are hard-coded in as values of gIpcNonCachedDataAddr and
         * gIpcNonCachedDataSize in Ipu1_0.cfg
         * to map SR0, REMOTE_LOG_MEM sections.
         * tlb_config_eveX.c need to be modified otherwise
        DDR3_BASE_ADDR_1            = DDR3_BASE_ADDR_0 + DDR3_BASE_SIZE_0;
        DDR3_BASE_SIZE_1            = DDR3_SIZE - DDR3_BASE_SIZE_0;
        if(core=="ipu1_1" || core=="ipu1_0" || core=="ipu2" || core=="a15_0")
            /*  for ipu1_0, ipu1_1, ipu2 DDR3_BASE_ADDR_1 should be
        DSP1_L2_SRAM_SIZE           = 288*KB;
        DSP2_L2_SRAM_ADDR           = 0x41000000;
        DSP2_L2_SRAM_SIZE           = 288*KB;
        EVE1_SRAM_ADDR              = 0x42000000;
        EVE1_SRAM_SIZE              = 1*MB;
        EVE2_SRAM_ADDR              = 0x42100000;
        EVE2_SRAM_SIZE              = 1*MB;
        TOTAL_MEM_SIZE              = (DDR3_SIZE);
        /* First 512 MB - cached */
        /* EVE vecs space should be align with 16MB boundary, and if possible try to fit
         * the entire vecs+code+data in 16MB section. In this case a single TLB map would
         * be enough to map vecs+code+data of an EVE.
         * tlb_config_eveX.c need to be modified if any of these EVE memory sections or
         * SR1_FRAME_BUFFER_MEM section is modified.
        /* EVE self-branch instruction block - EVE1_VECS
         * In SBL, EVE self-branch instruction is inserted @ 0x80000000 if no AppImage for EVE.
         * This could overwrites the code/data loaded at 0x80000000.
         * So Reserving a small memory block in the beginning of the DDR @0x8000 0000 for
         * EVE self-branch instruction if no AppImage for EVE.
         * If EVE enabled, then the EVE VECS/DATA/CODE is placed @0x8000 0000,
         * and hence we did not observe any issue.
         * If EVE is disabled, then also DO NOT remove this EVE1_VECS section @0x80000000,
         * if no AppImage for EVE. This could overwrites the code/data loaded at 0x80000000
        EVE1_VECS_SIZE              = 0.5*MB;
        EVE1_CODE_SIZE              =   2*MB;
        EVE1_DATA_SIZE              =13.5*MB;
        EVE2_VECS_SIZE              = 0.5*MB;
        EVE2_CODE_SIZE              =   2*MB;
        EVE2_DATA_SIZE              =13.5*MB;
        NDK_DATA_SIZE               =   4*MB;
        IPU1_1_CODE_SIZE            =   2*MB;
        IPU1_1_DATA_SIZE            =   9*MB;
        IPU1_0_CODE_SIZE            =  12*MB;
        IPU1_0_DATA_SIZE            =  17*MB;
        IPU2_CODE_SIZE              =   2*MB;
        IPU2_DATA_SIZE              =   9*MB;
        DSP1_CODE_SIZE              =   4*MB;
        DSP1_DATA_SIZE              =  12.5*MB;
        DSP1_DATA_SIZE_2            =   1*MB;
        DSP2_CODE_SIZE              =   2*MB;
        DSP2_DATA_SIZE              =  12.5*MB;
        DSP2_DATA_SIZE_2            =   1*MB;
        /* A15_0_CODE_SIZE reduced since it is not used in .bld file.
         * Check .bld for details. Originally 2 + 14 MB.
        A15_0_DATA_SIZE             =  13*MB;
        if(java.lang.System.getenv("OPENCL_INCLUDE") == "yes")
            A15_0_DATA_SIZE_INC     =  101*MB /* in MB */
            A15_0_DATA_SIZE         =  (A15_0_DATA_SIZE + A15_0_DATA_SIZE_INC);
        if(java.lang.System.getenv("ECC_FFI_INCLUDE")=="yes")
            /* Ensure ECC regions are 64kB aligned */
            SR1_FRAME_BUFFER_SIZE       = 309*MB;
            SR1_BUFF_ECC_ASIL_SIZE      =   1*MB;
            SR1_BUFF_ECC_QM_SIZE        =  40*MB;
            SR1_BUFF_NON_ECC_ASIL_SIZE  =   1*MB;
        else
            SR1_BUFF_ECC_ASIL_SIZE      =   4*KB;
            SR1_BUFF_ECC_QM_SIZE        =   4*KB;
            SR1_BUFF_NON_ECC_ASIL_SIZE  =   4*KB;
            SR1_FRAME_BUFFER_SIZE       = 351*MB - (SR1_BUFF_ECC_ASIL_SIZE + SR1_BUFF_ECC_QM_SIZE + SR1_BUFF_NON_ECC_ASIL_SIZE);
                SR1_FRAME_BUFFER_SIZE   = SR1_FRAME_BUFFER_SIZE - A15_0_DATA_SIZE_INC;
        /* Second 512 MB - non-cached */
        REMOTE_LOG_SIZE             =  160*KB;
        SYSTEM_IPC_SHM_SIZE         =  480*KB;
        LINK_STATS_SIZE             =  256*KB;
        HDVPSS_DESC_SIZE            = 1024*KB;
        SR0_SIZE                    =  128*KB;
        OPENVX_SHM_SIZE             =    2*MB;
        if((java.lang.System.getenv("OPENCL_INCLUDE") == "yes"))
            /* when OpenCL is enabled we need more SR0 space
            SR0_SIZE                =  2*MB;
        /* Cached Section */
        /* Changes for ECC
         * EVE code will run only from non-ECC region
         * All code section should be next to non-ECC region (using EVE section) to
         * allow them to be easily taken out of ECC region for debugging.
         * Make sure DSP1_DATA_ADDR_2 and DSP2_DATA_ADDR_2 are immediately after
         * SR1_BUFF_ECC_QM_ADDR and should be 2*MB in total - this size should
         * be kept constant across all platforms and should match the increment
         * to heapStats.heapSize in utils_xmc_mpu.c
        EVE1_VECS_ADDR             = DDR3_BASE_ADDR_0;
        EVE1_CODE_ADDR             = EVE1_VECS_ADDR             + EVE1_VECS_SIZE;
        EVE1_DATA_ADDR             = EVE1_CODE_ADDR             + EVE1_CODE_SIZE;
        EVE2_VECS_ADDR             = EVE1_DATA_ADDR             + EVE1_DATA_SIZE;
        EVE2_CODE_ADDR             = EVE2_VECS_ADDR             + EVE2_VECS_SIZE;
        EVE2_DATA_ADDR             = EVE2_CODE_ADDR             + EVE2_CODE_SIZE;
        NDK_DATA_ADDR              = EVE2_DATA_ADDR             + EVE2_DATA_SIZE;
        IPU1_1_CODE_ADDR           = NDK_DATA_ADDR              + NDK_DATA_SIZE;
        IPU1_0_CODE_ADDR           = IPU1_1_CODE_ADDR           + IPU1_1_CODE_SIZE;
        IPU2_CODE_ADDR             = IPU1_0_CODE_ADDR           + IPU1_0_CODE_SIZE;
        DSP1_CODE_ADDR             = IPU2_CODE_ADDR             + IPU2_CODE_SIZE;
        DSP2_CODE_ADDR             = DSP1_CODE_ADDR             + DSP1_CODE_SIZE;
        IPU1_1_DATA_ADDR           = DSP2_CODE_ADDR             + DSP2_CODE_SIZE;
        IPU1_0_DATA_ADDR           = IPU1_1_DATA_ADDR           + IPU1_1_DATA_SIZE;
        IPU2_DATA_ADDR             = IPU1_0_DATA_ADDR           + IPU1_0_DATA_SIZE;
        DSP1_DATA_ADDR             = IPU2_DATA_ADDR             + IPU2_DATA_SIZE;
        DSP2_DATA_ADDR             = DSP1_DATA_ADDR             + DSP1_DATA_SIZE;
        A15_0_DATA_ADDR            = DSP2_DATA_ADDR             + DSP2_DATA_SIZE;
        SR1_BUFF_ECC_ASIL_ADDR     = A15_0_DATA_ADDR            + A15_0_DATA_SIZE;
        SR1_BUFF_ECC_QM_ADDR       = SR1_BUFF_ECC_ASIL_ADDR     + SR1_BUFF_ECC_ASIL_SIZE;
        DSP1_DATA_ADDR_2           = SR1_BUFF_ECC_QM_ADDR       + SR1_BUFF_ECC_QM_SIZE;
        DSP2_DATA_ADDR_2           = DSP1_DATA_ADDR_2           + DSP1_DATA_SIZE_2;
        SR1_BUFF_NON_ECC_ASIL_ADDR = DSP2_DATA_ADDR_2           + DSP2_DATA_SIZE_2;
        SR1_FRAME_BUFFER_ADDR      = SR1_BUFF_NON_ECC_ASIL_ADDR + SR1_BUFF_NON_ECC_ASIL_SIZE;
        /* Non Cached Section */
        SR0_ADDR                    = DDR3_BASE_ADDR_1;
        REMOTE_LOG_ADDR             = SR0_ADDR              + SR0_SIZE;
        LINK_STATS_ADDR             = REMOTE_LOG_ADDR       + REMOTE_LOG_SIZE;
        SYSTEM_IPC_SHM_ADDR         = LINK_STATS_ADDR       + LINK_STATS_SIZE;
        HDVPSS_DESC_ADDR            = SYSTEM_IPC_SHM_ADDR   + SYSTEM_IPC_SHM_SIZE;
        OPENVX_SHM_ADDR             = HDVPSS_DESC_ADDR      + HDVPSS_DESC_SIZE;
        if ((SR1_FRAME_BUFFER_ADDR + SR1_FRAME_BUFFER_SIZE) > (DDR3_BASE_ADDR_0 + DDR3_BASE_SIZE_0))
          throw xdc.$$XDCException("MEMORY_MAP OVERFLOW ERROR ",
                                   "\nRegion End: " + "0x" + java.lang.Long.toHexString(DDR3_BASE_ADDR_0 + DDR3_BASE_SIZE_0) +
                                   "\nActual End: " + "0x" + java.lang.Long.toHexString(SR1_FRAME_BUFFER_ADDR + SR1_FRAME_BUFFER_SIZE));
        if(java.lang.System.getenv("OPENVX_INCLUDE")=="yes")
            if ((OPENVX_SHM_ADDR + OPENVX_SHM_SIZE) > (DDR3_BASE_ADDR_1 + DDR3_BASE_SIZE_1))
                throw xdc.$$XDCException("MEMORY_MAP OVERFLOW ERROR with OpenVx",
                                   "\nRegion End: " + "0x" + java.lang.Long.toHexString(DDR3_BASE_ADDR_1 + DDR3_BASE_SIZE_1) +
                                   "\nActual End: " + "0x" + java.lang.Long.toHexString(OPENVX_SHM_ADDR + OPENVX_SHM_SIZE));
        else
            if ((HDVPSS_DESC_ADDR + HDVPSS_DESC_SIZE) > (DDR3_BASE_ADDR_1 + DDR3_BASE_SIZE_1))
                throw xdc.$$XDCException("MEMORY_MAP OVERFLOW ERROR",
                                   "\nActual End: " + "0x" + java.lang.Long.toHexString(HDVPSS_DESC_ADDR + HDVPSS_DESC_SIZE));
        if ((DDR3_BASE_SIZE_1 + DDR3_BASE_SIZE_0) > (TOTAL_MEM_SIZE))
          throw xdc.$$XDCException("MEMORY_MAP EXCEEDS DDR SIZE ERROR ",
                                   "\nRegion End: " + "0x" + java.lang.Long.toHexString(DDR3_BASE_SIZE_1 + DDR3_BASE_SIZE_0) +
                                   "\nActual End: " + "0x" + java.lang.Long.toHexString(TOTAL_MEM_SIZE));
        var memory = new Array();
        var index = 0;
        memory[index++] = ["IPU1_1_CODE_MEM", {
                comment : "IPU1_1_CODE_MEM",
                base    : IPU1_1_CODE_ADDR,
                len     : IPU1_1_CODE_SIZE
        memory[index++] = ["IPU1_1_DATA_MEM", {
                comment : "IPU1_1_DATA_MEM",
                base    : IPU1_1_DATA_ADDR,
                len     : IPU1_1_DATA_SIZE
        memory[index++] = ["IPU1_0_CODE_MEM", {
                comment : "IPU1_0_CODE_MEM",
                base    : IPU1_0_CODE_ADDR,
                len     : IPU1_0_CODE_SIZE
        memory[index++] = ["IPU1_0_DATA_MEM", {
                comment : "IPU1_0_DATA_MEM",
                base    : IPU1_0_DATA_ADDR,
                len     : IPU1_0_DATA_SIZE
        memory[index++] = ["IPU2_CODE_MEM", {
                comment : "IPU2_CODE_MEM",
                base    : IPU2_CODE_ADDR,
                len     : IPU2_CODE_SIZE
        memory[index++] = ["IPU2_DATA_MEM", {
                comment : "IPU2_DATA_MEM",
                base    : IPU2_DATA_ADDR,
                len     : IPU2_DATA_SIZE
        memory[index++] = ["DSP1_CODE_MEM", {
                comment : "DSP1_CODE_MEM",
                base    : DSP1_CODE_ADDR,
                len     : DSP1_CODE_SIZE
        memory[index++] = ["DSP1_DATA_MEM", {
                comment : "DSP1_DATA_MEM",
                base    : DSP1_DATA_ADDR,
                len     : DSP1_DATA_SIZE
        memory[index++] = ["DSP1_DATA_MEM_2", {
                comment : "DSP1_DATA_MEM_2",
                base    : DSP1_DATA_ADDR_2,
                len     : DSP1_DATA_SIZE_2
        memory[index++] = ["DSP2_CODE_MEM", {
                comment : "DSP2_CODE_MEM",
                base    : DSP2_CODE_ADDR,
                len     : DSP2_CODE_SIZE
        memory[index++] = ["DSP2_DATA_MEM", {
                comment : "DSP2_DATA_MEM",
                base    : DSP2_DATA_ADDR,
                len     : DSP2_DATA_SIZE
        memory[index++] = ["DSP2_DATA_MEM_2", {
                comment : "DSP2_DATA_MEM_2",
                base    : DSP2_DATA_ADDR_2,
                len     : DSP2_DATA_SIZE_2
        memory[index++] = ["NDK_MEM", {
                comment : "NDK_MEM",
                base    : NDK_DATA_ADDR,
                len     : NDK_DATA_SIZE
        memory[index++] = ["A15_0_DATA_MEM", {
                comment : "A15_0_DATA_MEM",
                base    : A15_0_DATA_ADDR,
                len     : A15_0_DATA_SIZE
        memory[index++] = ["EVE1_VECS_MEM", {
                comment : "EVE1_VECS_MEM",
                base    : EVE1_VECS_ADDR,
                len     : EVE1_VECS_SIZE
        memory[index++] = ["EVE1_CODE_MEM", {
                comment : "EVE1_CODE_MEM",
                base    : EVE1_CODE_ADDR,
                len     : EVE1_CODE_SIZE
        memory[index++] = ["EVE1_DATA_MEM", {
                comment : "EVE1_DATA_MEM",
                base    : EVE1_DATA_ADDR,
                len     : EVE1_DATA_SIZE
        memory[index++] = ["EVE2_VECS_MEM", {
                comment : "EVE2_VECS_MEM",
                base    : EVE2_VECS_ADDR,
                len     : EVE2_VECS_SIZE
        memory[index++] = ["EVE2_CODE_MEM", {
                comment : "EVE2_CODE_MEM",
                base    : EVE2_CODE_ADDR,
                len     : EVE2_CODE_SIZE
        memory[index++] = ["EVE2_DATA_MEM", {
                comment : "EVE2_DATA_MEM",
                base    : EVE2_DATA_ADDR,
                len     : EVE2_DATA_SIZE
        memory[index++] = ["SR1_FRAME_BUFFER_MEM", {
                comment : "SR1_FRAME_BUFFER_MEM",
                base    : SR1_FRAME_BUFFER_ADDR,
                len     : SR1_FRAME_BUFFER_SIZE
        memory[index++] = ["SR1_BUFF_ECC_ASIL_MEM", {
                comment : "SR1_BUFF_ECC_ASIL_MEM",
                base    : SR1_BUFF_ECC_ASIL_ADDR,
                len     : SR1_BUFF_ECC_ASIL_SIZE
        memory[index++] = ["SR1_BUFF_ECC_QM_MEM", {
                comment : "SR1_BUFF_ECC_QM_MEM",
                base    : SR1_BUFF_ECC_QM_ADDR,
                len     : SR1_BUFF_ECC_QM_SIZE
        memory[index++] = ["SR1_BUFF_NON_ECC_ASIL_MEM", {
                comment : "SR1_BUFF_NON_ECC_ASIL_MEM",
                base    : SR1_BUFF_NON_ECC_ASIL_ADDR,
                len     : SR1_BUFF_NON_ECC_ASIL_SIZE
        memory[index++] = ["SR0", {
                comment : "SR0",
                base    : SR0_ADDR,
                len     : SR0_SIZE
        memory[index++] = ["HDVPSS_DESC_MEM", {
                comment : "HDVPSS_DESC_MEM",
                base    : HDVPSS_DESC_ADDR,
                len     : HDVPSS_DESC_SIZE
        memory[index++] = ["REMOTE_LOG_MEM", {
                comment : "REMOTE_LOG_MEM",
                base    : REMOTE_LOG_ADDR,
                len     : REMOTE_LOG_SIZE
        memory[index++] = ["LINK_STATS_MEM", {
                comment : "LINK_STATS_MEM",
                base    : LINK_STATS_ADDR,
                len     : LINK_STATS_SIZE
        memory[index++] = ["SYSTEM_IPC_SHM_MEM", {
                comment : "SYSTEM_IPC_SHM_MEM",
                base    : SYSTEM_IPC_SHM_ADDR,
                len     : SYSTEM_IPC_SHM_SIZE
        xdc.print("# !!! Core is [" + core + "] !!!" );
        memory[index++] = ["DSP1_L2_SRAM", {
                comment: "DSP1_L2_SRAM",
                base: DSP1_L2_SRAM_ADDR,
                len:  DSP1_L2_SRAM_SIZE
        memory[index++] = ["DSP2_L2_SRAM", {
                comment: "DSP2_L2_SRAM",
                base: DSP2_L2_SRAM_ADDR,
                len:  DSP2_L2_SRAM_SIZE
    /* This is a dummy section needed for OpenCL */
            L1DSRAM_ADDR = 0x00F00000;
            L1DSRAM_SIZE = 0x00008000;
            OCL_LOCAL_ADDR = 0x0083B000;
            OCL_LOCAL_SIZE = 0x00004000;
            memory[index++] = ["L1DSRAM", {
                comment: "L1DSRAM",
                base: L1DSRAM_ADDR,
                len:  L1DSRAM_SIZE
            memory[index++] = ["OPENVX_SHM_MEM", {
                    comment: "OPENVX_SHM_MEM",
                    base: OPENVX_SHM_ADDR,
                   len:  OPENVX_SHM_SIZE
        return (memory);
    2. vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/a15_0/a15_0.cfg
    *  file name: a15_0.cfg
    *  Set A15 core 0 specific configuration
    var CurrentPlatform = java.lang.System.getenv("PLATFORM");
    var DualA15_smpbios = java.lang.System.getenv("DUAL_A15_SMP_BIOS");
    var OpenCL = java.lang.System.getenv("OPENCL_INCLUDE");
    var OpenCV = java.lang.System.getenv("ENABLE_OPENCV");
    xdc.print("# !!! Current build platform is [" + CurrentPlatform + "] !!!" );
    xdc.loadPackage('ti.sysbios').profile = "release";
    xdc.loadCapsule("src/rtos/bios_app_common/tda2px/cfg/BIOS_common.cfg");
    /* root of the configuration object model */
    var Program = xdc.useModule('xdc.cfg.Program');
    xdc.useModule('ti.sysbios.gates.GateHwi');
    var BIOS = xdc.useModule('ti.sysbios.BIOS');
    if(OpenCL=="yes")
    var SecondsClock = xdc.useModule('ti.sysbios.hal.SecondsClock');
    BIOS.cpuFreq.hi = 0;
    BIOS.cpuFreq.lo = 750000000; /* 750 MHz */
    if(DualA15_smpbios=="yes")
       BIOS.smpEnabled = true;
    else
       BIOS.smpEnabled = false;
     *  ======== IPC Configuration ========
    Program.global.procName = "HOST";
    xdc.loadCapsule("src/rtos/bios_app_common/tda2px/cfg/IPC_common.cfg");
    var NdkProcToUse = java.lang.System.getenv("NDK_PROC_TO_USE");
    if(NdkProcToUse=="a15_0")
       xdc.print("# !!! Linking to NDK !!!" );
       xdc.loadCapsule("src/rtos/bios_app_common/tda2px/cfg/NDK_config.cfg");
     *  ======== Operating System Configuration ========
    /* no rts heap */
    Program.heap = 0;
    Program.argSize = 100;  /* minimum size */
    if(OpenCL=="yes")
        Program.stack = 0x4000;
    else
    /* create a default heap */
    var HeapMem = xdc.useModule('ti.sysbios.heaps.HeapMem');
    var heapMemParams = new HeapMem.Params();
    if(OpenCL=="yes")
        heapMemParams.size = 0x6000000;
    else
        heapMemParams.size = 0x600000;
    var Memory = xdc.useModule('xdc.runtime.Memory');
    Memory.defaultHeapInstance = HeapMem.create(heapMemParams);
    if(OpenCL=="yes")
        Memory.defaultHeapSize = 0x6000000;
    /* Enable Cache */
       var Cache = xdc.useModule('ti.sysbios.family.arm.a15.smp.Cache');
    else
       var Cache = xdc.useModule('ti.sysbios.family.arm.a15.Cache');
    Cache.enableCache = true;
     *              MMU Configuration              *
    var Mmu = xdc.useModule('ti.sysbios.family.arm.a15.Mmu');
    Mmu.enableMMU = true;
     * SYS/BIOS assigns the following defaults to MAIR0 ATTR0, ATTR1 and ATTR2:
     * ATTR0 -> 0x44 (mark memory region as non-cacheable normal memory)
     * ATTR1 -> 0x00 (mark memory region as device memory, i.e. strongly
     * ordered and non-cacheable)
     * ATTR2 -> 0xFF (mark memory region as normal memory, RW cacheable and
     * RW allocate)
    // descriptor attribute structure
    var attrs0 = new Mmu.DescriptorAttrs();
    Mmu.initDescAttrsMeta(attrs0);
    attrs0.type = Mmu.DescriptorType_BLOCK;    // BLOCK descriptor
    attrs0.noExecute = true;                   // not executable
    attrs0.accPerm = 0;                        // read/write at PL1
    attrs0.shareable = 2;                      // shareable
    attrs0.attrIndx = 1;                       // strongly ordered and non-cacheable
    // NOTE: Currently mapping all region as non-cacheable, device memory.
    //If in future application want to use OCMC memories it needs to remove corresponding MMU entries from below and make it cacheable.
    for (var i=0x40000000; i < 0x60000000; i = i + 0x00200000) {
        Mmu.setSecondLevelDescMeta(i, i, attrs0);
    var attrs1 = new Mmu.DescriptorAttrs();
    Mmu.initDescAttrsMeta(attrs1);
    attrs1.type = Mmu.DescriptorType_BLOCK;    // BLOCK descriptor
    var attrs2 = new Mmu.DescriptorAttrs();
    Mmu.initDescAttrsMeta(attrs2);
    attrs2.type = Mmu.DescriptorType_BLOCK;    // BLOCK descriptor
    for (var i=0xA0000000; i <= 0xFFFFFFFF; i = i + 0x00200000) {
    for (var i = 0; i < Program.cpu.memoryMap.length; i++)
        memSegment = Program.cpu.memoryMap[i];
        if (memSegment.name == "NDK_MEM")
            var attrs3 = new Mmu.DescriptorAttrs();
            Mmu.initDescAttrsMeta(attrs3);
            attrs3.type = Mmu.DescriptorType_BLOCK;    // BLOCK descriptor
            attrs3.noExecute = true;                   // not executable
            attrs3.shareable = 2;                      // shareable
            attrs3.accPerm = 0;                        // read/write at PL1
            attrs3.attrIndx = 2;                       // Mark mem regions as cached, normal memory
            for (var j=memSegment.base; j < (memSegment.base + memSegment.len); j = j + 0x00200000)
                Mmu.setSecondLevelDescMeta(j, j, attrs3);
    /* .text is allocated as per "codeMemory" defined in .bld file.
     * .data, .stack, .bss, .sysmem, etc are allocated as per
     * "dataMemory" defined in .bld file */
    Program.sectMap[".bss:extMemNonCache:remoteLogCoreShm"] = "REMOTE_LOG_MEM";
    Program.sectMap[".bss:extMemNonCache:hcfResourceTable"] = "REMOTE_LOG_MEM";
    Program.sectMap[".bss:extMemNonCache:ipcShm"]           = "SYSTEM_IPC_SHM_MEM";
    Program.sectMap[".bss:extMemNonCache:linkStats"]        = "LINK_STATS_MEM";
    if (java.lang.System.getenv("OPENVX_INCLUDE") == "yes")
        Program.sectMap[".bss:extMemNonCache:tiovxObjDescShm"] = "OPENVX_SHM_MEM";
    Program.sectMap[".bss:NDK_PACKETMEM"]                   = "NDK_MEM";
    Program.sectMap[".bss:NDK_MMBUFFER"]                    = "NDK_MEM";
    var InitXbar    = xdc.useModule("ti.sysbios.family.shared.vayu.IntXbar");
    /* Exception hook function */
    var ExceptionA15 = xdc.useModule('ti.sysbios.family.arm.exc.Exception');
    /* enable print of exception handing info */
    ExceptionA15.excHookFunc ='&Utils_a15ExceptionHookFxn';
    ExceptionA15.enableDecode=true;
    /* XDC runtime function */
    var Error = xdc.useModule("xdc.runtime.Error");
    Error.raiseHook = "&Utils_commonErrorRaiseHook";
    /* Add an idle thread 'Utils_idleFxn' that monitors interrupts. */
    var Idle = xdc.useModule("ti.sysbios.knl.Idle");
    if (DualA15_smpbios == "yes")
        Idle.addCoreFunc('&Utils_idleFxn', 0);
        Idle.addCoreFunc('&Utils_idleFxn', 1);
    else
        Idle.addFunc('&Utils_idleFxn');
    /* Assign GPTimer2 to be used for BIOS Clock 1-ms tick */
     *          CLOCK Module Configuraion          *
    var Clock = xdc.useModule("ti.sysbios.knl.Clock");
    if(OpenCL=="yes")
        Clock.tickMode = Clock.TickMode_PERIODIC;
    else
        Clock.tickSource = Clock.TickSource_USER;
    *           Timer Module Configuraion         *
    /* Assign GPTimer2 to be used for Timestamp */
    /* Set to 1-ms Tick and Enable Wakeup for OVF interrupt */
    var Timer = xdc.useModule('ti.sysbios.timers.dmtimer.Timer');
    var timerParams = new Timer.Params();
    timerParams.period = 1000;
    timerParams.twer.ovf_wup_ena = 1;
    timerParams.tiocpCfg.emufree = 1;
    timerParams.tsicr.posted = 0;
    /* Timer ID = 1 for GPTimer2 and input clock runs at 20 MHz */
    Timer.intFreqs[1].hi = 0;
    Timer.intFreqs[1].lo = 20000000;
    Timer.create(1, '&mainA15TimerTick', timerParams);
    /* Assign GPTimer3 to be used for Timestamp */
    /* Timer ID = 2 for GPTimer3 and input clock runs at 20 MHz */
    var DMTimer = xdc.useModule('ti.sysbios.timers.dmtimer.Timer');
    var timerParams2 = new DMTimer.Params();
    timerParams2.tsicr.posted = 0;
    DMTimer.intFreqs[2].hi = 0;
    DMTimer.intFreqs[2].lo = 20000000;
    var DMTimestampProvider = xdc.useModule("ti.sysbios.timers.dmtimer.TimestampProvider");
    DMTimestampProvider.timerId = 2;
    DMTimestampProvider.useClockTimer = false;
    var Timestamp = xdc.useModule("xdc.runtime.Timestamp");
    Timestamp.SupportProxy = DMTimestampProvider;
    /* Indicate GPT2 & GPT3 are used */
    var TimerSupport = xdc.useModule('ti.sysbios.family.shared.vayu.TimerSupport');
    TimerSupport.availMask = 0x0006;
    /* In order to check how much percentange of Idle time the CPU is in Low power */
    var LocalTimestampProvider = xdc.useModule('ti.sysbios.family.arm.a15.TimestampProvider');
    /* Add POSIX Support */
    if(OpenCV=="yes")
        var Settings = xdc.useModule('ti.sysbios.posix.Settings');
        Settings.supportsMutexPriority = true;
    if(OpenCL=="yes")
        xdc.global.oclProcName = "HOST";
        var OCL = xdc.useModule('ti.opencl.OpenCL');
        OCL.computeUnitList = "0";
        OCL.OCL_ipc_customized = true;
        OCL.OCL_memory_customized =true;
        OCL.OCL_HOSTPROG_base = Program.cpu.memoryMap["A15_0_DATA_MEM"].base;
        OCL.OCL_HOSTPROG_len  = Program.cpu.memoryMap["SR1_FRAME_BUFFER_MEM"].base - Program.cpu.memoryMap["A15_0_DATA_MEM"].base
                                + Program.cpu.memoryMap["SR1_FRAME_BUFFER_MEM"].len;
        OCL.OCL_GLOBAL_base   = Program.cpu.memoryMap["EVE2_CODE_MEM"].base;
        OCL.OCL_GLOBAL_len    = Program.cpu.memoryMap["EVE2_CODE_MEM"].len;
        OCL.OCL_LOCAL_base    = Program.cpu.memoryMap["OCMC_RAM2"].base;
        OCL.OCL_LOCAL_len     = Program.cpu.memoryMap["OCMC_RAM2"].len;
    3. vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu1_0/Ipu1_0.cfg
    *  file name: Ipu1_0.cfg
    *  Set IPU1 core0 specific configuration
    *  Platform: VAYU_bios_elf
    *  Target: ti.targets.arm.elf.M4
    var A15TargetOS     = java.lang.System.getenv("A15_TARGET_OS");
    if (A15TargetOS == "Qnx")
        A15TargetOS = "Linux";
    if(NdkProcToUse=="ipu1_0")
    var GIO          = xdc.useModule('ti.sysbios.io.GIO');
    var Core         = xdc.useModule('ti.sysbios.family.arm.ducati.Core');
    /* set the ipuId and coreId */
    Core.ipuId = 1;
    Core.id = 0;
    if (A15TargetOS == "Linux")
    else
    /* Physical address of VPDMA desc is HDVPSS_DESC_ADDR */
    Program.global.XDC_CFG_VPDMA_DESC_PHYS_ADDR  = Program.cpu.memoryMap['HDVPSS_DESC_MEM'].base;
    /* Memory section address and size */
    Program.global.XDC_SR1_FRAME_BUFFER_ADDR = Program.cpu.memoryMap['SR1_FRAME_BUFFER_MEM'].base;
    Program.global.XDC_SR1_FRAME_BUFFER_SIZE = Program.cpu.memoryMap['SR1_FRAME_BUFFER_MEM'].len;
    Program.global.XDC_SR1_BUFF_ECC_ASIL_ADDR = Program.cpu.memoryMap['SR1_BUFF_ECC_ASIL_MEM'].base;
    Program.global.XDC_SR1_BUFF_ECC_ASIL_SIZE = Program.cpu.memoryMap['SR1_BUFF_ECC_ASIL_MEM'].len;
    Program.global.XDC_SR1_BUFF_ECC_QM_ADDR = Program.cpu.memoryMap['SR1_BUFF_ECC_QM_MEM'].base;
    Program.global.XDC_SR1_BUFF_ECC_QM_SIZE = Program.cpu.memoryMap['SR1_BUFF_ECC_QM_MEM'].len;
    Program.global.XDC_SR1_BUFF_NON_ECC_ASIL_ADDR = Program.cpu.memoryMap['SR1_BUFF_NON_ECC_ASIL_MEM'].base;
    Program.global.XDC_SR1_BUFF_NON_ECC_ASIL_SIZE = Program.cpu.memoryMap['SR1_BUFF_NON_ECC_ASIL_MEM'].len;
     *  ======== IPU1 CORE0 Processor (primary core) ========
     *  AMMU config need to be done only on one core
     *  This is done in primary core (CORE0) , so do it here
     *              Ammu Configuraiton             *
        var ammu = xdc.loadCapsule("Ammu1_linux.cfg");
    if (A15TargetOS == "Bios")
        var ammu = xdc.loadCapsule("Ammu1_bios.cfg");
    ammu.init();
    Program.global.procName = "IPU1-0";
    /* no rts heap */
    Program.heap = 0;
    heapMemParams.size = 0x40000;
    Memory.defaultHeapSize  = 0x15000;
    Program.sectMap[".text"]                      = "IPU1_0_CODE_MEM";
    Program.sectMap[".const"]                     = "IPU1_0_CODE_MEM";
    Program.sectMap[".plt"]                       = "IPU1_0_CODE_MEM";
    Program.sectMap[".data"]                      = "IPU1_0_DATA_MEM";
    Program.sectMap[".bss"]                       = "IPU1_0_DATA_MEM";
    Program.sectMap[".neardata"]                  = "IPU1_0_DATA_MEM";
    Program.sectMap[".rodata"]                    = "IPU1_0_DATA_MEM";
    Program.sectMap[".bss:taskStackSection"]      = "IPU1_0_DATA_MEM";
    var ipu_pri     = java.lang.System.getenv("IPU_PRIMARY_CORE");
    if (ipu_pri == "ipu1_0")
    Program.sectMap[".bss:extMemNonCache:vpdma"]  = "HDVPSS_DESC_MEM";
    Program.sectMap[".bss:heapMemDDR"]            = "SR1_FRAME_BUFFER_MEM";
    Program.sectMap[".bss:heapMemDDREccAsil"]     = "SR1_BUFF_ECC_ASIL_MEM";
    Program.sectMap[".bss:heapMemDDREccQM"]       = "SR1_BUFF_ECC_QM_MEM";
    Program.sectMap[".bss:heapMemDDRNonEccAsil"]  = "SR1_BUFF_NON_ECC_ASIL_MEM";
    Program.sectMap[".bss:heapMemOCMC"]           = "OCMC_RAM1";
    var DSP1_DATA_MEM = Program.cpu.memoryMap['DSP1_DATA_MEM'];
    Program.global.gXdcDsp1DataAddr = DSP1_DATA_MEM.base;
    Program.global.gXdcDsp1DataSize = DSP1_DATA_MEM.len;
    var DSP2_DATA_MEM = Program.cpu.memoryMap['DSP2_DATA_MEM'];
    Program.global.gXdcDsp2DataAddr = DSP2_DATA_MEM.base;
    Program.global.gXdcDsp2DataSize = DSP2_DATA_MEM.len;
    var EVE1_DATA_MEM = Program.cpu.memoryMap['EVE1_DATA_MEM'];
    Program.global.gXdcEve1DataAddr = EVE1_DATA_MEM.base;
    Program.global.gXdcEve1DataSize = EVE1_DATA_MEM.len;
    /* The following value is used by L3FW, so subtract 0x20000000 to get
     * physical address. M4 uses the alias at 0xA0000000.
    var LINK_STATS_MEM = Program.cpu.memoryMap['LINK_STATS_MEM'];
    Program.global.gXdcLinkStatsAddr = LINK_STATS_MEM.base - 0x20000000;
    Program.global.gXdcLinkStatsSize = LINK_STATS_MEM.len;
    if(java.lang.System.getenv("IVAHD_INCLUDE")=="yes")
        xdc.loadCapsule("src/rtos/bios_app_common/tda2px/cfg/RMAN_IRES_iva.cfg");
    var HwiM3       = xdc.useModule('ti.sysbios.family.arm.m3.Hwi');
    HwiM3.enableException = true;
    HwiM3.nvicCCR.DIV_0_TRP = 1;
    HwiM3.excHookFunc = '&Utils_m4ExceptionHookFxn';
        xdc.loadCapsule("src/rtos/bios_app_common/tda2px/ipu1_0/Ipu1_0_a15_linux.cfg");
    else
        Timer.intFreqs[8].hi = 0;
        /* system clock runs at 20 MHz */
        Timer.intFreqs[8].lo = 20000000;
        Timer.create(8, '&mainIPU1_C0TimerTick', timerParams);
        DMTimer.intFreqs[10].hi = 0;
        DMTimer.intFreqs[10].lo = 20000000;
        DMTimestampProvider.timerId = 10;
        /* allocate timer 9 to IPU0 */
        TimerSupport.availMask = 0x0500;
        if (java.lang.System.getenv("ENABLE_TASK_PROFILE_UTIL") == "yes")
             * Task Timer utility *
            var Task = xdc.useModule('ti.sysbios.knl.Task');
            /* Define and add one Task Hook Set */
            Task.addHookSet({
                registerFxn: '&Utils_taskTimerRegisterHook',
                createFxn: '&Utils_taskTimerCreateHook',
                readyFxn: '&Utils_taskTimerReadyHook',
                switchFxn: '&Utils_taskTimerSwitchHook',
                exitFxn: '&Utils_taskTimerExitHook',
                deleteFxn: '&Utils_taskTimerDeleteHook',
    var LocalTimestampProvider = xdc.useModule('ti.sysbios.family.arm.ducati.TimestampProvider');
    4. vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu1_0/Ammu1_bios.cfg
    *  file name: Ammu1.cfg
    *  Set IPU1 (core 0 and core 1) AMMU configuration
     * NOTE:
     * Region 0x42000000 to 0x44000000 (32MB) is BitBand region in IPU.
     * Any L3/L4 peripherals mapped to this region must be accsssed via virtual
     * address on IPU side.
     * On TDA2xx below peripherals fall in this BitBand region
     *   - EVE1/2/3/4 MBOX0/1
     *   - System EDMA
     * Further IPC package by default acceses System mailbox's on IPU side via
     * virtual address's
     * In AMMU config, one large page can be used to do this virutal to physical
     * address mapping as shown below,
     *   Virutal Address          Physical Address
     *  0x60000000:0x7FFFFFFF -> 0x40000000:0x5FFFFFFF   (512MB)
     * However this wastes a large page which can be used for other purposes
     * Ex, mapping GPMC NOR memory of 64MB.
     * Hence AMMU config below maps multiple small and medium pages to specific
     * address ranges of the required peripherals.
    function init()
        var Cache = xdc.useModule('ti.sysbios.hal.unicache.Cache');
        var AMMU = xdc.useModule('ti.sysbios.hal.ammu.AMMU');
        AMMU.configureAmmu = true;
        /*********************** Medium Pages *************************/
        /* ISS */
        var entry = AMMU.mediumPages[0];
        entry.logicalAddress = 0x62200000;
        entry.translatedAddress = 0x42200000;
        entry.size = AMMU.Medium_256K;
        entry.L1_writePolicy = AMMU.WritePolicy_WRITE_THROUGH;
        entry.L1_allocate    = AMMU.AllocatePolicy_NON_ALLOCATE;
        /* ISS */
        var entry = AMMU.mediumPages[1];
        entry.logicalAddress = 0x62240000;
        entry.translatedAddress = 0x42240000;
        entry.L1_posted = AMMU.PostedPolicy_POSTED;
        /*********************** Small Pages *************************/
        /* EVE1 MBOX0 */
        var entry = AMMU.smallPages[2];
        entry.logicalAddress = 0x62088000;
        entry.translatedAddress = 0x42088000;
        entry.size = AMMU.Small_16K;
        /* EVE1 MBOX1 */
        var entry = AMMU.smallPages[3];
        entry.logicalAddress = 0x6208C000;
        entry.translatedAddress = 0x4208C000;
        /* EVE2 MBOX0 */
        var entry = AMMU.smallPages[4];
        entry.logicalAddress = 0x62188000;
        entry.translatedAddress = 0x42188000;
        /* EVE2 MBOX1 */
        var entry = AMMU.smallPages[5];
        entry.logicalAddress = 0x6218C000;
        entry.translatedAddress = 0x4218C000;
        /* System EDMA TPCC */
        var entry = AMMU.smallPages[6];
        entry.logicalAddress = 0x63300000;
        entry.translatedAddress = 0x43300000;
        var entry = AMMU.smallPages[7];
        entry.logicalAddress = 0x63304000;
        entry.translatedAddress = 0x43304000;
        /* System Mailbox 5, 6 */
        var entry = AMMU.smallPages[8];
        entry.logicalAddress = 0x68840000;
        entry.translatedAddress = 0x48840000;
        /* System Mailbox 7, 8 */
        var entry = AMMU.smallPages[9];
        entry.logicalAddress = 0x68844000;
        entry.translatedAddress = 0x48844000;
        /*********************** Large Pages *************************/
        var entry = AMMU.largePages[0];
        entry.logicalAddress = 0x40000000;
        entry.translatedAddress = 0x40000000;
        /* map program code/data memory into ammu (cacheable) */
        var entry = AMMU.largePages[1];
        entry.logicalAddress = 0x80000000;
        entry.L1_cacheable = AMMU.CachePolicy_CACHEABLE;
        entry.L1_allocate = AMMU.AllocatePolicy_ALLOCATE;
        entry.L1_writePolicy = AMMU.WritePolicy_WRITE_BACK;
        /* map SR_0 data memory into ammu (non-cacheable) */
        var entry = AMMU.largePages[2];
        entry.logicalAddress = 0x60000000;
    5. vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu2/Ipu2.cfg
    *  file name: Ipu2.cfg
    *  Set IPU2 core0 & core1 specific configuration
    if(NdkProcToUse=="ipu2")
    Core.ipuId = 2;
    Core.id = 0;
     *  ======== IPU2 CORE0 Processor (primary core) ========
        var ammu = xdc.loadCapsule("Ammu2_linux.cfg");
        var ammu = xdc.loadCapsule("Ammu2_bios.cfg");
    ammu.init();
    Program.global.procName = "IPU2";
    /* no rts heap */
    Program.heap = 0;
    Program.sectMap[".text"]                      = "IPU2_CODE_MEM";
    Program.sectMap[".const"]                     = "IPU2_CODE_MEM";
    Program.sectMap[".plt"]                       = "IPU2_CODE_MEM";
    Program.sectMap[".data"]                      = "IPU2_DATA_MEM";
    Program.sectMap[".bss"]                       = "IPU2_DATA_MEM";
    Program.sectMap[".neardata"]                  = "IPU2_DATA_MEM";
    Program.sectMap[".rodata"]                    = "IPU2_DATA_MEM";
    Program.sectMap[".bss:taskStackSection"]      = "IPU2_DATA_MEM";
    if (ipu_pri == "ipu2")
        xdc.loadCapsule("src/rtos/bios_app_common/tda2px/ipu2/Ipu2_a15_linux.cfg");
    else
        Timer.create(8, '&mainIPU2_TimerTick', timerParams);
    6. vision_sdk/links_fw/src/rtos/bios_app_common/tda2px/ipu2/Ammu2_bios.cfg
     * NOTE:
     *   - System EDMA
     * virtual address's
    function init()
        /* ISS */
        /* ISS */
        /* EVE1 MBOX0 */
        /* EVE1 MBOX1 */
        /* EVE2 MBOX0 */
        /* EVE2 MBOX1 */
    kyungtae
  • Hi Rishabh,
    I refer to your xs file on e2e and make the following changes.
    e2e.ti.com/.../2277707
    So I changed the size value below and confirmed that it boot normally.
    -DDR3_BASE_SIZE_0            = 1024*MB;
    +DDR3_BASE_SIZE_0            = 1008*MB;
    I am glad that your help has solved the problem.
    Thanks.
    kyungtae
    Glad that the issue is resolved.
    Thanks for the confirmation.
    Rishabh
